Part Number: AM62P-Q1
1、We used the ads6311 camera to capture the stream and found that the driver crashed,A video device has been generated
root@am62pxx-evm:/# ls /dev/video* /dev/video0 /dev/video1 /dev/video2 /dev/video3 /dev/video4 /dev/video5
2、log
v4l2-ctl -d/dev/video0 --set-fmt-video=width=640,height=480, --stream-mmap=3 --stream-skip=3 --stream-to=/tmp/yuv.bin --stream-count=1 --stream-poll [ 27.464375] ---- S_CLOSE from v4l_id (1174:1174) on CPU 2 [ 35.384366] client: v4l2-ctl (1177:1177) is running on CPU 1, pad: 0, name:m00_dToF_ads6311 spi0.0, fd: 000000009e91642b [ 35.389891] num_routes: 4, source_pad: 0, source_stream: 0 [ 35.400761] num_entries: 0, w*h: 480 * 128, code: 0x3008, bpp: 16 [ 35.406246] num_routes: 4, source_pad: 0, source_stream: 1 [ 35.412333] num_entries: 1, w*h: 480 * 128, code: 0x3008, bpp: 16 [ 35.417813] num_routes: 4, source_pad: 0, source_stream: 2 [ 35.423901] num_entries: 2, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 35.429386] num_routes: 4, source_pad: 0, source_stream: 3 [ 35.435126] num_entries: 3, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 35.440623] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ti_csi2rx_get_vc+0x124/0x124 [ 35.456763] CPU: 1 PID: 1177 Comm: v4l2-ctl Not tainted 6.6.32 #16 [ 35.462928] Hardware name: Texas Instruments AM62P5 SK (DT) [ 35.468485] Call trace: [ 35.470921] dump_backtrace+0x90/0xe8 [ 35.474578] show_stack+0x18/0x24 [ 35.477886] dump_stack_lvl+0x48/0x60 [ 35.481540] dump_stack+0x18/0x24 [ 35.484843] panic+0x31c/0x378 [ 35.487891] __ktime_get_real_seconds+0x0/0xc [ 35.492238] _ti_csi2rx_sd_set_routing+0x0/0xb8 [ 35.496759] ti_csi2rx_start_streaming+0x120/0x298 [ 35.501543] SMP: stopping secondary CPUs [ 35.505459] Kernel Offset: disabled [ 35.508935] CPU features: 0x0,00000008,00020000,1000420b [ 35.514232] Memory Limit: none [ 35.517277] ---[ end Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ti_csi2rx_get_vc+0x124/0x124 ]---
root@am62pxx-evm:/home/root# media-ctl -p
Media controller API version 6.6.32
[ 50.610005] ---- S_CLOSE from v4l_id (1176:1176) on CPU 2
Media device information
driver [ 52.308209] client: media-ctl (1178:1178) is running on CPU 1
j721e-csi2rx
model TI-CSI2RX
[ 52.316359] ---- S_OPEN from media-ctl (1178:1178) on CPU 1
bus info platform:30102000.ticsi2rx
hw revision 0x1
driver version 6.6.32
Device topology
- entity 1: 30102000.ticsi2rx (7 pads, 7 links, 1 route)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
[stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
<- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE]
pad1: Source
-> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
pad2: Source
-> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
pad3: Source
-> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
pad4: Source
-> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
pad5: Source
-> "30102000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE]
pad6: Source
-> "30102000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE]
- entity 9: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 1 route)
device node name /dev/v4l-subdev1
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
<- "m00_dToF_ads6311 spi0.0":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE]
pad2: Source
pad3: Source
pad4: Source
- entity 15: m00_dToF_ads6311 spi0.0 (1 pad, 1 link, 4 routes)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
routes:
0/0 -> 0/0 [ACTIVE]
0/0 -> 0/1 [ACTIVE]
0/0 -> 0/2 [ACTIVE]
0/0 -> 0/3 [ACTIVE]
pad0: Source
-> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE]
- entity 21: 30102000.ticsi2rx context 0 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE]
- entity 27: 30102000.ticsi2rx context 1 (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
<- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE]
- entity 33: 30102000.ticsi2rx context 2 (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
<- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE]
- entity 39: 30102000.ticsi2rx context 3 (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
<- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE]
- entity 45: 30102000.ticsi2rx context 4 (1 pad, 1 link)
device node name /dev/video4
pad0: Sink
<- "30102000.ticsi2rx":5 [ENABLED,IMMUTABLE]
- entity 51: 30102000.ticsi2rx context 5 (1 pad, 1 link)
