Other Parts Discussed in Thread: WL1837
Dear Sir,
I am currently working on the AM62x E3 Evaluation Board with the AM6254 processor, and I've encountered a few issues that I need assistance with:
Wi-Fi Connectivity Issue:
After loading the OS, I noticed that Wi-Fi is not functioning as expected. Running the ifconfig command does not list the wlan0 interface. I have verified that the Wi-Fi hardware is operational, so I believe this may be due to a configuration issue. Could you provide guidance on troubleshooting the Wi-Fi connectivity? I would appreciate any insights into possible Device Tree Source (DTS) misconfigurations or additional steps I could take.
Bluetooth Connectivity Issue:
Although Bluetooth is enabled on the AM6254 processor, it is not functioning as intended. My goal is to enable both Wi-Fi and Bluetooth in the DTS. Could you assist me in ensuring both interfaces are configured correctly?
SPI Configuration Issue:
When I add the device tree overlay in U-Boot mode, spidev appears in the /dev directory; however, this solution is not persistent. Could you advise on how to make spidev consistently appear in /dev/ directory and I am mentioning the u-boot messages.
/*WIFI Releated U-boot Messages*/ U-Boot SPL 2024.04 (Oct 15 2024 - 15:04:57 +0530) SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') SPL initial stack usage: 13392 bytes Trying to boot from MMC2 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Starting ATF on ARM64 core... NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty NOTICE: BL31: Built : 16:09:05, Feb 9 2024 U-Boot SPL 2024.04 (Oct 15 2024 - 15:33:04 +0530) SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') SPL initial stack usage: 1904 bytes Error (-2): cannot determine file size Trying to boot from MMC2 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted U-Boot 2024.04 (Oct 15 2024 - 15:33:04 +0530) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 DRAM: 2 GiB Core: 81 devices, 31 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -1 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'uEnv.txt' 20285952 bytes read in 242 ms (79.9 MiB/s) 60191 bytes read in 22 ms (2.6 MiB/s) Working FDT set to 88000000 ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK Working FDT set to 8feee000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.32-ti-g6de6e418c80e-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f8000000, size 128 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000f8000000..0x00000000ffffffff (131072 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000 [ 0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=fbddafd1-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000f1800000-0x00000000f5800000] (64MB) [ 0.000000] Memory: 1781064K/2097152K available (11968K kernel code, 1250K rwdata, 4036K rodata, 2432K init, 502K bss, 185016K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080440000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008595] Console: colour dummy device 80x25 [ 0.013198] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023882] pid_max: default: 32768 minimum: 301 [ 0.028686] LSM: initializing lsm=capability,integrity [ 0.034064] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.041649] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.051650] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.058984] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.066930] rcu: Hierarchical SRCU implementation. [ 0.071836] rcu: Max phase no-delay instances is 1000. [ 0.077461] Platform MSI: msi-controller@1820000 domain created [ 0.083803] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.093236] EFI services will not be available. [ 0.098166] smp: Bringing up secondary CPUs ... [ 0.103505] Detected VIPT I-cache on CPU1 [ 0.103596] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.103614] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000 [ 0.103672] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.104454] Detected VIPT I-cache on CPU2 [ 0.104518] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.104531] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000 [ 0.104567] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.105227] Detected VIPT I-cache on CPU3 [ 0.105284] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.105298] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000 [ 0.105329] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.105410] smp: Brought up 1 node, 4 CPUs [ 0.185155] SMP: Total of 4 processors activated. [ 0.189968] CPU features: detected: 32-bit EL0 Support [ 0.195244] CPU features: detected: CRC32 instructions [ 0.200570] CPU: All CPU(s) started at EL2 [ 0.204769] alternatives: applying system-wide alternatives [ 0.212441] devtmpfs: initialized [ 0.224485] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.234492] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.246036] pinctrl core: initialized pinctrl subsystem [ 0.252001] DMI not present or invalid. [ 0.256645] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.263673] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.271010] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.279046] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.287241] audit: initializing netlink subsys (disabled) [ 0.293001] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1 [ 0.293500] thermal_sys: Registered thermal governor 'step_wise' [ 0.300937] thermal_sys: Registered thermal governor 'power_allocator' [ 0.307134] cpuidle: using governor menu [ 0.317998] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.325030] ASID allocator initialised with 65536 entries [ 0.342425] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.352280] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts [ 0.363567] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.374938] Modules: 27680 pages in range for non-PLT usage [ 0.374950] Modules: 519200 pages in range for PLT usage [ 0.381523] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.393920] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.400330] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.407270] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.413678] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.420617] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.427024] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.433964] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.441909] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.451305] iommu: Default domain type: Translated [ 0.456238] iommu: DMA domain TLB invalidation policy: strict mode [ 0.462869] SCSI subsystem initialized [ 0.467048] usbcore: registered new interface driver usbfs [ 0.472697] usbcore: registered new interface driver hub [ 0.478159] usbcore: registered new device driver usb [ 0.483821] pps_core: LinuxPPS API ver. 1 registered [ 0.488903] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.498254] PTP clock support registered [ 0.502426] EDAC MC: Ver: 3.0.0 [ 0.506155] scmi_core: SCMI protocol bus registered [ 0.511494] FPGA manager framework [ 0.515065] Advanced Linux Sound Architecture Driver Initialized. [ 0.522304] vgaarb: loaded [ 0.525494] clocksource: Switched to clocksource arch_sys_counter [ 0.532013] VFS: Disk quotas dquot_6.6.0 [ 0.536071] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.549698] NET: Registered PF_INET protocol family [ 0.554969] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.564167] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.572972] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.580910] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.589116] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.597120] TCP: Hash tables configured (established 16384 bind 16384) [ 0.604033] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.610958] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.618472] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.624809] RPC: Registered named UNIX socket transport module. [ 0.630896] RPC: Registered udp transport module. [ 0.635707] RPC: Registered tcp transport module. [ 0.640516] RPC: Registered tcp-with-tls transport module. [ 0.646124] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.652716] NET: Registered PF_XDP protocol family [ 0.657635] PCI: CLS 0 bytes, default 64 [ 0.663156] Initialise system trusted keyrings [ 0.667977] workingset: timestamp_bits=46 max_order=19 bucket_order=0 [ 0.674916] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.681193] NFS: Registering the id_resolver key type [ 0.686409] Key type id_resolver registered [ 0.690688] Key type id_legacy registered [ 0.694806] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.701662] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.743001] Key type asymmetric registered [ 0.747197] Asymmetric key parser 'x509' registered [ 0.752245] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.759814] io scheduler mq-deadline registered [ 0.764448] io scheduler kyber registered [ 0.768583] io scheduler bfq registered [ 0.775591] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.782160] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.789617] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.802011] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.819503] loop: module loaded [ 0.823914] megasas: 07.725.01.00-rc1 [ 0.831408] tun: Universal TUN/TAP device driver, 1.6 [ 0.837738] VFIO - User Level meta-driver version: 0.3 [ 0.844118] usbcore: registered new interface driver usb-storage [ 0.850859] i2c_dev: i2c /dev entries driver [ 0.856878] sdhci: Secure Digital Host Controller Interface driver [ 0.863234] sdhci: Copyright(c) Pierre Ossman [ 0.867906] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.874485] ledtrig-cpu: registered to indicate activity on CPUs [ 0.880929] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.888212] usbcore: registered new interface driver usbhid [ 0.893916] usbhid: USB HID core driver [ 0.898197] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.906342] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.915306] optee: probing for conduit method. [ 0.919887] optee: revision 4.2 (12d7c4ee) [ 0.920221] optee: dynamic shared memory is enabled [ 0.930249] random: crng init done [ 0.933852] optee: initialized driver [ 0.939457] NET: Registered PF_PACKET protocol family [ 0.944766] Key type dns_resolver registered [ 0.957161] registered taskstats version 1 [ 0.961759] Loading compiled-in X.509 certificates [ 0.981362] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') [ 1.034822] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19 [ 1.064604] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.071681] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.081671] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.091449] i2c 1-003b: Fixed dependency cycle(s) with /connector-hdmi [ 1.098177] i2c 1-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 1.105989] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.113075] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz [ 1.119059] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.128328] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.138788] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.147684] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.158976] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.170317] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.180788] printk: console [ttyS2] disabled [ 1.185648] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 239, base_baud = 3000000) is a 8250 [ 1.194544] printk: console [ttyS2] enabled [ 1.194544] printk: console [ttyS2] enabled [ 1.203101] printk: bootconsole [ns16550a0] disabled [ 1.203101] printk: bootconsole [ns16550a0] disabled [ 1.221085] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 1.226242] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.233208] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.238604] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.245355] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.251775] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.258292] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.264527] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.271327] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.277974] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.286392] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.329501] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.341545] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.349648] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867 [ 1.357773] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.370726] am65-cpsw-nuss 8000000.ethernet: Use random MAC address [ 1.376994] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.384121] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.390636] pps pps0: new PPS source ptp0 [ 1.394956] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1 [ 1.409586] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.420429] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector [ 1.433331] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.438921] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.446783] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports [ 1.452791] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000000010 [ 1.462240] xhci-hcd xhci-hcd.0.auto: irq 254, io mem 0x31100000 [ 1.469045] hub 1-0:1.0: USB hub found [ 1.472839] hub 1-0:1.0: 1 port detected [ 1.478685] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz [ 1.491663] mmc0: CQHCI version 5.10 [ 1.497962] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.504729] pca953x 1-0022: using AI [ 1.536112] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.537102] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present! [ 1.537582] mmc1: CQHCI version 5.10 [ 1.555464] clk: Disabling unused clocks [ 1.562744] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19 [ 1.573534] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 1.585717] ALSA device list: [ 1.588692] No soundcards found. [ 1.592903] Waiting for root device PARTUUID=fbddafd1-02... [ 1.624674] mmc0: Command Queue Engine enabled [ 1.627601] mmc1: new ultra high speed SDR104 SDXC card at address 0001 [ 1.629151] mmc0: new HS200 MMC card at address 0001 [ 1.636496] mmcblk1: mmc1:0001 BC2QT 59.6 GiB [ 1.641285] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.646888] mmcblk1: p1 p2 [ 1.652690] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 1.658791] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 1.664621] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0) [ 1.705958] EXT4-fs (mmcblk1p2): mounted filesystem 660a97fb-706b-425b-bc35-fd7ca8d27a57 r/w with ordered data mode. Quota mode: none. [ 1.718172] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.727718] devtmpfs: mounted [ 1.732277] Freeing unused kernel memory: 2432K [ 1.736904] Run /sbin/init as init process [ 2.001913] systemd[1]: System time before build time, advancing clock. [ 2.054921] NET: Registered PF_INET6 protocol family [ 2.061000] Segment Routing with IPv6 [ 2.064757] In-situ OAM (IOAM) with IPv6 [ 2.109646] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 2.141579] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.10! [ 2.160370] systemd[1]: Hostname set to <am62xx-evm>. [ 2.407445] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 2.443183] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 2.526018] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 2.641576] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 2.725987] systemd[1]: Queued start job for default target Graphical Interface. [ 2.763605] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 2.788131] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 2.812026] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 2.835352] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 2.858043] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ 2.881885] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 2.905709] systemd[1]: Expecting device /dev/ttyS2... Expecting device /dev/ttyS2... [ 2.921772] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 2.937660] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 2.957617] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 2.973653] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 3.024141] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 3.045868] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 3.072891] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 3.094149] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 3.118941] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 3.142420] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 3.166421] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 3.186555] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 3.214596] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 3.238349] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 3.262328] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 3.310074] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 3.320621] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 3.350961] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 3.366359] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 3.385682] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 3.408422] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 3.435273] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 3.459536] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 3.487410] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 3.523582] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen.[ 3.535585] fuse: init (API version 7.39) .. [ 3.556424] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 3.570308] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 3.618284] systemd[1]: Starting Journal Service... Starting Journal Service... [ 3.646750] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 3.672404] systemd[1]: Starting Generate network units from Kernel command line... Starting Generate network units from Kernel command line... [ 3.704736] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems cryptodev: loading out-of-tree module taints kernel. [0m... [ 3.725287] cryptodev: driver 1.13 loaded. [ 3.733326] systemd-journald[123]: Collecting audit messages is enabled. [ 3.746384] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 3.784719] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 3.797767] systemd[1]: Mounted Huge Pages File System. [ OK ] Mounted Huge Pages File System. [ 3.810217] EXT4-fs (mmcblk1p2): re-mounted 660a97fb-706b-425b-bc35-fd7ca8d27a57 r/w. Quota mode: none. [ 3.825302] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Start psplas…temd progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev gracefully... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ 4.276750] systemd-journald[123]: Received client request to flush runtime journal. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev gracefully. Starting Create Static Device Nodes in /dev... [ OK ] Finished Coldplug All udev Devices. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /var/volatile... [ 4.580595] audit: type=1334 audit(1709054766.572:2): prog-id=6 op=LOAD [ 4.587325] audit: type=1334 audit(1709054766.580:3): prog-id=7 op=LOAD Starting Rule-based Manager for Device Events and Files... [ OK ] Mounted /var/volatile. Starting Load/Save OS Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Finished Load/Save OS Random Seed. [ OK ] Finished Create Volatile Files and Directories. [ 4.828508] audit: type=1334 audit(1709054766.820:4): prog-id=8 op=LOAD Starting Network Name Resolution... [ 4.874452] audit: type=1334 audit(1709054766.868:5): prog-id=9 op=LOAD Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ OK ] Started Rule-based Manager for Device Events and Files. [ 4.992595] audit: type=1334 audit(1709054766.984:6): prog-id=10 op=LOAD [ 5.000230] audit: type=1334 audit(1709054766.996:7): prog-id=11 op=LOAD [ 5.010900] audit: type=1334 audit(1709054766.996:8): prog-id=12 op=LOAD Starting User Database Manager... [ OK ] Finished Record System Boot/Shutdown in UTMP. [ OK ] Started User Database Manager. [ OK ] Started Network Time Synchronization. [ OK ] Started Network Name Resolution. [ OK ] Found device /dev/ttyS2. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. [ OK ] Listening on PC/SC Smart Card Daemon Activation Socket. Starting Weston socket... [ 6.039154] audit: type=1334 audit(1709054768.032:9): prog-id=13 op=LOAD Starting D-Bus System Message Bus... Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Listening on Weston socket. [ OK ] Finished Reboot and dump vmcore via kexec. [ OK ] Started D-Bus System Message Bus. [ 6.276432] dbus-broker-lau[397]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set [ 6.367753] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.376585] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ OK ] Reached target Socket Units. [ 6.391551] at24 0-0051: supply vcc not found, using dummy regulator [ 6.398636] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.407182] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ OK ] Reached target Basic System. [ 6.430302] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write [ 6.439907] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.449125] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000 [ 6.450363] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 6.472254] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.481191] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 6.484879] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode [ 6.498859] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device [ 6.506749] rtc-ti-k3 2b1f0000.rtc: registered as rtc0 [ 6.515480] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:12 UTC (12) [ 6.524415] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.524455] remoteproc remoteproc0: 5000000.m4fss is available [ 6.529845] remoteproc remoteproc0: powering up 5000000.m4fss [ 6.533277] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 6.537720] systemd-journald[123]: Time jumped backwards, rotating. [ 6.540580] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55016 [ 6.550228] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.575271] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 6.594602] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.605324] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node m4f-dma-memory@9cb00000 [ 6.609280] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 6.634319] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.636545] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 6.642789] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 6.654917] platform 78000000.r5f: configured R5F for IPC-only mode [ 6.669864] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000 [ 6.678419] virtio_rpmsg_bus virtio0: rpmsg host is online [ 6.678914] remoteproc remoteproc1: 78000000.r5f is available [ OK ] Started Periodic Command Scheduler virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 6.690119] remoteproc remoteproc1: attaching to 78000000.r5f [0m. [ 6.691120] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7) [ 6.691135] remoteproc remoteproc0: remote processor 5000000.m4fss is now up [ 6.703690] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.707214] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 6.715257] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 6.733202] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 6.775756] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9da00000 [ 6.779801] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.793387] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 6.805350] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 6.805700] virtio_rpmsg_bus virtio1: rpmsg host is online [ 6.813399] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 6.834531] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.835654] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7) [ 6.845569] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports Starting Print notice about GPLv3 packages[ 6.865387] sii902x 1-003b: supply iovcc not found, using dummy regulator ... [ 6.867127] remoteproc remoteproc1: remote processor 78000000.r5f is now attached [ 6.873395] sii902x 1-003b: supply cvcc12 not found, using dummy regulator [ 6.897634] i2c i2c-1: Added multiplexed i2c bus 3 [ 6.908445] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 6.917077] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports Starting IPv6 Packet Filtering Framework..[ 6.929075] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 . [ 6.940644] tidss 30200000.dss: [drm] Cannot find any crtc or sizes [ 6.948685] tidss 30200000.dss: [drm] Cannot find any crtc or sizes Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting PulseAudio Sound System... Starting Expand the rootfs partiti…to full size of the boot device.... [ OK ] Started Seva Launcher Service. [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. [ 7.085130] audit: type=1334 audit(13.060:10): prog-id=14 op=LOAD [ 7.088848] PVR_K: 179: Device: fd00000.gpu [ 7.097648] audit: type=1334 audit(13.064:11): prog-id=15 op=LOAD [ 7.097677] audit: type=1334 audit(13.064:12): prog-id=16 op=LOAD [ 7.125201] PVR_K: 179: Read BVNC 33.15.11.3 from HW device registers Starting User Login Management... [ 7.134308] PVR_K: 179: RGX Device registered with BVNC 33.15.11.3 [ 7.147389] [drm] Initialized pvr 24.1.6554834 20170530 for fd00000.gpu on minor 1 Starting Telnet Server... [ OK ] Started ti-apps-launcher service. [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Finished Telnet Server. [ OK ] Reached target Preparation for Network. [ OK ] Reached target Hardware activated USB gadget. [ 7.299917] audit: type=1334 audit(13.280:13): prog-id=17 op=LOAD Starting Network Configuration... [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Started Telephony service. [ 7.477531] remoteproc remoteproc2: 30074000.pru is available [ 7.484843] remoteproc remoteproc3: 30078000.pru is available Starting Virtual Console Setup... [ OK ] Started User Login Management. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.918425] Bluetooth: Core ver 2.22 [ 7.922249] NET: Registered PF_BLUETOOTH protocol family [ 7.930844] Bluetooth: HCI device and connection manager initialized [ 7.937347] Bluetooth: HCI socket layer initialized [ 7.942333] Bluetooth: L2CAP socket layer initialized [ 7.947498] Bluetooth: SCO socket layer initialized [ 8.163602] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 8.191334] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 8.198155] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ OK ] Finished Expand the rootfs partition to full size of the boot device.. [ 8.491676] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 8.501109] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ OK ] Started Network Configuration. [ OK ] Reached target Network. [ 8.524628] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL) [ 8.534056] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode Starting Save/Restore Sound Card State... Starting Enable and configure wl18xx bluetooth stack... Starting containerd container runtime... [ OK ] Started Netperf Benchmark Server. Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Finished Virtual Console Setup. [ OK ] Finished Save/Restore Sound Card State. [ OK ] Started PulseAudio Sound System. [ OK ] Reached target Sound Card. [ OK ] Finished Enable and configure wl18xx bluetooth stack. [ OK ] Finished Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Weston, a Wayland compositor, as a system service... [ OK ] Finished Synchronize System and HW clocks. [ OK ] Created slice User Slice of UID 1000. Starting User Runtime Directory /run/user/1000... [ OK ] Finished User Runtime Directory /run/user/1000. Starting User Manager for UID 1000... [ OK ] Created slice Slice /system/systemd-fsck. Expecting device /dev/mmcblk1p1... [ 9.918645] audit: type=1006 audit(15.900:14): pid=552 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ OK ] Found device /dev/mmcblk1p1. [ 9.931406] audit: type=1300 audit(15.900:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffffe73c018 a2=4 a3=1 items=0 ppid=1 pid=552 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 9.962856] audit: type=1327 audit(15.900:14): proctitle="(systemd)" Starting File System Check on /dev/mmcblk1p1... [ OK ] Finished File System Check on /dev/mmcblk1p1. Mounting /run/media/boot-mmcblk1p1... [ OK ] Mounted /run/media/boot-mmcblk1p1. [ OK ] Started User Manager for UID 1000. [ OK ] Started Session c1 of User weston 11.158726] audit: type=1006 audit(17.140:15): pid=532 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 0m. [ 11.172127] audit: type=1300 audit(17.140:15): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffeb11c618 a2=4 a3=1 items=0 ppid=1 pid=532 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 11.198316] audit: type=1327 audit(17.140:15): proctitle="(weston)" [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ 12.025742] PVR_K: 532: RGX Firmware image 'rgx.fw.33.15.11.3' loaded [ 12.045596] PVR_K: 532: Shader binary image 'rgx.sh.33.15.11.3' loaded [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ OK ] Started Session c2 of User weston. [ 12.415798] audit: type=1006 audit(18.396:16): pid=597 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=3 res=1 [ 12.431703] audit: type=1300 audit(18.396:16): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe5bf0348 a2=4 a3=1 items=0 ppid=1 pid=597 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=3 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 12.457792] audit: type=1327 audit(18.396:16): proctitle="(weston)" [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ OK ] Started Session c3 of User weston. [ 12.704277] audit: type=1006 audit(18.684:17): pid=607 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=4 res=1 [ 12.717015] audit: type=1300 audit(18.684:17): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffecbde918 a2=4 a3=1 items=0 ppid=1 pid=607 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=4 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 12.742960] audit: type=1327 audit(18.684:17): proctitle="(weston)" [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ OK ] Started containerd container runtime. [ OK ] Started Session c4 of User weston 13.015610] audit: type=1006 audit(18.996:18): pid=617 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=5 res=1 0m. [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ OK ] Started Session c5 of User weston. [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am62xx-evm ttyS2 Arago 2023.10 am62xx-evm ttyS2 am62xx-evm login: *************************************************************** *************************************************************** NOTICE: This file system contains the following GPL-3.0 packages: adwaita-icon-theme-symbolic autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gnu-config grub-common grub-editenv grub-efi gzip hidapi kbd-dev kbd-keymaps-pine less libasm1 libatomic-dev libatomic1 libbfd libdebuginfod1 libdw1 libelf1 libgcc-s-dev libgcc1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmpc3 libmpfr6 libopcodes libqt5charts-examples libqt5charts-plugins libqt5charts-qmlplugins libqt5charts5 libqt5serialport-examples libqt5serialport-plugins libqt5serialport-qmlplugins libqt5serialport5 libqt5svg-examples libqt5svg-plugins libqt5svg-qmlplugins libqt5svg5 libqt5virtualkeyboard-plugins libqt5virtualkeyboard-qmlplugins libqt5virtualkeyboard5 libreadline-dev libreadline8 libstdc++-dev libstdc++6 libunistring5 m4 make nettle parted piglit qt3d-plugins qt3d-qmlplugins qt3d qtbase-examples qtbase-plugins qtbase-qmlplugins qtbase qtconnectivity-plugins qtconnectivity-qmlplugins qtconnectivity qtdeclarative-plugins qtdeclarative-qmlplugins qtdeclarative-tools qtdeclarative qtgraphicaleffects-qmlplugins qtlocation-examples qtlocation-plugins qtlocation-qmlplugins qtlocation qtmultimedia-examples qtmultimedia-plugins qtmultimedia-qmlplugins qtmultimedia qtquick3d-plugins qtquick3d-qmlplugins qtquick3d qtquics-qmlplugins.control qtquics2-plugins.control qtquics2-qmlplugins.control qtquics2.control qtscript-examples qtscript-plugins qtscript-qmlplugins qtscript qtwayland-examples qtwayland-plugins qtwayland-qmlplugins qtwayland tar which If you do not wish to distribute GPL-3.0 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ 19.785724] kauditd_printk_skb: 9 callbacks suppressed [ 19.785741] audit: type=1334 audit(25.768:24): prog-id=20 op=UNLOAD [ 19.797220] audit: type=1334 audit(25.768:25): prog-id=19 op=UNLOAD [ 19.803504] audit: type=1334 audit(25.768:26): prog-id=18 op=UNLOAD am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: root [ 29.911556] audit: type=1006 audit(35.892:27): pid=1007 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=7 res=1 [ 29.923436] audit: type=1300 audit(35.892:27): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffc72b3c18 a2=1 a3=1 items=0 ppid=1 pid=1007 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 29.949394] audit: type=1327 audit(35.892:27): proctitle="(systemd)" [ 29.955799] audit: type=1334 audit(35.924:28): prog-id=21 op=LOAD [ 29.961953] audit: type=1300 audit(35.924:28): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff7435aa8 a2=90 a3=0 items=0 ppid=1 pid=1007 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null) [ 29.987096] audit: type=1327 audit(35.924:28): proctitle="(systemd)" [ 29.993523] audit: type=1334 audit(35.932:29): prog-id=21 op=UNLOAD [ 29.999844] audit: type=1300 audit(35.932:29): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffb7c14c60 items=0 ppid=1 pid=1007 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null) [ 30.024787] audit: type=1327 audit(35.932:29): proctitle="(systemd)" [ 30.031265] audit: type=1334 audit(35.932:30): prog-id=22 op=LOAD root@am62xx-evm:~# root@am62xx-evm:~# ifconfig eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 1c:63:49:18:84:f1 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether c2:f1:5e:34:af:4d txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 19 bytes 2246 (2.1 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 19 bytes 2246 (2.1 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 root@am62xx-evm:~# ls -al /lib/firmware/ti-connectivity/ total 1720 drwxr-xr-x 2 root root 4096 Oct 15 2024 . drwxr-xr-x 6 root root 4096 Jan 1 1970 .. -rw-r--r-- 1 root root 53542 Oct 15 2024 TIInit_10.6.15.bts -rw-r--r-- 1 root root 74975 Oct 15 2024 TIInit_11.8.32.bts -rw-r--r-- 1 root root 19367 Oct 15 2024 TIInit_12.10.28.bts -rw-r--r-- 1 root root 73655 Oct 15 2024 TIInit_12.8.32.bts -rw-r--r-- 1 root root 6094 Oct 15 2024 TIInit_6.12.26.bts -rw-r--r-- 1 root root 12698 Oct 15 2024 TIInit_6.7.16.bts -rw-r--r-- 1 root root 50749 Oct 15 2024 TIInit_7.6.15.bts -rw-r--r-- 1 root root 1353 Oct 15 2024 cc33xx-conf.bin -rw-r--r-- 1 root root 70212 Oct 15 2024 cc33xx_2nd_loader.bin -rw-r--r-- 1 root root 508332 Oct 15 2024 cc33xx_fw.bin -rw-r--r-- 1 root root 6017 Oct 15 2024 initscripts-TIInit_6.12.26.bts -rw-r--r-- 1 root root 1328 Oct 15 2024 initscripts-TIInit_6.12.26_avpr_add-on.bts -rw-r--r-- 1 root root 94 Oct 15 2024 initscripts-TIInit_6.12.26_ble_add-on.bts -rw-r--r-- 1 root root 38880 Oct 15 2024 initscripts-TIInit_6.7.16_avpr_add-on.bts -rw-r--r-- 1 root root 1230 Oct 15 2024 initscripts-TIInit_6.7.16_ble_add-on.bts -rw-r--r-- 1 root root 11480 Oct 15 2024 initscripts-TIInit_6.7.16_bt_spec_4.1.bts -rwxr-xr-x 1 root root 1229 Oct 15 2024 wl18xx-conf.bin -rwxr-xr-x 1 root root 746236 Oct 15 2024 wl18xx-fw-4.bin root@am62xx-ev /* BLUETOOTH U-BOOT MESSAGES*/ U-Boot SPL 2024.04 (Oct 15 2024 - 15:04:57 +0530) SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') SPL initial stack usage: 13392 bytes Trying to boot from MMC2 Warning: Detected image signing certificate on GP device. Skipping certificate t o prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate t o prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate t o prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate t o prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate t o prevent boot failure. This will fail if the image was also encrypted Starting ATF on ARM64 core... NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty NOTICE: BL31: Built : 16:09:05, Feb 9 2024 U-Boot SPL 2024.04 (Oct 15 2024 - 15:33:04 +0530) SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') SPL initial stack usage: 1904 bytes Error (-2): cannot determine file size Trying to boot from MMC2 Warning: Detected image signing certificate on GP device. Skipping certificate t o prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate t o prevent boot failure. This will fail if the image was also encrypted U-Boot 2024.04 (Oct 15 2024 - 15:33:04 +0530) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 DRAM: 2 GiB Core: 81 devices, 31 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -1 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'uEnv.txt' 20285952 bytes read in 239 ms (80.9 MiB/s) 60191 bytes read in 22 ms (2.6 MiB/s) Working FDT set to 88000000 ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK Working FDT set to 8feee000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.32-ti-g6de6e418c80e-dirty (oe-user@oe-host) (aa rch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP P REEMPT Fri Jul 26 14:32:20 UTC 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f8000000, s ize 128 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id share d-dma-pool [ 0.000000] OF: reserved mem: 0x00000000f8000000..0x00000000ffffffff (131072 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB ) nomap non-reusable tfa@80000000 [ 0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 Ki B) map non-reusable ramoops@9c700000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, s ize 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compati ble id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 Ki B) nomap non-reusable ipc-memories@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compa tible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 Ki B) nomap non-reusable m4f-dma-memory@9cb00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, s ize 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatibl e id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 K iB) nomap non-reusable m4f-memory@9cc00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compa tible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 Ki B) nomap non-reusable r5f-dma-memory@9da00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, s ize 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatibl e id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 K iB) nomap non-reusable r5f-memory@9db00000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 K iB) nomap non-reusable optee@9e800000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmi o32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m (ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(osp i_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=ea5bcfa0-02 rw r ootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000f1800000-0x00000000f580000 0] (64MB) [ 0.000000] Memory: 1781064K/2097152K available (11968K kernel code, 1250K rw data, 4036K rodata, 2432K init, 502K bss, 185016K reserved, 131072K cma-reserved ) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif fies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->1 9 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080440000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x000000008045000 0 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles : 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 43980 46511102ns [ 0.008592] Console: colour dummy device 80x25 [ 0.013195] Calibrating delay loop (skipped), value calculated using timer fr equency.. 