AM67A: Unable to successfully run "Compile and Validate on X86_PC" while using edgeai-tidl-tools
Part Number: AM67A
Hi Expert,
I use Ubuntu 22.04 and Python 3.10.14 built with pyenv virtual environment to use edgeai-tidl-tools.
I followed the steps in "Setup on X86_PC".
git clone https://github.com/TexasInstruments/edgeai-tidl-tools.git
cd edgeai-tidl-tools
export SOC=am67a
source ./setup.sh
export SOC=am67a
export TIDL_TOOLS_PATH=$(pwd)/tidl_tools
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$TIDL_TOOLS_PATH
export ARM64_GCC_PATH=$(pwd)/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu
mkdir build && cd build
cmake ../examples && make -j && cd ..
source ./scripts/run_python_examples.sh
While executing source ./scripts/run_python_examples.sh, I encountered AttributeError: 'InferenceSession' object has no attribute 'get_TI_benchmark_data'.
ace428@ace428-System-Product-Name:~/Desktop/edgeai-tidl-tools$ source ./scripts/run_python_examples.sh
X64 Architecture
Running 4 Models - ['cl-tfl-mobilenet_v1_1.0_224', 'ss-tfl-deeplabv3_mnv2_ade20k_float', 'od-tfl-ssd_mobilenet_v2_300_float', 'od-tfl-ssdlite_mobiledet_dsp_320x320_coco']
Running_Model :  cl-tfl-mobilenet_v1_1.0_224
Running_Model :  ss-tfl-deeplabv3_mnv2_ade20k_float
Running_Model :  od-tfl-ssd_mobilenet_v2_300_float
Running_Model :  od-tfl-ssdlite_mobiledet_dsp_320x320_coco
========================= [Model Compilation Started] =========================
Model compilation will perform the following stages:
1. Parsing
2. Graph Optimization
3. Quantization & Calibration
4. Memory Planning
============================== [Version Summary] ==============================
|          TIDL Tools Version          |              10_00_04_00             |
|         C7x Firmware Version         |              10_00_02_00             |
============================== [Parsing Started] ==============================
[TIDL Import] [PARSER] WARNING: Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options
1. Parsing
4. Memory Planning
1. Parsing
4. Memory Planning
TIDL Meta pipeLine (proto) file  : ../../../models/public/ssdlite_mobiledet_dsp_320x320_coco_20200519.prototxt
1. Parsing
4. Memory Planning
Number of OD backbone nodes = 112
Size of odBackboneNodeIds = 112
[TIDL Import]  WARNING: Kernel with non-power of 2 in [] is not optimal
Total Nodes = 81
Number of OD backbone nodes = 89
Size of odBackboneNodeIds = 89
|          Core           |      No. of Nodes       |   Number of Subgraphs   |
| C7x                     |                      81 |                       1 |
| CPU                     |                       0 |                       x |
============================= [Parsing Completed] =============================
Total Nodes = 34
| C7x                     |                      34 |                       1 |
| CPU                     |                       0 |                       x |
Total Nodes = 129
| C7x                     |                     129 |                       1 |
| CPU                     |                       0 |                       x |
=================== [Optimization for subgraph_201 started] ===================
Total Nodes = 107
| C7x                     |                     107 |                       1 |
| CPU                     |                       0 |                       x |
TF Meta pipeLine (proto) file : ../../../models/public/ssdlite_mobiledet_dsp_320x320_coco_20200519.prototxt
num_classes :              91
y_scale :                  10.000000
x_scale :                  10.000000
w_scale :                  5.000000
h_scale :                  5.000000
num_keypoints :            5.000000
score_threshold :          0.600000
iou_threshold :            0.450000
max_detections_per_class : 200
max_total_detections :     100
      scales, height_stride, width_stride, height_offset, width_offset
   0.2000000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.3500000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.5000000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.6500000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.8000000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
   0.9500000,   -1.0000000,   -1.0000000,   -1.0000000,   -1.0000000
aspect_ratios
   1.0000000
   2.0000000
   0.5000000
   3.0000000
   0.3333000
==================== [Optimization for subgraph_86 started] ====================
=================== [Optimization for subgraph_321 started] ===================
=================== [Optimization for subgraph_264 started] ===================
[TIDL Import] [PARSER] WARNING: Requested output data convert layer is not added to the network, It is currently not optimal
----------------------------- Optimization Summary -----------------------------
|          Layer         | Nodes before optimization | Nodes after optimization |
| TIDL_SoftMaxLayer      |                         1 |                        1 |
| TIDL_SqueezeLayer      |                         1 |                        0 |
| TIDL_ConvolutionLayer  |                        28 |                       27 |
| TIDL_EltWiseLayer      |                         2 |                        0 |
| TIDL_InnerProductLayer |                         0 |                        1 |
| TIDL_CastLayer         |                         1 |                        0 |
| TIDL_PoolingLayer      |                         1 |                        1 |
=================== [Optimization for subgraph_86 completed] ===================
| TIDL_ArgMaxLayer      |                         1 |                        1 |
| TIDL_ConcatLayer      |                         2 |                        2 |
| TIDL_ResizeLayer      |                         3 |                        5 |
| TIDL_ConvolutionLayer |                        60 |                       60 |
| TIDL_EltWiseLayer     |                        12 |                       10 |
| TIDL_CastLayer        |                         2 |                        0 |
================== [Optimization for subgraph_201 completed] ==================
| TIDL_OdOutputReformatLayer |                         0 |                        4 |
| TIDL_ConvolutionLayer      |                        94 |                       94 |
| TIDL_EltWiseLayer          |                        17 |                       15 |
| TIDL_DetectionOutputLayer  |                         0 |                        1 |
================== [Optimization for subgraph_321 completed] ==================
| TIDL_ConvolutionLayer      |                        76 |                       76 |
================== [Optimization for subgraph_264 completed] ==================
The soft limit is 10240
The hard limit is 10240
MEM: Init ... !!!
