TDA4AP-Q1: How to Enable MCU4-0 Cache ECC
Part Number: TDA4AP-Q1
Hi TI Experts,
Customer is working on TDA4AP SDK9.2.
They are following the below FAQ to enable the R5f cache ECC.
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1360109/faq-tda4vh-q1-performing-ecc-sec-ded-tests-on-r5f-cache-memories/5188790
However, as you could see from the below picture, the address used in FAQ is for MCU1-0. And in the register manual we could only find that for MCU1-0 & MCU1-1. Customer has a dual safety channel design, both MCU1-1 & MCU4-0 are their safety channel and need to enable cache ECC. They could not find the address corresponding to the MCU4-0 in the register manual.
Could you help customer to find the register address for MCU4-0 please?
Many thanks!
Kevin
  • Hi Kevin,
    This is the base address -
    The offsets remain the same.
    Josiitaa
  • thank you , I will have a try.
  • Hi  Josiitaa,
    I have some questions when  running the  TCM ECC demo  sdl_ecc_test_app ,   why  in some test cases  would trigger an interrupt  and others not?
    I am checking this behavior with the internal team. I will get back to you.
    Josiitaa
    TCM ECC errors are routed directly to the core via VIM and not via ESM. Hence we do not see any ESM callbacks for these tests. The SW does not handle these errors.
    The few callbacks that you see are coming directly from the R5F HW.
    Josiitaa
  • Hi Josiitaa,
    Thanks for your reply, this makes sense for us!
    Customer also mentions a related strange behavior about this. They are currently testing the cache/TCM ECC, after injecting the fault, they could read the fault status from the register, that is as expected. However, if they enable the ESM reset, after injecting the error the ESM will reset before they read the fault status, and more importantly it show there is no fault after ESM reset.
    The same step customer also did for other ESM errors, but for those ESM errors even though they enable ESM reset, they could still read out the fault after the ESM reset.
    Customer does not know why cache/TCM ECC has this difference. Is that also due to that TCM errors are routed to the VIM not ESM?
    Many Thanks,
    Kevin
  • Hi Kevin,
    Yes, this may also be because the TCM errors are routed to the R5F directly.
    Josiitaa
  • When I inject cache ecc error  in MCU4_0,  and MCU1_1 will run to die loop,  Why  cache ecc error of MCU4_0  impact  MCU1_1 runnning?
    MCU4_0  CACHE inject error code
    void BSW_TestCacheEcc(uint8_t inject_error)
    OSAL_log(PRINT_LEVEL_INFO, logbuf, "\nCache Ecc test start: \n");
    #define INJECT_ERROR_REGISTERs_MCU10 (0x40080000U) //
    #define INJECT_ERROR_REGISTERs_MCU11 (0x400C0000U) //
    #define INJECT_ERROR_REGISTERs_MCU40 (0x02A6B000U) //
    #define OFFSET_RAMID (0x08U) //
    #define OFFSET_CTRL_REG (0x14U) //
    #define OFFSET_CTRL_ERROR_REG (0x1CU) //
    #define INJECT_ERROR_REGISTER INJECT_ERROR_REGISTERs_MCU40
    #define ARRAY_SIZE (5) // Size of the array in bytes (32KB)
        uint8_t a[ARRAY_SIZE];
        uint8_t b[ARRAY_SIZE];
        // uint32_t *ptr1 = (uint32_t *)0x0E000028;
        // OSAL_log(PRINT_LEVEL_INFO, logbuf, "\nCache Ecc test start: 0x%8x\n" , *ptr1);
        for (uint32_t iii = 0; iii < ARRAY_SIZE; iii++)
            a[iii] = (iii % 256) + 1;
        OSAL_log(PRINT_LEVEL_INFO, logbuf, "\ninject one bit error\n");
        // if(inject_error == 0)
            // a. For single bit error injection:
            uint32_t *ptr2 = (uint32_t *)(INJECT_ERROR_REGISTER + OFFSET_RAMID); // Set RAM ID
            *ptr2 = 0x8;
            uint32_t *ptr3 = (uint32_t *)(INJECT_ERROR_REGISTER + OFFSET_CTRL_REG); // ECC Ctrl Reg
            *ptr3 = 0x28;                            // 0x28 for Data RAM IDs, 0x68 for Tag RAM IDs
            asm("NOP");                              // Enable ECC for Cache memories, Inject error into RAM ID 8
        OSAL_log(PRINT_LEVEL_INFO, logbuf, "\ninject two bit error\n");
        // else
            // b. For double bit error injection:
            *ptr2 = 0x8;
            uint32_t *ptr4 = (uint32_t *)(INJECT_ERROR_REGISTER + OFFSET_CTRL_ERROR_REG); // ECC Error Control2 reg
            *ptr4 = 0x30002;
            *ptr3 = 0x70;                            // 0x30 for Data RAM IDs, 0x70 for Tag RAM IDs
        OSAL_log(PRINT_LEVEL_INFO, logbuf, "\ninject end\n");
        // Access the cache memory region to trigger error
        for (uint32_t i = 0; i < ARRAY_SIZE; i++)
            b[i] = a[i];
        OSAL_log(PRINT_LEVEL_INFO, logbuf, "Cache Ecc test start: pass ,  gEccError %d \n", gEccError);
    And Here is  MCU1_1 running log:
    Are you also seeing the ESM status bit/ callback on the MCU4_0 core after injection?
    Josiitaa
  • No,   MCU1_1  manages  wkup/main/mcu  ESM modules.
    The error event 364 that your are getting corresponds to the MCU4_0. It is correct. You are seeing the callbacks on the MCU1_1 because the ESM is setup there.
    If you wish to clear the error, please set the ECC Ctrl Reg to 0 in the callback function.
    Josiitaa
  • Hi Josiitaa,
    I clear ECC Ctrl Reg  to 0 , but not help. Also  clear  ESM error.
    #define ECC_AGGR_MCU10 (0x40080000U) //
    #define ECC_AGGR_MCU11 (0x400C0000U) //
    #define ECC_AGGR_MCU40 (0x02A68000U) //
    static int32_t esmCallbackFunction(SDL_ESM_Inst esmInst,
                                        SDL_ESM_IntType esmIntrType,
                                        uint32_t grpChannel,
                                        uint32_t index,
                                        uint32_t intSrc,
                                        void *arg)
        SELFTEST_PRINTF("\n  ESM Call back function called : instType 0x%x, intType 0x%x, " \
                    "grpChannel 0x%x, index 0x%x, intSrc 0x%x ",
                    esmInst, esmIntrType, grpChannel, index, intSrc);
        if((SDLR_ESM0_ESM_LVL_EVENT_R5FSS2_COMMON0_ECC_SE_TO_ESM_0_0 <= intSrc && intSrc <= SDLR_ESM0_ESM_LVL_EVENT_R5FSS2_COMMON0_ECC_DE_TO_ESM_1_0) ||
            (SDLR_MCU_ESM0_ESM_LVL_EVENT_MCU_R5FSS0_COMMON0_ECC_SE_TO_ESM_0_0 <= intSrc && intSrc <= SDLR_MCU_ESM0_ESM_LVL_EVENT_MCU_R5FSS0_COMMON0_ECC_DE_TO_ESM_1_0))
            uint32_t *ptr3 = (uint32_t *)(ECC_AGGR_MCU11 + OFFSET_CTRL_REG);
            *ptr3 = 0;
            ptr3 = (uint32_t *)(ECC_AGGR_MCU40 + OFFSET_CTRL_REG);
            *ptr3 = 0;
            SDL_setEccError(true);
            SELFTEST_PRINTF("TCM VIM CACHE ECC ERROR: %d", intSrc);
        SELFTEST_ESMClrAllIntr();
        return SDL_PASS;
    Can you try adding the below lines after error injection and after setting the CTRL reg to 0?
    uint32_t *ptr5=(uint32_t *)0x40080008; // ECC vector Reg
    *ptr5=0x148000;
    while(((*ptr5>>24)&0x1)!=1)
    I have included the same in the FAQ for error injection.
    Additionally, you can include this in the callback for clearing after setting the ECC CTRL reg to 0.
    Josiitaa
  • Hi Josiitaa,
    I added the code  but it didn't help.
    Are you still seeing the ESM STS register error bit set? Make sure to stop the error injection, set the CTRL register value and clear the ESM STS bit. You can use the SDL_ESM_clearIntrStatus API to clear ESM status.
    Josiitaa
  • The MCU4_0 run to died loop I think it cann't do the error injection job.    In MCU1_1  I had clear ESM status , set  MCU1_1 ECC CTRL(0x40080014)to 0 and  MCU4_0 ECC CTRL 0x02A68014U to 0.
    What do you mean by died loop? You are getting the ESM callback only because of the error injection to the MCU4_0 ECC aggregator right?
    Josiitaa
  • (1)MCU4_0 after inject errors , it will goto died  loop  Data Abort.
    (2)Yes,  and  set the error injection to the MCU4_0  only once but  MCU1_1 will get in ESM callback loop , clear ECC CTRL and  ESM error , the ESM callback  loop cann't be ended.
    Are  you injecting single bit or double bit errors? Can you use the same steps in the SDL TCM example to do the injection on MCU4_0? The FAQ is mainly for cache memories where we have used the FORCE_N_ROW macro to inject errors continuously.
    Josiitaa
  • (1)step 1 : injecting single bit -----and MCU4_0 goto  died loop Data Abort  other steps not run.
    (2)step 2: injecting double bit .
    (3)step 3:  report pass or failure;
    Can you use the same steps in the SDL TCM example to do the injection on MCU4_0?  I will have a try.
    It is better to try one step at a time. Try to get single bit error injection for MCU4_0 working using the SDL TCM example.
    Josiitaa
  • Hi Josiitaa,
    I had tried as you mention  but MCU4-0 goto died loop, and MCU1-1 loop in ESM callback.
    Can you share the changes that you have made to the standalone test app as a patch?
    Josiitaa
  • I reproduced it in  sdl_ecc_test_app,  only run it MCU1_0, the error code cann't clear.  You can copy the code  to the file sdl/test/ecc/ecc_sdl/ecc_test_func.c to have a try.
     *   Copyright (c) Texas Instruments Incorporated 2019-2021
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  \file     ecc_test_func.c
     *  \brief    This file contains ECC SDL Function test code for R5 core.
