We are encountering a root login issue after porting SDK 10. Could you please advise if we might be missing something and provide guidance on how to resolve this root login problem?
Logs:
�����[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.32 (nithin@PPL-544U) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #6 SMP PREEMPT Mon Oct 7 17:42:42 IST 2024 [ 0.000000] Machine model: Texas Instruments AM62A7 SK [ 0.000000] Memory limited to 1024MB [ 0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma': size 576 MiB [ 0.000000] OF: reserved mem: initialized node mcu_r5-msram-memory@43C40000, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x0000000043c40000..0x0000000043c4ffff (64 KiB) nomap non-reusable mcu_r5-msram-memory@43C40000 [ 0.000000] OF: reserved mem: initialized node sharebuffer_bigdata_ddr, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x0000000098800000..0x00000000997fffff (16384 KiB) nomap non-reusable sharebuffer_bigdata_ddr [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000099800000..0x00000000998fffff (1024 KiB) nomap non-reusable c7x-dma-memory@99800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000099900000..0x000000009b7ffffe (31743 KiB) nomap non-reusable c7x-memory@99900000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9b800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable r5f-dma-memory@9b900000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-dma-memory@9c900000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009e700000, size 0 MiB [ 0.000000] OF: reserved mem: initialized node reserve-region-2-memory@9e700000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009e700000..0x000000009e77ffff (512 KiB) nomap non-reusable reserve-region-2-memory@9e700000 [ 0.000000] OF: reserved mem: 0x000000009e780000..0x000000009e7fffff (512 KiB) nomap non-reusable tfa@9e780000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a02fffff (3072 KiB) nomap non-reusable edgeai-rtos-ipc-memory-region [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0300000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a0300000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0300000..0x00000000a22fffff (32768 KiB) nomap non-reusable edgeai-dma-memory@a0300000 [ 0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2300000..0x00000000b7afffff (352256 KiB) map non-reusable edgeai_shared-memories [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b7b00000, size 111 MiB [ 0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@b7b00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000b7b00000..0x00000000be9fffff (113664 KiB) nomap non-reusable edgeai-core-heap-memory@b7b00000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x00000000987fffff] [ 0.000000] node 0: [mem 0x0000000098800000-0x000000009b7fefff] [ 0.000000] node 0: [mem 0x000000009b800000-0x00000000a22fffff] [ 0.000000] node 0: [mem 0x00000000a2300000-0x00000000b7afffff] [ 0.000000] node 0: [mem 0x00000000b7b00000-0x00000000be9fffff] [ 0.000000] node 0: [mem 0x00000000bea00000-0x00000000bfffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges [ 0.000000] cma: Reserved 80 MiB at 0x0000000093800000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 18 pages/cpu s34024 r8192 d31512 u73728 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,460800n8 init=/bin/sh mem=1G [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258047 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x000000008bf00000-0x000000008ff00000] (64MB) [ 0.000000] Memory: 215784K/1048572K available (8640K kernel code, 668K rwdata, 2448K rodata, 27648K init, 274K bss, 750868K reserved, 81920K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000313] Console: colour dummy device 80x25 [ 0.000358] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.000370] pid_max: default: 32768 minimum: 301 [ 0.000429] LSM: initializing lsm=capability,integrity [ 0.000514] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.000525] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.002238] rcu: Hierarchical SRCU implementation. [ 0.002250] rcu: Max phase no-delay instances is 1000. [ 0.002468] Platform MSI: msi-controller@1820000 domain created [ 0.002852] smp: Bringing up secondary CPUs ... [ 0.003481] Detected VIPT I-cache on CPU1 [ 