C6452 GEL file conversion to C file
Hi
In converting the GEL file, there is the link error of Get_Timeout()/Set_Timeout() function.
How should I handle this?
  • YC,
    I believe this is just implementing a delay to wait for a write to take effect.  You could potentially do this in C with a for loop that spins for a defined number of cycles.  Be careful if you implement this in C using optimization.  you need to take precautions against the optimizer eliminating empty for loops.  Be sure to declare your loop counter as volatile.
    regards,
    Dan