     *  \details  ECC SDL API module tests
    /*                             Include Files                                  */
    #include <stdint.h>
    #include <soc.h>
    #include <sdl_types.h>
    #include <src/sdl/sdl_ecc.h>
    #include <ti/drv/uart/UART_stdio.h>
    #include <sdl_cache.h>
    #include <interrupt.h>
    #include <sdl_exception.h>
    #include <sdl_arm_r5_pmu.h>
    #include <common/ecc_test_main.h>
    #include <sdl_esm.h>
    /* Osal API header files */
    #include <ti/osal/HwiP.h>
    #include <ti/osal/TimerP.h>
    /*                                Macros                                      */
    #define ATCM_BASE_ADDR  (0x00000000U)
    #define ATCM_SIZE       (0x00008000U)
    #define TEST_AREA_SIZE  (0x00000400U)
    #define ATCM_FILL_PATTERN (0xffffffffU)
    #define UART_printf printf
    /*                            Global Variables                                */
    SDL_ESM_config ECC_Test_esmInitConfig_WKUP =
        .esmErrorConfig = {0u, 8u}, /* Self test error config */
        .enableBitmap = {0xffffffffu, 0x00180003u, 0xffffffffu,
         /**< All events enable: except clkstop events for unused clocks */
        .priorityBitmap = {0xffffffffu, 0x00180003u, 0xffffffffu,
        /**< All events high priority: except clkstop events for unused clocks */
        .errorpinBitmap = {0xffffffffu, 0x00180003u, 0xffffffffu,
        /**< All events high priority: except clkstop for unused clocks
         *   and selftest error events */
    #if defined (SOC_J721E)||(SOC_J7200)
    SDL_ESM_config ECC_Test_esmInitConfig_MCU =
        .esmErrorConfig = {0u, 3u}, /* Self test error config */
        .enableBitmap = {0xffffffffu, 0xff03ffffu, 0x7fffffffu, 0x00000007u,
         /**< All events enable: except timer and self test  events, and Main ESM output */
        /* Temporarily disabling vim compare error as well*/
        .priorityBitmap = {0xffffffffu, 0xff03ffffu, 0x7fffffffu, 0x00000007u,
        /**< All events high priority: except timer, selftest error events, and Main ESM output */
        .errorpinBitmap = {0xffffffffu, 0xff03ffffu, 0x7fffffffu, 0x00000007u,
    SDL_ESM_config ECC_Test_esmInitConfig_MAIN =
        .esmErrorConfig = {1u, 8u}, /* Self test error config */
        .enableBitmap = {0x00000000u, 0xfffffffbu, 0x7fffffffu, 0xffffffffu,
                     0xffffffffu, 0xffffffffu, 0xffffffffu, 0xffffffffu,
                     0xffffffffu, 0xffffffffu, 0xffffffffu, 0x00000000u,
                     0x00000000u, 0x00000000u, 0x00000000u, 0x00003c0fu,
                     0xffffffffu,
          *   and PCIE events */
        .priorityBitmap = {0x00000000u, 0xfffffffbu, 0x7fffffffu, 0xffffffffu,
                             0x00000000u, 0x00000000u, 0x00000000u, 0x00000000u,
                             0xffffffffu,
        .errorpinBitmap = {0x00000000u, 0xfffffffbu, 0x7fffffffu, 0xffffffffu,
                           0xffffffffu,
    #endif
    #if defined (SOC_J721S2)
        .enableBitmap = {0xfffffffbu, 0xff33ffffu, 0x7fffffffu, 0x00000007u,
        .priorityBitmap = {0xfffffffbu, 0xff33ffffu, 0x7fffffffu, 0x00000007u,
        .errorpinBitmap = {0xfffffffbu, 0xff33ffffu, 0x7fffffffu, 0x00000007u,
        .enableBitmap = {0x00000000u, 0xffffffdbu, 0x7fffffffu, 0xffffffffu,
                     0xfffbfeffu,
        .priorityBitmap = {0x00000000u, 0xffffffdbu, 0x7fffffffu, 0xffffffffu,
                             0xfffbfeffu,
        .errorpinBitmap = {0x00000000u, 0xffffffdbu, 0x7fffffffu, 0xffffffffu,
                           0xfffbfeffu,
    #endif
    #if defined (SOC_J784S4)
    // SDL_ESM_config ECC_Test_esmInitConfig_MCU =
    //     .esmErrorConfig = {0u, 3u}, /* Self test error config */
    //     .enableBitmap = {0xfffffffbu, 0xff33ffffu, 0x7fffffffu, 0x00000007u,
    //      /**< All events enable: except timer and self test  events, and Main ESM output */
    //     /* Temporarily disabling vim compare error as well*/
    //     .priorityBitmap = {0xfffffffbu, 0xff33ffffu, 0x7fffffffu, 0x00000007u,
    //     /**< All events high priority: except timer, selftest error events, and Main ESM output */
    //     .errorpinBitmap = {0xfffffffbu, 0xff33ffffu, 0x7fffffffu, 0x00000007u,
    SDL_ESM_config ECC_Test_esmInitConfig_MCU = //kong test
        .enableBitmap = {0xfffffffbu, 0xff3fffffu, 0x7fffffffu, 0x00000007u,
        .priorityBitmap = {0xfffffffbu, 0xff3fffffu, 0x7fffffffu, 0x00000007u,
        .errorpinBitmap = {0xfffffffbu, 0xff03ffffu, 0x7fffffffu, 0x00000007u,
                       0xffffffffu, 0xfffffffbu, 0xffffffffu, 0xffffffffu,
                       0xffff7fffu, 0xffffffffu, 0xffffffffu, 0x00000000u,
                       0xfffbfeffu,
                       0xfffbfeffu,
                       0xfffbfeffu,
    #endif
    // extern int32_t SDL_ESM_applicationCallbackFunction(SDL_ESM_Inst esmInstType,
    //                                                    SDL_ESM_IntType esmIntType,
    //                                                    uint32_t grpChannel,
    //                                                    uint32_t index,
    //                                                    uint32_t intSrc,
    //                                                    void *arg);
    int32_t my_ESM_applicationCallbackFunction(SDL_ESM_Inst esmInstType,
                                                       uint32_t index,
                                                       uint32_t intSrc,
                                                       void *arg)
        uint32_t esmInstBaseAddr;
        printf("\n  ESM Call back function called : instType 0x%x, intType 0x%x, "
               esmInstType, esmIntType, grpChannel, index, intSrc);
        uint32_t *ptr3 = (uint32_t *)(ECC_AGGR_MCU10 + OFFSET_CTRL_REG);
        *ptr3 = 0;
        uint32_t *ptr5 = (uint32_t *)(ECC_AGGR_MCU10 + OFFSET_RAMID);
        *ptr5 = 0x148000;
        while (((*ptr5 >> 24) & 0x1) != 1)
            static uint32_t count = 0;
            count++;
            if (count == 1000000)
                printf("ECC clear timed out 0");
                count = 0;
        SDL_ESM_getBaseAddr(esmInstType, &esmInstBaseAddr);
        (void)SDL_ESM_enableIntr(esmInstBaseAddr, intSrc);
        return 0;
    /*                 Internal Function Declarations                             */
    extern int32_t ECC_Test_UTILS_TCMEnable(void);
    void ECC_Test_UTILS_initATCM(void)
        memset(ATCM_BASE_ADDR, ATCM_FILL_PATTERN, (ATCM_SIZE-TEST_AREA_SIZE));
    /*                          Function Definitions                              */
    /* Defines */
    #define MCU_R5F_MAX_MEM_SECTIONS   (7u)
    /* Function prototypes */
    void ECC_Test_copyResetVector(void);
    int32_t ECC_Test_EsmInitHandlerInit(SDL_ESM_Inst esmInstType);
    int32_t ECC_Test_init (void);
    void ECC_Test_VIMDEDInterruptHandler(void);
    static SDL_ECC_MemSubType ECC_Test_R5FCoresubMemTypeList[MCU_R5F_MAX_MEM_SECTIONS] =
        SDL_ECC_R5F_MEM_SUBTYPE_ATCM0_BANK0_VECTOR_ID,
        SDL_ECC_R5F_MEM_SUBTYPE_ATCM0_BANK1_VECTOR_ID,
        SDL_ECC_R5F_MEM_SUBTYPE_KS_VIM_RAM_VECTOR_ID,
        SDL_ECC_R5F_MEM_SUBTYPE_B0TCM0_BANK0_VECTOR_ID,
        SDL_ECC_R5F_MEM_SUBTYPE_B0TCM0_BANK1_VECTOR_ID,
        SDL_ECC_R5F_MEM_SUBTYPE_B1TCM0_BANK0_VECTOR_ID,
        SDL_ECC_R5F_MEM_SUBTYPE_B1TCM0_BANK1_VECTOR_ID,
    static SDL_ECC_InitConfig_t ECC_Test_R5FCoreECCInitConfig =
        .numRams = MCU_R5F_MAX_MEM_SECTIONS,
        /**< Number of Rams ECC is enabled  */
        .pMemSubTypeList = &(ECC_Test_R5FCoresubMemTypeList[0]),
        /**< Sub type list  */
    #ifdef SOC_J721E
    #define MCU_CBASS_MAX_MEM_SECTIONS (3u)
    #define MAIN_MSMC_AGGR0_MAX_MEM_SECTIONS (5u)
    static SDL_ECC_MemSubType ECC_Test_MCUCBASSsubMemTypeList[MCU_CBASS_MAX_MEM_SECTIONS] =
        SDL_MCU_CBASS_ECC_AGGR0_IMCU_COR_FW_VBUSP_32B_SOC_FW_SAFEG_WR_RAMECC_RAM_ID,
        SDL_MCU_CBASS_ECC_AGGR0_IMCU_COR_FW_VBUSP_32B_SOC_FW_SAFEG_RD_RAMECC_RAM_ID,
        SDL_MCU_CBASS_ECC_AGGR0_IMCU_COR_FW_VBUSP_32B_SOC_FW_SAFEG_EDC_CTRL_RAM_ID
    static SDL_ECC_InitConfig_t ECC_Test_MCUCBASSECCInitConfig =
        .numRams = MCU_CBASS_MAX_MEM_SECTIONS,
        .pMemSubTypeList = &(ECC_Test_MCUCBASSsubMemTypeList[0]),
    static SDL_ECC_MemSubType ECC_Test_MAINMSMC_A0subMemTypeList[MAIN_MSMC_AGGR0_MAX_MEM_SECTIONS] =
        SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_DRU_CBASS_MMR_CFG_EDC_RAM_ID,
        SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_MSMC_MMR_BUSECC_RAM_ID,
    	SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_RMW2_CACHE_TAG_PIPE_BUSECC_RAM_ID,
        SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_CLEC_SRAM_RAMECC_RAM_ID,
    	SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_CLEC_J7ES_CLEC_EDC_CTRL_BUSECC_RAM_ID,
    static SDL_ECC_InitConfig_t ECC_Test_MAINMSMCA0ECCInitConfig =
        .numRams = MAIN_MSMC_AGGR0_MAX_MEM_SECTIONS,
        .pMemSubTypeList = &(ECC_Test_MAINMSMC_A0subMemTypeList[0]),
    #endif
    #ifdef SOC_J7200
    #define MCU_NAVSS0_MAX_MEM_SECTIONS (1u)
    #define MAIN_MSMC_AGGR0_MAX_MEM_SECTIONS (2u)
    #define SDL_MMCSD0_MAX_MEM_SECTIONS (2u)
    static SDL_ECC_MemSubType ECC_Test_MCU_NAVSS0subMemTypeList[MCU_NAVSS0_MAX_MEM_SECTIONS] =
        SDL_VC_MAIN_HC_ECC_AGGR5_J7VC_HC2_CBASS_J7VC_RC_TO_HC2_VBUSM_M2M_BRIDGE_J7VC_HC2_CBASS_J7VC_RC_TO_HC2_VBUSM_M2M_BRIDGE_SRC_EDC_CTRL_BUSECC_RAM_ID,
    static SDL_ECC_InitConfig_t ECC_Test_MCU_NAVSS0ECCInitConfig =
        .numRams = MCU_NAVSS0_MAX_MEM_SECTIONS,
        .pMemSubTypeList = &(ECC_Test_MCU_NAVSS0subMemTypeList[0]),
    static SDL_ECC_MemSubType ECC_Test_SDL_MMCSD0subMemTypeList[ MCU_NAVSS0_MAX_MEM_SECTIONS] =
        SDL_MCU_VC_MCU_ECC_AGGR0_IMCU_COR_FW_VBUSP_32B_SOC_FW_SAFEG_EDC_CTRL_RAM_ID,
    static SDL_ECC_InitConfig_t ECC_Test_SDL_MMCSD0ECCInitConfig =
        .pMemSubTypeList = &(ECC_Test_SDL_MMCSD0subMemTypeList[0]),
    static SDL_ECC_MemSubType ECC_Test_SDL_NAVSS0_1subMemTypeList[ SDL_MMCSD0_MAX_MEM_SECTIONS] =
        SDL_NAVSS0_NAVSS256VCL_UDMASS_UDMASS_ECCAGGR0_EDC_CTRL_RAM_ID,
    	SDL_NAVSS0_NAVSS256VCL_UDMASS_UDMAP0_TPCFG_PSTATE_RAM_ID
    static SDL_ECC_InitConfig_t ECC_Test_NAVSS0_1InitConfig =
        .numRams = 1u,
        .pMemSubTypeList = &(ECC_Test_SDL_NAVSS0_1subMemTypeList[0]),
        SDL_COMPUTE_CLUSTER0_A72_J7_1MB_WRAP_A72_DUAL_MID_ECC_AGGR_CPU1_EDC_CTRL_RAM_ID,
    	SDL_COMPUTE_CLUSTER0_CPU1_IF_DATA_SPRAM_BANK0_ECC_SVBUS_RAM_ID
    #endif
    #ifdef SOC_J721S2
    #define MAIN_MSMC_AGGR0_MAX_MEM_SECTIONS (4u)
    	SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AE_MSMC_EN_DRU_MSMC_EN_4MB_WRAP_MSMC_4MB_MSMC_WRAP_ECC_AGGR0_DRU0_CBASS_MMR_CFG_EDC_RAM_ID,
        SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AE_P0_A72_DUAL_1MB_A72_DUAL_MID_ECC_AGGR_CPU1_A72_J7_1MB_WRAP_A72_DUAL_MID_ECC_AGGR_CPU1_EDC_CTRL_RAM_ID,
    	SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AE_P0_A72_DUAL_1MB_A72_DUAL_MID_ECC_AGGR_CPU1_CPU1_IF_DATA_SPRAM_BANK0_ECC_SVBUS_RAM_ID,
    	SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AE_MSMC_EN_DRU_MSMC_EN_4MB_WRAP_MSMC_4MB_MSMC_WRAP_ECC_AGGR0_DRU0_CBASS_MMR_FW_CH_EDC_RAM_ID
    static SDL_ECC_MemSubType ECC_Test_WKUP_VTM0subMemTypeList[MCU_NAVSS0_MAX_MEM_SECTIONS] =
        SDL_WKUP_VTM0_K3VTM_N16FFC_ECCAGGR_K3VTM_N16FFC_CFG_CBASS_VBUSP_P2P_BRIDGE_EDC_CTRL_0_RAM_ID,
    static SDL_ECC_InitConfig_t ECC_Test_WKUP_VTM0ECCInitConfig =
        .pMemSubTypeList = &(ECC_Test_WKUP_VTM0subMemTypeList[0]),
        SDL_NAVSS0_NAVSS512J7AM_MODSS_ECCAGGR0_NAVSS512J7AM_MODSS_ECCAGGR0_EDC_CTRL_RAM_ID,
    	SDL_NAVSS0_NAVSS512J7AM_MODSS_ECCAGGR0_NAVSS512J7AM_MODSS_SPINLOCK0_EDC_CTRL_0_RAM_ID
        .numRams = 1u,
        SDL_MCUM_MCU_ECC_AGGR0_J7AM_MCU_ECC_AGGR_IMCU_COR_FW_VBUSP_32B_SOC_FW_SAFEG_EDC_CTRL_RAM_ID,
    #endif
    #ifdef SOC_J784S4
        SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AHP_MSMC_EN_DRU_MSMC_EN_8MB_WRAP_MSMC_8MB_MSMC_WRAP_ECC_AGGR0_DRU0_CBASS_MMR_CFG_EDC_RAM_ID,
        SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AHP_MSMC_EN_DRU_MSMC_EN_8MB_WRAP_MSMC_8MB_MSMC_WRAP_ECC_AGGR0_VBUSP_DMSC_CBASS_DRU0_MMR_FW_BRIDGE_DST_BUSECC_RAM_ID,
        SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AHP_MSMC_EN_DRU_MSMC_EN_8MB_WRAP_MSMC_8MB_MSMC_WRAP_ECC_AGGR0_MSMC_LAMBDA3_WRAP_MSMC_QOR_MSMC_CORE_EMIF_PIPE_EMIF0_SLAVE_PIPE_EMIF_SLV_EDC_CTRL_0_RAM_ID,
    	SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AHP_MSMC_EN_DRU_MSMC_EN_8MB_WRAP_MSMC_8MB_MSMC_WRAP_ECC_AGGR0_MSMC_LAMBDA3_WRAP_MSMC_QOR_MSMC_CORE_EMIF_PIPE_EMIF0_DP_TO_VBUSMC_EDC_CTRL_0_RAM_ID,
        .numRams = 1u,
    #endif
    static void timerFxn(uintptr_t arg)
        return;
    static void VIM_Test_startTimer(void)
        TimerP_Params  timerParams;
        TimerP_Handle  timerHandle;
        /* Initialize the parameters */
        TimerP_Params_init(&timerParams);
        timerParams.startMode = (uint32_t)TimerP_StartMode_USER;
        timerParams.periodType = (uint32_t)TimerP_PeriodType_MICROSECS;
        timerParams.period    = 1000000u;
        timerHandle = TimerP_create(TimerP_ANY, (TimerP_Fxn)&timerFxn, &timerParams);
        if ( timerHandle != NULL_PTR)
            /* start the timer */
            (void)TimerP_start(timerHandle);
    HwiP_Handle ECC_Test_EsmHiHwiPHandle;
    HwiP_Handle ECC_Test_EsmLoHwiPHandle;
    HwiP_Handle ECC_Test_EsmCfgHwiPHandle;
    extern void *_resetvectors;
    #define VECTOR_SIZE 0x100
    #define APP_MAX_PROFILE_SIZE 16
    void ECC_Test_cpuCacheInv(const void * addr, int32_t size)
        SDL_armR5CacheInv(addr, size);
    void ECC_Test_cpuCacheWbInv(const void * addr, int32_t size)
        SDL_armR5CacheWbInv(addr, size);
        /* Invalidate cache */
        ECC_Test_cpuCacheInv(0, VECTOR_SIZE);
        /* copy the vectors into 0 location */
        /* Vectors are always assumed to be at 0 for R5 */
        memcpy(0, &_resetvectors, VECTOR_SIZE);
        /* Write back cache */
        ECC_Test_cpuCacheWbInv(0, VECTOR_SIZE);
    /* This is the list of exception handle and the parameters */
    const SDL_R5ExptnHandlers ECC_Test_R5ExptnHandlers =
        .udefExptnHandler = &SDL_EXCEPTION_undefInstructionExptnHandler,
        .swiExptnHandler = &SDL_EXCEPTION_swIntrExptnHandler,
        .pabtExptnHandler = &SDL_EXCEPTION_prefetchAbortExptnHandler,
        .dabtExptnHandler = &SDL_EXCEPTION_dataAbortExptnHandler,
        .irqExptnHandler = &SDL_EXCEPTION_irqExptnHandler,
        .fiqExptnHandler = &SDL_EXCEPTION_fiqExptnHandler,
        .udefExptnHandlerArgs = ((void *)0u),
        .swiExptnHandlerArgs = ((void *)0u),
        .pabtExptnHandlerArgs = ((void *)0u),
        .dabtExptnHandlerArgs = ((void *)0u),
        .irqExptnHandlerArgs = ((void *)0u),
    void ECC_Test_undefInstructionExptnCallback(void)
        UART_printf("\n Undefined Instruction exception");
    void ECC_Test_swIntrExptnCallback(void)
        UART_printf("\n Software interrupt exception");
    void ECC_Test_prefetchAbortExptnCallback(void)
        UART_printf("\n Prefetch Abort exception");
    void ECC_Test_dataAbortExptnCallback(void)
        UART_printf("\n Data Abort exception");
    void ECC_Test_irqExptnCallback(void)
        UART_printf("\n Irq exception");
    void ECC_Test_fiqExptnCallback(void)
        UART_printf("\n Fiq exception");
    void ECC_Test_exceptionInit(void)
        SDL_EXCEPTION_CallbackFunctions_t exceptionCallbackFunctions =
                 .udefExptnCallback = ECC_Test_undefInstructionExptnCallback,
                 .swiExptnCallback = ECC_Test_swIntrExptnCallback,
                 .pabtExptnCallback = ECC_Test_prefetchAbortExptnCallback,
                 .dabtExptnCallback = ECC_Test_dataAbortExptnCallback,
                 .irqExptnCallback = ECC_Test_irqExptnCallback,
                 .fiqExptnCallback = ECC_Test_fiqExptnCallback,
        /* Initialize SDL exception handler */
        SDL_EXCEPTION_init(&exceptionCallbackFunctions);
        /* Register SDL exception handler */
        Intc_RegisterExptnHandlers(&ECC_Test_R5ExptnHandlers);
        return;
    static uint32_t arg;
    * @fn      ECC_Test_init
    * @brief   Initializes Software Diagostics Test Framework
    * @param   None
    * @return    0 : Success; < 0 for failures
        int32_t retValue=0;
        void *ptr = (void *)&arg;
        SDL_ErrType_t result;
        SDL_ECC_staticRegs staticRegs;
        // /* Enable ATCM and BTCM */
        // ECC_Test_UTILS_TCMEnable();
        // /* Initialize ATCM */
        // ECC_Test_UTILS_initATCM();
        // Board_initCfg boardCfg;
        // boardCfg = BOARD_INIT_PINMUX_CONFIG |
        //            BOARD_INIT_UART_STDIO;
        // Board_init(boardCfg);
        // UART_printf("\nECC_Test_init: UART ready to print, proceeding with ECC_Test init \n");
        // UART_printf("\nECC_Test_init: Profile init complete \n");
        /* Call Init for ECC_Test software structures */
        /* Copy reset vector to 0 location */
        // ECC_Test_copyResetVector();
        // UART_printf("\nECC_Test_init: Copy Reset vector complete \n");
        // /* Initialise exception handler */
        // ECC_Test_exceptionInit();
        // UART_printf("\nECC_Test_init: Exception init complete \n");
        // /* Timer is used to trigger the interrupt vector used for VIM DED Handler error */
        // VIM_Test_startTimer();
        // /* Register VIM DED interrupt handler */
        // SDL_ECC_registerVIMDEDHandler(&ECC_Test_VIMDEDInterruptHandler);
        UART_printf("\nECC_Test_init: register VIM DED Handler complete \n");
        if (retValue == 0) {
            /* Initialize MCU ESM module */
            result = SDL_ESM_init(SDL_ESM_INST_MCU_ESM0, &ECC_Test_esmInitConfig_MCU, my_ESM_applicationCallbackFunction, ptr);
            if (result != SDL_PASS) {
                /* print error and quit */
                 UART_printf("ECC_Test_init: Error initializing MCU ESM: result = %d\n", result);
                retValue = -1;
            } else {
                UART_printf("\nECC_Test_init: Init MCU ESM complete \n");
            /* Initialize WKUP ESM module */
            result = SDL_ESM_init(SDL_ESM_INST_WKUP_ESM0, &ECC_Test_esmInitConfig_WKUP,my_ESM_applicationCallbackFunction,ptr);
                 UART_printf("ECC_Test_init: Error initializing WKUP ESM: result = %d\n", result);
                retValue = -1;
            } else {
                UART_printf("\nECC_Test_init: Init WKUP ESM complete \n");
            /* Initialize MAIN ESM module */
            result = SDL_ESM_init(SDL_ESM_INST_MAIN_ESM0, &ECC_Test_esmInitConfig_MAIN,my_ESM_applicationCallbackFunction,ptr);
                UART_printf("ECC_Test_init: Error initializing MAIN ESM: result = %d\n", result);
                retValue = -1;
            } else {
                UART_printf("\nECC_Test_init: Init MAIN ESM complete \n");
            /* Initialize ECC */
            result = SDL_ECC_init(SDL_ECC_MEMTYPE_MCU_R5F0_CORE, &ECC_Test_R5FCoreECCInitConfig);
                UART_printf("ECC_Test_init: Error initializing R5F core ECC: result = %d\n", result);
                retValue = -1;
            } else {
                UART_printf("\nECC_Test_init: R5F Core ECC Init complete \n");
            /* Read back the static registers */
            result = SDL_ECC_getStaticRegisters(SDL_ECC_MEMTYPE_MCU_R5F0_CORE, &staticRegs);
                UART_printf("ECC_Test_init: Error reading the static registers: result = %d\n", result);
                retValue = -1;
            } else {
                UART_printf("\nECC_Test_init: R5F Memtype Register Readback successful \n");
    // #if defined (SOC_J721E)
    //     if (retValue == 0) {
    //         /* Initialize ECC */
    //         result = SDL_ECC_init(SDL_ECC_MEMTYPE_MCU_CBASS_ECC_AGGR0, &ECC_Test_MCUCBASSECCInitConfig);
    //         if (result != SDL_PASS) {
    //             /* print error and quit */
    //              UART_printf("ECC_Test_init: Error initializing R5F core ECC: result = %d\n", result);
    //             retValue = -1;
    //         } else {
    //             UART_printf("\nECC_Test_init: MCU CBASS ECC Init complete \n");
    //         /* Read back the static registers */
    //         result = SDL_ECC_getStaticRegisters(SDL_ECC_MEMTYPE_MCU_CBASS_ECC_AGGR0, &staticRegs);
    //             UART_printf("ECC_Test_init: Error reading the static registers: result = %d\n", result);
    //             retValue = -1;
    //         } else {
    //             UART_printf("\nECC_Test_init: R5F Memtype Register Readback successful \n");
    // #endif
    // #if defined (SOC_J7200)
    //         result = SDL_ECC_init(SDL_ECC_VC_MAIN_HC_ECC_AGGR5_ECC_AGGR, &ECC_Test_MCU_NAVSS0ECCInitConfig);
    //              UART_printf("ECC_Test_init: Error initializing MCU_NAVSS0 ECC: result = %d\n", result);
    //             retValue = -1;
    //         } else {
    //             UART_printf("\nECC_Test_init: MCU_NAVSS0 ECC Init complete \n");
    //         result = SDL_ECC_init(SDL_ECC_NAVSS0_1_ECC_AGGR, &ECC_Test_NAVSS0_1InitConfig);
    //              UART_printf("ECC_Test_init: Error initializing MAIN ECC_COMPUTE_CLUSTER0_2  ECC: result = %d\n", result);
