TDA4VEN-Q1: LPDDR4 adaptation failed
Part Number: TDA4VEN-Q1
Other Parts Discussed in Thread: AM67, SYSCONFIG
Hi TI experts,
We are adapting the new ddr chip(SAMSUNG 4G K4FBE3D4HB-KHCLT2V) on the EVM board,but uboot spl doesn't seem to start properly.
Here are some action we made:
1.Refer to the new DDR parameters and use the DDR generation tool(SysConfig (ti.com)) to generate a new DDR configuration file.
2.Rename the generated file as k3-j722s-ddr-lp4-50-3733.dtsi and replace the original k3-j722s-ddr-lp4-50-3733.dtsi;
3.modify the memory node in k3-j722s-evm.dts as bellow
memory@80000000 {
    /* 8G RAM */
    reg = <0x00000000 0x80000000 0x00000000 0x80000000>,
             <0x00000008 0x80000000 0x00000000 0x80000000>;
    device_type = "memory";
    bootph-pre-ram;
4.rebuild u-boot-r5 and replace tiboot3.bin in sd BOOT partition.
question:
1.The new DDR parameters are as bellow file,please help me to check the parameters are correct or not?
TDA4VEntry DDR Config Tool配置参数.xlsx
2.Why uboot spl boot failed as bellow picture?
upload the generated files(please rename it as settings_info.syscfg when using):
settings_info.syscfg.txt
// @cliArgs --device "J722S_TDA4VEN_TDA4AEN_AM67" --package "AMW" --part "Default" --product "TDA4x_DRA8x_AM67x-AM69x_DDR_Config@0.11.00.0000"
const DDRSS = scripting.addModule("/DDRSS");
DDRSS.system_cfg_soc_number = "AM67x";
DDRSS.system_cfg_ddrss_active = "DDRSS0 Only";
DDRSS.system_cfg_dram_type = "LPDDR4";
DDRSS.system_cfg_msmc_intlv_hybrid = "NA";
DDRSS.system_cfg_msmc_intlv_size = 0;
DDRSS.system_cfg_msmc_intlv_gran = "128 B";
DDRSS.config_fsp0_MHz = 50;
DDRSS.config_fsp1_MHz = 2133;
DDRSS.config_fsp2_MHz = 2133;
DDRSS.lpddr4.config_dram_mr1_rd_pre_FS2 = "Static";
DDRSS.lpddr4.config_dram_mr1_rd_pst_FS2 = "1.5 x tCK";
DDRSS.lpddr4.config_dram_mr3_wr_pst_FS2 = "1.5 x tCK";
DDRSS.lpddr4.config_dram_mr3_dbi_rd_FS2 = "Disable";
DDRSS.lpddr4.config_dram_mr3_dbi_wr_FS2 = "Enable";
DDRSS.lpddr4.config_dram_mr2_rl_FS2 = 32;
DDRSS.lpddr4.config_dram_mr2_wls_FS2 = "WL set A";
DDRSS.lpddr4.config_dram_mr2_wl_FS2 = 16;
DDRSS.lpddr4.config_dram_mr1_nWR_FS2 = 34;
DDRSS.lpddr4.config_dram_odtlon_FS2 = 6;
DDRSS.lpddr4.config_dram_odtloff_FS2 = 26;
DDRSS.lpddr4.config_io_cell_enslicep_drv_dl0_dq = "48 Ohm";
DDRSS.lpddr4.config_io_cell_enslicep_drv_ac = "34.3 Ohm";
DDRSS.lpddr4.config_io_cell_enslicep_drv_cs = "34.3 Ohm";
DDRSS.lpddr4.config_io_cell_enslicep_odt_dl0_dq = "Hi-Z";
