TDA4VM: TDA4VM的J721EXCP01EVM
Part Number: TDA4VM
Hi team
     My goal is to implement an adaptation of ds90ub960->ds90ub953->ox03c10
     1、My question is,
   (1) How to see the successful association between 960 and 953
   (2) ds90ub953.ko is not loaded after the device is started, does it need to be loaded manually
   (3) Although the 960 driver is finished, the function in the figure is not executed. Is there a problem with this and how to solve it
static int ub960_init_rx_ports(struct ub960_data *priv)
  2155 {
  2156     unsigned int nport;
  2157
  2158     for (nport = 0; nport < priv->hw_data->num_rxports; nport++) {
  2159         struct ub960_rxport *rxport = priv->rxports[nport];
  2160
  2161         if (!rxport) {
  2162             continue;(Hi,team,It will loop through here four times and then exit the function)
  2163         }
  2164
  2165         if (priv->hw_data->is_ub9702)
  2166             ub960_init_rx_port_ub9702(priv, rxport);
  2167         else {
  2168             ub960_init_rx_port_ub960(priv, rxport);(This function will not execute)
  2169         }
  2170     }
  2171
  2172     return 0;
  2173 }
注. 1、This is my uEnv.txt
uenvcmd=if run check_psdk_setup; then echo "Already setup."; else run do_psdk_setup; mw.b ${loadaddr} 0 1; fatwrite mmc 1:1 ${loadaddr} .psdk_setup 1; reset; fi; if test "$board_name" = "j721e-evm"; then ; setenv args_all $args_all systemd.hostname=tda4vm; fi; if test ${boot_fit} -eq 1; then  setenv name_overlays $name_overlays_fit; fi;
# Setting the right U-Boot environment variables
dorprocboot=1
name_overlays=k3-j721e-evm-fusion.dtbo \
                k3-fpdlink-imx390-rcm-1-0.dtbo
# Name overlays when booting from fit image
name_overlays_fit=ti/k3-j721e-evm-fusion.dtbo \
                  ti/k3-fpdlink-imx390-rcm-1-0.dtbo
    Thanks in advance!
Best wishes
    Could you share the output of media-ctl -p? This will show you the device topology. Revert uEnv.txt to its original state and add the required overlays to the end the name_overlays line only. I recommend taking a look at the following pages to help you enable OX03C10.
    FAQ: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1403223/faq-most-common-problems-encountered-when-developing-camera-applications-on-the-am6x
    SDK Documentation: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/10_00_00_08/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/Camera/CSI2RX.html
    Thank you,
    Fabiana
  • Thank you for your reply
    I may not have reached the step of sensor configuration now, I want to successfully configure the drivers of ub960 and ub953, I recovered uEnv.txt and added two dtbo files in the back, but I will report an error under the diagram, what is the reason
    dorprocboot=1
    name_overlays=k3-j721e-edgeai-apps.dtbo k3-j721e-evm-fusion.dtbo k3-fpdlink-imx390-rcm-1-0.dtbo
    name_overlays_fit=ti/k3-j721e-edgeai-apps.dtbo k3-j721e-evm-fusion.dtbo k3-fpdlink-imx390-rcm-1-0.dtbo
     ds90ub960 5-0036: error -EIO: Failed to lock all RX ports
    [    6.554090] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    6.569667] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    6.577312] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    6.581288] ds90ub960: probe of 5-0036 failed with error -5
    [    6.594719] ds90ub960 5-003d: supply vddio not found, using dummy regulator
    This is my media-ctl -p
    Media controller API version 6.1.80
    Media device information
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    bus info        platform:4500000.ticsi2rx
    hw revision     0x1
    driver version  6.1.80
    Device topology
    - entity 1: 4500000.ticsi2rx (17 pads, 17 links, 1 route)
                type V4L2 subdev subtype Unknown flags 0
                device node name /dev/v4l-subdev0
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
                    <- "cdns_csi2rx.4504000.csi-bridge":1 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "4500000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
