TDA4AH-Q1: LPDDR4 Fails to boot at 1866MHz Clock speed
Part Number: TDA4AH-Q1
Other Parts Discussed in Thread: TDA4VM
At 1866MHz Clock Speed the device fails to boot and gets stuck at the uboot prompt after "I/TC: Primary CPU switching to normal world boot". This board has already successfully booted when clock is set at 1600MHz and 2133MHz. Unsure why at 1866MHz it would fail.
Only parameters changed between the 1600MHz and the 1866 MHz were the Latency parameters shown below and obviously the Memory frequency. Already made sure they match the DRAM devices datasheet.
After running the tda4vm_lp4_debug.out it shows a dfi_rddata_valid timeout and PLL Frequency Error. Is 1866MHz a supported frequency?
[MCU_Cortex_R5_0] DDRSS0 Training Results:
Training Results; Frequency 0; CS 0
PHY Vref Training:
	 DQ Lane 0 Vref Mode: 0x7 Vref Sel: 0x20
	 DQ Lane 1 Vref Mode: 0x7 Vref Sel: 0x1f
	 DQ Lane 2 Vref Mode: 0x7 Vref Sel: 0x22
	 DQ Lane 3 Vref Mode: 0x7 Vref Sel: 0x20
	 ACC Vref Control: 0x7ab
CA Training:
	 LP4 CA Programmed Delays:
	 CA Bit 0 delay: 348
	 CA Bit 1 delay: 338
	 CA Bit 2 delay: 34c
	 CA Bit 3 delay: 33e
	 CA Bit 4 delay: 34e
	 CA Bit 5 delay: 34e
Write Leveling:
	 DQ Lane 0 WRDQS: 0xa8
	 DQ Lane 1 WRDQS: 0xc6
	 DQ Lane 2 WRDQS: 0x72
	 DQ Lane 3 WRDQS: 0xa8
	 DQ Lane 0 Write Path Latency Add: 0x0
	 DQ Lane 1 Write Path Latency Add: 0x0
	 DQ Lane 2 Write Path Latency Add: 0x0
	 DQ Lane 3 Write Path Latency Add: 0x0
Gate Training:
	 DQS Gate Lane 0 : slave_delay: 16 lat_adj: 5
	 DQS Gate Lane 1 : slave_delay: 480 lat_adj: 4
	 DQS Gate Lane 2 : slave_delay: 52 lat_adj: 5
	 DQS Gate Lane 3 : slave_delay: 492 lat_adj: 4
Read Leveling:
	read_delay_fall, dq0 : 138
	read_delay_rise, dq0 : 144
	read_delay_fall, dq1 : 120
	read_delay_rise, dq1 : 126
	read_delay_fall, dq2 : 126
	read_delay_rise, dq2 : 144
	read_delay_fall, dq3 : 120
	read_delay_rise, dq3 : 138
	read_delay_fall, dq4 : 108
	read_delay_rise, dq4 : 120
	read_delay_fall, dq5 : 120
	read_delay_rise, dq5 : 132
	read_delay_fall, dq6 : 120
	read_delay_rise, dq6 : 132
	read_delay_fall, dq7 : 144
	read_delay_rise, dq7 : 156
	read_delay_fall, dq8 : 132
	read_delay_rise, dq8 : 144
	read_delay_fall, dq9 : 120
	read_delay_rise, dq9 : 132
	read_delay_fall, dq10 : 120
	read_delay_rise, dq10 : 132
	read_delay_fall, dq11 : 114
	read_delay_rise, dq11 : 132
	read_delay_fall, dq12 : 126
	read_delay_rise, dq12 : 132
	read_delay_fall, dq13 : 114
	read_delay_rise, dq13 : 126
	read_delay_fall, dq14 : 114
	read_delay_rise, dq14 : 114
	read_delay_fall, dq15 : 132
	read_delay_rise, dq15 : 138
	read_delay_fall, dq16 : 126
	read_delay_rise, dq16 : 132
	read_delay_fall, dq17 : 132
	read_delay_rise, dq17 : 138
	read_delay_fall, dq18 : 108
	read_delay_rise, dq18 : 108
	read_delay_fall, dq19 : 120
	read_delay_rise, dq19 : 126
	read_delay_fall, dq20 : 120
	read_delay_rise, dq20 : 120
	read_delay_fall, dq21 : 114
	read_delay_rise, dq21 : 120
	read_delay_fall, dq22 : 114
	read_delay_rise, dq22 : 108
	read_delay_fall, dq23 : 120
	read_delay_rise, dq23 : 126
