PROCESSOR-SDK-J721S2: DSI0 interface output failed when run vision app
Part Number: PROCESSOR-SDK-J721S2
Our custom board is based on J721S2(TDA4AL).
We want to output the image input from the camera through DSI.
The parts responsible for the output are as follows.
DSI0 -> MAX96789(Serializer) -> MAX96772(Deserializer) -> DP Panel
We initialized MAX96789 and MAX96772 using I2C4 in the R5 core.
To verify this, we added the Test Pattern Generator code in MAX96789 and confirmed that the pattern was displayed on the panel.
However, when we run the vision app, nothing is displayed on the panel.
Of course, we completed the ENABLE_DSS_DSI setting in the app_cfg_mcu2_0.h file by referring to e2e, etc.
Target OS is QNX 7.1 and the SDK used is 09.02.00.05.
Timing values:
${PSDK_RTOS_PATH}/vision_apps/platform/j721s2/rtos/common/app_init.c
prm.timings.width = 1920U;
prm.timings.height = 1080U;
prm.timings.hFrontPorch = 88U;
prm.timings.hBackPorch = 148U;
prm.timings.hSyncLen = 44U;
prm.timings.vFrontPorch = 4U;
prm.timings.vBackPorch = 36U;
prm.timings.vSyncLen = 5U;
prm.timings.pixelClock = 148500000ULL;
The contents of the question are as follows.
1. I calculated the laneSpeedInKbps value, but please let me know the exact calculation formula.
fps: 60, 10bit color depth, 4lanes, 1.25 overhead
kbps/lane = ((2200 * 1125) * 60 * 10 * (10/8) * 8 * 1.25) / 4 / 1000
laneSpeedInKbps = 464063
2. How can I check if the DSI0 setting is normal? Register or other things
3. Is there a way to check if the output is DSI0 when running the vision app (e.g. run_app_dof.sh, run_app_single_cam.sh)?
J721S2@QNX:/ti_fs/vision_apps#
[MCU2_0]      3.916311 s: CIO: Init ... Done !!!
[MCU2_0]      3.916335 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0]      3.916356 s: CPU is running FreeRTOS
[MCU2_0]      3.916371 s: APP: Init ... !!!
[MCU2_0]      3.916402 s: SCICLIENT: Init ... !!!
[MCU2_0]      3.916513 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[MCU2_0]      3.916541 s: SCICLIENT: DMSC FW revision 0x9
[MCU2_0]      3.916560 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_0]      3.916580 s: SCICLIENT: Init ... Done !!!
[MCU2_0]      3.916597 s: UDMA: Init ... !!!
[MCU2_0]      3.917413 s: UDMA: Init ... Done !!!
[MCU2_0]      3.917441 s: UDMA: Init for CSITX/CSIRX ... !!!
[MCU2_0]      3.917873 s: UDMA: Init for CSITX/CSIRX ... Done !!!
[MCU2_0]      3.917903 s: MEM: Init ... !!!
[MCU2_0]      3.917924 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ b9000000 of size 14680064 bytes !!!
[MCU2_0]      3.917962 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 60000000 of size 524288 bytes !!!
[MCU2_0]      3.917997 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ b9e00000 of size 2097152 bytes !!!
[MCU2_0]      3.918031 s: MEM: Init ... Done !!!
[MCU2_0]      3.918046 s: IPC: Init ... !!!
[MCU2_0]      3.918075 s: IPC: 5 CPUs participating in IPC !!!
[MCU2_0]      3.920661 s: IPC: Init ... Done !!!
[MCU2_0]      3.920695 s: APP: Syncing with 4 CPUs ... !!!
[MCU2_0]      4.405533 s: APP: Syncing with 4 CPUs ... Done !!!
[MCU2_0]      4.405556 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0]      4.405746 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0]      4.405778 s: FVID2: Init ... !!!
[MCU2_0]      4.405862 s: FVID2: Init ... Done !!!
[MCU2_0]      4.405901 s: SCICLIENT: Sciclient_pmSetModuleState module=219 state=2
[MCU2_0]      4.405979 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.406003 s: SCICLIENT: Sciclient_pmSetModuleState module=217 state=2
[MCU2_0]      4.406067 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.406088 s: SCICLIENT: Sciclient_pmSetModuleState module=218 state=2
[MCU2_0]      4.406141 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.406170 s: MAX96789 PWDN Set as high!
[MCU2_0]      4.416324 s: display_type=APP_DSS_DEFAULT_DISPLAY_TYPE_DSI
[MCU2_0]      4.416358 s: DSS: Init ... !!!
[MCU2_0]      4.416374 s: DSS: Display type is DSI !!!
[MCU2_0]      4.416391 s: DSS: M2M Path is enabled !!!
[MCU2_0]      4.416407 s: DSS: SoC init ... !!!
[MCU2_0]      4.416422 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=0
[MCU2_0]      4.416500 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.416521 s: SCICLIENT: Sciclient_pmSetModuleState module=154 state=2
[MCU2_0]      4.416574 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.416594 s: SCICLIENT: Sciclient_pmSetModuleState module=363 state=2
[MCU2_0]      4.416653 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.416672 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=0
[MCU2_0]      4.416721 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.416741 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=158 clk=14 parent=16
[MCU2_0]      4.416800 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]      4.416822 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=158 clk=16 freq=148500000
[MCU2_0]      4.416912 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[MCU2_0]      4.416933 s: SCICLIENT: Sciclient_pmModuleClkRequest module=158 clk=16 state=2 flag=2
[MCU2_0]      4.416999 s: SCICLIENT: Sciclient_pmModuleClkRequest success
[MCU2_0]      4.417020 s: SCICLIENT: Sciclient_pmSetModuleState module=158 state=2
[MCU2_0]      4.417100 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      4.417119 s: DSS: prm->timings.pixelClock=417100
[MCU2_0]      4.417144 s: DSS: SoC init ... Done !!!
[MCU2_0]      4.417162 s: DSS: Board init ... !!!
[MCU2_0]      4.417178 s: DSS: Board init ... Done !!!
[MCU2_0]      4.417194 s: DSS: Configuring SERDES ... !!!
[MCU2_0]      4.417212 s: DSS: domain = 0, i2cInst = 4, slaveAddr = 0x40
[MCU2_0]      4.417248 s: DSS: I2C4(4) Open OK !
[MCU2_0]      5.417331 s: DSS: Read MAX96789 ClientAddr 0x40 Regaddr 0x0d Regval 0x0080. MAX96789 is available!
[MCU2_0]      5.417371 s: DSS: SERDES MAX96789 is detected (RETRY:1)!!!
[MCU2_0]      5.417394 s: DSS: MAX96789/MAX96772 Initialize...
[MCU2_0]      5.417563 s: I2C4 OK REG 0x40 0x0308 VALUE 0x5e
[MCU2_0]      5.417734 s: I2C4 OK REG 0x40 0x0311 VALUE 0x01
[MCU2_0]      5.417902 s: I2C4 OK REG 0x40 0x0332 VALUE 0x4e
[MCU2_0]      5.418071 s: I2C4 OK REG 0x40 0x0333 VALUE 0xe4
[MCU2_0]      5.418239 s: I2C4 OK REG 0x40 0x0004 VALUE 0x50
[MCU2_0]      5.418407 s: I2C4 OK REG 0x40 0x0331 VALUE 0x03
[MCU2_0]      5.418576 s: I2C4 OK REG 0x40 0x0330 VALUE 0x04
[MCU2_0]      5.418745 s: I2C4 OK REG 0x40 0x031c VALUE 0x98
[MCU2_0]      5.418914 s: I2C4 OK REG 0x40 0x0321 VALUE 0x24
[MCU2_0]      5.419082 s: I2C4 OK REG 0x40 0x031d VALUE 0x98
[MCU2_0]      5.419249 s: I2C4 OK REG 0x40 0x0322 VALUE 0x24
[MCU2_0]      5.419418 s: I2C4 OK REG 0x40 0x0326 VALUE 0xe4
[MCU2_0]      5.419586 s: I2C4 OK REG 0x40 0x0002 VALUE 0x73
[MCU2_0]      5.419755 s: I2C4 OK REG 0x48 0xe790 VALUE 0x0a