    //             retValue = -1;
    //         } else {
    //             UART_printf("\nECC_Test_init: MAIN ECC_COMPUTE_CLUSTER0_2 ECC Init complete \n");
    //         result = SDL_ECC_init(SDL_ECC_MCU_VC_MCU_ECC_AGGR0, &ECC_Test_SDL_MMCSD0ECCInitConfig);
    //             retValue = -1;
    //         } else {
    //         result = SDL_ECC_getStaticRegisters(SDL_ECC_VC_MAIN_HC_ECC_AGGR5_ECC_AGGR, &staticRegs);
    //             UART_printf("ECC_Test_init: Error reading the MCU_NAVSS0 ECC static registers: result = %d\n", result);
    //             retValue = -1;
    //         } else {
    //             UART_printf("\nECC_Test_init: MCU_NAVSS0 Memtype Register Readback successful \n");
    // #endif
    // #if defined (SOC_J721E) || defined (SOC_J7200) || defined (SOC_J721S2) || defined (SOC_J784S4)
    //     /* Initialize an ECC aggregator type that requires mapping.
    //      * This example only shows MSMC_AGGR0 instance.*/
    //         result = SDL_ECC_init(SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0, &ECC_Test_MAINMSMCA0ECCInitConfig);
    //              UART_printf("ECC_Test_init: Error initializing MAIN_MSMC ECC: result = %d\n", result);
    //             retValue = -1;
    //         } else {
    //             UART_printf("\nECC_Test_init: MAIN_MSMC ECC Init complete \n");
    //     /* Test the path for MSMC mapping */
    //         result = SDL_ECC_getStaticRegisters(SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0, &staticRegs);
    //             retValue = -1;
    //         } else {
    //             UART_printf("\nECC_Test_init: MAIN_MSMC Memtype Register Readback successful \n");
    // #endif
    // #if defined (SOC_J721S2) || defined (SOC_J784S4)
    //         result = SDL_ECC_init(SDL_NAVSS0_1_ECC_AGGR, &ECC_Test_NAVSS0_1InitConfig);
    //             retValue = -1;
    //         } else {
    //         result = SDL_ECC_init(SDL_MCU_NAVSS0_0_ECC_AGGR, &ECC_Test_WKUP_VTM0ECCInitConfig);
    //             retValue = -1;
    //         } else {
    //         result = SDL_ECC_init(SDL_MCUM_MCU_ECC_AGGR0_ECC_AGGR, &ECC_Test_SDL_MMCSD0ECCInitConfig);
    //             retValue = -1;
    //         } else {
    //         result = SDL_ECC_init(SDL_WKUP_VTM0_ECC_AGGR, &ECC_Test_WKUP_VTM0ECCInitConfig);
    //             retValue = -1;
    //         } else {
    // #endif
        //     /* Initialize ECC callbacks within the MCU ESM */
        //     result = SDL_ECC_initEsm(SDL_ESM_INST_MCU_ESM0);
        //          UART_printf("ECC_Test_init: Error initializing ECC callback for MCU ESM: result = %d\n", result);
        //         retValue = -1;
        //     } else {
        //         UART_printf("\nECC_Test_init: ECC Callback Init complete for MCU ESM \n");
        //     /* Initialize ECC callbacks within the Main ESM */
        //     result = SDL_ECC_initEsm(SDL_ESM_INST_MAIN_ESM0);
        //          UART_printf("ECC_Test_init: Error initializing ECC callback for Main ESM: result = %d\n", result);
        //         retValue = -1;
        //     } else {
        //         UART_printf("\nECC_Test_init: ECC Callback Init complete for Main ESM \n");
        //     /* Initialize ECC callbacks within the WKUP ESM */
        //     result = SDL_ECC_initEsm(SDL_ESM_INST_WKUP_ESM0);
        //          UART_printf("ECC_Test_init: Error initializing ECC callback for WKUP ESM: result = %d\n", result);
        //         retValue = -1;
        //     } else {
        //         UART_printf("\nECC_Test_init: ECC Callback Init complete for WKUP ESM \n");
        //     /* Initialize VIM ECC memory ; This is specifically for VIM in lockstep*/
        //     /* All other memories are auto initialized by hardware */
        //     result = SDL_ECC_initMemory(SDL_ECC_MEMTYPE_MCU_R5F0_CORE, SDL_ECC_R5F_MEM_SUBTYPE_KS_VIM_RAM_VECTOR_ID);
        //           UART_printf("ECC_Test_init: Error initializing ECC memory: retValue = %d\n", retValue);
        //          retValue = -1;
        //      } else {
        //          UART_printf("\nECC_Test_init: ECC Memory init complete \n");
        //     result = SDL_ECC_initMemory(SDL_ECC_MEMTYPE_MCU_R5F0_CORE, 1U);
        //          retValue = -1;
        //      } else {
        //     result = SDL_ECC_initMemory(SDL_ECC_MEMTYPE_MCU_R5F0_CORE, 28U);
        //          retValue = -1;
        //      } else {
        return retValue;
    uint32_t SDL_getTime(void)
        return(SDL_R5PMU_readCntr(SDL_ARM_R5_PMU_CYCLE_COUNTER_NUM));
    /* Local functions */
    void ECC_Test_readVIMRAM(uint32_t offset);
    int32_t ECC_Test_ECC_waitDEDTrigger(uint64_t timeCount);
    void ECC_Test_ECC_dummyFunction(void);
    __attribute__((section(".ecc_test_ecc_testcodesection"))) void ECC_Test_ECC_dummyFunction(void)
        volatile int i;
        i = 10;
        return;
     * @fn      ECC_Test_runECC1BitInjectTest
     * @brief   Execute ECC 1 bit inject test
     * @param   None
    int32_t ECC_Test_runECC1BitInjectTest(void)
        int32_t retVal=0;
        SDL_ECC_InjectErrorConfig_t injectErrorConfig;
        volatile uint32_t testLocationValue;
        UART_printf("\n ATCM Single bit error inject: test starting");
        /* Note the address is relative to start of ram */
        injectErrorConfig.pErrMem = (uint32_t *)(0x00);
        /* Run one shot test for ATCM 1 bit error */
        injectErrorConfig.flipBitMask = 0x10;
        result = SDL_ECC_injectError(SDL_ECC_MEMTYPE_MCU_R5F0_CORE,
                                     SDL_INJECT_ECC_ERROR_FORCING_1BIT_ONCE,
                                     &injectErrorConfig);
        if (result != SDL_PASS ) {
            UART_printf("\n ATCM Single bit error inject at pErrMem 0x%p test failed",
                        injectErrorConfig.pErrMem);
            retVal = -1;
        } else {
            /* Access the memory where injection is expected */
            testLocationValue = injectErrorConfig.pErrMem[0];
            UART_printf("\n ATCM Single bit error inject at pErrMem 0x%p: test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitInjectTest
     * @brief   Execute ECC 2 bit Inject test
     * @param   None
    int32_t ECC_Test_runECC2BitInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM Double bit error inject: starting");
        /* Run one shot test for ATCM 2 bit error */
        injectErrorConfig.pErrMem = (uint32_t *)(0x200u);
        injectErrorConfig.flipBitMask = 0x101;
                                     SDL_INJECT_ECC_ERROR_FORCING_2BIT_ONCE,
            UART_printf("\n ATCM Double bit error inject: at pErrMem 0x%p: fixed location once test failed",
           retVal = -1;
        } else {
            UART_printf("\n ATCM Double bit error inject: pErrMem 0x%p fixed location once test complete",
        return retVal;
        uint32_t *vimAddr = (uint32_t *)0x40F82000;
        volatile uint32_t tmpValue;
        tmpValue = vimAddr[offset >> 2u];
     * @fn      ECC_Test_runECC1BitVIMRAMInjectTest
     * @brief   Execute ECC 1 bit inject test on VIM RAM
     * @param   None
    int32_t ECC_Test_runECC1BitVIMRAMInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n VIM RAM Single bit error inject: test starting");
        /* Note the address is Actual error address */
        injectErrorConfig.pErrMem = (uint32_t *)(0x40F82000u);
            UART_printf("\n VIM RAM Single bit error inject at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            /* Note this should result in actual error call back */
            UART_printf("\n VIM RAM Single bit error inject at pErrMem 0x%p: test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitVIMRAMInjectTest
     * @brief   Execute ECC 2 bit Inject test with VIM RAM
     * @param   None
    int32_t ECC_Test_runECC2BitVIMRAMInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n VIM RAM Double bit error inject: starting");
        /* Run one shot test for VIM RAM 2 bit error */
        /* Note the address is actual address */
        injectErrorConfig.pErrMem = (uint32_t *)(0x40F82004u);
            UART_printf("\n VIM RAM Double bit error inject: at pErrMem 0x%p: fixed location once test failed",
           retVal = -1;
        } else {
            UART_printf("\n VIM RAM Double bit error inject: pErrMem 0x%p fixed location once test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitVIMRAMDEDvector
     * @brief   Execute ECC 2 bit Inject test with VIM RAM,but expect to
     *          trigger VIM DED vector
     * @param   None
    int32_t ECC_Test_runECC2BitVIMRAMDEDvector(void)
        int32_t retVal=0;
        /* This is expected to trigger the DED vector */
        injectErrorConfig.pErrMem = (uint32_t *)(0x40F82098u);
           retVal = -1;
        } else {
        UART_printf("\n waiting for DED Vector Trigger");
        if (retVal == 0) {
            retVal = ECC_Test_ECC_waitDEDTrigger(0x100000000ull);
        if (retVal == 0) {
            UART_printf("\n DED Vector Trigger: Success");
        } else {
            UART_printf("\n DED Vector Trigger: Fail");
        return retVal;
     * @fn      ECC_Test_runECC1BitVIMRAMSelfTest
     * @brief   Execute ECC 1 bit self test on VIM RAM
     * @param   None
    int32_t ECC_Test_runECC1BitVIMRAMSelfTest(void)
        int32_t retVal=0;
        UART_printf("\n VIM RAM Single bit error self test: starting");
        result = SDL_ECC_selfTest(SDL_ECC_MEMTYPE_MCU_R5F0_CORE,
                                  &injectErrorConfig,
                                  100000);
            UART_printf("\n VIM RAM Single bit error self test: at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n VIM RAM Single bit error self test: at pErrMem 0x%p: test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitVIMRAMSelfTest
     * @brief   Execute ECC 2 bit Self test with VIM RAM
     * @param   None
    int32_t ECC_Test_runECC2BitVIMRAMSelfTest(void)
        int32_t retVal=0;
        UART_printf("\n VIM RAM Double bit error self test: starting");
                                  &injectErrorConfig,
                                  100000);
            UART_printf("\n VIM RAM Double bit error self test: at pErrMem 0x%p: fixed location once test failed",
           retVal = -1;
        } else {
            UART_printf("\n VIM RAM Double bit error self test: pErrMem 0x%p fixed location once test complete",
        return retVal;
     * @fn      ECC_Test_runECC1BitSelfTest
     * @brief   Execute ECC 1 bit Self test
     * @param   None
    int32_t ECC_Test_runECC1BitSelfTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM Single bit error self test: starting");