            pad2: Source
                    -> "4500000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
            pad3: Source
                    -> "4500000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
            pad4: Source
                    -> "4500000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
            pad5: Source
                    -> "4500000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE]
            pad6: Source
                    -> "4500000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE]
            pad7: Source
                    -> "4500000.ticsi2rx context 6":0 [ENABLED,IMMUTABLE]
            pad8: Source
                    -> "4500000.ticsi2rx context 7":0 [ENABLED,IMMUTABLE]
            pad9: Source
                    -> "4500000.ticsi2rx context 8":0 [ENABLED,IMMUTABLE]
            pad10: Source
                    -> "4500000.ticsi2rx context 9":0 [ENABLED,IMMUTABLE]
            pad11: Source
                    -> "4500000.ticsi2rx context 10":0 [ENABLED,IMMUTABLE]
            pad12: Source
                    -> "4500000.ticsi2rx context 11":0 [ENABLED,IMMUTABLE]
            pad13: Source
                    -> "4500000.ticsi2rx context 12":0 [ENABLED,IMMUTABLE]
            pad14: Source
                    -> "4500000.ticsi2rx context 13":0 [ENABLED,IMMUTABLE]
            pad15: Source
                    -> "4500000.ticsi2rx context 14":0 [ENABLED,IMMUTABLE]
            pad16: Source
                    -> "4500000.ticsi2rx context 15":0 [ENABLED,IMMUTABLE]
    - entity 19: cdns_csi2rx.4504000.csi-bridge (5 pads, 2 links, 1 route)
                 device node name /dev/v4l-subdev1
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    <- "ds90ub960 5-003d":4 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "4500000.ticsi2rx":0 [ENABLED,IMMUTABLE]
            pad2: Source
            pad3: Source
            pad4: Source
    - entity 25: ds90ub960 5-003d (6 pads, 1 link, 1 route)
                 device node name /dev/v4l-subdev2
            routes:
                    0/0 -> 4/0 [ACTIVE]
            pad0: Sink
            pad1: Sink
            pad2: Sink
            pad3: Sink
            pad4: Source
                    -> "cdns_csi2rx.4504000.csi-bridge":0 [ENABLED,IMMUTABLE]
            pad5: Source
    - entity 36: 4500000.ticsi2rx context 0 (1 pad, 1 link, 0 route)
                 type Node subtype V4L flags 0
                 device node name /dev/video2
            pad0: Sink
                    <- "4500000.ticsi2rx":1 [ENABLED,IMMUTABLE]
    - entity 42: 4500000.ticsi2rx context 1 (1 pad, 1 link, 0 route)
                 device node name /dev/video3
            pad0: Sink
                    <- "4500000.ticsi2rx":2 [ENABLED,IMMUTABLE]
    - entity 48: 4500000.ticsi2rx context 2 (1 pad, 1 link, 0 route)
                 device node name /dev/video4
            pad0: Sink
                    <- "4500000.ticsi2rx":3 [ENABLED,IMMUTABLE]
    - entity 54: 4500000.ticsi2rx context 3 (1 pad, 1 link, 0 route)
                 device node name /dev/video5
            pad0: Sink
                    <- "4500000.ticsi2rx":4 [ENABLED,IMMUTABLE]
    - entity 60: 4500000.ticsi2rx context 4 (1 pad, 1 link, 0 route)
                 device node name /dev/video6
            pad0: Sink
                    <- "4500000.ticsi2rx":5 [ENABLED,IMMUTABLE]
    - entity 66: 4500000.ticsi2rx context 5 (1 pad, 1 link, 0 route)
                 device node name /dev/video7
            pad0: Sink
                    <- "4500000.ticsi2rx":6 [ENABLED,IMMUTABLE]
    - entity 72: 4500000.ticsi2rx context 6 (1 pad, 1 link, 0 route)
                 device node name /dev/video8
            pad0: Sink
                    <- "4500000.ticsi2rx":7 [ENABLED,IMMUTABLE]
    - entity 78: 4500000.ticsi2rx context 7 (1 pad, 1 link, 0 route)
                 device node name /dev/video9
            pad0: Sink
                    <- "4500000.ticsi2rx":8 [ENABLED,IMMUTABLE]
    - entity 84: 4500000.ticsi2rx context 8 (1 pad, 1 link, 0 route)