[MCU2_0]      5.419924 s: I2C4 OK REG 0x48 0xe791 VALUE 0x00
[MCU2_0]      5.420092 s: I2C4 OK REG 0x48 0xe792 VALUE 0x04
[MCU2_0]      5.420259 s: I2C4 OK REG 0x48 0xe793 VALUE 0x00
[MCU2_0]      5.420428 s: I2C4 OK REG 0x48 0xe794 VALUE 0x80
[MCU2_0]      5.420596 s: I2C4 OK REG 0x48 0xe795 VALUE 0x07
[MCU2_0]      5.420765 s: I2C4 OK REG 0x48 0xe796 VALUE 0x58
[MCU2_0]      5.420934 s: I2C4 OK REG 0x48 0xe797 VALUE 0x00
[MCU2_0]      5.421103 s: I2C4 OK REG 0x48 0xe798 VALUE 0x2c
[MCU2_0]      5.421271 s: I2C4 OK REG 0x48 0xe799 VALUE 0x00
[MCU2_0]      5.421440 s: I2C4 OK REG 0x48 0xe79a VALUE 0x94
[MCU2_0]      5.421608 s: I2C4 OK REG 0x48 0xe79b VALUE 0x00
[MCU2_0]      5.421777 s: I2C4 OK REG 0x48 0xe79c VALUE 0x38
[MCU2_0]      5.421946 s: I2C4 OK REG 0x48 0xe79d VALUE 0x04
[MCU2_0]      5.422115 s: I2C4 OK REG 0x48 0xe79e VALUE 0x04
[MCU2_0]      5.422285 s: I2C4 OK REG 0x48 0xe79f VALUE 0x00
[MCU2_0]      5.422454 s: I2C4 OK REG 0x48 0xe7a0 VALUE 0x05
[MCU2_0]      5.422623 s: I2C4 OK REG 0x48 0xe7a1 VALUE 0x00
[MCU2_0]      5.422791 s: I2C4 OK REG 0x48 0xe7a2 VALUE 0x24
[MCU2_0]      5.422960 s: I2C4 OK REG 0x48 0xe7a3 VALUE 0x00
[MCU2_0]      5.423129 s: I2C4 OK REG 0x48 0xe7a4 VALUE 0x3c
[MCU2_0]      5.423300 s: I2C4 OK REG 0x48 0xe7a5 VALUE 0x0b
[MCU2_0]      5.423469 s: I2C4 OK REG 0x48 0xe7a6 VALUE 0x66
[MCU2_0]      5.423638 s: I2C4 OK REG 0x48 0xe7a7 VALUE 0x46
[MCU2_0]      5.423806 s: I2C4 OK REG 0x48 0xe7a8 VALUE 0x00
[MCU2_0]      5.423975 s: I2C4 OK REG 0x48 0xe7a9 VALUE 0x80
[MCU2_0]      5.424145 s: I2C4 OK REG 0x48 0xe7aa VALUE 0x40
[MCU2_0]      5.424314 s: I2C4 OK REG 0x48 0xe7ab VALUE 0x00
[MCU2_0]      5.424482 s: I2C4 OK REG 0x48 0xe7ac VALUE 0x00
[MCU2_0]      5.424651 s: I2C4 OK REG 0x48 0xe7ad VALUE 0x00
[MCU2_0]      5.424819 s: I2C4 OK REG 0x48 0xe7b0 VALUE 0x01
[MCU2_0]      5.424988 s: I2C4 OK REG 0x48 0xe7b1 VALUE 0x00
[MCU2_0]      5.425155 s: I2C4 OK REG 0x48 0x6003 VALUE 0x82
[MCU2_0]      5.425324 s: I2C4 OK REG 0x48 0xe7b2 VALUE 0x50
[MCU2_0]      5.425492 s: I2C4 OK REG 0x48 0xe7b3 VALUE 0x00
[MCU2_0]      5.425661 s: I2C4 OK REG 0x48 0xe7b4 VALUE 0x00
[MCU2_0]      5.425829 s: I2C4 OK REG 0x48 0xe7b5 VALUE 0x40
[MCU2_0]      5.425998 s: I2C4 OK REG 0x48 0xe7b6 VALUE 0x6c
[MCU2_0]      5.426165 s: I2C4 OK REG 0x48 0xe7b7 VALUE 0x20
[MCU2_0]      5.426334 s: I2C4 OK REG 0x48 0xe7b8 VALUE 0x07
[MCU2_0]      5.426502 s: I2C4 OK REG 0x48 0xe7b9 VALUE 0x00
[MCU2_0]      5.426671 s: I2C4 OK REG 0x48 0xe7ba VALUE 0x01
[MCU2_0]      5.426840 s: I2C4 OK REG 0x48 0xe7bb VALUE 0x00
[MCU2_0]      5.427008 s: I2C4 OK REG 0x48 0xe7bc VALUE 0x00
[MCU2_0]      5.427175 s: I2C4 OK REG 0x48 0xe7bd VALUE 0x00
[MCU2_0]      5.427344 s: I2C4 OK REG 0x48 0xe7be VALUE 0x52
[MCU2_0]      5.427512 s: I2C4 OK REG 0x48 0xe7bf VALUE 0x00
[MCU2_0]      5.427681 s: I2C4 OK REG 0x48 0xe776 VALUE 0x02
[MCU2_0]      5.427849 s: I2C4 OK REG 0x48 0xe777 VALUE 0x80
[MCU2_0]      5.427869 s: DSS: SERDES MAX96789 is ready !!!
[MCU2_0]      5.427887 s: DSS: MAX96789 Check...
[MCU2_0]      5.428092 s: I2C4 RD OK REG 0x0308 VALUE 0x5e
[MCU2_0]      5.428303 s: I2C4 RD OK REG 0x0311 VALUE 0x01
[MCU2_0]      5.428513 s: I2C4 RD OK REG 0x0332 VALUE 0x4e
[MCU2_0]      5.428723 s: I2C4 RD OK REG 0x0333 VALUE 0xe4
[MCU2_0]      5.428933 s: I2C4 RD OK REG 0x0004 VALUE 0x50
[MCU2_0]      5.429139 s: I2C4 RD OK REG 0x0331 VALUE 0x03
[MCU2_0]      5.429350 s: I2C4 RD OK REG 0x0330 VALUE 0x04
[MCU2_0]      5.429560 s: I2C4 RD OK REG 0x031c VALUE 0x98
[MCU2_0]      5.429770 s: I2C4 RD OK REG 0x0321 VALUE 0x24
[MCU2_0]      5.429977 s: I2C4 RD OK REG 0x031d VALUE 0x98
[MCU2_0]      5.430186 s: I2C4 RD OK REG 0x0322 VALUE 0x24
[MCU2_0]      5.430396 s: I2C4 RD OK REG 0x0326 VALUE 0xe4
[MCU2_0]      5.430603 s: I2C4 RD OK REG 0x0002 VALUE 0x73
[MCU2_0]      5.430810 s: I2C4 RD OK REG 0xe790 VALUE 0x0a
[MCU2_0]      5.431021 s: I2C4 RD OK REG 0xe791 VALUE 0x00
[MCU2_0]      5.431229 s: I2C4 RD OK REG 0xe792 VALUE 0x04
[MCU2_0]      5.431437 s: I2C4 RD OK REG 0xe793 VALUE 0x00
[MCU2_0]      5.431647 s: I2C4 RD OK REG 0xe794 VALUE 0x80
[MCU2_0]      5.431854 s: I2C4 RD OK REG 0xe795 VALUE 0x07
[MCU2_0]      5.432064 s: I2C4 RD OK REG 0xe796 VALUE 0x58
[MCU2_0]      5.432269 s: I2C4 RD OK REG 0xe797 VALUE 0x00
[MCU2_0]      5.432480 s: I2C4 RD OK REG 0xe798 VALUE 0x2c
[MCU2_0]      5.432690 s: I2C4 RD OK REG 0xe799 VALUE 0x00
[MCU2_0]      5.432900 s: I2C4 RD OK REG 0xe79a VALUE 0x94
[MCU2_0]      5.433108 s: I2C4 RD OK REG 0xe79b VALUE 0x00
[MCU2_0]      5.433317 s: I2C4 RD OK REG 0xe79c VALUE 0x38
[MCU2_0]      5.433524 s: I2C4 RD OK REG 0xe79d VALUE 0x04
[MCU2_0]      5.433734 s: I2C4 RD OK REG 0xe79e VALUE 0x04
[MCU2_0]      5.433944 s: I2C4 RD OK REG 0xe79f VALUE 0x00
[MCU2_0]      5.434153 s: I2C4 RD OK REG 0xe7a0 VALUE 0x05
[MCU2_0]      5.434363 s: I2C4 RD OK REG 0xe7a1 VALUE 0x00
[MCU2_0]      5.434570 s: I2C4 RD OK REG 0xe7a2 VALUE 0x24
[MCU2_0]      5.434780 s: I2C4 RD OK REG 0xe7a3 VALUE 0x00
[MCU2_0]      5.434987 s: I2C4 RD OK REG 0xe7a4 VALUE 0x3c
[MCU2_0]      5.435195 s: I2C4 RD OK REG 0xe7a5 VALUE 0x0b
[MCU2_0]      5.435403 s: I2C4 RD OK REG 0xe7a6 VALUE 0x66
[MCU2_0]      5.435613 s: I2C4 RD OK REG 0xe7a7 VALUE 0x46
[MCU2_0]      5.435820 s: I2C4 RD OK REG 0xe7a8 VALUE 0x00
[MCU2_0]      5.436027 s: I2C4 RD OK REG 0xe7a9 VALUE 0x80
[MCU2_0]      5.436233 s: I2C4 RD OK REG 0xe7aa VALUE 0x40
[MCU2_0]      5.436443 s: I2C4 RD OK REG 0xe7ab VALUE 0x00
[MCU2_0]      5.436653 s: I2C4 RD OK REG 0xe7ac VALUE 0x00
[MCU2_0]      5.436863 s: I2C4 RD OK REG 0xe7ad VALUE 0x00
[MCU2_0]      5.437074 s: I2C4 RD OK REG 0xe7b0 VALUE 0x01
[MCU2_0]      5.437280 s: I2C4 RD OK REG 0xe7b1 VALUE 0x00
[MCU2_0]      5.437490 s: I2C4 RD OK REG 0x6003 VALUE 0x82
[MCU2_0]      5.437700 s: I2C4 RD OK REG 0xe7b2 VALUE 0x50
[MCU2_0]      5.437908 s: I2C4 RD OK REG 0xe7b3 VALUE 0x00
[MCU2_0]      5.438118 s: I2C4 RD OK REG 0xe7b4 VALUE 0x00
[MCU2_0]      5.438327 s: I2C4 RD OK REG 0xe7b5 VALUE 0x40
[MCU2_0]      5.438534 s: I2C4 RD OK REG 0xe7b6 VALUE 0x6c
[MCU2_0]      5.438744 s: I2C4 RD OK REG 0xe7b7 VALUE 0x20
[MCU2_0]      5.438954 s: I2C4 RD OK REG 0xe7b8 VALUE 0x07
[MCU2_0]      5.439163 s: I2C4 RD OK REG 0xe7b9 VALUE 0x00
[MCU2_0]      5.439373 s: I2C4 RD OK REG 0xe7ba VALUE 0x01
[MCU2_0]      5.439580 s: I2C4 RD OK REG 0xe7bb VALUE 0x00
[MCU2_0]      5.439791 s: I2C4 RD OK REG 0xe7bc VALUE 0x00
[MCU2_0]      5.440001 s: I2C4 RD OK REG 0xe7bd VALUE 0x00
[MCU2_0]      5.440213 s: I2C4 RD OK REG 0xe7be VALUE 0x52
[MCU2_0]      5.440423 s: I2C4 RD OK REG 0xe7bf VALUE 0x00
[MCU2_0]      5.440633 s: I2C4 RD OK REG 0xe776 VALUE 0x02
[MCU2_0]      5.440841 s: I2C4 RD OK REG 0xe777 VALUE 0x80
[MCU2_0]      5.440859 s: DSS: Confirm OK
[MCU2_0]      5.440878 s: DSS: SERDES Configuration... Done !!!
[MCU2_0]      5.441597 s: DSS: appDssDefaultInit:207 {{
[MCU2_0]      5.441643 s: DCTRL: [appDctrlControl:194], CMD:[0x00000001]
[MCU2_0]      5.441680 s: DCTRL: [appDctrlControl:194], CMD:[0x0000000A]
[MCU2_0]      5.441703 s: DCTRL: numOfLanes=4, laneSpeedInKbps=464063
[MCU2_0]      5.441772 s: DSS: DSI appRemoteServiceRun, APP_DCTRL_CMD_SET_DSI_PARAMS, lane=4, lane_speed=464063 kbps
[MCU2_0]      5.441809 s: DCTRL: [appDctrlControl:194], CMD:[0x00000003]
[MCU2_0]      5.441909 s: DCTRL: [appDctrlControl:194], CMD:[0x00000005]
[MCU2_0]      5.442256 s: src/drv/dctrl/dss_dctrlDsi.c @ Line 947:
[MCU2_0]      5.442283 s: DSS::DEBUG, fps=60, pixelClock=148500000
[MCU2_0]      5.442310 s: src/drv/dctrl/dss_dctrlDsi.c @ Line 1028:
[MCU2_0]      5.442336 s: DSS::DEBUG, fps=60, pixelClock=148500000, connectedTo=0, retVal=0
[MCU2_0]      5.442365 s: src/drv/dctrl/dss_dctrlDsi.c @ Line 1055:
[MCU2_0]      5.442386 s: DSS::DEBUG, OK...
[MCU2_0]      5.442450 s: DCTRL: [appDctrlControl:194], CMD:[0x00000009]
[MCU2_0]      5.442482 s: DCTRL: [appDctrlControl:194], CMD:[0x00000006]
[MCU2_0]      5.442513 s: DCTRL: [appDctrlControl:194], CMD:[0x00000007]
[MCU2_0]      5.442542 s: DSS: appDssDefaultInit:209 }} retVal=0
[MCU2_0]      5.442563 s: DSS: Init ... Done !!!
[MCU2_0]      5.442579 s: VHWA: VPAC Init ... !!!
[MCU2_0]      5.442594 s: SCICLIENT: Sciclient_pmSetModuleState module=361 state=2
[MCU2_0]      5.442689 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.442711 s: VHWA: LDC Init ... !!!
[MCU2_0]      5.444277 s: VHWA: LDC Init ... Done !!!
[MCU2_0]      5.444306 s: VHWA: MSC Init ... !!!
[MCU2_0]      5.449811 s: VHWA: MSC Init ... Done !!!
[MCU2_0]      5.449840 s: VHWA: NF Init ... !!!
[MCU2_0]      5.450618 s: VHWA: NF Init ... Done !!!
[MCU2_0]      5.450643 s: VHWA: VISS Init ... !!!
[MCU2_0]      5.455754 s: VHWA: VISS Init ... Done !!!
[MCU2_0]      5.455788 s: VHWA: VPAC Init ... Done !!!
[MCU2_0]      5.455815 s:  VX_ZONE_INIT:Enabled
[MCU2_0]      5.455832 s:  VX_ZONE_ERROR:Enabled
[MCU2_0]      5.455848 s:  VX_ZONE_WARNING:Enabled
[MCU2_0]      5.455865 s:  VX_ZONE_LOG:Enabled
[MCU2_0]      5.456944 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MCU2-0
[MCU2_0]      5.457023 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target VPAC_NF
[MCU2_0]      5.457102 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target VPAC_LDC1
[MCU2_0]      5.457178 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target VPAC_MSC1
[MCU2_0]      5.457262 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target VPAC_MSC2
[MCU2_0]      5.457377 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target VPAC_VISS1
[MCU2_0]      5.457467 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CAPTURE1
[MCU2_0]      5.457555 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CAPTURE2
[MCU2_0]      5.457637 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CAPTURE3
[MCU2_0]      5.457724 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CAPTURE4
[MCU2_0]      5.457814 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CAPTURE5
[MCU2_0]      5.457892 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CAPTURE6
[MCU2_0]      5.457982 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CAPTURE7
[MCU2_0]      5.458066 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CAPTURE8
[MCU2_0]      5.458160 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DISPLAY1
[MCU2_0]      5.458255 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DISPLAY2
[MCU2_0]      5.458330 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CSITX
[MCU2_0]      5.458399 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target CSITX2
[MCU2_0]      5.458480 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSS_M2M1
[MCU2_0]      5.458560 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSS_M2M2
[MCU2_0]      5.458643 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSS_M2M3
[MCU2_0]      5.458717 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSS_M2M4
[MCU2_0]      5.458751 s:  VX_ZONE_INIT:[tivxInitLocal:137] Initialization Done !!!
[MCU2_0]      5.458773 s: APP: OpenVX Target kernel init ... !!!
[MCU2_0]      5.465313 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_0]      5.465343 s: CSI2RX: Init ... !!!
[MCU2_0]      5.465358 s: SCICLIENT: Sciclient_pmSetModuleState module=136 state=2
[MCU2_0]      5.465424 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.465448 s: SCICLIENT: Sciclient_pmSetModuleState module=38 state=2
[MCU2_0]      5.465498 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.465520 s: SCICLIENT: Sciclient_pmSetModuleState module=39 state=2
[MCU2_0]      5.465566 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.465586 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
[MCU2_0]      5.465644 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.465664 s: SCICLIENT: Sciclient_pmSetModuleState module=153 state=2
[MCU2_0]      5.465713 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.465835 s: CSI2RX: Init ... Done !!!
[MCU2_0]      5.465854 s: *****************************************************
[MCU2_0]      5.465875 s: ISS: Init ... !!!
[MCU2_0]      5.465889 s: *****************************************************
[MCU2_0]      5.465914 s: F=IssSensor_vc1940_Init,L=87 IssSensor_vc1940 5M Init............
[MCU2_0]      5.465943 s: F=IssSensor_Register,L=1262 Found sensor ST_VC1940_5M at location 0
[MCU2_0]      5.465972 s: F=IssSensor_vb1740_Init,L=114 IssSensor_vb1740 2M Init............
[MCU2_0]      5.465999 s: F=IssSensor_Register,L=1262 Found sensor ST_VB1740_2M at location 1
[MCU2_0]      5.466027 s: F=IssSensor_Register,L=1262 Found sensor IMX390-UB953_D3 at location 2
[MCU2_0]      5.466056 s: F=IssSensor_IMX390DISCOVERY_NARROW_Init,L=142 IssSensor_IMX390DISCOVERY_NARROW_Init
[MCU2_0]      5.466086 s: F=IssSensor_Register,L=1262 Found sensor IMX390-UB953-DISCOVERY-NARROW at location 3
[MCU2_0]      5.466117 s: F=IssSensor_IMX390DISCOVERY_MID_Init,L=152 IssSensor_IMX390DISCOVERY_MID_Init
[MCU2_0]      5.466151 s: F=IssSensor_Register,L=1262 Found sensor IMX390-UB953-DISCOVERY-MID at location 4
[MCU2_0]      5.467216 s: APP: Run ... !!!
[MCU2_1]      3.941336 s: CIO: Init ... Done !!!
[MCU2_1]      3.941388 s: ### CPU Frequency = 1000000000 Hz
[MCU2_1]      3.941411 s: CPU is running FreeRTOS
[MCU2_1]      3.941425 s: APP: Init ... !!!
[MCU2_1]      3.941456 s: SCICLIENT: Init ... !!!
[MCU2_1]      3.941566 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[MCU2_1]      3.941594 s: SCICLIENT: DMSC FW revision 0x9
[MCU2_1]      3.941613 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_1]      3.941632 s: SCICLIENT: Init ... Done !!!
[MCU2_1]      3.941649 s: UDMA: Init ... !!!
[MCU2_1]      3.942475 s: UDMA: Init ... Done !!!
[MCU2_1]      3.942506 s: MEM: Init ... !!!
[MCU2_1]      3.942529 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ ba000000 of size 16777216 bytes !!!
[MCU2_1]      3.942570 s: MEM: Init ... Done !!!
[MCU2_1]      3.942587 s: IPC: Init ... !!!
[MCU2_1]      3.942616 s: IPC: 5 CPUs participating in IPC !!!
[MCU2_1]      3.945168 s: IPC: Init ... Done !!!
[MCU2_1]      3.945204 s: APP: Syncing with 4 CPUs ... !!!
[MCU2_1]      4.405532 s: APP: Syncing with 4 CPUs ... Done !!!
[MCU2_1]      4.405555 s: REMOTE_SERVICE: Init ... !!!
[MCU2_1]      4.405741 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_1]      4.405778 s: FVID2: Init ... !!!
[MCU2_1]      4.405859 s: FVID2: Init ... Done !!!
[MCU2_1]      4.405897 s: VHWA: DMPAC: Init ... !!!
[MCU2_1]      4.405914 s: SCICLIENT: Sciclient_pmSetModuleState module=58 state=2
[MCU2_1]      4.406033 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1]      4.406058 s: SCICLIENT: Sciclient_pmSetModuleState module=62 state=2
[MCU2_1]      4.406118 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1]      4.406138 s: VHWA: DOF Init ... !!!
[MCU2_1]      4.409969 s: VHWA: DOF Init ... Done !!!
[MCU2_1]      4.409999 s: VHWA: SDE Init ... !!!
[MCU2_1]      4.411320 s: VHWA: SDE Init ... Done !!!
[MCU2_1]      4.411345 s: VHWA: DMPAC: Init ... Done !!!
[MCU2_1]      4.411375 s:  VX_ZONE_INIT:Enabled
[MCU2_1]      4.411393 s:  VX_ZONE_ERROR:Enabled
[MCU2_1]      4.411409 s:  VX_ZONE_WARNING:Enabled
[MCU2_1]      4.411425 s:  VX_ZONE_LOG:Enabled
[MCU2_1]      4.412531 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MCU2-1
[MCU2_1]      4.412611 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DMPAC_SDE
[MCU2_1]      4.412689 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DMPAC_DOF
[MCU2_1]      4.412721 s:  VX_ZONE_INIT:[tivxInitLocal:137] Initialization Done !!!
[MCU2_1]      4.412743 s: APP: OpenVX Target kernel init ... !!!
[MCU2_1]      4.412865 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_1]      4.412890 s: UDMA Copy: Init ... !!!
[MCU2_1]      4.413862 s: UDMA Copy: Init ... Done !!!
[MCU2_1]      4.413894 s: APP: Init ... Done !!!
