Part Number: PROCESSOR-SDK-AM62X
Hii,
I am working on the AM62x processor. I connected Wi-Fi to my phone successfully, and now I am trying to connect Bluetooth. However, I am unable to establish the Bluetooth connection. I will attach the code, and I would appreciate it if you could help me correct any mistakes in the code
// SPDX-License-Identifier: GPL-2.0
* AM625 SK: https://www.ti.com/lit/zip/sprr448
* Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
/dts-v1/;
#include "k3-am62x-sk-common.dtsi"
compatible = "ti,am625-sk", "ti,am625";
model = "Texas Instruments AM625 SK";
aliases {
serial4 = &main_uart1;
opp-table {
/* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
opp-1400000000 {
opp-hz = /bits/ 64 <1400000000>;
opp-supported-hw = <0x01 0x0004>;
clock-latency-ns = <6000000>;
memory@80000000 {
device_type = "memory";
/* 2G RAM */
reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
vmain_pd: regulator-0 {
/* TPS65988 PD CONTROLLER OUTPUT */
compatible = "regulator-fixed";
regulator-name = "vmain_pd";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-always-on;
regulator-boot-on;
vcc_5v0: regulator-1 {
/* Output of LM34936 */
regulator-name = "vcc_5v0";
vin-supply = <&vmain_pd>;
regulator-boot-on;
vcc_3v3_sys: regulator-2 {
/* output of LM61460-Q1 */
regulator-name = "vcc_3v3_sys";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
vdd_mmc1: regulator-3 {
/* TPS22918DBVR */
regulator-name = "vdd_mmc1";
regulator-boot-on;
enable-active-high;
vin-supply = <&vcc_3v3_sys>;
gpio = <&exp1 3 GPIO_ACTIVE_HIGH>;
vdd_sd_dv: regulator-4 {
/* Output of TLV71033 */
compatible = "regulator-gpio";
regulator-name = "tlv71033";
pinctrl-names = "default";
pinctrl-0 = <&vdd_sd_dv_pins_default>;
regulator-min-microvolt = <1800000>;
regulator-boot-on;
vin-supply = <&vcc_5v0>;
gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
vcc_1v8: regulator-5 {
/* output of TPS6282518DMQ */
regulator-name = "vcc_1v8";
regulator-max-microvolt = <1800000>;
regulator-boot-on;
wlan_lten: regulator-6 {
regulator-name = "wlan_lten";
/*regulator-always-on;*/
gpios = <&exp1 11 GPIO_ACTIVE_HIGH>;
wlan_en: regulator-7 {
regulator-name = "wlan_en";
vin-supply = <&wlan_lten>;
enable-active-high;
gpios = <&main_gpio0 71 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&wlan_en_pins_default>;
uart_dis: regulator-8 {
regulator-name = "uart_dis";
vin-supply = <&vcc_1v8>;
gpios = <&exp1 21 GPIO_ACTIVE_LOW>;
bt_lten: regulator-9 {
regulator-name = "bt_lten";
gpios = <&exp1 19 GPIO_ACTIVE_HIGH>;
ble_en: regulator-10 {
regulator-name = "ble_en";
vin-supply = <&bt_lten>;
enable-active-high;
gpios = <&mcu_gpio0 1 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&ble_en_pins_default>;
&main_pmx0 {
main_rgmii2_pins_default: main-rgmii2-pins-default {
pinctrl-single,pins = <
AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */
AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */
AM62X_IOPAD(0x18c, PIN_INPUT, 0) /* (AC21) RGMII2_RD2 */
AM62X_IOPAD(0x190, PIN_INPUT, 0) /* (AE22) RGMII2_RD3 */
