TDA4VH-Q1: Trace buffer not working in C7x
Part Number: TDA4VH-Q1
HI Ti team ,
we are trying to enable trace buffer in C7x ,
currently we are not able to see the folder in the
can you let us know how to enable trace buffer for c7x
  • Hi Gowtham,
    This is not currently supported in either the TI SDKs or the Upstream kernel.
    The C7x is a 64-bit processor, and there is no support for a 64-bit trace resource type in the kernel.
    regards
    Suman
  • Hi ,
    Thanks for the response,
     then is it possible to route the logs to UART somehow? is it possible and examples available?
    We need to know what happens inside C7x
    Regards ,
    Gowtham
  • Hi Gowtham,
    What is your s/w stack on C7x? C7x is most commonly used for TIDL, which is wrapped under an OpenVX node to allow data processing on different processors through an OpenVx graph.
    The Vision Apps stack provides a cross-processor tracing using a common shared memory and an user-space application, and this is an OS agnostic solution.
    Please see the Remote Log Enable in the Vision Apps documentation for details.
    regards
    Suman
