I noticed that when I refresh the u-boot and linux git repos that comes with the Linux SDK, I get notified of modified and/or untracked files. But why? I should essentially be getting a code drop from TI's repo right?
Here I am refreshing the u-boot git repo:
amandio@DESKTOP-UJC140B:~/REFERENCE/ti-processor-sdk-linux-edgeai-j721s2-evm-10_00_00_08/board-support/ti-u-boot-2024.04+git$ git status
Refresh index: 100% (20904/20904), done.
On branch ti-u-boot-2024.04
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git restore <file>..." to discard changes in working directory)
modified: configs/am62ax_evm_a53_defconfig
modified: configs/j7200_evm_a72_defconfig
modified: configs/j721e_evm_a72_defconfig
modified: configs/j721s2_evm_a72_defconfig
modified: configs/j722s_evm_a53_defconfig
modified: configs/j784s4_evm_a72_defconfig
modified: net/nfs.c
no changes added to commit (use "git add" and/or "git commit -a")
You can see the list of modified files that is reported when I run git status. Here is a diff of the u-boot changes:
diff --git a/configs/am62ax_evm_a53_defconfig b/configs/am62ax_evm_a53_defconfig
index dd6817a4..331ece6a 100644
--- a/configs/am62ax_evm_a53_defconfig
+++ b/configs/am62ax_evm_a53_defconfig
@@ -44,6 +44,7 @@ CONFIG_SPL_DM_MAILBOX=y
CONFIG_SPL_MTD=y
CONFIG_SPL_MTD_LOAD=y
CONFIG_SYS_MTD_U_BOOT_OFFS=0x280000
+CONFIG_CMD_NFS=y
CONFIG_SPL_NAND_SPI_SUPPORT=y
CONFIG_SPL_DM_SPI_FLASH=y
CONFIG_SPL_POWER_DOMAIN=y
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig
index f15d71cd..3fc57fc2 100644
--- a/configs/j7200_evm_a72_defconfig
+++ b/configs/j7200_evm_a72_defconfig
@@ -72,6 +72,7 @@ CONFIG_CMD_GPT=y
CONFIG_CMD_I2C=y
CONFIG_CMD_MMC=y
CONFIG_CMD_MTD=y
+CONFIG_CMD_NFS=y
CONFIG_CMD_REMOTEPROC=y
CONFIG_CMD_UFS=y
CONFIG_CMD_USB=y
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig
index 789d0abd..fdcdc6c2 100644
--- a/configs/j721e_evm_a72_defconfig
+++ b/configs/j721e_evm_a72_defconfig
@@ -71,6 +71,7 @@ CONFIG_CMD_GPT=y
CONFIG_CMD_I2C=y
CONFIG_CMD_MMC=y
CONFIG_CMD_MTD=y
+CONFIG_CMD_NFS=y
CONFIG_CMD_UFS=y
CONFIG_CMD_USB=y
diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig
index 8f6a69c4..3a4253a8 100644
--- a/configs/j721s2_evm_a72_defconfig
+++ b/configs/j721s2_evm_a72_defconfig
@@ -74,6 +74,7 @@ CONFIG_CMD_GPT=y
CONFIG_CMD_I2C=y
CONFIG_CMD_MMC=y
CONFIG_CMD_MTD=y
+CONFIG_CMD_NFS=y
CONFIG_CMD_UFS=y
CONFIG_CMD_USB=y
diff --git a/configs/j722s_evm_a53_defconfig b/configs/j722s_evm_a53_defconfig
index f807d0f0..44e05cdb 100644
--- a/configs/j722s_evm_a53_defconfig
+++ b/configs/j722s_evm_a53_defconfig
@@ -68,6 +68,7 @@ CONFIG_CMD_GPT=y
CONFIG_CMD_I2C=y
CONFIG_CMD_MMC=y
CONFIG_CMD_MTD=y
+CONFIG_CMD_NFS=y
CONFIG_CMD_USB=y
CONFIG_CMD_USB_MASS_STORAGE=y
diff --git a/configs/j784s4_evm_a72_defconfig b/configs/j784s4_evm_a72_defconfig
index 26a5e363..b080208c 100644
--- a/configs/j784s4_evm_a72_defconfig
+++ b/configs/j784s4_evm_a72_defconfig
