PROCESSOR-SDK-AM64X: AM64x-EVM eth1 is not being enumerated
Part Number: PROCESSOR-SDK-AM64X
Other Parts Discussed in Thread: TMDS64EVM, DP83869
I'm running the AM64x-EVM from an SD card flashed from the v10.00.07.04 SDK Yocto image tisdk-default-image-am64xx-evm.rootfs.wic.xz and noticed that ETH1 is missing. I'm sure it wasn't when I booted the board a few days ago with the same image. I have network cables connected to all three ports on the EVM and they all have link lights and connected at 1G on the switch.
U-Boot net list reports
eth0 : ethernet@8000000port@1 34:08:e1:80:b7:b3 active
eth2 : icssg1-eth-port@0 70:ff:76:1e:e8:d1
and in Linux ifconfig reports eth0: and eth2: but no eht1:
What has happened to disable eht1 and how do I re-enable it ?
Jon
  • To investigate further I reflashed v10.00.07.04 and found that on the first boot eth0, eth1 and eth2 were enumerated but then on a warm boot only eth0 and eth2. Following that on a further cold boot only eth0 and eth2 again.
    I then reflashed v09.02.01.10 and on multiple cold and warm boots eth0, eth1 and eth2 are all enumerated. I also noted that u-boot (2023.04-ti) in the v9 SDK enumerates eth3 and eth0 rather than eth2 and eth0.
    So
    1) what has been broken in the v10 SDK to make enumeration of eth1 unrelable ?
    2) what is the fix for this please ?
    Jon
  • Hello Jon,
    When you say "warm boot" what specific command/steps did you take to initiate "warm boot"?
    On an initial cold boot on an AM64x-EVM (TMDS64EVM) I found that in U-boot "net list" only reports eth0 and eth2, but in Linux "ifconfig" reports all three (eth0, eth1, and eth2).
    Afterwards, if I do a "reboot" command in Linux, I see U-boot "net list" still reports only eth0 and eth2, and Linux "ifconfig" still reports all three.
    Therefore, I wasn't able to reproduce the issue you are seeing.
    -Daolin
  • Hi Daolin,
    Please can you confirm which SDK and Linux kernel you are using and which revision of AM64x-EVM ?
    Please see my log below where you can see the issue clearly.
    This is what I did :-
    Power on (cold boot) eth0,eth1,eth2
    reboot (warm boot) eth0, eth2
    Shutdown
    Power on (cold boot) eth0, eth2
    Shutdown
    Please review the log, repeat these steps and report back.
    Jon
    ÿ
    U-Boot SPL 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    Resetting on cold boot to workaround ErrataID:i2331
    Please resend tiboot3.bin in case of UART/DFU boot
    resetting ...
    SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    SPL initial stack usage: 13392 bytes
    Trying to boot from MMC2
    Authentication passed
    Loading Environment from MMC... *** Warning - No MMC card found, using default environment
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    I/TC:
    I/TC: OP-TEE version: 4.2.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Apr 12 09:51:21 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    SoC:   AM64X SR2.0 HS-FS
    Model: Texas Instruments AM642 EVM
    Board: AM64-EVM rev C
    DRAM:  2 GiB
    Core:  98 devices, 31 uclasses, devicetree: separate
    NAND:  0 MiB
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1, eth2: icssg1-eth-port@0
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    574 bytes read in 41 ms (13.7 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    20285952 bytes read in 837 ms (23.1 MiB/s)
    64278 bytes read in 47 ms (1.3 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
    Working FDT set to 8feed000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.6.32-ti-g6de6e418c80e-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM642 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable m4f-dma-memory@a4000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable m4f-memory@a4100000
    [    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a57fffff (8192 KiB) nomap non-reusable ipc-memories@a5000000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a57fffff]
    [    0.000000]   node   0: [mem 0x00000000a5800000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fba00000 on node -1
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000f7800000-0x00000000fb800000] (64MB)
    [    0.000000] Memory: 1822796K/2097152K available (11968K kernel code, 1250K rwdata, 4036K rodata, 2432K init, 502K bss, 241588K reserved, 32768K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080040000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008654] Console: colour dummy device 80x25
    [    0.013265] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023945] pid_max: default: 32768 minimum: 301
    [    0.028774] LSM: initializing lsm=capability,integrity
    [    0.034166] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041749] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051866] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.059219] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.067213] rcu: Hierarchical SRCU implementation.
    [    0.072122] rcu:     Max phase no-delay instances is 1000.
    [    0.077778] Platform MSI: msi-controller@1820000 domain created
    [    0.084172] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.093724] EFI services will not be available.
    [    0.098731] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.112406] Detected VIPT I-cache on CPU1
    [    0.112514] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.112535] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
    [    0.112596] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.112743] smp: Brought up 1 node, 2 CPUs
    [    0.142131] SMP: Total of 2 processors activated.
    [    0.146942] CPU features: detected: 32-bit EL0 Support
    [    0.152215] CPU features: detected: CRC32 instructions
    [    0.157535] CPU: All CPU(s) started at EL2
    [    0.161722] alternatives: applying system-wide alternatives
    [    0.169410] devtmpfs: initialized
    [    0.183516] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.193514] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.201933] pinctrl core: initialized pinctrl subsystem
    [    0.207959] DMI not present or invalid.
    [    0.212735] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.219946] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.227383] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.235493] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.243723] audit: initializing netlink subsys (disabled)
    [    0.249562] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
    [    0.250152] thermal_sys: Registered thermal governor 'step_wise'
    [    0.257512] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.263929] cpuidle: using governor menu
    [    0.274869] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.281878] ASID allocator initialised with 65536 entries
    [    0.300781] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f4000/pinctrl@a40000/cpsw-cpts-pps
    [    0.316022] Modules: 27680 pages in range for non-PLT usage
    [    0.316045] Modules: 519200 pages in range for PLT usage
    [    0.322801] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.335197] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.341604] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.348539] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.354943] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.361878] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.368281] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.375215] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.383576] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
    [    0.393325] iommu: Default domain type: Translated
    [    0.398281] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.404991] SCSI subsystem initialized
    [    0.409385] usbcore: registered new interface driver usbfs
    [    0.415047] usbcore: registered new interface driver hub
    [    0.420525] usbcore: registered new device driver usb
    [    0.426369] pps_core: LinuxPPS API ver. 1 registered
    [    0.431456] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.440804] PTP clock support registered
    [    0.445022] EDAC MC: Ver: 3.0.0
    [    0.449146] scmi_core: SCMI protocol bus registered
    [    0.454668] FPGA manager framework
    [    0.458319] Advanced Linux Sound Architecture Driver Initialized.
    [    0.465847] vgaarb: loaded
    [    0.469161] clocksource: Switched to clocksource arch_sys_counter
    [    0.475724] VFS: Disk quotas dquot_6.6.0
    [    0.479779] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.494774] NET: Registered PF_INET protocol family
    [    0.500103] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.509871] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.518654] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.526587] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.534811] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.542850] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.549800] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.556758] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.564294] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.570758] RPC: Registered named UNIX socket transport module.
    [    0.576862] RPC: Registered udp transport module.
    [    0.581672] RPC: Registered tcp transport module.
    [    0.586480] RPC: Registered tcp-with-tls transport module.
    [    0.592085] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.598678] NET: Registered PF_XDP protocol family
    [    0.603598] PCI: CLS 0 bytes, default 64
    [    0.609112] Initialise system trusted keyrings
    [    0.614027] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.621086] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.627518] NFS: Registering the id_resolver key type
    [    0.632754] Key type id_resolver registered
    [    0.637034] Key type id_legacy registered
    [    0.641166] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.648019] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.696207] Key type asymmetric registered
    [    0.700413] Asymmetric key parser 'x509' registered
    [    0.705483] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.713049] io scheduler mq-deadline registered
    [    0.717706] io scheduler kyber registered
    [    0.721857] io scheduler bfq registered
    [    0.729395] pinctrl-single 4084000.pinctrl: 33 pins, size 132
    [    0.735860] pinctrl-single f4000.pinctrl: 180 pins, size 720
    [    0.743690] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.757609] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.777482] loop: module loaded
    [    0.782137] megasas: 07.725.01.00-rc1
    [    0.790879] tun: Universal TUN/TAP device driver, 1.6
    [    0.797640] VFIO - User Level meta-driver version: 0.3
    [    0.804387] usbcore: registered new interface driver usb-storage
    [    0.811246] i2c_dev: i2c /dev entries driver
    [    0.817033] sdhci: Secure Digital Host Controller Interface driver
    [    0.823402] sdhci: Copyright(c) Pierre Ossman
    [    0.828164] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.834892] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.841512] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.849048] usbcore: registered new interface driver usbhid
    [    0.854776] usbhid: USB HID core driver
    [    0.859149] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.866113] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.872967] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.881602] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.890831] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.895422] optee: revision 4.2 (12d7c4ee)
    [    0.912117] optee: dynamic shared memory is enabled
    [    0.922329] random: crng init done
    [    0.926000] optee: initialized driver
    [    0.932438] NET: Registered PF_PACKET protocol family
    [    0.937764] Key type dns_resolver registered
    [    0.951672] registered taskstats version 1
    [    0.956249] Loading compiled-in X.509 certificates
    [    0.977059] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    [    1.129031] pca953x 0-0038: supply vcc not found, using dummy regulator
    [    1.136003] pca953x 0-0038: using no AI
    [    1.153992] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.162214] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.169202] pca953x 1-0022: using AI
    [    1.194502] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.200762] ti-sci-intr bus@f4000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.210169] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.222602] ti-udma 485c0100.dma-controller: Number of rings: 68
    [    1.230601] ti-udma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    1.240927] ti-udma 485c0000.dma-controller: Number of rings: 288
    [    1.258799] ti-udma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
    [    1.270238] printk: console [ttyS2] disabled
    [    1.275304] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 317, base_baud = 3000000) is a 8250
    [    1.284248] printk: console [ttyS2] enabled
    [    1.292714] printk: bootconsole [ns16550a0] disabled
    [    1.310196] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.315307] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.322276] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.327672] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    1.334677] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    1.341499] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    1.348272] 0x000000700000-0x000000740000 : "ospi.env"
    [    1.354863] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    1.362061] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.368901] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.385543] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.429169] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.439454] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.447633] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
    [    1.460551] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    1.467684] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.474438] pps pps0: new PPS source ptp0
    [    1.478910] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.496728] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    1.509952] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.520834] mmc0: CQHCI version 5.10
    [    1.537770] j721e-pcie f102000.pcie: host bridge /bus@f4000/pcie@f102000 ranges:
    [    1.545253] j721e-pcie f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
    [    1.553424] j721e-pcie f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
    [    1.561247] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.561730] j721e-pcie f102000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x0000000000
    [    1.661380] mmc0: Command Queue Engine enabled
    [    1.665872] mmc0: new HS200 MMC card at address 0001
    [    1.671706] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.680800]  mmcblk0: p1
    [    1.684140] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.690494] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.696670] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
    [    2.573680] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
    [    2.580040] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.585532] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
    [    2.595003] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
    [    2.601911] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
    [    2.607929] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xfffffffff 64bit pref]
    [    2.615310] pci 0000:00:00.0: supports D1
    [    2.619320] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.627734] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.636006] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.642698] pci 0000:00:00.0: BAR 0: no space for [mem size 0x1000000000 64bit pref]
    [    2.650442] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x1000000000 64bit pref]
    [    2.658530] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.663680] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    2.670748] pcieport 0000:00:00.0: PME: Signaling with IRQ 520
    [    2.677014] pcieport 0000:00:00.0: AER: enabled with IRQ 520
    [    2.685427] mmc1: CQHCI version 5.10
    [    2.688090] clk: Disabling unused clocks
    [    2.721066] ALSA device list:
    [    2.724158]   No soundcards found.
    [    2.725740] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.735983] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.793741] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    2.801246] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
    [    2.811515]  mmcblk1: p1 p2
    [    3.045514] EXT4-fs (mmcblk1p2): mounted filesystem 27d406a0-8181-44e9-8e68-07b1dee77e6c r/w with ordered data mode. Quota mode: none.
    [    3.057769] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.067182] devtmpfs: mounted
    [    3.071779] Freeing unused kernel memory: 2432K
    [    3.076430] Run /sbin/init as init process
    [    3.407185] systemd[1]: System time before build time, advancing clock.
    [    3.469862] NET: Registered PF_INET6 protocol family
    [    3.476301] Segment Routing with IPv6
    [    3.480113] In-situ OAM (IOAM) with IPv6
    [    3.533660] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    3.565714] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    3.596058] systemd[1]: Hostname set to <am64xx-evm>.
    [    3.610205] systemd[1]: Initializing machine ID from random generator.
    [    4.164029] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.338897] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.455429] systemd[1]: Queued start job for default target Graphical Interface.
    [    4.501437] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    4.528430] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    4.552425] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    4.575706] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    4.597908] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    4.621873] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    4.645589] systemd[1]: Expecting device /dev/ttyS2...
    [    4.665628] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    4.685525] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    4.705483] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    4.725524] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    4.787522] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    4.809646] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    4.841894] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    4.866010] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.891248] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    4.918369] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.942485] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.966702] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.996561] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    5.018312] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    5.042418] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    5.089813] systemd[1]: Mounting Huge Pages File System...
    [    5.128399] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.162939] systemd[1]: Mounting Kernel Debug File System...
    [    5.182258] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    5.222079] systemd[1]: Mounting Temporary Directory /tmp...
    [    5.250561] systemd[1]: Starting Create List of Static Device Nodes...
    [    5.298573] systemd[1]: Starting Load Kernel Module configfs...
    [    5.346306] systemd[1]: Starting Load Kernel Module drm...
    [    5.402439] systemd[1]: Starting Load Kernel Module fuse...
    [    5.430347] systemd[1]: Starting RPC Bind...
    [    5.442017] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    5.454783] fuse: init (API version 7.39)
    [    5.486349] systemd[1]: Starting Journal Service...
    [    5.522593] systemd[1]: Starting Load Kernel Modules...
    [    5.585584] systemd[1]: Starting Generate network units from Kernel command line...
    [    5.628556] cryptodev: loading out-of-tree module taints kernel.
    [    5.637456] systemd-journald[104]: Collecting audit messages is enabled.
    [    5.645440] cryptodev: driver 1.13 loaded.
    [    5.653920] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.710361] systemd[1]: Starting Coldplug All udev Devices...
    [    5.762624] systemd[1]: Started RPC Bind.
    [    5.777452] EXT4-fs (mmcblk1p2): re-mounted 27d406a0-8181-44e9-8e68-07b1dee77e6c r/w. Quota mode: none.
    [    5.800767] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    5.830594] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gracefully...
    [  OK  ] Mounted FUSE Control File System.
    [    6.266048] systemd-journald[104]: Received client request to flush runtime journal.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create System Users...
    [    6.601833] audit: type=1334 audit(1709054767.192:2): prog-id=6 op=LOAD
    [    6.613789] audit: type=1334 audit(1709054767.200:3): prog-id=7 op=LOAD
    [    6.625409] audit: type=1334 audit(1709054767.200:4): prog-id=8 op=LOAD
             Starting User Database Manager...
    [  OK  ] Started User Database Manager.
    [  OK  ] Finished Create System Users.
    [  OK  ] Finished Coldplug All udev Devices.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    7.109235] audit: type=1334 audit(1709054767.696:5): prog-id=9 op=LOAD
    [    7.119675] audit: type=1334 audit(1709054767.704:6): prog-id=10 op=LOAD
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Dynamic Linker Cache...
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Load/Save OS Random Seed.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Rebuild Journal Catalog...
    [    7.556784] audit: type=1334 audit(1709054768.144:7): prog-id=11 op=LOAD
             Starting Network Name Resolution...
    [    7.601748] audit: type=1334 audit(1709054768.188:8): prog-id=12 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Finished Rebuild Journal Catalog.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Found device /dev/ttyS2.
    [   11.206390] CAN device driver interface
    [   11.291595] at24 0-0050: supply vcc not found, using dummy regulator
    [   11.317790] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    [  OK  ] Finished Rebuild Dynamic Linker Cache.
             Starting Update is Completed...
    [  OK  ] Finished Update is Completed.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Timer service to update the IP on OLED each 10s.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [   11.563112] platform 78000000.r5f: configured R5F for remoteproc mode
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [   11.595913] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [   11.633801] remoteproc remoteproc0: 78000000.r5f is available
             Starting Docker Socket for the API...
