Part Number: PROCESSOR-SDK-AM62A
Other Parts Discussed in Thread: SK-AM62A-LP
I am using SDK 10.00.00 in SK-AM62A-LP board.
In that, deep sleep is not working.
Initially, there was an issue with JPEG Encoder, which is giving kernel panic when suspended.
By default, logs won't be visible. To get detailed logs, I have added following bootargs in the U-Boot
=> setenv optargs "sysrq_always_enabled earlyprintk debug no_console_suspend"
Here is the detailed error message:
root@am62axx-evm:/opt/edgeai-gst-apps# echo mem > /sys/power/state [ 45.252250] PM: suspend entry (deep) [ 45.403617] Filesystems sync: 0.147 seconds [ 45.410029] Freezing user space processes [ 45.415619] Freezing user space processes completed (elapsed 0.001 seconds) [ 45.422602] OOM killer disabled. [ 45.425831] Freezing remaining freezable tasks [ 45.431536] Freezing remaining freezable tasks completed (elapsed 0.001 seconds) [ 45.453252] ti-sci 44043000.system-controller: ti_sci_cmd_set_device_constraint: device: 179: state: 1: ret 0 [ 45.463307] ti-sci 44043000.system-controller: ti_sci_cmd_set_device_constraint: device: 178: state: 1: ret 0 [ 45.476819] ti-sci 44043000.system-controller: ti_sci_cmd_set_device_constraint: device: 117: state: 1: ret 0 [ 46.507498] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_suspend+0x160/0x1a4) [ 46.516993] ti-sci 44043000.system-controller: Mbox send fail -110 [ 46.523170] ti-sci 44043000.system-controller: PM: dpm_run_callback(): platform_pm_suspend+0x0/0x6c returns -110 [ 46.533341] ti-sci 44043000.system-controller: PM: failed to suspend: error -110 [ 46.540731] PM: Some devices failed to suspend, or early wake event detected [ 46.547791] Internal error: synchronous external abort: 0000000096000010 [#1] PREEMPT SMP [ 46.555953] Modules linked in: snd_soc_hdmi_codec rpmsg_ctrl rpmsg_char overlay crct10dif_ce snd_soc_simple_card snd_soc_simple_card_utils e5010_jpeg_enc cfg80211 display_connector v4l2_jpeg k3_j72xx_bandgap rtc_ti_k3 rti_wdt bluetooth ecdh_generic ecc rfkill wave5 videobuf2_dma_contig videobuf2_memops ti_k3_r5_remoteproc v4l2_mem2mem ti_k3_dsp_remoteproc videobuf2_v4l2 videobuf2_common videodev mc sa2ul mcrc64 snd_soc_davinci_mcasp tidss snd_soc_ti_udma snd_soc_ti_edma snd_soc_ti_sdma drm_dma_helper sii902x snd_soc_tlv320aic3x_i2c snd_soc_tlv320aic3x drm_kms_helper tps6598x typec cryptodev(O) fuse drm drm_panel_orientation_quirks backlight ipv6 [ 46.613137] CPU: 2 PID: 1375 Comm: sh Tainted: G O 6.6.32-ti-gdb8871293143-dirty #1 [ 46.622165] Hardware name: Texas Instruments AM62A7 SK (DT) [ 46.627722] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 46.634669] pc : e5010_hw_bypass_mmu+0x4/0x28 [e5010_jpeg_enc] [ 46.640504] lr : e5010_init_device+0x20/0x134 [e5010_jpeg_enc] [ 46.646331] sp : ffff8000825cbac0 [ 46.649634] x29: ffff8000825cbac0 x28: ffff00080ad88000 x27: 0000000000000000 [ 46.656760] x26: 0000000000000000 x25: ffff8000814007c8 x24: ffff8000813472c8 [ 46.663884] x23: ffff8000806eba2c x22: 0000000000000000 x21: ffff00080163a280 [ 46.671009] x20: ffff00080015d410 x19: ffff00080163a280 x18: 0000000000000006 [ 46.678134] x17: 7463657465642074 x16: 6e65766520656b61 x15: ffff8000825cb620 [ 46.685258] x14: 0000000000000000 x13: ffff80008127f178 x12: 0000000000000ac8 [ 46.692382] x11: 0000000000000398 x10: ffff8000812d7178 x9 : ffff80008127f178 [ 46.699507] x8 : 00000000ffffefff x7 : 0000000000019a27 x6 : 000000e7f43ca808 [ 46.706631] x5 : 03ffffffffffffff x4 : 0038be5e00000000 x3 : 0000000000000018 [ 46.713756] x2 : 00000000000028ec x1 : 0000000000000001 x0 : ffff8000820d1270 [ 46.720881] Call trace: [ 46.723317] e5010_hw_bypass_mmu+0x4/0x28 [e5010_jpeg_enc] [ 46.728799] e5010_resume+0x30/0x80 [e5010_jpeg_enc] [ 46.733759] pm_generic_resume+0x2c/0x44 [ 46.737675] ti_sci_pd_resume+0x20/0x2c [ 46.741503] __device_resume+0x84/0x230 [ 46.745333] dpm_resume+0x9c/0x124 [ 46.748728] dpm_resume_end+0x18/0x30 [ 46.752384] suspend_devices_and_enter+0x1b0/0x550 [ 46.757166] pm_suspend+0x1ac/0x260 [ 46.760645] state_store+0x80/0xec [ 46.764041] kobj_attr_store+0x18/0x2c [ 46.767784] sysfs_kf_write+0x44/0x54 [ 46.771441] kernfs_fop_write_iter+0x120/0x1cc [ 46.775874] vfs_write+0x1c0/0x300 [ 46.779270] ksys_write+0x74/0x10c [ 46.782664] __arm64_sys_write+0x1c/0x28 [ 46.786579] invoke_syscall+0x48/0x114 [ 46.790322] el0_svc_common.constprop.0+0xc0/0xe0 [ 46.795016] do_el0_svc+0x1c/0x28 [ 46.798323] el0_svc+0x2c/0x84 [ 46.801369] el0t_64_sync_handler+0x120/0x12c [ 46.805717] el0t_64_sync+0x190/0x194 [ 46.809374] Code: 9124e021 95ba5b8e 17ffffe8 9101c000 (b9400002) [ 46.815452] ---[ end trace 0000000000000000 ]---
Next time, I removed the jpeg encoder module and tried deep sleep. I am getting the following error continuously
root@am62axx-evm:/opt/edgeai-gst-apps# root@am62axx-evm:/opt/edgeai-gst-apps# modprobe -rf e5010_jpeg_enc root@am62axx-evm:/opt/edgeai-gst-apps# echo mem > /sys/power/state [ 90.115761] PM: suspend entry (deep) [ 90.128252] Filesystems sync: 0.008 seconds [ 90.134664] Freezing user space processes [ 90.140287] Freezing user space processes completed (elapsed 0.001 seconds) [ 90.147267] OOM killer disabled. [ 90.150495] Freezing remaining freezable tasks [ 90.156198] Freezing remaining freezable tasks completed (elapsed 0.001 seconds) [ 90.174458] ti-sci 44043000.system-controller: ti_sci_cmd_set_device_constraint: device: 179: state: 1: ret 0 [ 90.184520] ti-sci 44043000.system-controller: ti_sci_cmd_set_device_constraint: device: 178: state: 1: ret 0 [ 90.198030] ti-sci 44043000.system-controller: ti_sci_cmd_set_device_constraint: device: 117: state: 1: ret 0 [ 91.211524] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_suspend+0x160/0x1a4) [ 91.221030] ti-sci 44043000.system-controller: Mbox send fail -110 [ 91.227209] ti-sci 44043000.system-controller: PM: dpm_run_callback(): platform_pm_suspend+0x0/0x6c returns -110 [ 91.237380] ti-sci 44043000.system-controller: PM: failed to suspend: error -110 [ 91.244772] PM: Some devices failed to suspend, or early wake event detected [ 92.267515] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x24) [ 92.278305] ti-sci 44043000.system-controller: Mbox send fail -110 [ 92.284484] spi-nand spi0.0: resume failed with -110 [ 