TDA4VH-Q1: TDA4VH: About the pcie2
Part Number: TDA4VH-Q1
Other Parts Discussed in Thread: TDA4VH
Platform:TDA4VH J784s4-evm
SDK:ti-processor-sdk-linux-adas-j784s4-evm-09_01_00_06
    Only pcie0, pcie1, and pcie3 are described in k3-j784s4-main.dtsi on the TDA4VH. We did not find the description of pcie2. If pcie2 is supported. If yes, can you provide device tree description of pcie2_rc and pcie2_ep.
  • Hi Chen,
    We added the node to device tree starting PSDK 10.0. Please reference the newest device tree file: https://git.ti.com/cgit/ti-linux-kernel/ti-linux-kernel/tree/arch/arm64/boot/dts/ti/k3-j784s4-main.dtsi?h=ti-linux-6.6.y#n1216
    Additionally, linking patch that can also be referenced alongside dtsi file above when porting back to 9.1 SDK: https://patchwork.kernel.org/project/linux-arm-kernel/patch/20240529082259.1619695-2-s-vadapalli@ti.com/
    Takuma
      What about "pcies_ep"? and this patch looks differernt from 9.1. Please check about our "k3-j784s4.dtsi" and "k3-j784s4-main.dtsi".
    k3-j784s4.dtsi
    // SPDX-License-Identifier: GPL-2.0
     * Device Tree Source for J784S4 SoC Family
     * TRM (SPRUJ43 JULY 2022) : http://www.ti.com/lit/zip/spruj52
     * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/
    #include <dt-bindings/interrupt-controller/irq.h>
    #include <dt-bindings/interrupt-controller/arm-gic.h>
    #include <dt-bindings/soc/ti,sci_pm_domain.h>
    #include "k3-pinctrl.h"
    	model = "Texas Instruments K3 J784S4 SoC";
    	compatible = "ti,j784s4";
    	interrupt-parent = <&gic500>;
    	#address-cells = <2>;
    	#size-cells = <2>;
    	cpus {
    		#address-cells = <1>;
    		#size-cells = <0>;
    		cpu-map {
    			cluster0: cluster0 {
    				core0 {
    					cpu = <&cpu0>;
    				core1 {
    					cpu = <&cpu1>;
    				core2 {
    					cpu = <&cpu2>;
    				core3 {
    					cpu = <&cpu3>;
    			cluster1: cluster1 {
    				core0 {
    					cpu = <&cpu4>;
    				core1 {
    					cpu = <&cpu5>;
    				core2 {
    					cpu = <&cpu6>;
    				core3 {
    					cpu = <&cpu7>;
    		cpu0: cpu@0 {
    			compatible = "arm,cortex-a72";
    			reg = <0x000>;
    			device_type = "cpu";
    			enable-method = "psci";
    			i-cache-size = <0xc000>;
    			i-cache-line-size = <64>;
    			i-cache-sets = <256>;
    			d-cache-size = <0x8000>;
    			d-cache-line-size = <64>;
    			d-cache-sets = <256>;
    			next-level-cache = <&L2_0>;
    		cpu1: cpu@1 {
    			reg = <0x001>;
    		cpu2: cpu@2 {
    			reg = <0x002>;
    		cpu3: cpu@3 {
    			reg = <0x003>;
    		cpu4: cpu@100 {
    			reg = <0x100>;
    			next-level-cache = <&L2_1>;
    		cpu5: cpu@101 {
    			reg = <0x101>;
    		cpu6: cpu@102 {
    			reg = <0x102>;
    		cpu7: cpu@103 {
    			reg = <0x103>;
    	L2_0: l2-cache0 {
    		compatible = "cache";
    		cache-level = <2>;
    		cache-unified;
    		cache-size = <0x200000>;
    		cache-sets = <1024>;
    		next-level-cache = <&msmc_l3>;
    	L2_1: l2-cache1 {
    		cache-level = <2>;
    		cache-unified;
    	msmc_l3: l3-cache0 {
    		cache-level = <3>;
    		cache-unified;
    	firmware {
    		optee {
    			compatible = "linaro,optee-tz";
    			method = "smc";
    		psci: psci {
    			compatible = "arm,psci-1.0";
    			method = "smc";
    	a72_timer0: timer-cl0-cpu0 {
    		compatible = "arm,armv8-timer";
    		interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */
    			     <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */
    			     <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */
    			     <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */
    	pmu: pmu {
    		compatible = "arm,cortex-a72-pmu";
    		/* Recommendation from GIC500 TRM Table A.3 */
    		interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>;
    	cbass_main: bus@100000 {
    		compatible = "simple-bus";
    		#size-cells = <2>;
    		ranges = <0x00 0x00100000 0x00 0x00100000 0x00 0x00020000>, /* ctrl mmr */
    			 <0x00 0x00600000 0x00 0x00600000 0x00 0x00031100>, /* GPIO */
    			 <0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* Time Sync Router */
    			 <0x00 0x01000000 0x00 0x01000000 0x00 0x0d000000>, /* Most peripherals */
    			 <0x00 0x0d000000 0x00 0x0d000000 0x00 0x01000000>, /* PCIe1 Core*/
    			 <0x00 0x0e800000 0x00 0x0e800000 0x00 0x01000000>, /* PCIe3 Core*/
    			 <0x00 0x10000000 0x00 0x10000000 0x00 0x08000000>, /* PCIe0 DAT0 */
    			 <0x00 0x18000000 0x00 0x18000000 0x00 0x08000000>, /* PCIe1 DAT0 */
    			 <0x44 0x00000000 0x44 0x00000000 0x00 0x08000000>, /* PCIe2 DAT0 */
    			 <0x44 0x10000000 0x44 0x10000000 0x00 0x08000000>, /* PCIe3 DAT0 */
    			 <0x00 0x64800000 0x00 0x64800000 0x00 0x0070c000>, /* C71_1 */
    			 <0x00 0x65800000 0x00 0x65800000 0x00 0x0070c000>, /* C71_2 */
    			 <0x00 0x66800000 0x00 0x66800000 0x00 0x0070c000>, /* C71_3 */
    			 <0x00 0x67800000 0x00 0x67800000 0x00 0x0070c000>, /* C71_4 */
    			 <0x00 0x6f000000 0x00 0x6f000000 0x00 0x00310000>, /* A72 PERIPHBASE */
    			 <0x00 0x70000000 0x00 0x70000000 0x00 0x00400000>, /* MSMC RAM */
    			 <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>, /* MAIN NAVSS */
    			 <0x41 0x00000000 0x41 0x00000000 0x01 0x00000000>, /* PCIe1 DAT1 */
    			 <0x43 0x00000000 0x43 0x00000000 0x01 0x00000000>, /* PCIe3 DAT1 */
    			 <0x4e 0x20000000 0x4e 0x20000000 0x00 0x00080000>, /* GPU */
    			 /* MCUSS_WKUP Range */
    			 <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>,
    			 <0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>,
    			 <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>,
    			 <0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>,
    			 <0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>,
    			 <0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>,
    			 <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>,
    			 <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>,
    			 <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>,
    			 <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>,
    			 <0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>,
    			 <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>,
    			 <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>;
    		cbass_mcu_wakeup: bus@28380000 {
    			#size-cells = <2>;
    			ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>, /* MCU NAVSS*/
    				 <0x00 0x40200000 0x00 0x40200000 0x00 0x00998400>, /* First peripheral window */
    				 <0x00 0x40f00000 0x00 0x40f00000 0x00 0x00020000>, /* CTRL_MMR0 */
    				 <0x00 0x41000000 0x00 0x41000000 0x00 0x00020000>, /* MCU R5F Core0 */
    				 <0x00 0x41400000 0x00 0x41400000 0x00 0x00020000>, /* MCU R5F Core1 */
    				 <0x00 0x41c00000 0x00 0x41c00000 0x00 0x00100000>, /* MCU SRAM */
    				 <0x00 0x42040000 0x00 0x42040000 0x00 0x03ac2400>, /* WKUP peripheral window */
    				 <0x00 0x45100000 0x00 0x45100000 0x00 0x00c24000>, /* MMRs, remaining NAVSS */
    				 <0x00 0x46000000 0x00 0x46000000 0x00 0x00200000>, /* CPSW */
    				 <0x00 0x47000000 0x00 0x47000000 0x00 0x00068400>, /* OSPI register space */
    				 <0x00 0x50000000 0x00 0x50000000 0x00 0x10000000>, /* FSS OSPI0/1 data region 0 */
    				 <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS OSPI0 data region 3 */
    				 <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; /* FSS OSPI1 data region 3*/
    	thermal_zones: thermal-zones {
    		#include "k3-j784s4-thermal.dtsi"
    /* Now include peripherals from each bus segment */
    #include "k3-j784s4-main.dtsi"
    #include "k3-j784s4-mcu-wakeup.dtsi"
    k3-j784s4-main.dtsi
     * Device Tree Source for J784S4 SoC Family Main Domain peripherals
    #include <dt-bindings/mux/mux.h>
    #include <dt-bindings/mux/ti-serdes.h>
    #include <dt-bindings/phy/phy.h>
    #include <dt-bindings/phy/phy-ti.h>
    	serdes_refclk: serdes-refclk {
    		#clock-cells = <0>;
    		compatible = "fixed-clock";
    &cbass_main {
    	msmc_ram: sram@70000000 {
    		compatible = "mmio-sram";
    		reg = <0x00 0x70000000 0x00 0x800000>;
    		#size-cells = <1>;
    		ranges = <0x00 0x00 0x70000000 0x800000>;
    		atf-sram@0 {
    			reg = <0x00 0x20000>;
    		tifs-sram@1f0000 {
    			reg = <0x1f0000 0x10000>;
    		l3cache-sram@200000 {
    			reg = <0x200000 0x200000>;
    	scm_conf: syscon@100000 {
    		compatible = "ti,j721e-system-controller", "syscon", "simple-mfd";
    		reg = <0x00 0x00100000 0x00 0x1c000>;
    		#size-cells = <1>;
    		ranges = <0x00 0x00 0x00100000 0x1c000>;
    		cpsw1_phy_gmii_sel: phy@4034 {
    			compatible = "ti,am654-phy-gmii-sel";
    			reg = <0x4034 0x4>;
    			#phy-cells = <1>;
    		cpsw0_phy_gmii_sel: phy@4044 {