device node name /dev/video5
pad0: Sink
<- "30102000.ticsi2rx":6 [ENABLED,IMMUTABLE]
4、dmesg
root@am62pxx-evm:/home/root# dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.32 (cd7475193@8ecd21008a44) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #16 SMP PREEMPT Mon Nov 11 08:30:06 UTC 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM62P5 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000 [ 0.000000] OF: reserved mem: 0x000000009e780000..0x000000009e7fffff (512 KiB) nomap non-reusable tfa@9e780000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009b4fffff] [ 0.000000] node 0: [mem 0x000000009b500000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000009ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920 [ 0.000000] pcpu-alloc: s42920 r8192 d30808 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=5a09f541-02 rw rootfstype=ext4 rootwait init=/home/root/init-byd.sh [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 7474744K/8388608K available (12416K kernel code, 1272K rwdata, 4232K rodata, 2496K init, 509K bss, 324040K reserved, 589824K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008552] Console: colour dummy device 80x25 [ 0.013142] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023814] pid_max: default: 32768 minimum: 301 [ 0.028613] LSM: initializing lsm=capability,integrity [ 0.033973] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.041734] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.051541] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.058838] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.066746] rcu: Hierarchical SRCU implementation. [ 0.071646] rcu: Max phase no-delay instances is 1000. [ 0.077220] Platform MSI: msi-controller@1820000 domain created [ 0.083498] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.092935] EFI services will not be available. [ 0.097799] smp: Bringing up secondary CPUs ... [ 0.103019] Detected VIPT I-cache on CPU1 [ 0.103089] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.103104] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000 [ 0.103151] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.103798] Detected VIPT I-cache on CPU2 [ 0.103854] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.103867] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000 [ 0.103900] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.104467] Detected VIPT I-cache on CPU3 [ 0.104515] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.104528] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000 [ 0.104557] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.104629] smp: Brought up 1 node, 4 CPUs [ 0.184278] SMP: Total of 4 processors activated. [ 0.189086] CPU features: detected: 32-bit EL0 Support [ 0.194351] CPU features: detected: CRC32 instructions [ 0.199657] CPU: All CPU(s) started at EL2 [ 0.203851] alternatives: applying system-wide alternatives [ 0.211135] devtmpfs: initialized [ 0.225344] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.235343] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.256510] pinctrl core: initialized pinctrl subsystem [ 0.262341] DMI not present or invalid. [ 0.266872] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.273813] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.281255] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.289367] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.297620] audit: initializing netlink subsys (disabled) [ 0.303321] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1 [ 0.303739] thermal_sys: Registered thermal governor 'step_wise' [ 0.311242] thermal_sys: Registered thermal governor 'power_allocator' [ 0.317418] cpuidle: using governor menu [ 0.328289] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.335301] ASID allocator initialised with 65536 entries [ 0.353936] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.364858] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.375163] Modules: 27488 pages in range for non-PLT usage [ 0.375171] Modules: 519008 pages in range for PLT usage [ 