Error While Compiling Qt application
Other Parts Discussed in Thread: AM1808
Hello all,
 I was giving a try to deploy the Qt application named "helloworl" on a AM1808 EVM board from Calixto. I was successful in deploying the normal C executable and run on the board. I have started by writing a simple Pushbutton program named main.cpp whose content you can find in the screenshot along with the contents of the .pro file.
I was not facing any errors while i have executed qmake -project and qmake, when ever i try to run the command make it prompts me with following error:
c -pipe   -Wall -W -D_REENTRANT -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB -I/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++ -I. -I/QtCore -I/QtGui -I -I. -I. -o main.o main.cpp
make: c: Command not found
make: [main.o] Error 127 (ignored)
o helloworl main.o    -L -lglib-2.0 -lQtGui -lQtCore -lpthread
make: o: Command not found
make: [helloworl] Error 127 (ignored)
Where the content of make file is as follows:
# Makefile for building: helloworl
# Generated by qmake (2.01a) (Qt 4.6.2) on: Mon Oct 24 19:23:38 2011
# Project:  helloworl.pro
# Template: app
# Command: /usr/bin/qmake -unix -o Makefile helloworl.pro
####### Compiler, tools and options
CC            = $(OE_QMAKE_CC)
CXX           = $(OE_QMAKE_CXX)
DEFINES       = -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB
CFLAGS        = -pipe $(OE_QMAKE_CFLAGS) -Wall -W -D_REENTRANT $(DEFINES)
CXXFLAGS      = -pipe $(OE_QMAKE_CFLAGS) $(OE_QMAKE_CXXFLAGS) -Wall -W -D_REENTRANT $(DEFINES)
INCPATH       = -I/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++ -I. -I$(OE_QMAKE_INCDIR_QT)/QtCore -I$(OE_QMAKE_INCDIR_QT)/QtGui -I$(OE_QMAKE_INCDIR_QT) -I. -I.
LINK          = $(OE_QMAKE_LINK)
LFLAGS        = $(OE_QMAKE_LDFLAGS)
LIBS          = $(SUBLIBS)  -L$(OE_QMAKE_LIBDIR_QT) -lglib-2.0 -lQtGui -lQtCore -lpthread
AR            = $(OE_QMAKE_AR) cqs
RANLIB        =
QMAKE         = /usr/bin/qmake
TAR           = tar -cf
COMPRESS      = gzip -9f
COPY          = cp -f
SED           = sed
COPY_FILE     = $(COPY)
COPY_DIR      = $(COPY) -r
STRIP         = $(OE_QMAKE_STRIP)
INSTALL_FILE  = install -m 644 -p
INSTALL_DIR   = $(COPY_DIR)
INSTALL_PROGRAM = install -m 755 -p
DEL_FILE      = rm -f
SYMLINK       = ln -f -s
DEL_DIR       = rmdir
MOVE          = mv -f
CHK_DIR_EXISTS= test -d
MKDIR         = mkdir -p
####### Output directory
OBJECTS_DIR   = ./
####### Files
SOURCES       = main.cpp
OBJECTS       = main.o
DIST          = /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/unix.conf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/linux.conf \
        /usr/share/qt4/mkspecs/qconfig.pri \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_functions.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_config.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/exclusive_builds.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_pre.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/release.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_post.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/warn_on.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/unix/thread.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/moc.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/resources.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/uic.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/yacc.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/lex.prf \
        /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/include_source_dir.prf \
        helloworl.pro
QMAKE_TARGET  = helloworl
DESTDIR       =
TARGET        = helloworl
first: all
####### Implicit rules
.SUFFIXES: .o .c .cpp .cc .cxx .C
.cpp.o:
    $(CXX) -c $(CXXFLAGS) $(INCPATH) -o "$@" "$<"
.cc.o:
.cxx.o:
.C.o:
.c.o:
    $(CC) -c $(CFLAGS) $(INCPATH) -o "$@" "$<"
####### Build rules
all: Makefile $(TARGET)
$(TARGET):  $(OBJECTS)
    $(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJCOMP) $(LIBS)
Makefile: helloworl.pro  /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++/qmake.conf /usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf \
    $(QMAKE) -unix -o Makefile helloworl.pro
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/g++.conf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/unix.conf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/common/linux.conf:
/usr/share/qt4/mkspecs/qconfig.pri:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_functions.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt_config.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/exclusive_builds.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_pre.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/release.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/default_post.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/warn_on.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/qt.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/unix/thread.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/moc.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/resources.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/uic.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/yacc.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/lex.prf:
/usr/local/ti-sdk-am180x-evm/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/features/include_source_dir.prf:
qmake:  FORCE
    @$(QMAKE) -unix -o Makefile helloworl.pro
dist:
    @$(CHK_DIR_EXISTS) .tmp/helloworl1.0.0 || $(MKDIR) .tmp/helloworl1.0.0
    $(COPY_FILE) --parents $(SOURCES) $(DIST) .tmp/helloworl1.0.0/ && $(COPY_FILE) --parents main.cpp .tmp/helloworl1.0.0/ && (cd `dirname .tmp/helloworl1.0.0` && $(TAR) helloworl1.0.0.tar helloworl1.0.0 && $(COMPRESS) helloworl1.0.0.tar) && $(MOVE) `dirname .tmp/helloworl1.0.0`/helloworl1.0.0.tar.gz . && $(DEL_FILE) -r .tmp/helloworl1.0.0
clean:compiler_clean
    -$(DEL_FILE) $(OBJECTS)
    -$(DEL_FILE) *~ core *.core
####### Sub-libraries
distclean: clean
    -$(DEL_FILE) $(TARGET)
    -$(DEL_FILE) Makefile
check: first
mocclean: compiler_moc_header_clean compiler_moc_source_clean
mocables: compiler_moc_header_make_all compiler_moc_source_make_all
compiler_moc_header_make_all:
compiler_moc_header_clean:
compiler_rcc_make_all:
compiler_rcc_clean:
compiler_image_collection_make_all: qmake_image_collection.cpp
compiler_image_collection_clean:
    -$(DEL_FILE) qmake_image_collection.cpp
compiler_moc_source_make_all:
compiler_moc_source_clean:
compiler_uic_make_all:
compiler_uic_clean:
compiler_yacc_decl_make_all:
compiler_yacc_decl_clean:
compiler_yacc_impl_make_all:
compiler_yacc_impl_clean:
compiler_lex_make_all:
compiler_lex_clean:
compiler_clean:
####### Compile
main.o: main.cpp
    $(CXX) -c $(CXXFLAGS) $(INCPATH) -o main.o main.cpp
####### Install
install:   FORCE
uninstall:   FORCE
FORCE:
