Part Number: AM62A7
hi, TI optee expert:
In order to support OPTEE RPMB secure storage, I have modified the configuration of optee-os and optee_client:
optee-os:
CFG_REE_FS ?= n
CFG_RPMB_FS ?= y
CFG_RPMB_ TESTKEY?= y
CFG_RPMB_WRITE_KEY ?= y
optee-client
RPMB_EMU = OFF
But I have encountered the following problem and I hope to get your help.
Additional explanation:
1.I have rewritten a 'Secure Storage' CA.
2. I wrote a file before, and the emmc rpmb counter has also changed
3. but Occasionally, it can be successful when reading from RPMB()
* Copyright (c) 2016, Linaro Limited
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
#include <err.h>
#include <stdio.h>
#include <string.h>
/* OP-TEE TEE client API (built by optee_client) */
#include <tee_client_api.h>
/* For the UUID (found in the TA's h-file(s)) */
#include <hello_world_ta.h>
TEEC_Result res;
TEEC_Context ctx;
TEEC_Session sess;
TEEC_Operation op;
uint32_t err_origin;
void usage(void)
printf("./xx <action>\n\taction:HELLO_WORLD / OTP / HWRNG /SeWrite /SeRead /SeDelete /HOTP /RSA_encode /AES_encode /AES_decode\n"
"\n\tOTP:One Time Program\n"
"\tHOTP: HMAC based on One Time Password\n");
int HELLO_WORLD(void);
int OTP(void);
int HWRNG(void);
int SeWrite(void);
int SeRead(void);
int SeDelete(void);
int HOTP(void);
int RSA_encode(void);
int AES_encode(void);
int AES_decode(void);
int main(int argc, int **argv)
if( argc != 2 )
usage();
return -1;
/* Initialize a context connecting us to the TEE */
res = TEEC_InitializeContext(NULL, &ctx);
if (res != TEEC_SUCCESS)
errx(1, "TEEC_InitializeContext failed with code 0x%x", res);
if( strcmp(argv[1], "HELLO_WORLD") == 0)
HELLO_WORLD();
else if (strcmp(argv[1], "OTP") == 0 )
OTP();
else if (strcmp(argv[1], "HWRNG") == 0 )
HWRNG();
else if (strcmp(argv[1], "SeWrite") == 0 )
SeWrite();
else if (strcmp(argv[1], "SeRead") == 0 )
SeRead();
else if (strcmp(argv[1], "SeDelete") == 0 )
SeDelete();
else if (strcmp(argv[1], "HOTP") == 0 )
HOTP();
else if (strcmp(argv[1], "RSA_encode") == 0 )
RSA_encode();
else if (strcmp(argv[1], "AES_encode") == 0 )
AES_encode();
else if (strcmp(argv[1], "AES_decode") == 0 )
AES_decode();
else
usage();
if( sess.session_id > 0 )
TEEC_CloseSession(&sess);
TEEC_FinalizeContext(&ctx);
return 0;
TEEC_UUID uuid = TA_HELLO_WORLD_UUID;
res = TEEC_OpenSession(&ctx, &sess, &uuid,
TEEC_LOGIN_PUBLIC, NULL, NULL, &err_origin);
errx(1, "TEEC_Opensession failed with code 0x%x origin 0x%x",
res, err_origin);
memset(&op, 0, sizeof(op));
op.paramTypes = TEEC_PARAM_TYPES(TEEC_VALUE_INOUT, TEEC_NONE,
TEEC_NONE, TEEC_NONE);
op.params[0].value.a = 42;
printf("##TA_CMD TA to increment %d\n", op.params[0].value.a);
res = TEEC_InvokeCommand(&sess, TA_HELLO_WORLD_CMD_INC_VALUE, &op,
&err_origin);
errx(1, "TEEC_InvokeCommand failed with code 0x%x origin 0x%x",
res, err_origin);
printf("TA incremented value to %d\n", op.params[0].value.a);
return 0;
int OTP(void)
