SK-AM64B: How to investigate CPU load ratio of tasks and interrupts
Part Number: SK-AM64B
Hello TI team!
I am investigating the CPU load factor.
Environment:
  CCS12.7.0
  AM64x MCU+ SDK 09.02.01
  SK-AM64B
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1392509/faq-how-to-profile-cpu-usage-with-mcu-sdk
I used TaskP_loadGetTotalCpuLoad() to check the CPU load rate for tasks and ISRs.
Next, I would like to examine the load ratio of tasks and interruptions separately.
For interrupts, I would like to know the load rate of I2C, MCAN, and ETHER.
  I want to use the i2C sample application i2c_led_blink_interrupt_lld to check the CPU load rate of I2C interrupts.
  In MCAN, I want to use mcan_loopback_interrupt application to check the CPU load rate of CAN interrupts.
  In ETHER, I want to use the enet_cpsw_loopback application to check the CPU load rate of ETHER send/receive interrupts.
How can I examine the CPU load ratio of tasks and interrupts separately?
https://software-dl.ti.com/mcu-plus-sdk/esd/AM64X/09_02_01_05/exports/docs/api_guide_am64x/group__SDL__R5FCPU__API.html
https://software-dl.ti.com/mcu-plus-sdk/esd/AM64X/09_02_01_05/exports/docs/api_guide_am64x/structSDL__R5FCPU__StaticRegs.html
https://software-dl.ti.com/mcu-plus-sdk/esd/AM64X/09_02_01_05/exports/docs/api_guide_am64x/structSDL__R5FCPU__StaticRegs.html#a37f206e43f9d1e672e7fc59b8e910982
Is ID_ISAR0 the interrupt load factor?
I am not sure.
I don't think it is mentioned in the Technical Reference Manual.
Yoshiki Koide