	read_delay_fall, dq24 : 126
	read_delay_rise, dq24 : 132
	read_delay_fall, dq25 : 126
	read_delay_rise, dq25 : 120
	read_delay_fall, dq26 : 114
	read_delay_rise, dq26 : 126
	read_delay_fall, dq27 : 126
	read_delay_rise, dq27 : 132
	read_delay_fall, dq28 : 114
	read_delay_rise, dq28 : 120
	read_delay_fall, dq29 : 120
	read_delay_rise, dq29 : 120
	read_delay_fall, dq30 : 120
	read_delay_rise, dq30 : 126
	read_delay_fall, dq31 : 132
	read_delay_rise, dq31 : 132
Write DQ Training:
	write_delay, dq0 : 960
	write_delay, dq1 : 984
	write_delay, dq2 : 968
	write_delay, dq3 : 968
	write_delay, dq4 : 992
	write_delay, dq5 : 968
	write_delay, dq6 : 968
	write_delay, dq7 : 952
	write_delay, dq8 : 976
	write_delay, dq9 : 992
	write_delay, dq10 : 992
	write_delay, dq11 : 992
	write_delay, dq12 : 984
	write_delay, dq13 : 992
	write_delay, dq14 : 992
	write_delay, dq15 : 992
	write_delay, dq16 : 992
	write_delay, dq17 : 992
	write_delay, dq18 : 1008
	write_delay, dq19 : 1008
	write_delay, dq20 : 992
	write_delay, dq21 : 992
	write_delay, dq22 : 992
	write_delay, dq23 : 992
	write_delay, dq24 : 976
	write_delay, dq25 : 984
	write_delay, dq26 : 992
	write_delay, dq27 : 992
	write_delay, dq28 : 992
	write_delay, dq29 : 992
	write_delay, dq30 : 984
	write_delay, dq31 : 976
Calibration Registers:
	CAL_OBS_0: 0x00814654
	CAL_OBS_2: 0x00814752
	CAL_OBS_3: 0xb3000000
	CAL_OBS_4: 0x00146540
	CAL_OBS_5: 0x00147528
	CAL_OBS_6: 0x00f4654f
	CAL_OBS_7: 0x03f4752f
CS Programmed Delays:
	phy_grp0_slave_delay_0: 0x0338
	phy_grp1_slave_delay_0: 0x0338
	phy_grp2_slave_delay_0: 0x034c
	phy_grp3_slave_delay_0: 0x034c
	phy_grp0_slave_delay_1: 0x034c
	phy_grp1_slave_delay_1: 0x0338
	phy_grp2_slave_delay_1: 0x034c
	phy_grp3_slave_delay_1: 0x034c
	phy_top_train_calib_error_info: 0x00000000
Training Results; Frequency 0; CS 1
PHY Vref Training:
CA Training:
	 CA Bit 0 delay: 348
	 CA Bit 1 delay: 338
	 CA Bit 2 delay: 34c
	 CA Bit 3 delay: 33e
	 CA Bit 4 delay: 34e
	 CA Bit 5 delay: 34e
Write Leveling:
	 DQ Lane 0 WRDQS: 0x0
	 DQ Lane 1 WRDQS: 0x0
	 DQ Lane 2 WRDQS: 0x0
	 DQ Lane 3 WRDQS: 0x0
Gate Training:
	 DQS Gate Lane 0 : slave_delay: 109 lat_adj: 5
	 DQS Gate Lane 1 : slave_delay: 109 lat_adj: 5
	 DQS Gate Lane 2 : slave_delay: 109 lat_adj: 5
	 DQS Gate Lane 3 : slave_delay: 109 lat_adj: 5
Read Leveling:
	read_delay_fall, dq0 : 160
	read_delay_rise, dq0 : 160
	read_delay_fall, dq1 : 160
	read_delay_rise, dq1 : 160
	read_delay_fall, dq2 : 160
	read_delay_rise, dq2 : 160
	read_delay_fall, dq3 : 160
	read_delay_rise, dq3 : 160
	read_delay_fall, dq4 : 160
	read_delay_rise, dq4 : 160
	read_delay_fall, dq5 : 160
	read_delay_rise, dq5 : 160
	read_delay_fall, dq6 : 160
	read_delay_rise, dq6 : 160
	read_delay_fall, dq7 : 160
	read_delay_rise, dq7 : 160
	read_delay_fall, dq8 : 160
	read_delay_rise, dq8 : 160
	read_delay_fall, dq9 : 160
	read_delay_rise, dq9 : 160
	read_delay_fall, dq10 : 160
	read_delay_rise, dq10 : 160
	read_delay_fall, dq11 : 160
	read_delay_rise, dq11 : 160
	read_delay_fall, dq12 : 160