[MCU2_1]      4.413913 s: APP: Run ... !!!
[MCU2_1]      4.413927 s: IPC: Starting echo test ...[9]
[MCU2_1]      4.413960 s: IPC: RecvTask: Creating ...
[MCU2_1]      4.413996 s: IPC: SendTask0: Creating ...
[MCU2_1]      4.414027 s: IPC: SendTask3: Creating ...
[MCU2_1]      4.414055 s: IPC: SendTask7: Creating ...
[MCU2_1]      4.414083 s: IPC: SendTask8: Creating ...
[MCU2_1]      4.414109 s: F=appIpcEchoTestStart,L=721: All done
[MCU2_1]      4.414131 s: APP: Run ... Done !!!
[MCU2_1]      4.414182 s: IPC: RecvTask: Started ...
[MCU2_1]      4.414254 s: IPC: RecvTask: Waiting for messages ...
[MCU2_1]      4.414293 s: IPC: SendTask0: Started ...
[MCU2_1]      4.414359 s: IPC: SendTask3: Started ...
[MCU2_1]      4.414391 s: IPC: SendTask7: Started ...
[MCU2_1]      4.414423 s: IPC: SendTask7: Sending messages to C7X_1 ...
[MCU2_1]      4.414449 s: IPC: SendTask7: Sending msg #0 "ping 0" from mcu2_1 to C7X_1...
[MCU2_1]      4.414490 s: IPC: SendTask8: Started ...
[MCU2_1]      4.414521 s: IPC: SendTask8: Sending messages to C7X_2 ...
[MCU2_1]      4.414554 s: IPC: SendTask8: Sending msg #0 "ping 0" from mcu2_1 to C7X_2...
[MCU2_1]      4.414592 s: IPC: RecvTask: Revcvd msg #1 "ping 0" len 7 bytes from C7X_1
[MCU2_1]      4.414658 s: IPC: RecvTask: Sending msg #1 "pong 0" len 6 bytes from mcu2_1 to C7X_1
[MCU2_1]      4.414696 s: IPC: RecvTask: Revcvd msg #2 "ping 0" len 7 bytes from C7X_2
[MCU2_1]      4.414728 s: IPC: RecvTask: Sending msg #2 "pong 0" len 6 bytes from mcu2_1 to C7X_2
[MCU2_1]      4.414770 s: IPC: RecvTask: Revcvd msg #3 "ping 1" len 7 bytes from C7X_1
[MCU2_1]      4.414798 s: IPC: RecvTask: Sending msg #3 "pong 1" len 6 bytes from mcu2_1 to C7X_1
[MCU2_1]      4.414838 s: IPC: RecvTask: Revcvd msg #4 "ping 1" len 7 bytes from C7X_2
[MCU2_1]      4.414866 s: IPC: RecvTask: Sending msg #4 "pong 1" len 6 bytes from mcu2_1 to C7X_2
[MCU2_1]      4.414907 s: IPC: SendTask7: Received msg #0 "pong 0" len 6 bytes from C7X_1 endPt 14
[MCU2_1]      4.414941 s: IPC: SendTask7: Sending msg #1 "ping 1" from mcu2_1 to C7X_1...
[MCU2_1]      4.414978 s: IPC: SendTask8: Received msg #0 "pong 0" len 6 bytes from C7X_2 endPt 14
[MCU2_1]      4.415010 s: IPC: SendTask8: Sending msg #1 "ping 1" from mcu2_1 to C7X_2...
[MCU2_1]      4.415057 s: IPC: SendTask7: Received msg #1 "pong 1" len 6 bytes from C7X_1 endPt 14
[MCU2_1]      4.415088 s: IPC: SendTask7: Finished test with C7X_1
[MCU2_1]      4.415128 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C7X_1[P] C7X_2[.]
[MCU2_1]      4.415153 s: F=rpmsg_senderFxn,L=618: end of show
[MCU2_1]      4.415177 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=7
[MCU2_1]      4.415205 s: IPC: SendTask8: Received msg #1 "pong 1" len 6 bytes from C7X_2 endPt 14
[MCU2_1]      4.415242 s: IPC: SendTask8: Finished test with C7X_2
[MCU2_1]      4.415270 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C7X_1[P] C7X_2[P]
[MCU2_1]      4.415294 s: F=rpmsg_senderFxn,L=618: end of show
[MCU2_1]      4.415314 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=8
[MCU2_1]      5.467559 s: IPC: SendTask3: Sending messages to mcu2_0 ...
[MCU2_1]      5.467588 s: IPC: SendTask3: Sending msg #0 "ping 0" from mcu2_1 to mcu2_0...
[MCU2_1]      5.467712 s: IPC: RecvTask: Revcvd msg #5 "ping 0" len 7 bytes from mcu2_0
[MCU2_1]      5.467749 s: IPC: RecvTask: Sending msg #5 "pong 0" len 6 bytes from mcu2_1 to mcu2_0
[MCU2_1]      5.468032 s: IPC: SendTask3: Received msg #0 "pong 0" len 6 bytes from mcu2_0 endPt 14
[MCU2_1]      5.468066 s: IPC: SendTask3: Sending msg #1 "ping 1" from mcu2_1 to mcu2_0...
[MCU2_1]      5.468157 s: IPC: SendTask3: Received msg #1 "pong 1" len 6 bytes from mcu2_0 endPt 14
[MCU2_1]      5.468191 s: IPC: SendTask3: Finished test with mcu2_0
[MCU2_1]      5.468231 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C7X_1[P] C7X_2[P]
[MCU2_1]      5.468256 s: F=rpmsg_senderFxn,L=618: end of show
[MCU2_1]      5.468276 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=3
[MCU2_1]      5.468302 s: IPC: RecvTask: Revcvd msg #6 "ping 1" len 7 bytes from mcu2_0
[MCU2_1]      5.468333 s: IPC: RecvTask: Sending msg #6 "pong 1" len 6 bytes from mcu2_1 to mcu2_0
[C7x_1 ]      4.316708 s: CIO: Init ... Done !!!
[C7x_1 ]      4.316724 s: ### CPU Frequency = 1000000000 Hz
[C7x_1 ]      4.316735 s: CPU is running FreeRTOS
[C7x_1 ]      4.316744 s: APP: Init ... !!!
[C7x_1 ]      4.316752 s: SCICLIENT: Init ... !!!
[C7x_1 ]      4.316852 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[C7x_1 ]      4.316866 s: SCICLIENT: DMSC FW revision 0x9
[C7x_1 ]      4.316876 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_1 ]      4.316887 s: SCICLIENT: Init ... Done !!!
[C7x_1 ]      4.316897 s: UDMA: Init ... !!!
[C7x_1 ]      4.317678 s: UDMA: Init ... Done !!!
[C7x_1 ]      4.317699 s: MEM: Init ... !!!
[C7x_1 ]      4.317711 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!!
[C7x_1 ]      4.317735 s: MEM: Init ... Done !!!
[C7x_1 ]      4.317744 s: IPC: Init ... !!!
[C7x_1 ]      4.317763 s: IPC: 5 CPUs participating in IPC !!!
[C7x_1 ]      4.319188 s: IPC: Init ... Done !!!
[C7x_1 ]      4.319203 s: APP: Syncing with 4 CPUs ... !!!
[C7x_1 ]      4.405534 s: APP: Syncing with 4 CPUs ... Done !!!
[C7x_1 ]      4.405548 s: REMOTE_SERVICE: Init ... !!!
[C7x_1 ]      4.405717 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_1 ]      4.405738 s:  VX_ZONE_INIT:Enabled
[C7x_1 ]      4.405748 s:  VX_ZONE_ERROR:Enabled
[C7x_1 ]      4.405759 s:  VX_ZONE_WARNING:Enabled
[C7x_1 ]      4.405770 s:  VX_ZONE_LOG:Enabled
[C7x_1 ]      4.405999 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1
[C7x_1 ]      4.406071 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_2
[C7x_1 ]      4.406140 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_3
[C7x_1 ]      4.406214 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_4
[C7x_1 ]      4.406285 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_5
[C7x_1 ]      4.406361 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_6
[C7x_1 ]      4.406431 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_7
[C7x_1 ]      4.406502 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP_C7-1_PRI_8
[C7x_1 ]      4.406525 s:  VX_ZONE_INIT:[tivxInitLocal:137] Initialization Done !!!
[C7x_1 ]      4.406537 s: APP: OpenVX Target kernel init ... !!!
[C7x_1 ]      4.406705 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_1 ]      4.406720 s: APP: Init ... Done !!!
[C7x_1 ]      4.406729 s: APP: Run ... !!!
[C7x_1 ]      4.406738 s: IPC: Starting echo test ...[9]
[C7x_1 ]      4.406763 s: IPC: RecvTask: Creating ...
[C7x_1 ]      4.406790 s: IPC: SendTask0: Creating ...
[C7x_1 ]      4.406816 s: IPC: SendTask3: Creating ...
[C7x_1 ]      4.406838 s: IPC: SendTask4: Creating ...
[C7x_1 ]      4.406862 s: IPC: SendTask8: Creating ...
[C7x_1 ]      4.406886 s: F=appIpcEchoTestStart,L=721: All done
[C7x_1 ]      4.406900 s: APP: Run ... Done !!!
[C7x_1 ]      4.406942 s: IPC: RecvTask: Started ...
[C7x_1 ]      4.406981 s: IPC: RecvTask: Waiting for messages ...
[C7x_1 ]      4.407000 s: IPC: SendTask0: Started ...
[C7x_1 ]      4.407024 s: IPC: SendTask3: Started ...
[C7x_1 ]      4.407047 s: IPC: SendTask4: Started ...
[C7x_1 ]      4.407067 s: IPC: SendTask8: Started ...
[C7x_1 ]      4.408061 s: IPC: SendTask8: Sending messages to C7X_2 ...
[C7x_1 ]      4.408078 s: IPC: SendTask8: Sending msg #0 "ping 0" from C7X_1 to C7X_2...
[C7x_1 ]      4.408229 s: IPC: RecvTask: Revcvd msg #1 "ping 0" len 7 bytes from C7X_2
[C7x_1 ]      4.408254 s: IPC: RecvTask: Sending msg #1 "pong 0" len 6 bytes from C7X_1 to C7X_2
[C7x_1 ]      4.408293 s: IPC: SendTask8: Received msg #0 "pong 0" len 6 bytes from C7X_2 endPt 14
[C7x_1 ]      4.408315 s: IPC: SendTask8: Sending msg #1 "ping 1" from C7X_1 to C7X_2...