                 device node name /dev/video10
            pad0: Sink
                    <- "4500000.ticsi2rx":9 [ENABLED,IMMUTABLE]
    - entity 90: 4500000.ticsi2rx context 9 (1 pad, 1 link, 0 route)
                 device node name /dev/video11
            pad0: Sink
                    <- "4500000.ticsi2rx":10 [ENABLED,IMMUTABLE]
    - entity 96: 4500000.ticsi2rx context 10 (1 pad, 1 link, 0 route)
                 device node name /dev/video12
            pad0: Sink
                    <- "4500000.ticsi2rx":11 [ENABLED,IMMUTABLE]
    - entity 102: 4500000.ticsi2rx context 11 (1 pad, 1 link, 0 route)
                  device node name /dev/video13
            pad0: Sink
                    <- "4500000.ticsi2rx":12 [ENABLED,IMMUTABLE]
    - entity 108: 4500000.ticsi2rx context 12 (1 pad, 1 link, 0 route)
                  device node name /dev/video14
            pad0: Sink
                    <- "4500000.ticsi2rx":13 [ENABLED,IMMUTABLE]
    - entity 114: 4500000.ticsi2rx context 13 (1 pad, 1 link, 0 route)
                  device node name /dev/video15
            pad0: Sink
                    <- "4500000.ticsi2rx":14 [ENABLED,IMMUTABLE]
    - entity 120: 4500000.ticsi2rx context 14 (1 pad, 1 link, 0 route)
                  device node name /dev/video16
            pad0: Sink
                    <- "4500000.ticsi2rx":15 [ENABLED,IMMUTABLE]
    - entity 126: 4500000.ticsi2rx context 15 (1 pad, 1 link, 0 route)
                  device node name /dev/video17
            pad0: Sink
                    <- "4500000.ticsi2rx":16 [ENABLED,IMMUTABLE]
    Looking forward to your reply!
  • Hi
       I have modified it again. Could you please help me check whether ds90ub960.ko is successfully loaded?
    dorprocboot=1
    name_overlays=k3-j721e-edgeai-apps.dtbo k3-j721e-evm-fusion.dtbo k3-fpdlink-imx390-rcm-0-0.dtbo
    [    5.670696] ds90ub960 5-0036: supply vddio not found, using dummy regulator
    [    5.758779] ds90ub960 5-003d: supply vddio not found, using dummy regulator
    [    9.497451] ds90ub960 5-003d: Consider updating driver ds90ub960 to match on endpoints
    [    9.657443] ds90ub960 5-0036: Consider updating driver ds90ub960 to match on endpoints
    root@tda4vm-sk:/# i2cdetect -y -r 5
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00:                         -- -- -- -- -- -- -- --
    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- UU -- -- -- -- -- -- UU -- --
    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    70: -- -- -- -- -- -- -- --
    root@tda4vm-sk:/# media-ctl -p
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    hw revision     0x1
    Device topology
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
            pad1: Source
            pad2: Source
            pad3: Source
            pad4: Source
            pad5: Source
            pad6: Source
            pad7: Source
            pad8: Source
            pad9: Source
            pad10: Source
            pad11: Source
            pad12: Source
            pad13: Source
            pad14: Source
            pad15: Source
            pad16: Source
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
            pad1: Source
            pad2: Source
            pad3: Source
            pad4: Source
            routes:
                    0/0 -> 4/0 [ACTIVE]
            pad0: Sink
            pad1: Sink
            pad2: Sink
            pad3: Sink
            pad4: Source
            pad5: Source
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
            pad0: Sink
    2.Why don't I have the I2C address of ds90ub953?How do I load this driver?
    Thank you very much and look forward to your reply!
    Are you using SK-TDA4VM or TDA4VM EVM? If you are using the latest SDK version (v10.0) on SK-TDA4VM, change k3-j721e-evm-fusion.dtbo to k3-j721e-sk-fpdlink-fusion.dtbo in uEnv.txt.
    See: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-sk-tda4vm/10_00_00/exports/edgeai-docs/devices/TDA4VM/linux/getting_started.html#imx390-raw-sensor
    Thank you,
    Fabiana