400.00 BogoMIPS (lpj=800000) [ 0.023880] pid_max: default: 32768 minimum: 301 [ 0.028688] LSM: initializing lsm=capability,integrity [ 0.034066] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, line ar) [ 0.041651] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.051644] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.058974] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adju st=1. [ 0.066925] rcu: Hierarchical SRCU implementation. [ 0.071831] rcu: Max phase no-delay instances is 1000. [ 0.077461] Platform MSI: msi-controller@1820000 domain created [ 0.083799] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1 820000 domain created [ 0.093236] EFI services will not be available. [ 0.098174] smp: Bringing up secondary CPUs ... [ 0.103511] Detected VIPT I-cache on CPU1 [ 0.103603] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.103621] GICv3: CPU1: using allocated LPI pending table @0x000000008046000 0 [ 0.103681] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.104473] Detected VIPT I-cache on CPU2 [ 0.104537] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.104551] GICv3: CPU2: using allocated LPI pending table @0x000000008047000 0 [ 0.104586] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.105249] Detected VIPT I-cache on CPU3 [ 0.105305] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.105319] GICv3: CPU3: using allocated LPI pending table @0x000000008048000 0 [ 0.105348] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.105429] smp: Brought up 1 node, 4 CPUs [ 0.185170] SMP: Total of 4 processors activated. [ 0.189983] CPU features: detected: 32-bit EL0 Support [ 0.195258] CPU features: detected: CRC32 instructions [ 0.200584] CPU: All CPU(s) started at EL2 [ 0.204784] alternatives: applying system-wide alternatives [ 0.212440] devtmpfs: initialized [ 0.224495] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns [ 0.234504] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.246059] pinctrl core: initialized pinctrl subsystem [ 0.252007] DMI not present or invalid. [ 0.256649] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.263677] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.271011] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allo cations [ 0.279047] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic al locations [ 0.287242] audit: initializing netlink subsys (disabled) [ 0.292997] audit: type=2000 audit(0.184:1): state=initialized audit_enabled= 0 res=1 [ 0.293488] thermal_sys: Registered thermal governor 'step_wise' [ 0.300932] thermal_sys: Registered thermal governor 'power_allocator' [ 0.307127] cpuidle: using governor menu [ 0.317995] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.325027] ASID allocator initialised with 65536 entries [ 0.342418] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/ i2c@20010000/bridge-hdmi@3b [ 0.352270] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f000 0/pinctrl@a40000/cpsw-cpts [ 0.363554] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f000 0/i2c@20010000/bridge-hdmi@3b [ 0.374938] Modules: 27680 pages in range for non-PLT usage [ 0.374947] Modules: 519200 pages in range for PLT usage [ 0.381514] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.393914] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.400323] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.407263] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.413671] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.420610] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.427018] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.433958] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.441903] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7 e02f] Detected [ 0.451312] iommu: Default domain type: Translated [ 0.456245] iommu: DMA domain TLB invalidation policy: strict mode [ 0.462875] SCSI subsystem initialized [ 0.467050] usbcore: registered new interface driver usbfs [ 0.472697] usbcore: registered new interface driver hub [ 0.478159] usbcore: registered new device driver usb [ 0.483828] pps_core: LinuxPPS API ver. 1 registered [ 0.488908] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it> [ 0.498259] PTP clock support registered [ 0.502430] EDAC MC: Ver: 3.0.0 [ 0.506149] scmi_core: SCMI protocol bus registered [ 0.511484] FPGA manager framework [ 0.515055] Advanced Linux Sound Architecture Driver Initialized. [ 0.522287] vgaarb: loaded [ 0.525480] clocksource: Switched to clocksource arch_sys_counter [ 0.531992] VFS: Disk quotas dquot_6.6.0 [ 0.536051] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.549674] NET: Registered PF_INET protocol family [ 0.554940] IP idents hash table entries: 32768 (order: 6, 262144 bytes, line ar) [ 0.564126] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 1638 4 bytes, linear) [ 0.572931] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.580872] TCP established hash table entries: 16384 (order: 5, 131072 bytes , linear) [ 0.589079] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linea r) [ 0.597089] TCP: Hash tables configured (established 16384 bind 16384) [ 0.604029] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.610959] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.618478] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.624803] RPC: Registered named UNIX socket transport module. [ 0.630889] RPC: Registered udp transport module. [ 0.635699] RPC: Registered tcp transport module. [ 0.640508] RPC: Registered tcp-with-tls transport module. [ 0.646117] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.652709] NET: Registered PF_XDP protocol family [ 0.657628] PCI: CLS 0 bytes, default 64 [ 0.663157] Initialise system trusted keyrings [ 0.667982] workingset: timestamp_bits=46 max_order=19 bucket_order=0 [ 0.674923] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.681203] NFS: Registering the id_resolver key type [ 0.686407] Key type id_resolver registered [ 0.690685] Key type id_legacy registered [ 0.694804] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.701659] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering ... [ 0.742996] Key type asymmetric registered [ 0.747192] Asymmetric key parser 'x509' registered [ 0.752241] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 44) [ 0.759809] io scheduler mq-deadline registered [ 0.764443] io scheduler kyber registered [ 0.768578] io scheduler bfq registered [ 0.775590] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.782156] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.789610] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.802020] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.819415] loop: module loaded [ 0.823818] megasas: 07.725.01.00-rc1 [ 0.831335] tun: Universal TUN/TAP device driver, 1.6 [ 0.837658] VFIO - User Level meta-driver version: 0.3 [ 0.844027] usbcore: registered new interface driver usb-storage [ 0.850772] i2c_dev: i2c /dev entries driver [ 0.856789] sdhci: Secure Digital Host Controller Interface driver [ 0.863143] sdhci: Copyright(c) Pierre Ossman [ 0.867818] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.874394] ledtrig-cpu: registered to indicate activity on CPUs [ 0.880843] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.888121] usbcore: registered new interface driver usbhid [ 0.893826] usbhid: USB HID core driver [ 0.898107] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.906267] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte rs available [ 0.915233] optee: probing for conduit method. [ 0.919816] optee: revision 4.2 (12d7c4ee) [ 0.920150] optee: dynamic shared memory is enabled [ 0.930178] random: crng init done [ 0.933779] optee: initialized driver [ 0.939363] NET: Registered PF_PACKET protocol family [ 0.944669] Key type dns_resolver registered [ 0.957100] registered taskstats version 1 [ 0.961690] Loading compiled-in X.509 certificates [ 0.980501] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') [ 1.033910] ti-sci-clk 44043000.system-controller:clock-controller: recalc-ra te failed for dev=81, clk=20, ret=-19 [ 1.063574] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.070639] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f000 0/i2c@20010000/bridge-hdmi@3b [ 1.080611] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/ i2c@20010000/bridge-hdmi@3b [ 1.090381] i2c 1-003b: Fixed dependency cycle(s) with /connector-hdmi [ 1.097110] i2c 1-003b: Fixed dependency cycle(s) with /bus@f0000/dss@3020000 0 [ 1.104931] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.111871] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz [ 1.117873] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Rout er 3 domain created [ 1.127135] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator d omain 28 created [ 1.137548] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.146466] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.157821] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.169158] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.179712] printk: console [ttyS2] disabled [ 1.184485] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 239, base_baud = 3 000000) is a 8250 [ 1.193446] printk: console [ttyS2] enabled [ 1.193446] printk: console [ttyS2] enabled [ 1.201973] printk: bootconsole [ns16550a0] disabled [ 1.201973] printk: bootconsole [ns16550a0] disabled [ 1.215807] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 1.220917] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.227879] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.233274] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.240075] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.246537] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.253005] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.259246] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.266111] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.272677] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.281083] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.325485] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 10 00000 [ 1.337458] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.345599] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867 [ 1.353725] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss vers ion 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.366693] am65-cpsw-nuss 8000000.ethernet: Use random MAC address [ 1.372964] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.380090] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.386596] pps pps0: new PPS source ptp0 [ 1.390905] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000 000, add_val:1 pps:1 [ 1.405458] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.416323] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/ i2c@20000000/tps6598x@3f/connector [ 1.431437] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.437003] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu mber 1 [ 1.444845] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports [ 1.450851] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000000010 [ 1.460330] xhci-hcd xhci-hcd.0.auto: irq 254, io mem 0x31100000 [ 1.467263] hub 1-0:1.0: USB hub found [ 1.471106] hub 1-0:1.0: 1 port detected [ 1.476954] cpufreq: cpufreq_online: CPU0: Running at unlisted initial freque ncy: 1200000 KHz, changing to: 1250000 KHz [ 1.489926] mmc0: CQHCI version 5.10 [ 1.495948] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.502748] pca953x 1-0022: using AI [ 1.532074] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64 -bit [ 1.536969] debugfs: Directory 'pd:186' with parent 'pm_genpd' already presen t! [ 1.537648] mmc1: CQHCI version 5.10 [ 1.551446] clk: Disabling unused clocks [ 1.558721] ti-sci-clk 44043000.system-controller:clock-controller: is_prepar ed failed for dev=81, clk=20, ret=-19 [ 1.574082] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64 -bit [ 1.574316] ALSA device list: [ 1.584631] No soundcards found. [ 1.588703] Waiting for root device PARTUUID=ea5bcfa0-02... [ 1.617582] mmc0: Command Queue Engine enabled [ 1.622048] mmc0: new HS200 MMC card at address 0001 [ 1.627720] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.628095] mmc1: new ultra high speed SDR104 SDXC card at address 0001 [ 1.634701] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 1.639476] mmcblk1: mmc1:0001 BC2QT 59.6 GiB [ 1.644811] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 1.649940] mmcblk1: p1 p2 [ 1.653946] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0) [ 1.703793] EXT4-fs (mmcblk1p2): mounted filesystem e4e24fc1-c44e-4a51-8334-2 fb3ebdb5e73 r/w with ordered data mode. Quota mode: none. [ 1.716003] VFS: Mounted root (ext4 filesystem) on device 179:66. [ 1.725771] devtmpfs: mounted [ 1.730337] Freeing unused kernel memory: 2432K [ 1.734965] Run /sbin/init as init process [ 2.001677] systemd[1]: System time before build time, advancing clock. [ 2.054910] NET: Registered PF_INET6 protocol family [ 2.061019] Segment Routing with IPv6 [ 2.064749] In-situ OAM (IOAM) with IPv6 [ 2.106509] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -S ELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUAL ITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMO N +UTMP +SYSVINIT default-hierarchy=unified) [ 2.138404] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.10! [ 2.160391] systemd[1]: Hostname set to <am62xx-evm>. [ 2.406296] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-la uncher.service is marked executable. Please remove executable permission bits. P roceeding anyway. [ 2.442103] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launc her.service is marked executable. Please remove executable permission bits. Proc eeding anyway. [ 2.525023] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please updat e your unit file, and consider removing