DRA821U-Q1: Boot linux via MMSCD NOT successful
Part Number: DRA821U-Q1
Hi, TI
SDK: ti-processor-sdk-linux-j7200-evm-10_00_07_03 & ti-processor-sdk-rtos-j7200-evm-10_00_00_03
HW: customer Hardware
    I am trying to boot linux vis MMSCD, and I do follow steps refer to link https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-j7200/10_00_00_03/exports/docs/pdk_j7200_10_00_00_27/docs/userguide/j7200/boot/boot_app.html
But they are not successful and continuously reboot. Bellow are muc log and linux log:
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB1, 14:14:08
Press CTRL-A Z for help on special keys
SBL Revision: 01.00.10.01 (Nov  7 2024 - 18:07:36)
TIFS  ver: 10.0.8--v10.00.08 (Fiery Fox)
Starting Sciserver..... PASSED
MCU R5F App started at 1067 usecs
Loading BootImage
 BootApp_MMCBootImageLate: fp 0x 0x41c08380, fileName is 0:/lateapp1
 Called SBL_MulticoreImageParse, status = 0
BootImage completed, status = 0
SBL_SlaveCoreBoot completed for Core ID#10, Entry point is 0x70014000
SBL_SlaveCoreBoot completed for Core ID#11, Entry point is 0x70016000
Loading BootImage
 BootApp_MMCBootImageLate: fp 0x 0x41c08380, fileName is 0:/atf_optee.appimage
 BootApp_MMCBootImageLate: fp 0x 0x41c08380, fileName is 0:/tikernelimage_linux.appimage
MCU2_0 booted
MCU2_1 booted
 BootApp_MMCBootImageLate: fp 0x 0x41c08380, fileName is 0:/tidtb_linux.appimage
SBL_SlaveCoreBoot completed for Core ID#0, Entry point is 0x70000000
Boot App: Started at 1242 usec
Boot App: Total Num booted cores = 3
Boot App: Booted Core ID #10 at 12742 usecs
Boot App: Booted Core ID #11 at 13250 usecs
Boot App: Booted Core ID #0 at 405630 usecs
MCU Boot Task started at 1242 usecs and finished at 421137 usecs
OPTIONS: I18n
Port /dev/ttyUSB2, 14:21:51
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
ERROR:   GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
I/TC:
I/TC: OP-TEE version: 4.2.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Apr 12 09:51:21 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.6.32-ti-g8636139a4976 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU4
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments J7200 EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@90
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-0
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-mem0
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-0
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-mem0
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-0
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-mem0
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-0
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-mem0
[    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a47fffff (8192 KiB) nomap non-reusable ipc-memo0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
[    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 32 MiB at 0x00000000fe000000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblt
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB)
[    0.000000] Memory: 3896332K/4194304K available (11968K kernel code, 1250K rwdata, 4036K rodata, 2432K init)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 4s
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008346] Console: colour dummy device 80x25
[    0.012913] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj)
[    0.023583] pid_max: default: 32768 minimum: 301
[    0.028339] LSM: initializing lsm=capability,integrity
[    0.033645] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.041220] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049685] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.056342] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.063600] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.071460] rcu: Hierarchical SRCU implementation.
[    0.076359] rcu:     Max phase no-delay instances is 1000.
[    0.081869] Platform MSI: msi-controller@1820000 domain created
[    0.088035] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.097393] EFI services will not be available.
[    0.102126] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.121103] Detected PIPT I-cache on CPU1
[    0.121132] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.121147] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[    0.121180] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.121241] smp: Brought up 1 node, 2 CPUs
[    0.150587] SMP: Total of 2 processors activated.
[    0.155392] CPU features: detected: 32-bit EL0 Support
[    0.160645] CPU features: detected: CRC32 instructions
[    0.165929] CPU: All CPU(s) started at EL2
[    0.170112] alternatives: applying system-wide alternatives
[    0.176627] devtmpfs: initialized
[    0.184440] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.194418] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.201949] pinctrl core: initialized pinctrl subsystem
[    0.207808] DMI not present or invalid.