93.291518] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_ringacc_ring_cfg_sci+0x94/0xf8) [ 93.301636] ti-sci 44043000.system-controller: RM_RA:Mbox config send fail -110 [ 93.308941] ti-udma 485c0000.dma-controller: TISCI config ring fail (-110) ring_idx 19 [ 93.316859] am65-cpsw-nuss 8000000.ethernet: Failed to cfg ringtx -110 [ 93.323479] am65-cpsw-nuss 8000000.ethernet: error -ETIMEDOUT: Failed to request tx dma channel [ 93.332184] am65-cpsw-nuss 8000000.ethernet: PM: dpm_run_callback(): ti_sci_pd_resume+0x0/0x2c returns -110 [ 93.341922] am65-cpsw-nuss 8000000.ethernet: PM: failed to resume: error -110 [ 94.379512] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_clock+0x28/0x34) [ 94.389339] ti-sci 44043000.system-controller: Mbox send fail -110 [ 95.403512] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_clock+0x28/0x34) [ 95.413338] ti-sci 44043000.system-controller: Mbox send fail -110 [ 96.427514] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_clock+0x28/0x34) [ 96.437346] ti-sci 44043000.system-controller: Mbox send fail -110 [ 96.443529] sdhci-am654 fa10000.mmc: PM: dpm_run_callback(): ti_sci_pd_resume+0x0/0x2c returns -110 [ 96.452571] sdhci-am654 fa10000.mmc: PM: failed to resume: error -110 [ 97.483512] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_clock+0x28/0x34) [ 97.493341] ti-sci 44043000.system-controller: Mbox send fail -110 [ 97.499523] sdhci-am654 fa00000.mmc: PM: dpm_run_callback(): ti_sci_pd_resume+0x0/0x2c returns -110 [ 97.508564] sdhci-am654 fa00000.mmc: PM: failed to resume: error -110 [ 98.539512] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x68/0xec) [ 98.549518] ti-sci 44043000.system-controller: Mbox send fail -110 [ 98.555695] ti-sci-clk 44043000.system-controller:clock-controller: determine-rate failed for dev=135, clk=0, ret=-110 [ 99.595511] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x68/0xec) [ 99.605510] ti-sci 44043000.system-controller: Mbox send fail -110 [ 99.611689] ti-sci-clk 44043000.system-controller:clock-controller: determine-rate failed for dev=135, clk=0, ret=-110 [ 100.651511] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x68/0xec) [ 100.661509] ti-sci 44043000.system-controller: Mbox send fail -110 [ 100.667685] ti-sci-clk 44043000.system-controller:clock-controller: determine-rate failed for dev=135, clk=0, ret=-110 [ 100.678369] cpu cpu0: _opp_config_clk_single: failed to set clock rate: -22 [ 100.685324] cpufreq: __target_index: Failed to change cpu frequency: -22 [ 100.692980] OOM killer enabled. [ 100.696151] Restarting tasks ... done. [ 100.701483] random: crng reseeded on system resumption [ 100.706875] PM: suspend exit -sh: echo: write error: Connection timed out root@am62axx-evm:/opt/edgeai-gst-apps# [ 100.732029] systemd-journald[126]: Sent WATCHDOG=1 notification. [ 101.707533] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_clock+0x28/0x34) [ 101.717396] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24) [ 101.727308] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24) [ 101.737220] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24) [ 101.747138] ti-sci 44043000.system-controller: Mbox send fail -110 [ 101.753324] ti-sci 44043000.system-controller: Mbox send fail -110 [ 101.759535] ti-sci 44043000.system-controller: Mbox send fail -110 [ 101.765766] ti-sci 44043000.system-controller: Mbox send fail -110 [ 102.795521] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24) [ 102.805465] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_clock+0x18/0x24) [ 102.815295] ti-sci 44043000.system-controller: Mbox send fail -110 [ 102.821476] ti-sci 44043000.system-controller: Mbox send fail -110 [ 102.827740] ti-sci-clk 44043000.system-controller:clock-controller: unprepare failed for dev=186, clk=6, ret=-110 [ 103.851543] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24) [ 103.861487] ti-sci 44043000.system-controller: Mbox send fail -110 [ 104.875521] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24) [ 104.885467] ti-sci 44043000.system-controller: Mbox send fail -110 root@am62axx-evm:/opt/edgeai-gst-apps# root@am62axx-evm:/opt/edgeai-gst-apps# root@am62axx-evm:/opt/edgeai-gst-apps# root@am62axx-evm:/opt/edgeai-gst-apps# root@am62axx-evm:/opt/edgeai-gst-apps# root@am62axx-evm:/opt/edgeai-gst-apps# [ 113.067501] mmc1: Timeout waiting for hardware cmd interrupt. [ 113.073255] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 113.079680] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 113.086106] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 113.092530] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 113.098954] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 113.105379] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 113.111803] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 113.118228] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 113.124653] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 113.131077] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 113.137502] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 113.143927] mmc1: sdhci: Cmd: 0x00000000 | Max curr: 0x00000000 [ 113.150352] mmc1: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000 [ 113.156775] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 113.163198] mmc1: sdhci: Host ctl2: 0x00000000 [ 113.167629] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 113.174746] mmc1: sdhci: ============================================ root@am62axx-evm:/opt/edgeai-gst-apps# [ 123.307502] mmc1: Timeout waiting for hardware cmd interrupt. [ 123.313254] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 123.319678] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 123.326103] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 123.332527] mmc1: sdhci: Argument: 0x000001aa | Trn mode: 0x00000000 [ 123.338950] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 123.345374] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 123.351798] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 123.358223] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 123.364647] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 123.371071] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 123.377495] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 