    [   11.661889] remoteproc remoteproc0: powering up 78000000.r5f
    [   11.666384] davinci_mdio 300b2400.mdio: Configuring MDIO in manual mode
    [   11.670101] remoteproc remoteproc0: Booting fw image am64-main-r5f0_0-fw, size 86352
    [   11.697674] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@a0000000
    [   11.712726] platform 78200000.r5f: configured R5F for remoteproc mode
    [   11.732983] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   11.738582] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   11.739599] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [   11.746380] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [   11.760867] remoteproc remoteproc0: remote processor 78000000.r5f is now up
    [   11.771222] davinci_mdio 300b2400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [  OK  ] Listening on PC/SC Smart Card Daemo[   11.794361] remoteproc remoteproc1: 78200000.r5f is available
    n Activation Socket.
    [   11.821939] davinci_mdio 300b2400.mdio: phy[15]: device 300b2400.mdio:0f, driver TI DP83869
    [   11.832104] audit: type=1334 audit(1709054772.408:9): prog-id=13 op=LOAD
    [   11.846238] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [   11.921417] remoteproc remoteproc1: powering up 78200000.r5f
    [   11.927226] remoteproc remoteproc1: Booting fw image am64-main-r5f0_1-fw, size 141772
    [  OK  ] Listening on Docker Socket for the API.
    [   11.950527] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@a1000000
    [   11.975429] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   11.976196] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [  OK  ] Reached target Socket Units.
    [   12.007191] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [   12.031639] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [   12.042032] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [   12.053763] remoteproc remoteproc2: 5000000.m4fss is available
    [   12.054930] remoteproc remoteproc1: remote processor 78200000.r5f is now up
    [   12.086962] platform 78400000.r5f: configured R5F for remoteproc mode
    [   12.098631] remoteproc remoteproc2: powering up 5000000.m4fss
    [   12.107102] remoteproc remoteproc2: Booting fw image am64-mcu-m4f0_0-fw, size 88248
    [   12.128593] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node m4f-dma-memory@a4000000
    [   12.128986] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   12.144861] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   12.146029] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [   12.153378] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
    [   12.159055] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   12.172134] remoteproc remoteproc2: remote processor 5000000.m4fss is now up
    [   12.217429] remoteproc remoteproc3: 78400000.r5f is available
    [   12.250732] remoteproc remoteproc3: powering up 78400000.r5f
    [   12.256840] remoteproc remoteproc3: Booting fw image am64-main-r5f1_0-fw, size 93260
    [   12.270389] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@a2000000
    [   12.283066] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   12.288824] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   12.299787] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
    [   12.306901] remoteproc remoteproc3: remote processor 78400000.r5f is now up
    [   12.317046] platform 78600000.r5f: configured R5F for remoteproc mode
    [  OK  ] Started D-Bus System Message Bus.
    [   12.389335] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   12.408427] remoteproc remoteproc4: 78600000.r5f is available
    [   12.409254] m_can_platform 20701000.can: m_can device registered (irq=528, version=32)
    [   12.420271] remoteproc remoteproc4: powering up 78600000.r5f
    [   12.428074] remoteproc remoteproc4: Booting fw image am64-main-r5f1_1-fw, size 91520
    [  OK  ] Reached target Basic System.
    [   12.438849] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node r5f-dma-memory@a3000000
    [   12.485367] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   12.491187] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [   12.492032] m_can_platform 20711000.can: m_can device registered (irq=529, version=32)
    [   12.503118] rproc-virtio rproc-virtio.4.auto: registered virtio4 (type 7)
    [   12.516571] remoteproc remoteproc4: remote processor 78600000.r5f is now up
    [   12.540156] dbus-broker-lau[435]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [  OK  ] Started Job spooling tools.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Expand the rootfs partiti…to full size of the boot device....
    [   12.804810] audit: type=1334 audit(1709054773.388:10): prog-id=14 op=LOAD
             Starting User Login Management...
    [   12.821304] audit: type=1334 audit(1709054773.392:11): prog-id=15 op=LOAD
    [   12.841331] audit: type=1334 audit(1709054773.392:12): prog-id=16 op=LOAD
             Starting Telnet Server...
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Reached target Preparation for Network.
    [   12.941285] audit: type=1334 audit(1709054773.528:13): prog-id=17 op=LOAD
    [   12.955325] gpio-mux mux-controller: 2-way mux-controller registered
             Starting Network Configuration...
    [  OK  ] Finished Telnet Server.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [   13.177403] remoteproc remoteproc5: 3000a000.txpru is available
    [   13.319284] remoteproc remoteproc6: 3000c000.txpru is available
    [  OK  ] Started Telephony service.
    [  OK  ] Created slice Slice /system/systemd-fsck.
             Expecting device /dev/mmcblk0p1   13.446291] remoteproc remoteproc7: 3008a000.txpru is available
    0m...
    [   13.551871] remoteproc remoteproc8: 3008c000.txpru is available
    [  OK  ] Found device /dev/mmcblk0p1.
    [  OK  ] Started User Login Management.
             Starting File System Check on /dev/mmcblk0p1...
    [   14.331995] m_can_platform 20701000.can main_mcan0: renamed from can0
    [   14.374648] m_can_platform 20711000.can main_mcan1: renamed from can1
    [   14.468317] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   14.486563] remoteproc remoteproc9: 30034000.pru is available
    [   14.510714] remoteproc remoteproc10: 30004000.rtu is available
    [   14.522178] Bluetooth: Core ver 2.22
    [   14.522722] remoteproc remoteproc11: 30038000.pru is available
    [   14.528010] NET: Registered PF_BLUETOOTH protocol family
    [   14.537188] Bluetooth: HCI device and connection manager initialized
    [   14.544888] Bluetooth: HCI socket layer initialized
    [   14.546900] remoteproc remoteproc12: 30006000.rtu is available
    [   14.549989] Bluetooth: L2CAP socket layer initialized
    [   14.561062] Bluetooth: SCO socket layer initialized
    [   14.586195] remoteproc remoteproc13: 300b8000.pru is available
             Starting Virtual Console Setup...
    [   14.617371] remoteproc remoteproc14: 30086000.rtu is available
    [   14.625640] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   14.636396] remoteproc remoteproc15: 300b4000.pru is available
    [   14.646307] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   14.658661] remoteproc remoteproc16: 30084000.rtu is available
    [   14.713473] TI DP83869 300b2400.mdio:0f: attached PHY driver (mii_bus:phy_addr=300b2400.mdio:0f, irq=POLL)
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [   14.731704] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: single EMAC mode
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Wait for Network to be Configured...
             Starting Permit User Sessions...
    [   15.382058] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   15.417708] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   15.485032] am65-cpsw-nuss 8000000.ethernet eth1: PHY [mdio_mux-0.1:03] driver [TI DP83869] (irq=POLL)
    [   15.496472] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Finished Permit User Sessions.
    [   15.932265] EXT4-fs (mmcblk0p1): mounted filesystem 494c54de-3900-468f-8a1c-66d0ddc33e66 r/w with ordered data mode. Quota mode: none.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Mounted /run/media/mmcblk0p1.
             Expecting device /dev/mmcblk1p1...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [   16.290940] remoteproc remoteproc15: powering up 300b4000.pru
    [   16.323972] remoteproc remoteproc15: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 39464
    [   16.335273] remoteproc remoteproc15: unsupported resource 5
    [   16.356872] remoteproc remoteproc15: remote processor 300b4000.pru is now up
    [   16.368983] remoteproc remoteproc16: powering up 30084000.rtu
    [   16.390698] remoteproc remoteproc16: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 31140
    [   16.400538] remoteproc remoteproc16: remote processor 30084000.rtu is now up
    [   16.408084] remoteproc remoteproc7: powering up 3008a000.txpru
    [   16.443256] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 39068
    [   16.453406] remoteproc remoteproc7: remote processor 3008a000.txpru is now up
    [   16.468801] pps pps1: new PPS source ptp2
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/boot-mmcblk1p1...
    [   17.041954] EXT4-fs (mmcblk1p2): resizing filesystem from 2436965 to 3856512 blocks
    [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [   18.867350] EXT4-fs (mmcblk1p2): resized filesystem to 3856512
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Started containerd container runtime.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am64xx-evm ttyS2
    Arago 2023.10 am64xx-evm ttyS2
    am64xx-evm login: ***************************************************************
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts-examples
            libqt5charts-plugins
            libqt5charts-qmlplugins
            libqt5charts5
            libqt5serialport-examples
            libqt5serialport-plugins
            libqt5serialport-qmlplugins
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg-qmlplugins
            libqt5svg5
            libqt5virtualkeyboard-plugins
            libqt5virtualkeyboard-qmlplugins
            libqt5virtualkeyboard5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring5
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity-plugins
            qtconnectivity-qmlplugins
            qtconnectivity
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-tools
            qtdeclarative
            qtgraphicaleffects-qmlplugins
            qtlocation-examples
            qtlocation-plugins
            qtlocation-qmlplugins
            qtlocation
            qtmultimedia-examples
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquics-qmlplugins.control
            qtquics2-plugins.control
            qtquics2-qmlplugins.control
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    am64xx-evm login: root
    [   26.158738] audit: type=1006 audit(1709054786.748:14): pid=991 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   26.171295] audit: type=1300 audit(1709054786.748:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffe0b5aa78 a2=1 a3=1 items=0 ppid=1 pid=991 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   26.199449] audit: type=1327 audit(1709054786.748:14): proctitle="(systemd)"
    [   26.238408] audit: type=1334 audit(1709054786.828:15): prog-id=18 op=LOAD
    [   26.246387] audit: type=1300 audit(1709054786.828:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe9eb34d8 a2=90 a3=0 items=0 ppid=1 pid=991 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   26.273251] audit: type=1327 audit(1709054786.828:15): proctitle="(systemd)"
    [   26.280901] audit: type=1334 audit(1709054786.828:16): prog-id=18 op=UNLOAD
    [   26.289326] audit: type=1300 audit(1709054786.828:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffa8a09c60 items=0 ppid=1 pid=991 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   26.315412] audit: type=1327 audit(1709054786.828:16): proctitle="(systemd)"
    [   26.323326] audit: type=1334 audit(1709054786.828:17): prog-id=19 op=LOAD
    root@am64xx-evm:~# ifconfig
    eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether 34:08:e1:80:b7:b3  txqueuelen 1000  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 0  bytes 0 (0.0 B)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether 70:ff:76:1e:e8:d0  txqueuelen 1000  (Ethernet)
    eth2: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether 70:ff:76:1e:e8:d1  txqueuelen 1000  (Ethernet)
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 10  bytes 1594 (1.5 KiB)
            TX packets 10  bytes 1594 (1.5 KiB)
    root@am64xx-evm:~#
    root@am64xx-evm:~# reboot
    root@am64xx-evm:~#          Stopping Session c1 of User root...
    [  OK  ] Removed slice Slice /system/modprobe.
    [  OK  ] Stopped target Login Prompts.
    [  OK  ] Stopped target Host and Network Name Lookups.
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target Timer Units.
    [  OK  ] Stopped Daily rotation of log files.
    [  OK  ] Stopped Daily Cleanup of Temporary Directories.
    [  OK  ] Stopped target System Time Set.
    [  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Stopping Job spooling tools...
             Stopping Avahi mDNS/DNS-SD Stack...
             Stopping containerd container runtime...
             Stopping Periodic Command Scheduler...
             Stopping Getty on tty1...
             Stopping irqbalance daemon...
             Stopping Reboot and dump vmcore via kexec...
             Stopping Netperf Benchmark Server...
             Stopping Telephony service...
    [  OK  ] Stopped Timer service to update the IP on OLED each 10s.
    [  OK  ] Stopped Expand the rootfs partition to full size of the boot device..
             Stopping Serial Getty on ttyS2...
             Stopping Simple Network Management Protocol (SNMP) Daemon....
             Stopping Load/Save OS Random Seed...
             Starting Record Runlevel Change in UTMP...
             Stopping Telnet Server...
    [  OK  ] Stopped Job spooling tools.
    [  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
    [  OK  ] Stopped Periodic Command Scheduler.
    [  OK  ] Stopped irqbalance daemon.
    [  OK  ] Stopped Telephony service.
    [  OK  ] Stopped Netperf Benchmark Server.
    [  OK  ] Stopped Wait for Network to be Configured.
    [  OK  ] Stopped containerd container runtime.
    [  OK  ] Stopped Getty on tty1.
    [  OK  ] Stopped Serial Getty on ttyS2.
    [  OK  ] Stopped Reboot and dump vmcore via kexec.
    [  OK  ] Stopped Telnet Server.
    [  OK  ] Stopped Load/Save OS Random Seed.
    [  OK  ] Stopped Session c1 of User root.
    [  OK  ] Stopped Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Finished Record Runlevel Change in UTMP.
    [  OK  ] Removed slice Slice /system/getty.
    [  OK  ] Removed slice Slice /system/serial-getty.
             Stopping User Login Management...
             Stopping Permit User Sessions...
             Stopping User Manager for UID 0...
    [  OK  ] Stopped User Login Management.
    [  OK  ] Stopped User Manager for UID 0.
    [  OK  ] Stopped Permit User Sessions.
    [   33.168292] kauditd_printk_skb: 5 callbacks suppressed
    [   33.168321] audit: type=1334 audit(1709054793.756:19): prog-id=14 op=UNLOAD
    [  OK  ] Stopped target Network.
    [  OK  ] Stopped target Remote File Systems.
             Stopping Network Configuration...
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Stopped Network Configuration.
    [   33.284374] audit: type=1334 audit(1709054793.872:20): prog-id=17 op=UNLOAD
    [  OK  ] Unmounted /run/user/0.
    [  OK  ] Stopped target Preparation for Network.
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
    [  OK  ] Stopped Generate network units from Kernel command line.
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [  OK  ] Removed slice User Slice of UID 0.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Path Units.
    [  OK  ] Stopped Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Stopped Forward Password Requests to Wall Directory Watch.
    [  OK  ] Stopped target Slice Units.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Socket Units.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Closed PC/SC Smart Card Daemon Activation Socket.
    [  OK  ] Closed Network Service Netlink Socket.
             Stopping D-Bus System Message Bus...
    [  OK  ] Stopped D-Bus System Message Bus.
    [   33.709296] audit: type=1334 audit(1709054794.296:21): prog-id=13 op=UNLOAD
    [  OK  ] Closed D-Bus System Message Bus Socket.
    [  OK  ] Stopped target System Initialization.
             Stopping Network Name Resolution...
             Stopping Network Time Synchronization...
    [  OK  ] Stopped Update is Completed.
    [  OK  ] Stopped Rebuild Dynamic Linker Cache.
    [  OK  ] Stopped Rebuild Journal Catalog.
    [  OK  ] Stopped Network Name Resolution.
    [  OK  ] Stopped Network Time Synchronization.
    [   33.893680] audit: type=1334 audit(1709054794.484:22): prog-id=11 op=UNLOAD
    [   33.900866] audit: type=1334 audit(1709054794.488:23): prog-id=12 op=UNLOAD
    [  OK  ] Stopped Apply Kernel Variables.
    [  OK  ] Closed Process Core Dump Socket.
    [  OK  ] Stopped Load Kernel Modules.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting /run/media/boot-mmcblk1p1...
             Unmounting /run/media/mmcblk0p1...
             Unmounting Temporary Directory /tmp...
    [   34.067258] EXT4-fs (mmcblk0p1): unmounting filesystem 494c54de-3900-468f-8a1c-66d0ddc33e66.
             Unmounting /var/volatile...
    [  OK  ] Unmounted /run/media/boot-mmcblk1p1.
    [  OK  ] Unmounted /run/media/mmcblk0p1.
    [  OK  ] Unmounted Temporary Directory /tmp.
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Swaps.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p1.
    [  OK  ] Stopped File System Check on /dev/mmcblk1p1.
    [  OK  ] Removed slice Slice /system/systemd-fsck.
    [  OK  ] Stopped target Preparation for Local File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Stopped Create System Users.
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev gracefully.
    [  OK  ] Reached target System Shutdown.
    [  OK  ] Reached target Late Shutdown Services.
    [  OK  ] Finished System Reboot.
    [  OK  ] Reached target System Reboot.
    [   34.443847] audit: type=1334 audit(1709054795.032:24): prog-id=16 op=UNLOAD
    [   34.451621] audit: type=1334 audit(1709054795.032:25): prog-id=15 op=UNLOAD
    [   34.475095] audit: type=1334 audit(1709054795.064:26): prog-id=8 op=UNLOAD
    [   34.483257] audit: type=1334 audit(1709054795.064:27): prog-id=7 op=UNLOAD
    [   34.493841] audit: type=1334 audit(1709054795.064:28): prog-id=6 op=UNLOAD
    [   34.518931] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   34.525916] watchdog: watchdog0: watchdog did not stop!