    			compatible = "ti,j784s4-cpsw9g-phy-gmii-sel";
    			ti,qsgmii-main-ports = <7>, <7>;
    			reg = <0x4044 0x20>;
    			#phy-cells = <1>;
    		serdes_ln_ctrl: mux-controller@4080 {
    			compatible = "mmio-mux";
    			reg = <0x00004080 0x30>;
    			#mux-control-cells = <1>;
    			mux-reg-masks = <0x4080 0x3>, <0x4084 0x3>, /* SERDES0 lane0/1 select */
    					<0x4088 0x3>, <0x408c 0x3>, /* SERDES0 lane2/3 select */
    					<0x4090 0x3>, <0x4094 0x3>, /* SERDES1 lane0/1 select */
    					<0x4098 0x3>, <0x409c 0x3>, /* SERDES1 lane2/3 select */
    					<0x40a0 0x3>, <0x40a4 0x3>, /* SERDES2 lane0/1 select */
    					<0x40a8 0x3>, <0x40ac 0x3>; /* SERDES2 lane2/3 select */
    		usb_serdes_mux: mux-controller@4000 {
    			reg = <0x4000 0x4>;
    			mux-reg-masks = <0x4000 0x8000000>; /* USB0 to SERDES0 lane 3 mux */
    		ehrpwm_tbclk: clock-controller@4140 {
    			compatible = "ti,am654-ehrpwm-tbclk", "syscon";
    			reg = <0x4140 0x18>;
    			#clock-cells = <1>;
    	main_ehrpwm0: pwm@3000000 {
    		compatible = "ti,am654-ehrpwm", "ti,am3352-ehrpwm";
    		#pwm-cells = <3>;
    		reg = <0x00 0x3000000 0x00 0x100>;
    		power-domains = <&k3_pds 219 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&ehrpwm_tbclk 0>, <&k3_clks 219 0>;
    		clock-names = "tbclk", "fck";
    		status = "disabled";
    	main_ehrpwm1: pwm@3010000 {
    		#pwm-cells = <3>;
    		reg = <0x00 0x3010000 0x00 0x100>;
    		power-domains = <&k3_pds 220 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&ehrpwm_tbclk 1>, <&k3_clks 220 0>;
    	main_ehrpwm2: pwm@3020000 {
    		#pwm-cells = <3>;
    		reg = <0x00 0x3020000 0x00 0x100>;
    		power-domains = <&k3_pds 221 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&ehrpwm_tbclk 2>, <&k3_clks 221 0>;
    	main_ehrpwm3: pwm@3030000 {
    		#pwm-cells = <3>;
    		reg = <0x00 0x3030000 0x00 0x100>;
    		power-domains = <&k3_pds 222 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&ehrpwm_tbclk 3>, <&k3_clks 222 0>;
    	main_ehrpwm4: pwm@3040000 {
    		#pwm-cells = <3>;
    		reg = <0x00 0x3040000 0x00 0x100>;
    		power-domains = <&k3_pds 223 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&ehrpwm_tbclk 4>, <&k3_clks 223 0>;
    	main_ehrpwm5: pwm@3050000 {
    		#pwm-cells = <3>;
    		reg = <0x00 0x3050000 0x00 0x100>;
    		power-domains = <&k3_pds 224 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&ehrpwm_tbclk 5>, <&k3_clks 224 0>;
    	gic500: interrupt-controller@1800000 {
    		compatible = "arm,gic-v3";
    		#size-cells = <2>;
    		ranges;
    		#interrupt-cells = <3>;
    		interrupt-controller;
    		reg = <0x00 0x01800000 0x00 0x200000>, /* GICD */
    		      <0x00 0x01900000 0x00 0x100000>, /* GICR */
    		      <0x00 0x6f000000 0x00 0x2000>,   /* GICC */
    		      <0x00 0x6f010000 0x00 0x1000>,   /* GICH */
    		      <0x00 0x6f020000 0x00 0x2000>;   /* GICV */
    		/* vcpumntirq: virtual CPU interface maintenance interrupt */
    		interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>;
    		gic_its: msi-controller@1820000 {
    			compatible = "arm,gic-v3-its";
    			reg = <0x00 0x01820000 0x00 0x10000>;
    			socionext,synquacer-pre-its = <0x1000000 0x400000>;
    			msi-controller;
    			#msi-cells = <1>;
    	main_gpio_intr: interrupt-controller@a00000 {
    		compatible = "ti,sci-intr";
    		reg = <0x00 0x00a00000 0x00 0x800>;
    		ti,intr-trigger-type = <1>;
    		#interrupt-cells = <1>;
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <10>;
    		ti,interrupt-ranges = <8 392 56>;
    	main_pmx0: pinctrl@11c000 {
    		compatible = "pinctrl-single";
    		/* Proxy 0 addressing */
    		reg = <0x00 0x11c000 0x00 0x120>;
    		#pinctrl-cells = <1>;
    		pinctrl-single,register-width = <32>;
    		pinctrl-single,function-mask = <0xffffffff>;
    	main_crypto: crypto@4e00000 {
    		compatible = "ti,j721e-sa2ul";
    		reg = <0x00 0x4e00000 0x00 0x1200>;
    		power-domains = <&k3_pds 369 TI_SCI_PD_EXCLUSIVE>;
    		#size-cells = <2>;
    		ranges = <0x00 0x04e00000 0x00 0x04e00000 0x00 0x30000>;
    		dmas = <&main_udmap 0xca40>, <&main_udmap 0x4a40>,
    				<&main_udmap 0x4a41>;
    		dma-names = "tx", "rx1", "rx2";
    		rng: rng@4e10000 {
    			compatible = "inside-secure,safexcel-eip76";
    			reg = <0x00 0x4e10000 0x00 0x7d>;
    			interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
    	main_uart0: serial@2800000 {
    		compatible = "ti,j721e-uart", "ti,am654-uart";
    		reg = <0x00 0x02800000 0x00 0x200>;
    		interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>;
    		current-speed = <115200>;
    		clocks = <&k3_clks 146 0>;
    		clock-names = "fclk";
    		power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>;
    	main_uart1: serial@2810000 {
    		reg = <0x00 0x02810000 0x00 0x200>;
    		interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 388 0>;
    		power-domains = <&k3_pds 388 TI_SCI_PD_EXCLUSIVE>;
    	main_uart2: serial@2820000 {
    		reg = <0x00 0x02820000 0x00 0x200>;
    		interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 389 0>;
    		power-domains = <&k3_pds 389 TI_SCI_PD_EXCLUSIVE>;
    	main_uart3: serial@2830000 {
    		reg = <0x00 0x02830000 0x00 0x200>;
    		interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 390 0>;
    		power-domains = <&k3_pds 390 TI_SCI_PD_EXCLUSIVE>;
    	main_uart4: serial@2840000 {
    		reg = <0x00 0x02840000 0x00 0x200>;
    		interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 391 0>;
    		power-domains = <&k3_pds 391 TI_SCI_PD_EXCLUSIVE>;
    	main_uart5: serial@2850000 {
    		reg = <0x00 0x02850000 0x00 0x200>;
    		interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 392 0>;
    		power-domains = <&k3_pds 392 TI_SCI_PD_EXCLUSIVE>;
    	main_uart6: serial@2860000 {
    		reg = <0x00 0x02860000 0x00 0x200>;
    		interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 393 0>;
    		power-domains = <&k3_pds 393 TI_SCI_PD_EXCLUSIVE>;
    	main_uart7: serial@2870000 {
    		reg = <0x00 0x02870000 0x00 0x200>;
    		interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 394 0>;
    		power-domains = <&k3_pds 394 TI_SCI_PD_EXCLUSIVE>;
    	main_uart8: serial@2880000 {
    		reg = <0x00 0x02880000 0x00 0x200>;
    		interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 395 0>;
    		power-domains = <&k3_pds 395 TI_SCI_PD_EXCLUSIVE>;
    	main_uart9: serial@2890000 {
    		reg = <0x00 0x02890000 0x00 0x200>;
    		interrupts = <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 396 0>;
    		power-domains = <&k3_pds 396 TI_SCI_PD_EXCLUSIVE>;
    	gpu: gpu@4e20000000 {
    		compatible = "ti,j721s2-pvr", "img,pvr-bxs64";
    		reg = <0x4e 0x20000000 0x00 0x80000>;
    		interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
    		power-domains = <&k3_pds 182 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 181 1>;
    	main_gpio0: gpio@600000 {
    		compatible = "ti,j721e-gpio", "ti,keystone-gpio";
    		reg = <0x00 0x00600000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupt-parent = <&main_gpio_intr>;
    		interrupts = <145>, <146>, <147>, <148>, <149>;
    		#interrupt-cells = <2>;
    		ti,ngpio = <66>;
    		ti,davinci-gpio-unbanked = <0>;
    		power-domains = <&k3_pds 163 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 163 0>;
    		clock-names = "gpio";
    	main_gpio2: gpio@610000 {
    		reg = <0x00 0x00610000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupts = <154>, <155>, <156>, <157>, <158>;
    		ti,ngpio = <66>;
    		power-domains = <&k3_pds 164 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 164 0>;
    	main_gpio4: gpio@620000 {
    		reg = <0x00 0x00620000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupts = <163>, <164>, <165>, <166>, <167>;
    		ti,ngpio = <66>;
    		power-domains = <&k3_pds 165 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 165 0>;
    	main_gpio6: gpio@630000 {
    		reg = <0x00 0x00630000 0x00 0x100>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupts = <172>, <173>, <174>, <175>, <176>;
    		ti,ngpio = <66>;
    		power-domains = <&k3_pds 166 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 166 0>;
    	usbss0: cdns-usb@4104000 {
    		compatible = "ti,j721e-usb";
    		reg = <0x00 0x4104000 0x00 0x100>;
    		dma-coherent;
    		power-domains = <&k3_pds 398 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 398 21>, <&k3_clks 398 2>;
    		clock-names = "ref", "lpm";
    		assigned-clocks = <&k3_clks 398 21>;    /* USB2_REFCLK */
    		assigned-clock-parents = <&k3_clks 398 22>; /* HFOSC0 */
    		#size-cells = <2>;
    		ranges;
    		usb0: usb@6000000 {
    			compatible = "cdns,usb3";
    			reg = <0x00 0x6000000 0x00 0x10000>,
    			      <0x00 0x6010000 0x00 0x10000>,