[C7x_1 ]      4.408372 s: IPC: RecvTask: Revcvd msg #2 "ping 1" len 7 bytes from C7X_2
[C7x_1 ]      4.408407 s: IPC: RecvTask: Sending msg #2 "pong 1" len 6 bytes from C7X_1 to C7X_2
[C7x_1 ]      4.408439 s: IPC: SendTask8: Received msg #1 "pong 1" len 6 bytes from C7X_2 endPt 14
[C7x_1 ]      4.408459 s: IPC: SendTask8: Finished test with C7X_2
[C7x_1 ]      4.408482 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C7X_1[s] C7X_2[P]
[C7x_1 ]      4.408496 s: F=rpmsg_senderFxn,L=618: end of show
[C7x_1 ]      4.408511 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=8
[C7x_1 ]      4.414273 s: IPC: SendTask4: Sending messages to mcu2_1 ...
[C7x_1 ]      4.414290 s: IPC: SendTask4: Sending msg #0 "ping 0" from C7X_1 to mcu2_1...
[C7x_1 ]      4.414496 s: IPC: RecvTask: Revcvd msg #3 "ping 0" len 7 bytes from mcu2_1
[C7x_1 ]      4.414519 s: IPC: RecvTask: Sending msg #3 "pong 0" len 6 bytes from C7X_1 to mcu2_1
[C7x_1 ]      4.414706 s: IPC: SendTask4: Received msg #0 "pong 0" len 6 bytes from mcu2_1 endPt 14
[C7x_1 ]      4.414729 s: IPC: SendTask4: Sending msg #1 "ping 1" from C7X_1 to mcu2_1...
[C7x_1 ]      4.414848 s: IPC: SendTask4: Received msg #1 "pong 1" len 6 bytes from mcu2_1 endPt 14
[C7x_1 ]      4.414867 s: IPC: SendTask4: Finished test with mcu2_1
[C7x_1 ]      4.414888 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C7X_1[s] C7X_2[P]
[C7x_1 ]      4.414901 s: F=rpmsg_senderFxn,L=618: end of show
[C7x_1 ]      4.414916 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=4
[C7x_1 ]      4.414985 s: IPC: RecvTask: Revcvd msg #4 "ping 1" len 7 bytes from mcu2_1
[C7x_1 ]      4.415006 s: IPC: RecvTask: Sending msg #4 "pong 1" len 6 bytes from C7X_1 to mcu2_1
[C7x_1 ]      5.467568 s: IPC: SendTask3: Sending messages to mcu2_0 ...
[C7x_1 ]      5.467589 s: IPC: SendTask3: Sending msg #0 "ping 0" from C7X_1 to mcu2_0...
[C7x_1 ]      5.467780 s: IPC: RecvTask: Revcvd msg #5 "ping 0" len 7 bytes from mcu2_0
[C7x_1 ]      5.467805 s: IPC: RecvTask: Sending msg #5 "pong 0" len 6 bytes from C7X_1 to mcu2_0
[C7x_1 ]      5.467940 s: IPC: SendTask3: Received msg #0 "pong 0" len 6 bytes from mcu2_0 endPt 14
[C7x_1 ]      5.467963 s: IPC: SendTask3: Sending msg #1 "ping 1" from C7X_1 to mcu2_0...
[C7x_1 ]      5.468072 s: IPC: SendTask3: Received msg #1 "pong 1" len 6 bytes from mcu2_0 endPt 14
[C7x_1 ]      5.468091 s: IPC: SendTask3: Finished test with mcu2_0
[C7x_1 ]      5.468115 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C7X_1[s] C7X_2[P]
[C7x_1 ]      5.468128 s: F=rpmsg_senderFxn,L=618: end of show
[C7x_1 ]      5.468143 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=3
[C7x_1 ]      5.468255 s: IPC: RecvTask: Revcvd msg #6 "ping 1" len 7 bytes from mcu2_0
[C7x_1 ]      5.468277 s: IPC: RecvTask: Sending msg #6 "pong 1" len 6 bytes from C7X_1 to mcu2_0
[C7x_2 ]      4.403205 s: CIO: Init ... Done !!!
[C7x_2 ]      4.403220 s: ### CPU Frequency = 1000000000 Hz
[C7x_2 ]      4.403233 s: CPU is running FreeRTOS
[C7x_2 ]      4.403241 s: APP: Init ... !!!
[C7x_2 ]      4.403249 s: SCICLIENT: Init ... !!!
[C7x_2 ]      4.403348 s: SCICLIENT: DMSC FW version [9.2.4--v09.02.04 (Kool Koala)]
[C7x_2 ]      4.403362 s: SCICLIENT: DMSC FW revision 0x9
[C7x_2 ]      4.403373 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_2 ]      4.403385 s: SCICLIENT: Init ... Done !!!
[C7x_2 ]      4.403394 s: UDMA: Init ... !!!
[C7x_2 ]      4.404174 s: UDMA: Init ... Done !!!
[C7x_2 ]      4.404187 s: MEM: Init ... !!!
[C7x_2 ]      4.404199 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 127000000 of size 16777216 bytes !!!
[C7x_2 ]      4.404221 s: MEM: Init ... Done !!!
[C7x_2 ]      4.404230 s: IPC: Init ... !!!
[C7x_2 ]      4.404246 s: IPC: 5 CPUs participating in IPC !!!
[C7x_2 ]      4.405505 s: IPC: Init ... Done !!!
[C7x_2 ]      4.405518 s: APP: Syncing with 4 CPUs ... !!!
[C7x_2 ]      4.405533 s: APP: Syncing with 4 CPUs ... Done !!!
[C7x_2 ]      4.405544 s: REMOTE_SERVICE: Init ... !!!
[C7x_2 ]      4.405660 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_2 ]      4.405719 s:  VX_ZONE_INIT:Enabled
[C7x_2 ]      4.405732 s:  VX_ZONE_ERROR:Enabled
[C7x_2 ]      4.405743 s:  VX_ZONE_WARNING:Enabled
[C7x_2 ]      4.405753 s:  VX_ZONE_LOG:Enabled
[C7x_2 ]      4.406357 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target DSP-1
[C7x_2 ]      4.406380 s:  VX_ZONE_INIT:[tivxInitLocal:137] Initialization Done !!!
[C7x_2 ]      4.406393 s: APP: OpenVX Target kernel init ... !!!
[C7x_2 ]      4.406709 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_2 ]      4.406724 s: UDMA Copy: Init ... !!!
[C7x_2 ]      4.407790 s: UDMA Copy: Init ... Done !!!
[C7x_2 ]      4.407804 s: APP: Init ... Done !!!
[C7x_2 ]      4.407813 s: APP: Run ... !!!
[C7x_2 ]      4.407821 s: IPC: Starting echo test ...[9]
[C7x_2 ]      4.407845 s: IPC: RecvTask: Creating ...
[C7x_2 ]      4.407868 s: IPC: SendTask0: Creating ...
[C7x_2 ]      4.407894 s: IPC: SendTask3: Creating ...
[C7x_2 ]      4.407916 s: IPC: SendTask4: Creating ...
[C7x_2 ]      4.407939 s: IPC: SendTask7: Creating ...
[C7x_2 ]      4.407962 s: F=appIpcEchoTestStart,L=721: All done
[C7x_2 ]      4.407975 s: APP: Run ... Done !!!
[C7x_2 ]      4.407990 s: IPC: RecvTask: Started ...
[C7x_2 ]      4.408029 s: IPC: RecvTask: Waiting for messages ...
[C7x_2 ]      4.408050 s: IPC: SendTask0: Started ...
[C7x_2 ]      4.408078 s: IPC: SendTask3: Started ...
[C7x_2 ]      4.408123 s: IPC: SendTask4: Started ...
[C7x_2 ]      4.408156 s: IPC: SendTask7: Started ...
[C7x_2 ]      4.408181 s: IPC: SendTask7: Sending messages to C7X_1 ...
[C7x_2 ]      4.408196 s: IPC: SendTask7: Sending msg #0 "ping 0" from C7X_2 to C7X_1...
[C7x_2 ]      4.408222 s: IPC: RecvTask: Revcvd msg #1 "ping 0" len 7 bytes from C7X_1
[C7x_2 ]      4.408245 s: IPC: RecvTask: Sending msg #1 "pong 0" len 6 bytes from C7X_2 to C7X_1
[C7x_2 ]      4.408305 s: IPC: SendTask7: Received msg #0 "pong 0" len 6 bytes from C7X_1 endPt 14
[C7x_2 ]      4.408327 s: IPC: SendTask7: Sending msg #1 "ping 1" from C7X_2 to C7X_1...
[C7x_2 ]      4.408367 s: IPC: RecvTask: Revcvd msg #2 "ping 1" len 7 bytes from C7X_1
[C7x_2 ]      4.408404 s: IPC: RecvTask: Sending msg #2 "pong 1" len 6 bytes from C7X_2 to C7X_1
[C7x_2 ]      4.408446 s: IPC: SendTask7: Received msg #1 "pong 1" len 6 bytes from C7X_1 endPt 14
[C7x_2 ]      4.408465 s: IPC: SendTask7: Finished test with C7X_1
[C7x_2 ]      4.408487 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C7X_1[P] C7X_2[s]
[C7x_2 ]      4.408501 s: F=rpmsg_senderFxn,L=618: end of show
[C7x_2 ]      4.408513 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=7
[C7x_2 ]      4.414280 s: IPC: SendTask4: Sending messages to mcu2_1 ...
[C7x_2 ]      4.414297 s: IPC: SendTask4: Sending msg #0 "ping 0" from C7X_2 to mcu2_1...
[C7x_2 ]      4.414597 s: IPC: RecvTask: Revcvd msg #3 "ping 0" len 7 bytes from mcu2_1
[C7x_2 ]      4.414619 s: IPC: RecvTask: Sending msg #3 "pong 0" len 6 bytes from C7X_2 to mcu2_1
[C7x_2 ]      4.414779 s: IPC: SendTask4: Received msg #0 "pong 0" len 6 bytes from mcu2_1 endPt 14
[C7x_2 ]      4.414801 s: IPC: SendTask4: Sending msg #1 "ping 1" from C7X_2 to mcu2_1...
[C7x_2 ]      4.414910 s: IPC: SendTask4: Received msg #1 "pong 1" len 6 bytes from mcu2_1 endPt 14
[C7x_2 ]      4.414930 s: IPC: SendTask4: Finished test with mcu2_1
[C7x_2 ]      4.414951 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C7X_1[P] C7X_2[s]
[C7x_2 ]      4.414965 s: F=rpmsg_senderFxn,L=618: end of show
[C7x_2 ]      4.414978 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=4
[C7x_2 ]      4.415062 s: IPC: RecvTask: Revcvd msg #4 "ping 1" len 7 bytes from mcu2_1
[C7x_2 ]      4.415082 s: IPC: RecvTask: Sending msg #4 "pong 1" len 6 bytes from C7X_2 to mcu2_1
[C7x_2 ]      5.467577 s: IPC: SendTask3: Sending messages to mcu2_0 ...
[C7x_2 ]      5.467597 s: IPC: SendTask3: Sending msg #0 "ping 0" from C7X_2 to mcu2_0...
[C7x_2 ]      5.467859 s: IPC: RecvTask: Revcvd msg #5 "ping 0" len 7 bytes from mcu2_0
[C7x_2 ]      5.467883 s: IPC: RecvTask: Sending msg #5 "pong 0" len 6 bytes from C7X_2 to mcu2_0
[C7x_2 ]      5.467985 s: IPC: SendTask3: Received msg #0 "pong 0" len 6 bytes from mcu2_0 endPt 14
[C7x_2 ]      5.468007 s: IPC: SendTask3: Sending msg #1 "ping 1" from C7X_2 to mcu2_0...
[C7x_2 ]      5.468106 s: IPC: SendTask3: Received msg #1 "pong 1" len 6 bytes from mcu2_0 endPt 14
[C7x_2 ]      5.468125 s: IPC: SendTask3: Finished test with mcu2_0
[C7x_2 ]      5.468153 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C7X_1[P] C7X_2[s]
[C7x_2 ]      5.468166 s: F=rpmsg_senderFxn,L=618: end of show
[C7x_2 ]      5.468179 s: F=rpmsg_senderFxn,L=628: Closed..dstProc=3
[C7x_2 ]      5.468293 s: IPC: RecvTask: Revcvd msg #6 "ping 1" len 7 bytes from mcu2_0
[C7x_2 ]      5.468314 s: IPC: RecvTask: Sending msg #6 "pong 1" len 6 bytes from C7X_2 to mcu2_0
J721S2@QNX:/ti_fs/vision_apps# ./run_app_dof.sh
F=appInit:L=96, appInit{{...
APP: Init QNX ... !!!
appIpcInit: IPC: Init QNX ... !!!
appIpcInit: IPC: Init ... Done !!!
   214.601330 s: REMOTE_SERVICE: Init ... !!!
   214.601483 s: REMOTE_SERVICE: Init ... Done !!!
   214.601516 s: GTC Frequency = 200 MHz
   214.601546 s:  VX_ZONE_INIT:Enabled
   214.601560 s:  VX_ZONE_ERROR:Enabled
   214.601573 s:  VX_ZONE_WARNING:Enabled
   214.601587 s:  VX_ZONE_LOG:Enabled
   214.601782 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
   214.601850 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
   214.601912 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
   214.601970 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
   214.601992 s:  VX_ZONE_INIT:[tivxInitLocal:137] Initialization Done !!!
   214.602034 s:  VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
F=appInit:L=105, }}...
F=app_init_display1,L=68 displayObj->display_option=1
F=app_init_display1,L=71 TIVX_TARGET_DISPLAY1
F=app_init_display2,L=96 displayObj->display_option=1
F=app_init_display2,L=99 TIVX_TARGET_DISPLAY2
F=app_create_graph,L=381
F=app_create_graph,L=390 app_create_graph_display2
F=app_create_graph_display2,L=187 displayObj->display_option=1
F=app_create_graph_display2,L=190
F=app_create_graph_display1,L=161 displayObj->display_option=1
F=app_create_graph_display1,L=164
F=app_create_graph,L=424 app_create_graph_display1, status=0
F=app_create_graph,L=498 end of func
F=app_run_task_create,L=527
F=app_run_task_create,L=535
F=app_run_graph,L=644 obj->output_file_path=./dof_out/
 Demo : Dense Optical Flow Example 1
 p: Print performance statistics
 e: Export performance statistics
 x: Exit
 Enter Choice: F=app_run_graph,L=648 run pyramid
F=app_run_graph,L=661 {{
F=app_run_graph,L=671 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001901.yuv, pipeline=-3
F=app_run_graph,L=671 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001902.yuv, pipeline=-2
    Is the application hung? Can you press "p" and check if the graph and display node is running fine?
    Nikhil
  • Hi, Nikhil Dasan,
    The app seems work fine, so I have press 'p' key.
    Threre is no error during running app.
    As a result are as following...
    J721S2-ICMU@QNX:/ti_fs/vision_apps# ./run_app_dof.sh
        32.761099 s: REMOTE_SERVICE: Init ... !!!
        32.761249 s: REMOTE_SERVICE: Init ... Done !!!
        32.761282 s: GTC Frequency = 200 MHz
        32.761313 s:  VX_ZONE_INIT:Enabled
        32.761326 s:  VX_ZONE_ERROR:Enabled
        32.761339 s:  VX_ZONE_WARNING:Enabled
        32.761352 s:  VX_ZONE_LOG:Enabled
        32.761553 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
        32.761622 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
        32.761677 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
        32.761734 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
        32.761758 s:  VX_ZONE_INIT:[tivxInitLocal:137] Initialization Done !!!
        32.761800 s:  VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
    F=appGrpxInit,L=153 {{
    F=app_draw_graphics,L=1465 update_type=0
    F=appGrpxInit,L=298 }} status=0
    F=app_init,L=327 display_option is enabled
    F=app_create_graph,L=382
    F=app_create_graph,L=391 app_create_graph_display2
    F=app_create_graph,L=425 app_create_graph_display1, status=0
    F=app_draw_graphics,L=1494 no drawing, update_type=1
    F=app_create_graph,L=499 end of func
    F=app_run_task_create,L=528
    F=app_run_task_create,L=536
    F=app_run_graph,L=645 obj->output_file_path=./dof_out/
     x: Exit
     Enter Choice: F=app_run_graph,L=649 run pyramid
    F=app_run_graph,L=662 {{
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001912.yuv, pipeline=0
    F=app_run_graph,L=718 ->pipeline=0
    F=app_run_graph,L=727 TIVX_TARGET_DISPLAY1
    Summary of CPU load,
    CPU: mpu1_0: TOTAL LOAD =   0. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU: mcu2_0: TOTAL LOAD =   2. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU: mcu2_1: TOTAL LOAD =   1. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  C7X_1: TOTAL LOAD =   0. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  C7X_2: TOTAL LOAD =   9. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    HWA performance statistics,
    HWA:   MSC0: LOAD =   1.22 % ( 5 MP/s )
    HWA:   DOF : LOAD =   3.78 % ( 4 MP/s )
    DDR performance statistics,
    DDR: READ  BW: AVG =    567 MB/s, PEAK =   1779 MB/s
    DDR: WRITE BW: AVG =     76 MB/s, PEAK =   1006 MB/s
    DDR: TOTAL BW: AVG =    643 MB/s, PEAK =   2785 MB/s
    Detailed CPU performance/memory statistics,
    CPU: mcu2_0: TASK:      FREERTOS_TA:   0. 0 %
    CPU: mcu2_0: TASK:           IPC_RX:   0. 2 %
    CPU: mcu2_0: TASK:       REMOTE_SRV:   0. 5 %
    CPU: mcu2_0: TASK:        LOAD_TEST:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CPU_0:   0. 0 %
    CPU: mcu2_0: TASK:        TIVX_V1NF:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_V1LDC:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_V1MSC1:   0.65 %
    CPU: mcu2_0: TASK:      TIVX_V1MSC2:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_V1VISS:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT1:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT2:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT3:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT4:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT5:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT6:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT7:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_CAPT8:   0. 0 %
    CPU: mcu2_0: TASK:       TIVX_DISP1:   0.25 %
    CPU: mcu2_0: TASK:       TIVX_DISP2:   0.43 %
    CPU: mcu2_0: TASK:       TIVX_CSITX:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_CSITX2:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_DPM2M1:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_DPM2M2:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_DPM2M3:   0. 0 %
    CPU: mcu2_0: TASK:      TIVX_DPM2M4:   0. 0 %
    CPU: mcu2_0: TASK:      IPC_TEST_RX:   0. 0 %
    CPU: mcu2_0: TASK:      IPC_TEST_TX:   0. 0 %
    CPU: mcu2_0: HEAP:    DDR_LOCAL_MEM: size =   14680064 B, free =   14190336 B ( 96 % unused)
    CPU: mcu2_0: HEAP:           L3_MEM: size =     524288 B, free =     524032 B ( 99 % unused)
    CPU: mcu2_0: HEAP:  DDR_CACHE_WT_ME: size =    2097152 B, free =    2096896 B ( 99 % unused)
    CPU: mcu2_1: TASK:      FREERTOS_TA:   0. 0 %
    CPU: mcu2_1: TASK:           IPC_RX:   0. 0 %
    CPU: mcu2_1: TASK:       REMOTE_SRV:   0. 7 %
    CPU: mcu2_1: TASK:        LOAD_TEST:   0. 0 %
    CPU: mcu2_1: TASK:       TIVX_CPU_1:   0. 0 %
    CPU: mcu2_1: TASK:         TIVX_SDE:   0. 0 %
    CPU: mcu2_1: TASK:         TIVX_DOF:   0.86 %
    CPU: mcu2_1: TASK:      IPC_TEST_RX:   0. 0 %
    CPU: mcu2_1: TASK:      IPC_TEST_TX:   0. 0 %
    CPU: mcu2_1: HEAP:    DDR_LOCAL_MEM: size =   16777216 B, free =   15851008 B ( 94 % unused)
    CPU: mcu2_1: HEAP:           L3_MEM: size =     524288 B, free =     524288 B (100 % unused)
    CPU:  C7X_1: TASK:      FREERTOS_TA:   0. 0 %
    CPU:  C7X_1: TASK:           IPC_RX:   0. 0 %
    CPU:  C7X_1: TASK:       REMOTE_SRV:   0. 0 %
    CPU:  C7X_1: TASK:        LOAD_TEST:   0. 0 %
    CPU:  C7X_1: TASK:      TIVX_C71_P1:   0. 0 %
    CPU:  C7X_1: TASK:      TIVX_C71_P2:   0. 0 %
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001913.yuv, pipeline=0
    CPU:  C7X_1: TASK:      TIVX_C71_P3:   0. 0 %
    CPU:  C7X_1: TASK:      TIVX_C71_P4:   0. 0 %
    CPU:  C7X_1: TASK:      TIVX_C71_P5:   0. 0 %
    CPU:  C7X_1: TASK:      TIVX_C71_P6:   0. 0 %
    CPU:  C7X_1: TASK:      TIVX_C71_P7:   0. 0 %
    CPU:  C7X_1: TASK:      TIVX_C71_P8:   0. 0 %
    CPU:  C7X_1: TASK:      IPC_TEST_RX:   0. 0 %
    CPU:  C7X_1: TASK:      IPC_TEST_TX:   0. 0 %
    CPU:  C7X_1: HEAP:    DDR_LOCAL_MEM: size =  268435456 B, free =  268435200 B ( 99 % unused)
    CPU:  C7X_1: HEAP:           L3_MEM: size =    3964928 B, free =    3964928 B (100 % unused)
    CPU:  C7X_1: HEAP:           L2_MEM: size =     458752 B, free =     458752 B (100 % unused)
    CPU:  C7X_1: HEAP:           L1_MEM: size =      16384 B, free =      16384 B (100 % unused)
    CPU:  C7X_1: HEAP:  DDR_SCRATCH_MEM: size =  385875968 B, free =  385875968 B (100 % unused)
    CPU:  C7X_2: TASK:      FREERTOS_TA:   0. 0 %
    CPU:  C7X_2: TASK:           IPC_RX:   0. 0 %
    CPU:  C7X_2: TASK:       REMOTE_SRV:   0. 0 %
    CPU:  C7X_2: TASK:        LOAD_TEST:   0. 0 %
    CPU:  C7X_2: TASK:         TIVX_CPU:   8.99 %
    CPU:  C7X_2: TASK:      IPC_TEST_RX:   0. 0 %
    CPU:  C7X_2: TASK:      IPC_TEST_TX:   0. 0 %
    CPU:  C7X_2: HEAP:    DDR_LOCAL_MEM: size =   16777216 B, free =   16772608 B ( 99 % unused)
    CPU:  C7X_2: HEAP:           L2_MEM: size =     458752 B, free =     458752 B (100 % unused)
    CPU:  C7X_2: HEAP:           L1_MEM: size =      16384 B, free =      16384 B (100 % unused)
    CPU:  C7X_2: HEAP:  DDR_SCRATCH_MEM: size =   67108864 B, free =   67108864 B (100 % unused)
    GRAPH:        graph_116 (#nodes =   5, #executions =     12)
     NODE:      VPAC_MSC1:          GaussianPyramid: avg =   2177 usecs, min/max =   2140 /   2217 usecs, #executions =         12
     NODE:      DMPAC_DOF:         DenseOpticalFlow: avg =   7266 usecs, min/max =   7230 /   7433 usecs, #executions =         12
     NODE:          DSP-1:             DofVisualize: avg =  17511 usecs, min/max =  17223 /  17606 usecs, #executions =         12
     NODE:       DISPLAY1:           Output Display: avg =  10504 usecs, min/max =     45 /  16843 usecs, #executions =         12
     NODE:       DISPLAY2:            Input Display: avg =   7673 usecs, min/max =     49 /  16102 usecs, #executions =         12
     PERF:           FILEIO: avg = 168351 usecs, min/max = 160414 / 177790 usecs, #executions =         12
     PERF:            TOTAL: avg = 168775 usecs, min/max = 160871 / 178246 usecs, #executions =         12
     PERF:            TOTAL:    5.92 FPS
     x: Exit
     Enter Choice: F=app_draw_graphics,L=1494 no drawing, update_type=1
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001914.yuv, pipeline=0
     x: Exit
     Enter Choice: F=app_run_graph,L=718 ->pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001915.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001916.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001917.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001918.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001919.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001920.yuv, pipeline=0
    pF=app_run_graph,L=662 {{
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001921.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001922.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001923.yuv, pipeline=0
    CPU: mcu2_1: TOTAL LOAD =   2. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  C7X_1: TOTAL LOAD = 42949668.96 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    CPU:  C7X_2: TOTAL LOAD =   7. 0 % ( HWI =   0. 0 %, SWI =   0. 0 % )
    HWA:   MSC0: LOAD =   1.26 % ( 5 MP/s )
    HWA:   DOF : LOAD =   4.31 % ( 5 MP/s )
    DDR: READ  BW: AVG =    625 MB/s, PEAK =   4869 MB/s
    DDR: WRITE BW: AVG =     81 MB/s, PEAK =    936 MB/s
    DDR: TOTAL BW: AVG =    706 MB/s, PEAK =   5805 MB/s
    CPU: mcu2_0: TASK:           IPC_RX:   0. 6 %
    CPU: mcu2_0: TASK:       REMOTE_SRV:   0.15 %
    CPU: mcu2_0: TASK:      TIVX_V1MSC1:   0.44 %
    CPU: mcu2_0: TASK:       TIVX_DISP1:   0.28 %
    CPU: mcu2_0: TASK:       TIVX_DISP2:   0.27 %
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001924.yuv, pipeline=0
    CPU: mcu2_1: TASK:       REMOTE_SRV:   0.15 %
    CPU: mcu2_1: TASK:         TIVX_DOF:   1. 8 %
    CPU:  C7X_2: TASK:       REMOTE_SRV:   0. 1 %
    CPU:  C7X_2: TASK:         TIVX_CPU:   9.61 %
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001925.yuv, pipeline=0
    GRAPH:        graph_116 (#nodes =   5, #executions =     24)
     NODE:      VPAC_MSC1:          GaussianPyramid: avg =   2176 usecs, min/max =   2122 /   2217 usecs, #executions =         24
     NODE:      DMPAC_DOF:         DenseOpticalFlow: avg =   7257 usecs, min/max =   7230 /   7433 usecs, #executions =         24
     NODE:          DSP-1:             DofVisualize: avg =  17547 usecs, min/max =  17223 /  17772 usecs, #executions =         24
     NODE:       DISPLAY1:           Output Display: avg =   9656 usecs, min/max =     45 /  16843 usecs, #executions =         24
     NODE:       DISPLAY2:            Input Display: avg =   7985 usecs, min/max =     49 /  16449 usecs, #executions =         24
     PERF:           FILEIO: avg = 168816 usecs, min/max = 160414 / 177790 usecs, #executions =         24
     PERF:            TOTAL: avg = 169698 usecs, min/max = 163750 / 173960 usecs, #executions =         12
     PERF:            TOTAL:    5.89 FPS
     x: Exit
     Enter Choice:
     x: Exit
     Enter Choice: F=app_run_graph,L=662 {{
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001926.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001927.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001928.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001929.yuv, pipeline=0
     x: Exit
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001930.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001931.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001932.yuv, pipeline=0
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001933.yuv, pipeline=0
    xF=app_run_graph,L=662 {{
    F=app_run_graph,L=672 input_file_name=/ti_fs/vision_apps/test_data/psdkra/tidl_demo_images/0000001934.yuv, pipeline=0
        39.328755 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!!
        39.336476 s:  VX_ZONE_INIT:[tivxDeInitLocal:205] De-Initialization Done !!!
    APP: Deinit ... !!!
        39.336554 s: REMOTE_SERVICE: Deinit ... !!!
        39.336618 s: REMOTE_SERVICE: Deinit ... Done !!!
    IPC: Deinit ... !!!
    IPC: Deinit ... Done !!!
    APP: Deinit ... Done !!!
  • Dear TI Experts,
    With regard to DSI output, I have checked some registers for DSI, DPHY-TX.
    In my humble opinion, the other registers seems find.
    but when I read DSI_VID_MODE_STS Register(0x0480_00F0),  it displayed 0x04.
    The value is ERR_MISSING_HSYNC bit.
    How can I resolve the issue?
    And also, I would appreciate it if you could answer the question I asked above.
    --- 8< --- Cut Here --- >8 ---
    # k3conf read 0x04800000
    | VERSION INFO |
    | K3CONF | QNX (version 0.1-nogit built Thu Oct 31 10:53:01 AM KST 2024) |
    | SoC | J721S2 SR1.0 |
    | SYSFW | ABI: 3.1 (firmware version 0x0009 '9.2.4--v09.02.04 (Kool Koala))') |
    Value at addr 0x4800000 = 0x948490d0
    # k3conf read 0x04800004
    | VERSION INFO |
    Value at addr 0x4800004 = 0x25
    # k3conf read 0x04800008
    | VERSION INFO |
    Value at addr 0x4800008 = 0x3c17
    # k3conf read 0x0480000c
    | VERSION INFO |
    Value at addr 0x480000c = 0x40f9
    # k3conf read 0x04800010
    | VERSION INFO |
    Value at addr 0x4800010 = 0x1f0000
    # k3conf read 0x04800024
    | VERSION INFO |
    Value at addr 0x4800024 = 0x3f
    # k3conf read 0x04800028
    | VERSION INFO |
    Value at addr 0x4800028 = 0x0
    # k3conf read 0x0480002c
    | VERSION INFO |
    Value at addr 0x480002c = 0x402a6
    # k3conf read 0x048000f0
    | VERSION INFO |
    Value at addr 0x48000f0 = 0x4
    # k3conf read 0x04480f04
    | VERSION INFO |
    Value at addr 0x4480f04 = 0x815b0402
    # k3conf read 0x04480f08
    | VERSION INFO |
    Value at addr 0x4480f08 = 0x80000006
    DSI output is fixed to 24bit RGB data and based on this, you need to calculate lane speed, can you please calculate lane speed as pixel clock * 24 / number of lanes and use this calculated value to see if it outputs correctly?
    Brijesh
  • Dear Brijesh Jadav,
    Thank you for commenting..
    Timing parameters are as following,
    prm.display_type = APP_DSS_DEFAULT_DISPLAY_TYPE_DSI;
    prm.timings.width = 1920U; // H_Res
    prm.timings.height = 1080U; // V_lines
    prm.timings.hFrontPorch = 8U; // H_fp
    prm.timings.hBackPorch = 40U; // H_bp
    prm.timings.hSyncLen = 32U; // H_syncW
    prm.timings.vFrontPorch = 17U; // V_fp
    prm.timings.vBackPorch = 6U; // V_bp
    prm.timings.vSyncLen = 8U; // V_syncW
    prm.timings.pixelClock = 133320000U;
    and lane speed is
    dsiParams.num_lanes = 4u;
    dsiParams.lane_speed_in_kbps = 799920U; // (2000 * 1111) * 60 * 24 / 1000 / 4
    and I've read a register named DSI_TOP_VBUSP_CFG_DSI_0_DSI
    J721S2@QNX:/# k3conf read 0x048000f0
    | VERSION INFO |
    Value at addr 0x48000f0 = 0x1
    The value 0x1 means "VSG_RUNNING: VSG is running [1]".
    and also I've read MAX96789 and MAX96772 registers.
    MAX96789
    # TCTRL : CTRL3
    RIB 80 13 1  CA
    # VID_TX__X : VIDEO_TX2
    RIB 80 102 1  8A   <- PCLK Locked
    MAX96772
    # TCTRL : CTRL3
    RIB 90 13 1  CA
    # VID_RX__X : VIDEO_RX8
    RIB 90 108 1  62                      <- VID_PKT_DET, VID_LOCKED
    # MISC : PMX_SS_STATE_B0
    RIB 90 7F0 1  1                       <- DP Link Training is success
    # MISC : PMX_SS_STATE_B1
    RIB 90 7F1 1  0
    They also displayed as normal locked.
    but still nothing display on the DP panel when I run vision apps like run_app_dof.sh.
    Are there anything checking points more in DSS, DSI0, and Serdes?
    and how can I display colorbar in the DP panel?
    When you VSG is running, DSI is outputting the data. Please check if there is anything in the Maxim SERDES that needs to be configured.
    Brijesh
  • Dear Brijesh,
    MAX96789 and MAX96772 were set to the values ​​confirmed by the vendor.
    Of course, Link Training with the DP panel is normal.
    I would appreciate it if you could let me know what files and points I need to modify for DSI setup.
    app_cfg_mcu2_0.h : ENABLE_DSS_DSI
    app_init.c : DSI timing parameters
    app_dss_defaults.c : DSS configuration
    app_dss_soc.c : Serdes configuration, I2C
    and more ?
  • Hi Jaseop,
    Sorry, didn't get it. What do you want to modify in the driver? Isn't DSI output already running? When VSG status shows it is enabled, DSI is enabled. Now DSS should start pushing the frames to the DSI. Most likely if your OpenVX graph is running, then DSI is outputting the data. What is Maxim reporting as input frame status? Is it receiving some data? or is it locked to input stream?
    Brijesh
  • Dear Brijesh,
    DSI status is VSG is running, MAX96789 is also PLCKDET, so it is normal,
    and MAX96772 is VID_PKT_DET, VID_LOCK. Of course, Link Training with DP Panel is also Good.
    Everything seems to be normal, but when I run the vision app or enable ColorBar, nothing is displayed on the panel.
    So I am trying to find what is wrong from the beginning.
    With regard to your question :
    The engineer says there is no problem in the serdes registers.
    All registers seems works and fine.
    and would you check the below registers ?
    J721S2-ICMU@QNX:/# k3conf read 0x0480002c
    | VERSION INFO |
    Value at addr 0x480002c = 0x4054a
    bit 17(DPHY_PLL_LOCK) is '0'. Is it OK ?
    If not, how can I resolve the issue ?
          0h DPHY Lane and PLL status information
    31:19 RESERVED NONE 0h Reserved
    18 PPI_C_TX_READY_HS R 0h Value of ppi_c_tx_ready_hs input
    17 DPHY_PLL_LOCK R 0h Value of dphy_pll_lock input
    16 RESERVED NONE 0h Reserved
    15:12 PPI_D_RX_ULPS_ESC R 0h Value of ppi_d_rx_ulps_esc input
    11 RESERVED NONE 0h Reserved
    10:9 DATLANE4_STATE R 0h DATLANE4_STATE: state of the data lane 4 [00: start / 01: idle / 10: write / 11: ULPM]
    8:7 DATLANE3_STATE R 0h DATLANE3_STATE: state of the data lane 3 [00: start / 01: idle / 10: write / 11: ULPM]
    6:5 DATLANE2_STATE R 0h DATLANE2_STATE: state of the data lane 2 [00: start / 01: idle / 10: write / 11: ULPM]
    4:2 DATLANE1_STATE R 0h DATLANE1_STATE: state of the data lane 1 [000: start / 001: idle / 010: write / 011: ULPM / 100: read]
    1:0 CLKLANE_STATE R 0h CLKLANE_STATE: state of the clock lane [00: start / 01: idle / 10: HS / 11: ULPM]
    J721S2-ICMU@QNX:/# k3conf read 0x04800024
    | VERSION INFO |
    J721S2-ICMU@QNX:/# k3conf read 0x048000f0
    | VERSION INFO |
    What's the value of register 0x048000E8 and 0x048000EC? If you read them multiple times, are the values changing in these registers?
    Brijesh
  • Dear Brijesh,
    I thank you very much for your kindly reply.
    I have read several times as you requested.
    0x0480_00E8 : vertical position
    0x0480_00EC : Horizontal Position
    The values are changed when I read the registers.
    As a result are as follows
    J721S2-ICMU@QNX:/ti_fs/vision_apps# k3conf read 0x048000f0
    | VERSION INFO        |
    J721S2-ICMU@QNX:/ti_fs/vision_apps# k3conf read 0x048000e8
    | VERSION INFO        |
    Value at addr 0x48000e8 = 0x19
    | VERSION INFO        |
    Value at addr 0x48000e8 = 0x256
    | VERSION INFO        |
    Value at addr 0x48000e8 = 0xaa6
    | VERSION INFO        |
    Value at addr 0x48000e8 = 0x556
    | VERSION INFO        |
    Value at addr 0x48000e8 = 0x432
    J721S2-ICMU@QNX:/ti_fs/vision_apps# k3conf read 0x048000ec
    | VERSION INFO        |
    Value at addr 0x48000ec = 0x44
    | VERSION INFO        |
    | VERSION INFO        |
    Value at addr 0x48000ec = 0x23
    | VERSION INFO        |
    | VERSION INFO        |
    | VERSION INFO        |
    | VERSION INFO        |
    Value at addr 0x48000ec = 0x64
    | VERSION INFO        |
    | VERSION INFO        |
    Since these values are changing, which means the position in the frame is changing, which in turn means DSI is outputting the data.
    Brijesh
  • Dear Brijesh,
    Thanks for checking the status of the SoC.
    TDA4AL DSI -> MAX96789 -> MAX96772 -> DP Panel.
    However, VS_DET_X and HS_DET_X are not detected in the MAX96789 Serializer.
    When I read MAX96789 0x55D register, it display as follows:
    RIB 80 55D 1 3
    It means HS_POL_X and VS_POL_X are Active high, but VS, HS are NOT detected.
    Would you help me how can I resolve this issue ?
  • Hi Jaseop,
    I will not be able help much on Maxim SERDES. All i can say is DSI is outputting the data since its position is changing and also VSG is enabled.
    You can
    - probably probe the data lanes to confirm they are toggling
    - check the number of DSI lanes in TDA4 and Maxim SERDES
    - see if there is any sequencing required in the Maxim Serdes.
    Brijesh
  • Dear Brijesh,
    We were able to output images normally to the panel after changing DSI LANE from 4 to 2, doubling the lane speed, and changing the Vfp value of MAX96772 from 17 to 16.
    Here, I have one question.
    static Dss_DctrlDsi2DpBridgeBlankingParams supportedBlanks[] =
    { /* 133.32M */
    .vpBlankingParams = {
    .standard = FVID2_STD_CUSTOM,
    .scanFormat = FVID2_SF_PROGRESSIVE,
    .fps = 60U;
    .width = 1920U;
    .height = 1080U;
    .hFrontPorch = 8U;
    .hBackPorch = 40U;
    .hSyncLen = 32U;
    .vFrontPorch = 17U;
    .vBackPorch = 6U;
    .vSyncLen = 8U
    .dsi2DpBlankingParams = {
    .fps = 60U,
    .width = 1920U,
    .height = 1080U,
    .pixelClock = 133320000U,
    .hFrontPorch = 8U,
    .hBackPorch = 40U,
    .hSyncLen = 32,
    .vFrontPorch = 16U,
    .vBackPorch = 6U,
    .vSyncLen = 8
    vpBlankingParams.vFrontPorch is 17, but dsi2DpBlankingParams.vFrontPorch is 16.
    If I set the two values ​​to the same, an error occurs.
    Can you tell me why? I wonder why the two values ​​should be different.
    For example, dsi2DpBlankingParams
    vFrontPortch = 16U -> vFrontPort = 17U
    # k3conf read 0x048000f0 = 0x4
  • Hello Jaseop,
    That's great news.
    yes, VFP needs to be atleast one line less that the original VFP in VP. This is given in the DSI portion of the specs. In fact in the RTOS driver, we keep the VFP fixed to 1 for non-bridge resolution as shown below.
    if (DSS_DSI_CONNECTION_DSI2DP_BRIDGE != connectedTo)
    dsiObj->videoSizeCfg.vfp = 1;
    else
    dsiObj->videoSizeCfg.vfp = mInfo->vFrontPorch;
    Brijesh
  • Dear Brijesh,
    I thank you for your support all the time.
    We were trying to use 4 DSI Lanes on a J721S2 based board, but for some reason, the Serializer could not detect HSYNC and VSYNC.
    How can we analyze the cause? And can we use DSI 2 Lane as Lane 34 instead of Lane 12?
    We are trying to check if there is a physical problem in Data Lane 34.
  • Hi Jaseop,
    I think this might require changes in DSI_mctl_main_phy_ctl register to enable just lane34, could you please try out?
    Please note this is not validated...
    Brijesh