AM62X_IOPAD(0x180, PIN_INPUT, 0) /* (AD23) RGMII2_RXC */
AM62X_IOPAD(0x17c, PIN_INPUT, 0) /* (AD22) RGMII2_RX_CTL */
AM62X_IOPAD(0x16c, PIN_OUTPUT, 0) /* (Y18) RGMII2_TD0 */
AM62X_IOPAD(0x170, PIN_OUTPUT, 0) /* (AA18) RGMII2_TD1 */
AM62X_IOPAD(0x174, PIN_OUTPUT, 0) /* (AD21) RGMII2_TD2 */
AM62X_IOPAD(0x178, PIN_OUTPUT, 0) /* (AC20) RGMII2_TD3 */
AM62X_IOPAD(0x168, PIN_OUTPUT, 0) /* (AE21) RGMII2_TXC */
AM62X_IOPAD(0x164, PIN_OUTPUT, 0) /* (AA19) RGMII2_TX_CTL */
ospi0_pins_default: ospi0-pins-default {
AM62X_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */
AM62X_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */
AM62X_IOPAD(0x00c, PIN_INPUT, 0) /* (E25) OSPI0_D0 */
AM62X_IOPAD(0x010, PIN_INPUT, 0) /* (G24) OSPI0_D1 */
AM62X_IOPAD(0x014, PIN_INPUT, 0) /* (F25) OSPI0_D2 */
AM62X_IOPAD(0x018, PIN_INPUT, 0) /* (F24) OSPI0_D3 */
AM62X_IOPAD(0x01c, PIN_INPUT, 0) /* (J23) OSPI0_D4 */
AM62X_IOPAD(0x020, PIN_INPUT, 0) /* (J25) OSPI0_D5 */
AM62X_IOPAD(0x024, PIN_INPUT, 0) /* (H25) OSPI0_D6 */
AM62X_IOPAD(0x028, PIN_INPUT, 0) /* (J22) OSPI0_D7 */
AM62X_IOPAD(0x008, PIN_INPUT, 0) /* (J24) OSPI0_DQS */
vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
AM62X_IOPAD(0x007c, PIN_INPUT, 7) /* (P25) GPMC0_CLK.GPIO0_31 */
main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-pins-default {
AM62X_IOPAD(0x01d4, PIN_INPUT, 7) /* (B15) UART0_RTSn.GPIO1_23 */
wlan_en_pins_default: wlan-en-pins-default {
AM62X_IOPAD(0x124, PIN_OUTPUT, 7) /* (A23) MMC2_SDCD.GPIO0_71 */
main_mmc2_pins_default: main-mmc2-pins-default {
AM62X_IOPAD(0x120, PIN_INPUT, 0) /* (C24) MMC2_CMD */
AM62X_IOPAD(0x118, PIN_INPUT, 0) /* (D25) MMC2_CLK */
AM62X_IOPAD(0x114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */
AM62X_IOPAD(0x110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */
AM62X_IOPAD(0x10c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */
AM62X_IOPAD(0x108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */
AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */
main_wlirq_pins_default: main-wlirq-pins-default {
AM62X_IOPAD(0x128, PIN_INPUT, 7) /* (B23) MMC2_SDWP.GPIO0_72 */
&mcu_pmx0 {
mcu_bt_en_pins_default: bt-en-pins-default {
AM62X_MCU_IOPAD(0x000, PIN_OUTPUT, 7) /* MCU_SPI0_CS0.MCU_GPIO0_0 */
&main_i2c1 {
exp1: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "GPIO_CPSW2_RST", "GPIO_CPSW1_RST",
"PRU_DETECT", "MMC1_SD_EN",
"VPP_LDO_EN", "EXP_PS_3V3_En",
"EXP_PS_5V0_En", "EXP_HAT_DETECT",
"GPIO_AUD_RSTn", "GPIO_eMMC_RSTn",
"UART1_FET_BUF_EN", "WL_LT_EN",
"GPIO_HDMI_RSTn", "CSI_GPIO1",
"CSI_GPIO2", "PRU_3V3_EN",
"HDMI_INTn", "PD_I2C_IRQ",
"MCASP1_FET_EN", "MCASP1_BUF_BT_EN",
"MCASP1_FET_SEL", "UART1_FET_SEL",
"TSINT#", "IO_EXP_TEST_LED";
interrupt-parent = <&main_gpio1>;
interrupts = <23 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>;
buf_en {
gpio-hog;
gpios = <10 GPIO_ACTIVE_LOW>;
output-high;
line-name = "UART1_BUF_EN";
&sdhci1 {
vmmc-supply = <&vdd_mmc1>;
vqmmc-supply = <&vdd_sd_dv>;
&sdhci2 {
status = "okay";
