Other Parts Discussed in Thread: OMAPL138
Hi All,
I got helloDSP 1.10 and compiled it. It works great.
I want to change folders, code and makefile for my project. I have been working on dsp makefile and I had a problem with tconf. I can't set output directory for tconf. I have debug and release directories and need to put *_c.c, *.s62, etc files under particular directory. I have checked the link http://processors.wiki.ti.com/index.php/DSP_BIOS_FAQ and tried -Dconfig.programName but I still have problem. Could you please give me a clear example for debug, release configuration?
Serdar
# @file Makefile
# @path
# @desc Makefile for helloDSP (Debug and Release versions)
# @ver 1.10
# Copyright (c) Texas Instruments Incorporated 2002-2009
# Use of this software is controlled by the terms and conditions found in the
# license agreement under which this software has been supplied or provided.
SHELL = /bin/sh
# Base for TI toolchain
# This may change depending if you are using other versions of the compiler
BASE_COMPILER := /opt/TI/C6000CGT6.1.9
BASE_SABIOS := /home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/bios_5_41_00_06
#BASE_BSL := $(BASE_TOOLCHAIN)/boards/evmomapl137_v1
XDCTOOLS := /home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/xdctools_3_20_00_41
# Name of the TI compiler and DSP/BIOS builder (Tconf)
# This usually does not change
CC := cl6x
TCONF := tconf
# Base for DSPLink
# This may have to be changed depending on your installation paths
# and DSPLink version
DSPLINK := /home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink
# Project name.
# This variable can be used to set all source/BIOS/object filenames
# For clarity, in this example it sets only the .OUT .CMD and .MAP filenames
PROJNAME := message
# Global variables for building helloDSP
# Note that common debug, compiler and linker flags are already
# set in the lower part of this Makefile
# CSRCS are for C-source files, ASRCS for asm and BIOSTCF is the BIOS TCF file
DEBUG :=
#CFLAGS := -I$(BASE_BSL)/dsp/include
#LDFLAGS := -i$(BASE_BSL)/dsp/lib
#CFLAGS := -I$(DSP_LINK)/dsp/export/INCLUDE/DspBios/OMAPL138
LDFLAGS := -i$(DSP_LINK)/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE
CFLAGS := \
-I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc/DspBios -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc/DspBios/5.XX -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc/DspBios/5.XX/OMAPL138GEM -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc/DA8XXGEM -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc/C64XX -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/src/samples/message -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/src/samples/message/DspBios -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/src/samples/message/DspBios/ -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/bios_5_41_00_06/packages/ti/bios/include -I/opt/TI/C6000CGT6.1.9/include -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/bios_5_41_00_06/packages/ti/rtdx/include/c6000 -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/bios_5_41_00_06/packages/ti/psl/include -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/BUILD/OMAPL138GEM_0/INCLUDE -I/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/INCLUDE/DspBios/OMAPL138/internal
