Other Parts Discussed in Thread: AM68A,
I used this command to train and compile by Model Maker,
./run_modelmaker.sh AM68A config_obj_detection_x.yaml
i want to change the trainning and compilation parameters
e.g.
Detection Top K: from 200 to 500
View the previous posts, It can be modified through the following two files,
I want to know which file should be changed?
I modified the above files to retrain and compile,
Checked the complied files,but it didn’t seem to take effect.
mchi@ubuntu22:~/github/edgeai-tensorlab/edgeai-modelmaker/data/projects/obj_detect_sdk10$ grep -inr top_k run/20240914-225031/yolox_s_lite/run.yaml:18: detection_top_k: 200 run/20240914-225031/yolox_s_lite/status.json:221: "detection_top_k":200, run/20240914-225031/yolox_s_lite/run.json:220: "detection_top_k":200, run/20240914-225031/yolox_s_lite/training/model.prototxt:24: top_k: 200 run/20240914-225031/yolox_s_lite/training/model.prototxt:27: keep_top_k: 200 run/20240914-225031/yolox_s_lite/status.yaml:19: detection_top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/work/od-8220/model/model.prototxt:24: top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/work/od-8220/model/model.prototxt:27: keep_top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/work/od-8220/result.yaml:86: object_detection:top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/work/od-8220/config.yaml:75: object_detection:top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/work/od-8220/param.yaml:129: object_detection:top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/pkg/20240914-225031_yolox_s_lite_onnxrt_AM68A/model/model.prototxt:24: top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/pkg/20240914-225031_yolox_s_lite_onnxrt_AM68A/model/model.prototxt:27: keep_top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/pkg/20240914-225031_yolox_s_lite_onnxrt_AM68A/config.yaml:75: object_detection:top_k: 200 run/20240914-225031/yolox_s_lite/compilation/AM68A/pkg/20240914-225031_yolox_s_lite_onnxrt_AM68A/param.yaml:129: object_detection:top_k: 200 run/20240915-002311/yolox_s_lite/run.yaml:18: detection_top_k: 200 run/20240915-002311/yolox_s_lite/status.json:221: "detection_top_k":200, run/20240915-002311/yolox_s_lite/run.json:220: "detection_top_k":200, run/20240915-002311/yolox_s_lite/training/model.prototxt:24: top_k: 200 run/20240915-002311/yolox_s_lite/training/model.prototxt:27: keep_top_k: 200 run/20240915-002311/yolox_s_lite/status.yaml:19: detection_top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/work/od-8220/model/model.prototxt:24: top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/work/od-8220/model/model.prototxt:27: keep_top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/work/od-8220/result.yaml:86: object_detection:top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/work/od-8220/config.yaml:75: object_detection:top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/work/od-8220/param.yaml:129: object_detection:top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/pkg/20240915-002311_yolox_s_lite_onnxrt_AM68A/model/model.prototxt:24: top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/pkg/20240915-002311_yolox_s_lite_onnxrt_AM68A/model/model.prototxt:27: keep_top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/pkg/20240915-002311_yolox_s_lite_onnxrt_AM68A/config.yaml:75: object_detection:top_k: 200 run/20240915-002311/yolox_s_lite/compilation/AM68A/pkg/20240915-002311_yolox_s_lite_onnxrt_AM68A/param.yaml:129: object_detection:top_k: 200 run/20240915-220931/yolox_s_lite/run.yaml:18: detection_top_k: 200 run/20240915-220931/yolox_s_lite/status.json:221: "detection_top_k":200, run/20240915-220931/yolox_s_lite/run.json:220: "detection_top_k":200, run/20240915-220931/yolox_s_lite/training/model.prototxt:24: top_k: 200 run/20240915-220931/yolox_s_lite/training/model.prototxt:27: keep_top_k: 200 run/20240915-220931/yolox_s_lite/status.yaml:19: detection_top_k: 200 run/20240915-220931/yolox_s_lite/compilation/AM68A/work/od-8220/model/model.prototxt:24: top_k: 200 run/20240915-220931/yolox_s_lite/compilation/AM68A/work/od-8220/model/model.prototxt:27: keep_top_k: 200 run/20240915-220931/yolox_s_lite/compilation/AM68A/work/od-8220/result.yaml:86: object_detection:top_k: 200 run/20240915-220931/yolox_s_lite/compilation/AM68A/work/od-8220/config.yaml:75: object_detection:top_k: 200 grep: run/20240915-220931/yolox_s_lite/compilation/AM68A/work/od-8220/artifacts/detslabels_tidl_net.bin: binary file matches grep: run/20240915-220931/yolox_s_lite/compilation/AM68A/work/od-8220/artifacts/tempDir/detslabels_tidl_net.bin: binary file matches run/20240915-220931/yolox_s_lite/compilation/AM68A/work/od-8220/param.yaml:129: object_detection:top_k: 200 run/20240914-224307/yolox_s_lite/run.yaml:18: detection_top_k: 200 run/20240914-224307/yolox_s_lite/status.json:221: "detection_top_k":200, run/20240914-224307/yolox_s_lite/run.json:220: "detection_top_k":200, run/20240914-224307/yolox_s_lite/status.yaml:19: detection_top_k: 200
I want to know what else is required after modifying the parameters? How to confirm that the parameters have indeed been modified? thanks