the setting altogether. [ 2.640991] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 2.725555] systemd[1]: Queued start job for default target Graphical Interfa ce. [ 2.763604] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 2.788083] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 2.812020] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 2.835352] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 2.858020] systemd[1]: Started Dispatch Password Requests to Console Directo ry Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ 2.881867] systemd[1]: Started Forward Password Requests to Wall Directory W atch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 2.905704] systemd[1]: Expecting device /dev/ttyS2... Expecting device /dev/ttyS2... [ 2.921768] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 2.937622] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 2.957606] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 2.973627] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 3.024049] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 3.049838] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 3.076995] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 3.098305] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 3.123301] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 3.146726] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 3.170814] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 3.186982] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 3.229977] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 3.250798] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 3.274728] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 3.342110] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 3.352617] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 3.382697] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 3.398376] systemd[1]: Kernel Trace File System was skipped because of an un met condition check (ConditionPathExists=/sys/kernel/tracing). [ 3.417621] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 3.440285] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 3.484502] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 3.507105] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 3.527370] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 3.564542] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 3.580229] fuse: init (API version 7.39) [ 3.593199] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 3.610190] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 3.632094] systemd[1]: Starting Journal Service... Starting Journal Service... [ 3.657141] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 3.684067] systemd[1]: Starting Generate network units from Kernel command l ine... Starting Generate network units from Kernel command line... [ 3.711596] cryptodev: loading out-of-tree module taints kernel. [ 3.719278] cryptodev: driver 1.13 loaded. [ 3.721097] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 3.738289] systemd-journald[128]: Collecting audit messages is enabled. [ 3.756022] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 3.822363] systemd[1]: Started RPC Bind. [ 3.822828] EXT4-fs (mmcblk1p2): re-mounted e4e24fc1-c44e-4a51-8334-2fb3ebdb5 e73 r/w. Quota mode: none. [ OK ] Started RPC Bind. [ 3.849286] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Start psplas…temd progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables... [ 4.273178] systemd-journald[128]: Received client request to flush runtime j ournal. Starting Create Static Device Nodes in /dev gracefully... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev gracefully. Starting Create Static Device Nodes in /dev... [ OK ] Finished Coldplug All udev Devices. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /var/volatile... [ 4.588823] audit: type=1334 audit(1709054766.580:2): prog-id=6 op=LOAD [ 4.595576] audit: type=1334 audit(1709054766.588:3): prog-id=7 op=LOAD Starting Rule-based Manager for Device Events and Files... [ OK ] Mounted /var/volatile. Starting Load/Save OS Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Finished Load/Save OS Random Seed. [ OK ] Finished Create Volatile Files and Directories. [ 4.883830] audit: type=1334 audit(1709054766.876:4): prog-id=8 op=LOAD Starting Network Name Resolution... [ 4.930447] audit: type=1334 audit(1709054766.924:5): prog-id=9 op=LOAD Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ OK ] Started Rule-based Manager for Device Events and Files. [ 4.989374] audit: type=1334 audit(1709054766.980:6): prog-id=10 op=LOAD [ 4.999043] audit: type=1334 audit(1709054766.988:7): prog-id=11 op=LOAD [ 5.009668] audit: type=1334 audit(1709054766.988:8): prog-id=12 op=LOAD Starting User Database Manager... [ OK ] Finished Record System Boot/Shutdown in UTMP. [ OK ] Started User Database Manager. [ OK ] Found device /dev/ttyS2. [ OK ] Started Network Name Resolution. [ OK ] Started Network Time Synchronization. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. [ OK ] Listening on PC/SC Smart Card Daemon Activation Socket. Starting Weston socket... [ 6.063008] audit: type=1334 audit(1709054768.056:9): prog-id=13 op=LOAD Starting D-Bus System Message Bus... Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Listening on Weston socket. [ OK ] Finished Reboot and dump vmcore via kexec. [ OK ] Started D-Bus System Message Bus. [ 6.286030] dbus-broker-lau[412]: memfd_create() called without MFD_EXEC or M FD_NOEXEC_SEAL set [ 6.365559] at24 0-0051: supply vcc not found, using dummy regulator [ 6.385012] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.393855] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ OK ] Reached target Socket Units. [ OK ] Reached target Basic System. [ 6.426073] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.439645] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ 6.452407] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write [ 6.455569] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.469911] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ OK ] Started Job spooling tools. [ 6.483628] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.494686] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ 6.495116] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma- memory@9cb00000 Starting Avahi mDNS/DNS-SD Stack... [ 6.525643] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... [ 6.590697] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device Starting IPv6 Packet Filtering Framework... [ 6.611286] platform 78000000.r5f: R5F core may have been powered on by a dif ferent host, programmed state (0) != actual state (1) [ 6.626709] platform 78000000.r5f: configured R5F for IPC-only mode [ 6.633371] platform 78000000.r5f: assigned reserved memory node r5f-dma-memo ry@9da00000 [ 6.642443] remoteproc remoteproc1: 78000000.r5f is available [ 6.645716] remoteproc remoteproc0: 5000000.m4fss is available [ 6.648420] remoteproc remoteproc1: attaching to 78000000.r5f [ 6.655225] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.660987] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 6.668911] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ 6.676022] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r 5f-dma-memory@9da00000 [ 6.682039] rtc-ti-k3 2b1f0000.rtc: registered as rtc0 [ 6.682134] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00: 12 UTC (12) [ 6.685989] systemd-journald[128]: Time jumped backwards, rotating. [ 6.688019] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.688054] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ 6.689122] remoteproc remoteproc0: powering up 5000000.m4fss [ 6.689143] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55016 [ 6.691824] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.691879] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ 6.691924] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node m 4f-dma-memory@9cb00000 [ 6.692610] virtio_rpmsg_bus virtio0: rpmsg host is online [ 6.692639] rproc-virtio rproc-virtio.3.auto: registered virtio0 (type 7) [ 6.692647] remoteproc remoteproc0: remote processor 5000000.m4fss is now up [ 6.694996] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.695933] virtio_rpmsg_bus virtio1: rpmsg host is online [ 6.695972] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7) [ 6.695980] remoteproc remoteproc1: remote processor 78000000.r5f is now atta ched [ 6.817543] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ 6.817562] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd Starting IPv4 Packet Filtering Framework..[ 6.833922] virtio_rpmsg_b us virtio0: creating channel ti.ipc4.ping-pong addr 0xd . [ 6.847873] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.849881] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 6.857609] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ 6.887579] sii902x 1-003b: supply iovcc not found, using dummy regulator [ 6.896581] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 6.930284] sii902x 1-003b: supply cvcc12 not found, using dummy regulator [ 6.943976] i2c i2c-1: Added multiplexed i2c bus 3 [ 6.968509] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@0/ports [ 6.977150] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txe s/oldi@1/ports [ 6.987333] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 [ 6.996201] tidss 30200000.dss: [drm] Cannot find any crtc or sizes [ 7.004549] tidss 30200000.dss: [drm] Cannot find any crtc or sizes [ OK ] Started irqbalance daemon. [ 7.017975] PVR_K: 188: Device: fd00000.gpu Starting Telephony service... [ 7.041615] PVR_K: 188: Read BVNC 33.15.11.3 from HW device registers Starting PulseAudio Sound System... [ 7.058339] PVR_K: 188: RGX Device registered with BVNC 33.15.11.3 Starting Expand the rootfs partiti…to full size of the boot device.... [ 7.086531] [drm] Initialized pvr 24.1.6554834 20170530 for fd00000.gpu on mi nor 1 [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. [ 7.116330] audit: type=1334 audit(12.928:10): prog-id=14 op=LOAD [ 7.128729] audit: type=1334 audit(12.940:11): prog-id=15 op=LOAD Starting User Login Management... [ 7.144534] audit: type=1334 audit(12.940:12): prog-id=16 op=LOAD Starting Telnet Server... [ OK ] Started ti-apps-launcher service. [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Finished Telnet Server. [ OK ] Reached target Preparation for Network. [ OK ] Reached target Hardware [ 7.535435] audit: type=1334 audit(13.348:13 ): prog-id=17 op=LOAD activated USB gadget. Starting Network Configuration... [ 7.565806] remoteproc remoteproc2: 30078000.pru is available [ 7.576782] remoteproc remoteproc3: 30074000.pru is available [ OK ] Started Avahi mDNS/DNS-SD Stack. Starting Virtual Console Setup... [ OK ] Started User Login Management. [ OK ] Started Telephony service. [ 9.229559] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 9.275368] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 9.282121] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600 ' Starting Save/Restore Sound Card State... [ OK ] Finished Expand the rootfs partition to full size of the boot device.. [ OK ] Finished Save/Restore Sound Card State. [ OK ] Reached target Sound Card. [ 9.441649] Bluetooth: Core ver 2.22 [ 9.445628] NET: Registered PF_BLUETOOTH protocol family [ 9.451101] Bluetooth: HCI device and connection manager initialized [ 9.457583] Bluetooth: HCI socket layer initialized [ 9.462551] Bluetooth: L2CAP socket layer initialized [ 9.467772] Bluetooth: SCO socket layer initialized [ OK ] Finished Virtual Console Setup. [ OK ] Started Network Configuration. [ OK ] Reached target Network. [ 9.593082] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] drive r [TI DP83867] (irq=POLL) [ 9.602756] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-r xid link mode Starting Enable and configure wl18xx bluetooth stack... Starting containerd container runtime... [ OK ] Started Netperf Benchmark Server 9.644833] am65-cpsw-nuss 8000000.et hernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL) m. [ 9.667255] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-r xid link mode Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Finished Enable and configure wl18xx bluetooth stack. [ OK ] Finished Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Weston, a Wayland compositor, as a system service... [ OK ] Finished Synchronize System and HW clocks. [ OK ] Created slice User Slice of UID 1000. Starting User Runtime Directory /run/user/1000... [ OK ] Finished User Runtime Directory /run/user/1000. Starting User Manager for UID 1000... [ 10.955690] audit: type=1006 audit(16.768:14): pid=550 uid=0 old-auid=4294967 295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ 10.967916] audit: type=1300 audit(16.768:14): arch=c00000b7 syscall=64 succe ss=yes exit=4 a0=8 a1=ffffec9921c8 a2=4 a3=1 items=0 ppid=1 pid=550 auid=1000 ui d=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(sy stemd)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 10.994095] audit: type=1327 audit(16.768:14): proctitle="(systemd)" [ OK ] Created slice Slice /system/systemd-fsck. Expecting device /dev/mmcblk1p1... [ OK ] Started PulseAudio Sound System. [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ OK ] Finished File System Check on /dev/mmcblk1p1. Mounting /run/media/boot-mmcblk1p1... [ OK ] Started User Manager for UID 1000. [ OK ] Started Session c1 of User weston 12.206889] audit: type=1006 audit(1 8.020:15): pid=532 