DDRSS.lpddr4.config_io_cell_enslicen_odt_dl0_dq = "48 Ohm";
DDRSS.lpddr4.config_dram_mr14_vr_dq_FS2 = "Range 0";
DDRSS.lpddr4.config_dram_mr14_vref_dq_FS2 = 16;
DDRSS.lpddr4.config_dram_mr12_vr_ca_FS2 = "Range 0";
DDRSS.lpddr4.config_dram_mr12_vref_ca_FS2 = 25.6;
DDRSS.lpddr4.config_dram_mr3_pdds_FS2 = "RZQ/5(48ohm)";
DDRSS.lpddr4.config_dram_mr3_pu_cal_FS2 = "VDDQ / 3";
DDRSS.lpddr4.config_dram_mr22_odtd_ca_FS2 = "ODT_CA Bond Pad";
DDRSS.lpddr4.config_dram_mr22_odte_ck_FS2 = "Enable";
DDRSS.lpddr4.config_dram_mr22_odte_cs_FS2 = "Enable";
DDRSS.lpddr4.config_dram_mr11_ca_odt_FS2 = "RZQ/4(60ohm)";
DDRSS.lpddr4.config_dram_mr11_dq_odt_FS2 = "RZQ/5(48ohm)";
DDRSS.lpddr4.config_dram_mr22_soc_odt_FS2 = "RZQ/5(48ohm)";
DDRSS.lpddr4.system_cfg_dram_width = 32;
DDRSS.lpddr4.system_cfg_dram_density = 16;
DDRSS.lpddr4.system_cfg_dram_ranks = 2;
DDRSS.lpddr4.system_cfg_temp_range = "> 85C";
DDRSS.lpddr4.system_cfg_dram_mr4_poll = "No";
DDRSS.lpddr4.system_cfg_sys_temp_grad = 30;
DDRSS.lpddr4.system_cfg_lpm = "No";
DDRSS.lpddr4.system_cfg_fastboot = "No";
DDRSS.lpddr4.system_cfg_periodic_train = "Yes";
DDRSS.lpddr4.config_dram_mr1_bl_FS0 = "16 sequential";
DDRSS.lpddr4.config_dram_mr1_bl_FS1 = "16 sequential";
DDRSS.lpddr4.config_dram_mr1_bl_FS2 = "16 sequential";
DDRSS.lpddr4.config_dram_mr1_rd_pre_FS0 = "Static";
DDRSS.lpddr4.config_dram_mr1_rd_pre_FS1 = "Static";
DDRSS.lpddr4.config_dram_mr1_rd_pst_FS0 = "1.5 x tCK";
DDRSS.lpddr4.config_dram_mr1_rd_pst_FS1 = "1.5 x tCK";
DDRSS.lpddr4.config_dram_mr3_wr_pst_FS0 = "1.5 x tCK";
DDRSS.lpddr4.config_dram_mr3_wr_pst_FS1 = "1.5 x tCK";
DDRSS.lpddr4.config_dram_mr3_dbi_rd_FS0 = "Disable";
DDRSS.lpddr4.config_dram_mr3_dbi_rd_FS1 = "Disable";
DDRSS.lpddr4.config_dram_mr3_dbi_wr_FS0 = "Enable";
DDRSS.lpddr4.config_dram_mr3_dbi_wr_FS1 = "Enable";
DDRSS.lpddr4.config_dram_mr2_rl_FS0 = 6;
DDRSS.lpddr4.config_dram_mr2_wls_FS0 = "WL set A";
DDRSS.lpddr4.config_dram_mr2_wl_FS0 = 4;
DDRSS.lpddr4.config_dram_mr1_nWR_FS0 = 6;
DDRSS.lpddr4.config_dram_odtlon_FS0 = 0;
DDRSS.lpddr4.config_dram_odtloff_FS0 = 0;
DDRSS.lpddr4.config_dram_mr2_rl_FS1 = 32;
DDRSS.lpddr4.config_dram_mr2_wls_FS1 = "WL set A";
DDRSS.lpddr4.config_dram_mr2_wl_FS1 = 16;
DDRSS.lpddr4.config_dram_mr1_nWR_FS1 = 34;
DDRSS.lpddr4.config_dram_odtlon_FS1 = 6;
DDRSS.lpddr4.config_dram_odtloff_FS1 = 26;
DDRSS.lpddr4.config_dram_tINIT1_ns = 200000;
DDRSS.lpddr4.config_dram_tINIT2_ns = 10;
DDRSS.lpddr4.config_dram_tINIT3_ns = 2000000;