    [   34.556557] systemd-shutdown[1]: Using hardware watchdog 'K3 RTI Watchdog', version 0, device /dev/watchdog0
    [   34.566904] systemd-shutdown[1]: Modifying watchdog timeout is not supported, reusing the programmed timeout.
    [   34.577092] systemd-shutdown[1]: Watchdog running with a timeout of 1min.
    [   34.637781] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   34.664936] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   34.703017] systemd-journald[104]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   34.722406] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   34.749604] systemd-shutdown[1]: Unmounting file systems.
    [   34.758911] (sd-remount)[1074]: Remounting '/' read-only with options ''.
    [   34.810370] EXT4-fs (mmcblk1p2): re-mounted 27d406a0-8181-44e9-8e68-07b1dee77e6c ro. Quota mode: none.
    [   34.832320] systemd-shutdown[1]: All filesystems unmounted.
    [   34.837963] systemd-shutdown[1]: Deactivating swaps.
    [   34.843179] systemd-shutdown[1]: All swaps deactivated.
    [   34.848427] systemd-shutdown[1]: Detaching loop devices.
    [   34.860615] systemd-shutdown[1]: All loop devices detached.
    [   34.866403] systemd-shutdown[1]: Stopping MD devices.
    [   34.872062] systemd-shutdown[1]: All MD devices stopped.
    [   34.877409] systemd-shutdown[1]: Detaching DM devices.
    [   34.882976] systemd-shutdown[1]: All DM devices detached.
    [   34.888402] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [   34.898083] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   34.904983] systemd-shutdown[1]: Failed to disable hardware watchdog, ignoring: Device or resource busy
    [   34.914383] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   34.921260] watchdog: watchdog0: watchdog did not stop!
    [   34.936518] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   34.943633] systemd-shutdown[1]: Rebooting.
    [   34.984665] reboot: Restarting system
    I/TC:
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    20285952 bytes read in 838 ms (23.1 MiB/s)
    Starting kernel ...
    [    0.008648] Console: colour dummy device 80x25
    [    0.013259] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023940] pid_max: default: 32768 minimum: 301
    [    0.028766] LSM: initializing lsm=capability,integrity
    [    0.034157] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041739] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051872] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.059227] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.067222] rcu: Hierarchical SRCU implementation.
    [    0.072132] rcu:     Max phase no-delay instances is 1000.
    [    0.077791] Platform MSI: msi-controller@1820000 domain created
    [    0.084197] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.093753] EFI services will not be available.
    [    0.098759] smp: Bringing up secondary CPUs ...
    [    0.112425] Detected VIPT I-cache on CPU1
    [    0.112532] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.112552] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
    [    0.112613] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.112760] smp: Brought up 1 node, 2 CPUs
    [    0.142146] SMP: Total of 2 processors activated.
    [    0.146958] CPU features: detected: 32-bit EL0 Support
    [    0.152228] CPU features: detected: CRC32 instructions
    [    0.157551] CPU: All CPU(s) started at EL2
    [    0.161738] alternatives: applying system-wide alternatives
    [    0.169440] devtmpfs: initialized
    [    0.183549] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.193547] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.201951] pinctrl core: initialized pinctrl subsystem
    [    0.207976] DMI not present or invalid.
    [    0.212747] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.219964] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.227405] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.235512] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.243736] audit: initializing netlink subsys (disabled)
    [    0.249577] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
    [    0.250168] thermal_sys: Registered thermal governor 'step_wise'
    [    0.257527] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.263940] cpuidle: using governor menu
    [    0.274879] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.281889] ASID allocator initialised with 65536 entries
    [    0.300767] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f4000/pinctrl@a40000/cpsw-cpts-pps
    [    0.316033] Modules: 27680 pages in range for non-PLT usage
    [    0.316056] Modules: 519200 pages in range for PLT usage
    [    0.322836] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.335227] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.341634] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.348570] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.354975] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.361909] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.368313] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.375247] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.383573] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
    [    0.393330] iommu: Default domain type: Translated
    [    0.398286] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.404998] SCSI subsystem initialized
    [    0.409387] usbcore: registered new interface driver usbfs
    [    0.415050] usbcore: registered new interface driver hub
    [    0.420527] usbcore: registered new device driver usb
    [    0.426371] pps_core: LinuxPPS API ver. 1 registered
    [    0.431459] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.449136] scmi_core: SCMI protocol bus registered
    [    0.454655] FPGA manager framework
    [    0.458308] Advanced Linux Sound Architecture Driver Initialized.
    [    0.465813] vgaarb: loaded
    [    0.469130] clocksource: Switched to clocksource arch_sys_counter
    [    0.475695] VFS: Disk quotas dquot_6.6.0
    [    0.479753] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.494740] NET: Registered PF_INET protocol family
    [    0.500070] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.509829] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.518611] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.526545] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.534768] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.542810] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.549761] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.556719] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.564254] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.570727] RPC: Registered named UNIX socket transport module.
    [    0.576837] RPC: Registered udp transport module.
    [    0.581645] RPC: Registered tcp transport module.
    [    0.586453] RPC: Registered tcp-with-tls transport module.
    [    0.592059] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.598652] NET: Registered PF_XDP protocol family
    [    0.603572] PCI: CLS 0 bytes, default 64
    [    0.609096] Initialise system trusted keyrings
    [    0.614042] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.621098] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.627553] NFS: Registering the id_resolver key type
    [    0.632798] Key type id_resolver registered
    [    0.637077] Key type id_legacy registered
    [    0.641199] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.648053] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.696228] Key type asymmetric registered
    [    0.700434] Asymmetric key parser 'x509' registered
    [    0.705507] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.713073] io scheduler mq-deadline registered
    [    0.717727] io scheduler kyber registered
    [    0.721878] io scheduler bfq registered
    [    0.729419] pinctrl-single 4084000.pinctrl: 33 pins, size 132
    [    0.735884] pinctrl-single f4000.pinctrl: 180 pins, size 720
    [    0.743709] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.757701] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.777299] loop: module loaded
    [    0.782015] megasas: 07.725.01.00-rc1
    [    0.790733] tun: Universal TUN/TAP device driver, 1.6
    [    0.797488] VFIO - User Level meta-driver version: 0.3
    [    0.804205] usbcore: registered new interface driver usb-storage
    [    0.811122] i2c_dev: i2c /dev entries driver
    [    0.816910] sdhci: Secure Digital Host Controller Interface driver
    [    0.823283] sdhci: Copyright(c) Pierre Ossman
    [    0.828035] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.834709] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.841333] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.848851] usbcore: registered new interface driver usbhid
    [    0.854566] usbhid: USB HID core driver
    [    0.858918] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.865896] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.872776] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.881481] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.890707] optee: probing for conduit method.
    [    0.895313] optee: revision 4.2 (12d7c4ee)
    [    0.911989] optee: dynamic shared memory is enabled
    [    0.922210] random: crng init done
    [    0.925881] optee: initialized driver
    [    0.932381] NET: Registered PF_PACKET protocol family
    [    0.937716] Key type dns_resolver registered
    [    0.951578] registered taskstats version 1
    [    0.955999] Loading compiled-in X.509 certificates
    [    0.977192] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    [    1.129349] pca953x 0-0038: supply vcc not found, using dummy regulator
    [    1.136315] pca953x 0-0038: using no AI
    [    1.161951] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.169750] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.176729] pca953x 1-0022: using AI
    [    1.202455] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.208720] ti-sci-intr bus@f4000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.218130] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.230532] ti-udma 485c0100.dma-controller: Number of rings: 68
    [    1.238532] ti-udma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    1.248851] ti-udma 485c0000.dma-controller: Number of rings: 288
    [    1.266670] ti-udma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
    [    1.278110] printk: console [ttyS2] disabled
    [    1.283189] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 317, base_baud = 3000000) is a 8250
    [    1.292132] printk: console [ttyS2] enabled
    [    1.300598] printk: bootconsole [ns16550a0] disabled
    [    1.318211] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.323341] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.330309] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.335706] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    1.342706] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    1.349525] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    1.356299] 0x000000700000-0x000000740000 : "ospi.env"
    [    1.362887] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    1.370107] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.376936] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.393482] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.437140] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.447420] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.455602] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
    [    1.468503] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    1.475637] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.482370] pps pps0: new PPS source ptp0
    [    1.486826] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.504534] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    1.517769] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.528973] mmc0: CQHCI version 5.10
    [    1.542117] j721e-pcie f102000.pcie: host bridge /bus@f4000/pcie@f102000 ranges:
    [    1.549646] j721e-pcie f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
    [    1.557910] j721e-pcie f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
    [    1.566017] j721e-pcie f102000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x0000000000
    [    1.571823] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.665716] mmc0: Command Queue Engine enabled
    [    1.670235] mmc0: new HS200 MMC card at address 0001
    [    1.676087] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.685184]  mmcblk0: p1
    [    1.688484] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.694819] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.700967] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
    [    2.573694] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
    [    2.580065] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.585557] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
    [    2.595028] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
    [    2.601937] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
    [    2.607956] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xfffffffff 64bit pref]
    [    2.615339] pci 0000:00:00.0: supports D1
    [    2.619350] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.627745] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.636004] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.642696] pci 0000:00:00.0: BAR 0: no space for [mem size 0x1000000000 64bit pref]
    [    2.650440] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x1000000000 64bit pref]
    [    2.658527] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.663690] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    2.670730] pcieport 0000:00:00.0: PME: Signaling with IRQ 520
    [    2.676988] pcieport 0000:00:00.0: AER: enabled with IRQ 520
    [    2.685408] mmc1: CQHCI version 5.10
    [    2.688085] clk: Disabling unused clocks
    [    2.721158] ALSA device list:
    [    2.724144]   No soundcards found.
    [    2.727736] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.736236] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.793609] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    2.801064] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
    [    2.811318]  mmcblk1: p1 p2
    [    3.100055] EXT4-fs (mmcblk1p2): mounted filesystem 27d406a0-8181-44e9-8e68-07b1dee77e6c r/w with ordered data mode. Quota mode: none.
    [    3.112314] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.121698] devtmpfs: mounted
    [    3.126306] Freeing unused kernel memory: 2432K
    [    3.130949] Run /sbin/init as init process
    [    3.459234] systemd[1]: System time before build time, advancing clock.
    [    3.528517] NET: Registered PF_INET6 protocol family
    [    3.534962] Segment Routing with IPv6
    [    3.538776] In-situ OAM (IOAM) with IPv6
    [    3.591584] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    3.623469] systemd[1]: Detected architecture arm64.
    [    3.659855] systemd[1]: Hostname set to <am64xx-evm>.
    [    4.139435] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.309876] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.423411] systemd[1]: Queued start job for default target Graphical Interface.
    [    4.465583] systemd[1]: Created slice Slice /system/getty.
    [    4.492414] systemd[1]: Created slice Slice /system/modprobe.
    [    4.516409] systemd[1]: Created slice Slice /system/serial-getty.
    [    4.539686] systemd[1]: Created slice User and Session Slice.
    [    4.561886] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.585845] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.609563] systemd[1]: Expecting device /dev/ttyS2...
    [    4.629613] systemd[1]: Reached target Path Units.
    [    4.649475] systemd[1]: Reached target Remote File Systems.
    [    4.669441] systemd[1]: Reached target Slice Units.
    [    4.689501] systemd[1]: Reached target Swaps.
    [    4.751607] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.777589] systemd[1]: Reached target RPC Port Mapper.
    [    4.809733] systemd[1]: Listening on Process Core Dump Socket.
    [    4.833976] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.859258] systemd[1]: Listening on Journal Audit Socket.
    [    4.882349] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.906463] systemd[1]: Listening on Journal Socket.
    [    4.930701] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.960737] systemd[1]: Listening on udev Control Socket.
    [    4.982272] systemd[1]: Listening on udev Kernel Socket.
    [    5.006398] systemd[1]: Listening on User Database Manager Socket.
    [    5.053795] systemd[1]: Mounting Huge Pages File System...
    [    5.095025] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.108169] systemd[1]: Mounting Kernel Debug File System...
    [    5.122493] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    5.156012] systemd[1]: Mounting Temporary Directory /tmp...
    [    5.206374] systemd[1]: Starting Create List of Static Device Nodes...
    [    5.238649] systemd[1]: Starting Load Kernel Module configfs...
    [    5.286245] systemd[1]: Starting Load Kernel Module drm...
    [    5.319337] systemd[1]: Starting Load Kernel Module fuse...
    [    5.373879] systemd[1]: Starting RPC Bind...
    [    5.390839] fuse: init (API version 7.39)
    [    5.396617] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    5.438371] systemd[1]: Starting Journal Service...
    [    5.486553] systemd[1]: Starting Load Kernel Modules...
    [    5.542529] systemd[1]: Starting Generate network units from Kernel command line...
    [    5.590703] cryptodev: loading out-of-tree module taints kernel.
    [    5.609808] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.617241] cryptodev: driver 1.13 loaded.
             Starting Remount Root and Kernel File Systems systemd-journald[105]: Collecting audit messages is enabled.
    [0m...
    [    5.662177] systemd[1]: Starting Coldplug All udev Devices...
    [    5.709323] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    5.734869] systemd[1]: Mounted Huge Pages File System.
    [    5.769262] EXT4-fs (mmcblk1p2): re-mounted 27d406a0-8181-44e9-8e68-07b1dee77e6c r/w. Quota mode: none.
    [    5.771865] systemd[1]: Mounted POSIX Message Queue File System.
    [    5.816905] systemd[1]: Started Journal Service.
             Starting Create Static Device Nodes in /dev gr[    6.241995] systemd-journald[105]: Received client request to flush runtime journal.
    acefully...
    [    6.721187] audit: type=1334 audit(1709054767.256:2): prog-id=6 op=LOAD
    [    6.736715] audit: type=1334 audit(1709054767.272:3): prog-id=7 op=LOAD
    [    7.092556] audit: type=1334 audit(1709054767.628:4): prog-id=8 op=LOAD
    [    7.135545] audit: type=1334 audit(1709054767.672:5): prog-id=9 op=LOAD
    [    7.223384] audit: type=1334 audit(1709054767.760:6): prog-id=10 op=LOAD
    [    7.238610] audit: type=1334 audit(1709054767.768:7): prog-id=11 op=LOAD
    [    7.248602] audit: type=1334 audit(1709054767.768:8): prog-id=12 op=LOAD
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [    8.428627] audit: type=1334 audit(1709054768.964:9): prog-id=13 op=LOAD
    [    9.000260] dbus-broker-lau[257]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [    9.433255] audit: type=1334 audit(1709054769.968:10): prog-id=14 op=LOAD
    [    9.449685] audit: type=1334 audit(1709054769.980:11): prog-id=15 op=LOAD
    [   10.317494] Bluetooth: Core ver 2.22
    [   10.321392] NET: Registered PF_BLUETOOTH protocol family
    [   10.333279] Bluetooth: HCI device and connection manager initialized
    [   10.345242] Bluetooth: HCI socket layer initialized
    [   10.354470] Bluetooth: L2CAP socket layer initialized
    [   10.365346] Bluetooth: SCO socket layer initialized
    [   11.254558] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.288638] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   11.296012] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   11.623469] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   11.643598] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   11.768800] at24 0-0050: supply vcc not found, using dummy regulator
    [   11.784916] CAN device driver interface
    [   11.795363] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    [   12.783514] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
    [   12.837570] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [   12.838857] davinci_mdio 300b2400.mdio: Configuring MDIO in manual mode
    [   12.887377] platform 78000000.r5f: configured R5F for remoteproc mode
    [   12.907440] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   12.921659] remoteproc remoteproc1: 78000000.r5f is available
    [   12.923091] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [   12.936250] davinci_mdio 300b2400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [   12.977053] remoteproc remoteproc1: powering up 78000000.r5f
    [   12.992920] remoteproc remoteproc0: 5000000.m4fss is available
    [   12.995773] remoteproc remoteproc1: Booting fw image am64-main-r5f0_0-fw, size 86352
    [   13.021561] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@a0000000
    [   13.028758] remoteproc remoteproc0: powering up 5000000.m4fss
    [   13.034415] davinci_mdio 300b2400.mdio: phy[15]: device 300b2400.mdio:0f, driver TI DP83869
    [   13.040172] remoteproc remoteproc0: Booting fw image am64-mcu-m4f0_0-fw, size 88248
    [   13.045695] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   13.052630] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   13.067307] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [   13.076683] platform 78200000.r5f: configured R5F for remoteproc mode
    [   13.086260] remoteproc remoteproc1: remote processor 78000000.r5f is now up
    [   13.094913] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node m4f-dma-memory@a4000000
    [   13.105348] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   13.111056] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [   13.118948] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [   13.126517] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [   13.133501] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
    [   13.141506] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
             Expecting device /dev/mmcblk0p1   13.209336] remoteproc remoteproc2: 78200000.r5f is available
    0m...