@@ -73,6 +73,7 @@ CONFIG_CMD_GPT=y
CONFIG_CMD_I2C=y
CONFIG_CMD_MMC=y
CONFIG_CMD_MTD=y
+CONFIG_CMD_NFS=y
CONFIG_CMD_USB=y
CONFIG_CMD_TIME=y
diff --git a/net/nfs.c b/net/nfs.c
index 7a8887ef..3d25468d 100644
--- a/net/nfs.c
+++ b/net/nfs.c
@@ -212,24 +212,6 @@ static void rpc_req(int rpc_prog, int rpc_proc, uint32_t *data, int datalen)
break;
case PROG_MOUNT:
- switch (choosen_nfs_version) {
- case NFS_V1:
- rpc_pkt.u.call.vers = htonl(1);
- break;
- case NFS_V2:
- rpc_pkt.u.call.vers = htonl(2);
- break;
- case NFS_V3:
- rpc_pkt.u.call.vers = htonl(3);
- break;
- case NFS_UNKOWN:
- /* nothing to do */
- break;
- break;
case PROG_PORTMAP:
default:
rpc_pkt.u.call.vers = htonl(2); /* portmapper is version 2 */
And here I am refreshing the Linux git repo. Here there are modified and untracked files.
amandio@DESKTOP-UJC140B:~/REFERENCE/ti-processor-sdk-linux-edgeai-j721s2-evm-10_00_00_08/board-support/ti-linux-kernel-6.6.32+git-ti$ git status
Refresh index: 100% (82147/82147), done.
On branch ti-linux-6.6.y
modified: arch/arm64/boot/dts/ti/Makefile
modified: arch/arm64/configs/defconfig
modified: drivers/remoteproc/ti_k3_dsp_remoteproc.c
modified: drivers/tty/vt/Makefile
modified: drivers/tty/vt/conmakehash.c
modified: drivers/video/logo/pnmtologo.c
modified: lib/build_OID_registry
Untracked files:
(use "git add <file>..." to include in what will be committed)
arch/arm64/boot/dts/ti/k3-j721s2-edgeai-apps.dtso
arch/arm64/boot/dts/ti/k3-j721s2-rtos-memory-map.dtsi
arch/arm64/boot/dts/ti/k3-j721s2-vision-apps.dtso
And here is the diff from the Linux repo:
diff --git a/arch/arm64/boot/dts/ti/Makefile b/arch/arm64/boot/dts/ti/Makefile
index 649b338fe..a4e85e1dc 100644
--- a/arch/arm64/boot/dts/ti/Makefile
+++ b/arch/arm64/boot/dts/ti/Makefile
@@ -137,6 +137,8 @@ dtb-$(CONFIG_ARCH_K3) += k3-j721s2-evm-gesi-exp-board.dtbo
k3-j721s2-evm-dtbs := k3-j721s2-common-proc-board.dtb k3-j721s2-evm-gesi-exp-board.dtbo
dtb-$(CONFIG_ARCH_K3) += k3-j721s2-evm.dtb
dtb-$(CONFIG_ARCH_K3) += k3-j721s2-evm-pcie1-ep.dtbo
+dtb-$(CONFIG_ARCH_K3) += k3-j721s2-vision-apps.dtbo
+dtb-$(CONFIG_ARCH_K3) += k3-j721s2-edgeai-apps.dtbo
# Boards with J722s SoC
dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm.dtb
diff --git a/arch/arm64/configs/defconfig b/arch/arm64/configs/defconfig
index f8047c965..f3c5421c9 100644
--- a/arch/arm64/configs/defconfig
+++ b/arch/arm64/configs/defconfig
@@ -17,6 +17,8 @@ CONFIG_IKCONFIG_PROC=y
CONFIG_NUMA_BALANCING=y
CONFIG_MEMCG=y
CONFIG_BLK_CGROUP=y
+CONFIG_CFS_BANDWIDTH=y
+CONFIG_RT_GROUP_SCHED=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_HUGETLB=y
@@ -25,7 +27,12 @@ CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_CGROUP_BPF=y
+CONFIG_NAMESPACES=y
+CONFIG_UTS_NS=y
+CONFIG_IPC_NS=y
CONFIG_USER_NS=y
+CONFIG_PID_NS=y
+CONFIG_NET_NS=y
CONFIG_SCHED_AUTOGROUP=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_KALLSYMS_ALL=y
@@ -120,6 +127,7 @@ CONFIG_KVM=y