[    0.212067] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.218545] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.225860] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.233897] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.242019] audit: initializing netlink subsys (disabled)
[    0.247636] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
[    0.247846] thermal_sys: Registered thermal governor 'step_wise'
[    0.255559] thermal_sys: Registered thermal governor 'power_allocator'
[    0.261718] cpuidle: using governor menu
[    0.272460] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.279425] ASID allocator initialised with 65536 entries
[    0.291733] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[    0.302729] Modules: 27680 pages in range for non-PLT usage
[    0.302733] Modules: 519200 pages in range for PLT usage
[    0.308898] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.321282] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.327688] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.334623] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.341024] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.347958] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.354359] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.361293] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.368469] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected
[    0.377694] iommu: Default domain type: Translated
[    0.382611] iommu: DMA domain TLB invalidation policy: strict mode
[    0.389065] SCSI subsystem initialized
[    0.393089] usbcore: registered new interface driver usbfs
[    0.398713] usbcore: registered new interface driver hub
[    0.404152] usbcore: registered new device driver usb
[    0.409540] pps_core: LinuxPPS API ver. 1 registered
[    0.414618] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.423958] PTP clock support registered
[    0.428046] EDAC MC: Ver: 3.0.0
[    0.431488] scmi_core: SCMI protocol bus registered
[    0.436711] FPGA manager framework
[    0.440221] Advanced Linux Sound Architecture Driver Initialized.
[    0.446878] vgaarb: loaded
[    0.449805] clocksource: Switched to clocksource arch_sys_counter
[    0.456173] VFS: Disk quotas dquot_6.6.0
[    0.460205] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.470510] NET: Registered PF_INET protocol family
[    0.475750] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.484734] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.493515] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.501441] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.509649] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.518337] TCP: Hash tables configured (established 32768 bind 32768)
[    0.525160] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.532080] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.539507] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.545620] RPC: Registered named UNIX socket transport module.
[    0.551688] RPC: Registered udp transport module.
[    0.556493] RPC: Registered tcp transport module.
[    0.561296] RPC: Registered tcp-with-tls transport module.
[    0.566898] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.573481] NET: Registered PF_XDP protocol family
[    0.578384] PCI: CLS 0 bytes, default 64
[    0.583021] Initialise system trusted keyrings
[    0.587686] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.594445] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.600563] NFS: Registering the id_resolver key type
[    0.605746] Key type id_resolver registered
[    0.610019] Key type id_legacy registered
[    0.614122] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.620972] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.642114] Key type asymmetric registered
[    0.646300] Asymmetric key parser 'x509' registered
[    0.651309] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.658875] io scheduler mq-deadline registered
[    0.663502] io scheduler kyber registered
[    0.667618] io scheduler bfq registered
[    0.673071] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    0.679109] pinctrl-single 4301c038.pinctrl: 2 pins, size 8
[    0.684900] pinctrl-single 4301c068.pinctrl: 59 pins, size 236
[    0.691095] pinctrl-single 4301c174.pinctrl: 8 pins, size 32
[    0.697037] pinctrl-single 11c000.pinctrl: 67 pins, size 268
[    0.703013] pinctrl-single 11c11c.pinctrl: 3 pins, size 12
[    0.708992] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.718017] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.729312] loop: module loaded
[    0.733066] megasas: 07.725.01.00-rc1
[    0.738520] tun: Universal TUN/TAP device driver, 1.6
[    0.744205] VFIO - User Level meta-driver version: 0.3
[    0.750006] usbcore: registered new interface driver usb-storage
[    0.756437] i2c_dev: i2c /dev entries driver
[    0.761429] sdhci: Secure Digital Host Controller Interface driver
[    0.767754] sdhci: Copyright(c) Pierre Ossman