    [   13.269352] remoteproc remoteproc2: powering up 78200000.r5f
    [   13.277282] remoteproc remoteproc2: Booting fw image am64-main-r5f0_1-fw, size 141772
    [   13.294271] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@a1000000
    [   13.311681] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   13.311872] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   13.326636] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
    [   13.339400] remoteproc remoteproc2: remote processor 78200000.r5f is now up
    [   13.342702] gpio-mux mux-controller: 2-way mux-controller registered
    [   13.381517] m_can_platform 20701000.can: m_can device registered (irq=528, version=32)
    [   13.402949] m_can_platform 20711000.can: m_can device registered (irq=529, version=32)
    [   13.447398] platform 78400000.r5f: configured R5F for remoteproc mode
    [   13.509730] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   13.527306] remoteproc remoteproc3: 78400000.r5f is available
    [   13.554577] remoteproc remoteproc3: powering up 78400000.r5f
    [   13.560795] remoteproc remoteproc3: Booting fw image am64-main-r5f1_0-fw, size 93260
    [   13.664797] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@a2000000
    [   13.676199] platform 78600000.r5f: configured R5F for remoteproc mode
    [   13.684514] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   13.690309] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   13.697985] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
    [   13.704951] remoteproc remoteproc3: remote processor 78400000.r5f is now up
    [   13.743186] remoteproc remoteproc5: 3000a000.txpru is available
    [   13.760413] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   13.772986] remoteproc remoteproc4: 78600000.r5f is available
    [   13.783986] remoteproc remoteproc6: 3000c000.txpru is available
    [   13.790335] remoteproc remoteproc4: powering up 78600000.r5f
    [   13.796282] remoteproc remoteproc4: Booting fw image am64-main-r5f1_1-fw, size 91520
    [   13.807745] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node r5f-dma-memory@a3000000
    [   13.822277] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   13.827968] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [   13.837520] rproc-virtio rproc-virtio.4.auto: registered virtio4 (type 7)
    [   13.846714] remoteproc remoteproc4: remote processor 78600000.r5f is now up
    [   13.859259] remoteproc remoteproc7: 3008a000.txpru is available
    [   13.931943] remoteproc remoteproc8: 3008c000.txpru is available
    [  OK  ] Listening on Load/Save RF Kill Swit[   14.430672] remoteproc remoteproc9: 300b8000.pru is available
    [   14.441613] remoteproc remoteproc10: 30086000.rtu is available
    [   14.451058] remoteproc remoteproc11: 300b4000.pru is available
    [   14.459676] remoteproc remoteproc12: 30084000.rtu is available
    [   14.467295] remoteproc remoteproc13: 30034000.pru is available
    [   14.475642] remoteproc remoteproc14: 30038000.pru is available
    [   14.484058] remoteproc remoteproc15: 30006000.rtu is available
    [   14.492459] remoteproc remoteproc16: 30004000.rtu is available
    [  OK  ] Finished File System Check on /dev/[   14.767605] TI DP83869 300b2400.mdio:0f: attached PHY driver (mii_bus:phy_addr=300b2400.mdio:0f, irq=POLL)
    mmcblk0p1.
    [   14.784926] m_can_platform 20711000.can main_mcan1: renamed from can1
    [   14.857778] m_can_platform 20701000.can main_mcan0: renamed from can0
    [   14.951045] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: single EMAC mode
    [   15.274773] EXT4-fs (mmcblk0p1): mounted filesystem 494c54de-3900-468f-8a1c-66d0ddc33e66 r/w with ordered data mode. Quota mode: none.
    [   15.814776] remoteproc remoteproc11: powering up 300b4000.pru
    [   15.832327] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 39464
    [   15.844740] remoteproc remoteproc11: unsupported resource 5
    [   15.851297] remoteproc remoteproc11: remote processor 300b4000.pru is now up
    [   15.884889] remoteproc remoteproc12: powering up 30084000.rtu
    [   15.907870] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 31140
    [   15.918451] remoteproc remoteproc12: remote processor 30084000.rtu is now up
    [   15.931452] remoteproc remoteproc7: powering up 3008a000.txpru
             Starting File System Check on /dev/mmcblk1p1   15.945600] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 39068
    0m...
    [   15.979566] remoteproc remoteproc7: remote processor 3008a000.txpru is now up
    [   16.009305] pps pps1: new PPS source ptp2
     _____                    _____           _         _
                  |___|                    |___|
    am64xx-evm login: ro***************************************************************
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts5
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring5
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity
            qtdeclarative-tools
            qtdeclarative
            qtlocation-examples
            qtlocation-plugins
            qtlocation
            qtmultimedia
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland
            tar
            which
    ot
    [   20.097096] kauditd_printk_skb: 2 callbacks suppressed
    [   20.102405] audit: type=1006 audit(1709054780.632:14): pid=975 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   20.116285] audit: type=1300 audit(1709054780.632:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff906cc98 a2=1 a3=1 items=0 ppid=1 pid=975 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   20.142930] audit: type=1327 audit(1709054780.632:14): proctitle="(systemd)"
    [   20.178426] audit: type=1334 audit(1709054780.716:15): prog-id=18 op=LOAD
    [   20.186069] audit: type=1300 audit(1709054780.716:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffffcac9818 a2=90 a3=0 items=0 ppid=1 pid=975 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   20.212010] audit: type=1327 audit(1709054780.716:15): proctitle="(systemd)"
    [   20.219181] audit: type=1334 audit(1709054780.720:16): prog-id=18 op=UNLOAD
    [   20.226685] audit: type=1300 audit(1709054780.720:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffaf437c60 items=0 ppid=1 pid=975 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   20.252963] audit: type=1327 audit(1709054780.720:16): proctitle="(systemd)"
    [   20.260827] audit: type=1334 audit(1709054780.720:17): prog-id=19 op=LOAD
    root@am64xx-evm:~#
            RX packets 20  bytes 2306 (2.2 KiB)
            TX packets 20  bytes 2306 (2.2 KiB)
    [   30.398560] kauditd_printk_skb: 5 callbacks suppressed
    [   30.398579] audit: type=1334 audit(1709054790.936:19): prog-id=14 op=UNLOAD
    [   30.573810] audit: type=1334 audit(1709054791.112:20): prog-id=17 op=UNLOAD
    [   30.960591] audit: type=1334 audit(1709054791.496:21): prog-id=13 op=UNLOAD
             Stopping Record System Boot/Shutdown in UTMP...
    [   31.149106] audit: type=1334 audit(1709054791.684:22): prog-id=8 op=UNLOAD
    [   31.156590] audit: type=1334 audit(1709054791.688:23): prog-id=9 op=UNLOAD
    [  OK  ] Stopped Record System Boot/Shutdown in UTMP.
    [   31.506317] EXT4-fs (mmcblk0p1): unmounting filesystem 494c54de-3900-468f-8a1c-66d0ddc33e66.
    [   31.842092] audit: type=1334 audit(1709054792.380:24): prog-id=7 op=UNLOAD
    [   31.850240] audit: type=1334 audit(1709054792.380:25): prog-id=6 op=UNLOAD
    [   31.858537] audit: type=1334 audit(1709054792.388:26): prog-id=16 op=UNLOAD
    [   31.866735] audit: type=1334 audit(1709054792.388:27): prog-id=15 op=UNLOAD
    [   31.873843] audit: type=1334 audit(1709054792.388:28): prog-id=12 op=UNLOAD
    [   31.898816] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   31.906871] watchdog: watchdog0: watchdog did not stop!
    [   31.936701] systemd-shutdown[1]: Using hardware watchdog 'K3 RTI Watchdog', version 0, device /dev/watchdog0
    [   31.946619] systemd-shutdown[1]: Modifying watchdog timeout is not supported, reusing the programmed timeout.
    [   31.956566] systemd-shutdown[1]: Watchdog running with a timeout of 1min.
    [   32.017396] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   32.077724] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   32.112377] systemd-journald[105]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   32.135402] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   32.159960] systemd-shutdown[1]: Unmounting file systems.
    [   32.169290] (sd-remount)[1039]: Remounting '/' read-only with options ''.
    [   32.235610] EXT4-fs (mmcblk1p2): re-mounted 27d406a0-8181-44e9-8e68-07b1dee77e6c ro. Quota mode: none.
    [   32.253025] systemd-shutdown[1]: All filesystems unmounted.
    [   32.258696] systemd-shutdown[1]: Deactivating swaps.
    [   32.263927] systemd-shutdown[1]: All swaps deactivated.
    [   32.269191] systemd-shutdown[1]: Detaching loop devices.
    [   32.281453] systemd-shutdown[1]: All loop devices detached.
    [   32.287160] systemd-shutdown[1]: Stopping MD devices.
    [   32.292819] systemd-shutdown[1]: All MD devices stopped.
    [   32.298160] systemd-shutdown[1]: Detaching DM devices.
    [   32.303688] systemd-shutdown[1]: All DM devices detached.
    [   32.309148] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [   32.318930] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   32.326074] systemd-shutdown[1]: Failed to disable hardware watchdog, ignoring: Device or resource busy
    [   32.335494] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   32.342362] watchdog: watchdog0: watchdog did not stop!
    [   32.357934] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   32.364902] systemd-shutdown[1]: Rebooting.
    [   32.397758] reboot: Restarting system
    U-Boot SPL 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    SPL initial stack usage: 13392 bytes
    Trying to boot from MMC2
    Authentication passed
    Loading Environment from MMC... *** Warning - No MMC card found, using default environment
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    I/TC:
    I/TC: OP-TEE version: 4.2.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Apr 12 09:51:21 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    SoC:   AM64X SR2.0 HS-FS
    Model: Texas Instruments AM642 EVM
    Board: AM64-EVM rev C
    DRAM:  2 GiB
    Core:  98 devices, 31 uclasses, devicetree: separate
    NAND:  0 MiB
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1, eth2: icssg1-eth-port@0
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    574 bytes read in 41 ms (13.7 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    20285952 bytes read in 837 ms (23.1 MiB/s)
    64278 bytes read in 46 ms (1.3 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
    Working FDT set to 8feed000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.6.32-ti-g6de6e418c80e-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM642 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable m4f-dma-memory@a4000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable m4f-memory@a4100000
    [    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a57fffff (8192 KiB) nomap non-reusable ipc-memories@a5000000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a57fffff]
    [    0.000000]   node   0: [mem 0x00000000a5800000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fba00000 on node -1
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000f7800000-0x00000000fb800000] (64MB)
    [    0.000000] Memory: 1822796K/2097152K available (11968K kernel code, 1250K rwdata, 4036K rodata, 2432K init, 502K bss, 241588K reserved, 32768K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080040000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008656] Console: colour dummy device 80x25
    [    0.013264] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023944] pid_max: default: 32768 minimum: 301
    [    0.028771] LSM: initializing lsm=capability,integrity
    [    0.034164] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041749] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051887] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.059240] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.067239] rcu: Hierarchical SRCU implementation.
    [    0.072149] rcu:     Max phase no-delay instances is 1000.
    [    0.077805] Platform MSI: msi-controller@1820000 domain created
    [    0.084201] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.093755] EFI services will not be available.
    [    0.098758] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.112431] Detected VIPT I-cache on CPU1
    [    0.112540] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.112560] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
    [    0.112621] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.112768] smp: Brought up 1 node, 2 CPUs
    [    0.142157] SMP: Total of 2 processors activated.
    [    0.146966] CPU features: detected: 32-bit EL0 Support
    [    0.152237] CPU features: detected: CRC32 instructions
    [    0.157559] CPU: All CPU(s) started at EL2
    [    0.161745] alternatives: applying system-wide alternatives
    [    0.169529] devtmpfs: initialized
    [    0.183592] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.193595] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.202100] pinctrl core: initialized pinctrl subsystem
    [    0.208045] DMI not present or invalid.
    [    0.212803] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.220208] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.227665] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.235788] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.243999] audit: initializing netlink subsys (disabled)
    [    0.249890] audit: type=2000 audit(0.172:1): state=initialized audit_enabled=0 res=1
    [    0.250509] thermal_sys: Registered thermal governor 'step_wise'
    [    0.257844] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.264055] cpuidle: using governor menu
    [    0.274961] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.281971] ASID allocator initialised with 65536 entries
    [    0.300727] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f4000/pinctrl@a40000/cpsw-cpts-pps
    [    0.316028] Modules: 27680 pages in range for non-PLT usage
    [    0.316051] Modules: 519200 pages in range for PLT usage
    [    0.322840] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.335243] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.341650] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.348584] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.354990] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.361923] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.368334] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.375271] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.383636] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
    [    0.393337] iommu: Default domain type: Translated
    [    0.398278] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.405012] SCSI subsystem initialized
    [    0.409395] usbcore: registered new interface driver usbfs
    [    0.420522] usbcore: registered new device driver usb
    [    0.426360] pps_core: LinuxPPS API ver. 1 registered
    [    0.431444] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.440791] PTP clock support registered
    [    0.445016] EDAC MC: Ver: 3.0.0
    [    0.449134] scmi_core: SCMI protocol bus registered
    [    0.454665] FPGA manager framework
    [    0.458298] Advanced Linux Sound Architecture Driver Initialized.
    [    0.465725] vgaarb: loaded
    [    0.469050] clocksource: Switched to clocksource arch_sys_counter
    [    0.475631] VFS: Disk quotas dquot_6.6.0
    [    0.479690] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.494629] NET: Registered PF_INET protocol family
    [    0.499961] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.509710] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.518493] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.526428] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.534652] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.542704] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.549666] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.556593] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.564126] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.570571] RPC: Registered named UNIX socket transport module.
    [    0.576675] RPC: Registered udp transport module.
    [    0.581484] RPC: Registered tcp transport module.
    [    0.586292] RPC: Registered tcp-with-tls transport module.
    [    0.591897] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.598491] NET: Registered PF_XDP protocol family
    [    0.603421] PCI: CLS 0 bytes, default 64
    [    0.608982] Initialise system trusted keyrings
    [    0.613918] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.620965] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.627418] NFS: Registering the id_resolver key type
    [    0.632660] Key type id_resolver registered
    [    0.636939] Key type id_legacy registered
    [    0.641064] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.647917] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.696063] Key type asymmetric registered
    [    0.700266] Asymmetric key parser 'x509' registered
    [    0.705324] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.712890] io scheduler mq-deadline registered
    [    0.717528] io scheduler kyber registered
    [    0.721683] io scheduler bfq registered
    [    0.729217] pinctrl-single 4084000.pinctrl: 33 pins, size 132
    [    0.735708] pinctrl-single f4000.pinctrl: 180 pins, size 720
    [    0.743544] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.757492] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.777128] loop: module loaded
    [    0.781803] megasas: 07.725.01.00-rc1
    [    0.790573] tun: Universal TUN/TAP device driver, 1.6
    [    0.797330] VFIO - User Level meta-driver version: 0.3
    [    0.804033] usbcore: registered new interface driver usb-storage
    [    0.810934] i2c_dev: i2c /dev entries driver
    [    0.816743] sdhci: Secure Digital Host Controller Interface driver
    [    0.823113] sdhci: Copyright(c) Pierre Ossman
    [    0.827965] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.834707] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.848856] usbcore: registered new interface driver usbhid
    [    0.854571] usbhid: USB HID core driver
    [    0.858936] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.865909] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.872774] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.881429] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.890671] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.895278] optee: revision 4.2 (12d7c4ee)
    [    0.911967] optee: dynamic shared memory is enabled
    [    0.922199] random: crng init done
    [    0.925875] optee: initialized driver
    [    0.932331] NET: Registered PF_PACKET protocol family
    [    0.937668] Key type dns_resolver registered
    [    0.951611] registered taskstats version 1
    [    0.956191] Loading compiled-in X.509 certificates
    [    0.977017] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    [    1.129179] pca953x 0-0038: supply vcc not found, using dummy regulator
    [    1.136169] pca953x 0-0038: using no AI
    [    1.161889] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.169695] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.176694] pca953x 1-0022: using AI
    [    1.202376] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.208633] ti-sci-intr bus@f4000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.218042] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.230407] ti-udma 485c0100.dma-controller: Number of rings: 68
    [    1.238408] ti-udma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    1.248740] ti-udma 485c0000.dma-controller: Number of rings: 288
    [    1.266582] ti-udma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
    [    1.278003] printk: console [ttyS2] disabled
    [    1.283061] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 317, base_baud = 3000000) is a 8250
    [    1.292006] printk: console [ttyS2] enabled
    [    1.300478] printk: bootconsole [ns16550a0] disabled
    [    1.318031] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.323185] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.330156] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.335555] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    1.342557] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    1.349375] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    1.356130] 0x000000700000-0x000000740000 : "ospi.env"
    [    1.362698] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    1.369941] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.376751] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.393239] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.437062] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.447359] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.455540] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
    [    1.468461] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    1.475595] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.482338] pps pps0: new PPS source ptp0
    [    1.486803] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.504708] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    1.517889] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.528764] mmc0: CQHCI version 5.10
    [    1.545710] j721e-pcie f102000.pcie: host bridge /bus@f4000/pcie@f102000 ranges:
    [    1.553197] j721e-pcie f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
    [    1.561380] j721e-pcie f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
    [    1.569077] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.569500] j721e-pcie f102000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x0000000000
    [    1.669620] mmc0: Command Queue Engine enabled
    [    1.674163] mmc0: new HS200 MMC card at address 0001
    [    1.679975] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.688803]  mmcblk0: p1
    [    1.692138] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.698454] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.704624] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
    [    2.590243] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
    [    2.596605] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.602098] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
    [    2.611569] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
    [    2.618477] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
    [    2.624495] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xfffffffff 64bit pref]
    [    2.631878] pci 0000:00:00.0: supports D1
    [    2.635887] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.644289] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.652571] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.659268] pci 0000:00:00.0: BAR 0: no space for [mem size 0x1000000000 64bit pref]
    [    2.667011] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x1000000000 64bit pref]
    [    2.675100] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.680250] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    2.687292] pcieport 0000:00:00.0: PME: Signaling with IRQ 520
    [    2.693549] pcieport 0000:00:00.0: AER: enabled with IRQ 520
    [    2.701960] mmc1: CQHCI version 5.10
    [    2.704619] clk: Disabling unused clocks
    [    2.737747] ALSA device list:
    [    2.740733]   No soundcards found.