CSRCS := main.c message_config.c swiMessage.c tskMessage.c
ASRCS :=
BIOSTCF := message.tcf
OBJS :=
LIBS := \
-l/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplink.lib \
-l/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkpool.lib \
-l/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkmpcs.lib \
-l/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkmplist.lib \
-l/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkmsg.lib \
-l/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinknotify.lib \
-l/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkringio.lib \
-l/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkdata.lib
#LIBS := -ldsplink.lib -ldsplinkpool.lib -ldsplinkmpcs.lib -ldsplinkmplist.lib -ldsplinkmsg.lib -#ldsplinknotify.lib -ldsplinkringio.lib -ldsplinkdata.lib
# If the DSP/Link was rebuilt by the user, add -ldsplinkdata.lib to the line above
CMDS := $(PROJNAME).cmd
MAPFILE := $(PROJNAME).map
BIN := $(PROJNAME).out
# DSP/BIOS generated files
BIOSSRC := $(BIOSTCF:%.tcf=%cfg.s62) $(BIOSTCF:%.tcf=%cfg_c.c)
BIOSCMD := $(BIOSTCF:%.tcf=%cfg.cmd)
# Adding DSP/BIOS generated files to the sources and the linker variables
CSRCS += $(BIOSTCF:%.tcf=%cfg_c.c)
ASRCS += $(BIOSTCF:%.tcf=%cfg.s62)
CMDS += $(BIOSCMD)
# DSP/BIOS common flags
BFLAGS := -Dconfig.importPath="$(BASE_SABIOS)/packages; \
$(BASE_SABIOS)/packages/ti/bios; \
$(DSPLINK)/dsp/inc/DspBios; \
$(DSPLINK)/dsp/inc/DspBios/5.XX/OMAPL138GEM; \
$(DSPLINK)/dsp/inc/DspBios/5.XX;"
# All common compiler and linker flags
ALL_CFLAGS := -q -pdr -pdv -pden -ml3 -mv6400+ --disable:sploop $(CFLAGS)
ALL_LDFLAGS := -z -c -q -x $(LDFLAGS)
# Compiler and Linker options for Debug
CFLAGS_D := -g -d"_DEBUG" --no_compress $(DEBUG) $(ALL_CFLAGS)
OBJDIR_D := Debug
BINDIR_D := $(OBJDIR_D)
OBJS_D := $(CSRCS:%.c=$(OBJDIR_D)/%.obj) $(ASRCS:%.s62=$(OBJDIR_D)/%.obj)
LIBS_D := $(LIBS)
MAPFILE_D := $(OBJDIR_D)/$(MAPFILE)
# Compiler and Linker options for Release
CFLAGS_R := -o3 $(ALL_CFLAGS)
OBJDIR_R := Release
BINDIR_R := $(OBJDIR_R)
OBJS_R := $(CSRCS:%.c=$(OBJDIR_R)/%.obj) $(ASRCS:%.s62=$(OBJDIR_R)/%.obj)
LIBS_R := $(LIBS)
MAPFILE_R := $(OBJDIR_R)/$(MAPFILE)
# Compiler common include directories
CINCLUDES := -I$(DSPLINK)/dsp/inc \
-I$(DSPLINK)/dsp/inc/DspBios \
-I$(DSPLINK)/dsp/inc/DspBios/5.XX \
-I$(DSPLINK)/dsp/inc/DspBios/5.XX/OMAPL138GEM \
-I$(DSPLINK)/dsp/inc/C64XX \
-I$(BASE_SABIOS)/packages/ti/bios/include \
-I$(BASE_COMPILER)/include \
-I$(BASE_SABIOS)/packages/ti/rtdx/include/c6000 \
-I$(BASE_SABIOS)/packages/ti/psl/include \
-I$(DSPLINK)/dsp/export/INCLUDE/DspBios/OMAPL138 \
-Isrc \
-I../common \
-I./
# Compiler common symbol definitions
#DEFS := -dMAX_DSPS=1 \
# -dMAX_PROCESSORS=2 \
# -dID_GPP=1 \
# -dOMAPL138 \
# -dPROC_COMPONENT \
# -dPOOL_COMPONENT \
# -dNOTIFY_COMPONENT \
# -dMPCS_COMPONENT \
# -dRINGIO_COMPONENT \
# -dMPLIST_COMPONENT \
# -dMSGQ_COMPONENT \
# -dMSGQ_ZCPY_LINK \
# -dCHNL_COMPONENT \
# -dCHNL_ZCPY_LINK \
# -dZCPY_LINK \
# -dPROCID=0 \
# -dDA8XXGEM \
# -DOS_LINUX \
# -dDA8XXGEM_INTERFACE=SHMEM_INTERFACE \
# -dPHYINTERFACE=SHMEM_INTERFACE \
# -dTSK_MODE \
# -DDDSP_DEBUG \
# -dDSP_TSK_MODE
DEFS := \