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=42949672 95 ses=2 res=1 0m. [ 12.220111] audit: type=1300 audit(18.020:15): arch=c00000b7 syscall=64 succe ss=yes exit=4 a0=8 a1=ffffe174b018 a2=4 a3=1 items=0 ppid=1 pid=532 auid=1000 ui d=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(west on)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 12.246301] audit: type=1327 audit(18.020:15): proctitle="(weston)" [ OK ] Mounted /run/media/boot-mmcblk1p1. [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ 13.247810] PVR_K: 532: RGX Firmware image 'rgx.fw.33.15.11.3' loaded [ 13.268104] PVR_K: 532: Shader binary image 'rgx.sh.33.15.11.3' loaded [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ OK ] Started Session c2 of User weston. [ 13.637014] audit: type=1006 audit(19.448:16): pid=599 uid=0 old-auid=4294967 295 auid=1000 tty=tty7 old-ses=4294967295 ses=3 res=1 [ 13.651860] audit: type=1300 audit(19.448:16): arch=c00000b7 syscall=64 succe ss=yes exit=4 a0=8 a1=ffffe00842b8 a2=4 a3=1 items=0 ppid=1 pid=599 auid=1000 ui d=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=3 comm="(west on)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 13.677826] audit: type=1327 audit(19.448:16): proctitle="(weston)" [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ OK ] Started Session c3 of User weston. [ 13.917717] audit: type=1006 audit(19.728:17): pid=608 uid=0 old-auid=4294967 295 auid=1000 tty=tty7 old-ses=4294967295 ses=4 res=1 [ 13.929744] audit: type=1300 audit(19.728:17): arch=c00000b7 syscall=64 succe ss=yes exit=4 a0=8 a1=ffffc63fe098 a2=4 a3=1 items=0 ppid=1 pid=608 auid=1000 ui d=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=4 comm="(west on)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 13.955684] audit: type=1327 audit(19.728:17): proctitle="(weston)" [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ OK ] Started Session c4 of User weston. [ 14.166638] audit: type=1006 audit(19.980:18): pid=619 uid=0 old-auid=4294967 295 auid=1000 tty=tty7 old-ses=4294967295 ses=5 res=1 [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ OK ] Started Session c5 of User weston. [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am62xx-evm ttyS2 Arago 2023.10 am62xx-evm ttyS2 am62xx-evm login: am62xx-evm login: am62xx-evm login: ro************************************************************ *** *************************************************************** NOTICE: This file system contains the following GPL-3.0 packages: adwaita-icon-theme-symbolic autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gnu-config grub-common grub-editenv grub-efi gzip hidapi kbd-dev kbd-keymaps-pine less libasm1 libatomic-dev libatomic1 libbfd libdebuginfod1 libdw1 libelf1 libgcc-s-dev libgcc1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmpc3 libmpfr6 libopcodes libqt5charts-examples libqt5charts-plugins libqt5charts-qmlplugins libqt5charts5 libqt5serialport-examples libqt5serialport-plugins libqt5serialport-qmlplugins libqt5serialport5 libqt5svg-examples libqt5svg-plugins libqt5svg-qmlplugins libqt5svg5 libqt5virtualkeyboard-plugins libqt5virtualkeyboard-qmlplugins libqt5virtualkeyboard5 libreadline-dev libreadline8 libstdc++-dev libstdc++6 libunistring5 m4 make nettle parted piglit qt3d-plugins qt3d-qmlplugins qt3d qtbase-examples qtbase-plugins qtbase-qmlplugins qtbase qtconnectivity-plugins qtconnectivity-qmlplugins qtconnectivity qtdeclarative-plugins qtdeclarative-qmlplugins qtdeclarative-tools qtdeclarative qtgraphicaleffects-qmlplugins qtlocation-examples qtlocation-plugins qtlocation-qmlplugins qtlocation qtmultimedia-examples qtmultimedia-plugins qtmultimedia-qmlplugins qtmultimedia qtquick3d-plugins qtquick3d-qmlplugins qtquick3d qtquics-qmlplugins.control qtquics2-plugins.control qtquics2-qmlplugins.control qtquics2.control qtscript-examples qtscript-plugins qtscript-qmlplugins qtscript qtwayland-examples qtwayland-plugins qtwayland-qmlplugins qtwayland tar which If you do not wish to distribute GPL-3.0 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** ot [ 20.379164] kauditd_printk_skb: 9 callbacks suppressed [ 20.379188] audit: type=1006 audit(26.192:24): pid=999 uid=0 old-auid=4294967 295 auid=0 tty=(none) old-ses=4294967295 ses=7 res=1 [ 20.397763] audit: type=1300 audit(26.192:24): arch=c00000b7 syscall=64 succe ss=yes exit=1 a0=8 a1=ffffefd7f188 a2=1 a3=1 items=0 ppid=1 pid=999 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm="(syste md)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 20.424289] audit: type=1327 audit(26.192:24): proctitle="(systemd)" [ 20.431725] audit: type=1334 audit(26.224:25): prog-id=21 op=LOAD [ 20.439095] audit: type=1300 audit(26.224:25): arch=c00000b7 syscall=280 succ ess=yes exit=8 a0=5 a1=ffffd7089c88 a2=90 a3=0 items=0 ppid=1 pid=999 auid=0 uid =0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm="syst emd" exe="/usr/lib/systemd/systemd" key=(null) [ 20.465005] audit: type=1327 audit(26.224:25): proctitle="(systemd)" [ 20.472215] audit: type=1334 audit(26.236:26): prog-id=21 op=UNLOAD [ 20.479484] audit: type=1300 audit(26.236:26): arch=c00000b7 syscall=57 succe ss=yes exit=0 a0=8 a1=1 a2=0 a3=ffffb1576c60 items=0 ppid=1 pid=999 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm="system d" exe="/usr/lib/systemd/systemd" key=(null) [ 20.505295] audit: type=1327 audit(26.236:26): proctitle="(systemd)" [ 20.511850] audit: type=1334 audit(26.236:27): prog-id=22 op=LOAD root@am62xx-evm:~# root@am62xx-evm:~# sudo systemctl start bluetooth root@am62xx-evm:~# [ 39.486543] kauditd_printk_skb: 8 callbacks suppressed [ 39.486561] audit: type=1334 audit(45.300:32): prog-id=23 op=LOAD [ 39.497880] audit: type=1334 audit(45.304:33): prog-id=24 op=LOAD [ 39.504118] audit: type=1334 audit(45.312:34): prog-id=25 op=LOAD ^C root@am62xx-evm:~# sudo systemctl enable bluetooth [ 47.259005] audit: type=1334 audit(53.072:35): prog-id=26 op=LOAD [ 47.265207] audit: type=1334 audit(53.076:36): prog-id=27 op=LOAD [ 47.271405] audit: type=1334 audit(53.076:37): prog-id=6 op=UNLOAD [ 47.277648] audit: type=1334 audit(53.076:38): prog-id=7 op=UNLOAD [ 47.283904] audit: type=1334 audit(53.092:39): prog-id=28 op=LOAD [ 47.290064] audit: type=1334 audit(53.092:40): prog-id=13 op=UNLOAD [ 47.296382] audit: type=1334 audit(53.096:41): prog-id=29 op=LOAD [ 47.302532] audit: type=1334 audit(53.096:42): prog-id=8 op=UNLOAD [ 47.308775] audit: type=1334 audit(53.104:43): prog-id=30 op=LOAD [ 47.314907] audit: type=1334 audit(53.104:44): prog-id=9 op=UNLOAD root@am62xx-evm:~# sudo systemctl status bluetooth * bluetooth.service - Bluetooth service Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset> Active: active (running) since Thu 1970-01-01 00:00:45 UTC; 13s ago Docs: man:bluetoothd(8) Main PID: 1026 (bluetoothd) Status: "Running" Tasks: 1 (limit: 2087) Memory: 2.0M (peak: 2.3M) CPU: 97ms CGroup: /system.slice/bluetooth.service `-1026 /usr/libexec/bluetooth/bluetoothd Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/src/plu> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/profile> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/src/plu> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/src/plu> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/src/plu> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/src/plu> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/src/plu> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/profile> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: /usr/src/debug/bluez5/5.72/src/plu> Jan 01 00:00:45 am62xx-evm bluetoothd[1026]: Bluetooth management interface 1.2> root@am62xx-evm:~# sudo bluetoothctl scan on No default controller available root@am62xx-evm:~# [ 69.742178] kauditd_printk_skb: 26 callbacks suppressed [ 69.742195] audit: type=1334 audit(75.556:71): prog-id=34 op=UNLOAD [ 69.753827] audit: type=1334 audit(75.556:72): prog-id=33 op=UNLOAD [ 69.760113] audit: type=1334 audit(75.556:73): prog-id=32 op=UNLOAD sudo bluetoothctl Agent registeredct to bluetoothd... [bluetooth]# [bluetooth]# [bluetooth]# hciconfigh]# hciconfig [bluetooth]# 2nd bootlogfor bluetooth using hciconfig U-Boot 2024.04 (Oct 15 2024 - 15:33:04 +0530) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 DRAM: 2 GiB Core: 81 devices, 31 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -1 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'uEnv.txt' 20285952 bytes read in 238 ms (81.3 MiB/s) 60191 bytes read in 22 ms (2.6 MiB/s) Working FDT set to 88000000 ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK Working FDT set to 8feee000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.32-ti-g6de6e418c80e-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f8000000, size 128 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000f8000000..0x00000000ffffffff (131072 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000 [ 0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=ea5bcfa0-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000f1800000-0x00000000f5800000] (64MB) [ 0.000000] Memory: 1781064K/2097152K available (11968K kernel code, 1250K rwdata, 4036K rodata, 2432K init, 502K bss, 185016K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080440000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008593] Console: colour dummy device 80x25 [ 0.013197] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023883] pid_max: default: 32768 minimum: 301 [ 0.028689] LSM: initializing lsm=capability,integrity [ 0.034066] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.041651] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.051653] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.058986] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.066939] rcu: Hierarchical SRCU implementation. [ 0.071844] rcu: Max phase no-delay instances is 1000. [ 0.077471] Platform MSI: msi-controller@1820000 domain created [ 0.083808] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.093242] EFI services will not be available. [ 0.098175] smp: Bringing up secondary CPUs ... [ 0.103511] Detected VIPT I-cache on CPU1 [ 0.103600] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.103618] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000 [ 0.103677] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.104460] Detected VIPT I-cache on CPU2 [ 0.104521] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.104535] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000 [ 0.104572] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.105227] Detected VIPT I-cache on CPU3 [ 0.105282] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.105296] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000 [ 0.105325] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.105410] smp: Brought up 1 node, 4 CPUs [ 0.185153] SMP: Total of 4 processors activated. [ 0.189966] CPU features: detected: 32-bit EL0 Support [ 0.195241] CPU features: detected: CRC32 instructions [ 0.200563] CPU: All CPU(s) started at EL2 [ 0.204762] alternatives: applying system-wide alternatives [ 0.212444] devtmpfs: initialized [ 0.224492] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.234502] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.246066] pinctrl core: initialized pinctrl subsystem [ 0.252017] DMI not present or invalid. [ 0.256663] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.263695] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.271032] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.279068] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.287261] audit: initializing netlink subsys (disabled) [ 0.293020] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1 [ 0.293517] thermal_sys: Registered thermal governor 'step_wise' [ 0.300954] thermal_sys: Registered thermal governor 'power_allocator' [ 0.307149] cpuidle: using governor menu [ 0.318014] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.325042] ASID allocator initialised with 65536 entries [ 0.342426] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.352277] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts [ 0.363554] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.374921] Modules: 27680 pages in range for non-PLT usage [ 0.374932] Modules: 519200 pages in range for PLT usage [ 0.381518] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.393917] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.400327] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.407267] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.413675] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.420615] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.427022] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.433962] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.441907] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.451303] iommu: Default domain type: Translated [ 0.456234] iommu: DMA domain TLB invalidation policy: strict mode [ 0.462873] SCSI subsystem initialized [ 0.467049] usbcore: registered new interface driver usbfs [ 0.472696] usbcore: registered new interface driver hub [ 0.478157] usbcore: registered new device driver usb [ 0.483820] pps_core: LinuxPPS API ver. 1 registered [ 0.488900] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.498252] PTP clock support registered [ 0.502422] EDAC MC: Ver: 3.0.0 [ 0.506147] scmi_core: SCMI protocol bus registered [ 0.511482] FPGA manager framework [ 0.515052] Advanced Linux Sound Architecture Driver Initialized. [ 0.522291] vgaarb: loaded [ 0.525478] clocksource: Switched