Part Number: PROCESSOR-SDK-AM62X
Hii,
I am working on the AM62x processor and I am trying to toggle the GPIO pins. However, after making changes in the k3-am62x-sk-common.dtsi file, I am unable to achieve this. Could you please guide me on how I can toggle the GPIO pins successfully please find the code and output i have attached below can you please suggest how to resolvre the issues...
root@am62xx-evm:~# gpiodetect
gpiochip0 [600000.gpio] (92 lines)
gpiochip1 [601000.gpio] (52 lines)
gpiochip2 [1-0022] (24 lines)
root@am62xx-evm:~# gpioinfo
gpiochip0 - 92 lines:
line 0: unnamed input
line 1: unnamed input
line 2: unnamed input
line 3: unnamed input
line 4: unnamed input
line 5: unnamed input
line 6: unnamed input
line 7: unnamed input
line 8: unnamed input
line 9: unnamed input
line 10: unnamed input
line 11: unnamed input
line 12: unnamed input
line 13: unnamed input
line 14: unnamed input
line 15: unnamed input
line 16: unnamed input
line 17: unnamed input
line 18: unnamed input
line 19: unnamed input
line 20: unnamed input
line 21: unnamed input
line 22: unnamed input
line 23: unnamed input
line 24: unnamed input
line 25: unnamed input
line 26: unnamed input
line 27: unnamed input
line 28: unnamed input
line 29: unnamed input
line 30: unnamed input
line 31: unnamed output consumer=tlv71033
line 32: unnamed input
line 33: unnamed input
line 34: unnamed input
line 35: unnamed input
line 36: unnamed input
line 37: unnamed input
line 38: unnamed input
line 39: unnamed input
line 40: unnamed input
line 41: unnamed input
line 42: unnamed input
line 43: unnamed input
line 44: unnamed input
line 45: unnamed input
line 46: unnamed input
line 47: unnamed input
line 48: unnamed input
line 49: unnamed input
line 50: unnamed input
line 51: unnamed input
line 52: unnamed input
line 53: unnamed input
line 54: unnamed input
line 55: unnamed input
line 56: unnamed input
line 57: unnamed input
line 58: unnamed input
line 59: unnamed input
line 60: unnamed input
line 61: unnamed input
line 62: unnamed input
line 63: unnamed input
line 64: unnamed input
line 65: unnamed input
line 66: unnamed input
line 67: unnamed input
line 68: unnamed input
line 69: unnamed input
line 70: unnamed input
line 71: unnamed output consumer=regulator-7
line 72: unnamed input
line 73: unnamed input
line 74: unnamed input
line 75: unnamed input
line 76: unnamed input
line 77: unnamed input
line 78: unnamed input
line 79: unnamed input
line 80: unnamed input
line 81: unnamed input
line 82: unnamed input
line 83: unnamed input
line 84: unnamed input
line 85: unnamed input
line 86: unnamed input
line 87: unnamed input
line 88: unnamed input
line 89: unnamed input
line 90: unnamed input
line 91: unnamed input
gpiochip1 - 52 lines:
line 31: unnamed input
gpiochip2 - 24 lines:
line 0: "GPIO_CPSW2_RST" input
line 1: "GPIO_CPSW1_RST" input
line 2: "PRU_DETECT" input
line 3: "MMC1_SD_EN" output consumer="regulator-3"
line 4: "VPP_LDO_EN" input
line 5: "EXP_PS_3V3_En" input
line 6: "EXP_PS_5V0_En" input
line 7: "EXP_HAT_DETECT" input
line 8: "GPIO_AUD_RSTn" input
line 9: "GPIO_eMMC_RSTn" input
line 10: "UART1_FET_BUF_EN" input
line 11: "WL_LT_EN" output active-low consumer="regulator-6"
line 12: "GPIO_HDMI_RSTn" input
line 13: "CSI_GPIO1" input
line 14: "CSI_GPIO2" input
line 15: "PRU_3V3_EN" input
line 16: "HDMI_INTn" input consumer="interrupt"
line 17: "PD_I2C_IRQ" input
line 18: "MCASP1_FET_EN" input
line 19: "MCASP1_BUF_BT_EN" input
line 20: "MCASP1_FET_SEL" input
line 21: "UART1_FET_SEL" input
line 22: "TSINT#" input
line 23: "IO_EXP_TEST_LED" input
root@am62xx-evm:~# gpioset gpiochip149=1
gpioset: cannot find line 'gpiochip149'
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~# gpioset gpiochip1 49=1
gpioset: invalid line value: 'gpiochip1'
root@am62xx-evm:~# gpioset gpiochip1 19=1
root@am62xx-evm:~# ls /sys/class/gpio
ls: cannot access '/sys/class/gpio': No such file or directory
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
// SPDX-License-Identifier: GPL-2.0-only OR MIT
* Common dtsi for AM62x SK and derivatives
* Copyright (C) 2021-2024 Texas Instruments Incorporated - https://www.ti.com/
#include <dt-bindings/leds/common.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/net/ti-dp83867.h>