    [    2.743666] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.752540] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.809888] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    2.817408] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
    [    2.827842]  mmcblk1: p1 p2
    [    3.115552] EXT4-fs (mmcblk1p2): mounted filesystem 27d406a0-8181-44e9-8e68-07b1dee77e6c r/w with ordered data mode. Quota mode: none.
    [    3.127809] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.137213] devtmpfs: mounted
    [    3.141828] Freeing unused kernel memory: 2432K
    [    3.146473] Run /sbin/init as init process
    [    3.474526] systemd[1]: System time before build time, advancing clock.
    [    3.543701] NET: Registered PF_INET6 protocol family
    [    3.550265] Segment Routing with IPv6
    [    3.554041] In-situ OAM (IOAM) with IPv6
    [    3.607153] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    3.639006] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    3.671796] systemd[1]: Hostname set to <am64xx-evm>.
    [    4.152321] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.322917] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.436572] systemd[1]: Queued start job for default target Graphical Interface.
    [    4.485212] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    4.508480] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    4.532360] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    4.555588] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    4.577803] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    4.601754] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    4.625484] systemd[1]: Expecting device /dev/ttyS2...
    [    4.645548] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    4.665383] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    4.685377] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    4.705407] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    4.767430] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    4.789548] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    4.821642] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    4.845917] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.871142] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    4.894318] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.918444] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.934640] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    5.093938] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    5.118168] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    5.142297] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    5.277672] systemd[1]: Mounting Huge Pages File System...
    [    5.314881] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.329958] systemd[1]: Mounting Kernel Debug File System...
    [    5.358137] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    5.380553] systemd[1]: Mounting Temporary Directory /tmp...
    [    5.410404] systemd[1]: Starting Create List of Static Device Nodes...
    [    5.442490] systemd[1]: Starting Load Kernel Module configfs...
    [    5.490181] systemd[1]: Starting Load Kernel Module drm...
    [    5.538230] systemd[1]: Starting Load Kernel Module fuse...
    [    5.572224] systemd[1]: Starting RPC Bind...
    [    5.581317] fuse: init (API version 7.39)
    [    5.590172] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    5.627112] systemd[1]: Starting Journal Service...
    [    5.686311] systemd[1]: Starting Load Kernel Modules...
    [    5.714509] systemd[1]: Starting Generate network units from Kernel command line...
    [    5.774466] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.802682] cryptodev: loading out-of-tree module taints kernel.
    [    5.818422] systemd[1]: Starting Coldplug All udev Devices...
    [    5.821461] systemd-journald[105]: Collecting audit messages is enabled.
    [    5.844039] cryptodev: driver 1.13 loaded.
    [    5.873797] systemd[1]: Started RPC Bind.
    [    5.894698] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    5.924514] EXT4-fs (mmcblk1p2): re-mounted 27d406a0-8181-44e9-8e68-07b1dee77e6c r/w. Quota mode: none.
    [    5.927895] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    5.968911] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [    5.990732] systemd[1]: Mounted Temporary Directory /tmp.
    [  OK  ] Mounted Temporary Directory /tmp.
    [    6.025330] systemd[1]: Finished Create List of Static Device Nodes.
    [  OK  ] Finished Create List of Static Device Nodes.
    [    6.054364] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gracefully...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [    6.532415] systemd-journald[105]: Received client request to flush runtime journal.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    6.897160] audit: type=1334 audit(1709054767.412:2): prog-id=6 op=LOAD
    [    6.904039] audit: type=1334 audit(1709054767.420:3): prog-id=7 op=LOAD
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Load/Save OS Random Seed.
    [  OK  ] Finished Create Volatile Files and Directories.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [    7.284951] audit: type=1334 audit(1709054767.804:4): prog-id=8 op=LOAD
             Starting Network Name Resolution...
    [    7.336687] audit: type=1334 audit(1709054767.856:5): prog-id=9 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [    7.461269] audit: type=1334 audit(1709054767.980:6): prog-id=10 op=LOAD
             Starting User Database Manager...
    [    7.477734] audit: type=1334 audit(1709054767.980:7): prog-id=11 op=LOAD
    [    7.495209] audit: type=1334 audit(1709054767.992:8): prog-id=12 op=LOAD
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Timer service to update the IP on OLED each 10s.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [    9.370071] audit: type=1334 audit(1709054769.892:9): prog-id=13 op=LOAD
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [    9.866408] dbus-broker-lau[333]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Expand the rootfs partiti…to full size of the boot device....
    [   10.093602] audit: type=1334 audit(1709054770.616:10): prog-id=14 op=LOAD
    [   10.105758] audit: type=1334 audit(1709054770.620:11): prog-id=15 op=LOAD
             Starting User Login Management...
             Starting Telnet Server...
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Finished Telnet Server.
    [  OK  ] Started Telephony service.
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [   10.916726] Bluetooth: Core ver 2.22
    [   10.921939] NET: Registered PF_BLUETOOTH protocol family
    [   10.928549] Bluetooth: HCI device and connection manager initialized
    [   10.937166] Bluetooth: HCI socket layer initialized
    [   10.943212] Bluetooth: L2CAP socket layer initialized
    [   10.952125] Bluetooth: SCO socket layer initialized
    [   11.373875] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.415177] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   11.426274] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Started User Login Management.
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
             Starting Enable and configure wl18xx bluetooth stack...
    [   11.740815] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [  OK  ] Started Netperf Benchmark Server   11.761254] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    m.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Wait for Network to be Configured...
             Starting Permit User Sessions...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [   12.270775] CAN device driver interface
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [   12.546853] at24 0-0050: supply vcc not found, using dummy regulator
    [   12.637621] davinci_mdio 300b2400.mdio: Configuring MDIO in manual mode
    [   12.671015] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    [   12.726681] platform 78000000.r5f: configured R5F for remoteproc mode
    [   12.749115] davinci_mdio 300b2400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [   12.769961] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   12.813808] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
    [   12.856158] remoteproc remoteproc0: 78000000.r5f is available
    [   12.871759] davinci_mdio 300b2400.mdio: phy[15]: device 300b2400.mdio:0f, driver TI DP83869
    [   12.882390] remoteproc remoteproc0: powering up 78000000.r5f
    [   12.888592] remoteproc remoteproc0: Booting fw image am64-main-r5f0_0-fw, size 86352
    [   12.900535] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@a0000000
    [   12.914132] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   12.914985] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   12.920946] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [   12.935152] remoteproc remoteproc0: remote processor 78000000.r5f is now up
    [   12.981747] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [   12.996695] platform 78200000.r5f: configured R5F for remoteproc mode
    [   13.048258] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [   13.055607] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [   13.106502] remoteproc remoteproc2: 78200000.r5f is available
    [   13.107025] remoteproc remoteproc1: 5000000.m4fss is available
    [   13.152112] remoteproc remoteproc2: powering up 78200000.r5f
    [   13.161249] remoteproc remoteproc2: Booting fw image am64-main-r5f0_1-fw, size 141772
    [   13.169901] remoteproc remoteproc1: powering up 5000000.m4fss
    [   13.176248] remoteproc remoteproc1: Booting fw image am64-mcu-m4f0_0-fw, size 88248
    [   13.188430] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@a1000000
    [   13.200606] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node m4f-dma-memory@a4000000
    [   13.203124] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   13.209921] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [   13.222009] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [   13.224233] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   13.234832] remoteproc remoteproc2: remote processor 78200000.r5f is now up
    [   13.241999] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [   13.242191] platform 78400000.r5f: configured R5F for remoteproc mode
    [   13.256635] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   13.264078] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   13.264854] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
    [   13.279351] remoteproc remoteproc1: remote processor 5000000.m4fss is now up
    [   13.288732] remoteproc remoteproc3: 78400000.r5f is available
    [   13.321009] remoteproc remoteproc3: powering up 78400000.r5f
    [   13.329380] remoteproc remoteproc3: Booting fw image am64-main-r5f1_0-fw, size 93260
    [   13.343587] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@a2000000
    [   13.354522] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   13.360235] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   13.368311] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
    [   13.375351] platform 78600000.r5f: configured R5F for remoteproc mode
    [   13.376952] remoteproc remoteproc3: remote processor 78400000.r5f is now up
    [   13.421594] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   13.490661] m_can_platform 20701000.can: m_can device registered (irq=528, version=32)
    [   13.494426] remoteproc remoteproc4: 78600000.r5f is available
    [   13.512333] remoteproc remoteproc4: powering up 78600000.r5f
    [   13.518194] remoteproc remoteproc4: Booting fw image am64-main-r5f1_1-fw, size 91520
    [   13.529353] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node r5f-dma-memory@a3000000
    [   13.530551] m_can_platform 20711000.can: m_can device registered (irq=529, version=32)
    [   13.541987] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   13.552046] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [   13.564921] rproc-virtio rproc-virtio.4.auto: registered virtio4 (type 7)
    [   13.571942] remoteproc remoteproc4: remote processor 78600000.r5f is now up
    [   13.699065] gpio-mux mux-controller: 2-way mux-controller registered
    [   13.734158] remoteproc remoteproc5: 3000a000.txpru is available
    [   13.789324] remoteproc remoteproc6: 3000c000.txpru is available
    [   13.800495] remoteproc remoteproc7: 3008a000.txpru is available
    [   13.823603] remoteproc remoteproc8: 3008c000.txpru is available
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [   14.472759] remoteproc remoteproc9: 30034000.pru is available
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [   14.487243] remoteproc remoteproc10: 30004000.rtu is available
    [   14.501286] remoteproc remoteproc11: 30038000.pru is available
    [   14.511405] remoteproc remoteproc12: 30006000.rtu is available
    [   14.524324] remoteproc remoteproc13: 300b4000.pru is available
    [   14.533758] remoteproc remoteproc14: 30084000.rtu is available
    [   14.559829] TI DP83869 300b2400.mdio:0f: attached PHY driver (mii_bus:phy_addr=300b2400.mdio:0f, irq=POLL)
    [   14.589940] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: single EMAC mode
    [   14.609959] remoteproc remoteproc15: 300b8000.pru is available
    [   14.624613] remoteproc remoteproc16: 30086000.rtu is available
             Starting Virtual Console Setup...
    [   14.800890] m_can_platform 20701000.can main_mcan0: renamed from can0
    [  OK  ] Created slice Slice /system/systemd-fsck.
             Expecting device /dev/mmcblk0p1...
    [   15.037824] m_can_platform 20711000.can main_mcan1: renamed from can1
    [  OK  ] Finished Virtual Console Setup.
             Expecting device /dev/mmcblk1p1...
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [   15.935467] remoteproc remoteproc13: powering up 300b4000.pru
    [   15.967385] remoteproc remoteproc13: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 39464
    [   16.010066] remoteproc remoteproc13: unsupported resource 5
    [   16.033659] remoteproc remoteproc13: remote processor 300b4000.pru is now up
    [   16.041205] remoteproc remoteproc14: powering up 30084000.rtu
    [   16.053214] remoteproc remoteproc14: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 31140
    [   16.074970] remoteproc remoteproc14: remote processor 30084000.rtu is now up
    [   16.082409] remoteproc remoteproc7: powering up 3008a000.txpru
    [   16.098621] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 39068
    [   16.112792] remoteproc remoteproc7: remote processor 3008a000.txpru is now up
    [   16.125399] pps pps1: new PPS source ptp2
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/boot-mmcblk1p1...
    [   16.656848] EXT4-fs (mmcblk0p1): mounted filesystem 494c54de-3900-468f-8a1c-66d0ddc33e66 r/w with ordered data mode. Quota mode: none.
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [  OK  ] Started containerd container runtime.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am64xx-evm ttyS2
    Arago 2023.10 am64xx-evm ttyS2
    am64xx-evm login: ***************************************************************
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts-examples
            libqt5charts-plugins
            libqt5charts-qmlplugins
            libqt5charts5
            libqt5serialport-examples
            libqt5serialport-plugins
            libqt5serialport-qmlplugins
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg-qmlplugins
            libqt5svg5
            libqt5virtualkeyboard-plugins
            libqt5virtualkeyboard-qmlplugins
            libqt5virtualkeyboard5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring5
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity-plugins
            qtconnectivity-qmlplugins
            qtconnectivity
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-tools
            qtdeclarative
            qtgraphicaleffects-qmlplugins
            qtlocation-examples
            qtlocation-plugins
            qtlocation-qmlplugins
            qtlocation
            qtmultimedia-examples
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquics-qmlplugins.control
            qtquics2-plugins.control
            qtquics2-qmlplugins.control
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    root
    [   20.390614] kauditd_printk_skb: 2 callbacks suppressed
    [   20.390640] audit: type=1006 audit(1709054780.908:14): pid=974 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   20.408396] audit: type=1300 audit(1709054780.908:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffffcbc68c8 a2=1 a3=1 items=0 ppid=1 pid=974 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   20.435046] audit: type=1327 audit(1709054780.908:14): proctitle="(systemd)"
    [   20.458265] audit: type=1334 audit(1709054780.980:15): prog-id=18 op=LOAD
    [   20.465142] audit: type=1300 audit(1709054780.980:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc407ab48 a2=90 a3=0 items=0 ppid=1 pid=974 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   20.491088] audit: type=1327 audit(1709054780.980:15): proctitle="(systemd)"
    [   20.498898] audit: type=1334 audit(1709054780.980:16): prog-id=18 op=UNLOAD
    [   20.506993] audit: type=1300 audit(1709054780.980:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffb12fdc60 items=0 ppid=1 pid=974 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   20.533444] audit: type=1327 audit(1709054780.980:16): proctitle="(systemd)"
    [   20.540633] audit: type=1334 audit(1709054780.980:17): prog-id=19 op=LOAD
    ifconfig
    root@am64xx-evm:~# ifconfig
    eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether 34:08:e1:80:b7:b3  txqueuelen 1000  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 0  bytes 0 (0.0 B)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    eth2: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether 70:ff:76:1e:e8:d1  txqueuelen 1000  (Ethernet)
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 10  bytes 1594 (1.5 KiB)
            TX packets 10  bytes 1594 (1.5 KiB)
    root@am64xx-evm:~# shutdown
    Shutdown scheduled for Tue 2024-02-27 17:27:28 UTC, use 'shutdown -c' to cancel.
    root@am64xx-evm:~# uname -a
    Linux am64xx-evm 6.6.32-ti-g6de6e418c80e-dirty #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024 aarch64 GNU/Linux
    root@am64xx-evm:~#          Stopping Session c1 of User [  OK  ] Removed slice Slice /system/modprobe.