0.381553] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.393939] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.400341] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.407274] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.413678] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.420610] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.427010] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.433942] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.441629] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected [ 0.450945] iommu: Default domain type: Translated [ 0.455863] iommu: DMA domain TLB invalidation policy: strict mode [ 0.462436] SCSI subsystem initialized [ 0.466386] libata version 3.00 loaded. [ 0.466551] usbcore: registered new interface driver usbfs [ 0.472187] usbcore: registered new interface driver hub [ 0.477640] usbcore: registered new device driver usb [ 0.483248] mc: Linux media interface: v0.10 [ 0.487652] videodev: Linux video capture interface: v2.00 [ 0.493286] pps_core: LinuxPPS API ver. 1 registered [ 0.498360] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.507697] PTP clock support registered [ 0.511865] EDAC MC: Ver: 3.0.0 [ 0.515523] scmi_core: SCMI protocol bus registered [ 0.520760] FPGA manager framework [ 0.524312] Advanced Linux Sound Architecture Driver Initialized. [ 0.531411] vgaarb: loaded [ 0.534504] clocksource: Switched to clocksource arch_sys_counter [ 0.541004] VFS: Disk quotas dquot_6.6.0 [ 0.545056] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.558319] NET: Registered PF_INET protocol family [ 0.563605] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.576647] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.585480] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.593415] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.601918] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.611199] TCP: Hash tables configured (established 65536 bind 65536) [ 0.618046] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.625151] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.632833] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.639044] RPC: Registered named UNIX socket transport module. [ 0.645116] RPC: Registered udp transport module. [ 0.649922] RPC: Registered tcp transport module. [ 0.654727] RPC: Registered tcp-with-tls transport module. [ 0.660331] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.666917] NET: Registered PF_XDP protocol family [ 0.671825] PCI: CLS 0 bytes, default 64 [ 0.677093] Initialise system trusted keyrings [ 0.681850] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 0.688730] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.694952] NFS: Registering the id_resolver key type [ 0.700142] Key type id_resolver registered [ 0.704415] Key type id_legacy registered [ 0.708525] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.715373] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.754475] Key type asymmetric registered [ 0.758667] Asymmetric key parser 'x509' registered [ 0.763696] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241) [ 0.771256] io scheduler mq-deadline registered [ 0.775885] io scheduler kyber registered [ 0.780008] io scheduler bfq registered [ 0.787097] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.793600] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.806526] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.823046] loop: module loaded [ 0.827313] megasas: 07.725.01.00-rc1 [ 0.834835] tun: Universal TUN/TAP device driver, 1.6 [ 0.840979] VFIO - User Level meta-driver version: 0.3 [ 0.847361] usbcore: registered new interface driver usb-storage [ 0.854067] i2c_dev: i2c /dev entries driver [ 0.860107] sdhci: Secure Digital Host Controller Interface driver [ 0.866445] sdhci: Copyright(c) Pierre Ossman [ 0.871120] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.877636] ledtrig-cpu: registered to indicate activity on CPUs [ 0.884081] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.891345] usbcore: registered new interface driver usbhid [ 0.897045] usbhid: USB HID core driver [ 0.901247] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100 [ 0.908071] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100 [ 0.914797] omap-mailbox 29020000.mailbox: no available mbox devices found [ 0.921857] omap-mailbox 29030000.mailbox: no available mbox devices found [ 0.930625] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.939613] optee: probing for conduit method. [ 0.944178] optee: revision 4.2 (12d7c4ee) [ 0.944459] optee: dynamic shared memory is enabled [ 0.953867] optee: initialized driver [ 0.959120] NET: Registered PF_PACKET protocol family [ 0.964387] Key type dns_resolver registered [ 0.977301] registered taskstats version 1 [ 0.981763] Loading compiled-in X.509 certificates [ 0.999335] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') [ 1.050255] platform 79000000.r5f: configured R5F for remoteproc mode [ 1.057142] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000 [ 1.067008] remoteproc remoteproc0: 79000000.r5f is available [ 1.073057] remoteproc remoteproc0: Direct firmware load for am62p-mcu-r5f0_0-fw failed with error -2 [ 1.082523] remoteproc remoteproc0: powering up 79000000.r5f [ 1.088406] remoteproc remoteproc0: Direct firmware load for am62p-mcu-r5f0_0-fw failed with error -2 [ 1.097866] remoteproc remoteproc0: request_firmware failed: -2 [ 1.103924] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 1.116090] platform 78000000.r5f: configured R5F for IPC-only mode [ 1.122597] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000 [ 1.131478] remoteproc remoteproc1: 78000000.r5f is available [ 1.137442] remoteproc remoteproc1: attaching to 78000000.r5f [ 1.143868] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 1.150747] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node r5f-dma-memory@9c800000 [ 1.160525] virtio_rpmsg_bus virtio0: rpmsg host is online [ 1.161029] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 1.166151] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7) [ 1.173847] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 1.180709] remoteproc remoteproc1: remote processor 78000000.r5f is now attached [ 1.197338] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.204390] pca953x 1-0023: supply vcc not found, using dummy regulator [ 1.211276] pca953x 1-0023: using AI [ 1.240614] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.250560] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.260301] i2c 1-003b: Fixed dependency cycle(s) with /connector-hdmi [ 1.267035] i2c 1-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 1.274623] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.281407] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz [ 1.287336] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.296543] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.305541] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created [ 1.315715] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.324397] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.335453] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.346327] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.355854] ti-udma 4e230000.dma-controller: Number of rings: 6 [ 1.362533] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6) [ 1.371983] printk: console [ttyS2] disabled [ 1.376684] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 252, base_baud = 3000000) is a 8250 [ 1.385556] printk: console [ttyS2] enabled [ 1.394008] printk: bootconsole [ns16550a0] disabled [ 1.409650] spi-nor spi1.0: s28hs512t (65536 Kbytes) [ 1.414757] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.421718] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.427112] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.433783] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.440157] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.446609] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.452787] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.459544] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.465999] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.474127] spi spi0.0: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000 [ 1.522512] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000 [ 1.537305] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.545411] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867 [ 1.553531] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006 [ 1.566384] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.573517] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.580041] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0 [ 1.593784] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.603947] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector [ 1.617277] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.622817] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 1.630643] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports [ 1.636649] xhci-hcd xhci-hcd.1.