#include "k3-am625.dtsi"
aliases {
serial2 = &main_uart0;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
mmc2 = &sdhci2;
spi0 = &ospi0;
ethernet0 = &cpsw_port1;
ethernet1 = &cpsw_port2;
usb0 = &usb0;
usb1 = &usb1;
chosen {
stdout-path = "serial2:115200n8";
memory@80000000 {
bootph-pre-ram;
device_type = "memory";
/* 2G RAM */
reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
ramoops@9ca00000 {
compatible = "ramoops";
reg = <0x00 0x9ca00000 0x00 0x00100000>;
record-size = <0x8000>;
console-size = <0x8000>;
ftrace-size = <0x00>;
pmsg-size = <0x8000>;
/* global cma region */
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x00 0x8000000>;
linux,cma-default;
secure_tfa_ddr: tfa@9e780000 {
reg = <0x00 0x9e780000 0x00 0x80000>;
alignment = <0x1000>;
no-map;
secure_ddr: optee@9e800000 {
reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
no-map;
wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 {
reg = <0x00 0x9db00000 0x00 0xc00000>;
no-map;
/*leds {
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = <&usr_led_pins_default>;
led-0 {
label = "am62-sk:green:heartbeat_none";
gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "none";
function = LED_FUNCTION_HEARTBEAT;
default-state = "off";
tlv320_mclk: clk-0 {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <12288000>;
codec_audio: sound {
compatible = "simple-audio-card";
simple-audio-card,name = "AM62x-SKEVM";
simple-audio-card,widgets =
"Headphone", "Headphone Jack",
"Line", "Line In",
"Microphone", "Microphone Jack";
simple-audio-card,routing =
"Headphone Jack", "HPLOUT",
"Headphone Jack", "HPROUT",
"LINE1L", "Line In",
"LINE1R", "Line In",
"MIC3R", "Microphone Jack",
"Microphone Jack", "Mic Bias";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound_master>;
simple-audio-card,frame-master = <&sound_master>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp1>;
sound_master: simple-audio-card,codec {
sound-dai = <&tlv320aic3106>;
clocks = <&tlv320_mclk>;
hdmi0: connector-hdmi {
compatible = "hdmi-connector";
label = "hdmi";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&sii9022_out>;
&phy_gmii_sel {
bootph-all;
&main_pmx0 {
/* First pad number is ALW package and second is AMC package */
main_uart0_pins_default: main-uart0-default-pins {
bootph-all;
pinctrl-single,pins = <
AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14/A13) UART0_RXD */
AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14/E11) UART0_TXD */
main_uart1_pins_default: main-uart1-default-pins {
bootph-pre-ram;
AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19/B18) MCASP0_AXR3.UART1_CTSn */
AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19/B17) MCASP0_AXR2.UART1_RTSn */
AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19/D15) MCASP0_AFSR.UART1_RXD */
AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20/D16) MCASP0_ACLKR.UART1_TXD */
main_i2c0_pins_default: main-i2c0-default-pins {
AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16/E12) I2C0_SCL */
AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16/D14) I2C0_SDA */
main_i2c1_pins_default: main-i2c1-default-pins {
bootph-all;
AM62X_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17/A17) I2C1_SCL */
AM62X_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17/A16) I2C1_SDA */
main_i2c2_pins_default: main-i2c2-default-pins {
AM62X_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22/H18) GPMC0_CSn2.I2C2_SCL */
AM62X_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24/H19) GPMC0_CSn3.I2C2_SDA */
main_mmc0_pins_default: main-mmc0-default-pins {
bootph-all;
AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3/V3) MMC0_CMD */
AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1/Y1) MMC0_CLK */
AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2/V2) MMC0_DAT0 */
AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1/V1) MMC0_DAT1 */
AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3/W2) MMC0_DAT2 */
AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4/W1) MMC0_DAT3 */
AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2/Y2) MMC0_DAT4 */
AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1/W3) MMC0_DAT5 */
AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2/W4) MMC0_DAT6 */
AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2/V4) MMC0_DAT7 */
main_mmc1_pins_default: main-mmc1-default-pins {
bootph-all;
AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21/C18) MMC1_CMD */
AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22/A20) MMC1_CLK */
AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22/A19) MMC1_DAT0 */
AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21/B19) MMC1_DAT1 */
AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21/B20) MMC1_DAT2 */
AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22/C19) MMC1_DAT3 */
AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17/C15) MMC1_SDCD */
usr_led_pins_default: usr-led-default-pins {
AM62X_IOPAD(0x244, PIN_OUTPUT, 7) /* (C17/B15) MMC1_SDWP.GPIO1_49 */
mygpio1_pins_default: mygpio1-pins-default {
AM62X_IOPAD(0x01d0, PIN_INPUT, 7) /* (A15) UART0_CTSn.GPIO1_22 */
AM62X_IOPAD(0x0088, PIN_INPUT, 7) /* (L24) GPMC0_OEn_REn.GPIO0_33 */
AM62X_IOPAD(0x01b4, PIN_INPUT, 7) /* (A13) SPI0_CS0.GPIO1_15 */
AM62X_IOPAD(0x01bc, PIN_INPUT, 7) /* (A14) SPI0_CLK.GPIO1_17 */
AM62X_IOPAD(0x01c0, PIN_INPUT, 7) /* (B13) SPI0_D0.GPIO1_18 */
AM62X_IOPAD(0x01c4, PIN_INPUT, 7) /* (B14) SPI0_D1.GPIO1_19 */
AM62X_IOPAD(0x0244, PIN_INPUT, 7) /* (c17) */
AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (l21) */
main_mdio1_pins_default: main-mdio1-default-pins {
AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24/V17) MDIO0_MDC */
AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22/U16) MDIO0_MDIO */
main_rgmii1_pins_default: main-rgmii1-default-pins {
bootph-all;
AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17/W15) RGMII1_RD0 */
AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17/Y16) RGMII1_RD1 */
AM62X_IOPAD(0x154, PIN_INPUT, 0) /* (AB16/AA17) RGMII1_RD2 */
AM62X_IOPAD(0x158, PIN_INPUT, 0) /* (AA15/Y15) RGMII1_RD3 */
AM62X_IOPAD(0x148, PIN_INPUT, 0) /* (AD17/AA16) RGMII1_RXC */
AM62X_IOPAD(0x144, PIN_INPUT, 0) /* (AE17/W14) RGMII1_RX_CTL */
AM62X_IOPAD(0x134, PIN_OUTPUT, 0) /* (AE20/U14) RGMII1_TD0 */
AM62X_IOPAD(0x138, PIN_OUTPUT, 0) /* (AD20/AA19) RGMII1_TD1 */
AM62X_IOPAD(0x13c, PIN_OUTPUT, 0) /* (AE18/Y17) RGMII1_TD2 */
AM62X_IOPAD(0x140, PIN_OUTPUT, 0) /* (AD18/AA18) RGMII1_TD3 */
AM62X_IOPAD(0x130, PIN_OUTPUT, 0) /* (AE19/W16) RGMII1_TXC */
AM62X_IOPAD(0x12c, PIN_OUTPUT, 0) /* (AD19/V15) RGMII1_TX_CTL */
main_usb1_pins_default: main-usb1-default-pins {
AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18/E16) USB1_DRVVBUS */
main_mcasp1_pins_default: main-mcasp1-default-pins {
AM62X_IOPAD(0x090, PIN_INPUT, 2) /* (M24/K17) GPMC0_BE0N_CLE.MCASP1_ACLKX */
AM62X_IOPAD(0x098, PIN_INPUT, 2) /* (U23/P21) GPMC0_WAIT0.MCASP1_AFSX */
AM62X_IOPAD(0x08c, PIN_OUTPUT, 2) /* (L25/J17) GPMC0_WEN.MCASP1_AXR0 */
AM62X_IOPAD(0x084, PIN_INPUT, 2) /* (L23/K20) GPMC0_ADVN_ALE.MCASP1_AXR2 */
main_dss0_pins_default: main-dss0-default-pins {
AM62X_IOPAD(0x100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */
AM62X_IOPAD(0x0f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
AM62X_IOPAD(0x104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */
AM62X_IOPAD(0x0fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */
AM62X_IOPAD(0x0b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */
AM62X_IOPAD(0x0bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */
AM62X_IOPAD(0x0c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */
AM62X_IOPAD(0x0c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */
AM62X_IOPAD(0x0c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */
AM62X_IOPAD(0x0cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */
AM62X_IOPAD(0x0d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */
AM62X_IOPAD(0x0d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */
AM62X_IOPAD(0x0d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */
AM62X_IOPAD(0x0dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */
AM62X_IOPAD(0x0e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */
AM62X_IOPAD(0x0e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */
AM62X_IOPAD(0x0e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */
AM62X_IOPAD(0x0ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */
AM62X_IOPAD(0x0f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */
AM62X_IOPAD(0x0f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */
AM62X_IOPAD(0x05c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */
AM62X_IOPAD(0x060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */
AM62X_IOPAD(0x064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */
AM62X_IOPAD(0x068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */
AM62X_IOPAD(0x06c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */
AM62X_IOPAD(0x070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */
AM62X_IOPAD(0x074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */
AM62X_IOPAD(0x078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */
&main_gpio0 {
pinctrl-0 = <&mygpio1_pins_default>;
status = "okay";
&mcu_pmx0 {
wkup_uart0_pins_default: wkup-uart0-default-pins {
bootph-pre-ram;
AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6/A7) WKUP_UART0_CTSn */
AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4/B4) WKUP_UART0_RTSn */
AM62X_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (B4/B5) WKUP_UART0_RXD */
AM62X_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (C5/C6) WKUP_UART0_TXD */
&wkup_uart0 {
/* WKUP UART0 is used by DM firmware */
bootph-pre-ram;
status = "reserved";
pinctrl-0 = <&wkup_uart0_pins_default>;
&main_uart0 {
bootph-all;
status = "okay";
pinctrl-0 = <&main_uart0_pins_default>;
&main_uart1 {
/* Main UART1 is used by TIFS firmware */
bootph-pre-ram;
pinctrl-0 = <&main_uart1_pins_default>;
&main_i2c0 {
status = "okay";
pinctrl-0 = <&main_i2c0_pins_default>;
clock-frequency = <400000>;
eeprom@51 {
/* AT24C512C-MAHM-T or M24512-DFMC6TG */
compatible = "atmel,24c512";
reg = <0x51>;
typec_pd0: tps6598x@3f {
compatible = "ti,tps6598x";
reg = <0x3f>;
connector {
compatible = "usb-c-connector";
label = "USB-C";
self-powered;
data-role = "dual";
power-role = "sink";
port {
usb_con_hs: endpoint {
remote-endpoint = <&usb0_hs_ep>;
&main_i2c1 {
status = "okay";
pinctrl-0 = <&main_i2c1_pins_default>;
clock-frequency = <100000>;
tlv320aic3106: audio-codec@1b {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x1b>;
ai3x-micbias-vg = <1>; /* 2.0V */
/* Regulators */
AVDD-supply = <&vcc_3v3_sys>;
IOVDD-supply = <&vcc_3v3_sys>;
DRVDD-supply = <&vcc_3v3_sys>;
sii9022: bridge-hdmi@3b {
compatible = "sil,sii9022";
reg = <0x3b>;
interrupt-parent = <&exp1>;
interrupts = <16 IRQ_TYPE_EDGE_FALLING>;
sil,i2s-data-lanes = < 0 >;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
sii9022_in: endpoint {
remote-endpoint = <&dpi1_out>;
port@1 {
reg = <1>;
sii9022_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
&main_i2c2 {
status = "okay";
pinctrl-0 = <&main_i2c2_pins_default>;
&sdhci0 {
bootph-all;
status = "okay";
pinctrl-0 = <&main_mmc0_pins_default>;
disable-wp;
&sdhci1 {
/* SD/MMC */
bootph-all;
status = "okay";
pinctrl-0 = <&main_mmc1_pins_default>;
disable-wp;
&cpsw3g {
bootph-all;
pinctrl-0 = <&main_rgmii1_pins_default>;
&cpsw_port1 {
bootph-all;
phy-mode = "rgmii-rxid";
phy-handle = <&cpsw3g_phy0>;
&cpsw3g_mdio {
bootph-all;
status = "okay";
pinctrl-0 = <&main_mdio1_pins_default>;
cpsw3g_phy0: ethernet-phy@0 {
bootph-all;
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,min-output-impedance;
&mailbox0_cluster0 {
mbox_m4_0: mbox-m4-0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
&usbss0 {
bootph-all;
status = "okay";
ti,vbus-divider;
&usbss1 {
status = "okay";
ti,vbus-divider;
&usb0 {
bootph-all;
usb-role-switch;
port {
usb0_hs_ep: endpoint {
remote-endpoint = <&usb_con_hs>;
&usb1 {
dr_mode = "host";
pinctrl-0 = <&main_usb1_pins_default>;
&mcasp1 {
status = "okay";
pinctrl-0 = <&main_mcasp1_pins_default>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
1 0 2 0
0 0 0 0
0 0 0 0
0 0 0 0
&dss {
status = "okay";
pinctrl-0 = <&main_dss0_pins_default>;
&dss_ports {
/* VP2: DPI Output */
port@1 {
reg = <1>;
dpi1_out: endpoint {
remote-endpoint = <&sii9022_in>;
/* mcu_gpio0 and mcu_gpio_intr are reserved for mcu firmware usage */
&mcu_gpio0 {
&mcu_gpio_intr {
}; root@am62xx-evm:~#
line 11: "WL_LT_EN" output active-low consumer="regu lator-6"
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
root@am62xx-evm:~#