MEM: Init ... Done !!!
 0.0s:  VX_ZONE_INIT:Enabled
 0.7s:  VX_ZONE_ERROR:Enabled
 0.8s:  VX_ZONE_WARNING:Enabled
 0.1219s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
MEM: Init ... !!!
 0.5s:  VX_ZONE_ERROR:Enabled
 0.7s:  VX_ZONE_WARNING:Enabled
 0.1157s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
MEM: Init ... !!!
 0.6s:  VX_ZONE_WARNING:Enabled
 0.1096s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
MEM: Init ... !!!
 0.1121s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
 ************ Frame index 1 : Running float inference ****************
 ************ Frame index 2 : Running fixed point mode for calibration ****************
-------- Running Calibration in Float Mode to Collect Tensor Statistics --------
[======================================>                                      ] [=============================================================================] 100 %
------------------ Fixed-point Calibration Iteration [1 / 5]: ------------------
------------------ Fixed-point Calibration Iteration [2 / 5]: ------------------
[======================================>                                      ] [======================================>                                      ] [=============================================================================] 100 %
------------------ Fixed-point Calibration Iteration [3 / 5]: ------------------
[======================================>                                      ] 50 %
[======================================>                                      ] [=============================================================================] [=============================================================================] 100 %
------------------ Fixed-point Calibration Iteration [4 / 5]: ------------------
------------------ Fixed-point Calibration Iteration [5 / 5]: ------------------
[======================================>                                      ] [=============================================================================] [======================================>                                      ] [=============================================================================] 100 %
==================== [Quantization & Calibration Completed] ====================
========================== [Memory Planning Started] ==========================
------------------------- Network Compiler Traces ------------------------------
Successful Memory Allocation
Successful Workload Creation
========================= [Memory Planning Completed] =========================
======================== Subgraph Compiled Successfully ========================
 Final number of subgraphs:1 , 34 nodes delegated to accelerator
Completed_Model :     1, Name : cl-tfl-mobilenet_v1_1.0_224                       , Total time :    2420.16, Offload Time :       0.00 , DDR RW MBs : 18446744073709.55, Output File : py_out_cl-tfl-mobilenet_v1_1.0_224_ADE_val_00001801.jpg
MEM: Deinit ... !!!
MEM: Alloc's: 26 alloc's of 87828789 bytes
MEM: Free's : 26 free's  of 87828789 bytes
MEM: Open's : 0 allocs  of 0 bytes
MEM: Deinit ... Done !!!
[======================================>                                      ] [======================================>                                      ] [=============================================================================] [=============================================================================] 100 %
[=============================================================================] ==================== [Quantization & Calibration Completed] ====================
 Final number of subgraphs:1 , 107 nodes delegated to accelerator
Completed_Model :     3, Name : od-tfl-ssd_mobilenet_v2_300_float                 , Total time :    6771.57, Offload Time :       0.00 , DDR RW MBs : 18446744073709.55, Output File : py_out_od-tfl-ssd_mobilenet_v2_300_float_ADE_val_00001801.jpg
MEM: Deinit ... !!!
MEM: Alloc's: 29 alloc's of 232691165 bytes
MEM: Free's : 29 free's  of 232691165 bytes
 Final number of subgraphs:1 , 129 nodes delegated to accelerator
Completed_Model :     4, Name : od-tfl-ssdlite_mobiledet_dsp_320x320_coco         , Total time :    8438.49, Offload Time :       0.00 , DDR RW MBs : 18446744073709.55, Output File : py_out_od-tfl-ssdlite_mobiledet_dsp_320x320_coco_ADE_val_00001801.jpg
MEM: Deinit ... !!!