[    0.772309] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.778373] ledtrig-cpu: registered to indicate activity on CPUs
[    0.784660] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.791526] usbcore: registered new interface driver usbhid
[    0.797224] usbhid: USB HID core driver
[    0.801827] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.810441] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.814996] optee: revision 4.2 (12d7c4ee)
[    0.831453] optee: dynamic shared memory is enabled
[    0.841064] random: crng init done
[    0.844601] optee: initialized driver
[    0.849400] NET: Registered PF_PACKET protocol family
[    0.854614] Key type dns_resolver registered
[    0.862422] registered taskstats version 1
[    0.866685] Loading compiled-in X.509 certificates
[    0.879008] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox))
[    0.907423] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    0.914103] pca953x 1-0021: supply vcc not found, using dummy regulator
[    0.920940] pca953x 1-0021: using no AI
[    1.929807] omap_i2c 2000000.i2c: timeout waiting for bus ready
[    1.935866] pca953x 1-0021: failed writing register
[    1.940911] pca953x: probe of 1-0021 failed with error -16
[    1.946737] pca953x 1-0020: supply vcc not found, using dummy regulator
[    1.953556] pca953x 1-0020: using no AI
[    2.961808] omap_i2c 2000000.i2c: timeout waiting for bus ready
[    2.967864] pca953x 1-0020: failed writing register
[    2.972907] pca953x: probe of 1-0020 failed with error -16
[    2.978678] pca953x 1-0022: supply vcc not found, using dummy regulator
[    2.985491] pca953x 1-0022: using AI
[    3.993807] omap_i2c 2000000.i2c: timeout waiting for bus ready
[    3.999863] pca953x 1-0022: failed writing register
[    4.004891] pca953x: probe of 1-0022 failed with error -16
[    4.010558] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
[    4.016760] pca953x 2-0020: supply vcc not found, using dummy regulator
[    4.023591] pca953x 2-0020: using no AI
[    5.033807] omap_i2c 2010000.i2c: timeout waiting for bus ready
[    5.039863] pca953x 2-0020: failed writing register
[    5.044916] pca953x: probe of 2-0020 failed with error -16
[    5.050569] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz
[    5.056325] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[    5.064863] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[    5.074196] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[    5.082783] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
[    5.093726] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
[    5.103620] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    5.110380] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    5.120776] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:21
[    5.130937] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    5.137697] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    5.145297] pinctrl-single 4301c000.pinctrl: mux offset out of range: 0xf8 (0x34)
[    5.152952] pinctrl-single 4301c000.pinctrl: could not add functions for mcu-uart0-pins-default 248x
[    5.162876] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 251, base_baud = 6000000) is a 8250
[    5.172509] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 252, base_baud = 3000000) is a 8250
[    5.181378] printk: console [ttyS2] enabled
[    5.189938] printk: bootconsole [ns16550a0] disabled
[    5.202458] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 253, base_baud = 3000000) is a 8250
[    5.212259] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    5.257810] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    5.265812] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    5.272524] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0
[    5.285372] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    5.292582] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    5.298811] pps pps0: new PPS source ptp0
[    5.302968] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    5.313332] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    5.322795] mmc0: CQHCI version 5.10
[    5.341914] vda_mcu_1v8: Bringing 800000uV into 1800000-1800000uV
    Are you using the prebuild binaries for Lateapps, and linux images?
    Is this being done on the EVM?
    Nikhil
  • Are you using the prebuild binaries for Lateapps, and linux images?
    Yes we use prebuild linux images and do as manual step
    We do not have EVM board and not try it on EVM
    The prebuilds are tested on the EVM, with the Linux device tree that corresponds to the devices on the EVM. If you have a custom board, then the Linux device tree shall be adapted to match your board. So do you have a linux kernel or device tree that boots fine on your custom board?
    Nikhil
  • Hi Dasan,
    After disable Pmic watchdog, there are more logs out, Why the kernel can not open the mmcblk1p2 which is rootfs in SD card?
    How can I debug it?