123.383919] mmc1: sdhci: Cmd: 0x0000081a | Max curr: 0x00000000 [ 123.390344] mmc1: sdhci: Resp[0]: 0x000001aa | Resp[1]: 0x00000000 [ 123.396769] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 123.403194] mmc1: sdhci: Host ctl2: 0x00000000 [ 123.407624] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 123.414741] mmc1: sdhci: ============================================ root@am62axx-evm:/opt/edgeai-gst-apps# root@am62axx-evm:/opt/edgeai-gst-apps# root@am62axx-evm:/opt/edgeai-gst-apps# [ 133.547504] mmc1: Timeout waiting for hardware cmd interrupt. [ 133.553258] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 133.559682] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 133.566107] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 133.572531] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 133.578956] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 133.585380] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 133.591805] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 133.598228] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 133.604653] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 133.611076] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 133.617500] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 133.623925] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00000000 [ 133.630350] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 133.636774] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 133.643199] mmc1: sdhci: Host ctl2: 0x00000000 [ 133.647629] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 133.654746] mmc1: sdhci: ============================================ [ 143.787503] mmc1: Timeout waiting for hardware cmd interrupt. [ 143.793257] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 143.799682] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 143.806108] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 143.812532] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 143.818957] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 143.825381] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 143.831805] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 143.838229] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 143.844652] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 143.851077] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 143.857501] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 143.863926] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00000000 [ 143.870349] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 143.876773] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 143.883198] mmc1: sdhci: Host ctl2: 0x00000000 [ 143.887627] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 143.894745] mmc1: sdhci: ============================================ [ 154.027502] mmc1: Timeout waiting for hardware cmd interrupt. [ 154.033255] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 154.039680] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 154.046106] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 154.052529] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 154.058953] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 154.065377] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 154.071801] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 154.078226] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 154.084651] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 154.091074] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 154.097498] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 154.103922] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00000000 [ 154.110346] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 154.116771] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 154.123196] mmc1: sdhci: Host ctl2: 0x00000000 [ 154.127625] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 154.134743] mmc1: sdhci: ============================================ [ 164.267501] mmc1: Timeout waiting for hardware cmd interrupt. [ 164.273256] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 164.279680] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 164.286105] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 164.292530] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 164.298954] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 164.305379] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 164.311804] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 164.318228] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 164.324653] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 164.331078] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 164.337502] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 164.343926] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00000000 [ 164.350350] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 164.356774] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 164.363198] mmc1: sdhci: Host ctl2: 0x00000000 [ 164.367628] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 164.374745] mmc1: sdhci: ============================================ [ 164.382617] mmc1: error -110 doing runtime resume [ 174.507502] mmc1: Timeout waiting for hardware cmd interrupt. [ 174.513255] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 174.519679] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 174.526105] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 174.532530] mmc1: sdhci: Argument: 0xaaaa0000 | Trn mode: 0x00000000 [ 174.538955] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 174.545379] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 174.551804] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 174.558228] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 174.564651] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 174.571076] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 174.577500] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 174.583925] mmc1: sdhci: Cmd: 0x00000d1a | Max curr: 0x00000000 [ 174.590349] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 174.596772] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 174.603197] mmc1: sdhci: Host ctl2: 0x00000000 [ 