    			      <0x00 0x6020000 0x00 0x10000>;
    			reg-names = "otg", "xhci", "dev";
    			interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>,  /* irq.0 */
    				     <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, /* irq.6 */
    				     <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; /* otgirq.0 */
    			interrupt-names = "host",
    					  "peripheral",
    					  "otg";
    	main_i2c0: i2c@2000000 {
    		compatible = "ti,j721e-i2c", "ti,omap4-i2c";
    		reg = <0x00 0x02000000 0x00 0x100>;
    		interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 270 2>;
    		clock-names = "fck";
    		power-domains = <&k3_pds 270 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c1: i2c@2010000 {
    		reg = <0x00 0x02010000 0x00 0x100>;
    		interrupts = <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 271 2>;
    		power-domains = <&k3_pds 271 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c2: i2c@2020000 {
    		reg = <0x00 0x02020000 0x00 0x100>;
    		interrupts = <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 272 2>;
    		power-domains = <&k3_pds 272 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c3: i2c@2030000 {
    		reg = <0x00 0x02030000 0x00 0x100>;
    		interrupts = <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 273 2>;
    		power-domains = <&k3_pds 273 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c4: i2c@2040000 {
    		reg = <0x00 0x02040000 0x00 0x100>;
    		interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 274 2>;
    		power-domains = <&k3_pds 274 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c5: i2c@2050000 {
    		reg = <0x00 0x02050000 0x00 0x100>;
    		interrupts = <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 275 2>;
    		power-domains = <&k3_pds 275 TI_SCI_PD_EXCLUSIVE>;
    	main_i2c6: i2c@2060000 {
    		reg = <0x00 0x02060000 0x00 0x100>;
    		interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		clocks = <&k3_clks 276 2>;
    		power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>;
        vpu0: video-codec@4210000 {
    		compatible = "cnm,cm521c-vpu";
    		reg = <0x00 0x4210000 0x00 0x10000>;
    		interrupts = <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 241 2>;
    		clock-names = "vcodec";
    		power-domains = <&k3_pds 241 TI_SCI_PD_EXCLUSIVE>;
    		sram = <&main_navss_sram>;
    		sram-size = <0x10000>;
    		operating-points-v2 = <&vpu_opp_table_0>;
    		vpu_opp_table_0: opp-table {
    			compatible = "operating-points-v2";
    			opp-20000000 {
    				opp-hz = /bits/ 64 <20000000>;
    			opp-100000000 {
    				opp-hz = /bits/ 64 <100000000>;
    			opp-200000000 {
    				opp-hz = /bits/ 64 <200000000>;
    			opp-400000000 {
    				opp-hz = /bits/ 64 <400000000>;
    			opp-600000000 {
    				opp-hz = /bits/ 64 <600000000>;
        vpu1: video-codec@4220000 {
    		reg = <0x00 0x4220000 0x00 0x10000>;
    		interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>;
    		clocks = <&k3_clks 242 2>;
    		power-domains = <&k3_pds 242 TI_SCI_PD_EXCLUSIVE>;
    		operating-points-v2 = <&vpu_opp_table_1>;
    		vpu_opp_table_1: opp-table {
    			opp-20000000 {
    			opp-100000000 {
    			opp-200000000 {
    			opp-400000000 {
    			opp-500000000 {
    	main_sdhci0: mmc@4f80000 {
    		compatible = "ti,j721e-sdhci-8bit";
    		reg = <0x00 0x04f80000 0x00 0x1000>,
    		      <0x00 0x04f88000 0x00 0x400>;
    		interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
    		power-domains = <&k3_pds 140 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 140 1>, <&k3_clks 140 2>;
    		clock-names =  "clk_ahb", "clk_xin";
    		assigned-clocks = <&k3_clks 140 2>;
    		assigned-clock-parents = <&k3_clks 140 3>;
    		bus-width = <8>;
    		ti,otap-del-sel-legacy = <0x0>;
    		ti,otap-del-sel-mmc-hs = <0x0>;
    		ti,otap-del-sel-ddr52 = <0x6>;
    		ti,otap-del-sel-hs200 = <0x8>;
    		ti,otap-del-sel-hs400 = <0x5>;
    		ti,itap-del-sel-legacy = <0x10>;
    		ti,itap-del-sel-mmc-hs = <0xa>;
    		ti,strobe-sel = <0x77>;
    		ti,clkbuf-sel = <0x7>;
    		ti,trm-icp = <0x8>;
    		mmc-ddr-1_8v;
    		mmc-hs200-1_8v;
    		mmc-hs400-1_8v;
    		dma-coherent;
    	main_sdhci1: mmc@4fb0000 {
    		compatible = "ti,j721e-sdhci-4bit";
    		reg = <0x00 0x04fb0000 0x00 0x1000>,
    		      <0x00 0x04fb8000 0x00 0x400>;
    		interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
    		power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 141 3>, <&k3_clks 141 4>;
    		assigned-clocks = <&k3_clks 141 4>;
    		assigned-clock-parents = <&k3_clks 141 5>;
    		bus-width = <4>;
    		ti,otap-del-sel-sd-hs = <0x0>;
    		ti,otap-del-sel-sdr12 = <0xf>;
    		ti,otap-del-sel-sdr25 = <0xf>;
    		ti,otap-del-sel-sdr50 = <0xc>;
    		ti,otap-del-sel-sdr104 = <0x5>;
    		ti,otap-del-sel-ddr50 = <0xc>;
    		ti,itap-del-sel-legacy = <0x0>;
    		ti,itap-del-sel-sd-hs = <0x0>;
    		ti,itap-del-sel-sdr12 = <0x0>;
    		ti,itap-del-sel-sdr25 = <0x0>;
    		ti,trm-icp = <0x8>;
    		dma-coherent;
    	serdes_wiz0: wiz@5060000 {
    		compatible = "ti,j784s4-wiz-10g";
    		#size-cells = <1>;
    		power-domains = <&k3_pds 404 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 404 2>, <&k3_clks 404 6>, <&serdes_refclk>, <&k3_clks 404 5>;
    		clock-names = "fck", "core_ref_clk", "ext_ref_clk", "core_ref1_clk";
    		assigned-clocks = <&k3_clks 404 6>;
    		assigned-clock-parents = <&k3_clks 404 10>;
    		num-lanes = <4>;
    		#reset-cells = <1>;
    		#clock-cells = <1>;
    		ranges = <0x5060000 0x00 0x5060000 0x10000>;
    		serdes0: serdes@5060000 {
    			compatible = "ti,j721e-serdes-10g";
    			reg = <0x05060000 0x010000>;
    			reg-names = "torrent_phy";
    			resets = <&serdes_wiz0 0>;
    			reset-names = "torrent_reset";
    			clocks = <&serdes_wiz0 TI_WIZ_PLL0_REFCLK>,
    				 <&serdes_wiz0 TI_WIZ_PHY_EN_REFCLK>;
    			clock-names = "refclk", "phy_en_refclk";
    			assigned-clocks = <&serdes_wiz0 TI_WIZ_PLL0_REFCLK>,
    					  <&serdes_wiz0 TI_WIZ_PLL1_REFCLK>,
    					  <&serdes_wiz0 TI_WIZ_REFCLK_DIG>;
    			assigned-clock-parents = <&k3_clks 404 6>,
    						 <&k3_clks 404 6>,
    						 <&k3_clks 404 6>;
    			#size-cells = <0>;
    			#clock-cells = <1>;
    	serdes_wiz1: wiz@5070000 {
    		#size-cells = <1>;
    		power-domains = <&k3_pds 405 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 405 2>, <&k3_clks 405 6>, <&serdes_refclk>, <&k3_clks 405 5>;
    		assigned-clocks = <&k3_clks 405 6>;
    		assigned-clock-parents = <&k3_clks 405 10>;
    		num-lanes = <4>;
    		#reset-cells = <1>;
    		#clock-cells = <1>;
    		ranges = <0x05070000 0x00 0x05070000 0x10000>;
    		serdes1: serdes@5070000 {
    			reg = <0x05070000 0x010000>;
    			resets = <&serdes_wiz1 0>;
    			clocks = <&serdes_wiz1 TI_WIZ_PLL0_REFCLK>,
    				 <&serdes_wiz1 TI_WIZ_PHY_EN_REFCLK>;
    			assigned-clocks = <&serdes_wiz1 TI_WIZ_PLL0_REFCLK>,
    					  <&serdes_wiz1 TI_WIZ_PLL1_REFCLK>,
    					  <&serdes_wiz1 TI_WIZ_REFCLK_DIG>;
    			assigned-clock-parents = <&k3_clks 405 6>,
    						 <&k3_clks 405 6>,
    						 <&k3_clks 405 6>;
    			#size-cells = <0>;
    			#clock-cells = <1>;
    	serdes_wiz2: wiz@5020000 {
    		#size-cells = <1>;
    		power-domains = <&k3_pds 406 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 406 2>, <&k3_clks 406 6>, <&serdes_refclk>, <&k3_clks 406 5>;
    		assigned-clocks = <&k3_clks 406 6>;
    		assigned-clock-parents = <&k3_clks 406 10>;
    		num-lanes = <4>;
    		#reset-cells = <1>;
    		#clock-cells = <1>;
    		ranges = <0x05020000 0x00 0x05020000 0x10000>;
    		serdes2: serdes@5020000 {
    			reg = <0x05020000 0x010000>;
    			resets = <&serdes_wiz2 0>;
    			clocks = <&serdes_wiz2 TI_WIZ_PLL0_REFCLK>,
    				 <&serdes_wiz2 TI_WIZ_PHY_EN_REFCLK>;
    			assigned-clocks = <&serdes_wiz2 TI_WIZ_PLL0_REFCLK>,
    					  <&serdes_wiz2 TI_WIZ_PLL1_REFCLK>,
    					  <&serdes_wiz2 TI_WIZ_REFCLK_DIG>;
    			assigned-clock-parents = <&k3_clks 406 6>,
    						 <&k3_clks 406 6>,
    						 <&k3_clks 406 6>;
    			#size-cells = <0>;
    			#clock-cells = <1>;
    	serdes_wiz4: wiz@5050000 {
    		#size-cells = <1>;
    		power-domains = <&k3_pds 407 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 407 2>, <&k3_clks 407 6>, <&serdes_refclk>, <&k3_clks 407 5>;
    		assigned-clocks = <&k3_clks 407 6>;
    		assigned-clock-parents = <&k3_clks 407 10>;
    		num-lanes = <4>;
    		#reset-cells = <1>;
    		#clock-cells = <1>;
    		ranges = <0x05050000 0x00 0x05050000 0x10000>,
    			 <0xa030a00 0x00 0xa030a00 0x40>; /* DPTX PHY */
    		serdes4: serdes@5050000 {
    			 * Note: we also map DPTX PHY registers as the Torrent
    			 * needs to manage those.