DDRSS.lpddr4.config_dram_tINIT4_tCK = 5;
DDRSS.lpddr4.config_dram_tINIT5_ns = 2000;
DDRSS.lpddr4.UNREFERENCED = 100;
DDRSS.lpddr4.config_dram_tREFIab_ns = 3904;
DDRSS.lpddr4.config_dram_tREFIpb_ns = 488;
DDRSS.lpddr4.config_dram_tRFCab_ns = 280;
DDRSS.lpddr4.config_dram_tRFCpb_ns = 140;
DDRSS.lpddr4.config_dram_tVRCG_ENABLE_ns = 200;
DDRSS.lpddr4.config_dram_tVRCG_DISABLE_ns = 100;
DDRSS.lpddr4.config_dram_tOSCO_tCK = 8;
DDRSS.lpddr4.config_dram_tOSCO_ns = 40;
DDRSS.lpddr4.config_dram_tZQCAL_ns = 1000;
DDRSS.lpddr4.config_dram_tZQLAT_tCK = 8;
DDRSS.lpddr4.config_dram_tZQLAT_ns = 30;
DDRSS.lpddr4.config_dram_tZQRESET_tCK = 3;
DDRSS.lpddr4.config_dram_tZQRESET_ns = 50;
DDRSS.lpddr4.config_dram_tFClong_ns = 250;
DDRSS.lpddr4.config_dram_tCKFSPE_tCK = 4;
DDRSS.lpddr4.config_dram_tCKFSPE_ns = 7.5;
DDRSS.lpddr4.config_dram_tCKFSPX_tCK = 4;
DDRSS.lpddr4.config_dram_tCKFSPX_ns = 7.5;
DDRSS.lpddr4.config_dram_tDQSCKmin_ns = 1.5;
DDRSS.lpddr4.config_dram_tDQSCKmax_ns = 3.5;
DDRSS.lpddr4.config_dram_tCKE_tCK = 4;
DDRSS.lpddr4.config_dram_tCKE_ns = 7.5;
DDRSS.lpddr4.config_dram_tCMDCKE_tCK = 3;
DDRSS.lpddr4.config_dram_tCMDCKE_ns = 1.75;
DDRSS.lpddr4.config_dram_tCKELCK_tCK = 5;
DDRSS.lpddr4.config_dram_tCKELCK_ns = 5;
DDRSS.lpddr4.config_dram_tCSCKE_ns = 1.75;
DDRSS.lpddr4.config_dram_tCKELCS_tCK = 5;
DDRSS.lpddr4.config_dram_tCKELCS_ns = 5;
DDRSS.lpddr4.config_dram_tCKCKEH_tCK = 3;
DDRSS.lpddr4.config_dram_tCKCKEH_ns = 1.75;
DDRSS.lpddr4.config_dram_tXP_tCK = 5;
DDRSS.lpddr4.config_dram_tXP_ns = 7.5;
DDRSS.lpddr4.config_dram_tCSCKEH_ns = 1.75;
DDRSS.lpddr4.config_dram_tCKEHCS_tCK = 5;
DDRSS.lpddr4.config_dram_tCKEHCS_ns = 7.5;
DDRSS.lpddr4.config_dram_tMRWCKEL_tCK = 10;
DDRSS.lpddr4.config_dram_tMRWCKEL_ns = 14;
DDRSS.lpddr4.config_dram_tZQCKE_tCK = 3;
DDRSS.lpddr4.config_dram_tZQCKE_ns = 1.75;
DDRSS.lpddr4.config_dram_tMRW_tCK = 10;
DDRSS.lpddr4.config_dram_tMRW_ns = 10;
DDRSS.lpddr4.config_dram_tMRD_tCK = 10;
DDRSS.lpddr4.config_dram_tMRD_ns = 14;
DDRSS.lpddr4.config_dram_tMRR_tCK = 8;
DDRSS.lpddr4.config_dram_tMRRI_tCK = 20;
DDRSS.lpddr4.config_dram_tSDO_tCK = 12;
DDRSS.lpddr4.config_dram_tSDO_ns = 20;
DDRSS.lpddr4.config_dram_tSR_tCK = 3;
DDRSS.lpddr4.config_dram_tSR_ns = 15;
DDRSS.lpddr4.config_dram_tXSR_tCK = 2;
DDRSS.lpddr4.config_dram_tXSR_ns = 287.5;
DDRSS.lpddr4.config_dram_tCCD_tCK = 8;
DDRSS.lpddr4.config_dram_tCCDMW_tCK = 32;
DDRSS.lpddr4.config_dram_tRTP_tCK = 8;
DDRSS.lpddr4.config_dram_tRTP_ns = 7.5;
DDRSS.lpddr4.config_dram_tRCD_tCK = 4;