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010 [ 1.646079] xhci-hcd xhci-hcd.1.auto: irq 269, io mem 0x31100000 [ 1.652844] hub 1-0:1.0: USB hub found [ 1.656627] hub 1-0:1.0: 1 port detected [ 1.665663] spi spi0.0: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000 [ 1.675137] platform 30101000.csi-bridge: Fixed dependency cycle(s) with /bus@f0000/spi@20100000/ads6311_spi@0 [ 1.685582] 2222222222222222222222222222222222222 [ 1.690586] Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY [ 1.698210] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz [ 1.710687] mmc0: CQHCI version 5.10 [ 1.719728] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.726506] pca953x 1-0022: using AI [ 1.735432] debugfs: Directory 'pd:244' with parent 'pm_genpd' already present! [ 1.737052] mmc1: CQHCI version 5.10 [ 1.742801] debugfs: Directory 'pd:244' with parent 'pm_genpd' already present! [ 1.750525] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.753629] debugfs: Directory 'pd:243' with parent 'pm_genpd' already present! [ 1.768383] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present! [ 1.777007] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 1.784331] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 1.790516] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 1.792766] clk: Disabling unused clocks [ 1.807851] ALSA device list: [ 1.810898] No soundcards found. [ 1.814773] Waiting for root device PARTUUID=5a09f541-02... [ 1.844582] mmc0: Command Queue Engine enabled [ 1.849080] mmc0: new HS400 MMC card at address 0001 [ 1.854857] mmcblk0: mmc0:0001 G1M15L 29.6 GiB [ 1.859869] mmc1: new ultra high speed SDR104 SDXC card at address aaaa [ 1.860718] mmcblk0: p1 p2 [ 1.867076] mmcblk1: mmc1:aaaa SD64G 59.5 GiB [ 1.869756] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB [ 1.878586] mmcblk1: p1 p2 p3 [ 1.879454] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB [ 1.887450] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (236:0) [ 2.232557] EXT4-fs (mmcblk1p2): recovery complete [ 2.238225] EXT4-fs (mmcblk1p2): mounted filesystem 85f376bd-a8f0-42ba-a709-aeb042c2e8b7 r/w with ordered data mode. Quota mode: none. [ 2.250367] VFS: Mounted root (ext4 filesystem) on device 179:34. [ 2.257250] devtmpfs: mounted [ 2.260862] Freeing unused kernel memory: 2496K [ 2.265466] Run /home/root/init-byd.sh as init process [ 2.270595] with arguments: [ 2.270598] /home/root/init-byd.sh [ 2.270601] with environment: [ 2.270603] HOME=/ [ 2.270606] TERM=linux [ 2.529809] systemd[1]: System time before build time, advancing clock. [ 2.564495] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 2.596368] systemd[1]: Detected architecture arm64. [ 2.606639] systemd[1]: Hostname set to <am62pxx-evm>. [ 2.815448] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 2.849692] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 2.897115] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6. [ 2.906047] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6. [ 2.945759] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.055562] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.140157] systemd[1]: Queued start job for default target Graphical Interface. [ 3.179763] systemd[1]: Created slice Slice /system/getty. [ 3.187847] systemd[1]: Created slice Slice /system/modprobe. [ 3.199226] systemd[1]: Created slice Slice /system/serial-getty. [ 3.210819] systemd[1]: Created slice User and Session Slice. [ 3.221675] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 3.230560] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 3.243554] systemd[1]: Expecting device /dev/ttyS2... [ 3.254228] systemd[1]: Reached target Path Units. [ 3.264473] systemd[1]: Reached target Remote File Systems. [ 3.275581] systemd[1]: Reached target Slice Units. [ 3.286012] systemd[1]: Reached target Swaps. [ 3.323522] systemd[1]: Listening on RPCbind Server Activation Socket. [ 3.330438] systemd[1]: Reached target RPC Port Mapper. [ 3.348068] systemd[1]: Listening on Process Core Dump Socket. [ 3.354476] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 