MEM: Alloc's: 29 alloc's of 139198365 bytes
MEM: Free's : 29 free's  of 139198365 bytes
 Final number of subgraphs:1 , 81 nodes delegated to accelerator
Completed_Model :     2, Name : ss-tfl-deeplabv3_mnv2_ade20k_float                , Total time :   38532.05, Offload Time :       0.00 , DDR RW MBs : 18446744073709.55, Output File : py_out_ss-tfl-deeplabv3_mnv2_ade20k_float_ADE_val_00001801.jpg
MEM: Deinit ... !!!
MEM: Alloc's: 26 alloc's of 408724625 bytes
MEM: Free's : 26 free's  of 408724625 bytes
run python3 tflrt_delegate.py
 Number of subgraphs:1 , 34 nodes delegated out of 34 nodes
 Number of subgraphs:1 , 81 nodes delegated out of 81 nodes
 Number of subgraphs:1 , 107 nodes delegated out of 107 nodes
MEM: Init ... !!!
 Number of subgraphs:1 , 129 nodes delegated out of 129 nodes
MEM: Init ... !!!
 0.6s:  VX_ZONE_ERROR:Enabled
 0.2013s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
 0.2451s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
MEM: Init ... !!!
 0.1102s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
MEM: Init ... !!!
 0.9s:  VX_ZONE_WARNING:Enabled
 0.1510s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
 ,  0  0.691726  warplane, military plane ,,  1  0.181373  missile ,,  2  0.109571  projectile, missile ,,  3  0.006352  cannon ,,  4  0.005370  aircraft carrier, carrier, flattop, attack aircraft carrier ,
Saving image to  ../../../output_images/
Completed_Model :     1, Name : cl-tfl-mobilenet_v1_1.0_224                       , Total time :     252.48, Offload Time :     252.47 , DDR RW MBs : 18446744073709.55, Output File : py_out_cl-tfl-mobilenet_v1_1.0_224_airshow.jpg
MEM: Deinit ... !!!
MEM: Alloc's: 26 alloc's of 27127485 bytes
MEM: Free's : 26 free's  of 27127485 bytes
Completed_Model :     3, Name : od-tfl-ssd_mobilenet_v2_300_float                 , Total time :     930.89, Offload Time :     930.88 , DDR RW MBs : 18446744073709.55, Output File : py_out_od-tfl-ssd_mobilenet_v2_300_float_ADE_val_00001801.jpg
MEM: Deinit ... !!!
MEM: Alloc's: 29 alloc's of 86511875 bytes
MEM: Free's : 29 free's  of 86511875 bytes
Completed_Model :     4, Name : od-tfl-ssdlite_mobiledet_dsp_320x320_coco         , Total time :    1429.23, Offload Time :    1429.22 , DDR RW MBs : 18446744073709.55, Output File : py_out_od-tfl-ssdlite_mobiledet_dsp_320x320_coco_ADE_val_00001801.jpg
MEM: Deinit ... !!!
MEM: Alloc's: 29 alloc's of 38501115 bytes
MEM: Free's : 29 free's  of 38501115 bytes
Completed_Model :     2, Name : ss-tfl-deeplabv3_mnv2_ade20k_float                , Total time :    4264.49, Offload Time :    4264.48 , DDR RW MBs : 18446744073709.55, Output File : py_out_ss-tfl-deeplabv3_mnv2_ade20k_float_ADE_val_00001801.jpg
MEM: Deinit ... !!!
MEM: Alloc's: 26 alloc's of 85712597 bytes
MEM: Free's : 26 free's  of 85712597 bytes
Available execution providers :  ['AzureExecutionProvider', 'CPUExecutionProvider']
Running 2 Models - ['cl-ort-resnet18-v1', 'od-ort-ssd-lite_mobilenetv2_fpn']
Running_Model :  cl-ort-resnet18-v1
Downloading   ../../../models/public/resnet18_opset9.onnx
Running_Model :  od-ort-ssd-lite_mobilenetv2_fpn
Running shape inference on model ../../../models/public/ssd-lite_mobilenetv2_fpn.onnx
/home/ace428/.local/lib/python3.10/site-packages/onnxruntime/capi/onnxruntime_inference_collection.py:69: UserWarning: Specified provider 'TIDLCompilationProvider' is not in available provider names.Available providers: 'AzureExecutionProvider, CPUExecutionProvider'
  warnings.warn(
*************** EP Error ***************
EP Error Unknown Provider Type: TIDLCompilationProvider when using ['TIDLCompilationProvider', 'CPUExecutionProvider']
Falling back to ['CPUExecutionProvider'] and retrying.