0.003557] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.003576] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000 [ 0.003639] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.004408] Detected VIPT I-cache on CPU2 [ 0.004462] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.004475] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000 [ 0.004507] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.005108] Detected VIPT I-cache on CPU3 [ 0.005159] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.005171] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000 [ 0.005200] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.005268] smp: Brought up 1 node, 4 CPUs [ 0.005274] SMP: Total of 4 processors activated. [ 0.005279] CPU features: detected: 32-bit EL0 Support [ 0.005283] CPU features: detected: CRC32 instructions [ 0.005351] CPU: All CPU(s) started at EL2 [ 0.005354] alternatives: applying system-wide alternatives [ 0.006586] devtmpfs: initialized [ 0.013746] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.013771] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.016078] pinctrl core: initialized pinctrl subsystem [ 0.016898] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.017622] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 0.017688] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.017752] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.018275] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.018362] ASID allocator initialised with 65536 entries [ 0.027189] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts [ 0.029949] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.030385] Modules: 22816 pages in range for non-PLT usage [ 0.030392] Modules: 514336 pages in range for PLT usage [ 0.031019] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.031028] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.031033] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.031036] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.031040] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.031043] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.031047] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.031050] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.031432] cryptd: max_cpu_qlen set to 1000 [ 0.032219] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected [ 0.032508] iommu: Default domain type: Translated [ 0.032514] iommu: DMA domain TLB invalidation policy: strict mode [ 0.032999] mc: Linux media interface: v0.10 [ 0.033028] videodev: Linux video capture interface: v2.00 [ 0.033058] pps_core: LinuxPPS API ver. 1 registered [ 0.033061] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.033072] PTP clock support registered [ 0.033092] EDAC MC: Ver: 3.0.0 [ 0.033498] FPGA manager framework [ 0.034345] clocksource: Switched to clocksource arch_sys_counter [ 0.040316] Carveout Heap: Exported 0 MiB at 0x0000000043c40000 [ 0.040416] Carveout Heap: Exported 16 MiB at 0x0000000098800000 [ 0.040501] Carveout Heap: Exported 344 MiB at 0x00000000a2300000 [ 0.040609] NET: Registered PF_INET protocol family [ 0.040739] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.041730] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) [ 0.041788] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.041800] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.041855] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.042072] TCP: Hash tables configured (established 8192 bind 8192) [ 0.042159] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.042190] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 0.042331] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.042439] Starting Decompress [ 0.047525] Initialise system trusted keyrings [ 0.047793] workingset: timestamp_bits=46 max_order=17 bucket_order=0 [ 0.079684] Key type asymmetric registered [ 0.079706] Asymmetric key parser 'x509' registered [ 0.079781] io scheduler mq-deadline registered [ 0.079787] io scheduler kyber registered [ 0.083362] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.084016] pinctrl-single f4000.pinctrl: 151 pins, size 604 [ 0.085524] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.091736] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.105664] loop: module loaded [ 0.109076] CAN device driver interface [ 0.109935] i2c_dev: i2c /dev entries driver [ 0.112818] ledtrig-cpu: registered to indicate activity on CPUs [ 0.113118] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.113807] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100 [ 0.114056] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100 [ 0.114190] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100 [ 0.114252] omap-mailbox 29030000.mailbox: no available mbox devices found [ 0.116544] NET: Registered PF_PACKET protocol family [ 0.116562] can: controller area network core [ 0.116615] NET: Registered PF_CAN protocol family [ 0.116624] can: raw protocol [ 0.116631] can: broadcast manager protocol [ 0.116640] can: netlink gateway - max_hops=1 [ 0.116710] Key type dns_resolver registered [ 0.120602] Loading compiled-in X.509 certificates [ 0.129172] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.4-v09.00.04_am62a_dkek+ (Ko') [ 0.154230] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000 [ 0.154783] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode [ 0.154837] k3-dsp-rproc 7e000000.dsp: local reset is deasserted for device [ 0.155057] remoteproc remoteproc0: 7e000000.dsp is available [ 0.156704] platform 79000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 0.156824] platform 79000000.r5f: configured R5F for IPC-only mode [ 0.156938] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000 [ 0.157286] remoteproc remoteproc1: 79000000.r5f is available [ 0.157300] remoteproc remoteproc1: attaching to 79000000.r5f [ 0.157963] platform 79000000.r5f: R5F core initialized in IPC-only mode [ 0.157997] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@9b800000 [ 0.158735] virtio_rpmsg_bus virtio0: rpmsg host is online [ 0.158767] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7) [ 0.158774] remoteproc remoteproc1: remote processor 79000000.r5f is now attached [ 0.160423] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 0.160545] platform 78000000.r5f: configured R5F for IPC-only mode [ 0.160671] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000 [ 0.161202] remoteproc remoteproc2: 78000000.r5f is available [ 0.161213] remoteproc remoteproc2: attaching to 78000000.r5f [ 0.161753] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 0.161781] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@9c800000 [ 0.162420] virtio_rpmsg_bus virtio1: rpmsg host is online [ 0.162452] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7) [ 0.162461] remoteproc remoteproc2: remote processor 78000000.r5f is now attached [ 0.162640] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 0.164016] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 0.164779] omap_i2c 20010000.i2c: bus 0 rev0.12 at 400 kHz [ 0.166169] omap_i2c 20020000.i2c: bus 1 rev0.12 at 400 kHz [ 0.167717] omap_i2c 20030000.i2c: bus 2 rev0.12 at 400 kHz [ 0.168050] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 0.168238] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 0.168484] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 0.168827] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created [ 0.169701] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 0.172381] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 0.174992] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 0.177355] ti-udma 485c0000.dma-controller: Channels: 26 (tchan: 12, rchan: 14) [ 0.178960] ti-udma 4e230000.dma-controller: Number of rings: 6 [ 0.179574] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6) [ 0.181077] printk: console [ttyS2] disabled [ 0.181451] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 164, base_baud = 3000000) is a 8250 [ 0.181508] printk: console [ttyS2] enabled [ 0.390750] Decompress Completed [ 0.595111] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found [ 0.596859] vdec 30210000.video-codec: failed to get irq resource, falling back to polling [ 0.603263] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE' [ 0.605286] vdec 30210000.video-codec: Product Code: 0x521c [ 0.606873] vdec 30210000.video-codec: Firmware Revision: 320127 [ 0.608791] remoteproc remoteproc0: powering up 7e000000.dsp [ 0.610425] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11604048 [ 0.623747] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000 [ 0.625633] clk: Disabling unused clocks [ 