    			reg = <0x05050000 0x010000>,
    			      <0x0a030a00 0x40>; /* DPTX PHY */
    			resets = <&serdes_wiz4 0>;
    			clocks = <&serdes_wiz4 TI_WIZ_PLL0_REFCLK>,
    				 <&serdes_wiz4 TI_WIZ_PHY_EN_REFCLK>;
    			assigned-clocks = <&serdes_wiz4 TI_WIZ_PLL0_REFCLK>,
    					  <&serdes_wiz4 TI_WIZ_PLL1_REFCLK>,
    					  <&serdes_wiz4 TI_WIZ_REFCLK_DIG>;
    			assigned-clock-parents = <&k3_clks 407 6>,
    						 <&k3_clks 407 6>,
    						 <&k3_clks 407 6>;
    			#size-cells = <0>;
    			#clock-cells = <1>;
    	main_navss: bus@30000000 {
    		#size-cells = <2>;
    		ranges = <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>;
    		ti,sci-dev-id = <280>;
    		dma-coherent;
    		dma-ranges;
    		main_navss_sram: navss-sram@30000000{
    			reg = <0x00 0x30000000 0x00 0x10000>;
    			#size-cells = <1>;
    			ranges = <0x0 0x00 0x30000000 0x10000>;
    		main_navss_intr: interrupt-controller@310e0000 {
    			reg = <0x00 0x310e0000 0x00 0x4000>;
    			ti,intr-trigger-type = <4>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <283>;
    			ti,interrupt-ranges = <0 64 64>,
    					      <64 448 64>,
    					      <128 672 64>;
    		main_udmass_inta: msi-controller@33d00000 {
    			compatible = "ti,sci-inta";
    			reg = <0x00 0x33d00000 0x00 0x100000>;
    			#interrupt-cells = <0>;
    			interrupt-parent = <&main_navss_intr>;
    			msi-controller;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <321>;
    			ti,interrupt-ranges = <0 0 256>;
    			ti,unmapped-event-sources = <&main_bcdma_csi>;
    		secure_proxy_main: mailbox@32c00000 {
    			compatible = "ti,am654-secure-proxy";
    			#mbox-cells = <1>;
    			reg-names = "target_data", "rt", "scfg";
    			reg = <0x00 0x32c00000 0x00 0x100000>,
    			      <0x00 0x32400000 0x00 0x100000>,
    			      <0x00 0x32800000 0x00 0x100000>;
    			interrupt-names = "rx_011";
    			interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
    		hwspinlock: hwlock@30e00000 {
    			compatible = "ti,am654-hwspinlock";
    			reg = <0x00 0x30e00000 0x00 0x1000>;
    			#hwlock-cells = <1>;
    		mailbox0_cluster0: mailbox@31f80000 {
    			compatible = "ti,am654-mailbox";
    			reg = <0x00 0x31f80000 0x00 0x200>;
    			#mbox-cells = <1>;
    			ti,mbox-num-users = <4>;
    			ti,mbox-num-fifos = <16>;
    		mailbox0_cluster1: mailbox@31f81000 {
    			reg = <0x00 0x31f81000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster2: mailbox@31f82000 {
    			reg = <0x00 0x31f82000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster3: mailbox@31f83000 {
    			reg = <0x00 0x31f83000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster4: mailbox@31f84000 {
    			reg = <0x00 0x31f84000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster5: mailbox@31f85000 {
    			reg = <0x00 0x31f85000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster6: mailbox@31f86000 {
    			reg = <0x00 0x31f86000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster7: mailbox@31f87000 {
    			reg = <0x00 0x31f87000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster8: mailbox@31f88000 {
    			reg = <0x00 0x31f88000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster9: mailbox@31f89000 {
    			reg = <0x00 0x31f89000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster10: mailbox@31f8a000 {
    			reg = <0x00 0x31f8a000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox0_cluster11: mailbox@31f8b000 {
    			reg = <0x00 0x31f8b000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster0: mailbox@31f90000 {
    			reg = <0x00 0x31f90000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster1: mailbox@31f91000 {
    			reg = <0x00 0x31f91000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster2: mailbox@31f92000 {
    			reg = <0x00 0x31f92000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster3: mailbox@31f93000 {
    			reg = <0x00 0x31f93000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster4: mailbox@31f94000 {
    			reg = <0x00 0x31f94000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster5: mailbox@31f95000 {
    			reg = <0x00 0x31f95000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster6: mailbox@31f96000 {
    			reg = <0x00 0x31f96000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster7: mailbox@31f97000 {
    			reg = <0x00 0x31f97000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster8: mailbox@31f98000 {
    			reg = <0x00 0x31f98000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster9: mailbox@31f99000 {
    			reg = <0x00 0x31f99000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster10: mailbox@31f9a000 {
    			reg = <0x00 0x31f9a000 0x00 0x200>;
    			#mbox-cells = <1>;
    		mailbox1_cluster11: mailbox@31f9b000 {
    			reg = <0x00 0x31f9b000 0x00 0x200>;
    			#mbox-cells = <1>;
    		main_ringacc: ringacc@3c000000 {
    			compatible = "ti,am654-navss-ringacc";
    			reg = <0x00 0x3c000000 0x00 0x400000>,
    			      <0x00 0x38000000 0x00 0x400000>,
    			      <0x00 0x31120000 0x00 0x100>,
    			      <0x00 0x33000000 0x00 0x40000>;
    			reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target";
    			ti,num-rings = <1024>;
    			ti,sci-rm-range-gp-rings = <0x1>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <315>;
    			msi-parent = <&main_udmass_inta>;
    		main_udmap: dma-controller@31150000 {
    			compatible = "ti,j721e-navss-main-udmap";
    			reg = <0x00 0x31150000 0x00 0x100>,
    			      <0x00 0x34000000 0x00 0x80000>,
    			      <0x00 0x35000000 0x00 0x200000>;
    			reg-names = "gcfg", "rchanrt", "tchanrt";
    			#dma-cells = <1>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <319>;
    			ti,ringacc = <&main_ringacc>;
    			ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */
    						<0x0f>, /* TX_HCHAN */
    						<0x10>; /* TX_UHCHAN */
    			ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */
    						<0x0b>, /* RX_HCHAN */
    						<0x0c>; /* RX_UHCHAN */
    			ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */
    		main_bcdma_csi: dma-controller@311a0000 {
    			compatible = "ti,j721s2-dmss-bcdma-csi";
    			reg = <0x00 0x311a0000 0x00 0x100>,
    				<0x00 0x35d00000 0x00 0x20000>,
    				<0x00 0x35c00000 0x00 0x10000>,
    				<0x00 0x35e00000 0x00 0x80000>;
    			reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt";
    			#dma-cells = <3>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <281>;
    			ti,sci-rm-range-rchan = <0x21>;
    			ti,sci-rm-range-tchan = <0x22>;
    		cpts@310d0000 {
    			compatible = "ti,j721e-cpts";
    			reg = <0x00 0x310d0000 0x00 0x400>;
    			reg-names = "cpts";
    			clocks = <&k3_clks 282 0>;
    			clock-names = "cpts";
    			assigned-clocks = <&k3_clks 62 3>; /* CPTS_RFT_CLK */
    			assigned-clock-parents = <&k3_clks 62 5>; /* MAIN_0_HSDIV6_CLK */
    			interrupts-extended = <&main_navss_intr 391>;
    			interrupt-names = "cpts";
    			ti,cpts-periodic-outputs = <6>;
    			ti,cpts-ext-ts-inputs = <8>;
    	main_cpsw0: ethernet@c000000 {
    		compatible = "ti,j784s4-cpswxg-nuss";
    		reg = <0x00 0xc000000 0x00 0x200000>;
    		reg-names = "cpsw_nuss";
    		#size-cells = <2>;
    		ranges = <0x00 0x00 0x00 0xc000000 0x00 0x200000>;
    		dma-coherent;
    		clocks = <&k3_clks 64 0>;
    		power-domains = <&k3_pds 64 TI_SCI_PD_EXCLUSIVE>;
    		dmas = <&main_udmap 0xca00>,
    		       <&main_udmap 0xca01>,
    		       <&main_udmap 0xca02>,
    		       <&main_udmap 0xca03>,
    		       <&main_udmap 0xca04>,
    		       <&main_udmap 0xca05>,
    		       <&main_udmap 0xca06>,
    		       <&main_udmap 0xca07>,
    		       <&main_udmap 0x4a00>;
    		dma-names = "tx0", "tx1", "tx2", "tx3",
    			    "tx4", "tx5", "tx6", "tx7",
    			    "rx";
    		ethernet-ports {
