TDA4VL-Q1: TDA4 SA5 ti SCI intigrate issue
Part Number: TDA4VL-Q1
Hello TI experts:
We are trying to intigrate the PDK 10 in our ECU.and we meet some issue in intigrate the SCI module.
we are using the packages\ti\drv\sciclient\soc\V4\tifs-hs-enc.bin for tifs firmware.
and when the A72 core booted,the logs prints as bellows.
it seems the SCI have already response the request but not correct
VERBOSE: Message successfully sent on thread SP_HIGH_PRIORITY
VERBOSE: Message successfully received from thread SP_RESPONSE
ERROR: Failed to get response (-19)
ERROR: Transfer send failed (-19)
ERROR: Unable to query firmware capabilities (-19)
could you pls help us for this issue?
VERBOSE: Region: 0x70000000 - 0x70020000 has attributes 0xa
VERBOSE: Region: 0x70000000 - 0x7000b000 has attributes 0x2
VERBOSE: Region: 0x7000b000 - 0x7000d000 has attributes 0x42
VERBOSE: Region: 0x70018000 - 0x70019000 has attributes 0x8
mmap:
 VA:0xa00000  PA:0xa00000  size:0x200000  attr:0x8  granularity:0x40000000
 VA:0x1800000  PA:0x1800000  size:0x200000  attr:0x8  granularity:0x40000000
 VA:0x2800000  PA:0x2800000  size:0x200000  attr:0x8  granularity:0x40000000
 VA:0x32400000  PA:0x32400000  size:0x200000  attr:0x8  granularity:0x40000000
 VA:0x32800000  PA:0x32800000  size:0x200000  attr:0x8  granularity:0x40000000
 VA:0x32c00000  PA:0x32c00000  size:0x200000  attr:0x8  granularity:0x40000000
 VA:0x70000000  PA:0x70000000  size:0xb000  attr:0x2  granularity:0x40000000
 VA:0x7000b000  PA:0x7000b000  size:0x2000  attr:0x42  granularity:0x40000000
 VA:0x70018000  PA:0x70018000  size:0x1000  attr:0x8  granularity:0x40000000
 VA:0x70000000  PA:0x70000000  size:0x20000  attr:0xa  granularity:0x40000000
VERBOSE: Translation tables state:
VERBOSE:   Xlat regime:     EL3
VERBOSE:   Max allowed PA:  0xffffffff
VERBOSE:   Max allowed VA:  0xffffffff
VERBOSE:   Max mapped PA:   0x7001ffff
VERBOSE:   Max mapped VA:   0x7001ffff
VERBOSE:   Initial lookup level: 1
VERBOSE:   Entries @initial lookup level: 4
VERBOSE:   Used 3 sub-tables out of 4 (spare: 1)
  [LV1] VA:0x0 size:0x40000000
    [LV2] VA:0x0 size:0x200000
    [LV2] (4 invalid descriptors omitted)
    [LV2] VA:0xa00000 PA:0xa00000 size:0x200000 DEV-RW-XN-S
    [LV2] VA:0xc00000 size:0x200000
    [LV2] (5 invalid descriptors omitted)
    [LV2] VA:0x1800000 PA:0x1800000 size:0x200000 DEV-RW-XN-S
    [LV2] VA:0x1a00000 size:0x200000
    [LV2] (6 invalid descriptors omitted)
    [LV2] VA:0x2800000 PA:0x2800000 size:0x200000 DEV-RW-XN-S
    [LV2] VA:0x2a00000 size:0x200000
    [LV2] (380 invalid descriptors omitted)
    [LV2] VA:0x32400000 PA:0x32400000 size:0x200000 DEV-RW-XN-S
    [LV2] VA:0x32600000 size:0x200000
    [LV2] VA:0x32800000 PA:0x32800000 size:0x200000 DEV-RW-XN-S
    [LV2] VA:0x32a00000 size:0x200000
    [LV2] VA:0x32c00000 PA:0x32c00000 size:0x200000 DEV-RW-XN-S
    [LV2] VA:0x32e00000 size:0x200000
    [LV2] (104 invalid descriptors omitted)
  [LV1] VA:0x40000000 size:0x40000000
    [LV2] VA:0x40000000 size:0x200000
    [LV2] (383 invalid descriptors omitted)
    [LV2] VA:0x70000000 size:0x200000
      [LV3] VA:0x70000000 PA:0x70000000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70001000 PA:0x70001000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70002000 PA:0x70002000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70003000 PA:0x70003000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70004000 PA:0x70004000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70005000 PA:0x70005000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70006000 PA:0x70006000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70007000 PA:0x70007000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70008000 PA:0x70008000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x70009000 PA:0x70009000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x7000a000 PA:0x7000a000 size:0x1000 MEM-RO-EXEC-S
      [LV3] VA:0x7000b000 PA:0x7000b000 size:0x1000 MEM-RO-XN-S
      [LV3] VA:0x7000c000 PA:0x7000c000 size:0x1000 MEM-RO-XN-S
      [LV3] VA:0x7000d000 PA:0x7000d000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x7000e000 PA:0x7000e000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x7000f000 PA:0x7000f000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70010000 PA:0x70010000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70011000 PA:0x70011000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70012000 PA:0x70012000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70013000 PA:0x70013000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70014000 PA:0x70014000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70015000 PA:0x70015000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70016000 PA:0x70016000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70017000 PA:0x70017000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70018000 PA:0x70018000 size:0x1000 DEV-RW-XN-S
      [LV3] VA:0x70019000 PA:0x70019000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x7001a000 PA:0x7001a000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x7001b000 PA:0x7001b000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x7001c000 PA:0x7001c000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x7001d000 PA:0x7001d000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x7001e000 PA:0x7001e000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x7001f000 PA:0x7001f000 size:0x1000 MEM-RW-XN-S
      [LV3] VA:0x70020000 size:0x1000
      [LV3] (479 invalid descriptors omitted)
    [LV2] VA:0x70200000 size:0x200000
    [LV2] (126 invalid descriptors omitted)
  [LV1] VA:0x80000000 size:0x40000000
  [LV1] (1 invalid descriptors omitted)
NOTICE:  BL31: v2.10.0(debug):v2.10.0-367-g00f1ec6b8-dirty
NOTICE:  BL31: Built : 01:28:54, Nov 13 2024
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    Maximum SPI INTID supported: 991
INFO:    SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
INFO:    BL31: Initializing runtime services
ERROR:   GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
VERBOSE: BL31: cortex_a72: CPU workaround for erratum 859971 was not applied
INFO:    BL31: cortex_a72: CPU workaround for erratum 1319367 was applied
VERBOSE: BL31: cortex_a72: CPU workaround for CVE 2017_5715 was not applied
INFO:    BL31: cortex_a72: CPU workaround for CVE 2018_3639 was applied
INFO:    BL31: cortex_a72: CPU workaround for CVE 2022_23960 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xfe000000
INFO:    SPSR = 0x3c9
VERBOSE: Argument #0 = 0xfdf80000
VERBOSE: Argument #1 = 0x0
VERBOSE: Argument #2 = 0x0
VERBOSE: Argument #3 = 0x0
VERBOSE: Argument #4 = 0x0
VERBOSE: Argument #5 = 0x0
VERBOSE: Argument #6 = 0x0
VERBOSE: Argument #7 = 0x0
U-Boot 2024.04-dirty (Nov 13 2024 - 09:30:37 +0800)
SoC:   J721S2 SR1.0 HS-SE
Model: Texas Instruments J721S2 EVM
i2c_omap i2c@42120000: pinctrl_select_state_full: uclass_get_device_by_phandle_i        d: err=-19
EEPROM not available at 0x50, trying to read at 0x51
Timed out in wait_for_bb: status=1000
Reading on-board EEPROM at 0x51 failed -121
Board: J721S2X-PM1-SOM rev E1
DRAM:  2 GiB (effective 16 GiB)
ti_sci system-controller@44083000: ti_sci_get_response: Message receive failed.
mmap:
INFO:    SPSR = 0x3c9
No serial driver found
resetting ...
System reset not supported on this platform
### ERROR ### Please RESET the board ###
mmap:
INFO:    SPSR = 0x3c9
resetting ...
mmap:
VERBOSE: Waiting for thread SP_RESPONSE to fill
ERROR:   Timeout waiting for thread SP_RESPONSE to fill
ERROR:   Thread SP_RESPONSE verification failed (-60)
ERROR:   Message receive failed (-60)
ERROR:   Failed to get response (-60)
ERROR:   Transfer send failed (-60)
WARNING: Unable to take system power reference
ERROR:   Unable to query firmware capabilities (-60)
INFO:    SPSR = 0x3c9
mmap:
INFO:    SPSR = 0x3c9
mmap:
INFO:    SPSR = 0x3c9
i2c_omap i2c@42120000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
ti_sci system-controller@44083000: ti_sci_get_response: Message receive failed. ret = -110
resetting ...