174.607628] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 174.614745] mmc1: sdhci: ============================================ [ 184.747501] mmc1: Timeout waiting for hardware cmd interrupt. [ 184.753254] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 184.759679] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 184.766104] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 184.772528] mmc1: sdhci: Argument: 0xaaaa0000 | Trn mode: 0x00000000 [ 184.778953] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 184.785377] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 184.791801] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 184.798225] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 184.804649] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 184.811074] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 184.817498] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 184.823922] mmc1: sdhci: Cmd: 0x00000d1a | Max curr: 0x00000000 [ 184.830345] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 184.836769] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 184.843192] mmc1: sdhci: Host ctl2: 0x00000000 [ 184.847623] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 184.854741] mmc1: sdhci: ============================================ [ 191.236309] systemd-journald[126]: Sent WATCHDOG=1 notification. [ 194.987503] mmc1: Timeout waiting for hardware cmd interrupt. [ 194.993258] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 194.999683] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 195.006108] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 195.012532] mmc1: sdhci: Argument: 0xaaaa0000 | Trn mode: 0x00000000 [ 195.018956] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 195.025381] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 195.031805] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 195.038230] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 195.044654] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 195.051078] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 195.057503] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 195.063929] mmc1: sdhci: Cmd: 0x00000d1a | Max curr: 0x00000000 [ 195.070353] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 195.076777] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 195.083201] mmc1: sdhci: Host ctl2: 0x00000000 [ 195.087631] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 195.094749] mmc1: sdhci: ============================================ [ 205.227502] mmc1: Timeout waiting for hardware cmd interrupt. [ 205.233254] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 205.239678] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 205.246103] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 205.252527] mmc1: sdhci: Argument: 0xaaaa0000 | Trn mode: 0x00000000 [ 205.258952] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 205.265377] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 205.271802] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 205.278226] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 205.284650] mmc1: sdhci: Int enab: 0x00000000 | Sig enab: 0x00000000 [ 205.291074] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 205.297498] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 205.303922] mmc1: sdhci: Cmd: 0x00000d1a | Max curr: 0x00000000 [ 205.310346] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 205.316770] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 205.323194] mmc1: sdhci: Host ctl2: 0x00000000 [ 205.327626] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 205.334743] mmc1: sdhci: ============================================ [ 205.342620] mmc1: card aaaa removed [ 205.342624] I/O error, dev mmcblk1, sector 9013120 op 0x1:(WRITE) flags 0x9800 phys_seg 2 prio class 2 [ 205.355488] Aborting journal on device mmcblk1p2-8. [ 205.360497] JBD2: I/O error when updating journal superblock for mmcblk1p2-8. [ 205.469096] EXT4-fs (mmcblk1p2): shut down requested (2) [ 205.660492] irq 537: nobody cared (try booting with the "irqpoll" option) [ 205.667290] CPU: 0 PID: 456 Comm: dbus-broker Tainted: G O 6.6.32-ti-gdb8871293143-dirty #1 [ 205.677013] Hardware name: Texas Instruments AM62A7 SK (DT) [ 205.682570] Call trace: [ 205.685006] dump_backtrace+0x90/0xe8 [ 205.688669] show_stack+0x18/0x24 [ 205.691979] dump_stack_lvl+0x48/0x60 [ 205.695633] dump_stack+0x18/0x24 [ 205.698938] __report_bad_irq+0x38/0xe0 [ 205.702767] note_interrupt+0x310/0x360 [ 205.706593] handle_irq_event+0x9c/0xa8 [ 205.710422] handle_fasteoi_irq+0xa4/0x230 [ 205.714509] generic_handle_domain_irq+0x2c/0x44 [ 205.719119] gic_handle_irq+0x50/0x12c [ 205.722859] do_interrupt_handler+0x50/0x8c [ 205.727032] el1_interrupt+0x34/0x68 [ 205.730599] el1h_64_irq_handler+0x18/0x24 [ 205.734686] el1h_64_irq+0x64/0x68 [ 205.738079] __do_softirq+0xa0/0x26c [ 205.741644] ____do_softirq+0x10/0x1c [ 205.745297] call_on_irq_stack+0x24/0x4c [ 205.749210] do_softirq_own_stack+0x1c/0x2c [ 205.753382] irq_exit_rcu+0xc0/0xdc [ 205.756863] el0_interrupt+0x50/0xd4 [ 205.760428] __el0_irq_handler_common+0x18/0x24 [ 205.764948] el0t_64_irq_handler+0x10/0x1c [ 205.769034] el0t_64_irq+0x190/0x194 [ 205.772601] handlers: [ 205.774864] [<000000008f682cfd>] sdhci_irq threaded [<000000004a2a5f76>] sdhci_thread_irq [ 205.783044] Disabling IRQ #537 [ 207.627523] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24) [ 207.637469] ti-sci 44043000.system-controller: Mbox send fail -110 [ 215.723501] mmc1: Timeout waiting for hardware cmd interrupt. [ 215.729257] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 215.735682] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 215.742110] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 215.748539] mmc1: sdhci: Argument: 0x00000c00 | Trn mode: 0x00000000 [ 215.754967] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 215.761396] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 215.767823] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 215.774249] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018000 [ 215.780676] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 215.787103] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 