        injectErrorConfig.pErrMem = (uint32_t *)(0x100);
                                  &injectErrorConfig,
                                  100000);
             UART_printf("\n ATCM Single bit error self test at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n ATCM Single bit error self test at pErrMem 0x%p: test complete",
        return retVal;
    int32_t ECC_Test_runECC_nonAccessable1BitSelfTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM non accessable Single bit error self test: starting");
                                  0U,
                                  &injectErrorConfig,
                                  100000);
        if (result != SDL_EFAIL ) {
             UART_printf("\n ATCM non accessable Single bit error self test at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n ATCM non accessable Single bit error self test at pErrMem 0x%p: test complete",
        return retVal;
    int32_t ECC_Test_runECC1BitNeg1SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM Single bit error negative-1 self test: starting");
        /* To get EFAIL  passing invalid chkgrp*/
        injectErrorConfig.chkGrp = 50U;
                                  28U,
                                  &injectErrorConfig,
                                  100000);
             UART_printf("\n ATCM Single bit error negative-1 self test at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n ATCM Single bit error negative-1 self test at pErrMem 0x%p: test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitSelfTest
     * @brief   Execute ECC 2 bit Self Test
     * @param   None
    int32_t ECC_Test_runECC2BitSelfTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM Double bit error self test: starting");
        injectErrorConfig.pErrMem = (uint32_t *)(0x400u);
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n ATCM Double bit error self test: at pErrMem 0x%p: fixed location once test failed",
            retVal = -1;
        } else {
            UART_printf("\n ATCM Double bit error self test: pErrMem 0x%p fixed location once test complete",
        return retVal;
     * @fn      ECC_Test_runECC1BitB0TCM0Bank0SelfTest
     * @brief   Execute ECC single bit error test on BTCM0 Bank 0 memory
     * @param   None
    int32_t ECC_Test_runECC1BitB0TCM0Bank0SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n B0TCM0 Bank0 Single bit error self test: starting");
        injectErrorConfig.pErrMem = (uint32_t *)(0x41010100u);
        /* Run one shot test for BTCM0 1 bit error */
        injectErrorConfig.flipBitMask = 0x20;
                                  &injectErrorConfig,
                                  100000);
            UART_printf("\n B0TCM0 Bank0 Single bit error self test at pErrMem 0x%p test failed",
           retVal = -1;
        } else {
            UART_printf("\n B0TCM0 Bank0 Single bit error self test at pErrMem 0x%p: test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitB0TCM0Bank0SelfTest
     * @brief   Execute ECC Double bit error test on BTCM0 Bank 0 memory
     * @param   None
    int32_t ECC_Test_runECC2BitB0TCM0Bank0SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n B0TCM0 Bank0 Double bit error self test: starting");
        /* Run one shot test for BTCM0 2 bit error */
        injectErrorConfig.pErrMem = (uint32_t *)(0x41010200u);
        injectErrorConfig.flipBitMask = 0x201;
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n B0TCM0 Bank0 Double bit error self test: at pErrMem 0x%p: fixed location once test failed",
           retVal = -1;
        } else {
            UART_printf("\n B0TCM0 Bank0 Double bit error self test: pErrMem 0x%p fixed location once test complete",
        return retVal;
     * @fn      ECC_Test_runECC1BitB0TCM0Bank1SelfTest
     * @brief   Execute ECC Single bit error test on BTCM0 Bank 1 memory
     * @param   None
    int32_t ECC_Test_runECC1BitB0TCM0Bank1SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n B0TCM0 Bank1 Single bit error self test: starting");
        injectErrorConfig.pErrMem = (uint32_t *)(0x41010104u);
                                  &injectErrorConfig,
                                  100000);
            UART_printf("\n B0TCM0 Bank1 Single bit error self test at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n B0TCM0 Bank1 Single bit error self test at pErrMem 0x%p: test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitB0TCM0Bank1SelfTest
     * @brief   Execute ECC Double bit error test on BTCM0 Bank 1 memory
     * @param   None
    int32_t ECC_Test_runECC2BitB0TCM0Bank1SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n B0TCM0 Bank1 Double bit error self test: starting");
        injectErrorConfig.pErrMem = (uint32_t *)(0x41010204u);
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n B0TCM0 Bank1 Double bit error self test: at pErrMem 0x%p: fixed location once test failed",
            retVal = -1;
        } else {
            UART_printf("\n B0TCM0 Bank1 Double bit error self test: pErrMem 0x%p fixed location once test complete",
        return retVal;
     * @fn      ECC_Test_runECC1BitB1TCM0Bank0SelfTest
     * @brief   Execute ECC Double bit error test on B1TCM0 Bank 0 memory
     * @param   None
    int32_t ECC_Test_runECC1BitB1TCM0Bank0SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n B1TCM0 Bank0 Single bit error self test: starting");
         injectErrorConfig.pErrMem = (uint32_t *)(0x41010108u);
                                   &injectErrorConfig,
                                   100000);
             UART_printf("\n B1TCM0 Bank0 Single bit error self test at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n B1TCM0 Bank0 Single bit error self test at pErrMem 0x%p: test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitB1TCM0Bank0SelfTest
     * @param   None
    int32_t ECC_Test_runECC2BitB1TCM0Bank0SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n B1TCM0 Bank0 Double bit error self test: starting");
        injectErrorConfig.pErrMem = (uint32_t *)(0x41010208u);
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n B1TCM0 Bank0 Double bit error self test: at pErrMem 0x%p: fixed location once test failed",
           retVal = -1;
        } else {
            UART_printf("\n B1TCM0 Bank0 Double bit error self test: pErrMem 0x%p fixed location once test complete",
        return retVal;
     * @fn      ECC_Test_runECC1BitB1TCM0Bank1SelfTest
     * @brief   Execute ECC Single bit error test on B1TCM0 Bank 1 memory
     * @param   None
    int32_t ECC_Test_runECC1BitB1TCM0Bank1SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n B1TCM0 Bank1 Single bit error self test: starting");
        injectErrorConfig.pErrMem = (uint32_t *)(0x4101010cu);
                                  &injectErrorConfig,
                                  100000);
            UART_printf("\n B1TCM0 Bank1 Single bit error self test at pErrMem 0x%p test failed",
           retVal = -1;
        } else {
            UART_printf("\n B1TCM0 Bank1 Single bit error self test at pErrMem 0x%p: test complete",
        return retVal;
     * @fn      ECC_Test_runECC2BitB1TCM0Bank1SelfTest
     * @param   None
    int32_t ECC_Test_runECC2BitB1TCM0Bank1SelfTest(void)
        int32_t retVal=0;
        UART_printf("\n B1TCM0 Bank1 Double bit error self test: starting");
        injectErrorConfig.pErrMem = (uint32_t *)(0x4101020cu);
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n B1TCM0 Bank1 Double bit error self test: at pErrMem 0x%p: fixed location once test failed",
            retVal = -1;
        } else {
            UART_printf("\n B1TCM0 Bank1 Double bit error self test: pErrMem 0x%p fixed location once test complete",
        return retVal;
     * @fn      ECC_Test_runECC1BitCBASSSelfTest
     * @brief   Execute ECC Single bit error self test on CBASS ECC aggregator
     * @param   None
    int32_t ECC_Test_runECC1BitCBASSSelfTest(void)
        int32_t retVal=0;
        uint32_t subType,mainMem;
        UART_printf("\n CBASS Single bit error self test: starting");
        memset(&injectErrorConfig, 0, sizeof(injectErrorConfig));
        /* Run one shot test for CBASS 2 bit error */
        injectErrorConfig.pErrMem = (uint32_t *)(0u);
        injectErrorConfig.flipBitMask = 0x1;
        injectErrorConfig.chkGrp = 0x0;
    #if defined(SOC_J721E)
    	mainMem = SDL_ECC_MEMTYPE_MCU_CBASS_ECC_AGGR0;
        subType = SDL_MCU_CBASS_ECC_AGGR0_IMCU_COR_FW_VBUSP_32B_SOC_FW_SAFEG_EDC_CTRL_RAM_ID;
    #elif defined (SOC_J7200)
    	mainMem = SDL_ECC_VC_MAIN_HC_ECC_AGGR5_ECC_AGGR;
        subType = SDL_VC_MAIN_HC_ECC_AGGR5_J7VC_HC2_CBASS_J7VC_RC_TO_HC2_VBUSM_M2M_BRIDGE_J7VC_HC2_CBASS_J7VC_RC_TO_HC2_VBUSM_M2M_BRIDGE_SRC_EDC_CTRL_BUSECC_RAM_ID;
    #elif defined (SOC_J721S2)
    	mainMem = SDL_WKUP_VTM0_ECC_AGGR;
        subType = SDL_WKUP_VTM0_K3VTM_N16FFC_ECCAGGR_K3VTM_N16FFC_CFG_CBASS_VBUSP_P2P_BRIDGE_EDC_CTRL_0_RAM_ID;
    #elif defined (SOC_J784S4)
    #endif
        result = SDL_ECC_selfTest(mainMem,
                                  subType,
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n CBASS  Single bit error self test: Subtype %d: test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n CBASS Single bit error self test: Subtype 0x%8x test complete",
                        subType);
        return retVal;
     * @fn      ECC_Test_runECC1BitCBASSInjectTest
     * @brief   Execute ECC Single bit error inject test on CBASS ECC aggregator
     * @param   None
    int32_t ECC_Test_runECC1BitCBASSInjectTest(void)
        int32_t retVal=0;
        uint32_t subType, mainMem;
        UART_printf("\n CBASS Single bit error inject test: starting");
    #endif
        result = SDL_ECC_injectError(mainMem,
                                  subType,
                                  &injectErrorConfig
            UART_printf("\n CBASS  Single bit error inject test: Subtype %d: test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n CBASS Single bit error inject test: Subtype 0x%8x test complete",
                        subType);
        return retVal;
     * @fn      ECC_Test_runECC2BitCBASSSelfTest
     * @brief   Execute ECC Double bit error self test on CBASS ECC aggregator
     * @param   None
    int32_t ECC_Test_runECC2BitCBASSSelfTest(void)
        int32_t retVal=0;
        UART_printf("\n CBASS Double bit error self test: starting");
        injectErrorConfig.flipBitMask = 0x3;
        injectErrorConfig.chkGrp = 0x4;
    	mainMem = SDL_ECC_MCU_VC_MCU_ECC_AGGR0;
        subType = SDL_MCU_VC_MCU_ECC_AGGR0_IMCU_COR_FW_VBUSP_32B_SOC_FW_SAFEG_EDC_CTRL_RAM_ID;