-dTSK_MODE \
-DDDSP_DEBUG \
-dMAX_DSPS=1 \
-dID_GPP=1 \
-dOMAPL138 \
-dPROC_COMPONENT \
-dPOOL_COMPONENT \
-dMPCS_COMPONENT \
-dMSGQ_COMPONENT \
-dMSGQ_ZCPY_LINK \
-dCHNL_COMPONENT \
-dCHNL_ZCPY_LINK \
-dZCPY_LINK \
-dPROCID=0 \
-dDA8XXGEM \
-dDSP_TSK_MODE
# Linker common library search path
LDINCLUDES := -i$(BASE_COMPILER)/lib \
-i$(BASE_SABIOS)/packages/ti/bios/lib \
-i$(BASE_SABIOS)/packages/ti/rtdx/lib/c6000 \
-i$(BASE_SABIOS)/packages/ti/psl/lib
# Linker library search path for Debug
LDINCLUDES_D := $(LDINCLUDES) -i$(DSPLINK)/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/DEBUG/
# If the DSP/Link was rebuilt by the user, replace the line above
# with the one below to use the updated libraries
#LDINCLUDES_D := $(LDINCLUDES) -i$(DSPLINK)/dsp/BUILD/OMAPL1XXGEM_0/EXPORT/DEBUG/
# Linker library search path for Release
LDINCLUDES_R := $(LDINCLUDES) -i$(DSPLINK)/dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/
#LDINCLUDES_R := $(LDINCLUDES) -i$(DSPLINK)/dsp/BUILD/OMAPL1XXGEM_0/EXPORT/RELEASE/
# Compiler and Linker procedure
# From this point and on changes are highly unlikely.
# - Be careful if changing the order of the linker object and library files
# - The DSP/BIOS TCONF build needs to come before everything else
# - The clean rule also removes all DSP/BIOS generated files
.PHONY: all
all: $(BIOSSRC) Debug Release
$(BIOSSRC): src/$(BIOSTCF)
@echo Building DSP/BIOS file...
$(XDCTOOLS)/$(TCONF) $(BFLAGS) $< 0
# /home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/xdctools_3_20_00_41/tconf -Dconfig.importPath="/home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/bios_5_41_00_06/packages; /home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/bios_5_41_00_06/packages/ti/bios; /home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc/DspBios; /home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc/DspBios/5.XX/OMAPL138GEM; /home/serdar/factory-20110711/build_armv5l-timesys-linux-uclibcgnueabi/DSPLink-1_65/DSPLink-1_65/dsplink/dsp/inc/DspBios/5.XX;./" src/message.tcf 0
# Building Debug...
.PHONY: Debug
Debug: $(BINDIR_D)/$(BIN)
$(BINDIR_D)/$(BIN) : $(OBJS_D)
@echo Compiling Debug...
@$(BASE_COMPILER)/bin/$(CC) $(ALL_LDFLAGS) $(LDINCLUDES_D) -o$@ $(OBJS_D) $(LIBS_D) -m$(MAPFILE_D) $(CMDS)
$(OBJDIR_D)/%.obj : %.c
@$(BASE_COMPILER)/bin/$(CC) $(ALL_DEBUG) $(DEFS) $(CFLAGS_D) $(CINCLUDES) -fr$(OBJDIR_D) $<
$(OBJDIR_D)/%.obj : %.s62
# Building Release...
.PHONY: Release
Release: $(BINDIR_R)/$(BIN)
$(BINDIR_R)/$(BIN) : $(OBJS_R)
@echo Compiling Release...
$(BASE_COMPILER)/bin/$(CC) $(ALL_LDFLAGS) $(LDINCLUDES_R) -o$@ $(OBJS_R) $(LIBS_R) -m$(MAPFILE_R) src/message.cmd messagecfg.cmd
# $(CMDS)
$(OBJDIR_R)/%.obj : src/%.c
$(BASE_COMPILER)/bin/$(CC) $(DEFS) $(CFLAGS_R) $(CINCLUDES) -fr$(OBJDIR_R) $<
$(OBJDIR_R)/%.obj : %.c
$(OBJDIR_R)/%.obj : %.s62
.PHONY: clean
clean:
@rm -f *.cdb
@rm -f *cfg.*
@rm -f *cfg_c.*
@rm -f ./$(OBJDIR_D)/*
@rm -f ./$(OBJDIR_R)/*