    			#size-cells = <0>;
    			main_cpsw0_port1: port@1 {
    				reg = <1>;
    				label = "port1";
    				ti,mac-only;
    			main_cpsw0_port2: port@2 {
    				reg = <2>;
    				label = "port2";
    				ti,mac-only;
    			main_cpsw0_port3: port@3 {
    				reg = <3>;
    				label = "port3";
    				ti,mac-only;
    			main_cpsw0_port4: port@4 {
    				reg = <4>;
    				label = "port4";
    				ti,mac-only;
    			main_cpsw0_port5: port@5 {
    				reg = <5>;
    				label = "port5";
    			main_cpsw0_port6: port@6 {
    				reg = <6>;
    				label = "port6";
    			main_cpsw0_port7: port@7 {
    				reg = <7>;
    				label = "port7";
    			main_cpsw0_port8: port@8 {
    				reg = <8>;
    				label = "port8";
    		main_cpsw0_mdio: mdio@f00 {
    			compatible = "ti,cpsw-mdio","ti,davinci_mdio";
    			reg = <0x00 0xf00 0x00 0x100>;
    			#size-cells = <0>;
    			bus_freq = <1000000>;
    		cpts@3d000 {
    			compatible = "ti,am65-cpts";
    			reg = <0x00 0x3d000 0x00 0x400>;
    			clocks = <&k3_clks 64 3>;
    			interrupts-extended = <&gic500 GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
    			ti,cpts-ext-ts-inputs = <4>;
    			ti,cpts-periodic-outputs = <2>;
    	main_cpsw1: ethernet@c200000 {
    		compatible = "ti,j721e-cpsw-nuss";
    		reg = <0x00 0xc200000 0x00 0x200000>;
    		ranges = <0x00 0x00 0x00 0xc200000 0x00 0x200000>;
    		#size-cells = <2>;
    		dma-coherent;
    		clocks = <&k3_clks 62 0>;
    		power-domains = <&k3_pds 62 TI_SCI_PD_EXCLUSIVE>;
    		dmas = <&main_udmap 0xc640>,
    		       <&main_udmap 0xc641>,
    		       <&main_udmap 0xc642>,
    		       <&main_udmap 0xc643>,
    		       <&main_udmap 0xc644>,
    		       <&main_udmap 0xc645>,
    		       <&main_udmap 0xc646>,
    		       <&main_udmap 0xc647>,
    		       <&main_udmap 0x4640>;
    			    "rx";
    		ethernet-ports {
    			#size-cells = <0>;
    			main_cpsw1_port1: port@1 {
    				reg = <1>;
    				label = "port1";
    				phys = <&cpsw1_phy_gmii_sel 1>;
    				ti,mac-only;
    		main_cpsw1_mdio: mdio@f00 {
    			compatible = "ti,cpsw-mdio", "ti,davinci_mdio";
    			#size-cells = <0>;
    		cpts@3d000 {
    			interrupts-extended = <&gic500 GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
    	pcie0_rc: pcie@2900000 {
    		compatible = "ti,j784s4-pcie-host";
    		reg = <0x00 0x02900000 0x00 0x1000>,
    		      <0x00 0x02907000 0x00 0x400>,
    		      <0x00 0x0d000000 0x00 0x00800000>,
    		      <0x00 0x10000000 0x00 0x00001000>;
    		reg-names = "intd_cfg", "user_cfg", "reg", "cfg";
    		interrupt-names = "link_state";
    		interrupts = <GIC_SPI 318 IRQ_TYPE_EDGE_RISING>;
    		device_type = "pci";
    		ti,syscon-pcie-ctrl = <&scm_conf 0x4070>;
    		max-link-speed = <3>;
    		num-lanes = <4>;
    		power-domains = <&k3_pds 332 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 332 0>;
    		#address-cells = <3>;
    		#size-cells = <2>;
    		bus-range = <0x0 0xff>;
    		vendor-id = <0x104c>;
    		device-id = <0xb00d>;
    		msi-map = <0x0 &gic_its 0x0 0x10000>;
    		dma-coherent;
    		ranges = <0x01000000 0x0 0x10001000 0x0 0x10001000 0x0 0x0010000>,
    			 <0x02000000 0x0 0x10011000 0x0 0x10011000 0x0 0x7fef000>;
    		dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>;
    		interrupt-map-mask = <0 0 0 7>;
    		interrupt-map = <0 0 0 1 &pcie0_intc 0>,
    				<0 0 0 2 &pcie0_intc 0>,
    				<0 0 0 3 &pcie0_intc 0>,
    				<0 0 0 4 &pcie0_intc 0>;
    		pcie0_intc: interrupt-controller {
    			interrupts = <GIC_SPI 312 IRQ_TYPE_EDGE_RISING>;
    	pcie0_ep: pcie-ep@2900000 {
    		compatible = "ti,j784s4-pcie-ep";
    		      <0x00 0x10000000 0x00 0x08000000>;
    		reg-names = "intd_cfg", "user_cfg", "reg", "mem";
    		num-lanes = <4>;
    		max-functions = /bits/ 8 <6>;
    		max-virtual-functions = /bits/ 8 <4 4 4 4 0 0>;
    		dma-coherent;
    	pcie1_rc: pcie@2910000 {
    		reg = <0x00 0x02910000 0x00 0x1000>,
    		      <0x00 0x02917000 0x00 0x400>,
    		      <0x00 0x0d800000 0x00 0x00800000>,
    		      <0x00 0x18000000 0x00 0x00001000>;
    		interrupts = <GIC_SPI 330 IRQ_TYPE_EDGE_RISING>;
    		ti,syscon-pcie-ctrl = <&scm_conf 0x4074>;
    		ti,syscon-pcie-refclk-out = <&scm_conf 0x9008 0x900c 0x18090 0x8074 0x1>;
    		num-lanes = <4>;
    		power-domains = <&k3_pds 333 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 333 0>;
    		#size-cells = <2>;
    		device-id = <0xb013>;
    		msi-map = <0x0 &gic_its 0x10000 0x10000>;
    		dma-coherent;
    		ranges = <0x01000000 0x0 0x18001000  0x00 0x18001000  0x0 0x0010000>,
    			 <0x02000000 0x0 0x18011000  0x00 0x18011000  0x0 0x7fef000>;
    		interrupt-map = <0 0 0 1 &pcie1_intc 0>,
    				<0 0 0 2 &pcie1_intc 0>,
    				<0 0 0 3 &pcie1_intc 0>,
    				<0 0 0 4 &pcie1_intc 0>;
    		pcie1_intc: interrupt-controller {
    			interrupts = <GIC_SPI 324 IRQ_TYPE_EDGE_RISING>;
    	pcie1_ep: pcie-ep@2910000 {
    		      <0x00 0x18000000 0x00 0x08000000>;
    		num-lanes = <4>;
    		dma-coherent;
    	pcie3_rc: pcie@2930000 {
    		reg = <0x00 0x02930000 0x00 0x1000>,
    			<0x00 0x02937000 0x00 0x400>,
    			<0x00 0x0e800000 0x00 0x00800000>,
    			<0x44 0x10000000 0x00 0x00001000>;
    		interrupts = <GIC_SPI 354 IRQ_TYPE_EDGE_RISING>;
    		ti,syscon-pcie-ctrl = <&scm_conf 0x407c>;
    		num-lanes = <4>;
    		power-domains = <&k3_pds 335 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 335 0>;
    		#size-cells = <2>;
    		msi-map = <0x0 &gic_its 0x30000 0x10000>;
    		dma-coherent;
    		ranges = <0x01000000 0x0 0x00001000 0x44 0x10001000 0x0 0x0010000>,
    			<0x02000000 0x0 0x00011000 0x44 0x10011000 0x0 0x7fef000>;
    		interrupt-map = <0 0 0 1 &pcie3_intc 0>,
    			<0 0 0 2 &pcie3_intc 0>,
    			<0 0 0 3 &pcie3_intc 0>,
    			<0 0 0 4 &pcie3_intc 0>;
    		pcie3_intc: interrupt-controller {
    			interrupts = <GIC_SPI 348 IRQ_TYPE_EDGE_RISING>;
    	pcie3_ep: pcie-ep@2930000 {
    		num-lanes = <4>;
    		dma-coherent;
    	main_mcan0: can@2701000 {
    		compatible = "bosch,m_can";
    		reg = <0x00 0x02701000 0x00 0x200>,
    		      <0x00 0x02708000 0x00 0x8000>;
    		reg-names = "m_can", "message_ram";
    		power-domains = <&k3_pds 245 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 245 6>, <&k3_clks 245 1>;
    		clock-names = "hclk", "cclk";
    		interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>;
    		interrupt-names = "int0", "int1";
    		bosch,mram-cfg = <0x00 128 64 64 64 64 32 32>;
    	main_mcan1: can@2711000 {
    		reg = <0x00 0x02711000 0x00 0x200>,
    		      <0x00 0x02718000 0x00 0x8000>;
    		power-domains = <&k3_pds 246 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 246 6>, <&k3_clks 246 1>;
    		interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan2: can@2721000 {
    		reg = <0x00 0x02721000 0x00 0x200>,
    		      <0x00 0x02728000 0x00 0x8000>;
    		power-domains = <&k3_pds 247 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 247 6>, <&k3_clks 247 1>;
    		interrupts = <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan3: can@2731000 {
    		reg = <0x00 0x02731000 0x00 0x200>,
    		      <0x00 0x02738000 0x00 0x8000>;
    		power-domains = <&k3_pds 248 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 248 6>, <&k3_clks 248 1>;
    		interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan4: can@2741000 {
    		reg = <0x00 0x02741000 0x00 0x200>,
    		      <0x00 0x02748000 0x00 0x8000>;
    		power-domains = <&k3_pds 249 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 249 6>, <&k3_clks 249 1>;
    		interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan5: can@2751000 {
    		reg = <0x00 0x02751000 0x00 0x200>,
    		      <0x00 0x02758000 0x00 0x8000>;
    		power-domains = <&k3_pds 250 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 250 6>, <&k3_clks 250 1>;
    		interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan6: can@2761000 {
    		reg = <0x00 0x02761000 0x00 0x200>,
    		      <0x00 0x02768000 0x00 0x8000>;
    		power-domains = <&k3_pds 251 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 251 6>, <&k3_clks 251 1>;
    		interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan7: can@2771000 {
    		reg = <0x00 0x02771000 0x00 0x200>,
    		      <0x00 0x02778000 0x00 0x8000>;
    		power-domains = <&k3_pds 252 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 252 6>, <&k3_clks 252 1>;
    		interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan8: can@2781000 {
    		reg = <0x00 0x02781000 0x00 0x200>,
    		      <0x00 0x02788000 0x00 0x8000>;
    		power-domains = <&k3_pds 253 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 253 6>, <&k3_clks 253 1>;
    		interrupts = <GIC_SPI 576 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 577 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan9: can@2791000 {
    		reg = <0x00 0x02791000 0x00 0x200>,
    		      <0x00 0x02798000 0x00 0x8000>;
    		power-domains = <&k3_pds 254 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 254 6>, <&k3_clks 254 1>;
    		interrupts = <GIC_SPI 579 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 580 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan10: can@27a1000 {
    		reg = <0x00 0x027a1000 0x00 0x200>,
    		      <0x00 0x027a8000 0x00 0x8000>;
    		power-domains = <&k3_pds 255 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 255 6>, <&k3_clks 255 1>;
    		interrupts = <GIC_SPI 582 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 583 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan11: can@27b1000 {
    		reg = <0x00 0x027b1000 0x00 0x200>,
    		      <0x00 0x027b8000 0x00 0x8000>;
    		power-domains = <&k3_pds 256 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 256 6>, <&k3_clks 256 1>;
    		interrupts = <GIC_SPI 585 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 586 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan12: can@27c1000 {
    		reg = <0x00 0x027c1000 0x00 0x200>,
    		      <0x00 0x027c8000 0x00 0x8000>;
    		power-domains = <&k3_pds 257 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 257 6>, <&k3_clks 257 1>;
    		interrupts = <GIC_SPI 588 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 589 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan13: can@27d1000 {
    		reg = <0x00 0x027d1000 0x00 0x200>,
    		      <0x00 0x027d8000 0x00 0x8000>;
    		power-domains = <&k3_pds 258 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 258 6>, <&k3_clks 258 1>;
    		interrupts = <GIC_SPI 591 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 592 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan14: can@2681000 {
    		reg = <0x00 0x02681000 0x00 0x200>,
    		      <0x00 0x02688000 0x00 0x8000>;
    		power-domains = <&k3_pds 259 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 259 6>, <&k3_clks 259 1>;
    		interrupts = <GIC_SPI 594 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 595 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan15: can@2691000 {
    		reg = <0x00 0x02691000 0x00 0x200>,
    		      <0x00 0x02698000 0x00 0x8000>;
    		power-domains = <&k3_pds 260 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 260 6>, <&k3_clks 260 1>;
    		interrupts = <GIC_SPI 597 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 598 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan16: can@26a1000 {
    		reg = <0x00 0x026a1000 0x00 0x200>,
    		      <0x00 0x026a8000 0x00 0x8000>;
    		power-domains = <&k3_pds 261 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 261 6>, <&k3_clks 261 1>;
    		interrupts = <GIC_SPI 784 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 785 IRQ_TYPE_LEVEL_HIGH>;
    	main_mcan17: can@26b1000 {
    		reg = <0x00 0x026b1000 0x00 0x200>,
    		      <0x00 0x026b8000 0x00 0x8000>;
    		power-domains = <&k3_pds 262 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 262 6>, <&k3_clks 262 1>;
    		interrupts = <GIC_SPI 787 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 788 IRQ_TYPE_LEVEL_HIGH>;
    	main_spi0: spi@2100000 {
    		compatible = "ti,am654-mcspi","ti,omap4-mcspi";
    		reg = <0x00 0x02100000 0x00 0x400>;
    		interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 376 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 376 1>;
    	main_spi1: spi@2110000 {
    		reg = <0x00 0x02110000 0x00 0x400>;
    		interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 377 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 377 1>;
    	main_spi2: spi@2120000 {
    		reg = <0x00 0x02120000 0x00 0x400>;
    		interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 378 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 378 1>;
    	main_spi3: spi@2130000 {
    		reg = <0x00 0x02130000 0x00 0x400>;
    		interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 379 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 379 1>;
    	main_spi4: spi@2140000 {
    		reg = <0x00 0x02140000 0x00 0x400>;
    		interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 380 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 380 1>;
    	main_spi5: spi@2150000 {
    		reg = <0x00 0x02150000 0x00 0x400>;
    		interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 381 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 381 1>;
    	main_spi6: spi@2160000 {
    		reg = <0x00 0x02160000 0x00 0x400>;
    		interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 382 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 382 1>;
    	main_spi7: spi@2170000 {
    		reg = <0x00 0x02170000 0x00 0x400>;
    		interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>;
    		#size-cells = <0>;
    		power-domains = <&k3_pds 383 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 383 1>;
    	dphy_tx0: phy@4480000 {
    		compatible = "ti,j721e-dphy";
    		reg = <0x0 0x04480000 0x0 0x1000>;
    		clocks = <&k3_clks 402 20>, <&k3_clks 402 3>;
    		clock-names = "psm", "pll_ref";
    		#phy-cells = <0>;
    		power-domains = <&k3_pds 402 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 402 3>;
    		assigned-clock-parents = <&k3_clks 402 4>;
    		assigned-clock-rates = <19200000>;
    	dsi0: dsi@4800000 {
    		compatible = "ti,j721e-dsi";
    		reg = <0x0 0x04800000 0x0 0x100000>, <0x0 0x04710000 0x0 0x100>;
    		clocks = <&k3_clks 215 2>, <&k3_clks 215 5>;
    		clock-names = "dsi_p_clk", "dsi_sys_clk";
    		power-domains = <&k3_pds 215 TI_SCI_PD_EXCLUSIVE>;
    		interrupts = <GIC_SPI 600 IRQ_TYPE_LEVEL_HIGH>;
    		phys = <&dphy_tx0>;
    		phy-names = "dphy";
    		dsi0_ports: ports {
    			#size-cells = <0>;
    			port@0 {
    				reg = <0>;
    			port@1 {
    				reg = <1>;
    	timesync_router: pinctrl@a40000 {
    		reg = <0x0 0xa40000 0x0 0x800>;
    		#size-cells = <0>;
    		pinctrl-single,function-mask = <0x000107ff>;
    	mhdp: dp-bridge@a000000 {
    		compatible = "ti,j721e-mhdp8546";
    		reg = <0x0 0xa000000 0x0 0x30a00>,
    		      <0x0 0x4f40000 0x0 0x20>;
    		reg-names = "mhdptx", "j721e-intg";
    		clocks = <&k3_clks 217 11>;
    		interrupts = <GIC_SPI 614 IRQ_TYPE_LEVEL_HIGH>;
    		power-domains = <&k3_pds 217 TI_SCI_PD_EXCLUSIVE>;
    		dp0_ports: ports {
    			#size-cells = <0>;
    	dss: dss@4a00000 {
    		compatible = "ti,j721e-dss";
    		reg = <0x00 0x04a00000 0x00 0x10000>, /* common_m */
    		      <0x00 0x04a10000 0x00 0x10000>, /* common_s0*/
    		      <0x00 0x04b00000 0x00 0x10000>, /* common_s1*/
    		      <0x00 0x04b10000 0x00 0x10000>, /* common_s2*/
    		      <0x00 0x04a20000 0x00 0x10000>, /* vidl1 */