    [    6.019188] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    6.019213] tps6594: probe of 0-0048 failed with error -121
    [    6.032390] tps6594 0-004c: error -EREMOTEIO: Failed to set PMIC state
    [    6.038934] tps6594: probe of 0-004c failed with error -121
    [    6.046141] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, g)
    [    6.056370] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, g)
    [    6.068110] spi-nor spi0.0: unrecognized JEDEC id bytes: 80 00 00 00 00 00
    [    6.075434] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    6.106351] mmc0: Command Queue Engine enabled
    [    6.110816] mmc0: new HS400 MMC card at address 0001
    [    6.116126] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    6.120619] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    6.121565] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    6.128666] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
    [    6.133827] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    6.139886] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0
    [    6.145343] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    6.157600] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    6.170991] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    6.177182] pps pps0: new PPS source ptp1
    [    6.181347] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000,1
    [    6.198330] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    6.209445] debugfs: Directory 'pd:49' with parent 'pm_genpd' already present!
    [    6.217922] debugfs: Directory 'pd:35' with parent 'pm_genpd' already present!
    [    6.225606] clk: Disabling unused clocks
    [    6.241792] ALSA device list:
    [    6.244764]   No soundcards found.
    [    6.248309] ========================wsc before:
    [    6.252857] ========================wsc after:/dev/mmcblk1p2
    [    6.258865] /dev/root: Can't open blockdev
    [    6.262977] VFS: Cannot open root device "/dev/mmcblk1p2" or unknown-block(0,0): e6
    [    6.271145] Please append a correct "root=" boot option; here are the available pa:
    [    6.279492] b300        31080448 mmcblk0
    [    6.279496]  driver: mmcblk
    [    6.286284] b320           32256 mmcblk0boot0
    [    6.286287]  (driver?)
    [    6.293072] b340           32256 mmcblk0boot1
    [    6.293075]  (driver?)
    [    6.299856] List of all bdev filesystems:
    [    6.303856]  ext3
    [    6.303858]  ext4
    [    6.305777]  ext2
    [    6.307692]  squashfs
    [    6.309611]  vfat
    [    6.311873]
    [    6.315273] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-bl)
    [    6.323521] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.6.32-g6de6e418c80e-dirty #2
    [    6.331162] Hardware name: Texas Instruments J7200 EVM (DT)
    [    6.336719] Call trace:
    [    6.339156]  dump_backtrace+0x90/0xe8
    [    6.342819]  show_stack+0x18/0x24
    [    6.346124]  dump_stack_lvl+0x48/0x60
    [    6.349776]  dump_stack+0x18/0x24
    [    6.353079]  panic+0x324/0x380
    [    6.356126]  mount_root_generic+0x268/0x338
    [    6.360300]  mount_root+0x170/0x334
    [    6.363777]  prepare_namespace+0xa8/0x2c4
    [    6.367776]  kernel_init_freeable+0x248/0x288
    [    6.372121]  kernel_init+0x24/0x1dc
    [    6.375602]  ret_from_fork+0x10/0x20
    [    6.379166] SMP: stopping secondary CPUs
    [    6.383078] Kernel Offset: 0x80000 from 0xffff800080000000
    [    6.388549] PHYS_OFFSET: 0x80000000
    [    6.392026] CPU features: 0x0,80000200,28020000,1000420b
    [    6.397325] Memory Limit: none
    [    6.400370] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on u-
    This is because you would have to append the below at the end of in the bootargs in the common-proc dts  for SBL to get access to the rootfs
    i.e. bootargs = "console=ttyS2 ......... root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait" ;
    Nikhil
  • Hi
    Is the dts file: ti-processor-sdk-linux-j7200-evm-10_00_07_03/board-support/ti-linux-kernel-6.6.32+git-ti/arch/arm64/boot/dts/ti/k3-j7200-common-proc-board.dts?
    I can not find bootargs in this file.
    I believe the bootargs is removed from SDK 10.0 onwards. It was there in the earlier SDK version
    You can do the below to add this in "chosen"
    chosen {
        stdout-path = "serial2:115200n8";
        bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait";
    Nikhil
  • Thanks, it works.