DDRSS.lpddr4.config_dram_tRCD_ns = 18;
DDRSS.lpddr4.config_dram_tRPpb_tCK = 4;
DDRSS.lpddr4.config_dram_tRPpb_ns = 18;
DDRSS.lpddr4.config_dram_tRPab_tCK = 4;
DDRSS.lpddr4.config_dram_tRPab_ns = 21;
DDRSS.lpddr4.config_dram_tRASmin_tCK = 3;
DDRSS.lpddr4.config_dram_tRASmin_ns = 42;
DDRSS.lpddr4.config_dram_tRASmax_ns = 35136;
DDRSS.lpddr4.config_dram_tWR_tCK = 6;
DDRSS.lpddr4.config_dram_tWR_ns = 18;
DDRSS.lpddr4.config_dram_tWTR_tCK = 8;
DDRSS.lpddr4.config_dram_tWTR_ns = 10;
DDRSS.lpddr4.config_dram_tRRD_tCK = 4;
DDRSS.lpddr4.config_dram_tRRD_ns = 10;
DDRSS.lpddr4.config_dram_tPPD_tCK = 4;
DDRSS.lpddr4.config_dram_tFAW_tCK = 0;
DDRSS.lpddr4.config_dram_tFAW_ns = 40;
DDRSS.lpddr4.config_dram_tESCKE_tCK = 3;
DDRSS.lpddr4.config_dram_tESCKE_ns = 1.75;
DDRSS.lpddr4.config_dram_tDStrain_ns = 2;
DDRSS.lpddr4.config_dram_tADR_ns = 20;
DDRSS.lpddr4.config_dram_tCAENT_ns = 250;
DDRSS.lpddr4.config_dram_tVREFcalong_ns = 250;
DDRSS.lpddr4.config_dram_tVREFcashort_ns = 80;
DDRSS.lpddr4.config_dram_tCKEHDQS_ns = 10;
DDRSS.lpddr4.config_dram_tMRZ_ns = 1.5;
DDRSS.lpddr4.config_dram_tODTonMIN_ns = 1.5;
DDRSS.lpddr4.config_dram_tODTonMAX_ns = 3.5;
DDRSS.lpddr4.config_dram_tODToffMIN_ns = 1.5;
DDRSS.lpddr4.config_dram_tODToffMAX_ns = 3.5;
DDRSS.lpddr4.config_dram_tTSI_ns = 32000000;
DDRSS.lpddr4.config_dram_TempMargin_ns = 2;
DDRSS.lpddr4.config_io_cell_mode_dl0 = "Range 0";
DDRSS.lpddr4.config_io_cell_vrefsel_dl0 = 16.7;
DDRSS.lpddr4.config_io_cell_mode_ac = "Range 0";
DDRSS.lpddr4.config_io_cell_vrefsel_ac = 16.7;
DDRSS.lpddr4.config_io_cell_enslicep_drv_dl0_dqs = "48 Ohm";
DDRSS.lpddr4.config_io_cell_enslicen_drv_dl0_dq = "48 Ohm";
DDRSS.lpddr4.config_io_cell_enslicen_drv_dl0_dqs = "48 Ohm";
DDRSS.lpddr4.config_io_cell_enslicen_drv_ac = "34.3 Ohm";
DDRSS.lpddr4.config_io_cell_enslicen_drv_cs = "34.3 Ohm";
DDRSS.lpddr4.config_io_cell_enslicep_odt_dl0_dqs = "Hi-Z";
DDRSS.lpddr4.config_io_cell_enslicen_odt_dl0_dqs = "48 Ohm";
DDRSS.lpddr4.config_dram_mr14_vr_dq_FS0 = "Range 0";
DDRSS.lpddr4.config_dram_mr14_vr_dq_FS1 = "Range 0";
DDRSS.lpddr4.config_dram_mr14_vref_dq_FS0 = 16;
DDRSS.lpddr4.config_dram_mr14_vref_dq_FS1 = 16;
DDRSS.lpddr4.config_dram_mr12_vr_ca_FS0 = "Range 0";
DDRSS.lpddr4.config_dram_mr12_vr_ca_FS1 = "Range 0";
DDRSS.lpddr4.config_dram_mr12_vref_ca_FS0 = 25.6;
DDRSS.lpddr4.config_dram_mr12_vref_ca_FS1 = 25.6;
DDRSS.lpddr4.config_dram_mr3_pdds_FS0 = "RZQ/5(48ohm)";
DDRSS.lpddr4.config_dram_mr3_pdds_FS1 = "RZQ/5(48ohm)";