3.367496] systemd[1]: Listening on Journal Audit Socket. [ 3.379024] systemd[1]: Listening on Journal Socket (/dev/log). [ 3.386440] systemd[1]: Listening on Journal Socket. [ 3.397067] systemd[1]: Listening on Network Service Netlink Socket. [ 3.409568] systemd[1]: Listening on udev Control Socket. [ 3.419765] systemd[1]: Listening on udev Kernel Socket. [ 3.430594] systemd[1]: Listening on User Database Manager Socket. [ 3.462907] systemd[1]: Mounting Huge Pages File System... [ 3.472605] systemd[1]: Mounting POSIX Message Queue File System... [ 3.484540] systemd[1]: Mounting Kernel Debug File System... [ 3.491975] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 3.514705] systemd[1]: Mounting Temporary Directory /tmp... [ 3.521280] systemd[1]: Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/6.6.32/modules.devname). [ 3.545276] systemd[1]: Starting Load Kernel Module configfs... [ 3.556195] systemd[1]: Starting Load Kernel Module drm... [ 3.567543] systemd[1]: Starting Load Kernel Module fuse... [ 3.579035] systemd[1]: Starting Start psplash boot splash screen... [ 3.591822] systemd[1]: Starting RPC Bind... [ 3.596776] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 3.620836] systemd[1]: Starting Journal Service... [ 3.637967] systemd[1]: Starting Load Kernel Modules... [ 3.651457] systemd[1]: Starting Generate network units from Kernel command line... [ 3.671083] systemd[1]: Starting Remount Root and Kernel File Systems... [ 3.690820] systemd[1]: Starting Create Static Device Nodes in /dev gracefully... [ 3.708812] systemd[1]: Starting Coldplug All udev Devices... [ 3.719255] systemd[1]: Bind mount volatile /var/cache was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/var/cache). [ 3.737451] systemd[1]: Bind mount volatile /var/lib was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/var/lib). [ 3.750245] systemd[1]: Bind mount volatile /var/spool was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/var/spool). [ 3.755000] EXT4-fs (mmcblk1p2): re-mounted 85f376bd-a8f0-42ba-a709-aeb042c2e8b7 r/w. Quota mode: none. [ 3.763560] systemd[1]: Bind mount volatile /srv was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/srv). [ 3.786810] systemd-journald[136]: Collecting audit messages is enabled. [ 3.793149] systemd[1]: Started RPC Bind. [ 3.799605] systemd[1]: Mounted Huge Pages File System. [ 3.809665] systemd[1]: Mounted POSIX Message Queue File System. [ 3.821612] systemd[1]: Mounted Kernel Debug File System. [ 3.832886] systemd[1]: Mounted Temporary Directory /tmp. [ 3.845164] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 3.857629] systemd[1]: Finished Load Kernel Module configfs. [ 3.864838] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 3.876514] systemd[1]: Finished Load Kernel Module drm. [ 3.882615] systemd[1]: Started Journal Service. [ 4.001612] systemd-journald[136]: Received client request to flush runtime journal. [ 4.102434] audit: type=1334 audit(1709054765.568:2): prog-id=6 op=LOAD [ 4.118608] audit: type=1334 audit(1709054765.580:3): prog-id=7 op=LOAD [ 4.162983] audit: type=1334 audit(1709054765.632:4): prog-id=8 op=LOAD [ 4.170884] audit: type=1334 audit(1709054765.636:5): prog-id=9 op=LOAD [ 4.182587] audit: type=1334 audit(1709054765.636:6): prog-id=10 op=LOAD [ 4.400970] audit: type=1334 audit(1709054765.868:7): prog-id=11 op=LOAD [ 4.415141] audit: type=1334 audit(1709054765.884:8): prog-id=12 op=LOAD [ 4.430828] audit: type=1334 audit(1709054765.900:9): prog-id=11 op=UNLOAD [ 4.470767] audit: type=1334 audit(1709054765.940:10): prog-id=12 op=UNLOAD [ 4.886568] random: crng init done [ 5.577159] kauditd_printk_skb: 22 callbacks suppressed [ 5.577175] audit: type=1334 audit(1709054767.044:33): prog-id=25 op=LOAD [ 5.696300] audit: type=1334 audit(1709054767.164:34): prog-id=25 op=UNLOAD [ 5.709657] audit: type=1334 audit(1709054767.176:35): prog-id=26 op=LOAD [ 5.834171] audit: type=1334 audit(1709054767.300:36): prog-id=27 op=LOAD [ 5.853081] audit: type=1334 audit(1709054767.320:37): prog-id=28 op=LOAD [ 5.879126] audit: type=1334 audit(1709054767.344:38): prog-id=29 op=LOAD [ 5.886577] audit: type=1334 audit(1709054767.344:39): prog-id=30 op=LOAD [ 5.897089] audit: type=1334 audit(1709054767.356:40): prog-id=27 op=UNLOAD [ 5.907863] audit: type=1334 audit(1709054767.356:41): prog-id=28 