vmmc-supply = <&wlan_en>;
pinctrl-0 = <&main_mmc2_pins_default>;
bus-width = <4>;
non-removable;
ti,fails-without-test-cd;
cap-power-off-card;
keep-power-in-suspend;
ti,driver-strength-ohm = <50>;
assigned-clocks = <&k3_clks 157 158>;
assigned-clock-parents = <&k3_clks 157 160>;
#address-cells = <1>;
#size-cells = <0>;
wlcore: wlcore@2 {
compatible = "ti,wl1837";
reg = <2>;
pinctrl-0 = <&main_wlirq_pins_default>;
interrupt-parent = <&main_gpio0>;
interrupts = <72 IRQ_TYPE_EDGE_RISING>;
&cpsw3g {
pinctrl-0 = <&main_rgmii1_pins_default
&main_rgmii2_pins_default>;
cpts@3d000 {
/* MAP HW3_TS_PUSH to GENF1 */
ti,pps = <2 1>;
&cpsw_port2 {
phy-mode = "rgmii-rxid";
phy-handle = <&cpsw3g_phy1>;
&cpsw3g_mdio {
cpsw3g_phy1: ethernet-phy@1 {
reg = <1>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,min-output-impedance;
&mailbox0_cluster0 {
mbox_m4_0: mbox-m4-0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
&ospi0 {
status = "okay";
pinctrl-0 = <&ospi0_pins_default>;
flash@0{
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-tx-bus-width = <8>;
spi-rx-bus-width = <8>;
spi-max-frequency = <25000000>;
cdns,tshsl-ns = <60>;
cdns,tsd2d-ns = <60>;
cdns,tchsh-ns = <60>;
cdns,tslch-ns = <60>;
cdns,read-delay = <4>;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {
label = "ospi.tiboot3";
reg = <0x0 0x80000>;
partition@80000 {
label = "ospi.tispl";
reg = <0x80000 0x200000>;
partition@280000 {
label = "ospi.u-boot";
reg = <0x280000 0x400000>;
partition@680000 {
label = "ospi.env";
reg = <0x680000 0x40000>;
partition@6c0000 {
label = "ospi.env.backup";
reg = <0x6c0000 0x40000>;
partition@800000 {
label = "ospi.rootfs";
reg = <0x800000 0x37c0000>;
partition@3fc0000 {
label = "ospi.phypattern";
reg = <0x3fc0000 0x40000>;
&tlv320aic3106 {
DVDD-supply = <&vcc_1v8>;
#define K3_TS_OFFSET(pa, val) (0x4+(pa)*4) (0x10000 | val)
×ync_router {
status = "okay";
pinctrl-0 = <&cpsw_cpts>;
/* Use Time Sync Router to map GENF1 input to HW3_TS_PUSH output */
cpsw_cpts: cpsw-cpts {
/* pps [cpsw cpts genf1] in17 -> out12 [cpsw cpts hw3_push] */
K3_TS_OFFSET(12, 17)
/dts-v1/;
aliases {
opp-table {
opp-1400000000 {
memory@80000000 {
/* 2G RAM */
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
/* TPS22918DBVR */
regulator-boot-on;
enable-active-high;
regulator-boot-on;
<3300000 0x1>;
regulator-boot-on;
enable-active-high;
enable-active-high;
&main_pmx0 {
&mcu_pmx0 {
&main_i2c1 {
exp1: gpio@22 {
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
buf_en {
gpio-hog;
output-high;
&sdhci1 {
&sdhci2 {
status = "okay";
bus-width = <4>;
non-removable;
cap-power-off-card;
#size-cells = <0>;
wlcore: wlcore@2 {
reg = <2>;
&cpsw3g {
cpts@3d000 {
ti,pps = <2 1>;
&cpsw_port2 {
&cpsw3g_mdio {
reg = <1>;
&ospi0 {
status = "okay";
flash@0{
reg = <0x0>;
partitions {
#size-cells = <1>;
partition@0 {
partition@80000 {
partition@280000 {
partition@680000 {
label = "ospi.env";
partition@6c0000 {
partition@800000 {
partition@3fc0000 {
&tlv320aic3106 {
×ync_router {
status = "okay";