DDRSS.lpddr4.config_dram_mr3_pu_cal_FS0 = "VDDQ / 3";
DDRSS.lpddr4.config_dram_mr3_pu_cal_FS1 = "VDDQ / 3";
DDRSS.lpddr4.config_dram_mr22_odtd_ca_FS0 = "ODT_CA Bond Pad";
DDRSS.lpddr4.config_dram_mr22_odtd_ca_FS1 = "ODT_CA Bond Pad";
DDRSS.lpddr4.config_dram_mr22_odte_ck_FS0 = "Enable";
DDRSS.lpddr4.config_dram_mr22_odte_ck_FS1 = "Enable";
DDRSS.lpddr4.config_dram_mr22_odte_cs_FS0 = "Enable";
DDRSS.lpddr4.config_dram_mr22_odte_cs_FS1 = "Enable";
DDRSS.lpddr4.config_dram_mr11_ca_odt_FS0 = "RZQ/4(60ohm)";
DDRSS.lpddr4.config_dram_mr11_ca_odt_FS1 = "RZQ/4(60ohm)";
DDRSS.lpddr4.config_dram_mr11_dq_odt_FS0 = "RZQ/5(48ohm)";
DDRSS.lpddr4.config_dram_mr11_dq_odt_FS1 = "RZQ/5(48ohm)";
DDRSS.lpddr4.config_dram_mr22_soc_odt_FS0 = "RZQ/5(48ohm)";
DDRSS.lpddr4.config_dram_mr22_soc_odt_FS1 = "RZQ/5(48ohm)";
DDRSS.lpddr4.config_dram_byteswap_01 = "No";
DDRSS.lpddr4.config_dram_byteswap_23 = "No";
DDRSS.lpddr4.config_dram_DQ0 = "Memory DQ0";
DDRSS.lpddr4.config_dram_DQ1 = "Memory DQ1";
DDRSS.lpddr4.config_dram_DQ2 = "Memory DQ2";
DDRSS.lpddr4.config_dram_DQ3 = "Memory DQ3";
DDRSS.lpddr4.config_dram_DQ4 = "Memory DQ4";
DDRSS.lpddr4.config_dram_DQ5 = "Memory DQ5";
DDRSS.lpddr4.config_dram_DQ6 = "Memory DQ6";
DDRSS.lpddr4.config_dram_DQ7 = "Memory DQ7";
DDRSS.lpddr4.config_dram_DQ8 = "Memory DQ8";
DDRSS.lpddr4.config_dram_DQ9 = "Memory DQ9";
DDRSS.lpddr4.config_dram_DQ10 = "Memory DQ10";
DDRSS.lpddr4.config_dram_DQ11 = "Memory DQ11";
DDRSS.lpddr4.config_dram_DQ12 = "Memory DQ12";
DDRSS.lpddr4.config_dram_DQ13 = "Memory DQ13";
DDRSS.lpddr4.config_dram_DQ14 = "Memory DQ14";
DDRSS.lpddr4.config_dram_DQ15 = "Memory DQ15";
DDRSS.lpddr4.config_dram_DQ16 = "Memory DQ16";
DDRSS.lpddr4.config_dram_DQ17 = "Memory DQ17";
DDRSS.lpddr4.config_dram_DQ18 = "Memory DQ18";
DDRSS.lpddr4.config_dram_DQ19 = "Memory DQ19";
DDRSS.lpddr4.config_dram_DQ20 = "Memory DQ20";
DDRSS.lpddr4.config_dram_DQ21 = "Memory DQ21";
DDRSS.lpddr4.config_dram_DQ22 = "Memory DQ22";
DDRSS.lpddr4.config_dram_DQ23 = "Memory DQ23";
DDRSS.lpddr4.config_dram_DQ24 = "Memory DQ24";
DDRSS.lpddr4.config_dram_DQ25 = "Memory DQ25";
DDRSS.lpddr4.config_dram_DQ26 = "Memory DQ26";
DDRSS.lpddr4.config_dram_DQ27 = "Memory DQ27";
DDRSS.lpddr4.config_dram_DQ28 = "Memory DQ28";
DDRSS.lpddr4.config_dram_DQ29 = "Memory DQ29";
DDRSS.lpddr4.config_dram_DQ30 = "Memory DQ30";
DDRSS.lpddr4.config_dram_DQ31 = "Memory DQ31";
Regards.