    		      <0x00 0x04a30000 0x00 0x10000>, /* vidl2 */
    		      <0x00 0x04a50000 0x00 0x10000>, /* vid1 */
    		      <0x00 0x04a60000 0x00 0x10000>, /* vid2 */
    		      <0x00 0x04a70000 0x00 0x10000>, /* ovr1 */
    		      <0x00 0x04a90000 0x00 0x10000>, /* ovr2 */
    		      <0x00 0x04ab0000 0x00 0x10000>, /* ovr3 */
    		      <0x00 0x04ad0000 0x00 0x10000>, /* ovr4 */
    		      <0x00 0x04a80000 0x00 0x10000>, /* vp1 */
    		      <0x00 0x04aa0000 0x00 0x10000>, /* vp1 */
    		      <0x00 0x04ac0000 0x00 0x10000>, /* vp1 */
    		      <0x00 0x04ae0000 0x00 0x10000>, /* vp4 */
    		      <0x00 0x04af0000 0x00 0x10000>; /* wb */
    		reg-names = "common_m", "common_s0",
    			    "common_s1", "common_s2",
    			    "vidl1", "vidl2","vid1","vid2",
    			    "ovr1", "ovr2", "ovr3", "ovr4",
    			    "vp1", "vp2", "vp3", "vp4",
    			    "wb";
    		clocks = <&k3_clks 218 0>,
    			 <&k3_clks 218 2>,
    			 <&k3_clks 218 5>,
    			 <&k3_clks 218 14>,
    			 <&k3_clks 218 18>;
    		clock-names = "fck", "vp1", "vp2", "vp3", "vp4";
    		power-domains = <&k3_pds 218 TI_SCI_PD_EXCLUSIVE>;
    		interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>,
    			     <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>;
    		interrupt-names = "common_m",
    				  "common_s0",
    				  "common_s1",
    				  "common_s2";
    		dss_ports: ports {
    	ti_csi2rx0: ticsi2rx@4500000 {
    		compatible = "ti,j721e-csi2rx";
    		dmas = <&main_bcdma_csi 0 0x4940 0>, <&main_bcdma_csi 0 0x4941 0>,
    		<&main_bcdma_csi 0 0x4942 0>, <&main_bcdma_csi 0 0x4943 0>,
    		<&main_bcdma_csi 0 0x4944 0>, <&main_bcdma_csi 0 0x4945 0>,
    		<&main_bcdma_csi 0 0x4946 0>, <&main_bcdma_csi 0 0x4947 0>;
    		dma-names = "rx0", "rx1", "rx2", "rx3", "rx4", "rx5", "rx6", "rx7";
    		reg = <0x00 0x04500000 0x00 0x00001000>;
    		power-domains = <&k3_pds 72 TI_SCI_PD_EXCLUSIVE>;
    		#size-cells = <2>;
    		ranges;
    		cdns_csi2rx0: csi-bridge@4504000 {
    			compatible = "cdns,csi2rx";
    			reg = <0x00 0x04504000 0x00 0x00001000>;
    			clocks = <&k3_clks 72 2>, <&k3_clks 72 0>, <&k3_clks 72 2>,
    				<&k3_clks 72 2>, <&k3_clks 72 3>, <&k3_clks 72 3>;
    			clock-names = "sys_clk", "p_clk", "pixel_if0_clk",
    				"pixel_if1_clk", "pixel_if2_clk", "pixel_if3_clk";
    			phys = <&dphy_rx0>;
    			phy-names = "dphy";
    			ports {
    				#size-cells = <0>;
    				csi0_port0: port@0 {
    					reg = <0>;
    				csi0_port1: port@1 {
    					reg = <1>;
    				csi0_port2: port@2 {
    					reg = <2>;
    				csi0_port3: port@3 {
    					reg = <3>;
    				csi0_port4: port@4 {
    					reg = <4>;
    	ti_csi2rx1: ticsi2rx@4510000 {
    		dmas = <&main_bcdma_csi 0 0x4960 0>, <&main_bcdma_csi 0 0x4961 0>,
    		<&main_bcdma_csi 0 0x4962 0>, <&main_bcdma_csi 0 0x4963 0>;
    		dma-names = "rx0", "rx1", "rx2", "rx3";
    		reg = <0x00 0x04510000 0x00 0x00001000>;
    		power-domains = <&k3_pds 73 TI_SCI_PD_EXCLUSIVE>;
    		#size-cells = <2>;
    		ranges;
    		cdns_csi2rx1: csi-bridge@4514000 {
    			reg = <0x00 0x04514000 0x00 0x00001000>;
    			clocks = <&k3_clks 73 2>, <&k3_clks 73 0>, <&k3_clks 73 2>,
    				<&k3_clks 73 2>, <&k3_clks 73 3>, <&k3_clks 73 3>;
    			phys = <&dphy_rx1>;
    			phy-names = "dphy";
    			ports {
    				#size-cells = <0>;
    				csi1_port0: port@0 {
    					reg = <0>;
    				csi1_port1: port@1 {
    					reg = <1>;
    				csi1_port2: port@2 {
    					reg = <2>;
    				csi1_port3: port@3 {
    					reg = <3>;
    				csi1_port4: port@4 {
    					reg = <4>;
    	ti_csi2rx2: ticsi2rx@4520000 {
    		dmas = <&main_bcdma_csi 0 0x4980 0>, <&main_bcdma_csi 0 0x4981 0>,
    		<&main_bcdma_csi 0 0x4982 0>, <&main_bcdma_csi 0 0x4983 0>;
    		reg = <0x00 0x04520000 0x00 0x00001000>;
    		power-domains = <&k3_pds 74 TI_SCI_PD_EXCLUSIVE>;
    		#size-cells = <2>;
    		ranges;
    		cdns_csi2rx2: csi-bridge@4524000 {
    			reg = <0x00 0x04524000 0x00 0x00001000>;
    			clocks = <&k3_clks 74 2>, <&k3_clks 74 0>, <&k3_clks 74 2>,
    				<&k3_clks 74 2>, <&k3_clks 74 3>, <&k3_clks 74 3>;
    			phys = <&dphy_rx2>;
    			phy-names = "dphy";
    			ports {
    				#size-cells = <0>;
    				csi2_port0: port@0 {
    					reg = <0>;
    				csi2_port1: port@1 {
    					reg = <1>;
    				csi2_port2: port@2 {
    					reg = <2>;
    				csi2_port3: port@3 {
    					reg = <3>;
    				csi2_port4: port@4 {
    					reg = <4>;
    	dphy_rx0: phy@4580000 {
    		compatible = "cdns,dphy-rx";
    		reg = <0x00 0x04580000 0x00 0x00001100>;
    		#phy-cells = <0>;
    		power-domains = <&k3_pds 212 TI_SCI_PD_EXCLUSIVE>;
    	dphy_rx1: phy@4590000 {
    		reg = <0x00 0x04590000 0x00 0x00001100>;
    		#phy-cells = <0>;
    		power-domains = <&k3_pds 213 TI_SCI_PD_EXCLUSIVE>;
    	dphy_rx2: phy@45a0000 {
    		reg = <0x00 0x045a0000 0x00 0x00001100>;
    		#phy-cells = <0>;
    		power-domains = <&k3_pds 214 TI_SCI_PD_EXCLUSIVE>;
    	ufs_wrapper: ufs-wrapper@4e80000 {
    		compatible = "ti,j721e-ufs";
    		reg = <0x00 0x4e80000 0x00 0x100>;
    		power-domains = <&k3_pds 387 TI_SCI_PD_EXCLUSIVE>;
    		clocks = <&k3_clks 387 3>;
    		assigned-clocks = <&k3_clks 387 3>;
    		assigned-clock-parents = <&k3_clks 387 6>;
    		ranges;
    		#size-cells = <2>;
    		ufs@4e84000 {
    			compatible = "cdns,ufshc-m31-16nm", "jedec,ufs-2.0";
    			reg = <0x00 0x4e84000 0x00 0x10000>;
    			interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
    			freq-table-hz = <250000000 250000000>, <19200000 19200000>,
    					<19200000 19200000>;
    			clocks = <&k3_clks 387 1>, <&k3_clks 387 3>, <&k3_clks 387 3>;
    			clock-names = "core_clk", "phy_clk", "ref_clk";
    			dma-coherent;
    	main_r5fss0: r5fss@5c00000 {
    		compatible = "ti,j721s2-r5fss";
    		ti,cluster-mode = <0>;
    		#size-cells = <1>;
    		ranges = <0x5c00000 0x00 0x5c00000 0x20000>,
    			 <0x5d00000 0x00 0x5d00000 0x20000>;
    		power-domains = <&k3_pds 336 TI_SCI_PD_EXCLUSIVE>;
    		main_r5fss0_core0: r5f@5c00000 {
    			compatible = "ti,j721s2-r5f";
    			reg = <0x5c00000 0x00010000>,
    			      <0x5c10000 0x00010000>;
    			reg-names = "atcm", "btcm";
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <339>;
    			ti,sci-proc-ids = <0x06 0xff>;
    			resets = <&k3_reset 339 1>;
    			firmware-name = "j784s4-main-r5f0_0-fw";
    			ti,atcm-enable = <1>;
    			ti,btcm-enable = <1>;
    			ti,loczrama = <1>;
    		main_r5fss0_core1: r5f@5d00000 {
    			reg = <0x5d00000 0x00010000>,
    			      <0x5d10000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <340>;
    			ti,sci-proc-ids = <0x07 0xff>;
    			resets = <&k3_reset 340 1>;
    			firmware-name = "j784s4-main-r5f0_1-fw";
    			ti,loczrama = <1>;
    	main_r5fss1: r5fss@5e00000 {
    		#size-cells = <1>;
    		ranges = <0x5e00000 0x00 0x5e00000 0x20000>,
    			 <0x5f00000 0x00 0x5f00000 0x20000>;
    		power-domains = <&k3_pds 337 TI_SCI_PD_EXCLUSIVE>;
    		main_r5fss1_core0: r5f@5e00000 {
    			reg = <0x5e00000 0x00010000>,
    			      <0x5e10000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <341>;
    			ti,sci-proc-ids = <0x08 0xff>;
    			resets = <&k3_reset 341 1>;
    			firmware-name = "j784s4-main-r5f1_0-fw";
    			ti,loczrama = <1>;
    		main_r5fss1_core1: r5f@5f00000 {
    			reg = <0x5f00000 0x00010000>,
    			      <0x5f10000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <342>;
    			ti,sci-proc-ids = <0x09 0xff>;
    			resets = <&k3_reset 342 1>;
    			firmware-name = "j784s4-main-r5f1_1-fw";
    			ti,loczrama = <1>;
    	main_r5fss2: r5fss@5900000 {
    		#size-cells = <1>;
    		ranges = <0x5900000 0x00 0x5900000 0x20000>,
    			 <0x5a00000 0x00 0x5a00000 0x20000>;
    		power-domains = <&k3_pds 338 TI_SCI_PD_EXCLUSIVE>;
