Daolin:
What about aconits tecnologies' EC-Master ?
Daolin:
Hello Jim,
I've moved your inquiry into this separate thread as the FAQ was supposed to be locked.
The reason why the Acontis EC-Master was not added to the FAQ was because I am not aware of if it has been tested internally on TI processors before. I will double check with the internal team if it ever was setup before.
-Daolin
For software from a 3rd party, you should primarily check with them for examples and support.
Hi Jim,
Below is some information on Acontis running with SolidRun's AM64x SOM.
https://www.acontis.com/en/ethercat-master-on-solidruns-compact-am64x-som.html
https://github.com/SolidRun/Documentation/blob/bsp/am64/ethercat-demo.md
So yes Acontis EtherCAT Master can run on TI processors but for more specific support from 3rd parties such as Acontis, you would need to contact them directly.
-Daolin