215.793530] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 215.799957] mmc1: sdhci: Cmd: 0x0000341a | Max curr: 0x00000000 [ 215.806385] mmc1: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000 [ 215.812811] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 215.819235] mmc1: sdhci: Host ctl2: 0x00000000 [ 215.823665] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 215.830783] mmc1: sdhci: ============================================ [ 225.963502] mmc1: Timeout waiting for hardware cmd interrupt. [ 225.969255] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 225.975679] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 225.982105] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 225.988532] mmc1: sdhci: Argument: 0x80000c08 | Trn mode: 0x00000000 [ 225.994961] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 226.001390] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 226.007817] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 226.014246] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018000 [ 226.020672] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 226.027100] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 226.033527] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 226.039954] mmc1: sdhci: Cmd: 0x0000341a | Max curr: 0x00000000 [ 226.046380] mmc1: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000 [ 226.052807] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 226.059233] mmc1: sdhci: Host ctl2: 0x00000000 [ 226.063664] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 226.070782] mmc1: sdhci: ============================================ [ 236.203501] mmc1: Timeout waiting for hardware cmd interrupt. [ 236.209257] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 236.215682] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 236.222107] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 236.228532] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 236.234957] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 236.241383] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 236.247811] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 236.254238] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018001 [ 236.260666] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 236.267093] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 236.273520] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 236.279946] mmc1: sdhci: Cmd: 0x00000000 | Max curr: 0x00000000 [ 236.286374] mmc1: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000 [ 236.292800] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 236.299226] mmc1: sdhci: Host ctl2: 0x00000000 [ 236.303659] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 236.310779] mmc1: sdhci: ============================================ [ 246.443502] mmc1: Timeout waiting for hardware cmd interrupt. [ 246.449253] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 246.455677] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 246.462102] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 246.468526] mmc1: sdhci: Argument: 0x000001aa | Trn mode: 0x00000000 [ 246.474951] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 246.481375] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 246.487801] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 246.494230] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018001 [ 246.500657] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 246.507085] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 246.513512] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 246.519938] mmc1: sdhci: Cmd: 0x0000081a | Max curr: 0x00000000 [ 246.526366] mmc1: sdhci: Resp[0]: 0x000001aa | Resp[1]: 0x00000000 [ 246.532793] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 246.539220] mmc1: sdhci: Host ctl2: 0x00000000 [ 246.543653] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 246.550774] mmc1: sdhci: ============================================ [ 256.683502] mmc1: Timeout waiting for hardware cmd interrupt. [ 256.689255] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 256.695680] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 256.702105] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 256.708529] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 256.714953] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 256.721378] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 256.727802] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 256.734226] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018000 [ 256.740652] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 256.747079] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 256.753508] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 256.759935] mmc1: sdhci: Cmd: 0x00000502 | Max curr: 0x00000000 [ 256.766363] mmc1: sdhci: Resp[0]: 0x000001aa | Resp[1]: 0x00000000 [ 256.772790] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 256.779217] mmc1: sdhci: Host ctl2: 0x00000000 [ 256.783650] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 256.790771] mmc1: sdhci: ============================================ [ 265.741795] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10923 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 265.762938] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 265.777533] systemd-journald[126]: Rotating... [ 265.783324] systemd-journald[126]: Reserving 333 entries in field hash table. [ 265.796962] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 265.804698] systemd-journald[126]: Vacuuming... [ 265.809824] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 266.923501] mmc1: Timeout waiting for hardware cmd interrupt. [ 266.929257] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 266.935681] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 266.942106] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 266.948530] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 266.954954] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 266.961378] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 266.967803] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 266.974227] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018000 [ 