    [  OK  ] Stopped target Host and Network Name Lookups.
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target Timer Units.
    [  OK  ] Stopped Daily rotation of log files.
    [  OK  ] Stopped Daily Cleanup of Temporary Directories.
    [  OK  ] Stopped target System Time Set.
    [  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Stopping Reboot and dump vmcore via kexec...
    [  OK  ] Stopped Timer service to update the IP on OLED each 10s.
             Stopping Load/Save OS Random Seed...
    [  OK  ] Stopped target Login Prompts.
             Stopping Job spooling tools...
             Stopping Avahi mDNS/DNS-SD Stack...
             Stopping containerd container runtime...
             Stopping Periodic Command Scheduler...
             Stopping Getty on tty1...
             Stopping irqbalance daemon...
             Stopping Netperf Benchmark Server...
             Stopping Telephony service...
    [  OK  ] Stopped Expand the rootfs partition to full size of the boot device..
             Stopping Serial Getty on ttyS2...
             Stopping Simple Network Management Protocol (SNMP) Daemon....
             Stopping Telnet Server...
    [  OK  ] Stopped Job spooling tools.
    [  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
    [  OK  ] Stopped Periodic Command Scheduler.
    [  OK  ] Stopped irqbalance daemon.
    [  OK  ] Stopped Telephony service.
    [  OK  ] Stopped Netperf Benchmark Server.
    [  OK  ] Stopped Wait for Network to be Configured.
    [  OK  ] Stopped containerd container runtime.
    [  OK  ] Stopped Getty on tty1.
    [  OK  ] Stopped Serial Getty on ttyS2.
    [  OK  ] Stopped Reboot and dump vmcore via kexec.
    [  OK  ] Stopped Load/Save OS Random Seed.
    [  OK  ] Stopped Telnet Server.
    [  OK  ] Stopped Session c1 of User root.
    [  OK  ] Removed slice Slice /system/getty.
    [  OK  ] Removed slice Slice /system/serial-getty.
             Stopping User Login Management...
             Stopping Permit User Sessions...
             Stopping User Manager for UID 0...
    [  OK  ] Stopped Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Stopped Permit User Sessions.
    [  OK  ] Stopped User Manager for UID 0.
    [  OK  ] Stopped User Login Management.
    [   89.070539] kauditd_printk_skb: 5 callbacks suppressed
    [   89.070558] audit: type=1334 audit(1709054849.592:19): prog-id=14 op=UNLOAD
    [  OK  ] Stopped target Network.
    [  OK  ] Stopped target Remote File Systems.
             Stopping Network Configuration...
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Stopped Network Configuration.
    [  OK  ] Unmounted /run/user/0.
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [   89.264519] audit: type=1334 audit(1709054849.784:20): prog-id=17 op=UNLOAD
    [  OK  ] Removed slice User Slice of UID 0.
    [  OK  ] Stopped target Preparation for Network.
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Path Units.
    [  OK  ] Stopped Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Stopped Forward Password Requests to Wall Directory Watch.
    [  OK  ] Stopped target Slice Units.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Socket Units.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Closed PC/SC Smart Card Daemon Activation Socket.
    [  OK  ] Closed Network Service Netlink Socket.
             Stopping D-Bus System Message Bus...
    [  OK  ] Stopped Generate network units from Kernel command line.
    [  OK  ] Stopped D-Bus System Message Bus.
    [   89.652764] audit: type=1334 audit(1709054850.172:21): prog-id=13 op=UNLOAD
    [  OK  ] Closed D-Bus System Message Bus Socket.
    [  OK  ] Stopped target System Initialization.
             Stopping Network Name Resolution...
             Stopping Network Time Synchronization...
    [  OK  ] Stopped Network Name Resolution.
    [  OK  ] Stopped Network Time Synchronization.
    [   89.833232] audit: type=1334 audit(1709054850.352:22): prog-id=9 op=UNLOAD
    [   89.841983] audit: type=1334 audit(1709054850.360:23): prog-id=8 op=UNLOAD
    [  OK  ] Stopped Apply Kernel Variables.
    [  OK  ] Closed Process Core Dump Socket.
    [  OK  ] Stopped Load Kernel Modules.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting /run/media/boot-mmcblk1p1...
             Unmounting /run/media/mmcblk0p1...
             Unmounting Temporary Directory /tmp...
    [   90.044976] EXT4-fs (mmcblk0p1): unmounting filesystem 494c54de-3900-468f-8a1c-66d0ddc33e66.
             Unmounting /var/volatile...
    [  OK  ] Unmounted /run/media/boot-mmcblk1p1.
    [  OK  ] Unmounted /run/media/mmcblk0p1.
    [  OK  ] Unmounted Temporary Directory /tmp.
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Swaps.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped File System Check on /dev/mmcblk0p1.
    [  OK  ] Stopped File System Check on /dev/mmcblk1p1.
    [  OK  ] Removed slice Slice /system/systemd-fsck.
    [  OK  ] Stopped target Preparation for Local File Systems.
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Stopped Create Static Device Nodes in /dev gracefully.
    [  OK  ] Reached target System Shutdown.
    [  OK  ] Reached target Late Shutdown Services.
    [  OK  ] Finished System Power Off.
    [  OK  ] Reached target System Power Off.
    [   90.444420] audit: type=1334 audit(1709054850.964:24): prog-id=16 op=UNLOAD
    [   90.452771] audit: type=1334 audit(1709054850.964:25): prog-id=15 op=UNLOAD
    [   90.460845] audit: type=1334 audit(1709054850.972:26): prog-id=7 op=UNLOAD
    [   90.468526] audit: type=1334 audit(1709054850.972:27): prog-id=6 op=UNLOAD
    [   90.476388] audit: type=1334 audit(1709054850.980:28): prog-id=5 op=UNLOAD
    [   90.570263] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   90.583286] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   90.614948] systemd-journald[105]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   90.636166] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   90.660161] systemd-shutdown[1]: Unmounting file systems.
    [   90.670016] (sd-remount)[1039]: Remounting '/' read-only with options ''.
    [   90.717971] EXT4-fs (mmcblk1p2): re-mounted 27d406a0-8181-44e9-8e68-07b1dee77e6c ro. Quota mode: none.
    [   90.735458] systemd-shutdown[1]: All filesystems unmounted.
    [   90.741124] systemd-shutdown[1]: Deactivating swaps.
    [   90.746617] systemd-shutdown[1]: All swaps deactivated.
    [   90.751888] systemd-shutdown[1]: Detaching loop devices.
    [   90.764202] systemd-shutdown[1]: All loop devices detached.
    [   90.769967] systemd-shutdown[1]: Stopping MD devices.
    [   90.775625] systemd-shutdown[1]: All MD devices stopped.
    [   90.781075] systemd-shutdown[1]: Detaching DM devices.
    [   90.787035] systemd-shutdown[1]: All DM devices detached.
    [   90.792486] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [   90.812473] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   90.819317] systemd-shutdown[1]: Powering off.
    [   90.854410] reboot: Power down
    þ
    Resetting on cold boot to workaround ErrataID:i2331
    Please resend tiboot3.bin in case of UART/DFU boot
    resetting ...
    I/TC:
    DRAM:  2 GiB
    NAND:  0 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    20285952 bytes read in 838 ms (23.1 MiB/s)
    Starting kernel ...
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008655] Console: colour dummy device 80x25
    [    0.013267] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023947] pid_max: default: 32768 minimum: 301
    [    0.028775] LSM: initializing lsm=capability,integrity
    [    0.034163] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041747] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051871] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.059227] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.067220] rcu: Hierarchical SRCU implementation.
    [    0.072130] rcu:     Max phase no-delay instances is 1000.
    [    0.077788] Platform MSI: msi-controller@1820000 domain created
    [    0.084187] PCI/MSI: /bus@f4000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.093742] EFI services will not be available.
    [    0.098737] smp: Bringing up secondary CPUs ...
    [    0.112399] Detected VIPT I-cache on CPU1
    [    0.112508] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.112528] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
    [    0.112589] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.112734] smp: Brought up 1 node, 2 CPUs
    [    0.142119] SMP: Total of 2 processors activated.
    [    0.146930] CPU features: detected: 32-bit EL0 Support
    [    0.152202] CPU features: detected: CRC32 instructions
    [    0.157524] CPU: All CPU(s) started at EL2
    [    0.161710] alternatives: applying system-wide alternatives
    [    0.169397] devtmpfs: initialized
    [    0.183505] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.193499] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.201917] pinctrl core: initialized pinctrl subsystem
    [    0.207944] DMI not present or invalid.
    [    0.212717] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.219923] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.227365] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.235473] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.243697] audit: initializing netlink subsys (disabled)
    [    0.249541] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
    [    0.250132] thermal_sys: Registered thermal governor 'step_wise'
    [    0.257489] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.263903] cpuidle: using governor menu
    [    0.274840] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.281852] ASID allocator initialised with 65536 entries
    [    0.300777] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f4000/pinctrl@a40000/cpsw-cpts-pps
    [    0.316071] Modules: 27680 pages in range for non-PLT usage
    [    0.316093] Modules: 519200 pages in range for PLT usage
    [    0.322869] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.335263] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.341669] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.348604] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.355008] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.361943] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.368347] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.375282] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.383623] k3-chipinfo 43000014.chipid: Family:AM64X rev:SR2.0 JTAGID[0x1bb3802f] Detected
    [    0.393364] iommu: Default domain type: Translated
    [    0.398318] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.405026] SCSI subsystem initialized
    [    0.409412] usbcore: registered new interface driver usbfs
    [    0.415075] usbcore: registered new interface driver hub
    [    0.420553] usbcore: registered new device driver usb
    [    0.426393] pps_core: LinuxPPS API ver. 1 registered
    [    0.431480] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.440829] PTP clock support registered
    [    0.445046] EDAC MC: Ver: 3.0.0
    [    0.449163] scmi_core: SCMI protocol bus registered
    [    0.454688] FPGA manager framework
    [    0.458333] Advanced Linux Sound Architecture Driver Initialized.
    [    0.465837] vgaarb: loaded
    [    0.469160] clocksource: Switched to clocksource arch_sys_counter
    [    0.475724] VFS: Disk quotas dquot_6.6.0
    [    0.479780] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.494754] NET: Registered PF_INET protocol family
    [    0.500082] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.509848] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.518631] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.526566] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.534788] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.542830] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.549782] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.556742] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.564276] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.570731] RPC: Registered named UNIX socket transport module.
    [    0.576839] RPC: Registered udp transport module.
    [    0.581649] RPC: Registered tcp transport module.
    [    0.586456] RPC: Registered tcp-with-tls transport module.
    [    0.592063] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.598656] NET: Registered PF_XDP protocol family
    [    0.603575] PCI: CLS 0 bytes, default 64
    [    0.609098] Initialise system trusted keyrings
    [    0.614020] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.621082] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.627516] NFS: Registering the id_resolver key type
    [    0.632753] Key type id_resolver registered
    [    0.637032] Key type id_legacy registered
    [    0.641163] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.648016] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.696201] Key type asymmetric registered
    [    0.700406] Asymmetric key parser 'x509' registered
    [    0.705475] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.713040] io scheduler mq-deadline registered
    [    0.717694] io scheduler kyber registered
    [    0.721845] io scheduler bfq registered
    [    0.729406] pinctrl-single 4084000.pinctrl: 33 pins, size 132
    [    0.735868] pinctrl-single f4000.pinctrl: 180 pins, size 720
    [    0.743703] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.757673] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.777497] loop: module loaded
    [    0.782155] megasas: 07.725.01.00-rc1
    [    0.790920] tun: Universal TUN/TAP device driver, 1.6
    [    0.797706] VFIO - User Level meta-driver version: 0.3
    [    0.804428] usbcore: registered new interface driver usb-storage
    [    0.811332] i2c_dev: i2c /dev entries driver
    [    0.817140] sdhci: Secure Digital Host Controller Interface driver
    [    0.823555] sdhci: Copyright(c) Pierre Ossman
    [    0.828316] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.834994] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.841576] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.849092] usbcore: registered new interface driver usbhid
    [    0.854809] usbhid: USB HID core driver
    [    0.859158] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fc9100
    [    0.866142] omap-mailbox 29040000.mailbox: omap mailbox rev 0x66fc9100
    [    0.873004] omap-mailbox 29060000.mailbox: omap mailbox rev 0x66fc9100
    [    0.881726] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.890961] optee: probing for conduit method.
    [    0.895556] optee: revision 4.2 (12d7c4ee)
    [    0.912235] optee: dynamic shared memory is enabled
    [    0.922428] random: crng init done
    [    0.926096] optee: initialized driver
    [    0.932571] NET: Registered PF_PACKET protocol family
    [    0.937905] Key type dns_resolver registered
    [    0.951818] registered taskstats version 1
    [    0.956242] Loading compiled-in X.509 certificates
    [    0.977292] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    [    1.129747] pca953x 0-0038: supply vcc not found, using dummy regulator
    [    1.136703] pca953x 0-0038: using no AI
    [    1.154020] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.161825] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.168801] pca953x 1-0022: using AI
    [    1.194504] omap_i2c 20010000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.200752] ti-sci-intr bus@f4000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.210153] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.222560] ti-udma 485c0100.dma-controller: Number of rings: 68
    [    1.230572] ti-udma 485c0100.dma-controller: Channels: 24 (bchan: 12, tchan: 6, rchan: 6)
    [    1.240928] ti-udma 485c0000.dma-controller: Number of rings: 288
    [    1.258772] ti-udma 485c0000.dma-controller: Channels: 44 (tchan: 29, rchan: 15)
    [    1.270214] printk: console [ttyS2] disabled
    [    1.275281] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 317, base_baud = 3000000) is a 8250
    [    1.284230] printk: console [ttyS2] enabled
    [    1.292692] printk: bootconsole [ns16550a0] disabled
    [    1.310236] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.315377] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.322346] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.327744] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    1.334761] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    1.341567] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    1.348362] 0x000000700000-0x000000740000 : "ospi.env"
    [    1.355021] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    1.362214] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.369027] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.385530] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.429166] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.439453] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.447630] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00903, cpsw version 0x6BA80903 Ports: 3 quirks:00000006
    [    1.460539] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.4
    [    1.467672] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.474414] pps pps0: new PPS source ptp0
    [    1.478925] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.496741] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 16
    [    1.509930] am65-cpts 39000000.cpts: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.520725] mmc0: CQHCI version 5.10
    [    1.536885] j721e-pcie f102000.pcie: host bridge /bus@f4000/pcie@f102000 ranges:
    [    1.544372] j721e-pcie f102000.pcie:       IO 0x0068001000..0x0068010fff -> 0x0068001000
    [    1.552479] j721e-pcie f102000.pcie:      MEM 0x0068011000..0x006fffffff -> 0x0068011000
    [    1.560580] j721e-pcie f102000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x0000000000
    [    1.561220] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.657703] mmc0: Command Queue Engine enabled
    [    1.662227] mmc0: new HS200 MMC card at address 0001
    [    1.668051] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.676896]  mmcblk0: p1
    [    1.680247] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.686561] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.692725] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
    [    2.581480] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
    [    2.587822] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.593315] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x68001000-0x68010fff])
    [    2.602786] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
    [    2.609694] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
    [    2.615711] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xfffffffff 64bit pref]
    [    2.623095] pci 0000:00:00.0: supports D1
    [    2.627105] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.635537] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.643813] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.650483] pci 0000:00:00.0: BAR 0: no space for [mem size 0x1000000000 64bit pref]
    [    2.658224] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x1000000000 64bit pref]
    [    2.666312] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.671457] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    2.678533] pcieport 0000:00:00.0: PME: Signaling with IRQ 520
    [    2.684788] pcieport 0000:00:00.0: AER: enabled with IRQ 520
    [    2.693256] mmc1: CQHCI version 5.10
    [    2.695786] clk: Disabling unused clocks
    [    2.728708] ALSA device list:
    [    2.731796]   No soundcards found.
    [    2.735840] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.743648] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.802446] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    2.809927] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
    [    2.820386]  mmcblk1: p1 p2
    [    3.106851] EXT4-fs (mmcblk1p2): mounted filesystem 27d406a0-8181-44e9-8e68-07b1dee77e6c r/w with ordered data mode. Quota mode: none.
    [    3.119176] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.128577] devtmpfs: mounted
    [    3.133217] Freeing unused kernel memory: 2432K
    [    3.137858] Run /sbin/init as init process
    [    3.466387] systemd[1]: System time before build time, advancing clock.