#define PTA_K3_OTP_KEYWRITING_UUID \
{ 0xacc50f40, 0x0613, 0x4abd, \
{ 0x8d, 0xfe, 0xa9, 0x64, 0xcb, 0x74, 0xeb, 0x69} }
TEEC_UUID uuid = PTA_K3_OTP_KEYWRITING_UUID;
int index = 0;
printf("## Please Type OTP index:");
fscanf(stdin, "%d", &index);
#define TA_OTP_KEYWRITING_CMD_READ_MMR 0
op.paramTypes =
TEEC_PARAM_TYPES(TEEC_VALUE_INPUT,
TEEC_VALUE_OUTPUT,
op.params[0].value.a = index;
res = TEEC_InvokeCommand(&sess, TA_OTP_KEYWRITING_CMD_READ_MMR, &op,
&err_origin);
res, err_origin);
printf("##OTP READ index[%d]=%d\n",index, op.params[1].value.a);
return 0;
int HWRNG(void)
#define PTA_RNG_UUID \
{ 0xab7a617c, 0xb8e7, 0x4d8f, \
{ 0x83, 0x01, 0xd0, 0x9b, 0x61, 0x03, 0x6b, 0x64 } }
TEEC_UUID uuid = PTA_RNG_UUID;
res, err_origin);
#define PTA_CMD_GET_ENTROPY 0x0
#define PTA_CMD_GET_RNG_INFO 0x1
op.paramTypes =
TEEC_PARAM_TYPES(TEEC_VALUE_OUTPUT,
TEEC_NONE,
res = TEEC_InvokeCommand(&sess, PTA_CMD_GET_RNG_INFO, &op,
&err_origin);
res, err_origin);
printf("##RNG INFO: rate:%d quality:%d\n", op.params[0].value.a, op.params[0].value.b);
op.paramTypes =
TEEC_PARAM_TYPES(TEEC_MEMREF_TEMP_INOUT,
TEEC_NONE,
char buf[128] = { 0 };
op.params[0].tmpref.size = sizeof(buf);
op.params[0].tmpref.buffer = buf;
res = TEEC_InvokeCommand(&sess, PTA_CMD_GET_ENTROPY, &op,
&err_origin);
res, err_origin);
for(int i = 0 ;i < 128 ; i +=8 )
printf("##RNG ENTROPY: %02x %02x %02x %02x %02x %02x %02x %02x\n", \
buf[i + 0], buf[i + 1], buf[i + 2],buf[i + 3],buf[i + 4],buf[i + 5],buf[i + 6],buf[i + 7] );
return 0;
int SeWrite(void)
#define TA_SECURE_STORAGE_CMD_READ_RAW 0
#define TA_SECURE_STORAGE_CMD_WRITE_RAW 1
#define TA_SECURE_STORAGE_CMD_DELETE 2
#define TA_SECURE_STORAGE_UUID \
{ 0xf4e750bb, 0x1437, 0x4fbf, \
{ 0x87, 0x85, 0x8d, 0x35, 0x80, 0xc3, 0x49, 0x94 } }
TEEC_UUID uuid = TA_SECURE_STORAGE_UUID;
char filename [100] = { 0 };
char data [1024] = { 0 };
printf("=>Filename(write):");
fflush(stdout);
fscanf(stdin, "%s", filename);
printf("=>data(write):");
fflush(stdout);
fscanf(stdin, "%s", data);
// printf("<%s><%s>\n", filename, data);
res, err_origin);
op.paramTypes = TEEC_PARAM_TYPES(TEEC_MEMREF_TEMP_INPUT, TEEC_MEMREF_TEMP_INPUT,
op.params[0].tmpref.buffer = filename;
op.params[0].tmpref.size = strlen(filename);
op.params[1].tmpref.buffer = data;
op.params[1].tmpref.size = strlen(data);
printf("##TA_CMD TA_SECURE_STORAGE_CMD_WRITE_RAW start\n");
res = TEEC_InvokeCommand(&sess, TA_SECURE_STORAGE_CMD_WRITE_RAW, &op,
&err_origin);
res, err_origin);
printf("##TA_CMD TA_SECURE_STORAGE_CMD_WRITE_RAW end\n");
return 0;
int SeRead(void)
printf("=>Filename(read):");
fflush(stdout);
res, err_origin);
op.paramTypes = TEEC_PARAM_TYPES(TEEC_MEMREF_TEMP_INPUT, TEEC_MEMREF_TEMP_OUTPUT,
op.params[1].tmpref.size = sizeof(data) - 1;
printf("##TA_CMD TA_SECURE_STORAGE_CMD_READ_RAW start\n");
res = TEEC_InvokeCommand(&sess, TA_SECURE_STORAGE_CMD_READ_RAW, &op,
&err_origin);
res, err_origin);
printf("##TA_CMD TA_SECURE_STORAGE_CMD_READ_RAW end\n");