    This seems to be a 32Gbit device, with x32 width. I assume it is dual rank, such that each channel density (per rank) is 8Gb. (if you believe this is not correct, please let me know...as I do not have the datasheet)
    The part used on the TI EVM is dual rank  with x32 width, but channel density (per rank) is 16Gb.
    As a first step, can we try to use the TI default settings in Sysconfig for AM67 as a starting point, and only make modifications to account for density differences between the memory you have selected and the memory on the TI EVM? (please see files below)
    am67_cust_.k4fbe3d4hb_test1.zip
    Kevin
  • Hi Kevin,
    Send the datasheet via email to you.
    BR,
    Biao
  • Hi Kevin,
    Sorry for delay because i am out of office for holiday.
    Yes, I think you are right.
    After I use the TI default settings in Sysconfig for AM67, replace k3-j722s-ddr-lp4-50-3733.dtsi with the file in your attachment in u-boot.The output on the console is as follows.
    Regards.
  • Hi Kevin,
    do you have some debug binary can provide to customer? customer now can boot successfully using 800MHz, but failed in higher frequency, I have tried help change some parameter in config tool, but all can't work. and how to disable the CBT training in TDA4VEN? Customer is using Samsung lpddr, I think this may related to CBT training. pls help priority this, customer have built their custom board, some issue come related ddr even in 800MHz, we need help customer fix it earlier.
    BR
    Biao
  • Hi Biao,
    No, not for this device.
    After initializing DDR, are they able to run some memory test? (write some known data into DDR and then read it back and compare the value)?
    How many boards has the customer built and tried to bring-up? Do they all behave the same?
    Kevin
  • Hi Kevin,
    Thanks for reply, them can run the mem test in 800MHz, but their issue is the board can't boot in higher frequency(1600 or 1866), customer produce serval boards, all have same behavior, customer also have a try to rework the EVM LPDDR4 to samsung LPDDR4, the failure is same as customer board. previously I also suspect the signal integrity in rework EVM, but now custom board have same issue.
    BR,
    Biao
  • Hi Biao,
    Uploading all registers dump value in different ddr data rates.And I will upload the results of memtester testing later.
    regdump_dr_2000_DDRSS_PHY_67_323_579_835_set_0x104.txt
    regdump_dr_3733.txt
    regdump_dr_1400.txt
    Regards.