    		main_r5fss2_core0: r5f@5900000 {
    			reg = <0x5900000 0x00010000>,
    			      <0x5910000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <343>;
    			ti,sci-proc-ids = <0x0a 0xff>;
    			resets = <&k3_reset 343 1>;
    			firmware-name = "j784s4-main-r5f2_0-fw";
    			ti,loczrama = <1>;
    		main_r5fss2_core1: r5f@5a00000 {
    			reg = <0x5a00000 0x00010000>,
    			      <0x5a10000 0x00010000>;
    			ti,sci = <&sms>;
    			ti,sci-dev-id = <344>;
    			ti,sci-proc-ids = <0x0b 0xff>;
    			resets = <&k3_reset 344 1>;
    			firmware-name = "j784s4-main-r5f2_1-fw";
    			ti,loczrama = <1>;
    	c71_0: dsp@64800000 {
    		compatible = "ti,j721s2-c71-dsp";
    		reg = <0x00 0x64800000 0x00 0x00080000>,
    		      <0x00 0x64e00000 0x00 0x0000c000>;
    		reg-names = "l2sram", "l1dram";
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <30>;
    		ti,sci-proc-ids = <0x30 0xff>;
    		resets = <&k3_reset 30 1>;
    		firmware-name = "j784s4-c71_0-fw";
    	c71_1: dsp@65800000 {
    		reg = <0x00 0x65800000 0x00 0x00080000>,
    		      <0x00 0x65e00000 0x00 0x0000c000>;
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <33>;
    		ti,sci-proc-ids = <0x31 0xff>;
    		resets = <&k3_reset 33 1>;
    		firmware-name = "j784s4-c71_1-fw";
    	c71_2: dsp@66800000 {
    		reg = <0x00 0x66800000 0x00 0x00080000>,
    		      <0x00 0x66e00000 0x00 0x0000c000>;
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <37>;
    		ti,sci-proc-ids = <0x32 0xff>;
    		resets = <&k3_reset 37 1>;
    		firmware-name = "j784s4-c71_2-fw";
    	c71_3: dsp@67800000 {
    		reg = <0x00 0x67800000 0x00 0x00080000>,
    		      <0x00 0x67e00000 0x00 0x0000c000>;
    		ti,sci = <&sms>;
    		ti,sci-dev-id = <40>;
    		ti,sci-proc-ids = <0x33 0xff>;
    		resets = <&k3_reset 40 1>;
    		firmware-name = "j784s4-c71_3-fw";
    	main_esm: esm@700000 {
    		compatible = "ti,j721e-esm";
    		reg = <0x00 0x700000 0x00 0x1000>;
    		ti,esm-pins = <688>, <689>, <690>, <691>, <692>, <693>, <694>,
    			      <695>;
    		bootph-pre-ram;
    	watchdog0: watchdog@2200000 {
    		compatible = "ti,j7-rti-wdt";
    		reg = <0x00 0x2200000 0x00 0x100>;
    		clocks = <&k3_clks 348 1>;
    		power-domains = <&k3_pds 348 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 348 0>;
    		assigned-clock-parents = <&k3_clks 348 4>;
    	watchdog1: watchdog@2210000 {
    		reg = <0x00 0x2210000 0x00 0x100>;
    		clocks = <&k3_clks 349 1>;
    		power-domains = <&k3_pds 349 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 349 0>;
    		assigned-clock-parents = <&k3_clks 349 4>;
    	watchdog2: watchdog@2220000 {
    		reg = <0x00 0x2220000 0x00 0x100>;
    		clocks = <&k3_clks 350 1>;
    		power-domains = <&k3_pds 350 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 350 0>;
    		assigned-clock-parents = <&k3_clks 350 4>;
    	watchdog3: watchdog@2230000 {
    		reg = <0x00 0x2230000 0x00 0x100>;
    		clocks = <&k3_clks 351 1>;
    		power-domains = <&k3_pds 351 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 351 0>;
    		assigned-clock-parents = <&k3_clks 351 4>;
    	watchdog4: watchdog@2240000 {
    		reg = <0x00 0x2240000 0x00 0x100>;
    		clocks = <&k3_clks 352 1>;
    		power-domains = <&k3_pds 352 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 352 0>;
    		assigned-clock-parents = <&k3_clks 352 4>;
    	watchdog5: watchdog@2250000 {
    		reg = <0x00 0x2250000 0x00 0x100>;
    		clocks = <&k3_clks 353 1>;
    		power-domains = <&k3_pds 353 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 353 0>;
    		assigned-clock-parents = <&k3_clks 353 4>;
    	watchdog6: watchdog@2260000 {
    		reg = <0x00 0x2260000 0x00 0x100>;
    		clocks = <&k3_clks 354 1>;
    		power-domains = <&k3_pds 354 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 354 0>;
    		assigned-clock-parents = <&k3_clks 354 4>;
    	watchdog7: watchdog@2270000 {
    		reg = <0x00 0x2270000 0x00 0x100>;
    		clocks = <&k3_clks 355 1>;
    		power-domains = <&k3_pds 355 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 355 0>;
    		assigned-clock-parents = <&k3_clks 355 4>;
    	 * The following RTI instances are coupled with MCU R5Fs, c7x and
    	 * GPU so keeping them reserved as these will be used by their
    	 * respective firmware
    	watchdog8: watchdog@22f0000 {
    		reg = <0x00 0x22f0000 0x00 0x100>;
    		clocks = <&k3_clks 360 1>;
    		power-domains = <&k3_pds 360 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 360 0>;
    		assigned-clock-parents = <&k3_clks 360 4>;
    		/* reserved for GPU */
    		status = "reserved";
    	watchdog9: watchdog@2300000 {
    		reg = <0x00 0x2300000 0x00 0x100>;
    		clocks = <&k3_clks 356 1>;
    		power-domains = <&k3_pds 356 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 356 0>;
    		assigned-clock-parents = <&k3_clks 356 4>;
    		/* reserved for C7X_0 DSP */
    	watchdog10: watchdog@2310000 {
    		reg = <0x00 0x2310000 0x00 0x100>;
    		clocks = <&k3_clks 357 1>;
    		power-domains = <&k3_pds 357 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 357 0>;
    		assigned-clock-parents = <&k3_clks 357 4>;
    		/* reserved for C7X_1 DSP */
    	watchdog11: watchdog@2320000 {
    		reg = <0x00 0x2320000 0x00 0x100>;
    		clocks = <&k3_clks 358 1>;
    		power-domains = <&k3_pds 358 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 358 0>;
    		assigned-clock-parents = <&k3_clks 358 4>;
    		/* reserved for C7X_2 DSP */
    	watchdog12: watchdog@2330000 {
    		reg = <0x00 0x2330000 0x00 0x100>;
    		clocks = <&k3_clks 359 1>;
    		power-domains = <&k3_pds 359 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 359 0>;
    		assigned-clock-parents = <&k3_clks 359 4>;
    		/* reserved for C7X_3 DSP */
    	watchdog13: watchdog@23c0000 {
    		reg = <0x00 0x23c0000 0x00 0x100>;
    		clocks = <&k3_clks 361 1>;
    		power-domains = <&k3_pds 361 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 361 0>;
    		assigned-clock-parents = <&k3_clks 361 4>;
    		/* reserved for MAIN_R5F0_0 */
    	watchdog14: watchdog@23d0000 {
    		reg = <0x00 0x23d0000 0x00 0x100>;
    		clocks = <&k3_clks 362 1>;
    		power-domains = <&k3_pds 362 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 362 0>;
    		assigned-clock-parents = <&k3_clks 362 4>;
    		/* reserved for MAIN_R5F0_1 */
    	watchdog15: watchdog@23e0000 {
    		reg = <0x00 0x23e0000 0x00 0x100>;
    		clocks = <&k3_clks 363 1>;
    		power-domains = <&k3_pds 363 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 363 0>;
    		assigned-clock-parents = <&k3_clks 363 4>;
    		/* reserved for MAIN_R5F1_0 */
    	watchdog16: watchdog@23f0000 {
    		reg = <0x00 0x23f0000 0x00 0x100>;
    		clocks = <&k3_clks 364 1>;
    		power-domains = <&k3_pds 364 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 364 0>;
    		assigned-clock-parents = <&k3_clks 364 4>;
    		/* reserved for MAIN_R5F1_1 */
    	watchdog17: watchdog@2540000 {
    		reg = <0x00 0x2540000 0x00 0x100>;
    		clocks = <&k3_clks 365 1>;
    		power-domains = <&k3_pds 365 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 365 0>;
    		assigned-clock-parents = <&k3_clks 366 4>;
    		/* reserved for MAIN_R5F2_0 */
    	watchdog18: watchdog@2550000 {
    		reg = <0x00 0x2550000 0x00 0x100>;
    		clocks = <&k3_clks 366 1>;
    		power-domains = <&k3_pds 366 TI_SCI_PD_EXCLUSIVE>;
    		assigned-clocks = <&k3_clks 366 0>;
    		/* reserved for MAIN_R5F2_1 */
  • Hi Chen,
    Yes, these are different from 9.1 SDK. In general, we do not backport patches onto previous SDK and new feature/bug fixes are provided in the new SDK. These will have to be done on customer-side.
    Let us know if you have questions or issues while porting these patches to 9.1 SDK.
    Takuma
