Part Number: AM625
| 1. CE Test Results | ||||||||||||
--> LAN1 & LAN2 CE Test POE SUPPLY MOE
| Test | Standard | Test Mode | Result | Remarks | ||||||||
| LAN1 [POE SUPPLY] |
Limit: CLASS- B
Frequency: 150 KHz to 30 MHz |
--> POE SUPPLY Mode
Interface:- LAN1, LAN2, USB, eMMC, RTC, Temp, IR |
FAIL | LAN1_CE_POE_SUPPLY_WITH_COMN-14092024 | ||||||||
| LAN2 [POE SUPPLY] | FAIL | LAN2_CE_POE_SUPPLY_WITH_COMN-14092024 | ||||||||||
| 2. RE Test Results | ||||||||||||
-->RE Test POE SUPPLY MOE
RE [POE SUPPLY]
Limit: CLASS- B Frequency: 30mhz To 1ghz |
--> POE SUPPLY Mode
FAIL | RE_POE SUPPLY RE-30 TO 1ghz -14.09.2024 | ||||||||
| Limit: CLASS- B Frequency: 1ghz to 6ghz |
PASS | RE_POE SUPPLY_RE-1 TO 6ghz -14.09.2024 | ||||||||||
We have attached the RE & CE report and schematic design of our ACM Boards so please check and share your suggestions like what changes we should make for these components to pass this RE & CE test.
RE_POE SUPPLY RE-30 TO 1ghz -14.09.2024.PdfLAN1_CE_POE_SUPPLY_WITH_COMN-14092024.PdfLAN2_CE_POE_SUPPLY_WITH_COMN-14092024.Pdf