  • Unlocking this thread.
    Is help still needed here? Were you able to complete the memtester testing?
    Kevin
  • Hi Kevin,
    I will let customer upload the mem tester result soon, can you help review the reg dump? can you see anything abnormal here?
    BR,
    Biao
  • Hi Kevin,
    Sorry for the lack of effective progress on this issue. Below are the results measured by memtester at DDR rate of 800MHz. Please check it.
    Also, may I ask how to obtain the values of all MR registers?
    samsung 4g ddr_data rate 800m_memteste 1g failed.txt
    root@j722s-evm:~# memtester 1G
    memtester version 4.6.0 (64-bit)
    Copyright (C) 2001-2020 Charles Cazabon.
    Licensed under the GNU General Public License version 2 (only).
    pagesize is 4096
    pagesizemask is 0xfffffffffffff000
    want 1024MB (1073741824 bytes)
    got  1024MB (1073741824 bytes), trying mlock ...locked.
    Loop 1:
      Stuck Address       : ok
      Random Value        : FAILURE: 0x3bcb0000bfefa7ff != 0x3bcbbcbabfef8904 at offset 0x0000000016105800.
    FAILURE: 0x3f7effff46665808 != 0x3f7ec84a46668ddf at offset 0x0000000016105808.
    FAILURE: 0x7ffb00007bf3a7ef != 0x7ffb2bd47bf33fcd at offset 0x0000000016105810.
    FAILURE: 0xefdfffff4ef95818 != 0xefdf577a4ef9c268 at offset 0x0000000016105818.
    FAILURE: 0x7fbb0000e6eda7df != 0x7fbba644e6ed56d9 at offset 0x0000000016105820.
    FAILURE: 0x5f6fffffff7e5828 != 0x5f6f667aff7e780e at offset 0x0000000016105828.
    FAILURE: 0x77ff0000afbfa7cf != 0x77ffba20afbf13d9 at offset 0x0000000016105830.
    FAILURE: 0x79f3ffff47765838 != 0x79f345bc4776b6dd at offset 0x0000000016105838.
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Sequential Increment: ok
      Solid Bits          : testing  17FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62000.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62008.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62010.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62018.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62020.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62028.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62030.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62038.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62040.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62048.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62050.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62058.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62060.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62068.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62070.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62078.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62080.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62088.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62090.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62098.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb620a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb620a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb620b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb620b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb620c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb620c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb620d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb620d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb620e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb620e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb620f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb620f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62100.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62108.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62110.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62118.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62120.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62128.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62130.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62138.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62140.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62148.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62150.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62158.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62160.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62168.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62170.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62178.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62180.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62188.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62190.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62198.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb621a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb621a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb621b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb621b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb621c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb621c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb621d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb621d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb621e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb621e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb621f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb621f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62200.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62208.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62210.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62218.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62220.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62228.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62230.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62238.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62240.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62248.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62250.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62258.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62260.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62268.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62270.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62278.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62280.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62288.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62290.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62298.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb622a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb622a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb622b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb622b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb622c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb622c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb622d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb622d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb622e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb622e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb622f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb622f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62300.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62308.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62310.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62318.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62320.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62328.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62330.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62338.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62340.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62348.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62350.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62358.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62360.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62368.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62370.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62378.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62380.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62388.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62390.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62398.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb623a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb623a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb623b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb623b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb623c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb623c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb623d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb623d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb623e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb623e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb623f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb623f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62400.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62408.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62410.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62418.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62420.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62428.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62430.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62438.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62440.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62448.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62450.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62458.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62460.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62468.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62470.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62478.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62480.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62488.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62490.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62498.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb624a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb624a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb624b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb624b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb624c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb624c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb624d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb624d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb624e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb624e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb624f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb624f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62500.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62508.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62510.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62518.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62520.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62528.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62530.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62538.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62540.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62548.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62550.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62558.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62560.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62568.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62570.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62578.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62580.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62588.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62590.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62598.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb625a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb625a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb625b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb625b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb625c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb625c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb625d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb625d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb625e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb625e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb625f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb625f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62600.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62608.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62610.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62618.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62620.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62628.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62630.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62638.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62640.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62648.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62650.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62658.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62660.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62668.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62670.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62678.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62680.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62688.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62690.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62698.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb626a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb626a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb626b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb626b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb626c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb626c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb626d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb626d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb626e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb626e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb626f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb626f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62700.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62708.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62710.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62718.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62720.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62728.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62730.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62738.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62740.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62748.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62750.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62758.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62760.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62768.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62770.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62778.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62780.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62788.