    	mainMem = SDL_MCUM_MCU_ECC_AGGR0_ECC_AGGR;
        subType = SDL_MCUM_MCU_ECC_AGGR0_J7AM_MCU_ECC_AGGR_IMCU_COR_FW_VBUSP_32B_SOC_FW_SAFEG_EDC_CTRL_RAM_ID;
    #endif
                                  subType,
                                  &injectErrorConfig,
    							  10000000);
            UART_printf("\n CBASS  Double bit error self test: Subtype %d: fixed location once test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n CBASS Double bit error self test: Subtype 0x%8x fixed location once test complete",
                        subType);
        return retVal;
     * @fn      ECC_Test_runECC2BitCBASSInjectTest
     * @brief   Execute ECC Doule bit error inject test on CBASS ECC aggregator
     * @param   None
    int32_t ECC_Test_runECC2BitCBASSInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n CBASS Double bit error inject test: starting");
        injectErrorConfig.flipBitMask = 0x5;
    #endif
                                  subType,
            UART_printf("\n CBASS  Double bit error inject test: Subtype %d: test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n CBASS Double bit error inject test: Subtype 0x%8x test complete",
                        subType);
        return retVal;
     * @fn      ECC_Test_runECC1BitMSMCRAMSelfTest
     * @brief   Execute ECC Single bit error self test on MSMC_BUSECC_RAM aggregator
     * @param   None
    #if defined (SOC_J721E) || (SOC_J7200) || (SOC_J721S2) || (SOC_J784S4)
    int32_t ECC_Test_runECC1BitMSMCRAMSelfTest(void)
        int32_t retVal=0;
        uint32_t subType;
        UART_printf("\n SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0 Single bit error self test: starting");
        /* Run one shot test for SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0 1 bit error */
        subType = SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_MSMC_MMR_BUSECC_RAM_ID;
        subType = SDL_COMPUTE_CLUSTER0_A72_J7_1MB_WRAP_A72_DUAL_MID_ECC_AGGR_CPU1_EDC_CTRL_RAM_ID;
        subType = SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AE_MSMC_EN_DRU_MSMC_EN_4MB_WRAP_MSMC_4MB_MSMC_WRAP_ECC_AGGR0_DRU0_CBASS_MMR_FW_CH_EDC_RAM_ID;
        subType = SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AHP_MSMC_EN_DRU_MSMC_EN_8MB_WRAP_MSMC_8MB_MSMC_WRAP_ECC_AGGR0_MSMC_LAMBDA3_WRAP_MSMC_QOR_MSMC_CORE_EMIF_PIPE_EMIF0_DP_TO_VBUSMC_EDC_CTRL_0_RAM_ID;
    #endif
        result = SDL_ECC_selfTest(SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0,
                                  subType,
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0  Single bit error self test: Subtype %d: test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0 Single bit error self test: Subtype 0x%8x test complete",
                        subType);
        return retVal;
    #endif
     * @fn      ECC_Test_runECC2BitMSMCRAMSelfTest
     * @brief   Execute ECC Double bit error self test on MSMC_BUSECC_RAM ECC aggregator
     * @param   None
    int32_t ECC_Test_runECC2BitMSMCRAMSelfTest(void)
        int32_t retVal=0;
        UART_printf("\n MSMC_BUSECC_RAM Double bit error self test: starting");
    	/* Run one shot test for MSMC_BUSECC_RAM 2 bit error */
        injectErrorConfig.chkGrp = 0x1;
    	mainMem = SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0;
        injectErrorConfig.chkGrp = 1u;
    	mainMem = SDL_ECC_NAVSS0_1_ECC_AGGR;
        subType = SDL_NAVSS0_NAVSS256VCL_UDMASS_UDMASS_ECCAGGR0_EDC_CTRL_RAM_ID;
    	mainMem = SDL_NAVSS0_1_ECC_AGGR;
        subType = SDL_NAVSS0_NAVSS512J7AM_MODSS_ECCAGGR0_NAVSS512J7AM_MODSS_ECCAGGR0_EDC_CTRL_RAM_ID;
    #endif
                                  subType,
                                  &injectErrorConfig,
    							  10000);
            UART_printf("\n SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0  Double bit error self test: Subtype %d: fixed location once test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n SDL_ECC_MEMTYPE_MAIN_MSMC_AGGR0 Double bit error self test: Subtype 0x%8x fixed location once test complete",
                        subType);
            UART_printf("\n SDL_ECC_NAVSS0_1_ECC_AGGR  Double bit error self test: Subtype %d: fixed location once test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n SDL_ECC_NAVSS0_1_ECC_AGGR Double bit error self test: Subtype 0x%8x fixed location once test complete",
                        subType);
            UART_printf("\n SDL_NAVSS0_1_ECC_AGGR  Double bit error self test: Subtype %d: fixed location once test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n SDL_NAVSS0_1_ECC_AGGR Double bit error self test: Subtype 0x%8x fixed location once test complete",
                        subType);
                        subType);
            retVal = -1;
        } else {
                        subType);
    	#endif
        return retVal;
     * @fn      ECC_Test_runECC1BitMSMC_CACHE_selfTest
     * @brief   Execute ECC Single bit error self test on CACHE_TAG_PIPE_BUSECC aggregator
     * @param   None
    int32_t ECC_Test_runECC1BitMSMC_CACHE_selfTest(void)
        int32_t retVal=0;
        uint32_t subType;
        UART_printf("\n CACHE_TAG_PIPE_BUSECC Single bit error self test: starting");
        /* Run one shot test for CACHE_TAG_PIPE_BUSECC 1 bit error */
        subType = SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_RMW2_CACHE_TAG_PIPE_BUSECC_RAM_ID;
                                  subType,
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n CACHE_TAG_PIPE_BUSECC  Single bit error self test: Subtype %d: test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n CACHE_TAG_PIPE_BUSECC Single bit error self test: Subtype 0x%8x test complete",
                        subType);
        return retVal;
     * @fn      ECC_Test_runECC2BitMSMC_CACHE_selfTest
     * @brief   Execute ECC Double bit error self test on CACHE_TAG_PIPE_BUSECC ECC aggregator
     * @param   None
    int32_t ECC_Test_runECC2BitMSMC_CACHE_selfTest(void)
        int32_t retVal=0;
        uint32_t subType;
        UART_printf("\n CACHE_TAG_PIPE_BUSECC Double bit error self test: starting");
    	/* Run one shot test for CACHE_TAG_PIPE_BUSECC 2 bit error */
                                  subType,
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n CACHE_TAG_PIPE_BUSECC  Double bit error self test: Subtype %d: fixed location once test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n CACHE_TAG_PIPE_BUSECC Double bit error self test: Subtype 0x%8x fixed location once test complete",
                        subType);
        return retVal;
     * @fn      ECC_Test_runECC1BitMSMCCLECselfTest
     * @brief   Execute ECC Single bit error self test on CLEC_EDC_CTRL_BUSECC aggregator
     * @param   None
    int32_t ECC_Test_runECC1BitMSMCCLECselfTest(void)
        int32_t retVal=0;
       uint32_t subType;
        UART_printf("\n CLEC_EDC_CTRL_BUSECC Single bit error self test: starting");
        /* Run one shot test for CLEC_EDC_CTRL_BUSECC 1 bit error */
        subType = SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_CLEC_J7ES_CLEC_EDC_CTRL_BUSECC_RAM_ID;
                                  subType,
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n CLEC_EDC_CTRL_BUSECC  Single bit error self test: Subtype %d: test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n CLEC_EDC_CTRL_BUSECC Single bit error self test: Subtype 0x%8x test complete",
                        subType);
        return retVal;
     * @fn      ECC_Test_runECC2BitMSMCCLECselfTest
     * @brief   Execute ECC Double bit error self test on CLEC_EDC_CTRL_BUSECC ECC aggregator
     * @param   None
    int32_t ECC_Test_runECC2BitMSMCCLECselfTest(void)
        int32_t retVal=0;
       uint32_t subType;
        UART_printf("\n CLEC_EDC_CTRL_BUSECC Double bit error self test: starting");
    	/* Run one shot test for CLEC_EDC_CTRL_BUSECC 2 bit error */
                                  subType,
                                  &injectErrorConfig,
                                  1000);
            UART_printf("\n CLEC_EDC_CTRL_BUSECC  Double bit error self test: Subtype %d: fixed location once test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n CLEC_EDC_CTRL_BUSECC Double bit error self test: Subtype 0x%8x fixed location once test complete",
                        subType);
        return retVal;
    #endif
    static bool ECC_Test_ECC_DEDTriggerFlag = false;
     * @brief   indicate DED trigger
    void ECC_Test_ECC_indicateDEDTrigger(void)
        ECC_Test_ECC_DEDTriggerFlag = true;
        int32_t retVal = 0;
        uint32_t startTimeStamp, curTimeStamp, lastTimeStamp, deltaTime;
        uint64_t elapsedTime = 0u;
        startTimeStamp = SDL_getTime();
        lastTimeStamp = startTimeStamp;
        while(ECC_Test_ECC_DEDTriggerFlag != true) {
            curTimeStamp = SDL_getTime();
            deltaTime = curTimeStamp-lastTimeStamp;
            lastTimeStamp = curTimeStamp;
            elapsedTime += deltaTime;
            if (elapsedTime > timeCount) {
                break;
        if (ECC_Test_ECC_DEDTriggerFlag == true ) {
        } else {
            retVal = -1;
        return retVal;
     * @fn      ECC_Test_runECC2BitCodeInjectTest
     * @brief   Execute ECC 2 bit Inject error on program section
     * @param   None
    int32_t ECC_Test_runECC2BitCodeInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM Double bit Program section error inject: starting");
        /* Error injection on program memory */
        injectErrorConfig.pErrMem = (uint32_t *)(&ECC_Test_ECC_dummyFunction);
        /* Call progrem for the ECC error to take effect */
        ECC_Test_ECC_dummyFunction();
            UART_printf("\n ATCM Double bit Program section error inject: at pErrMem 0x%p: fixed location once test failed",
           retVal = -1;
        } else {
            UART_printf("\n ATCM Double bit Program section error inject: pErrMem 0x%p fixed location once test complete",
        return retVal;
    int32_t ECC_Test_runECC_ErrMemInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n Error inject: EFAIL test starting");
            UART_printf("\n Error inject at pErrMem 0x%p EFAIL test failed",
            retVal = -1;
        } else {
            UART_printf("\n Error inject at pErrMem 0x%p: EFAIL test complete",
        return retVal;
    int32_t ECC_Test_runECC1BitNrowInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM Single bit N row error inject: test starting");
        /* Run one shot test for ATCM 1 bit N row error */
                                     SDL_INJECT_ECC_ERROR_FORCING_1BIT_N_ROW_ONCE,
            UART_printf("\n ATCM Single bit N row error inject at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n ATCM Single bit N row error inject at pErrMem 0x%p: test complete",
        return retVal;
    int32_t ECC_Test_runECC1BitRepeatInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM Single bit Repeat error inject: test starting");
        /* Run one shot test for ATCM 1 bit Repeat error */
                                     SDL_INJECT_ECC_ERROR_FORCING_1BIT_REPEAT,
            UART_printf("\n ATCM Single bit Repeat error inject at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n ATCM Single bit Repeat error inject at pErrMem 0x%p: test complete",
        return retVal;
    int32_t ECC_Test_runECC2BitNrowInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n ATCM Double bit N row error inject: test starting");
        /* Run one shot test for ATCM 2 bit N row error */
                                     SDL_INJECT_ECC_ERROR_FORCING_2BIT_N_ROW_ONCE,
            UART_printf("\n ATCM Double bit N row error inject at pErrMem 0x%p test failed",
            retVal = -1;
        } else {
            UART_printf("\n ATCM Double bit N row error inject at pErrMem 0x%p: test complete",
        return retVal;
    int32_t ECC_Test_runECC2BitRepeatInjectTest(void)
        int32_t retVal=0;
        UART_printf("\n NAVSS0_1 Double bit repeat error inject: starting");
    	/* Run one shot test for NAVSS0_1 2 bit error */
        subType = SDL_NAVSS0_NAVSS256VCL_UDMASS_UDMAP0_TPCFG_PSTATE_RAM_ID;
                                    subType,
                                    SDL_INJECT_ECC_ERROR_FORCING_2BIT_REPEAT,
            UART_printf("\n NAVSS0_1  Double bit repeat error inject: Subtype %d: fixed location once test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n NAVSS0_1 Double bit repeat error inject: Subtype 0x%8x fixed location once test complete",
                        subType);
        return retVal;
    #endif
    #if defined (SOC_J721E) || defined (SOC_J721S2) || defined (SOC_J784S4)
        int32_t retVal=0;
        UART_printf("\n MSMC_BUSECC_RAM Double bit repeat error inject: starting");
        subType = SDL_COMPUTE_CLUSTER0_MSMC_ECC_AGGR0_DRU_CBASS_MMR_CFG_EDC_RAM_ID;
    	subType = SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AE_MSMC_EN_DRU_MSMC_EN_4MB_WRAP_MSMC_4MB_MSMC_WRAP_ECC_AGGR0_DRU0_CBASS_MMR_CFG_EDC_RAM_ID;
    	subType = SDL_COMPUTE_CLUSTER0_COMPUTE_CLUSTER_J7AHP_MSMC_EN_DRU_MSMC_EN_8MB_WRAP_MSMC_8MB_MSMC_WRAP_ECC_AGGR0_DRU0_CBASS_MMR_CFG_EDC_RAM_ID;
    	#endif
                                    subType,
            UART_printf("\n MSMC_BUSECC_RAM  Double bit repeat error inject: Subtype %d: fixed location once test failed",
                        subType);
            retVal = -1;
        } else {
            UART_printf("\n MSMC_BUSECC_RAM Double bit repeat error inject: Subtype 0x%8x fixed location once test complete",
                        subType);
        return retVal;
    #endif
     * @fn      ECC_Test_runECCSEC_DED_MSMCRAMSelfTest
     * @param   None
    #if defined (SOC_J721E) || (SOC_J7200) || (SOC_J721S2)|| (SOC_J784S4)
    int32_t ECC_Test_runECCSEC_DED_MSMCRAMSelfTest(void)
        int32_t retVal=0;
        uint32_t subType, i;
        UART_printf("\n MSMC_BUSECC_RAM Single bit error self test: starting");
        /* Run one shot test for MSMC_BUSECC_RAM 1 bit error */
    #endif
    	for(i = SDL_INJECT_ECC_ERROR_FORCING_1BIT_ONCE; i<= SDL_INJECT_ECC_ERROR_FORCING_2BIT_N_ROW_REPEAT; i++)
                                      subType,
                                      i,
                                      &injectErrorConfig,
                                      1000);
        if (result == SDL_PASS ) {
            UART_printf("\n ECC_Test_runECCSEC_DED_MSMCRAMSelfTest  Single bit error self test: Subtype %d: test failed",
                        subType);
    		retVal = -1;
        } else {
            UART_printf("\n ECC_Test_runECCSEC_DED_MSMCRAMSelfTest Single bit error self test: Subtype 0x%8x test complete",
                        subType);
    		retVal = 0;
        return retVal;
    #endif
    __attribute__((interrupt, section(".text.hwi"), target("arm"), aligned(32))) void ECC_Test_VIMDEDInterruptHandler(void);
    * @fn      ECC_Test_VIMDEDInterruptHandler
    * @brief   Sample DED Interrupt handler
    * @param   None
    * @return   None
        /* Action to be taken by customer */
        UART_printf("\n  VIM DED error happened \n");
        UART_printf("  Take action \n");
        /* clear appropriate interrupt events */
        ECC_Test_ECC_indicateDEDTrigger();
    static int32_t ECC_sdlFuncTest(void)
        int32_t result;
        int32_t retVal = 0;
        UART_printf("\n ECC SDL API tests: starting");
        result = ECC_Test_runECC1BitInjectTest();
            retVal = -1;
            UART_printf("\n ECC_Test_runECC1BitInjectTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitInjectTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitInjectTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitSelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitSelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC_nonAccessable1BitSelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC_nonAccessable1BitSelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitNeg1SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitNeg1SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitSelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitSelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitB0TCM0Bank0SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitB0TCM0Bank0SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitB0TCM0Bank0SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitB0TCM0Bank0SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitB0TCM0Bank1SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitB0TCM0Bank1SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitB0TCM0Bank1SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitB0TCM0Bank1SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitB1TCM0Bank0SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitB1TCM0Bank0SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitB1TCM0Bank0SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitB1TCM0Bank0SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitB1TCM0Bank1SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitB1TCM0Bank1SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitB1TCM0Bank1SelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitB1TCM0Bank1SelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitCodeInjectTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitCodeInjectTest has failed...");
        // if (retVal == 0) {
        //     result = ECC_Test_runECC2BitCBASSSelfTest();
        //         retVal = -1;
        //         UART_printf("\n ECC_Test_runECC2BitCBASSSelfTest has failed...");
        //     result = ECC_Test_runECC2BitCBASSInjectTest();
        //         retVal = -1;
        //         UART_printf("\n ECC_Test_runECC2BitCBASSInjectTest has failed...");
        //     result = ECC_Test_runECC1BitCBASSSelfTest();
        //         retVal = -1;
        //         UART_printf("\n ECC_Test_runECC1BitCBASSSelfTest has failed...");
        //     result = ECC_Test_runECC1BitCBASSInjectTest();
        //         retVal = -1;
        //         UART_printf("\n ECC_Test_runECC1BitCBASSInjectTest has failed...");
        //     result = ECC_Test_runECC1BitMSMCRAMSelfTest();
        //         retVal = -1;
        //         UART_printf("\n ECC_Test_runECC1BitMSMCRAMSelfTest has failed...");
        //     result = ECC_Test_runECC2BitMSMCRAMSelfTest();
        //         retVal = -1;
        //         UART_printf("\n ECC_Test_runECC2BitMSMCRAMSelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitMSMC_CACHE_selfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitMSMC_CACHE_selfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitMSMC_CACHE_selfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitMSMC_CACHE_selfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitMSMCCLECselfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitMSMCCLECselfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitMSMCCLECselfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitMSMCCLECselfTest has failed...");
    #endif
        if (retVal == 0) {
            result = ECC_Test_runECC_ErrMemInjectTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC_ErrMemInjectTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitNrowInjectTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitNrowInjectTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitRepeatInjectTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitRepeatInjectTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitNrowInjectTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitNrowInjectTest has failed...");
        //     result = ECC_Test_runECC2BitRepeatInjectTest();
        //         retVal = -1;
        //         UART_printf("\n ECC_Test_runECC2BitRepeatInjectTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitVIMRAMInjectTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitVIMRAMInjectTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitVIMRAMInjectTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitVIMRAMInjectTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC1BitVIMRAMSelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC1BitVIMRAMSelfTest has failed...");
        if (retVal == 0) {
            result = ECC_Test_runECC2BitVIMRAMSelfTest();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitVIMRAMSelfTest has failed...");
        //     result = ECC_Test_runECCSEC_DED_MSMCRAMSelfTest();
        //         retVal = -1;
        //         UART_printf("\n ECC_Test_runECCSEC_DED_MSMCRAMSelfTest has failed...");
        /* This needs to be last as it is destructive */
        if (retVal == 0) {
            result = ECC_Test_runECC2BitVIMRAMDEDvector();
                retVal = -1;
                UART_printf("\n ECC_Test_runECC2BitVIMRAMDEDvector has failed...");
        if ( retVal == 0) {
            UART_printf("\n ECC SDL API tests: success");
        } else {
            UART_printf("\n ECC SDL API tests: failed");
        return retVal;
    void BSW_EnableCachePMCR(void)
        //  Enable the export functionality of R5F PMCR register for routing Cache events to ESM/ Pulsar registers.