fprintf(stdout, "=>data(read):<%s>\n", data);
return 0;
int SeDelete(void)
fflush(stdout);
res, err_origin);
op.paramTypes = TEEC_PARAM_TYPES(TEEC_MEMREF_TEMP_INPUT, TEEC_NONE,
printf("##TA_CMD TA_SECURE_STORAGE_CMD_DELETE start\n");
res = TEEC_InvokeCommand(&sess, TA_SECURE_STORAGE_CMD_DELETE, &op,
&err_origin);
res, err_origin);
printf("##TA_CMD TA_SECURE_STORAGE_CMD_DELETE end\n");
return 0;
int HOTP(void)
#define TA_HOTP_CMD_REGISTER_SHARED_KEY 0
#define TA_HOTP_CMD_GET_HOTP 1
#define TA_HOTP_UUID \
{ 0x484d4143, 0x2d53, 0x4841, \
{ 0x31, 0x20, 0x4a, 0x6f, 0x63, 0x6b, 0x65, 0x42 } }
TEEC_UUID uuid = TA_HOTP_UUID;
uint8_t K[] = {
0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38,
0x39, 0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36,
0x37, 0x38, 0x39, 0x30
// fflush(stdout);
// fscanf(stdin, "%s", filename);
res, err_origin);
op.params[0].tmpref.buffer = K;
op.params[0].tmpref.size = sizeof(K);
// printf("##TA_CMD TA_HOTP_CMD_REGISTER_SHARED_KEY start\n");
res = TEEC_InvokeCommand(&sess, TA_HOTP_CMD_REGISTER_SHARED_KEY, &op,
&err_origin);
res, err_origin);
// printf("##TA_CMD TA_HOTP_CMD_REGISTER_SHARED_KEY end\n");
while(1)
char input = 'n';
printf("## generate One Time Password(y/n)?");
fscanf(stdin, "%c", &input);
if(input != 'y')
printf("## exit ...\n");
break;
else
while ((input = getchar()) != '\n' && input != EOF) {}
op.paramTypes = TEEC_PARAM_TYPES(TEEC_VALUE_OUTPUT, TEEC_NONE,
// printf("##TA_CMD TA_HOTP_CMD_GET_HOTP start\n");
res = TEEC_InvokeCommand(&sess, TA_HOTP_CMD_GET_HOTP, &op,
&err_origin);
res, err_origin);
// printf("##TA_CMD TA_HOTP_CMD_GET_HOTP end\n");
printf("## one Time Password:%d\n", op.params[0].value.a);
return 0;
int get_rsa_args(int *key_size, char * inbuff)
char input = 0;
printf("## please type keysize(256/512/1024):");
fscanf(stdin, "%d", key_size);
printf("## please type string( len<=%d):",*key_size / 8 -11);
fscanf(stdin, "%s", inbuff);
printf("keysize<%d> buff<%s>\n", *key_size, inbuff);
if( strlen(inbuff) > ( *key_size/8 ) -11 )
printf("buff len is too big\n");
return -1;
#define TA_ACIPHER_CMD_GEN_KEY 0
#define TA_ACIPHER_CMD_ENCRYPT 1
#define TA_ACIPHER_UUID \
{ 0xa734eed9, 0xd6a1, 0x4244, { \
0xaa, 0x50, 0x7c, 0x99, 0x71, 0x9e, 0x7b, 0x7b } }
TEEC_UUID uuid = TA_ACIPHER_UUID;
int key_size = 0;
char inbuff[1024] = { 0 };
char outbuff[1024] = { 0 };
get_rsa_args(&key_size, inbuff);
res, err_origin);
/*************************** cmd1-genkey *********************************/
op.paramTypes = TEEC_PARAM_TYPES(TEEC_VALUE_INPUT, TEEC_NONE,
op.params[0].value.a = key_size;
res = TEEC_InvokeCommand(&sess, TA_ACIPHER_CMD_GEN_KEY, &op,
&err_origin);
res, err_origin);
/*************************** cmd2-encrypt *********************************/
op.params[0].tmpref.buffer = inbuff;
op.params[0].tmpref.size = strlen(inbuff);
op.params[1].tmpref.buffer = outbuff;
op.params[1].tmpref.size = sizeof(outbuff);