	read_delay_rise, dq12 : 160
	read_delay_fall, dq13 : 160
	read_delay_rise, dq13 : 160
	read_delay_fall, dq14 : 160
	read_delay_rise, dq14 : 160
	read_delay_fall, dq15 : 160
	read_delay_rise, dq15 : 160
	read_delay_fall, dq16 : 160
	read_delay_rise, dq16 : 160
	read_delay_fall, dq17 : 160
	read_delay_rise, dq17 : 160
	read_delay_fall, dq18 : 160
	read_delay_rise, dq18 : 160
	read_delay_fall, dq19 : 160
	read_delay_rise, dq19 : 160
	read_delay_fall, dq20 : 160
	read_delay_rise, dq20 : 160
	read_delay_fall, dq21 : 160
	read_delay_rise, dq21 : 160
	read_delay_fall, dq22 : 160
	read_delay_rise, dq22 : 160
	read_delay_fall, dq23 : 160
	read_delay_rise, dq23 : 160
	read_delay_fall, dq24 : 160
	read_delay_rise, dq24 : 160
	read_delay_fall, dq25 : 160
	read_delay_rise, dq25 : 160
	read_delay_fall, dq26 : 160
	read_delay_rise, dq26 : 160
	read_delay_fall, dq27 : 160
	read_delay_rise, dq27 : 160
	read_delay_fall, dq28 : 160
	read_delay_rise, dq28 : 160
	read_delay_fall, dq29 : 160
	read_delay_rise, dq29 : 160
	read_delay_fall, dq30 : 160
	read_delay_rise, dq30 : 160
	read_delay_fall, dq31 : 160
	read_delay_rise, dq31 : 160
Write DQ Training:
	write_delay, dq0 : 640
	write_delay, dq1 : 640
	write_delay, dq2 : 640
	write_delay, dq3 : 640
	write_delay, dq4 : 640
	write_delay, dq5 : 640
	write_delay, dq6 : 640
	write_delay, dq7 : 640
	write_delay, dq8 : 640
	write_delay, dq9 : 640
	write_delay, dq10 : 640
	write_delay, dq11 : 640
	write_delay, dq12 : 640
	write_delay, dq13 : 640
	write_delay, dq14 : 640
	write_delay, dq15 : 640
	write_delay, dq16 : 640
	write_delay, dq17 : 640
	write_delay, dq18 : 640
	write_delay, dq19 : 640
	write_delay, dq20 : 640
	write_delay, dq21 : 640
	write_delay, dq22 : 640
	write_delay, dq23 : 640
	write_delay, dq24 : 640
	write_delay, dq25 : 640
	write_delay, dq26 : 640
	write_delay, dq27 : 640
	write_delay, dq28 : 640
	write_delay, dq29 : 640
	write_delay, dq30 : 640
	write_delay, dq31 : 640
Training Results; Frequency 1; CS 0
PHY Vref Training:
	 DQ Lane 1 Vref Mode: 0x7 Vref Sel: 0x20
CA Training:
	 CA Bit 0 delay: 348
	 CA Bit 1 delay: 338
	 CA Bit 2 delay: 34c
	 CA Bit 3 delay: 33e
	 CA Bit 4 delay: 34c
	 CA Bit 5 delay: 34e
Write Leveling:
	 DQ Lane 1 WRDQS: 0xc0
Gate Training:
	 DQS Gate Lane 0 : slave_delay: 90 lat_adj: 3
	 DQS Gate Lane 1 : slave_delay: 42 lat_adj: 3
	 DQS Gate Lane 2 : slave_delay: 440 lat_adj: 15
	 DQS Gate Lane 3 : slave_delay: 464 lat_adj: 2
Read Leveling:
	read_delay_rise, dq7 : 144
	read_delay_fall, dq8 : 138
	read_delay_rise, dq10 : 126
	read_delay_rise, dq11 : 126
	read_delay_rise, dq12 : 126
	read_delay_fall, dq13 : 120
	read_delay_rise, dq15 : 132
	read_delay_fall, dq25 : 120
	read_delay_rise, dq28 : 114
Write DQ Training:
	write_delay, dq0 : 807
	write_delay, dq1 : 815
	write_delay, dq2 : 2047
	write_delay, dq3 : 2047
	write_delay, dq4 : 2047
	write_delay, dq5 : 815
	write_delay, dq6 : 807
	write_delay, dq7 : 807
	write_delay, dq8 : 2047
	write_delay, dq9 : 2047
	write_delay, dq10 : 2047
	write_delay, dq11 : 815
	write_delay, dq12 : 811
