Part Number: TDA4VM
Is there a way I can run Ubuntu 20.04 / 22.04 / 24.04 in the TDA4VM board? (Probably SK-TDA4VM)
Part Number: TDA4VM
We haven't tried running ubuntu directly on TDA4VM board. But it is possible to run ubuntu on the docker that comes pre-packaged with SDK.
Tanmay
Hi Tanmay,
Is there any documentation about running ubuntu on the docker?
How to install that ubuntu?
You can try using the steps mentioned here : https://www.makeuseof.com/run-ubuntu-as-docker-container/
Tanmay
I do not quite understand what you intend to do.
But yes, if you integrate the x11 app with your yocto build, you should be able to run x11.
Tanmay
Hi Tanmay,
Basically, I need ubuntu in TDA4VM.
And easiest way I can get there is by using docker. But integrating wayland display server with gnome is quite difficult. Thats why I want to use x11 as my display server