266.980650] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 266.987077] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 266.993504] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 266.999931] mmc1: sdhci: Cmd: 0x00000502 | Max curr: 0x00000000 [ 267.006358] mmc1: sdhci: Resp[0]: 0x000001aa | Resp[1]: 0x00000000 [ 267.012784] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 267.019211] mmc1: sdhci: Host ctl2: 0x00000000 [ 267.023644] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 267.030765] mmc1: sdhci: ============================================ [ 277.163503] mmc1: Timeout waiting for hardware cmd interrupt. [ 277.169255] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 277.175679] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 277.182104] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 277.188529] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 277.194954] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 277.201379] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 277.207803] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 277.214227] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018000 [ 277.220650] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 277.227075] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 277.233500] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 277.236048] systemd-journald[126]: Sent WATCHDOG=1 notification. [ 277.239925] mmc1: sdhci: Cmd: 0x00000502 | Max curr: 0x00000000 [ 277.239930] mmc1: sdhci: Resp[0]: 0x000001aa | Resp[1]: 0x00000000 [ 277.239935] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 277.239939] mmc1: sdhci: Host ctl2: 0x00000000 [ 277.239943] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 277.239948] mmc1: sdhci: ============================================ [ 287.403502] mmc1: Timeout waiting for hardware cmd interrupt. [ 287.409256] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 287.415680] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 287.422106] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 287.428530] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 287.434956] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 287.441380] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 287.447804] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 287.454229] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018000 [ 287.460653] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 287.467078] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 287.473501] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 287.479926] mmc1: sdhci: Cmd: 0x00000502 | Max curr: 0x00000000 [ 287.486349] mmc1: sdhci: Resp[0]: 0x000001aa | Resp[1]: 0x00000000 [ 287.492774] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 287.499199] mmc1: sdhci: Host ctl2: 0x00000000 [ 287.503630] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 287.510747] mmc1: sdhci: ============================================ [ 297.643502] mmc1: Timeout waiting for hardware cmd interrupt. [ 297.649256] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 297.655680] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 297.662106] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 297.668530] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 297.674955] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 297.681379] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 297.687803] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 297.694227] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018001 [ 297.700651] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 297.707076] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 297.713499] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 297.719924] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00000000 [ 297.726347] mmc1: sdhci: Resp[0]: 0x00400120 | Resp[1]: 0x00000000 [ 297.732772] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 297.739196] mmc1: sdhci: Host ctl2: 0x00000000 [ 297.743626] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 297.750743] mmc1: sdhci: ============================================ [ 307.883503] mmc1: Timeout waiting for hardware cmd interrupt. [ 307.889257] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 307.895682] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 307.902108] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 307.908532] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 307.914956] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 307.921380] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 307.927805] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 307.934229] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018001 [ 307.940654] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 307.947078] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 307.953502] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 307.959926] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00000000 [ 307.966350] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 307.972774] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 307.979197] mmc1: sdhci: Host ctl2: 0x00000000 [ 307.983627] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 307.990747] mmc1: sdhci: ============================================ [ 313.746508] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10923 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 313.767976] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 313.782766] systemd-journald[126]: Rotating... [ 313.788925] systemd-journald[126]: Reserving 333 entries in field hash table. [ 313.802932] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 313.810899] systemd-journald[126]: Vacuuming... [ 313.816287] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 315.766538] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10923 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 315.787897] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 315.802622] systemd-journald[126]: Rotating... [ 315.808755] systemd-journald[126]: Reserving 333 entries in field hash table. [ 315.822838] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 315.830661] systemd-journald[126]: Vacuuming... [ 