        asm("MOV R5, #0x0");
        asm("MRC     P15,#0, R5, C9, C12,#0");
        asm("ORR     R5, R5, #0x2");                    // Reset event counter
        asm("MCR     P15,#0, R5, C9, C12,#0");
        asm("ORR     R5, R5, #0x11");
        asm("MOV r4, #0x60");
        asm("MCR p15,#0,r4,c9,c13,#1");
        printf("\nCache Ecc test start: \n");
        // printf("\nCache Ecc test start: 0x%8x\n" , *ptr1);
        //     // a. For single bit error injection:
        //     uint32_t *ptr2 = (uint32_t *)0x40080008; // Set RAM ID
        //     *ptr2 = 0x8;
        //     uint32_t *ptr3 = (uint32_t *)0x40080014; // ECC Ctrl Reg
        //     *ptr3 = 0x28;                            // 0x28 for Data RAM IDs, 0x68 for Tag RAM IDs
        //     asm("NOP");                              // Enable ECC for Cache memories, Inject error into RAM ID 8
        // else
            *ptr2 = 0x8;
            uint32_t *ptr4 = (uint32_t *)0x4008001C; // ECC Error Control2 reg
            *ptr4 = 0x30002;
            b[i] = a[i];
        printf("Cache Ecc test start: pass\n");
    /* ECC Function module test */
    int32_t ECC_funcTest(void)
        int32_t testResult;
        BSW_EnableCachePMCR();
        testResult = ECC_Test_init();
        if (testResult != 0)
            UART_printf("\n ECC SDL API tests: unsuccessful");
            return SDL_EFAIL;
         uint32_t global_variable;
        asm volatile("MRC p15, 0, %0, c1, c0, 1" : "=r"(global_variable));
        printf("Global variable: 0x%8x\n", global_variable);
        // printf("\n\n witness test \n\n");
        BSW_TestCacheEcc(0);
        // testResult = ECC_sdlFuncTest();
        return (testResult);
    /* Nothing past this point */
    So the standalone sdl_ecc_test_app is giving you an infinite ESM callback on the MCU1_0? Without any changes?
    Josiitaa
  • Hi Josiitaa,
    Have changes,  delete unneed function and add inject ecc code so on...   You can copy the code to compare with the origin code.
    I see that you have included the code for cache error injection here. You do not require that here if you are trying to test TCM. This SDL example is for TCM error injection and testing.
    Why have you commented the exception handlers?
    Josiitaa
  • I used  this example to  test  cache error injection  and do not test TCM.
    I wanted to  use ESM handler  to  handle all the error,  that is easy to write error handle logic.
  • Can you share a example of  cache ecc app?
  • Understood.
    This thread was initially about TCM.
    For cache, we do not have an example currently, you would have to follow the steps mentioned in the FAQ. This has only been tested for MCU1_0 and not for MCU4_0 by TI so far.
    Josiitaa
  • Hi Josiitaa,
    As customer has to implement cache ECC feature on MCU4-0, by following the steps in the FAQ it seems that the ESM could not be cleared. Could you help check internally about the reason and explain to the customer please?
    Many Thanks,
    Kevin
  • Hi Josiitaa,
    Let me summarize the test results customer tried.
    For the TCM ECC, it could be cleared successfully no matter which R5f core used.
    However, for the cache ECC, customer tried MCU1-0, MCU1-1, MCU4-0, sadly all of them have the same result that customer could not clear it. The details is discussed above by the customer.
    Hence, this problem is not related to which r5f core using, but related to cache ecc itself. Customer is following the FAQ, so may need your support about which differences needed to make cahce ecc work.
    Many Thanks,
    Kevin
  • Hi Kevin,
    Understood. I will check internally on why the cache errors are not getting cleared and get back to you.
    Josiitaa
  • Hi Kevin,
    Let us try to get the cache errors cleared on MCU1-0 first.
    The sequence of steps is as follows -
    1. Make sure that you are running the code from non-cached memory. Only the array a and b must be cached as shown below:
    uint32_t a[ARRAY_SIZE] __attribute__((section(".DDR_Cache.filebuf")));
    2. Inject errors including this register polling as mentioned in the FAQ.
    3. Set the CTRL register to 0.
    4. Poll the PULSAR_EVNT_BUS_ESM_STATUS register to see if it 0. If it is not 0, read the PULSAR_EVNT_BUS_ESM_CLR register and write the same value to the PULSAR_EVNT_BUS_ESM_CLR register until the PULSAR_EVNT_BUS_ESM_STATUS register becomes 0.
    Josiitaa
  • Hi Josiitaa,
     It  works on MCU1_0 ,  and How to clear cache ecc error  in MCU4_0?
    Have you tried the same approach on MCU4_0?
    Josiitaa
  • I have tried but  can not work on MCU4_0. And  the PULSAR_EVNT_BUS_ESM_STATUS register address   of  MCU4_0  is the same as MCU1_0?
    The MCU4_0 PULSAR_EVNT_BUS_ESM_STATUS is 0x0002A33014h and MCU1_0 is 0x004072F014h.
    Josiitaa
  • Hi Josiitaa,
    MCU4_0 cache ecc error have cleared, but  MCU4_0  cache ecc error  cause  MCU1_1 goto died and no error information. That is unnormal.    MCU4_0 and MCU1_1 run in  spl mode.
    The only link that I see between MCU4_0 and MCU1_1 is the ESM event for cache error. Can you disable the MCU4_0 cache events and check if this issue still occurs? This is to confirm if the cache error injection is only causing the abort.
    Disable the below events in the ESM enable bitmap:
    #define SDLR_ESM0_ESM_LVL_EVENT_R5FSS2_COMMON0_ECC_SE_TO_ESM_0_0 (364U)
    #define SDLR_ESM0_ESM_LVL_EVENT_R5FSS2_COMMON0_ECC_DE_TO_ESM_0_0 (365U)
    Josiitaa
  • Hi Josiitaa,
    Thanks for your help that customer could clear MCU4-0 cache ecc error successfully now!
    The only problem left is that when injecting the cache ecc error in MCU4-0, the MCU1-1 will have no more printing and seems stuck.
    The process for producing this problem is as follow:
    1: In SPL mode, the MCU1-1 is running normally and keep printing the running information.
    2: Inject the cache ecc error on MCU4-0
    3: The MCU1-1 detects the cache ecc error from MCU4-0
    4: The MCU1-1 runs the esm callback function to clear the cache ecc error from MCU4-0
    5: The cache ecc error from MCU4-0 is cleared
    6: The MCU1-1 will stuck & does not print any more information after running the esm callback function
    7: We currently do not know the exact place MCU1-1 stucks at, but it should be after running the esm callback function
    Kevin
  • If I disable 364U 365U In ESM bitmap ,  After MCU4_0 inject cache ecc error , MCU1_1 is running normal.
  • Hi Kong,
    So this problem is resolved?
    Kevin
  • No, if disabled the error, when the error occur,  we don't  know  what happen. Just like  disable the cache ecc.
  • Hi Kong,
    Can you please clarify the following points.
    1. You have mentioned that MCU1_1 is running SPL. What is running on MCU1_0? How are you running SPL on MCU1_1?
    2. Can you share the logs you are seeing on MCU1_1 before it halts?
    3. SPL does not have any mechanism to notify when interrupts occurs. How are you polling for the interrupts on MCU1_1?
    4. After clearing the cache error, are you checking the ESM STS registers to see if the status bits are also cleared?
    Josiitaa
  • 1. MCU1_0 is running SPL.  MCU1_1 MCU4_0, running our app.
    2. I make a mistake here :  I used CCS debug  clear cache error app, it work. But  in SPL mode , it cann't clear cache error. (both MCU1_1 and MCU4_0)
    The app will died here : while(((*ptr2>>24)&0x1)!=1),  if I comment this  it will died here: while(*pEsmStatus != 0)
    #define R5FSS_COMMON0_PULSAR_EVNT_BUS_ESM_STATUS     (0x4072F014U)
    #define R5FSS_COMMON0_PULSAR_EVNT_BUS_ESM_CLR        (0x4072F01CU)
    #define R5FSS40_COMMON0_PULSAR_EVNT_BUS_ESM_STATUS   (0x02A33014U)
    #define R5FSS40_COMMON0_PULSAR_EVNT_BUS_ESM_CLR      (0x02A3301CU)
    #define INJECT_ERROR_REGISTERs_MCU10 (0x40080000U) //
    #define INJECT_ERROR_REGISTERs_MCU11 (0x400C0000U) //
    #define INJECT_ERROR_REGISTERs_MCU40 (0x02A6B000U) //
    #define OFFSET_RAMID (0x08U) //
    #define OFFSET_CTRL_REG (0x14U) //
    #define OFFSET_CTRL_ERROR_REG (0x1CU) //
    void SDL_clearEsmEccError(uint32_t intSrc)
        uint32_t *pEsmStatus = (uint32_t *)R5FSS_COMMON0_PULSAR_EVNT_BUS_ESM_STATUS;
        uint32_t *pEsmClr = (uint32_t *)R5FSS_COMMON0_PULSAR_EVNT_BUS_ESM_CLR;
        uint32_t clearStatus = 0;
        uint32_t *ptr2, *ptr3, ptr5;
        if(SDLR_ESM0_ESM_LVL_EVENT_R5FSS2_COMMON0_ECC_SE_TO_ESM_0_0 <= intSrc && intSrc <= SDLR_ESM0_ESM_LVL_EVENT_R5FSS2_COMMON0_ECC_DE_TO_ESM_1_0)//<! MCU4_0
            pEsmStatus = (uint32_t *)R5FSS40_COMMON0_PULSAR_EVNT_BUS_ESM_STATUS;
            pEsmClr = (uint32_t *)R5FSS40_COMMON0_PULSAR_EVNT_BUS_ESM_CLR;
            ptr2 = (uint32_t *)(INJECT_ERROR_REGISTERs_MCU40 + OFFSET_RAMID);
            ptr3 = (uint32_t *)(INJECT_ERROR_REGISTERs_MCU40 + OFFSET_CTRL_REG);
        else if(SDLR_MCU_ESM0_ESM_LVL_EVENT_MCU_R5FSS0_COMMON0_ECC_SE_TO_ESM_0_0 <= intSrc && intSrc <= SDLR_MCU_ESM0_ESM_LVL_EVENT_MCU_R5FSS0_COMMON0_ECC_DE_TO_ESM_1_0) //<! MCU1_1
        *ptr3 = 0;
        *ptr2=0x148008;
             /* code */
        // SELFTEST_PRINTF("%s %d\n", __func__, __LINE__);
            static uint32_t clearCount = 0;
            clearStatus = *pEsmClr;
            *pEsmClr = clearStatus;
            *pEsmStatus = 0;
           if (/* condition */ clearCount++ > 10000000)
            /* code */
            SELFTEST_PRINTF("Clear ESM ECC Error %d\n", clearStatus);
            clearCount = 0;
  • Hi Kong,
    Please confirm that your code including SDL_clearEsmEccError is in non cached memory.
    Josiitaa
  • I renamed  a[]  b[]    to test_a[] test_b[], and this is the allocate address:( all in  DDR address range)
    MCU1_1
    MCU4_0:
    It seems that even your SDL_clearEsmEccError is in the same DDR memory range. Does that mean that it is cached?
    Can you make sure that everything except test_a[] test_b[] is non cached?
    Josiitaa
  • Hi Josiitaa,
      All of my code is running in DDR,  that is non cached,   include test_a[] test_b[].
     0xA0000000 is  DDR range is non cached too.
    Icache and Dcache range is
