TDA4VM: I2C Write Timed Out when using I2C_IRQSTATUS_RAW
Part Number: TDA4VM
Hello TI,
We are using I2C to access PMIC and following the steps in TRM (Figure 12-34. I2C Master Transmitter Mode, Polling Method, in F/S and HS Modes).
During the step to check XRDY flag (I2C_IRQSTATUS_RAW->XRDY) the timed out condition is reached and the transmission is not completed.
But when trying the approach to read the XRDY on the I2C_STAT (even though is a legacy status register) the transmission is completed.
Both registers have the same value, so why does this happen? In TRM it recommends to read I2C_IRQSTATUS_RAW, so why should we read I2C_STAT?
Thank you and Regards,
Marina Prado Lenza
  • Hi Marina,
    Do you mean solely reading the I2C_IRQSTATUS_RAW register causes a time out error on the transmission?
    Have you tested reading the I2C_IRQSTATUS register?
    Neehar
  • Hi Neehar,
    When reading and clearing the I2C_IRQSTATUS_RAW the transmission is never completed. Also when reading and clearing the I2C_IRQSTATUS the transmission is never completed.
    But when clearing I2C_IRQSTATUS and reading I2C_IRQSTATUS_RAW then the transmission is completed.
    In TRM, both registers are R/W and share same values. This lead us to think that this information is not up to date, and I2C_IRQSTATUS is a write register and 2C_IRQSTATUS_RAW is a read register, even though this is not described in the TRM.
    Marina
    I will look into this further and get back to you.
    Neehar
  • Hi Marina,
    How are you reading and clearing the registers? Are you directly reading/writing to the address?
    Please take a look at the following from the TRM:
    Neehar
