PROCESSOR-SDK-AM68A: TIDL tools - ONNX model compilation issues
Part Number: PROCESSOR-SDK-AM68A
I am trying to generate model artifacts for an ONNX object detection model using a script located in the TIDL tools x86 container at examples/osrt_python/ort/onnxrt_ep.py. However, I get the following logs and error when I try to run the script after setting my model path in the dir -
root@fc5a52ad3ba2:/home/root/examples/osrt_python/ort# python3 onnxrt_ep.py -c
Available execution providers :  ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
Running 1 Models - ['resnet18_rcnn_azureml']
Running_Model :  resnet18_rcnn_azureml
Running shape inference on model ../../../models/public/resnet18_rcnn_azureml.onnx
========================= [Model Compilation Started] =========================
Model compilation will perform the following stages:
1. Parsing
2. Graph Optimization
3. Quantization & Calibration
4. Memory Planning
============================== [Version Summary] ==============================
|          TIDL Tools Version          |              10_00_06_00             |
|         C7x Firmware Version         |              10_00_02_00             |
|            Runtime Version           |            1.14.0+10000005           |
|          Model Opset Version         |                  11                  |
NOTE: The runtime version here specifies ONNXRT_VERSION+TIDL_VERSION
Ex: 1.14.0+1000XXXX -> ONNXRT 1.14.0 and a TIDL_VERSION 10.00.XX.XX
============================== [Parsing Started] ==============================
[TIDL Import]  WARNING: 'meta_layers_names_list' is not provided - running OD post processing in ARM mode
Number of OD backbone nodes = 0
Size of odBackboneNodeIds = 0
------------------------- Subgraph Information Summary -------------------------
|          Core           |      No. of Nodes       |   Number of Subgraphs   |
| C7x                     |                       1 |                       1 |
| CPU                     |                      11 |                       x |
|       Node        |        Node Name       |                                          Reason                                           |
| Unsqueeze         | Unsqueeze_1217         | Layer type not supported by TIDL                                                          |
| Unsqueeze         | Unsqueeze_1218         | Layer type not supported by TIDL                                                          |
| ReduceMax         | ReduceMax_1209         | Reducing in all dimensions is not supported in TIDL-RT                                    |
| Cast              | Cast_1210              | Only supported at the terminal nodes (Input/Output) of the network                        |
| Mul               | Mul_1213               | The variable inputs in Add/Mul/Sub/Div layer must of be same dimensions or broadcast-able |
| Unsqueeze         | Unsqueeze_1214         | Layer type not supported by TIDL                                                          |
| Add               | Add_1215               | The variable inputs in Add/Mul/Sub/Div layer must of be same dimensions or broadcast-able |
| Unsqueeze         | Unsqueeze_1216         | Layer type not supported by TIDL                                                          |
| NonMaxSuppression | NonMaxSuppression_1221 | Layer type not supported by TIDL                                                          |
| Gather            | Gather_1223            | Only line gather is supported                                                             |
============================= [Parsing Completed] =============================
1. Parsing
4. Memory Planning
[TIDL Import] [PARSER] WARNING: Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
| Identity | /roi_heads/box_roi_pool/Identity | Not supported as an individual operator |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
| Identity | /roi_heads/box_roi_pool/Identity_1 | Not supported as an individual operator |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
| Identity | /roi_heads/box_roi_pool/Identity_2 | Not supported as an individual operator |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
| Identity | /roi_heads/box_roi_pool/Identity_3 | Not supported as an individual operator |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
1. Parsing
4. Memory Planning
| C7x                     |                       0 |                       0 |
| CPU                     |                       1 |                       x |
| Identity | Identity_1707 | Not supported as an individual operator |
1. Parsing
4. Memory Planning
| C7x                     |                       1 |                       1 |
| CPU                     |                      14 |                       x |
| Unsqueeze         | Unsqueeze_1693         | Layer type not supported by TIDL                                                          |
| Unsqueeze         | Unsqueeze_1694         | Layer type not supported by TIDL                                                          |
| ReduceMax         | ReduceMax_1685         | Reducing in all dimensions is not supported in TIDL-RT                                    |
| Cast              | Cast_1686              | Only supported at the terminal nodes (Input/Output) of the network                        |
| Mul               | Mul_1689               | The variable inputs in Add/Mul/Sub/Div layer must of be same dimensions or broadcast-able |
| Unsqueeze         | Unsqueeze_1690         | Layer type not supported by TIDL                                                          |
| Add               | Add_1691               | The variable inputs in Add/Mul/Sub/Div layer must of be same dimensions or broadcast-able |
| Unsqueeze         | Unsqueeze_1692         | Layer type not supported by TIDL                                                          |
| NonMaxSuppression | NonMaxSuppression_1697 | Layer type not supported by TIDL                                                          |
| Gather            | Gather_1699            | Only line gather is supported                                                             |
| Shape             | Shape_1701             | Layer type not supported by TIDL                                                          |
| Gather            | Gather_1702            | Input dimensions must be greater than 1D                                                  |
| Equal             | Equal_1704             | Layer type not supported by TIDL                                                          |
| If                | If_1705                | Layer type not supported by TIDL                                                          |
Process Process-1:
Traceback (most recent call last):
  File "/usr/lib/python3.10/multiprocessing/process.py", line 314, in _bootstrap
    self.run()
  File "/usr/lib/python3.10/multiprocessing/process.py", line 108, in run
    self._target(*self._args, **self._kwargs)
  File "/home/root/examples/osrt_python/ort/onnxrt_ep.py", line 223, in run_model
    sess = rt.InferenceSession(config['model_path'] ,providers=EP_list, provider_options=[delegate_options, {}], sess_options=so)
  File "/usr/local/lib/python3.10/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 362, in __init__
    self._create_inference_session(providers, provider_options, disabled_optimizers)
  File "/usr/local/lib/python3.10/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 410, in _create_inference_session
    sess.initialize_session(providers, provider_options, disabled_optimizers)
onnxruntime.capi.onnxruntime_pybind11_state.Fail: [ONNXRuntimeError] : 1 : FAIL : Failed to add kernel for TIDL_0 com.microsoft TIDLExecutionProvider: Conflicting with a registered kernel with op versions.
Can you help diagnose and rectify this issue.
Suraj
