DM6467: Some signal names on EVM are not matched with datasheet
My customer found that the signal name for timer output pins on EVM are not same as the ones in datasheet. I think we need to refer to the ones in datasheet. Would you pls help to ask Spectrumdigitial to fix this (http://support.spectrumdigital.com/boards/evmdm6467/revf/)?
Signal no.        Signal name
                     EVM          Datasheet
W8              TOUT0      TOUTOL
W7              TOUT1      TOUT0U
AA5             TOUT2      TOUT1L
AB4             TOUT3      TOUT1U
Y5               TOUT4      TOUT2
  • Chris,
    Thanks for your feedback. The EVM was designed based on the spec (even before data sheet was created). That's the reason for mis-match. I will pass this info to Spectrum to fix it in the revision of the schematic.
    Regards, Srirami.