	write_delay, dq13 : 815
	write_delay, dq14 : 2047
	write_delay, dq15 : 2047
	write_delay, dq16 : 815
	write_delay, dq17 : 2047
	write_delay, dq18 : 2047
	write_delay, dq19 : 2047
	write_delay, dq20 : 815
	write_delay, dq21 : 819
	write_delay, dq22 : 819
	write_delay, dq23 : 2047
	write_delay, dq24 : 819
	write_delay, dq25 : 819
	write_delay, dq26 : 2047
	write_delay, dq27 : 2047
	write_delay, dq28 : 2047
	write_delay, dq29 : 819
	write_delay, dq30 : 819
	write_delay, dq31 : 819
	phy_grp0_slave_delay_0: 0x0336
	phy_grp1_slave_delay_0: 0x0336
	phy_grp1_slave_delay_1: 0x0336
Training Results; Frequency 1; CS 1
PHY Vref Training:
CA Training:
	 CA Bit 0 delay: 348
	 CA Bit 1 delay: 338
	 CA Bit 2 delay: 34c
	 CA Bit 3 delay: 33e
	 CA Bit 4 delay: 34c
	 CA Bit 5 delay: 34e
Write Leveling:
Gate Training:
Read Leveling:
Write DQ Training:
DRAM VREF Values:
	mr12_f1_cs0: 0x00000021
	mr12_f1_cs1: 0x00000027
	mr12_f1_cs2: 0x00000023
	mr12_f1_cs3: 0x00000027
	mr12_f2_cs0: 0x00000020
	mr12_f2_cs1: 0x00000027
	mr12_f2_cs2: 0x00000021
	mr12_f2_cs3: 0x00000027
	mr14_f1_cs0: 0x00000020
	mr14_f1_cs1: 0x0000000f
	mr14_f1_cs2: 0x0000001d
	mr14_f1_cs3: 0x0000000f
	mr14_f2_cs0: 0x0000001b
	mr14_f2_cs1: 0x0000000f
	mr14_f2_cs2: 0x0000001d
	mr14_f2_cs3: 0x0000000f
PHY IO Pad TERM Registers:
	PHY_1320: 0x00014654
	PHY_1321: 0x00014654
	PHY_1322: 0x00014654
	PHY_1323: 0x00014654
	PHY_1324: 0x00014654
	PHY_1325: 0x00014752
	PHY_1326: 0x00014752
	PHY_1327: 0x00014654
	PHY_1328: 0x00014654
Enhanced Error Reporting:
	DQS Gate Error: 1
	Training Error: 1
	FSM Tran Error: 0
	PLL      Error: 1
	Parity   Error: 0
	Timeout  Error: 1
	Timeout Error Info:
		dfi_rddata_valid           Timeout: 1
		Max PLL lock assertion     Timeout: 1
		Min PLL lock assertion     Timeout: 0
		DFI PHY master interface   Timeout: 0
		dfi_phyupd_req (PI - PHY)  Timeout: 0
		dfi_phyupd_req (CTL - PHY) Timeout: 0
		dfi_lp_ack                 Timeout: 0
		DFS change @ PI - PHY      Timeout: 0
		DFS change @ CTL -PHY      Timeout: 0
		CA / CS training           Timeout: 0
		WRLVL training             Timeout: 0
		RDGATE training            Timeout: 0
		RDDATA training            Timeout: 0
		WDQ training               Timeout: 0
	Training Error Info: 0x00007800
	Data Slice Error Info (bits [4:0]):
		Byte0: 0x00000102
		Byte1: 0x00000102
		Byte2: 0x00000102
		Byte3: 0x00000102
	PLL Frequency Error: 0xf
  • Hi Chris,
    It looks like write DQ training had some issues (see below). This type of issue was more common a few years back (prior to v0.8.0 of the register configuration tool) but we should have made improvements to the register settings to avoid this type of issue.
    Can you confirm which TI device you are using? TDA4AH or TDA4VM?
    Can you provide the filled-in spreadsheet you used to generate your register configuration for LPDDR4-1866?
    Can you comment on which SDK (and SDK version) you are using?
    Can you also please dump the values of all the PLL12 registers after the issue occurs?
    Write DQ Training:
