Part Number: J722SXH01EVM
Other Parts Discussed in Thread: AM67A
Hello, I'm experiencing a boot loop issue with my AM67A EVM, which fails to fully boot and restarts at different points in the initialization process. Here’s a detailed description of the steps I’ve taken, the observed behavior, and logs:
Setup:
- Platform: AM67A EVM
- Image: Downloaded the default bootable SD card image (tisdk-edgeai-image-j722s-evm.wic.xz ) from the official TI release page.
- Flashing: Used Balena Etcher to flash the image onto an SD card
I tried with version v10x and v9x and the issue is the same. I also tried different SD card.
Issue:
The system goes into a boot loop, restarting before reaching a stable login prompt. Each attempt logs slightly different stopping points, suggesting a critical error that triggers a reboot at various stages.
U-Boot SPL 2024.04-ti-g818c76aed67f (Aug 01 2024 - 19:19:47 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
SPL initial stack usage: 17048 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE: BL31: Built : 16:09:05, Feb 9 2024
U-Boot 2024.04-ti-g818c76aed67f (Aug 01 2024 - 19:19:47 +0000)
SoC: J722S SR1.0 HS-FS
Model: Texas Instruments J722S EVM
DRAM: 2 GiB (effective 8 GiB)
Core: 79 devices, 29 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
940 bytes read in 33 ms (27.3 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
50228 bytes read in 60 ms (817.4 KiB/s)
Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices
Load Remote Processor 0 with data@addr=0x82000000 50228 bytes: Success!
600992 bytes read in 75 ms (7.6 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 600992 bytes: Success!
11821224 bytes read in 277 ms (40.7 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 11821224 bytes: Success!
11821224 bytes read in 278 ms (40.6 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 11821224 bytes: Success!
20560384 bytes read in 838 ms (23.4 MiB/s)
78078 bytes read in 39 ms (1.9 MiB/s)
Working FDT set to 88000000
6651 bytes read in 35 ms (185.5 KiB/s)
ERROR: reserving fdt memory region failed (addr=880000000 size=20000000 flags=4)
Loading Device Tree to 000000008fee9000, end 000000008fffffff ... OK
Working FDT set to 8fee9000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.32-ti-gdb8871293143-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #1 SMP PREEMPT Thu Aug 1 19:10:56 UTC 2024
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: Texas Instruments J722S EVM
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: 0x000000009e780000..0x000000009e7fffff (512 KiB) nomap non-reusable tfa@9e780000
[ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a5000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a6ffffff (32768 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region@a5000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000acffffff (98304 KiB) nomap non-reusable vision-apps-dma-memory@a7000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ad000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@ad000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000ad000000..0x00000000ad0fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@ad000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ad100000, size 63 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@ad100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000ad100000..0x00000000b0ffffff (64512 KiB) nomap non-reusable vision-apps-c71_0-memory@ad100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b1000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b1000000..0x00000000b10fffff (1024 KiB) nomap non-reusable vision-apps-c71_1-dma-memory@b1000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b1100000, size 63 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory1b1100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b1100000..0x00000000b4ffffff (64512 KiB) nomap non-reusable vision-apps-c71_1-memory1b1100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b5000000, size 40 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@b5000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b5000000..0x00000000b77fffff (40960 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@b5000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000880000000..0x000000089fffffff (524288 KiB) nomap non-reusable vision-apps-core-heap-memory-hi@880000000
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] OF: reserved mem: 0x0000000900000000..0x000000091fffffff (524288 KiB) map non-reusable vision_apps_shared-memories
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 896 MiB
[ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000980000000..0x00000009b7ffffff (917504 KiB) map reusable linux-cma-buffers@980000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x00000000a3ffffff]
[ 0.000000] node 0: [mem 0x00000000a4000000-0x00000000a4ffffff]
[ 0.000000] node 0: [mem 0x00000000a5000000-0x00000000b77fffff]
[ 0.000000] node 0: [mem 0x00000000b7800000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000089fffffff]
[ 0.000000] node 0: [mem 0x00000008a0000000-0x00000009ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 20 pages/cpu s43112 r8192 d30616 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 5783132K/8388608K available (12160K kernel code, 1262K rwdata, 4064K rodata, 2432K init, 506K bss, 1687972K reserved, 917504K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008a0040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a0050000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008595] Console: colour dummy device 80x25
[ 0.013187] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023857] pid_max: default: 32768 minimum: 301
[ 0.028655] LSM: initializing lsm=capability,integrity
[ 0.034019] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.041781] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.051663] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.058971] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.066877] rcu: Hierarchical SRCU implementation.
[ 0.071777] rcu: Max phase no-delay instances is 1000.
[ 0.077369] Platform MSI: msi-controller@1820000 domain created
[ 0.083710] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.093220] EFI services will not be available.
[ 0.098112] smp: Bringing up secondary CPUs ...
[ 0.103348] Detected VIPT I-cache on CPU1
[ 0.103423] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.103439] GICv3: CPU1: using allocated LPI pending table @0x00000008a0060000
[ 0.103490] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.104155] Detected VIPT I-cache on CPU2
[ 0.104210] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.104223] GICv3: CPU2: using allocated LPI pending table @0x00000008a0070000
[ 0.104255] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.104835] Detected VIPT I-cache on CPU3
[ 0.104884] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.104898] GICv3: CPU3: using allocated LPI pending table @0x00000008a0080000
[ 0.104928] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.104997] smp: Brought up 1 node, 4 CPUs
[ 0.184636] SMP: Total of 4 processors activated.
[ 0.189443] CPU features: detected: 32-bit EL0 Support
[ 0.194709] CPU features: detected: CRC32 instructions
[ 0.200015] CPU: All CPU(s) started at EL2
[ 0.204208] alternatives: applying system-wide alternatives
[ 0.211496] devtmpfs: initialized
[ 0.226978] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.236959] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.266903] pinctrl core: initialized pinctrl subsystem
[ 0.272812] DMI not present or invalid.
[ 0.277335] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.284255] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.291696] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.299808] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.308062] audit: initializing netlink subsys (disabled)
[ 0.313765] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
[ 0.314191] thermal_sys: Registered thermal governor 'step_wise'
[ 0.321689] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.327868] cpuidle: using governor menu
[ 0.338694] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.345711] ASID allocator initialised with 65536 entries
[ 0.365980] platform 30220000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.377973] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.388824] Modules: 27616 pages in range for non-PLT usage
[ 0.388832] Modules: 519136 pages in range for PLT usage
[ 0.395259] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.407642] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.414045] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.420976] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.427377] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.434308] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.440708] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.447641] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.455411] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
[ 0.465164] iommu: Default domain type: Translated
[ 0.470088] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.476678] SCSI subsystem initialized
[ 0.480803] usbcore: registered new interface driver usbfs
[ 0.486436] usbcore: registered new interface driver hub
[ 0.491890] usbcore: registered new device driver usb
[ 0.497612] pps_core: LinuxPPS API ver. 1 registered
[ 0.502688] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.512026] PTP clock support registered
[ 0.516212] EDAC MC: Ver: 3.0.0
[ 0.519906] scmi_core: SCMI protocol bus registered
[ 0.525200] FPGA manager framework
[ 0.528751] Advanced Linux Sound Architecture Driver Initialized.
[ 0.535873] vgaarb: loaded
[ 0.538960] clocksource: Switched to clocksource arch_sys_counter
[ 0.545451] VFS: Disk quotas dquot_6.6.0
[ 0.549499] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.562692] Carveout Heap: Exported 512 MiB at 0x0000000900000000
[ 0.569038] NET: Registered PF_INET protocol family
[ 0.574302] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.587253] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.596085] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.604019] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.612510] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.621872] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.628741] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.635842] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.643519] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.649782] RPC: Registered named UNIX socket transport module.
[ 0.655857] RPC: Registered udp transport module.
[ 0.660661] RPC: Registered tcp transport module.
[ 0.665465] RPC: Registered tcp-with-tls transport module.
[ 0.671068] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.677651] NET: Registered PF_XDP protocol family
[ 0.682561] PCI: CLS 0 bytes, default 64
[ 0.687977] Initialise system trusted keyrings
[ 0.692755] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.699653] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.705879] NFS: Registering the id_resolver key type
[ 0.711071] Key type id_resolver registered
[ 0.715344] Key type id_legacy registered
[ 0.719455] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.726302] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.766295] Key type asymmetric registered
[ 0.770485] Asymmetric key parser 'x509' registered
[ 0.775513] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.783200] io scheduler mq-deadline registered
[ 0.787834] io scheduler kyber registered
[ 0.791953] io scheduler bfq registered
[ 0.799180] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.805763] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.818712] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 0.835737] loop: module loaded
[ 0.840021] megasas: 07.725.01.00-rc1
[ 0.847545] tun: Universal TUN/TAP device driver, 1.6
[ 0.853800] VFIO - User Level meta-driver version: 0.3
[ 0.860316] usbcore: registered new interface driver usb-storage
[ 0.867099] i2c_dev: i2c /dev entries driver
[ 0.872819] sdhci: Secure Digital Host Controller Interface driver
[ 0.879155] sdhci: Copyright(c) Pierre Ossman
[ 0.883850] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.890319] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.896793] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.904041] usbcore: registered new interface driver usbhid
[ 0.909740] usbhid: USB HID core driver
[ 0.913956] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[ 0.920800] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[ 0.927586] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[ 0.934378] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
[ 0.942484] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.951594] optee: probing for conduit method.
[ 0.956165] optee: revision 4.2 (12d7c4ee)
[ 0.956462] optee: dynamic shared memory is enabled
[ 0.965872] optee: initialized driver
[ 0.971583] Initializing XFRM netlink socket
[ 0.976002] NET: Registered PF_PACKET protocol family
[ 0.981250] Key type dns_resolver registered
[ 0.993135] registered taskstats version 1
[ 0.997472] Loading compiled-in X.509 certificates
[ 1.014432] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[ 1.073108] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.080316] pca953x 1-0023: supply vcc not found, using dummy regulator
[ 1.087223] pca953x 1-0023: using AI
[ 1.113075] omap_i2c 20000000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.120016] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 1.129964] platform 30220000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 1.139706] i2c 2-003b: Fixed dependency cycle(s) with /connector-hdmi
[ 1.146421] i2c 2-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000
[ 1.153990] omap_i2c 20010000.i2c: bus 2 rev0.12 at 100 kHz
[ 1.160860] pca954x 3-0070: supply vdd not found, using dummy regulator
[ 1.191259] i2c i2c-3: Added multiplexed i2c bus 4
[ 1.196334] i2c i2c-3: Added multiplexed i2c bus 5
[ 1.201238] pca954x 3-0070: registered 2 multiplexed busses for I2C switch pca9543
[ 1.209192] pca954x 3-0071: supply vdd not found, using dummy regulator
[ 1.216355] i2c i2c-3: Added multiplexed i2c bus 6
[ 1.221420] i2c i2c-3: Added multiplexed i2c bus 7
[ 1.226330] pca954x 3-0071: registered 2 multiplexed busses for I2C switch pca9543
[ 1.234108] omap_i2c 20020000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.240004] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 1.248322] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.257523] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.266484] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
[ 1.280823] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.289265] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16)
[ 1.300092] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.310875] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.320446] ti-udma 4e230000.dma-controller: Number of rings: 40
[ 1.328075] ti-udma 4e230000.dma-controller: Channels: 20 (bchan: 0, tchan: 8, rchan: 12)
[ 1.338279] printk: console [ttyS2] disabled
[ 1.342977] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 273, base_baud = 3000000) is a 8250
[ 1.351863] printk: console [ttyS2] enabled
[ 1.360339] printk: bootconsole [ns16550a0] disabled
[ 1.374158] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.379247] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.386209] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.391603] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.398276] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.404744] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.411301] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.417470] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.424268] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.430711] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.482969] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
[ 1.494353] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.502492] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
[ 1.515493] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.522626] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.529209] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
[ 1.543065] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.553483] cpu cpu0: _of_add_opp_table_v2: no supported OPPs
[ 1.561278] cpu cpu0: OPP table can't be empty
[ 1.567125] mmc0: CQHCI version 5.10
[ 1.575178] pca953x 2-0020: supply vcc not found, using dummy regulator
[ 1.581961] pca953x 2-0020: using no AI
[ 1.607415] j721e-pcie f102000.pcie: host bridge /bus@f0000/pcie@f102000 ranges:
[ 1.609583] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.614861] j721e-pcie f102000.pcie: IO 0x0068001000..0x0068010fff -> 0x0068001000
[ 1.630399] j721e-pcie f102000.pcie: MEM 0x0068011000..0x006fffffff -> 0x0068011000
[ 1.638491] j721e-pcie f102000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.706020] mmc0: Command Queue Engine enabled
[ 1.710497] mmc0: new HS400 MMC card at address 0001
[ 1.716092] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[ 1.722005] mmcblk0: p1 p2
[ 1.725431] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[ 1.731302] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[ 1.737028] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[ 2.651655] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
[ 2.657967] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.663455] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x68001000-0x68010fff])
[ 2.672922] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
[ 2.679816] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
[ 2.685887] pci 0000:00:00.0: supports D1
[ 2.689894] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.698315] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.706507] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.713138] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.718236] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[ 2.725149] pcieport 0000:00:00.0: PME: Signaling with IRQ 486
[ 2.731283] pcieport 0000:00:00.0: AER: enabled with IRQ 486
[ 2.738669] mmc1: CQHCI version 5.10
[ 2.738819] debugfs: Directory 'pd:244' with parent 'pm_genpd' already present!
[ 2.751138] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 2.758471] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 2.767097] clk: Disabling unused clocks
[ 2.777126] ALSA device list:
[ 2.779530] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 2.780186] No soundcards found.
[ 2.791465] Waiting for root device PARTUUID=076c4a2a-02...
[ 2.843675] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 2.850988] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
[ 2.860041] mmcblk1: p1 p2
[ 3.070022] EXT4-fs (mmcblk1p2): recovery complete
[ 3.081709] EXT4-fs (mmcblk1p2): mounted filesystem 0c2ac924-7a74-402b-b4a1-6ffdfa34bea9 r/w with ordered data mode. Quota mode: none.
[ 3.093876] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 3.102652] devtmpfs: mounted
[ 3.106342] Freeing unused kernel memory: 2432K
[ 3.110937] Run /sbin/init as init process
[ 3.310464] systemd[1]: System time before build time, advancing clock.
[ 3.352363] NET: Registered PF_INET6 protocol family
[ 3.358367] Segment Routing with IPv6
[ 3.362097] In-situ OAM (IOAM) with IPv6
[ 3.402650] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.434549] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[ 3.459375] systemd[1]: Hostname set to <j722s-evm>.
[ 3.556946] systemd-sysv-generator[105]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[ 3.781412] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.902226] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.989972] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.033028] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 4.057507] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 4.081523] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 4.104837] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.127462] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 4.151339] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.175170] systemd[1]: Expecting device /dev/ttyS2...
[ 4.191229] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 4.207125] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.227092] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 4.243114] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 4.296638] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 4.319309] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 4.348536] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 4.371559] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 4.396281] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 4.419858] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.443817] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.463959] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.491732] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.511747] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.531722] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 4.583381] systemd[1]: Mounting Huge Pages File System...
[ 4.603395] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.631578] systemd[1]: Mounting Kernel Debug File System...
[ 4.655646] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.675573] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.705071] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.731943] systemd[1]: Starting Load Kernel Module configfs...
[ 4.783714] systemd[1]: Starting Load Kernel Module drm...
[ 4.807945] systemd[1]: Starting Load Kernel Module fuse...
[ 4.842823] systemd[1]: Starting Start psplash boot splash screen...
[ 4.849682] fuse: init (API version 7.39)
[ 4.879209] systemd[1]: Starting RPC Bind...
[ 4.895528] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 4.916584] systemd[1]: Starting Journal Service...
[ 4.939726] systemd[1]: Starting Load Kernel Modules...
[ 4.960554] systemd[1]: Starting Generate network units from Kernel command line...
[ 4.994004] cryptodev: loading out-of-tree module taints kernel.
[ 5.001646] cryptodev: driver 1.13 loaded.
[ 5.013129] systemd-journald[124]: Collecting audit messages is enabled.
[ 5.017534] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.048931] systemd[1]: Starting Coldplug All udev Devices...
[ 5.079944] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 5.101706] systemd[1]: Mounted Huge Pages File System.
[ 5.103515] EXT4-fs (mmcblk1p2): re-mounted 0c2ac924-7a74-402b-b4a1-6ffdfa34bea9 r/w. Quota mode: none.
[ OK ] Mounted Huge Pages File System.
[ 5.137425] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Start psplas…temd progress communication helper.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev gr[ 5.584448] systemd-journald[124]: Received client request to flush runtime journal.
acefully...
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create Static Device Nodes in /dev gracefully.
Starting Create System Users...
[ 5.823762] audit: type=1334 audit(1709054766.512:2): prog-id=6 op=LOAD
[ 5.830476] audit: type=1334 audit(1709054766.516:3): prog-id=7 op=LOAD
[ 5.837159] audit: type=1334 audit(1709054766.524:4): prog-id=8 op=LOAD
Starting User Database Manager...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Started User Database Manager.
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /var/volatile...
[ 6.157814] audit: type=1334 audit(1709054766.844:5): prog-id=9 op=LOAD
[ 6.164541] audit: type=1334 audit(1709054766.852:6): prog-id=10 op=LOAD
Starting Rule-based Manager for Device Events and Files...
[ OK ] Mounted /var/volatile.
Starting Load/Save OS Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Create Volatile Files and Directories...
[ OK ] Finished Create Volatile Files and Directories.
Starting Rebuild Journal Catalog...
[ 6.416537] audit: type=1334 audit(1709054767.104:7): prog-id=11 op=LOAD
Starting Network Name Resolution...
[ 6.440580] audit: type=1334 audit(1709054767.128:8): prog-id=12 op=LOAD
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Finished Rebuild Journal Catalog.
[ OK ] Started Network Name Resolution.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Reached target System Time Set.
[ OK ] Found device /dev/ttyS2.
[ 7.003039] random: crng init done
[ OK ] Finished Load/Save OS Random Seed.
[ 7.792243] CAN device driver interface
[ 7.876237] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@ad000000
[ 7.902562] k3-dsp-rproc 7e000000.dsp: configured DSP for IPC-only mode
[ 7.927216] mc: Linux media interface: v0.10
[ 7.932311] remoteproc remoteproc0: 7e000000.dsp is available
[ 7.938453] remoteproc remoteproc0: attaching to 7e000000.dsp
[ 7.957076] videodev: Linux video capture interface: v2.00
[ 7.984102] k3-dsp-rproc 7e000000.dsp: DSP initialized in IPC-only mode
[ 7.990906] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vision-apps-c71-dma-memory@ad000000
[ 8.006169] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 8.007176] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 8.014007] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
[ 8.020837] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.026796] remoteproc remoteproc0: remote processor 7e000000.dsp is now attached
[ 8.048677] k3-dsp-rproc 7e200000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b1000000
[ 8.062438] k3-dsp-rproc 7e200000.dsp: configured DSP for IPC-only mode
[ 8.086551] platform 79000000.r5f: configured R5F for IPC-only mode
[ 8.091691] remoteproc remoteproc1: 7e200000.dsp is available
[ 8.093170] platform 79000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
[ 8.100006] remoteproc remoteproc1: attaching to 7e200000.dsp
[ 8.100520] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.122738] remoteproc remoteproc2: 79000000.r5f is available
[ 8.122836] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[ 8.128802] remoteproc remoteproc2: attaching to 79000000.r5f
[ 8.134024] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 8.153337] k3-dsp-rproc 7e200000.dsp: DSP initialized in IPC-only mode
[ 8.154588] platform 79000000.r5f: R5F core initialized in IPC-only mode
[ 8.160166] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b1000000
[ 8.167148] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.167163] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
[ 8.183330] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 8.185671] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 8.196241] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
[ 8.215564] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[ 8.215728] remoteproc remoteproc1: remote processor 7e200000.dsp is now attached
[ 8.223735] vdec 30210000.video-codec: Product Code: 0x521c
[ 8.224922] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 8.224961] rproc-virtio rproc-virtio.3.auto: registered virtio2 (type 7)
[ 8.224969] remoteproc remoteproc2: remote processor 79000000.r5f is now attached
[ 8.243016] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.249931] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[ 8.251035] vdec 30210000.video-codec: Firmware Revision: 320127
[ 8.266189] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 8.273960] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[ 8.293465] platform 78000000.r5f: configured R5F for IPC-only mode
[ 8.299563] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.341456] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.344057] platform 78000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ OK ] Reached target Hardware activated USB gadget.
[ 8.387272] remoteproc remoteproc3: 78000000.r5f is available
[ 8.392098] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.393854] remoteproc remoteproc3: attaching to 78000000.r5f
[ 8.431310] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.434827] platform 78000000.r5f: R5F core initialized in IPC-only mode
[ 8.446696] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.458717] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.499059] m_can_platform 4e08000.can: m_can device registered (irq=500, version=32)
[ 8.510213] sii902x 2-003b: supply iovcc not found, using dummy regulator
[ 8.518166] sii902x 2-003b: supply cvcc12 not found, using dummy regulator
[ 8.532134] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 8.532747] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[ 8.539247] rproc-virtio rproc-virtio.4.auto: registered virtio3 (type 7)
[ 8.545545] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[ 8.552098] remoteproc remoteproc3: remote processor 78000000.r5f is now attached
[ 8.556557] e5010 fd20000.e5010: Device registered as /dev/video2
[ 8.561616] i2c i2c-2: Added multiplexed i2c bus 8
[ 8.586061] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.594849] platform 78400000.r5f: configured R5F for IPC-only mode
[ 8.602323] platform 78400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 8.604103] [drm] Initialized tidss 1.0.0 20180215 for 30220000.dss on minor 0
[ 8.620016] tidss 30220000.dss: [drm] Cannot find any crtc or sizes
[ 8.627755] tidss 30220000.dss: [drm] Cannot find any crtc or sizes
[ 8.631407] remoteproc remoteproc4: 78400000.r5f is available
[ 8.640500] remoteproc remoteproc4: attaching to 78400000.r5f
[ 8.647698] platform 78400000.r5f: R5F core initialized in IPC-only mode
[ 8.649448] PVR_K: 213: Device: fd80000.gpu
[ 8.654511] rproc-virtio rproc-virtio.6.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 8.748229] m_can_platform 4e18000.can: m_can device registered (irq=503, version=32)
[ 8.766672] PVR_K: 213: Read BVNC 36.53.104.796 from HW device registers
[ 8.777183] PVR_K: 213: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[ 8.797594] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 8.800040] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 8.805275] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 8.816360] rproc-virtio rproc-virtio.6.auto: registered virtio4 (type 7)
[ 8.817661] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 8.823106] [drm] Initialized pvr 24.1.6554834 20170530 for fd80000.gpu on minor 1
[ 8.830667] remoteproc remoteproc4: remote processor 78400000.r5f is now attached
[ 8.831971] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.854442] virtio_rpmsg_bus virtio0: msg received with no recipient
[ 8.874660] m_can_platform 20701000.can: m_can device registered (irq=505, version=32)
Starting Virtual Console Setup...
[ 8.957038] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.976006] virtio_rpmsg_bus virtio4: msg received with no recipient
[ 8.982778] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[ 8.998322] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[ 9.014454] virtio_rpmsg_bus virtio1: msg received with no recipient
[ 9.050772] m_can_platform 4e18000.can mcu_mcan1: renamed from can1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Running uenvcmd ...
50228 bytes read in 61 ms (803.7 KiB/s)
11821224 bytes read in 276 ms (40.8 MiB/s)
20560384 bytes read in 839 ms (23.4 MiB/s)
78078 bytes read in 38 ms (2 MiB/s)
Starting kernel ...
[ 0.008593] Console: colour dummy device 80x25
[ 0.013185] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023855] pid_max: default: 32768 minimum: 301
[ 0.028645] LSM: initializing lsm=capability,integrity
[ 0.034007] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.041768] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.051643] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.058943] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.066851] rcu: Hierarchical SRCU implementation.
[ 0.071751] rcu: Max phase no-delay instances is 1000.
[ 0.077342] Platform MSI: msi-controller@1820000 domain created
[ 0.083684] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.093193] EFI services will not be available.
[ 0.098087] smp: Bringing up secondary CPUs ...
[ 0.103327] Detected VIPT I-cache on CPU1
[ 0.103401] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.103418] GICv3: CPU1: using allocated LPI pending table @0x00000008a0060000
[ 0.103466] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.104144] Detected VIPT I-cache on CPU2
[ 0.104198] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.104211] GICv3: CPU2: using allocated LPI pending table @0x00000008a0070000
[ 0.104245] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.104820] Detected VIPT I-cache on CPU3
[ 0.104872] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.104885] GICv3: CPU3: using allocated LPI pending table @0x00000008a0080000
[ 0.104916] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.104985] smp: Brought up 1 node, 4 CPUs
[ 0.184619] SMP: Total of 4 processors activated.
[ 0.189425] CPU features: detected: 32-bit EL0 Support
[ 0.194690] CPU features: detected: CRC32 instructions
[ 0.199994] CPU: All CPU(s) started at EL2
[ 0.204187] alternatives: applying system-wide alternatives
[ 0.211554] devtmpfs: initialized
[ 0.227047] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.237026] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.266905] pinctrl core: initialized pinctrl subsystem
[ 0.272806] DMI not present or invalid.
[ 0.277330] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.284251] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.291693] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.299800] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.308053] audit: initializing netlink subsys (disabled)
[ 0.313755] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
[ 0.314182] thermal_sys: Registered thermal governor 'step_wise'
[ 0.321678] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.327859] cpuidle: using governor menu
[ 0.338687] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.345705] ASID allocator initialised with 65536 entries
[ 0.365935] platform 30220000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.377933] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.388789] Modules: 27616 pages in range for non-PLT usage
[ 0.388799] Modules: 519136 pages in range for PLT usage
[ 0.395226] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.407605] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.414007] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.420939] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.427338] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.434269] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.440670] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.447602] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.455374] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
[ 0.465143] iommu: Default domain type: Translated
[ 0.470059] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.476642] SCSI subsystem initialized
[ 0.480779] usbcore: registered new interface driver usbfs
[ 0.486407] usbcore: registered new interface driver hub
[ 0.491859] usbcore: registered new device driver usb
[ 0.497580] pps_core: LinuxPPS API ver. 1 registered
[ 0.502652] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.511991] PTP clock support registered
[ 0.516178] EDAC MC: Ver: 3.0.0
[ 0.519880] scmi_core: SCMI protocol bus registered
[ 0.525178] FPGA manager framework
[ 0.528732] Advanced Linux Sound Architecture Driver Initialized.
[ 0.535836] vgaarb: loaded
[ 0.538940] clocksource: Switched to clocksource arch_sys_counter
[ 0.545420] VFS: Disk quotas dquot_6.6.0
[ 0.549456] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.562700] Carveout Heap: Exported 512 MiB at 0x0000000900000000
[ 0.569075] NET: Registered PF_INET protocol family
[ 0.574348] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.587317] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.596151] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.604086] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.612575] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.621909] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.628773] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.635878] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.643551] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.649812] RPC: Registered named UNIX socket transport module.
[ 0.655888] RPC: Registered udp transport module.
[ 0.660691] RPC: Registered tcp transport module.
[ 0.665494] RPC: Registered tcp-with-tls transport module.
[ 0.671104] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.677688] NET: Registered PF_XDP protocol family
[ 0.682598] PCI: CLS 0 bytes, default 64
[ 0.687938] Initialise system trusted keyrings
[ 0.692705] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.699605] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.705811] NFS: Registering the id_resolver key type
[ 0.711000] Key type id_resolver registered
[ 0.715272] Key type id_legacy registered
[ 0.719383] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.726231] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.766213] Key type asymmetric registered
[ 0.770404] Asymmetric key parser 'x509' registered
[ 0.775430] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.783121] io scheduler mq-deadline registered
[ 0.787755] io scheduler kyber registered
[ 0.791874] io scheduler bfq registered
[ 0.799099] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.805708] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.818611] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 0.835623] loop: module loaded
[ 0.839913] megasas: 07.725.01.00-rc1
[ 0.847400] tun: Universal TUN/TAP device driver, 1.6
[ 0.853608] VFIO - User Level meta-driver version: 0.3
[ 0.860151] usbcore: registered new interface driver usb-storage
[ 0.866961] i2c_dev: i2c /dev entries driver
[ 0.872768] sdhci: Secure Digital Host Controller Interface driver
[ 0.879119] sdhci: Copyright(c) Pierre Ossman
[ 0.883841] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.890315] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.896789] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.904037] usbcore: registered new interface driver usbhid
[ 0.909741] usbhid: USB HID core driver
[ 0.913958] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[ 0.920816] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[ 0.927603] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[ 0.934389] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
[ 0.942475] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.951565] optee: probing for conduit method.
[ 0.956128] optee: revision 4.2 (12d7c4ee)
[ 0.956415] optee: dynamic shared memory is enabled
[ 0.965824] optee: initialized driver
[ 0.971521] Initializing XFRM netlink socket
[ 0.975945] NET: Registered PF_PACKET protocol family
[ 0.981181] Key type dns_resolver registered
[ 0.993006] registered taskstats version 1
[ 0.997350] Loading compiled-in X.509 certificates
[ 1.014259] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[ 1.072928] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.080155] pca953x 1-0023: supply vcc not found, using dummy regulator
[ 1.087058] pca953x 1-0023: using AI
[ 1.113052] omap_i2c 20000000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.119980] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 1.129922] platform 30220000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 1.139656] i2c 2-003b: Fixed dependency cycle(s) with /connector-hdmi
[ 1.146374] i2c 2-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000
[ 1.153945] omap_i2c 20010000.i2c: bus 2 rev0.12 at 100 kHz
[ 1.160800] pca954x 3-0070: supply vdd not found, using dummy regulator
[ 1.191245] i2c i2c-3: Added multiplexed i2c bus 4
[ 1.196325] i2c i2c-3: Added multiplexed i2c bus 5
[ 1.201229] pca954x 3-0070: registered 2 multiplexed busses for I2C switch pca9543
[ 1.209179] pca954x 3-0071: supply vdd not found, using dummy regulator
[ 1.216351] i2c i2c-3: Added multiplexed i2c bus 6
[ 1.221416] i2c i2c-3: Added multiplexed i2c bus 7
[ 1.226320] pca954x 3-0071: registered 2 multiplexed busses for I2C switch pca9543
[ 1.234101] omap_i2c 20020000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.240005] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 1.248325] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.257514] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.266476] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
[ 1.280810] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.289279] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16)
[ 1.300110] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.310919] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.320519] ti-udma 4e230000.dma-controller: Number of rings: 40
[ 1.328141] ti-udma 4e230000.dma-controller: Channels: 20 (bchan: 0, tchan: 8, rchan: 12)
[ 1.338421] printk: console [ttyS2] disabled
[ 1.343137] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 273, base_baud = 3000000) is a 8250
[ 1.352016] printk: console [ttyS2] enabled
[ 1.360487] printk: bootconsole [ns16550a0] disabled
[ 1.386116] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.391220] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.398183] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.403578] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.410259] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.416698] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.423248] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.429414] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.436232] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.442697] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.494951] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
[ 1.506320] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.514455] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
[ 1.527466] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.534600] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.541186] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
[ 1.555113] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.567608] cpu cpu0: _of_add_opp_table_v2: no supported OPPs
[ 1.573473] cpu cpu0: OPP table can't be empty
[ 1.579205] mmc0: CQHCI version 5.10
[ 1.587151] pca953x 2-0020: supply vcc not found, using dummy regulator
[ 1.593945] pca953x 2-0020: using no AI
[ 1.619497] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.634810] j721e-pcie f102000.pcie: host bridge /bus@f0000/pcie@f102000 ranges:
[ 1.642263] j721e-pcie f102000.pcie: IO 0x0068001000..0x0068010fff -> 0x0068001000
[ 1.650359] j721e-pcie f102000.pcie: MEM 0x0068011000..0x006fffffff -> 0x0068011000
[ 1.658449] j721e-pcie f102000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.713383] mmc0: Command Queue Engine enabled
[ 1.717872] mmc0: new HS400 MMC card at address 0001
[ 1.723507] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[ 1.729387] mmcblk0: p1 p2
[ 1.732787] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[ 1.738633] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[ 1.744351] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[ 2.671634] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
[ 2.677948] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.683435] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x68001000-0x68010fff])
[ 2.692902] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff]
[ 2.699797] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400
[ 2.705871] pci 0000:00:00.0: supports D1
[ 2.709877] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.718316] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.726514] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.733147] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.738238] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[ 2.745157] pcieport 0000:00:00.0: PME: Signaling with IRQ 486
[ 2.751266] pcieport 0000:00:00.0: AER: enabled with IRQ 486
[ 2.758700] mmc1: CQHCI version 5.10
[ 2.758816] debugfs: Directory 'pd:244' with parent 'pm_genpd' already present!
[ 2.771203] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 2.778535] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 2.787147] clk: Disabling unused clocks
[ 2.797461] ALSA device list:
[ 2.799516] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 2.800436] No soundcards found.
[ 2.811616] Waiting for root device PARTUUID=076c4a2a-02...
[ 2.861660] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 2.868935] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
[ 2.877965] mmcblk1: p1 p2
[ 3.087638] EXT4-fs (mmcblk1p2): recovery complete
[ 3.093696] EXT4-fs (mmcblk1p2): mounted filesystem 0c2ac924-7a74-402b-b4a1-6ffdfa34bea9 r/w with ordered data mode. Quota mode: none.
[ 3.105868] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 3.114713] devtmpfs: mounted
[ 3.118407] Freeing unused kernel memory: 2432K
[ 3.122989] Run /sbin/init as init process
[ 3.322440] systemd[1]: System time before build time, advancing clock.
[ 3.364196] NET: Registered PF_INET6 protocol family
[ 3.370197] Segment Routing with IPv6
[ 3.373923] In-situ OAM (IOAM) with IPv6
[ 3.414638] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.446463] systemd[1]: Detected architecture arm64.
[ 3.471333] systemd[1]: Hostname set to <j722s-evm>.
[ 3.582696] systemd-sysv-generator[107]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[ 3.834401] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.954891] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 4.042766] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.076973] systemd[1]: Created slice Slice /system/getty.
[ 4.101449] systemd[1]: Created slice Slice /system/modprobe.
[ 4.125499] systemd[1]: Created slice Slice /system/serial-getty.
[ 4.148827] systemd[1]: Created slice User and Session Slice.
[ 4.171451] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.195332] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.219156] systemd[1]: Expecting device /dev/ttyS2...
[ 4.235218] systemd[1]: Reached target Path Units.
[ 4.251110] systemd[1]: Reached target Remote File Systems.
[ 4.271082] systemd[1]: Reached target Slice Units.
[ 4.287096] systemd[1]: Reached target Swaps.
[ 4.340394] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 4.367277] systemd[1]: Reached target RPC Port Mapper.
[ 4.396480] systemd[1]: Listening on Process Core Dump Socket.
[ 4.419504] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.444270] systemd[1]: Listening on Journal Audit Socket.
[ 4.467802] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.491823] systemd[1]: Listening on Journal Socket.
[ 4.507972] systemd[1]: Listening on Network Service Netlink Socket.
[ 4.535713] systemd[1]: Listening on udev Control Socket.
[ 4.555700] systemd[1]: Listening on udev Kernel Socket.
[ 4.575739] systemd[1]: Listening on User Database Manager Socket.
[ 4.627361] systemd[1]: Mounting Huge Pages File System...
[ 4.647369] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.695398] systemd[1]: Mounting Kernel Debug File System...
[ 4.715496] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.735360] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.757128] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.783926] systemd[1]: Starting Load Kernel Module configfs...
[ 4.803791] systemd[1]: Starting Load Kernel Module drm...
[ 4.823988] systemd[1]: Starting Load Kernel Module fuse...
[ 4.856790] systemd[1]: Starting Start psplash boot splash screen...
Starting Start psplash boot splash screen.[ 4.865077] fuse: init (API version 7.39)
[ 4.891687] systemd[1]: Starting RPC Bind...
[ 4.907479] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 4.928248] systemd[1]: Starting Journal Service...
[ 4.951426] systemd[1]: Starting Load Kernel Modules...
[ 4.972437] systemd[1]: Starting Generate network units from Kernel command line...
[ 4.997714] cryptodev: loading out-of-tree module taints kernel.
[ 5.000476] systemd[1]: Starting Remount Root and Kernel File Systems...
Starting Remount Root and Kernel File Systems cryptodev: driver 1.13 loaded.
[0m...
[ 5.031348] systemd-journald[125]: Collecting audit messages is enabled.
[ 5.036054] systemd[1]: Starting Coldplug All udev Devices...
[ 5.076646] systemd[1]: Started RPC Bind.
[ 5.096210] EXT4-fs (mmcblk1p2): re-mounted 0c2ac924-7a74-402b-b4a1-6ffdfa34bea9 r/w. Quota mode: none.
[ 5.108690] systemd[1]: Mounted Huge Pages File System.
[ 5.135881] systemd[1]: Started Journal Service.
[ 5.531930] systemd-journald[125]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev gracefully...
[ 5.758758] audit: type=1334 audit(1709054766.432:2): prog-id=6 op=LOAD
[ 5.765567] audit: type=1334 audit(1709054766.440:3): prog-id=7 op=LOAD
[ 5.772262] audit: type=1334 audit(1709054766.448:4): prog-id=8 op=LOAD
[ 6.101816] audit: type=1334 audit(1709054766.776:5): prog-id=9 op=LOAD
[ 6.108528] audit: type=1334 audit(1709054766.784:6): prog-id=10 op=LOAD
[ 6.370228] audit: type=1334 audit(1709054767.044:7): prog-id=11 op=LOAD
[ 6.395956] audit: type=1334 audit(1709054767.072:8): prog-id=12 op=LOAD
[ 6.975028] random: crng init done
[ 7.653201] CAN device driver interface
[ 7.745571] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@ad000000
[ 7.759548] k3-dsp-rproc 7e000000.dsp: configured DSP for IPC-only mode
[ 7.791251] mc: Linux media interface: v0.10
[ 7.803302] remoteproc remoteproc0: 7e000000.dsp is available
[ 7.814052] remoteproc remoteproc0: attaching to 7e000000.dsp
[ 7.828026] videodev: Linux video capture interface: v2.00
[ 7.834399] k3-dsp-rproc 7e000000.dsp: DSP initialized in IPC-only mode
[ 7.843446] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vision-apps-c71-dma-memory@ad000000
[ 7.864130] platform 79000000.r5f: configured R5F for IPC-only mode
[ 7.872587] platform 79000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
[ 7.884630] remoteproc remoteproc1: 79000000.r5f is available
[ 7.890619] remoteproc remoteproc1: attaching to 79000000.r5f
[ 7.896987] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 7.897450] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 7.899094] platform 79000000.r5f: R5F core initialized in IPC-only mode
[ 7.899118] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
[ 7.899635] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 7.899660] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
[ 7.899667] remoteproc remoteproc1: remote processor 79000000.r5f is now attached
[ 7.903894] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
[ 7.909876] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[ 7.916477] remoteproc remoteproc0: remote processor 7e000000.dsp is now attached
[ 7.969772] k3-dsp-rproc 7e200000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b1000000
[ 7.976775] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 7.981009] k3-dsp-rproc 7e200000.dsp: configured DSP for IPC-only mode
[ 7.991599] platform 78000000.r5f: configured R5F for IPC-only mode
[ 7.998242] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[ 8.004525] platform 78000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.017738] remoteproc remoteproc2: 7e200000.dsp is available
[ 8.021325] remoteproc remoteproc3: 78000000.r5f is available
[ 8.026861] remoteproc remoteproc2: attaching to 7e200000.dsp
[ 8.032409] remoteproc remoteproc3: attaching to 78000000.r5f
[ 8.049580] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.051968] platform 78000000.r5f: R5F core initialized in IPC-only mode
[ 8.059967] k3-dsp-rproc 7e200000.dsp: DSP initialized in IPC-only mode
[ 8.064790] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.082300] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b1000000
[ 8.092172] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 8.092577] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[ 8.098253] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
[ 8.105856] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[ 8.112556] remoteproc remoteproc3: remote processor 78000000.r5f is now attached
[ 8.126650] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.141481] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 8.141856] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 8.147094] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
[ 8.154682] platform 78400000.r5f: configured R5F for IPC-only mode
[ 8.160967] remoteproc remoteproc2: remote processor 7e200000.dsp is now attached
[ 8.174583] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.175658] platform 78400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 8.199574] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[ 8.203474] remoteproc remoteproc4: 78400000.r5f is available
[ 8.205188] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 8.210729] remoteproc remoteproc4: attaching to 78400000.r5f
[ 8.237465] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.250145] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[ 8.258179] vdec 30210000.video-codec: Product Code: 0x521c
[ 8.264525] vdec 30210000.video-codec: Firmware Revision: 320127
[ 8.271538] platform 78400000.r5f: R5F core initialized in IPC-only mode
[ 8.279017] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 8.313551] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.369169] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 8.369796] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 8.382172] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 8.389737] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.394043] rproc-virtio rproc-virtio.5.auto: registered virtio4 (type 7)
[ 8.397499] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 8.404293] remoteproc remoteproc4: remote processor 78400000.r5f is now attached
[ 8.412897] virtio_rpmsg_bus virtio4: msg received with no recipient
[ 8.425701] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ OK ] Reached target Hardware activated U[ 8.437022] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
SB gadget.
[ 8.446780] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.455835] virtio_rpmsg_bus virtio3: msg received with no recipient
[ 8.456290] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.467117] virtio_rpmsg_bus virtio0: msg received with no recipient
[ 8.474190] sii902x 2-003b: supply iovcc not found, using dummy regulator
[ 8.532885] sii902x 2-003b: supply cvcc12 not found, using dummy regulator
[ 8.548631] i2c i2c-2: Added multiplexed i2c bus 8
[ 8.550361] PVR_K: 190: Device: fd80000.gpu
[ 8.564743] e5010 fd20000.e5010: Device registered as /dev/video2
[ 8.578741] m_can_platform 4e08000.can: m_can device registered (irq=501, version=32)
[ 8.579998] PVR_K: 190: Read BVNC 36.53.104.796 from HW device registers
[ 8.593924] PVR_K: 190: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[ 8.615400] m_can_platform 4e18000.can: m_can device registered (irq=503, version=32)
[ 8.627404] [drm] Initialized pvr 24.1.6554834 20170530 for fd80000.gpu on minor 0
[ 8.651521] m_can_platform 20701000.can: m_can device registered (irq=504, version=32)
[ 8.810994] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports
[ 8.861328] [drm] Initialized tidss 1.0.0 20180215 for 30220000.dss on minor 1
[ 8.869461] tidss 30220000.dss: [drm] Cannot find any crtc or sizes
[ 8.877161] tidss 30220000.dss: [drm] Cannot find any crtc or sizes
[ 8.916600] m_can_platform 4e08000.can mcu_mcan0: renamed from can0
[ 8.947932] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
U-Boot SPL 2024.04-ti-g818c76aed67f (Aug 01 2024 - 19:19:47 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
SPL initial stack usage: 17048 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
