AM620-Q1: Clarification on Memory Configurations and OSPI-NAND Detection Issue on AM62x LP Board
Part Number: AM620-Q1
Hello Team,
I am working with the AM62x-LP evaluation board and have encountered some confusion regarding the flash memory interfaces supported and the configuration observed in U-Boot.
       1. Memory Interface Discrepancy:
  •         On the TI AM62x-LP product page SK-AM62-LP Development kit | TI.com, in features list it mention that the flash interface supported Quad Serial Peripheral Interface (QSPI).
  •         In the AM62x-LP User Guide and schematic, the board provides a 512Mb OSPI0 flash interface,
  •         and the interfacing table lists an eMMC (MTFC16GAPALBH-IT) along with a NAND flash device (16GB).
Could you please clarify the exact supported flash memory interface QSPI or OSPI NAND ? and configuration for the AM62x-LP?
Please provide the steps to access the OSPI-NAND and emmc-NAND from u-boot ?
         2. Issue with OSPI-NAND in U-Boot:
  • I have attached my U-Boot logs for reference. In the U-boot logs, Nand memory is showing as 0 MB
    U-Boot 2023.04 (Oct 08 2024 - 12:51:44 +0530)
    SoC: AM62X SR1.0 HS-FS
    Model: Texas Instruments AM62x LP SK
    EEPROM not available at 80, trying to read at 81
    Board: AM62-LP-SKEVM rev E2
    DRAM: no bloblist found!2 GiB
    Core: 81 devices, 33 uclasses, devicetree: separate
    NAND: 0 MiB
    MMC: mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In: serial
    Out: serial
    Err: serial
    Net: eth0: ethernet@8000000port@1
    Hit any key to stop autoboot: 0
  • While trying with DFU Nand commands am getting an error as Device nand0 not found!
 Could you please help me resolve the issue and understand why the OSPI-NAND is not being detected in U-Boot?
=> dfu 0 nand 0
DFU entities configuration failed!
(partition table does not match dfu_alt_info?)
dfu - Device Firmware Upgrade
=> dfu 0 nand list
=> mtdparts
Device spi-nand0 not found!
Thanks & Regards,
Yashavanth Gowda
  • Could someone please provide insights on this issue? I haven't received a response for a few days.
  • U-Boot 2023.04 (Oct 08 2024 - 12:51:44 +0530)
    NAND: 0 MiB
    Are you using the un-modified SDK image from SDK v9.2 as-is? And it shows NAND as 0 MiB?
    Can you try the latest AM62 SDK images (v10.x, see https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-AM62X/10.00.07.04) with U-Boot 2024.04. When I look at U-Boot I can see there's an OSPI NAND being defined and fully enabled.
    arch/arm/dts/k3-am62-lp-sk.dts- flash@0{
    arch/arm/dts/k3-am62-lp-sk.dts:         compatible = "spi-nand";
    arch/arm/dts/k3-am62-lp-sk.dts-         reg = <0x0>;
    arch/arm/dts/k3-am62-lp-sk.dts-         spi-tx-bus-width = <8>;
    arch/arm/dts/k3-am62-lp-sk.dts-         spi-rx-bus-width = <8>;
    arch/arm/dts/k3-am62-lp-sk.dts-         spi-max-frequency = <50000000>;
    arch/arm/dts/k3-am62-lp-sk.dts-         cdns,tshsl-ns = <60>;
    arch/arm/dts/k3-am62-lp-sk.dts-         cdns,tsd2d-ns = <60>;
    arch/arm/dts/k3-am62-lp-sk.dts-         cdns,tchsh-ns = <60>;
    arch/arm/dts/k3-am62-lp-sk.dts-         cdns,tslch-ns = <60>;
    arch/arm/dts/k3-am62-lp-sk.dts-         cdns,read-delay = <1>;
    arch/arm/dts/k3-am62-lp-sk.dts-         bootph-all;
    arch/arm/dts/k3-am62-lp-sk.dts-         partitions {
    arch/arm/dts/k3-am62-lp-sk.dts-                 compatible = "fixed-partitions";
    arch/arm/dts/k3-am62-lp-sk.dts-                 #address-cells = <1>;
    arch/arm/dts/k3-am62-lp-sk.dts-                 #size-cells = <1>;
    arch/arm/dts/k3-am62-lp-sk.dts-                 partition@0 {
    arch/arm/dts/k3-am62-lp-sk.dts:                         label = "ospi_nand.tiboot3";
    arch/arm/dts/k3-am62-lp-sk.dts-                         reg = <0x0 0x80000>;
    arch/arm/dts/k3-am62-lp-sk.dts-                 };
    arch/arm/dts/k3-am62-lp-sk.dts-                 partition@80000 {
    arch/arm/dts/k3-am62-lp-sk.dts:                         label = "ospi_nand.tispl";
    arch/arm/dts/k3-am62-lp-sk.dts-                         reg = <0x80000 0x200000>;
    arch/arm/dts/k3-am62-lp-sk.dts-                 partition@280000 {
    arch/arm/dts/k3-am62-lp-sk.dts:                         label = "ospi_nand.u-boot";
    arch/arm/dts/k3-am62-lp-sk.dts-                         reg = <0x280000 0x400000>;
    arch/arm/dts/k3-am62-lp-sk.dts-                 partition@680000 {
    arch/arm/dts/k3-am62-lp-sk.dts:                         label = "ospi_nand.env";
    arch/arm/dts/k3-am62-lp-sk.dts-                         reg = <0x680000 0x40000>;
    arch/arm/dts/k3-am62-lp-sk.dts-                 partition@6c0000 {
    arch/arm/dts/k3-am62-lp-sk.dts:                         label = "ospi_nand.env.backup";
    arch/arm/dts/k3-am62-lp-sk.dts-                         reg = <0x6c0000 0x40000>;
    arch/arm/dts/k3-am62-lp-sk.dts-                 partition@2000000 {
    arch/arm/dts/k3-am62-lp-sk.dts:                         label = "ospi_nand.rootfs";
    arch/arm/dts/k3-am62-lp-sk.dts-                         reg = <0x2000000 0x5fc0000>;
    arch/arm/dts/k3-am62-lp-sk.dts-                 partition@7fc0000 {
    arch/arm/dts/k3-am62-lp-sk.dts:                         label = "ospi_nand.phypattern";
    arch/arm/dts/k3-am62-lp-sk.dts-                         reg = <0x7fc0000 0x40000>;
    arch/arm/dts/k3-am62-lp-sk.dts-};
    Regards, Andreas
  • Hello Andreas,
    I have tried with latest AM62 SDK(v10x) build the U-boot with default deconfig files below
    am62x_lpsk_r5_defconfig
    am62x_lpsk_a53_defconfig
    got the result same only & attached the logs
    U-Boot 2024.04 (Oct 17 2024 - 17:32:48 +0530)
    EEPROM not available at 0x50, trying to read at 0x51
    DRAM:  2 GiB
    Core:  83 devices, 32 uclasses, devicetree: separate
    NAND:  0 MiB
    In:    serial
    Out:   serial
    Err:   serial
    Could you please help us to know, are we missing anywhere? Do we need to add or remove any configurations/component in deconfig files?
    Thanks & Regards,
    Yashavantha Gowda
  • Yashavantha,
    let me talk to my colleagues to see what should be expected here and get back to you.
    Regards, Andreas