    [    3.535578] NET: Registered PF_INET6 protocol family
    [    3.542060] Segment Routing with IPv6
    [    3.545874] In-situ OAM (IOAM) with IPv6
    [    3.598417] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    3.630298] systemd[1]: Detected architecture arm64.
    [    3.657334] systemd[1]: Hostname set to <am64xx-evm>.
    [    4.146663] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.321280] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.435989] systemd[1]: Queued start job for default target Graphical Interface.
    [    4.481514] systemd[1]: Created slice Slice /system/getty.
    [    4.508477] systemd[1]: Created slice Slice /system/modprobe.
    [    4.532473] systemd[1]: Created slice Slice /system/serial-getty.
    [    4.555706] systemd[1]: Created slice User and Session Slice.
    [    4.577911] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.601866] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.625583] systemd[1]: Expecting device /dev/ttyS2...
    [    4.645634] systemd[1]: Reached target Path Units.
    [    4.665514] systemd[1]: Reached target Remote File Systems.
    [    4.685493] systemd[1]: Reached target Slice Units.
    [    4.705522] systemd[1]: Reached target Swaps.
    [    4.771662] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.797616] systemd[1]: Reached target RPC Port Mapper.
    [    4.829820] systemd[1]: Listening on Process Core Dump Socket.
    [    4.854011] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.879243] systemd[1]: Listening on Journal Audit Socket.
    [    4.906377] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.930504] systemd[1]: Listening on Journal Socket.
    [    4.954742] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.984727] systemd[1]: Listening on udev Control Socket.
    [    5.006361] systemd[1]: Listening on udev Kernel Socket.
    [    5.030449] systemd[1]: Listening on User Database Manager Socket.
    [    5.077824] systemd[1]: Mounting Huge Pages File System...
    [    5.116386] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.150121] systemd[1]: Mounting Kernel Debug File System...
    [    5.174127] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    5.209883] systemd[1]: Mounting Temporary Directory /tmp...
    [    5.223796] systemd[1]: Starting Create List of Static Device Nodes...
    [    5.262888] systemd[1]: Starting Load Kernel Module configfs...
    [    5.314067] systemd[1]: Starting Load Kernel Module drm...
    [    5.362526] systemd[1]: Starting Load Kernel Module fuse...
    [    5.398347] fuse: init (API version 7.39)
    [    5.426462] systemd[1]: Starting RPC Bind...
    [    5.441894] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    5.466262] systemd[1]: Starting Journal Service...
    [    5.522282] systemd[1]: Starting Load Kernel Modules...
    [    5.574735] cryptodev: loading out-of-tree module taints kernel.
    [    5.582142] systemd[1]: Starting Generate network units from Kernel command line...
    [    5.591610] cryptodev: driver 1.13 loaded.
    [    5.618551] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.642748] systemd[1]: Starting Coldplug All udev Devices...
    [    5.681134] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    5.695760] systemd-journald[105]: Collecting audit messages is enabled.
    [    5.710862] systemd[1]: Mounted Huge Pages File System.
    [    5.740736] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File Sy[    5.749635] EXT4-fs (mmcblk1p2): re-mounted 27d406a0-8181-44e9-8e68-07b1dee77e6c r/w. Quota mode: none.
    stem.
    [    5.777061] systemd[1]: Mounted Kernel Debug File System.
    [    5.810469] systemd[1]: Mounted Temporary Directory /tmp.
    [    5.835985] systemd[1]: Finished Create List of Static Device Nodes.
    [    5.866339] systemd[1]: Started Journal Service.
    [    6.237298] systemd-journald[105]: Received client request to flush runtime journal.
    [    6.613408] audit: type=1334 audit(1709054767.136:2): prog-id=6 op=LOAD
    [    6.625420] audit: type=1334 audit(1709054767.148:3): prog-id=7 op=LOAD
    [    7.021007] audit: type=1334 audit(1709054767.548:4): prog-id=8 op=LOAD
    [    7.063712] audit: type=1334 audit(1709054767.592:5): prog-id=9 op=LOAD
    [    7.195413] audit: type=1334 audit(1709054767.724:6): prog-id=10 op=LOAD
    [    7.205440] audit: type=1334 audit(1709054767.736:7): prog-id=11 op=LOAD
    [    7.217396] audit: type=1334 audit(1709054767.748:8): prog-id=12 op=LOAD
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [    9.002498] audit: type=1334 audit(1709054850.640:9): prog-id=13 op=LOAD
    [    9.552296] dbus-broker-lau[304]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [   10.039559] audit: type=1334 audit(1709054851.676:10): prog-id=14 op=LOAD
    [   10.050426] audit: type=1334 audit(1709054851.688:11): prog-id=15 op=LOAD
    [   10.807428] Bluetooth: Core ver 2.22
    [   10.811304] NET: Registered PF_BLUETOOTH protocol family
    [   10.817991] Bluetooth: HCI device and connection manager initialized
    [   10.824617] Bluetooth: HCI socket layer initialized
    [   10.830255] Bluetooth: L2CAP socket layer initialized
    [   10.837347] Bluetooth: SCO socket layer initialized
    [   11.469031] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.511690] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   11.512730] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   11.812709] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
    [   11.885734] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   11.942253] CAN device driver interface
    [   12.159402] davinci_mdio 300b2400.mdio: Configuring MDIO in manual mode
    [   12.209448] davinci_mdio 300b2400.mdio: davinci mdio revision 1.7, bus freq 1000000
    [   12.268819] davinci_mdio 300b2400.mdio: phy[15]: device 300b2400.mdio:0f, driver TI DP83869
    [   12.456080] at24 0-0050: supply vcc not found, using dummy regulator
    [   12.560668] platform 78000000.r5f: configured R5F for remoteproc mode
    [   12.563470] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    [   12.593587] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   12.619024] remoteproc remoteproc0: 78000000.r5f is available
    [   12.694907] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@a4000000
    [   12.710890] remoteproc remoteproc0: powering up 78000000.r5f
    [   12.716924] remoteproc remoteproc0: Booting fw image am64-main-r5f0_0-fw, size 86352
    [   12.733014] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@a0000000
    [   12.744464] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   12.750155] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   12.760557] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
    [   12.767475] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [   12.767662] platform 78200000.r5f: configured R5F for remoteproc mode
    [   12.775669] remoteproc remoteproc0: remote processor 78000000.r5f is now up
    [   12.789483] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [   12.794227] platform 78200000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [   12.808032] remoteproc remoteproc2: 78200000.r5f is available
    [   12.827961] remoteproc remoteproc1: 5000000.m4fss is available
    [   12.848394] remoteproc remoteproc2: powering up 78200000.r5f
    [   12.857940] remoteproc remoteproc2: Booting fw image am64-main-r5f0_1-fw, size 141772
    [   12.884423] remoteproc remoteproc1: powering up 5000000.m4fss
    [   12.894587] remoteproc remoteproc1: Booting fw image am64-mcu-m4f0_0-fw, size 88248
    [   12.910456] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@a1000000
    [   12.925762] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node m4f-dma-memory@a4000000
    [   12.936598] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   12.942383] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [   12.950022] platform 78400000.r5f: configured R5F for remoteproc mode
    [   12.951239] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
    [   12.963577] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [   12.971376] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   12.977260] remoteproc remoteproc2: remote processor 78200000.r5f is now up
    [   12.984680] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   12.986546] platform 78400000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   12.992256] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
    [   13.006979] remoteproc remoteproc1: remote processor 5000000.m4fss is now up
    [   13.019284] remoteproc remoteproc3: 78400000.r5f is available
    [   13.035313] remoteproc remoteproc3: powering up 78400000.r5f
    [   13.045433] remoteproc remoteproc3: Booting fw image am64-main-r5f1_0-fw, size 93260
    [   13.080006] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@a2000000
    [   13.092312] platform 78600000.r5f: configured R5F for remoteproc mode
    [   13.105977] platform 78600000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [   13.137617] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   13.143343] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [   13.154634] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
    [   13.162046] remoteproc remoteproc3: remote processor 78400000.r5f is now up
    [   13.165369] remoteproc remoteproc4: 78600000.r5f is available
    [   13.217096] remoteproc remoteproc4: powering up 78600000.r5f
    [   13.225049] remoteproc remoteproc4: Booting fw image am64-main-r5f1_1-fw, size 91520
    [   13.239688] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node r5f-dma-memory@a3000000
    [   13.256995] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   13.262745] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [   13.277113] rproc-virtio rproc-virtio.4.auto: registered virtio4 (type 7)
    [   13.286012] remoteproc remoteproc4: remote processor 78600000.r5f is now up
    [   13.320871] m_can_platform 20701000.can: m_can device registered (irq=528, version=32)
    [   13.336621] m_can_platform 20711000.can: m_can device registered (irq=529, version=32)
    [   13.421508] gpio-mux mux-controller: 2-way mux-controller registered
    [   13.512336] remoteproc remoteproc5: 3000a000.txpru is available
    [   13.589000] remoteproc remoteproc6: 3000c000.txpru is available
    [   13.601398] remoteproc remoteproc7: 3008a000.txpru is available
    [   13.640290] remoteproc remoteproc8: 3008c000.txpru is available
    [   14.410411] remoteproc remoteproc9: 30034000.pru is available
    [   14.421776] remoteproc remoteproc10: 30004000.rtu is available
    [   14.434118] remoteproc remoteproc11: 30038000.pru is available
    [   14.444476] remoteproc remoteproc12: 30006000.rtu is available
    [   14.461656] remoteproc remoteproc13: 300b4000.pru is available
    [   14.503580] remoteproc remoteproc14: 30084000.rtu is available
    [   14.599692] remoteproc remoteproc15: 300b8000.pru is available
    [   14.668410] remoteproc remoteproc16: 30086000.rtu is available
    [   14.859454] TI DP83869 300b2400.mdio:0f: attached PHY driver (mii_bus:phy_addr=300b2400.mdio:0f, irq=POLL)
    [   14.875454] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: single EMAC mode
    [   14.890094] m_can_platform 20711000.can main_mcan1: renamed from can1
    [   15.051959] m_can_platform 20701000.can main_mcan0: renamed from can0
    [   15.982533] remoteproc remoteproc13: powering up 300b4000.pru
    [   16.016378] remoteproc remoteproc13: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 39464
    [   16.029292] remoteproc remoteproc13: unsupported resource 5
    [   16.037803] remoteproc remoteproc13: remote processor 300b4000.pru is now up
    [   16.049316] remoteproc remoteproc14: powering up 30084000.rtu
    [   16.062607] remoteproc remoteproc14: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 31140
    [   16.075757] remoteproc remoteproc14: remote processor 30084000.rtu is now up
    [   16.088762] remoteproc remoteproc7: powering up 3008a000.txpru
    [   16.099418] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 39068
    [   16.113792] remoteproc remoteproc7: remote processor 3008a000.txpru is now up
             Starting File System Check on /dev/mmcblk0p1   16.125808] pps pps1: new PPS source ptp2
    0m...
    [   16.816598] EXT4-fs (mmcblk0p1): mounted filesystem 494c54de-3900-468f-8a1c-66d0ddc33e66 r/w with ordered data mode. Quota mode: none.
     _____                    _____           _         _
                  |___|                    |___|
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts5
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring5
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity
            qtdeclarative-tools
            qtdeclarative
            qtlocation-examples
            qtlocation-plugins
            qtlocation
            qtmultimedia
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland
            tar
            which
    am64xx-evm login: root
    [   21.455790] kauditd_printk_skb: 2 callbacks suppressed
    [   21.455807] audit: type=1006 audit(1709054863.092:14): pid=974 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   21.473670] audit: type=1300 audit(1709054863.092:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffeafc2338 a2=1 a3=1 items=0 ppid=1 pid=974 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   21.500347] audit: type=1327 audit(1709054863.092:14): proctitle="(systemd)"
    [   21.566218] audit: type=1334 audit(1709054863.204:15): prog-id=18 op=LOAD
    [   21.574197] audit: type=1300 audit(1709054863.204:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff7d0bc78 a2=90 a3=0 items=0 ppid=1 pid=974 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   21.600114] audit: type=1327 audit(1709054863.204:15): proctitle="(systemd)"
    [   21.607302] audit: type=1334 audit(1709054863.204:16): prog-id=18 op=UNLOAD
    [   21.614349] audit: type=1300 audit(1709054863.204:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff87bbdc60 items=0 ppid=1 pid=974 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   21.639962] audit: type=1327 audit(1709054863.204:16): proctitle="(systemd)"
    [   21.647076] audit: type=1334 audit(1709054863.204:17): prog-id=19 op=LOAD
            RX packets 44  bytes 4082 (3.9 KiB)
            TX packets 44  bytes 4082 (3.9 KiB)
    Shutdown scheduled for Tue 2024-02-27 17:28:48 UTC, use 'shutdown -c' to cancel.
    root@am64xx-evm:~#          Stopping   OK  ] Removed slice Slice /system/modprobe.
    [   88.268681] kauditd_printk_skb: 5 callbacks suppressed
    [   88.268706] audit: type=1334 audit(1709054929.904:19): prog-id=14 op=UNLOAD
    [   88.460620] audit: type=1334 audit(1709054930.096:20): prog-id=17 op=UNLOAD
    [   88.816220] audit: type=1334 audit(1709054930.452:21): prog-id=13 op=UNLOAD
             Stopping Record System Boot/Shutdown in UTMP...
    [   88.991262] audit: type=1334 audit(1709054930.628:22): prog-id=9 op=UNLOAD
    [   88.999157] audit: type=1334 audit(1709054930.628:23): prog-id=8 op=UNLOAD
    [  OK  ] Stopped Record System Boot/Shutdown in UTMP.
    [   89.192386] EXT4-fs (mmcblk0p1): unmounting filesystem 494c54de-3900-468f-8a1c-66d0ddc33e66.
    [   89.609616] audit: type=1334 audit(1709054931.248:24): prog-id=12 op=UNLOAD
    [   89.617872] audit: type=1334 audit(1709054931.248:25): prog-id=11 op=UNLOAD
    [   89.627984] audit: type=1334 audit(1709054931.248:26): prog-id=10 op=UNLOAD
    [   89.635842] audit: type=1334 audit(1709054931.248:27): prog-id=16 op=UNLOAD
    [   89.643525] audit: type=1334 audit(1709054931.248:28): prog-id=15 op=UNLOAD
    [   89.732757] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   89.792529] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   89.825707] systemd-journald[105]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   89.848390] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   89.871860] systemd-shutdown[1]: Unmounting file systems.
    [   89.881107] (sd-remount)[1038]: Remounting '/' read-only with options ''.
    [   89.963967] EXT4-fs (mmcblk1p2): re-mounted 27d406a0-8181-44e9-8e68-07b1dee77e6c ro. Quota mode: none.
    [   89.983344] systemd-shutdown[1]: All filesystems unmounted.
    [   89.988993] systemd-shutdown[1]: Deactivating swaps.
    [   89.994236] systemd-shutdown[1]: All swaps deactivated.
    [   89.999480] systemd-shutdown[1]: Detaching loop devices.
    [   90.011862] systemd-shutdown[1]: All loop devices detached.
    [   90.017498] systemd-shutdown[1]: Stopping MD devices.
    [   90.023079] systemd-shutdown[1]: All MD devices stopped.
    [   90.028417] systemd-shutdown[1]: Detaching DM devices.
    [   90.033938] systemd-shutdown[1]: All DM devices detached.
    [   90.039358] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [   90.059261] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   90.066184] systemd-shutdown[1]: Powering off.
    [   90.102481] reboot: Power down
  • Hi Jon,
    Please can you confirm which SDK and Linux kernel you are using and which revision of AM64x-EVM ?
    I am using SDK 10.00.07 https://dr-download.ti.com/software-development/software-development-kit-sdk/MD-InmvA50mCw/10.00.07.04/tisdk-default-image-rt-am64xx-evm.rootfs.wic.xz
    Linux kernel is 6.6.32
    I'm using the latest version of https://www.ti.com/tool/TMDS64EVM - PROC101C. I believe this should be revision C.
    Upon cold boot (turning on powered off EVM) and warm boot (running "reboot" on EVM), I see the following 3 interfaces still show up using the sequence you specified.
