Part Number: PROCESSOR-SDK-J721S2
How to boot j721s2 board with a Bootable USB device?
what are pin settings for booting from usb?
Is there support in SBL needed?
Hi krishnan,
There is no driver support for USB in SBL.
Only DFU boot mode is supported using USB interface
For pin configuration please check "Boot Mode Pins" chapter of the TRM.If you are using EVM you can use below DIP switch configuration
Ref:https://www.ti.com/lit/an/spracy5/spracy5.pdf?ts=1729574580384
Diwakar
Hi Diwakar,
We are tried to use this DFU mode flashing. But we are getting below errors while loading the binary:
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
dfu-util: No DFU capable USB device available
Please let me know the solution on the same
Thanks in advance
Salih
Hi Salih
As you can seen your HOST is unable to see any available dfu device did you make sure you are using correct boot pin configuration ?
Are you using custom board or TI EVM.
Diwakar
Hi Diwakar,
Thanks for your inputs. We have tried with the procedures as mentioned in the document and I have changed boot switch for DFU.
The DFU is detected in our host and we can able to boot it at first time. When we tried to flash it in OSPI, we are failed to do it. Since the DFU USB is not detecting after the below commands fired on the EVM board:
Please give your inputs on the same. We have set the below switch settings for DFU
Salih
Hi Salih,
Can you raise the new thread for this as the original question is already answered.
Diwakar