Process Process-2:
Traceback (most recent call last):
  File "/home/ace428/.pyenv/versions/3.10.14/lib/python3.10/multiprocessing/process.py", line 314, in _bootstrap
    self.run()
  File "/home/ace428/.pyenv/versions/3.10.14/lib/python3.10/multiprocessing/process.py", line 108, in run
    self._target(*self._args, **self._kwargs)
  File "/home/ace428/Desktop/edgeai-tidl-tools/examples/osrt_python/ort/onnxrt_ep.py", line 239, in run_model
    imgs, output, proc_time, sub_graph_time, height, width  = infer_image(sess, input_images, config)
  File "/home/ace428/Desktop/edgeai-tidl-tools/examples/osrt_python/ort/onnxrt_ep.py", line 135, in infer_image
    copy_time, sub_graphs_proc_time, totaltime = get_benchmark_output(sess)
  File "/home/ace428/Desktop/edgeai-tidl-tools/examples/osrt_python/ort/onnxrt_ep.py", line 84, in get_benchmark_output
    benchmark_dict = interpreter.get_TI_benchmark_data()
This is my current environment information.
Package                  Version         Editable project location
absl-py                  2.1.0
attrs                    24.2.0
autocfg                  0.0.8
caffe2onnx               1.0.2
certifi                  2024.8.30
charset-normalizer       3.3.2
cloudpickle              3.0.0
coloredlogs              15.0.1
contourpy                1.3.0
cycler                   0.12.1
dataclasses              0.6
decorator                5.1.1
distro                   1.9.0
dlr                      1.13.0
exceptiongroup           1.2.2
filelock                 3.16.0
flatbuffers              1.12
fonttools                4.53.1
fsspec                   2024.9.0
gluoncv                  0.10.5.post0
graphviz                 0.20.3
grpcio                   1.66.1
huggingface-hub          0.24.7
humanfriendly            10.0
idna                     3.8
iniconfig                2.0.0
Jinja2                   3.1.4
kiwisolver               1.4.7
Markdown                 3.7
markdown-it-py           3.0.0
MarkupSafe               2.1.5
matplotlib               3.9.2
mdurl                    0.1.2
mpmath                   1.3.0
networkx                 3.3
numpy                    1.23.0
nvidia-cublas-cu12       12.1.3.1
nvidia-cuda-cupti-cu12   12.1.105
nvidia-cuda-nvrtc-cu12   12.1.105
nvidia-cuda-runtime-cu12 12.1.105
nvidia-cudnn-cu12        9.1.0.70
nvidia-cufft-cu12        11.0.2.54
nvidia-curand-cu12       10.3.2.106
nvidia-cusolver-cu12     11.4.5.107
nvidia-cusparse-cu12     12.1.0.106
nvidia-nccl-cu12         2.20.5
nvidia-nvjitlink-cu12    12.6.68
nvidia-nvtx-cu12         12.1.105
onnx                     1.13.0
onnx_graphsurgeon        0.3.26
onnxruntime              1.19.0
onnxruntime-tidl         1.14.0+10000005
onnxsim                  0.4.35
opencv-python            4.10.0.84
osrt_model_tools         1.2             /home/ace428/Desktop/edgeai-tidl-tools/scripts
packaging                24.1
pandas                   2.2.2
pillow                   10.4.0
pip                      24.2
pluggy                   1.5.0
portalocker              2.10.1
protobuf                 3.20.3
psutil                   6.0.0
pybind11                 2.13.5
pybind11_global          2.13.5
Pygments                 2.18.0
pyparsing                3.1.4
pytest                   8.3.3
python-dateutil          2.9.0.post0
pytz                     2024.2
PyYAML                   6.0.2
requests                 2.32.3
rich                     13.8.1
safetensors              0.4.5
scipy                    1.13.1
seaborn                  0.13.2
setuptools               74.1.2
six                      1.16.0
sympy                    1.13.2
tensorboard              2.17.1
tensorboard-data-server  0.7.2
tflite                   2.10.0
tflite-runtime           2.12.0
timm                     1.0.9
tomli                    2.0.1
torch                    2.4.1
torchvision              0.19.1
tornado                  6.4.1
tqdm                     4.66.5
triton                   3.0.0
tvm                      0.12.0
typing_extensions        4.12.2
tzdata                   2024.1
urllib3                  2.2.3
Werkzeug                 3.0.4
wheel                    0.44.0
yacs                     0.1.8
How to resolve this issue?
Kathy
  • Hi Kathy; what is the version that you were using? (I did not see it in your first window). Could you try to use "git checkout <version tag>" to checkout a specific version that matches your SDK?
    you can use "git tag" to list all the available version tags.
    Best regards
    Wen Li