315.836101] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 317.803210] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10924 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 317.824393] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 317.839067] systemd-journald[126]: Rotating... [ 317.845139] systemd-journald[126]: Reserving 333 entries in field hash table. [ 317.859223] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 317.867304] systemd-journald[126]: Vacuuming... [ 317.872995] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 318.123531] mmc1: Timeout waiting for hardware cmd interrupt. [ 318.129293] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 318.135724] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 318.142157] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 318.148586] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 318.155015] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 318.161444] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 318.167873] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 318.174302] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018001 [ 318.180731] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 318.187159] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 318.193588] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 318.200016] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00000000 [ 318.206444] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 318.212872] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 318.219299] mmc1: sdhci: Host ctl2: 0x00000000 [ 318.223733] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 318.230857] mmc1: sdhci: ============================================ [ 319.756419] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10925 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 319.777673] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 319.792349] systemd-journald[126]: Rotating... [ 319.798397] systemd-journald[126]: Reserving 333 entries in field hash table. [ 319.812494] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 319.820311] systemd-journald[126]: Vacuuming... [ 319.825810] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 321.765138] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10924 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 321.786542] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 321.801275] systemd-journald[126]: Rotating... [ 321.807377] systemd-journald[126]: Reserving 333 entries in field hash table. [ 321.821502] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 321.829320] systemd-journald[126]: Vacuuming... [ 321.834833] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 323.788248] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10925 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 323.809633] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 323.824671] systemd-journald[126]: Rotating... [ 323.830776] systemd-journald[126]: Reserving 333 entries in field hash table. [ 323.844881] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 323.852757] systemd-journald[126]: Vacuuming... [ 323.858348] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 325.812988] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10924 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 325.834460] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 325.849222] systemd-journald[126]: Rotating... [ 325.855319] systemd-journald[126]: Reserving 333 entries in field hash table. [ 325.869459] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 325.877279] systemd-journald[126]: Vacuuming... [ 325.882915] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 327.813665] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10924 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 327.834837] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 327.849486] systemd-journald[126]: Rotating... [ 327.855644] systemd-journald[126]: Reserving 333 entries in field hash table. [ 327.869900] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 327.877774] systemd-journald[126]: Vacuuming... [ 327.883487] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 328.363544] mmc1: Timeout waiting for hardware cmd interrupt. [ 328.369305] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 328.375733] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 328.382159] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 328.388584] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 328.395009] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 328.401434] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 328.407858] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 328.414283] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018001 [ 328.420707] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 328.427131] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 328.433556] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 328.439980] mmc1: sdhci: Cmd: 0x0000371a | Max curr: 0x00000000 [ 328.446404] mmc1: sdhci: Resp[0]: 0x00000120 | Resp[1]: 0x00000000 [ 328.452828] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 328.459252] mmc1: sdhci: Host ctl2: 0x00000000 [ 328.463682] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 328.470800] mmc1: sdhci: ============================================ [ 329.824080] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10923 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 329.845285] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 329.859934] systemd-journald[126]: Rotating... [ 329.866029] systemd-journald[126]: Reserving 333 entries in field hash table. [ 329.880166] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 329.888015] systemd-journald[126]: Vacuuming... [ 329.893769] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 331.846126] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10924 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 331.867666] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 331.882534] systemd-journald[126]: Rotating... [ 331.888660] systemd-journald[126]: Reserving 333 entries in field hash table. [ 331.902765] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 