    Linux am64xx-evm 6.6.32-rt32-g3f59cbad6c9a #1 SMP PREEMPT_RT Thu Oct 17 10:41:45 CDT 2024 aarch64 GNx
            ether 1c:63:49:1a:d8:aa  txqueuelen 1000  (Ethernet)
    eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet6 fe80::72ff:76ff:fe1f:3dc5  prefixlen 64  scopeid 0x20<link>
            ether 70:ff:76:1f:3d:c5  txqueuelen 1000  (Ethernet)
            RX packets 11  bytes 2462 (2.4 KiB)
            RX errors 0  dropped 11  overruns 0  frame 0
            TX packets 25  bytes 4348 (4.2 KiB)
            ether 70:ff:76:1f:3d:c6  txqueuelen 1000  (Ethernet)
            RX packets 91  bytes 7574 (7.3 KiB)
            TX packets 91  bytes 7574 (7.3 KiB)
    root@am64xx-evm:~#
    We also noticed that in your log, the PHY (DP83869) connected to eth1 interface does not show up in the boot log. Have you modified anything in the DTS for SDK 10.00.07?
    -Daolin
  • Hi Daolin,
    No, the DTS is unchanged; I have literally flashed the default image provided by TI onto an SD card and booted the EVM from it. As I said in the second post the default image from the v09.02.01.10 release seems solid (eth0,eth1,eth2 every boot) but the v10 SDK exhibits the behaviour described with eth1 not being initialised. I am not sure why you are not seeing this behaviour on your EVM. Do you have other hardware you can use or can you pass this to someone else to try theirs ?
    Jon
  • Hi Daolin,
    I've had another thought, could you dump your Board ID eeprom from U-Boot (this contains the MAC addresses). This is mine.
    =>i2c md 0x50 0.2 0x100
    0000: aa 55 33 ee 01 fc 00 10 2e 00 41 4d 36 34 2d 45    .U3.......AM64-E
    0010: 56 4d 00 00 00 00 00 00 00 00 43 00 30 31 30 31    VM........C.0101
    0020: 30 34 43 00 00 00 30 31 30 31 34 39 32 32 00 00    04C...01014922..
    0030: 00 00 00 00 30 34 33 34 11 02 00 10 29 13 c2 00    ....0434....)...
    0040: 10 00 70 ff 76 1e e8 d0 70 ff 76 1e e8 d1 70 ff    ..p.v...p.v...p.
    0050: 76 1e e8 d2 00 00 00 00 00 00 00 00 00 00 00 00    v...............
    0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    Jon
  • Hi Daolin,
    I believe the PHY which isn't being initialised is at address 0x03 (00011) and is the one with the FET switch between PRG1 and CPSW_RGMII1 MDC/MDIO. This is switched by the IO expander at address 0x22 (PRG1_RGMII2_FET_SEL).
    The other PHY at address 0x0F (01111) doesn't have this multiplexed MDC/MDIO interface.
    Could it be something around this FET switch or the IO expander which has been changed in the v10 SDK which is causing the eth1 to no longer be initialised ? In fact could it be that the v10 SDK treats ICSSG RGMII1 and ICSSG RGMII2 the same and doesn't actually initialise the FET switch at all ?
    Jon
  • Hi Jon,
    An update:
    I was taking the RT-Linux version of the wic image and that was why I cannot reproduce this issue.
    When took the non-RT Linux wic image, reflashed and now see the issue.
    Initial boot shows all 3 interfaces. Second boot, eth1 is missing when running "ifconfig".
    In fact, subsequently any boot, regardless of cold boot (poweroff) or warm boot (reboot), results in eth1 missing.
    Only after a completely new reflash of the non-RT image does all 3 interfaces show up in the initial boot.
    Temporary solution:
    However, when I ran "ifconfig -a", eth1 did show up. After running "ifconfig eth1 up", the eth1 gets brought up and will show up in "ifconfig".
    Furthermore, I noticed that after every reboot "systemctl status systemd-networkd.service" indicates the eth1 interface could not be brought up. After restarting this service, eth1 gets brought up and shows in "ifconfig".
    I think for some reason this systemd service is not able to bring up the eth1 device after boot up on non-RT Linux image.
    NOTE: although "ifconfig" can still be used, it is an outdated utility tool and we recommend using "ip a" instead. See https://opensource.com/article/21/1/ifconfig-ip-linux
    Log of ifconfig eth1 up test:
    [   19.263031] kauditd_printk_skb: 2 callbacks suppressed
    [   19.263050] audit: type=1006 audit(1709062347.708:14): pid=906 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   19.280934] audit: type=1300 audit(1709062347.708:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff7d5a958 a2=1 a3=1 items=0 ppid=1 pid=906 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0)
    [   19.307575] audit: type=1327 audit(1709062347.708:14): proctitle="(systemd)"
    [   19.327594] audit: type=1334 audit(1709062347.772:15): prog-id=18 op=LOAD
    [   19.335257] audit: type=1300 audit(1709062347.772:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc4ffda98 a2=90 a3=0 items=0 ppid=1 pid=906 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid)
    [   19.362117] audit: type=1327 audit(1709062347.772:15): proctitle="(systemd)"
    [   19.370081] audit: type=1334 audit(1709062347.772:16): prog-id=18 op=UNLOAD
    [   19.378117] audit: type=1300 audit(1709062347.772:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff7fb67c60 items=0 ppid=1 pid=906 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0)
    [   19.404343] audit: type=1327 audit(1709062347.772:16): proctitle="(systemd)"
    [   19.412273] audit: type=1334 audit(1709062347.772:17): prog-id=19 op=LOAD
            ether 1c:63:49:1a:d7:bc  txqueuelen 1000  (Ethernet)
            ether 70:ff:76:1f:3c:46  txqueuelen 1000  (Ethernet)
            RX packets 18  bytes 2186 (2.1 KiB)
            TX packets 18  bytes 2186 (2.1 KiB)
    root@am64xx-evm:~# ifconfig -a
    eth1: flags=4098<BROADCAST,MULTICAST>  mtu 1500
            ether 70:ff:76:1f:3c:45  txqueuelen 1000  (Ethernet)
    main_mcan0: flags=128<NOARP>  mtu 16
            unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 10  (UNSPEC)
            device interrupt 16
    main_mcan1: flags=128<NOARP>  mtu 16
            device interrupt 17
    root@am64xx-evm:~# ifconfig eth1 up
    [   29.471133] am65-cpsw-nuss 8000000.ethernet eth1: PHY [mdio_mux-0.1:03] driver [TI DP83869] (irq=POLL)
    [   29.480674] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    root@am64xx-evm:~# [   33.578108] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
            inet 172.168.1.122  netmask 255.255.255.0  broadcast 172.168.1.255
            inet6 fe80::72ff:76ff:fe1f:3c45  prefixlen 64  scopeid 0x20<link>
            RX packets 3  bytes 746 (746.0 B)
            TX packets 23  bytes 3592 (3.5 KiB)
    root@am64xx-evm:~#
    Log of systemd-networkd.service test:
    [   65.603262] kauditd_printk_skb: 2 callbacks suppressed
    [   65.603279] audit: type=1006 audit(1709061749.168:14): pid=907 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   65.621143] audit: type=1300 audit(1709061749.168:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffe73e3be8 a2=1 a3=1 items=0 ppid=1 pid=907 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0)
    [   65.648296] audit: type=1327 audit(1709061749.168:14): proctitle="(systemd)"
    [   65.706473] audit: type=1334 audit(1709061749.272:15): prog-id=18 op=LOAD
    [   65.714478] audit: type=1300 audit(1709061749.272:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffeb7af9f8 a2=90 a3=0 items=0 ppid=1 pid=907 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid)
    [   65.740408] audit: type=1327 audit(1709061749.272:15): proctitle="(systemd)"
    [   65.747596] audit: type=1334 audit(1709061749.272:16): prog-id=18 op=UNLOAD
    [   65.754747] audit: type=1300 audit(1709061749.272:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff84ce3c60 items=0 ppid=1 pid=907 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0)
    [   65.780475] audit: type=1327 audit(1709061749.272:16): proctitle="(systemd)"
    [   65.787715] audit: type=1334 audit(1709061749.272:17): prog-id=19 op=LOAD
    root@am64xx-evm:~# systemctl status systemd-networkd.service
    * systemd-networkd.service - Network Configuration
         Loaded: loaded (8;;file://am64xx-evm/usr/lib/systemd/system/systemd-networkd.service/usr/lib/systemd/system/systemd-networkd.service8;;; enabled; preset: enabled)8;;
         Active: active (running) since Tue 2024-02-27 19:21:34 UTC; 1min 1s ago
    TriggeredBy: * systemd-networkd.socket
           Docs: 8;;man:systemd-networkd.service(8)man:systemd-networkd.service(8)8;;8;;
                 8;;man:org.freedesktop.network1(5)man:org.freedesktop.network1(5)8;;8;;
       Main PID: 374 (systemd-network)
         Status: "Processing requests..."
          Tasks: 1 (limit: 2136)
       FD Store: 0 (limit: 512)
         Memory: 2.9M (peak: 3.2M)
            CPU: 445ms
         CGroup: /system.slice/systemd-networkd.service
                 `-374 /usr/lib/systemd/systemd-networkd
    Feb 27 19:21:34 am64xx-evm systemd-networkd[374]: eth0: Configuring with /etc/systemd/network/10-eth.network.
    Feb 27 19:21:34 am64xx-evm systemd-networkd[374]: eth1: found matching network '/etc/systemd/network/15-eth.network', based on potentially unpredictable interface name.
    Feb 27 19:21:34 am64xx-evm systemd-networkd[374]: eth1: Configuring with /etc/systemd/network/15-eth.network.
    Feb 27 19:21:34 am64xx-evm systemd-networkd[374]: eth0: Link UP
    Feb 27 19:21:34 am64xx-evm systemd-networkd[374]: eth1: Could not bring up interface, ignoring: No such device
    Feb 27 19:21:38 am64xx-evm systemd-networkd[374]: can0: Interface name change detected, renamed to main_mcan0.
    Feb 27 19:21:38 am64xx-evm systemd-networkd[374]: can1: Interface name change detected, renamed to main_mcan1.
    Feb 27 19:21:39 am64xx-evm systemd-networkd[374]: eth2: found matching network '/etc/systemd/network/15-eth.network', based on potentially unpredictable interface name.
    Feb 27 19:21:39 am64xx-evm systemd-networkd[374]: eth2: Configuring with /etc/systemd/network/15-eth.network.
    Feb 27 19:21:39 am64xx-evm systemd-networkd[374]: eth2: Link UP
    root@am64xx-evm:~# systemctl restart systemd-networkd.service
    [   78.986098] kauditd_printk_skb: 5 callbacks suppressed
    [   78.986116] audit: type=1334 audit(1709061762.552:19): prog-id=17 op=UNLOAD
    [   78.999832] audit: type=1334 audit(1709061762.556:20): prog-id=20 op=LOAD
    root@am64xx-evm:~# [   79.279919] am65-cpsw-nuss 8000000.ethernet eth1: PHY [mdio_mux-0.1:03] driver [TI DP83869] (irq=POLL)
    [   79.299271] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    root@am64xx-evm:~# [   83.405458] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
         Active: active (running) since Tue 2024-02-27 19:22:42 UTC; 5s ago
       Main PID: 928 (systemd-network)
         Memory: 1.3M (peak: 1.6M)
            CPU: 287ms
                 `-928 /usr/lib/systemd/systemd-networkd
    Feb 27 19:22:42 am64xx-evm systemd-networkd[928]: eth0: found matching network '/etc/systemd/network/10-eth.network', based on potentially unpredictable interface name.
    Feb 27 19:22:42 am64xx-evm systemd-networkd[928]: eth0: Configuring with /etc/systemd/network/10-eth.network.
    Feb 27 19:22:42 am64xx-evm systemd-networkd[928]: eth1: found matching network '/etc/systemd/network/15-eth.network', based on potentially unpredictable interface name.
    Feb 27 19:22:42 am64xx-evm systemd-networkd[928]: eth1: Configuring with /etc/systemd/network/15-eth.network.
    Feb 27 19:22:42 am64xx-evm systemd-networkd[928]: eth2: found matching network '/etc/systemd/network/15-eth.network', based on potentially unpredictable interface name.
    Feb 27 19:22:42 am64xx-evm systemd-networkd[928]: eth2: Configuring with /etc/systemd/network/15-eth.network.
    Feb 27 19:22:42 am64xx-evm systemd-networkd[928]: eth1: Link UP
    Feb 27 19:22:46 am64xx-evm systemd-networkd[928]: eth1: Gained carrier
    Feb 27 19:22:46 am64xx-evm systemd-networkd[928]: eth1: found matching network '/etc/systemd/network/15-eth.network', based on potentially unpredictable interface name.
    Feb 27 19:22:48 am64xx-evm systemd-networkd[928]: eth1: DHCPv4 address 172.168.1.122/24 acquired from 172.168.1.1
    root@am64xx-evm:~#
            RX packets 4  bytes 806 (806.0 B)
            TX packets 33  bytes 4882 (4.7 KiB)
    root@am64xx-evm:~#
    I have created an internal bug on this issue to hopefully root cause this issue. Thanks for bringing this issue to our attention!
    -Daolin
  • Hi Daolin,
    I'm not sure how this slipped through your testing.
    When do you expect this bug will be fixed ?
    Jon
  • Hi Jon,
    Good question, I'm trying to find out how in our internal testing it wasn't caught.
    The developer is reviewing this issue, this may take some time as there is a national holiday next week where the developer is located in. We do not have a fixed date yet. I will try to update you here when it has been fixed.
    Please ping this thread if you do not hear from me in two weeks.
    -Daolin
  • Hi Daolin,
    If a solution is at least a week away can you provide any guidance on where I can look in the SDK to identify the issue? We know that it worked in SDK v9 but was broken in v10 (non RT) and is broken between the RT and non-RT release of v10 so this should narrow it down hopefully.
    Jon
  • Hi Jon,
    As I mentioned in the "temporary solution" in a previous response: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1427145/processor-sdk-am64x-am64x-evm-eth1-is-not-being-enumerated/5476317#5476317 , the issue seems to lie in the systemd-networkd service failing to initialize/bring up the eth1 interface. You can see that in the systemctl status log of this service right after boot up in my earlier response.
    I currently do not know why this service fails to bring up the interface. The service runs on the OOB working versions RT-Linux SDK 10.0 and SDK 9.x as well. However, please note it might not be an issue with the systemd-networkd service itself but the failing message might be a symptom of an underlying issue. I think maybe the eth1 was not registered as a device before the systemd-networkd service starts running, but this is just my speculation.
    Alternatively, if you are short on time, you could also use the "temporary solution" I specified in a previous response as a workaround to unblock any development work you are working on.
    -Daolin
  • Hi Jon,
    Are you able to use RT-Linux instead of the non-RT Linux release? In other words, is any particular reason for using the non-RT Linux release for your use case?
    -Daolin
  • Ho Daolin,
    I tried the RT-Linux build but it crashed on our board.
    Jon
  • Hi Jon,
    RT-Linux build shouldn't have crashed OOB. Was there an error message right before the crash?
    -Daolin
  • Hi Daolin,
    I agree it shouldn't have crashed. I don't have a copy of the error but it was loading a firmware image onto the R5 core I think.
    Jon
  • Hi Jon,
    Thanks for clarifying, are you able to reboot with the RT-Linux version and share the error log?
    -Daolin
  • Ho Daolin,
    Is there a zip of the RT kernel filesystem image available somewhere ? I don't wish to reflash everything with the wic image right at the moment but may be able to in a few days.
    Jon
  • Hi Jon,
    You can find the tar.xz RT kernel filesystem in your <TI Processor RT-Linux SDK installation path>/filesystem/am64xxx-evm/
    ~/ti-processor-sdk-linux-rt-am64xx-evm-10.00.07.04/filesystem/am64xx-evm$ ls
    tisdk-base-image-rt-am64xx-evm.rootfs.tar.xz  tisdk-default-image-rt-am64xx-evm.rootfs.tar.xz  tisdk-thinlinux-image-rt-am64xx-evm.rootfs.tar.xz
    We are still working on trying to fix the issue on non-RT version, but this might take some time so as I mentioned before, if you need to use non-RT because of this RT version crash, you could use the workaround I mentioned before.
    -Daolin
  • Hi Daolin,
    I have reflashed tisdk-default-image-rt-am64xx-evm.rootfs.tar.xz together with our current dtb and it boots to the login prompt so I am unable to reproduce the previous crash but I can confirm that it boots with the RT kernel.
    Jon
  • Hi Jon, just to confirm, are you good for now with RT linux?.
    thank you,
    Paula
  • Hello Jon,
    Can you clarify if using the RT Linux image resolves the issue of eth1 not showing up?
    -Daolin
  • Hi both,
    Yes, I can confirm that eth1 comes up with the rt linux image.
    Jon
  • Hi Jon,
    Thanks for clarifying. Internally we are working to fix the eth1 issue on non-RT Linux SDK image, but I believe you are unblocked on your side by using RT-Linux.
    -Daolin