res = TEEC_InvokeCommand(&sess, TA_ACIPHER_CMD_ENCRYPT, &op,
&err_origin);
res, err_origin);
/*************************** result *********************************/
printf("## Encrypt Result:\n");
for( int i = 0; i < op.params[1].tmpref.size; i++ )
printf("%02x ", outbuff[i]);
if( (i+1) % 8 == 0)
printf("\n");
return 0;
char char2num(char c)
if( c >= '0' && c <='9')
return c-'0';
else if ( c >= 'a' && c <='f')
return c- 'a' +10;
else
return 0xff;
int AES_common(int mode)
#define TA_AES_UUID \
{ 0x5dbac793, 0xf574, 0x4871, \
{ 0x8a, 0xd3, 0x04, 0x33, 0x1e, 0xc1, 0x7f, 0x24 } }
#define TA_AES_ALGO_ECB 0
#define TA_AES_ALGO_CBC 1
#define TA_AES_ALGO_CTR 2
#define TA_AES_SIZE_128BIT (128 / 8)
#define TA_AES_SIZE_256BIT (256 / 8)
// #define TA_AES_MODE_ENCODE 1
// #define TA_AES_MODE_DECODE 0
#define TA_AES_CMD_PREPARE 0
#define TA_AES_CMD_SET_KEY 1
#define TA_AES_CMD_SET_IV 2
#define TA_AES_CMD_CIPHER 3
TEEC_UUID uuid = TA_AES_UUID;
res, err_origin);
/*************************** cmd1-prepare *********************************/
op.paramTypes = TEEC_PARAM_TYPES(TEEC_VALUE_INPUT, TEEC_VALUE_INPUT,
TEEC_VALUE_INPUT, TEEC_NONE);
op.params[0].value.a = TA_AES_ALGO_CTR;
op.params[1].value.a = TA_AES_SIZE_128BIT;
op.params[2].value.a = mode; // modify
res = TEEC_InvokeCommand(&sess, TA_AES_CMD_PREPARE, &op,
&err_origin);
res, err_origin);
/*************************** cmd2-setkey *********************************/
char key[TA_AES_SIZE_128BIT]= { 0 };
char iv[TA_AES_SIZE_128BIT] = { 0 };
int plain_txt[1024] = { 0 };
int result_txt[1024] = { 0 };
char tmp = 0;
memset(key, 0x51, sizeof(key));
op.params[0].tmpref.buffer = key;
op.params[0].tmpref.size = sizeof(key);
res = TEEC_InvokeCommand(&sess, TA_AES_CMD_SET_KEY, &op,
&err_origin);
res, err_origin);
/*************************** cmd3-setiv *********************************/
memset(iv, 0x12, sizeof(iv));
op.params[0].tmpref.buffer = iv;
op.params[0].tmpref.size = sizeof(iv);
res = TEEC_InvokeCommand(&sess, TA_AES_CMD_SET_IV, &op,
&err_origin);
res, err_origin);
/*************************** encode/decode *********************************/
printf("## please type text for de/en coding:size data1 data2 data3 ...(note: hex format)\n");
int input_size= 0;
fscanf(stdin, "%08x", &input_size);
for(int i = 0; i < input_size; i++)
fscanf(stdin, "%08x", &(plain_txt[i]) );
while ((tmp = getchar()) != '\n' && tmp != EOF) {}
op.params[0].tmpref.buffer = plain_txt;
op.params[0].tmpref.size = input_size*4;
op.params[1].tmpref.buffer = result_txt;
op.params[1].tmpref.size = sizeof(result_txt);
res = TEEC_InvokeCommand(&sess, TA_AES_CMD_CIPHER, &op,
&err_origin);
res, err_origin);
printf("## Encode/decode Result: (size:%d bytes)", op.params[1].tmpref.size);
for( int i = 0; i < op.params[1].tmpref.size / 4 ; i++ )
printf("%08x ", result_txt[i]);
if( (i+1) % 8 == 0)
printf("\n");
printf("\n");
return 0;
AES_common(TA_AES_MODE_ENCODE);
AES_common(TA_AES_MODE_DECODE);