331.910590] systemd-journald[126]: Vacuuming... [ 331.916578] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 336.036171] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10925 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 336.057470] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 336.072132] systemd-journald[126]: Rotating... [ 336.078228] systemd-journald[126]: Reserving 333 entries in field hash table. [ 336.092350] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 336.100487] systemd-journald[126]: Vacuuming... [ 336.106376] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 338.603533] mmc1: Timeout waiting for hardware cmd interrupt. [ 338.609293] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 338.615720] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 338.622146] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 338.628571] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000 [ 338.634995] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 338.641419] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 338.647843] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07 [ 338.654266] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018000 [ 338.660691] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 338.667115] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 338.673539] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 338.679963] mmc1: sdhci: Cmd: 0x00000102 | Max curr: 0x00000000 [ 338.686387] mmc1: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000 [ 338.692810] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 338.699234] mmc1: sdhci: Host ctl2: 0x00000000 [ 338.703665] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 338.710783] mmc1: sdhci: ============================================ [ 340.614802] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10923 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 340.636366] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 340.651110] systemd-journald[126]: Rotating... [ 340.657136] systemd-journald[126]: Reserving 333 entries in field hash table. [ 340.671259] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 340.679130] systemd-journald[126]: Vacuuming... [ 340.685172] systemd-journald[126]: Vacuuming done, freed 0B of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 340.973793] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24) [ 340.983994] ti-sci 44043000.system-controller: Mbox send fail -110 [ 343.720834] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10924 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 343.742523] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 343.757229] systemd-journald[126]: Rotating... [ 343.763263] systemd-journald[126]: Reserving 333 entries in field hash table. [ 343.777458] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 343.785262] systemd-journald[126]: Vacuuming... [ 343.793004] systemd-journald[126]: Deleted archived journal /run/log/journal/dcf0cae38be14991964b930aef28e870/system@21da31d4abf045158334a40e97eb581a-0000000000000001-000612605255754d.journal (3.1M). [ 343.810805] systemd-journald[126]: Vacuuming done, freed 3.1M of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 345.744956] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10924 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 345.766257] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 345.780956] systemd-journald[126]: Rotating... [ 345.787047] systemd-journald[126]: Reserving 333 entries in field hash table. [ 345.801340] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 345.809160] systemd-journald[126]: Vacuuming... [ 345.816912] systemd-journald[126]: Deleted archived journal /run/log/journal/dcf0cae38be14991964b930aef28e870/system@21da31d4abf045158334a40e97eb581a-00000000000011be-00061260526daeca.journal (3.3M). [ 345.834715] systemd-journald[126]: Vacuuming done, freed 3.3M of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 347.760172] systemd-journald[126]: Data hash table of /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal has a fill level at 75.0 (10923 of 14563 items, 8388608 file size, 767 bytes per hash table item), suggesting rotation. [ 347.781448] systemd-journald[126]: /run/log/journal/dcf0cae38be14991964b930aef28e870/system.journal: Journal header limits reached or header out-of-date, rotating. [ 347.796113] systemd-journald[126]: Rotating... [ 347.802204] systemd-journald[126]: Reserving 333 entries in field hash table. [ 347.816240] systemd-journald[126]: Reserving 14563 entries in data hash table. [ 347.824161] systemd-journald[126]: Vacuuming... [ 347.831839] systemd-journald[126]: Deleted archived journal /run/log/journal/dcf0cae38be14991964b930aef28e870/system@21da31d4abf045158334a40e97eb581a-000000000000220e-000612605282ba63.journal (3.0M). [ 347.849634] systemd-journald[126]: Vacuuming done, freed 3.0M of archived journals from /run/log/journal/dcf0cae38be14991964b930aef28e870. [ 348.843547] mmc1: Timeout waiting for hardware cmd interrupt. [ 348.849310] mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 348.855742] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 348.862173] mmc1: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000 [ 348.868602] mmc1: sdhci: Argument: 0x00000c00 | Trn mode: 0x00000000 [ 348.875031] mmc1: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000000 [ 348.881459] mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 348.887887] mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00004e47 [ 348.894315] mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00018000 [ 348.900742] mmc1: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083 [ 348.907171] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000001 [ 348.913599] mmc1: sdhci: Caps: 0x3de8c801 | Caps_1: 0x18002407 [ 348.920027] mmc1: sdhci: Cmd: 0x0000341a | Max curr: 0x00000000 [ 348.926453] mmc1: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000 [ 348.932881] mmc1: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000 [ 348.939308] mmc1: sdhci: Host ctl2: 0x00000000 [ 348.943742] mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000 [ 348.950864] mmc1: sdhci: ============================================