CONFIG_JUMP_LABEL=y
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
+CONFIG_BLK_DEV_THROTTLING=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
# CONFIG_COMPAT_BRK is not set
CONFIG_MEMORY_HOTPLUG=y
@@ -127,6 +135,9 @@ CONFIG_MEMORY_HOTREMOVE=y
CONFIG_KSM=y
CONFIG_MEMORY_FAILURE=y
CONFIG_TRANSPARENT_HUGEPAGE=y
+CONFIG_XFRM=y
+CONFIG_XFRM_ALGO=y
+CONFIG_XFRM_USER=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_XDP_SOCKETS=y
@@ -134,11 +145,16 @@ CONFIG_IP_MULTICAST=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
+CONFIG_INET_ESP=y
CONFIG_IPV6=m
CONFIG_NETFILTER=y
CONFIG_BRIDGE_NETFILTER=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_CONNTRACK_EVENTS=y
+CONFIG_NF_CONNTRACK_FTP=m
+CONFIG_NF_CONNTRACK_TFTP=m
+CONFIG_NF_NAT_FTP=m
+CONFIG_NF_NAT_TFTP=m
CONFIG_NETFILTER_XT_MARK=m
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
@@ -146,11 +162,16 @@ CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_IP_VS=m
+CONFIG_IP_VS_PROTO_TCP=y
+CONFIG_IP_VS_PROTO_UDP=y
+CONFIG_IP_VS_RR=m
+CONFIG_IP_VS_NFCT=y
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
+CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_FILTER=m
@@ -176,6 +197,7 @@ CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_FLOW=m
+CONFIG_NET_CLS_CGROUP=m
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_CMP=m
@@ -198,6 +220,7 @@ CONFIG_NET_ACT_GATE=m
CONFIG_HSR=m
CONFIG_QRTR_SMD=m
CONFIG_QRTR_TUN=m
+CONFIG_CGROUP_NET_PRIO=y
CONFIG_CAN=m
CONFIG_BT=m
CONFIG_BT_HIDP=m
@@ -339,11 +362,15 @@ CONFIG_PATA_OF_PLATFORM=y
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_BLK_DEV_DM=m
+CONFIG_DM_THIN_PROVISIONING=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
CONFIG_NETDEVICES=y
+CONFIG_DUMMY=m
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
+CONFIG_IPVLAN=m
+CONFIG_VXLAN=m
CONFIG_TUN=y
CONFIG_VETH=m
CONFIG_VIRTIO_NET=y
@@ -1572,7 +1599,10 @@ CONFIG_HTE_TEGRA194=y
CONFIG_HTE_TEGRA194_TEST=m
CONFIG_EXT2_FS=y
CONFIG_EXT3_FS=y
+CONFIG_EXT3_FS_POSIX_ACL=y
+CONFIG_EXT3_FS_SECURITY=y
CONFIG_EXT4_FS_POSIX_ACL=y
+CONFIG_EXT4_FS_SECURITY=y
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
CONFIG_FANOTIFY=y
@@ -1600,6 +1630,7 @@ CONFIG_SECURITY=y
CONFIG_CRYPTO_USER=y
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_ECHAINIV=y
+CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_CRYPTO_USER_API_HASH=m
diff --git a/drivers/remoteproc/ti_k3_dsp_remoteproc.c b/drivers/remoteproc/ti_k3_dsp_remoteproc.c
index 76d12782d..2b25acaad 100644
--- a/drivers/remoteproc/ti_k3_dsp_remoteproc.c
+++ b/drivers/remoteproc/ti_k3_dsp_remoteproc.c
@@ -806,18 +806,16 @@ static int k3_dsp_rproc_probe(struct platform_device *pdev)
} else {
dev_info(dev, "configured DSP for remoteproc mode\n");
- * ensure the DSP local reset is asserted to ensure the DSP
+ * ensure the DSP reset is asserted to ensure the DSP
* doesn't execute bogus code in .prepare() when the module
* reset is released.