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62790.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62798.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb627a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb627a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb627b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb627b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb627c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb627c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb627d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb627d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb627e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb627e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb627f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb627f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62800.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62808.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62810.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62818.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62820.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62828.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62830.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62838.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62840.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62848.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62850.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62858.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62860.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62868.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62870.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62878.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62880.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62888.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62890.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62898.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb628a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb628a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb628b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb628b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb628c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb628c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb628d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb628d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb628e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb628e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb628f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb628f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62900.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62908.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62910.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62918.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62920.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62928.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62930.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62938.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62940.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62948.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62950.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62958.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62960.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62968.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62970.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62978.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62980.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62988.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62990.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62998.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb629a0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb629a8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb629b0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb629b8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb629c0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb629c8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb629d0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb629d8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb629e0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb629e8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb629f0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb629f8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a00.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a08.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a10.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a18.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a20.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a28.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a30.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a38.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a40.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a48.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a50.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a58.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a60.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a68.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a70.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a78.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a80.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a88.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62a90.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62a98.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62aa0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62aa8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ab0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ab8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ac0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ac8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ad0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ad8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ae0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ae8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62af0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62af8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b00.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b08.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b10.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b18.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b20.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b28.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b30.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b38.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b40.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b48.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b50.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b58.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b60.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b68.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b70.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b78.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b80.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b88.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62b90.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62b98.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ba0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ba8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62bb0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62bb8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62bc0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62bc8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62bd0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62bd8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62be0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62be8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62bf0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62bf8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c00.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c08.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c10.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c18.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c20.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c28.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c30.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c38.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c40.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c48.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c50.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c58.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c60.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c68.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c70.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c78.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c80.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c88.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62c90.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62c98.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ca0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ca8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62cb0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62cb8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62cc0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62cc8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62cd0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62cd8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ce0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ce8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62cf0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62cf8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d00.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d08.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d10.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d18.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d20.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d28.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d30.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d38.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d40.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d48.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d50.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d58.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d60.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d68.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d70.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d78.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d80.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d88.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62d90.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62d98.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62da0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62da8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62db0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62db8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62dc0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62dc8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62dd0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62dd8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62de0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62de8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62df0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62df8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e00.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e08.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e10.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e18.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e20.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e28.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e30.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e38.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e40.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e48.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e50.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e58.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e60.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e68.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e70.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e78.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e80.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e88.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62e90.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62e98.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ea0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ea8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62eb0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62eb8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ec0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ec8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ed0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ed8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ee0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ee8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ef0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ef8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f00.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f08.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f10.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f18.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f20.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f28.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f30.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f38.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f40.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f48.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f50.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f58.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f60.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f68.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f70.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f78.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f80.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f88.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62f90.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62f98.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62fa0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62fa8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62fb0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62fb8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62fc0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62fc8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62fd0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62fd8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62fe0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62fe8.
    FAILURE: 0x0000ffff0000ffff != 0x0000000000000000 at offset 0x000000001bb62ff0.
    FAILURE: 0xffff0000ffff0000 != 0xffffffffffffffff at offset 0x000000001bb62ff8.
      Block Sequential    : ok
      Checkerboard        : testing  25
    Regards.
    Thanks for the update - looks like lower half of DQ bus is becoming corrupted. Possibly could be due to CA/CS timing.
    Will follow-up with some additional debug steps.
    Kevin