op=UNLOAD [ 5.920412] audit: type=1334 audit(1709054767.356:42): prog-id=31 op=LOAD [ 6.455276] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 6.464940] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 6.506422] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL) [ 6.516180] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode [ 7.975353] ti-apps-launche[382]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set [ 8.520132] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 8.814058] EXT4-fs (mmcblk1p3): mounted filesystem 90213d76-c575-445e-8c87-eebe7e24d3c7 r/w with ordered data mode. Quota mode: none. [ 11.943210] platform 2b300050.target-module: deferred probe pending [ 49.655250] ----- Probe Start ---driver_version: 3.2.0_LM20240904a---- [ 49.692571] ads6311 virtio0.ti.ipc4.ping-pong.-1.13: mcuctrl_rpmsg_probe() Line:9459 [ 49.706839] new channel: 0x401 -> 0xd, rpmsg_device_id: ti.ipc4.ping-pong, endpoint address: 0x401! [ 49.818516] rpmsg wait for completion time-out [ 49.818526] rpmsg read reg:0x0000 failed, ret:-110, rpmsg_from_user: 0 [ 49.822978] read mcuctrl reg[0x0000] return data:0x0000, ret:-110 [ 49.938520] rpmsg wait for completion time-out [ 49.938534] rpmsg read reg:0x0020 failed, ret:-110, rpmsg_from_user: 0 [ 49.942990] Fail to read mcu firmware type, ret:-110 [ 50.050541] rpmsg wait for completion time-out [ 50.055506] rpmsg read reg:0x0010 failed, ret:-110, rpmsg_from_user: 0 [ 50.059949] Fail to read mcu firmware version, ret:-110 [ 50.170511] rpmsg wait for completion time-out for 100 ms. [ 50.175735] rpmsg_tx: 00000000: 00 03 00 81 f6 3c 47 .....<G [ 50.189292] rpmsg Write mcu reg:0x0081 failed, ret:-110, rpmsg_from_user: 0 [ 50.189298] done, ret:0! [ 50.198923] SPI driver adaps,ads6311spi has no spi_device_id for adaps,ads6311spi [ 50.206738] adaps,ads6311spi spi0.0: cam_sensor_spi_driver_probe() Line:7904 <DRV_ADS6311> spi_controller : spi0 000000003e423846 name=ads6311spi,bus_num=0,irq:0 mode:0x0 spi max_speed:15000000 [ 50.224142] name=ads6311spi,bus_num=0,irq[0] cs[0] mode[0] CPHA[0] CPOL[0] CS_HIGH[0] msb_first[1] the original spi max_speed[15000000] [ 50.224160] ------TRACE_PM_RUNTIME--Begin of <__sensor_power_on> Line:4003--power_on:0, callline: 7489, sensor->power_on_times: 0--- [ 50.338512] rpmsg wait for completion time-out for 100 ms. [ 50.350425] rpmsg_tx: 00000000: 00 04 00 bd 00 01 b7 ....... [ 50.363982] rpmsg Write mcu reg:0x00bd failed, ret:-110, rpmsg_from_user: 0 [ 50.363988] Fail to power on tx and rx modules. [ 50.375457] Failed to power on tx and rx modules. [ 50.482509] rpmsg wait for completion time-out for 100 ms. [ 50.482517] rpmsg_tx: 00000000: 00 05 00 8a 00 00 80 ....... [ 50.496076] rpmsg Write mcu reg:0x008a failed, ret:-110, rpmsg_from_user: 0 [ 50.496082] Fail to set rx work mode: 0. [ 50.509489] Success for sensor reset cost 2542 us, sensor chip id: 0x3400 [ 50.516413] ------TRACE_PM_RUNTIME--End of <__sensor_power_on> Line:4167--power_on:1, load_script: 0, ret: 0, sensorId: 0x3400--- [ 50.516464] 11111111111111111111111111111111111 [ 50.528132] client: insmod (1157:1157) is running on CPU 1 [ 50.536414] done, ret:0! [ 50.604139] client: v4l_id (1176:1176) is running on CPU 2 [ 50.604175] ---- S_OPEN from v4l_id (1176:1176) on CPU 2 [ 50.610005] ---- S_CLOSE from v4l_id (1176:1176) on CPU 2 [ 52.308209] client: media-ctl (1178:1178) is running on CPU 1 [ 52.316359] ---- S_OPEN from media-ctl (1178:1178) on CPU 1 [ 52.328013] ---- S_CLOSE from media-ctl (1178:1178) on CPU 1 [ 95.255658] kauditd_printk_skb: 43 callbacks suppressed [ 95.255672] audit: type=1334 audit(1709054856.724:76): prog-id=45 op=LOAD [ 95.273647] audit: type=1334 audit(1709054856.736:77): prog-id=46 op=LOAD [ 95.280529] audit: type=1334 audit(1709054856.748:78): prog-id=47 op=LOAD [ 95.288120] audit: type=1334 audit(1709054856.756:79): prog-id=48 op=LOAD [ 95.295659] audit: type=1334 audit(1709054856.764:80): prog-id=49 op=LOAD [ 95.302520] audit: type=1334 audit(1709054856.768:81): prog-id=45 op=UNLOAD [ 95.310901] audit: type=1334 audit(1709054856.780:82): prog-id=46 op=UNLOAD [ 95.317880] audit: type=1334 audit(1709054856.780:83): prog-id=47 op=UNLOAD [ 95.324866] audit: type=1334 audit(1709054856.792:84): prog-id=48 op=UNLOAD [ 95.331837] audit: type=1334 audit(1709054856.792:85): prog-id=49 op=UNLOAD