0.625896] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node c7x-dma-memory@99800000 [ 0.629535] virtio_rpmsg_bus virtio2: rpmsg host is online [ 0.630975] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7) [ 0.63264] remoteproc remoteproc0: remote processor 7e000000.dsp is now up [ 0.640979] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd [ 0.641139] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [ 0.643371] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15 [ 0.647182] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe [ 0.648339] Freeing unused kernel memory: 27648K [ 0.649223] virtio_rpmsg_bus virtio2: msg received with no recipient [ 0.650383] Run /init as init process [ 0.652071] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe [ 0.654825] virtio_rpmsg_bus virtio1: msg received with no recipient INIT: version 2.96 booting INIT: Entering runlevel: 5 Starting syslogd/klogd: done /dev/mem opened. Memory mapped at address 0xffff81c75000. Read at address 0x000F4208 (0xffff81c75208): 0x00050007 Write at address 0x000F4208 (0xffff81c75208): 0x00010007, readback 0x00010007 /dev/mem opened. Memory mapped at address 0xffffa01d3000. Read at address 0x000F4214 (0xffffa01d3214): 0x00050007 Write at address 0x000F4214 (0xffffa01d3214): 0x00040000, readback 0x00040000 /dev/mem opened. Memory mapped at address 0xffff8f574000. Read at address 0x00601038 (0xffff8f574038): 0xFFFFFFFF Write at address 0[ 0.831846] max25614a: loading out-of-tree module taints kernel. x00601038 (0xffff8f574038): 0xFFFFFFEF, readback 0xFFFFFFEF /dev/mem opened. Memory mapped at address 0xffff83fc9000. Read at[ 0.835144] max25614a 1-004a: max25614a probed address 0x00601040 (0xffff83fc9040): 0x00000000 Write at addr[ 0.837568] max25614a 1-004a: Runtime PM usage count underflow! ess 0x00601040 (0xffff83fc9040): 0x00000010, readback 0x00000010 insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/pwm/pwm-tiehrpwm.ko': No such file or directory [ 0.845203] ox05b 2-0010: inck rate: 24000000 Hz [ 0.870554] ox05b_detect ox05b_detect: detected chip ID 0x0558 [ 0.872442] ox05b 2-0010: ox05b probed [ 1.028996] ox05b 2-0010: SCCB CRC mismatch occured Reg Addr: 0x3208 & Data: 0x4 [ 1.030880] ox05b 2-0010: nRcvCRC(Calculated CRC) 0xf03d & nReadCRC(Received from imager) 0x6d4c /home/root/ox05b-camera-setup.sh: line 31: media-ctl: not found /home/root/ox05b-camera-setup.sh: line 32: media-ctl: not found /home/root/ox05b-camera-setup.sh: line 33: media-ctl: not found /home/root/ox05b-camera-setup.sh: line 34: media-ctl: not found insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/common/usb-common.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/core/usbcore.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/gadget/udc/udc-core.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/dwc3/dwc3.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/dwc3/dwc3-am62.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/gadget/libcomposite.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/gadget/function/u_ether.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/gadget/function/usb_f_ecm.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/gadget/function/usb_f_rndis.ko': No such file or directory insmod: can't insert '/lib/modules/6.1.80-dirty/kernel/drivers/usb/gadget/legacy/g_ether.ko': No such file or directory ifconfig: SIOCGIFFLAGS: No such device Starting Dropbear SSH server: /etc/init.d/dropbear: line 45: dropbearkey: not found /sbin/ldconfig: Path `/lib' given more than once /sbin/ldconfig: Can't stat /lib64: No such file or directory /sbin/ldconfig: Can't stat /libilp32: No such file or directory /sbin/ldconfig: Path `/usr/lib' given more than once /sbin/ldconfig: Can't stat /usr/lib64: No such file or directory /sbin/ldconfig: Can't stat /usr/libilp32: No such file or directory /lib: libz.so.1 -> libz.so.1.3.1 libutil.so.1 -> libutil-2.30.so libudev.so.1 -> libudev.so.1.7.8 libsystemd.so.0 -> libsystemd.so.0.38.0 librt.so.1 -> librt-2.30.so libresolv.so.2 -> libresolv-2.30.so libpthread.so.0 -> libpthread-2.30.so libpamc.so.0 -> libpamc.so.0.82.1 libpam_misc.so.0 -> libpam_misc.so.0.82.1 libpam.so.0 -> libpam.so.0.85.1 libnss_myhostname.so.2 -> libnss_myhostname.so.2 libnss_hesiod.so.2 -> libnss_hesiod-2.30.so libnss_files.so.2 -> libnss_files-2.30.so libnss_dns.so.2 -> libnss_dns-2.30.so libnss_compat.so.2 -> libnss_compat-2.30.so libnsl.so.1 -> libnsl-2.30.so libmount.so.1 -> libmount.so.1.1.0 libm.so.6 -> libm-2.30.so libgcc_s.so.1 -> libgcc_s.so.1 libext2fs.so.2 -> libext2fs.so.2.4 libe2p.so.2 -> libe2p.so.2.3 libdl.so.2 -> libdl-2.30.so libcrypt.so.1 -> libcrypt-2.30.so libcom_err.so.2 -> libcom_err.so.2.1 libcap.so.2 -> libcap.so.2.69 libc.so.6 -> libc-2.30.so libblkid.so.1 -> libblkid.so.1.1.0 libanl.so.1 -> libanl-2.30.so libBrokenLocale.so.1 -> libBrokenLocale-2.30.so ld-linux-aarch64.so.1 -> ld-2.30.so /usr/lib: /sbin/ldconfig: Cannot stat /usr/lib/libblkid.so: No such file or directory /sbin/ldconfig: Cannot stat /usr/lib/libmount.so: No such file or directory /sbin/ldconfig: Cannot stat /usr/lib/libpthread.so: No such file or directory /sbin/ldconfig: Cannot stat /usr/lib/librt.so: No such file or directory /sbin/ldconfig: Cannot stat /usr/lib/libtbb.so: No such file or directory /sbin/ldconfig: Cannot stat /usr/lib/libtbb.so.12: No such file or directory libzstd.so.1 -> libzstd.so.1.5.5 libz.so.1 -> libz.so.1.3.1 libyaml-cpp.so.0.8 -> libyaml-cpp.so.0.8.0 libxml2.so.2 -> libxml2.so.2.12.8 libvx_tidl_rt.so.1.0 -> libvx_tidl_rt.so.1.0 libvorbis.so.0 -> libvorbis.so.0.4.9 libv4lconvert.so.0 -> libv4lconvert.so.0.0.0 libv4l2subdev.so.0 -> libv4l2subdev.so.0.0.0 libv4l2rds.so.0 -> libv4l2rds.so.0.0.0 libv4l2.so.0 -> libv4l2.so.0.0.0 libuuid.so.1 -> libuuid.so.1.3.0 libtivision_apps.so.8.6.0 -> libtivision_apps.so.8.6.0 libtivision_apps.so.10.0.0 -> libtivision_apps.so.10.0.0 libtiff.so.6 -> libtiff.so.6.0.2 libtidl_tfl_delegate.so.1.0 -> libtidl_tfl_delegate.so.1.0 libtidl_onnxrt_EP.so.1.0 -> libtidl_onnxrt_EP.so.1.0 libti_rpmsg_char.so.0 -> libti_rpmsg_char.so.0.6.7 libtheoradec.so.1 -> libtheoradec.so.1.1.4 libtag.so.2 -> libtag.so.2.0.1 (changed) libsubid.so.4 -> libsubid.so.4.0.0 libstdc++.so.6 -> libstdc++.so.6.0.32 libssl.so.3 -> libssl.so.3 libsoup-3.0.so.0 -> libsoup-3.0.so.0.7.1 libseccomp.so.2 -> libseccomp.so.2.5.5 libsbc.so.1 -> libsbc.so.1.3.1 libpsx.so.2 -> libpsx.so.2.69 libpcre.so.1 -> libpcre.so.1.2.13 liborc-0.4.so.0 -> liborc-0.4.so.0.38.0 libogg.so.0 -> libogg.so.0.8.5 libnettle.so.8 -> libnettle.so.8.8 libmediactl.so.0 -> libmediactl.so.0.0.0 liblzma.so.5 -> liblzma.so.5.4.6 libkmod.so.2 -> libkmod.so.2.4.1 libgudev-1.0.so.0 -> libgudev-1.0.so.0.3.0 libgthread-2.0.so.0 -> libgthread-2.0.so.0.7800.6 libgstvideo-1.0.so.0 -> libgstvideo-1.0.so.0.2212.0 libgsttiovx-1.0.so.1 -> libgsttiovx-1.0.so.1.0 libgsttag-1.0.so.0 -> libgsttag-1.0.so.0.2212.0 libgstsdp-1.0.so.0 -> libgstsdp-1.0.so.0.2212.0 libgstsctp-1.0.so.0 -> libgstsctp-1.0.so.0.2212.0 libgstreamer-1.0.so.0 -> libgstreamer-1.0.so.0.2212.0 libgstpbutils-1.0.so.0 -> libgstpbutils-1.0.so.0.2212.0 libgstnet-1.0.so.0 -> libgstnet-1.0.so.0.2212.0 libgstisoff-1.0.so.0 -> libgstisoff-1.0.so.0.2212.0 libgstinsertbin-1.0.so.0 -> libgstinsertbin-1.0.so.0.2212.0 libgstbasecamerabinsrc-1.0.so.0 -> libgstbasecamerabinsrc-1.0.so.0.2212.0 libgstbase-1.0.so.0 -> libgstbase-1.0.so.0.2212.0 libgstaudio-1.0.so.0 -> libgstaudio-1.0.so.0.2212.0 libgstapp-1.0.so.0 -> libgstapp-1.0.so.0.2212.0 libgstallocators-1.0.so.0 -> libgstallocators-1.0.so.0.2212.0 libgomp.so.1 -> libgomp.so.1.0.0 libgobject-2.0.so.0 -> libgobject-2.0.so.0.7800.6 libgmodule-2.0.so.0 -> libgmodule-2.0.so.0.7800.6 libglib-2.0.so.0 -> libglib-2.0.so.0.7800.6 libgio-2.0.so.0 -> libgio-2.0.so.0.7800.6 libffi.so.8 -> libffi.so.8.1.4 libexpat.so.1 -> libexpat.so.1.9.2 libedgeai-tiovx-modules.so.0.1.0 -> libedgeai-tiovx-modules.so.0.1.0 libedgeai-tiovx-kernels.so.0.1.0 -> libedgeai-tiovx-kernels.so.0.1.0 libedgeai-apps-utils.so.0.1.0 -> libedgeai-apps-utils.so.0.1.0 libdrm.so.2 -> libdrm.so.2.4.0 libdbus-1.so.3 -> libdbus-1.so.3.32.4 libcurl.so.4 -> libcurl.so.4.8.0 libcrypto.so.3 -> libcrypto.so.3 libcrypt.so.2 -> libcrypt.so.2.0.0 libcairo-gobject.so.2 -> libcairo-gobject.so.2.11800.0 libattr.so.1 -> libattr.so.1.1.2501 libatomic.so.1 -> libatomic.so.1.2.0 libacl.so.1 -> libacl.so.1.1.2302 libFLAC.so.12 -> libFLAC.so.12.1.0 __ __ | \/ | __ _ __ _ _ __ __ _ | |\/| | / _` | / _` | | '_ \ / _` | | | | || (_| | | (_| | | | | | | (_| | |_| |_| \__,_| \__, | |_| |_| \__,_| |___/ (none) login: root Login incorrect Login incorrect Login incorrect Login incorrect Login incorrect Maximum number of tries exceeded (5)