to clocksource arch_sys_counter [ 0.531985] VFS: Disk quotas dquot_6.6.0 [ 0.536045] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.549668] NET: Registered PF_INET protocol family [ 0.554940] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.564135] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.572945] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.580886] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.589092] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.597100] TCP: Hash tables configured (established 16384 bind 16384) [ 0.604039] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.610970] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.618491] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.624815] RPC: Registered named UNIX socket transport module. [ 0.630899] RPC: Registered udp transport module. [ 0.635709] RPC: Registered tcp transport module. [ 0.640518] RPC: Registered tcp-with-tls transport module. [ 0.646128] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.652720] NET: Registered PF_XDP protocol family [ 0.657641] PCI: CLS 0 bytes, default 64 [ 0.663179] Initialise system trusted keyrings [ 0.668008] workingset: timestamp_bits=46 max_order=19 bucket_order=0 [ 0.674943] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.681221] NFS: Registering the id_resolver key type [ 0.686420] Key type id_resolver registered [ 0.690699] Key type id_legacy registered [ 0.694817] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.701673] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.742999] Key type asymmetric registered [ 0.747195] Asymmetric key parser 'x509' registered [ 0.752245] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.759814] io scheduler mq-deadline registered [ 0.764448] io scheduler kyber registered [ 0.768585] io scheduler bfq registered [ 0.775615] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.782176] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.789616] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.802027] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.819473] loop: module loaded [ 0.823879] megasas: 07.725.01.00-rc1 [ 0.831371] tun: Universal TUN/TAP device driver, 1.6 [ 0.837700] VFIO - User Level meta-driver version: 0.3 [ 0.844085] usbcore: registered new interface driver usb-storage [ 0.850830] i2c_dev: i2c /dev entries driver [ 0.856854] sdhci: Secure Digital Host Controller Interface driver [ 0.863205] sdhci: Copyright(c) Pierre Ossman [ 0.867877] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.874450] ledtrig-cpu: registered to indicate activity on CPUs [ 0.880891] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.888167] usbcore: registered new interface driver usbhid [ 0.893871] usbhid: USB HID core driver [ 0.898154] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.906286] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.915265] optee: probing for conduit method. [ 0.919847] optee: revision 4.2 (12d7c4ee) [ 0.920181] optee: dynamic shared memory is enabled [ 0.930201] random: crng init done [ 0.933800] optee: initialized driver [ 0.939388] NET: Registered PF_PACKET protocol family [ 0.944689] Key type dns_resolver registered [ 0.957105] registered taskstats version 1 [ 0.961699] Loading compiled-in X.509 certificates [ 0.981277] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') [ 1.034719] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19 [ 1.064393] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.071431] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.081414] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.091167] i2c 1-003b: Fixed dependency cycle(s) with /connector-hdmi [ 1.097893] i2c 1-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 1.105723] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.112694] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz [ 1.118666] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.127914] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.138353] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.147287] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.158590] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.169976] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.180473] printk: console [ttyS2] disabled [ 1.185248] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 239, base_baud = 3000000) is a 8250 [ 1.194152] printk: console [ttyS2] enabled [ 1.194152] printk: console [ttyS2] enabled [ 1.202730] printk: bootconsole [ns16550a0] disabled [ 1.202730] printk: bootconsole [ns16550a0] disabled [ 1.217151] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 1.222283] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.229249] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.234645] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.241455] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.247913] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.254413] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.260620] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.267412] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.274007] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.282384] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.325489] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.337512] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.345615] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867 [ 1.353740] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.366693] am65-cpsw-nuss 8000000.ethernet: Use random MAC address [ 1.372963] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.380089] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.386580] pps pps0: new PPS source ptp0 [ 1.390879] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1 [ 1.405450] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.416253] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector [ 1.429019] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.434587] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.442387] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports [ 1.448390] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000000010 [ 1.457835] xhci-hcd xhci-hcd.0.auto: irq 254, io mem 0x31100000 [ 1.464661] hub 1-0:1.0: USB hub found [ 1.468484] hub 1-0:1.0: 1 port detected [ 1.474290] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz [ 1.487309] mmc0: CQHCI version 5.10 [ 1.493296] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.500169] pca953x 1-0022: using AI [ 1.532098] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.533127] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present! [ 1.533678] mmc1: CQHCI version 5.10 [ 1.551301] clk: Disabling unused clocks [ 1.558598] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19 [ 1.569532] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 1.573860] ALSA device list: [ 1.580076] No soundcards found. [ 1.584150] Waiting for root device PARTUUID=ea5bcfa0-02... [ 1.620296] mmc0: Command Queue Engine enabled [ 1.624772] mmc0: new HS200 MMC card at address 0001 [ 1.630438] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.634387] mmc1: new ultra high speed SDR104 SDXC card at address 0001 [ 1.636846] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 1.642182] mmcblk1: mmc1:0001 BC2QT 59.6 GiB [ 1.647487] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 1.652606] mmcblk1: p1 p2 [ 1.656812] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0) [ 3.326145] EXT4-fs (mmcblk1p2): recovery complete [ 3.345536] EXT4-fs (mmcblk1p2): mounted filesystem e4e24fc1-c44e-4a51-8334-2fb3ebdb5e73 r/w with ordered data mode. Quota mode: none. [ 3.357700] VFS: Mounted root (ext4 filesystem) on device 179:66. [ 3.367452] devtmpfs: mounted [ 3.372012] Freeing unused kernel memory: 2432K [ 3.376640] Run /sbin/init as init process [ 3.627322] systemd[1]: System time before build time, advancing clock. [ 3.676293] NET: Registered PF_INET6 protocol family [ 3.682415] Segment Routing with IPv6 [ 3.686172] In-situ OAM (IOAM) with IPv6 [ 3.728875] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 3.760753] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.10! [ 3.780410] systemd[1]: Hostname set to <am62xx-evm>. [ 4.026930] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 4.062755] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 4.145189] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.260992] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.345173] systemd[1]: Queued start job for default target Graphical Interface. [ 4.391589] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 4.416060] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 4.440026] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 4.463289] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 4.486024] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ 4.509851] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 4.533745] systemd[1]: Expecting device /dev/ttyS2... Expecting device /dev/ttyS2... [ 4.553766] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 4.569640] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.589613] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 4.605629] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 4.660118] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 4.681861] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 4.708989] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 4.730129] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 4.754945] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 4.778378] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 4.802411] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.822543] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.847525] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.870318] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 4.890288] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 4.938065] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.948627] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.978508] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.994414] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 5.015225] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 5.036516] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 5.063221] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 5.086969] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 5.107377] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 5.133205] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 5.155707] fuse: init (API version 7.39) [ 5.168483] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 5.182247] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 5.204483] systemd[1]: Starting Journal Service... Starting Journal Service... [ 5.231318] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 5.256033] systemd[1]: Starting Generate network units from Kernel command line... Starting Generate network units from Kernel command line... [ 5.282036] cryptodev: loading out-of-tree module taints kernel. [ 5.290020] cryptodev: driver 1.13 loaded. [ 5.305943] systemd-journald[128]: Collecting audit messages is enabled. [ 5.326483] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 5.362739] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 5.386199] EXT4-fs (mmcblk1p2): re-mounted e4e24fc1-c44e-4a51-8334-2fb3ebdb5e73 r/w. Quota mode: none. [ 5.387605] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 5.404471] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Start psplas…temd progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev gracefully... [ 5.850160] systemd-journald[128]: Received client request to flush runtime journal. [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev gracefully. Starting Create Static Device Nodes in /dev... [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Finished Coldplug All udev Devices. [ OK ] Reached target Preparation for Local File Systems. Mounting /var/volatile... [ 6.144539] audit: type=1334 audit(1709054766.512:2): prog-id=6 op=LOAD [ 6.151294] audit: type=1334 audit(1709054766.520:3): prog-id=7 op=LOAD Starting Rule-based Manager for Device Events and Files... [ OK ] Mounted /var/volatile. Starting Load/Save OS Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Finished Load/Save OS Random Seed. [ OK ] Finished Create Volatile Files and Directories. [ 6.403057] audit: type=1334 audit(1709054766.772:4): prog-id=8 op=LOAD Starting Network Name Resolution... [ 6.446201] audit: type=1334 audit(1709054766.816:5): prog-id=9 op=LOAD Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ OK ] Started Rule-based Manager for Device Events and Files. [ 6.590934] audit: type=1334 audit(1709054766.960:6): prog-id=10 op=LOAD [ 6.601745] audit: type=1334 audit(1709054766.972:7): prog-id=11 op=LOAD [ 6.613642] audit: type=1334 audit(1709054766.980:8): prog-id=12 op=LOAD Starting User Database Manager... [ OK ] Finished Record System Boot/Shutdown in UTMP. [ OK ] Started User Database Manager. [ OK ] Found device /dev/ttyS2. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Set. [ OK ] Started Network Name Resolution. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Reached target System Initialization. [ OK ] Started Daily rotation of log files. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. [ OK ] Listening on PC/SC Smart Card Daemon Activation Socket. Starting Weston socket... [ 7.808991] audit: type=1334 audit(1709054768.176:9): prog-id=13 op=LOAD [ 7.845302] at24 0-0051: supply vcc not found, using dummy regulator Starting D-Bus System Message Bus... [ 7.860658] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write [ 7.866916] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 7.880744] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports Starting Reboot and dump vmcore via kexec... [ 7.897052] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 7.905757] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ OK ] Listening on Docker Socket for the [ 7.922286] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports API. [ 7.933528] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ OK ] Listening on Weston socket. [ 7.948918] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000 [ 7.960691] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode [ 7.965004] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 7.967817] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device [ 7.976252] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ OK ] Finished Reboot and dump vmcore via kexec. [ 8.000806] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 8.000907] remoteproc remoteproc0: 5000000.m4fss is available [ 8.009825] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 8.031425] remoteproc remoteproc0: powering up 5000000.m4fss [ 8.036961] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 8.041711] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55016 [ 8.050189] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 8.061804] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node m4f-dma-memory@9cb00000 [ 8.068716] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 8.077367] virtio_rpmsg_bus virtio0: rpmsg host is online [ 8.077935] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 8.078067] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 8.085532] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 8.090386] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 8.093947] platform 78000000.r5f: configured R5F for IPC-only mode [ 8.098129] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7) [ 8.098148] remoteproc remoteproc0: remote processor 5000000.m4fss is now up [ 8.113650] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ OK ] Reached target Socket Units. [ 8.156636] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000 [ 8.158263] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 8.173435] remoteproc remoteproc1: 78000000.r5f is available [ 8.179377] remoteproc remoteproc1: attaching to 78000000.r5f [ 8.190196] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 8.192303] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 8.201617] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9da00000 [ 8.207164] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 8.233892] virtio_rpmsg_bus virtio1: rpmsg host is online [ 8.234834] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 8.238930] rtc-ti-k3 2b1f0000.rtc: registered as rtc0 [ 8.239023] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:14 UTC (14) [ 8.240148] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7) [ 8.247599] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 8.252710] remoteproc remoteproc1: remote processor 78000000.r5f is now attached [ 8.275095] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 8.284485] systemd-journald[128]: Time jumped backwards, rotating. [ OK ] Reached target Hardware activated U[ 8.302932] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports SB gadget. [ 8.322515] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 8.331397] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 8.342005] sii902x 1-003b: supply iovcc not found, using dummy regulator [ 8.349273] sii902x 1-003b: supply cvcc12 not found, using dummy regulator [ 8.363098] i2c i2c-1: Added multiplexed i2c bus 3 [ 8.372632] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports [ 8.381232] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports [ 8.392961] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 [ 8.401115] tidss 30200000.dss: [drm] Cannot find any crtc or sizes [ 8.410045] tidss 30200000.dss: [drm] Cannot find any crtc or sizes [ 8.555270] PVR_K: 186: Device: fd00000.gpu [ 8.586549] PVR_K: 186: Read BVNC 33.15.11.3 from HW device registers [ 8.595746] PVR_K: 186: RGX Device registered with BVNC 33.15.11.3 [ 8.603814] [drm] Initialized pvr 24.1.6554834 20170530 for fd00000.gpu on minor 1 [ 8.605699] remoteproc remoteproc2: 30074000.pru is available [ 8.619158] remoteproc remoteproc3: 30078000.pru is available [ OK ] Started D-Bus System Message Bus. [ OK ] Reached target Basic System. [ 8.693647] dbus-broker-lau[413]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set [ OK ] Started Job spooling tools. Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting PulseAudio Sound System... Starting Expand the rootfs partiti…to full size of the boot device.... [ OK ] Started Seva Launcher Service. [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. [ 8.947251] audit: type=1334 audit(15.204:10): prog-id=14 op=LOAD [ 8.959413] audit: type=1334 audit(15.212:11): prog-id=15 op=LOAD Starting User Login Management... Starting Telnet Server... [ OK ] Started ti-apps-launcher service. [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Finished Telnet Server. [ OK ] Reached target Preparation for Network. Starting Save/Restore Sound Card State... Starting Network Configuration... Starting Virtual Console Setup... [ OK ] Started Telephony service. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Finished Save/Restore Sound Card State. [ OK ] Reached target Sound Card. [ OK ] Started User Login Management. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 11.157863] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 11.171853] Bluetooth: Core ver 2.22 [ 11.175731] NET: Registered PF_BLUETOOTH protocol family [ 11.181190] Bluetooth: HCI device and connection manager initialized [ 11.187687] Bluetooth: HCI socket layer initialized [ 11.192723] Bluetooth: L2CAP socket layer initialized [ OK ] Created slice Slice /system/systemd[ 11.197989] Bluetooth: SCO socket layer initialized -fsck. Expecting device /dev/mmcblk1p1... [ 11.226882] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 11.233744] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ OK ] Finished Expand the rootfs partition to full size of the boot device.. [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ OK ] Started Network Configuration. [ OK ] Reached target Network. [ 11.480085] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) Starting Enable and configure wl18xx bluetooth[ 11.496722] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode stack... Starting containerd container runtime... [ OK ] Started Netperf Benchmark Server 11.529575] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL) m. [ 11.541879] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Finished Virtual Console Setup. [ OK ] Finished Enable and configure wl18xx bluetooth stack. [ OK ] Finished Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Weston, a Wayland compositor, as a system service... [ OK ] Finished File System Check on /dev/mmcblk1p1. Mounting /run/media/boot-mmcblk1p1... [ OK ] Mounted /run/media/boot-mmcblk1p1. [ OK ] Created slice User Slice of UID 1000. Starting User Runtime Directory /run/user/1000... [ OK ] Finished User Runtime Directory /run/user/1000. Starting User Manager for UID 1000... [ OK ] Finished Synchronize System and HW clocks. [ OK ] Started PulseAudio Sound System. [ 14.137443] kauditd_printk_skb: 2 callbacks suppressed [ 14.137459] audit: type=1006 audit(20.392:14): pid=579 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ 14.154735] audit: type=1300 audit(20.392:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe31a3888 a2=4 a3=1 items=0 ppid=1 pid=579 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 14.180957] audit: type=1327 audit(20.392:14): proctitle="(systemd)" [ OK ] Started User Manager for UID 1000. [ OK ] Started Session c1 of User weston 15.194602] audit: type=1006 audit(21.452:15): pid=563 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 0m. [ 15.208330] audit: type=1300 audit(21.452:15): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffcc7985e8 a2=4 a3=1 items=0 ppid=1 pid=563 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 15.234637] audit: type=1327 audit(21.452:15): proctitle="(weston)" [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ 16.317272] PVR_K: 563: RGX Firmware image 'rgx.fw.33.15.11.3' loaded [ 16.336583] PVR_K: 563: Shader binary image 'rgx.sh.33.15.11.3' loaded [FAILED] Failed to start Weston, a Wayland compositor, as a system service. See 'systemctl status weston.service' for details. Starting Weston, a Wayland compositor, as a system service... [ 16.790041] audit: type=1006 audit(23.044:16): pid=597 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=3 res=1 [ 16.802682] audit: type=1300 audit(23.044:16): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc71088d8 a2=4 a3=1 items=0 ppid=1 pid=597 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=3 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 16.828974] audit: type=1327 audit(23.044:16): proctitle="(weston)" [ 17.094912] audit: type=1006 audit(23.352:17): pid=610 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=4 res=1 _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am62xx-evm ttyS2 Arago 2023.10 am62xx-evm ttyS2 am62xx-evm login: [ 19.252879] kauditd_printk_skb: 8 callbacks suppressed [ 19.252902] audit: type=1701 audit(25.508:20): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=487 comm="ti-apps-launche" exe="/usr/bin/ti-apps-launcher" sig=11 res=1 [ 19.302267] audit: type=1334 audit(25.560:21): prog-id=18 op=LOAD [ 19.308545] audit: type=1334 audit(25.568:22): prog-id=19 op=LOAD [ 19.314843] audit: type=1334 audit(25.572:23): prog-id=20 op=LOAD *************************************************************** *************************************************************** NOTICE: This file system contains the following GPL-3.0 packages: adwaita-icon-theme-symbolic autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gnu-config grub-common grub-editenv grub-efi gzip hidapi kbd-dev kbd-keymaps-pine less libasm1 libatomic-dev libatomic1 libbfd libdebuginfod1 libdw1 libelf1 libgcc-s-dev libgcc1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmpc3 libmpfr6 libopcodes libqt5charts-examples libqt5charts-plugins libqt5charts-qmlplugins libqt5charts5 libqt5serialport-examples libqt5serialport-plugins libqt5serialport-qmlplugins libqt5serialport5 libqt5svg-examples libqt5svg-plugins libqt5svg-qmlplugins libqt5svg5 libqt5virtualkeyboard-plugins libqt5virtualkeyboard-qmlplugins libqt5virtualkeyboard5 libreadline-dev libreadline8 libstdc++-dev libstdc++6 libunistring5 m4 make nettle parted piglit qt3d-plugins qt3d-qmlplugins qt3d qtbase-examples qtbase-plugins qtbase-qmlplugins qtbase qtconnectivity-plugins qtconnectivity-qmlplugins qtconnectivity qtdeclarative-plugins qtdeclarative-qmlplugins qtdeclarative-tools qtdeclarative qtgraphicaleffects-qmlplugins qtlocation-examples qtlocation-plugins qtlocation-qmlplugins qtlocation qtmultimedia-examples qtmultimedia-plugins qtmultimedia-qmlplugins qtmultimedia qtquick3d-plugins qtquick3d-qmlplugins qtquick3d qtquics-qmlplugins.control qtquics2-plugins.control qtquics2-qmlplugins.control qtquics2.control qtscript-examples qtscript-plugins qtscript-qmlplugins qtscript qtwayland-examples qtwayland-plugins qtwayland-qmlplugins qtwayland tar which If you do not wish to distribute GPL-3.0 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** am62xx-evm login: am62xx-evm login: am62xx-evm login: am62xx-evm login: root [ 28.421709] audit: type=1334 audit(34.680:24): prog-id=20 op=UNLOAD [ 28.428034] audit: type=1334 audit(34.680:25): prog-id=19 op=UNLOAD [ 28.434331] audit: type=1334 audit(34.680:26): prog-id=18 op=UNLOAD _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am62xx-evm ttyS2 Arago 2023.10 am62xx-evm ttyS2 am62xx-evm login: root [ 31.155052] audit: type=1006 audit(37.412:27): pid=1011 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=7 res=1 [ 31.167017] audit: type=1300 audit(37.412:27): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff1a4d278 a2=1 a3=1 items=0 ppid=1 pid=1011 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 31.193087] audit: type=1327 audit(37.412:27): proctitle="(systemd)" [ 31.199522] audit: type=1334 audit(37.424:28): prog-id=21 op=LOAD [ 31.205697] audit: type=1300 audit(37.424:28): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd3139f58 a2=90 a3=0 items=0 ppid=1 pid=1011 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=7 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null) [ 31.230855] audit: type=1327 audit(37.424:28): proctitle="(systemd)" [ 31.237285] audit: type=1334 audit(37.448:29): prog-id=21 op=UNLOAD root@am62xx-evm:~# dmesg | grep -i bluetooth ^C root@am62xx-evm:~# lsmod | grep bluetooth bluetooth 516096 2 ecdh_generic 16384 1 bluetooth rfkill 28672 3 bluetooth,cfg80211 root@am62xx-evm:~# root@am62xx-evm:~# ^C root@am62xx-evm:~# ^C root@am62xx-evm:~# ^C root@am62xx-evm:~# ^C root@am62xx-evm:~# ^C root@am62xx-evm:~# ^C root@am62xx-evm:~# lsmod | grep bluetooth bluetooth 516096 2 ecdh_generic 16384 1 bluetooth rfkill 28672 3 bluetooth,cfg80211 root@am62xx-evm:~# hciconfig root@am62xx-evm:~#
Thank you for your support in resolving these issues.
Raj