- if (data->uses_lreset) {
- ret = reset_control_status(kproc->reset);
- if (ret < 0) {
- return dev_err_probe(dev, ret, "failed to get reset status\n");
- } else if (ret == 0) {
- dev_warn(dev, "local reset is deasserted for device\n");
- k3_dsp_rproc_reset(kproc);
+ ret = reset_control_status(kproc->reset);
+ if (ret < 0) {
+ return dev_err_probe(dev, ret, "failed to get reset status\n");
+ } else if (ret == 0) {
+ dev_warn(dev, "local reset is deasserted for device\n");
+ k3_dsp_rproc_reset(kproc);
diff --git a/drivers/tty/vt/Makefile b/drivers/tty/vt/Makefile
index b3dfe9d57..6ee373677 100644
--- a/drivers/tty/vt/Makefile
+++ b/drivers/tty/vt/Makefile
@@ -15,7 +15,7 @@ clean-files := consolemap_deftbl.c defkeymap.c
hostprogs += conmakehash
quiet_cmd_conmk = CONMK $@
- cmd_conmk = $(obj)/conmakehash $< > $@
+ cmd_conmk = $(obj)/conmakehash $< $(shell basename $<) > $@
$(obj)/consolemap_deftbl.c: $(src)/$(FONTMAPFILE) $(obj)/conmakehash
$(call cmd,conmk)
diff --git a/drivers/tty/vt/conmakehash.c b/drivers/tty/vt/conmakehash.c
index cddd789fe..d62510b28 100644
--- a/drivers/tty/vt/conmakehash.c
+++ b/drivers/tty/vt/conmakehash.c
@@ -253,7 +253,7 @@ int main(int argc, char *argv[])
#include <linux/types.h>\n\
\n\
u8 dfont_unicount[%d] = \n\
-{\n\t", argv[1], fontlen);
+{\n\t", argv[2], fontlen);
for ( i = 0 ; i < fontlen ; i++ )
diff --git a/drivers/video/logo/pnmtologo.c b/drivers/video/logo/pnmtologo.c
index ada5ef6e5..7527be845 100644
--- a/drivers/video/logo/pnmtologo.c
+++ b/drivers/video/logo/pnmtologo.c
@@ -13,7 +13,7 @@
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
+#include <libgen.h>
static const char *programname;
static const char *filename;
@@ -223,6 +223,7 @@ static inline int is_equal(struct color c1, struct color c2)
static void write_header(void)
+ char *filename_basename = basename(filename);
/* open logo file */
if (outputname) {
out = fopen(outputname, "w");
@@ -235,7 +236,7 @@ static void write_header(void)
fputs("/*\n", out);
fputs(" * DO NOT EDIT THIS FILE!\n", out);
fputs(" *\n", out);
- fprintf(out, " * It was automatically generated from %s\n", filename);
+ fprintf(out, " * It was automatically generated from %s\n", filename_basename);
fputs(" *\n", out);
fprintf(out, " * Linux logo %s\n", logoname);
fputs(" */\n\n", out);
diff --git a/lib/build_OID_registry b/lib/build_OID_registry
index d7fc32ea8..f6de0a7f7 100755
--- a/lib/build_OID_registry
+++ b/lib/build_OID_registry
@@ -8,6 +8,7 @@
use strict;
+use File::Basename;
my @names = ();
my @oids = ();
@@ -35,7 +36,7 @@ close IN_FILE || die;
open C_FILE, ">$ARGV[1]" or die;
print C_FILE "/*\n";
-print C_FILE " * Automatically generated by ", $0, ". Do not edit\n";
+print C_FILE " * Automatically generated by ", basename $0, ". Do not edit\n";
print C_FILE " */\n";
I am using v10.00.08 of the Linux SDK. Any reason why files shows up as modified or untracked? Shouldn't the Linux and u-boot source trees match what's in TI's repo at the commit hash/tag?
Thanks!
