TDA4VM: GPU FBO occasional exception
Part Number: TDA4VM
I have a question to ask. For one of our projects, we are using the TDA4 Linux system with SDK version 8.4. Recently, during the running process, there was a sudden exception in the bottom area of the car. The following is the result: (During the running process, a block of abnormal color was suddenly filled in, and the color was still different each time, but it was able to quickly recover to normal)
The bottom area of this car is made of FBO, with a total of 3 FBOs. During each run, the texture of the other 2 FBOs is transformed and drawn onto the current default FBO,
The normal effect is as follows:
Analysis: On which core is the shared memory used by FBO located? Suspected that the FBO (shared memory) at the bottom of the car was damaged, and then randomly filled with a color. Recently, BSP may have changed MCU, BSP, and removed Ethernet drivers. Will these have an impact? This issue has a high probability of occurring sporadically recently, and I always feel that there is a problem with the underlying driver or some firmware module.
Please  help diagnose it. Thank you~
  • ==========================================pvrlog with error captured===================
    [TS (START): 157.57]
    ===== Dumping environment info ======================================
    [TS: 157.58]
    Date: Tue Aug 30 17:09:10 CST 2022
    /proc/version: Linux version 5.10.120-g95b90aa828 (ubuntu@c027fcd6a9de) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Nov 12 07:11:46 UTC 2024
    Driver state: initialised
    env:
    export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/0/bus"
    export EDITOR="vi"
    export HOME="/home/root"
    export HUSHLOGIN="FALSE"
    export LANG="C"
    export LOGNAME="root"
    export MAIL="/var/spool/mail/root"
    export OLDPWD
    export PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin"
    export PWD="/home/root"
    export SHELL="/bin/sh"
    export SHLVL="2"
    export TERM="xterm"
    export USER="root"
    export WS_CALUDEV_FILE="/etc/udev/rules.d/ws-calibrate.rules"
    export XDG_CONFIG_HOME="/etc/"
    export XDG_RUNTIME_DIR="/tmp/0-runtime-dir"
    export XDG_SESSION_CLASS="user"
    export XDG_SESSION_ID="c1"
    export XDG_SESSION_TYPE="tty"
    lsmod:
    Module Size Used by
    veth 327680 0
    rpmsg_char 262144 20
    omap_rng 327680 0
    rng_core 327680 2 omap_rng
    irq_pruss_intc 262144 0
    pru_rproc 262144 0
    icss_iep 327680 0
    crct10dif_ce 327680 1
    ti_k3_r5_remoteproc 262144 0
    pvrsrvkm 1507328 24
    pruss 327680 1 pru_rproc
    sa2ul 327680 0
    sha512_generic 262144 1 sa2ul
    authenc 262144 1 sa2ul
    ti_k3_dsp_remoteproc 262144 0
    virtio_rpmsg_bus 327680 0
    cdns_dphy 262144 0
    rti_wdt 327680 0
    sch_fq_codel 262144 1
    rpmsg_kdrv_switch 262144 0
    /cpu/info
    processor : 0
    BogoMIPS : 400.00
    Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
    CPU implementer : 0x41
    CPU architecture: 8
    CPU variant : 0x1
    CPU part : 0xd08
    CPU revision : 0
    processor : 1
    BogoMIPS : 400.00
    CPU architecture: 8
    CPU variant : 0x1
    CPU part : 0xd08
    CPU revision : 0
    /proc/meminfo
    MemTotal: 2358080 kB
    MemFree: 1187200 kB
    MemAvailable: 1587712 kB
    Buffers: 18176 kB
    Cached: 445440 kB
    SwapCached: 0 kB
    Active: 96576 kB
    Inactive: 631552 kB
    Active(anon): 9344 kB
    Inactive(anon): 300416 kB
    Active(file): 87232 kB
    Inactive(file): 331136 kB
    Unevictable: 0 kB
    Mlocked: 0 kB
    SwapTotal: 0 kB
    SwapFree: 0 kB
    Dirty: 9152 kB
    Writeback: 0 kB
    AnonPages: 264576 kB
    Mapped: 98496 kB
    Shmem: 45184 kB
    KReclaimable: 13440 kB
    Slab: 43456 kB
    SReclaimable: 13440 kB
    SUnreclaim: 30016 kB
    KernelStack: 23360 kB
    PageTables: 7680 kB
    NFS_Unstable: 0 kB
    Bounce: 0 kB
    WritebackTmp: 0 kB
    CommitLimit: 1179008 kB
    Committed_AS: 2684928 kB
    VmallocTotal: 133009506240 kB
    VmallocUsed: 32576 kB
    VmallocChunk: 0 kB
    Percpu: 1280 kB
    HardwareCorrupted: 0 kB
    CmaTotal: 393216 kB
    CmaFree: 367360 kB
    lshw
    /usr/bin/pvrlogdump: line 225: lshw: command not found
    ===== Dumping powervr_ddk_install_km.log ============================
    [TS: 157.60]
    Not found
    ===== Dumping powervr_ddk_install_um.log ============================
    version rogueddk_1.15@6133109
    file /usr/lib/libPVRScopeServices.so.1.15.6133109
    link /usr/lib/libPVRScopeServices.so
    file /usr/bin/eglconfigs
    file /usr/bin/egldmabuf
    file /usr/bin/geglinfo
    file /usr/bin/ggles1test1
    file /usr/bin/ggles2test1
    file /usr/bin/ggles3driimage
    ===== Dumping powervr.ini ===========================================
    [TS: 157.61]
    Not found
    ===== Dumping fw snapshot ===========================================
    [TS: 157.61]
    ==== firmware_trace (1) ====
    Debug log type: none
    ==== debug_dump (1) ====
    ------------[ PVR DBG: START (High) ]------------
    OS kernel info: Linux 5.10.120-g95b90aa828 #1 SMP PREEMPT Tue Nov 12 07:11:46 UTC 2024 aarch64
    DDK info: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (release) j721e_linux
    Time now: 157732012us
    Services State: OK
    Server Errors: 0
    Connections Device ID:0(128) P247-V247-T421-SVCameraProcess
    ------[ Driver Info ]------
    Comparison of UM/KM components: MATCHING
    KM Arch: 64 Bit
    UM Connected Clients: 64 Bit
    UM info: 1.15 @ 6133109 (release) build options: 0x80000810
    KM info: 1.15 @ 6133109 (release) build options: 0x00000810
    Window system: wayland
    ------[ RGX Device ID:0 Start ]------
    ------[ RGX Info ]------
    Device Node (Info): 000000004f146d24 (0000000062bf77b2)
    RGX BVNC: 22.104.208.318 (rogue)
    RGX Device State: Active
    RGX Power State: ON
    FW info: 1.15 @ 6133109 (release) build options: 0x80000810
    BIF0 - OK
    RGX FW State: OK (HWRState 0x00000001: HWR OK;)
    RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
    RGX DVFS: 0 frequency changes. Current frequency: 750.000 MHz (sampled at 149902755760 ns). FW frequency: 100.000 MHz.
    RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
    RGX Kernel CCB WO:0x63 RO:0x63
    RGX Firmware CCB WO:0x0 RO:0x0
    RGX Kernel CCB commands executed = 18019
    RGX SLR: Forced UFO updates requested = 0
    RGX Errors: WGP:0, TRP:0
    Thread0: FW IRQ count = 32583
    Last sampled IRQ count in LISR = 32583
    FW System config flags = 0x00020000 (Ctx switch options: Medium CSW profile; VDM CS INDEX mode;)
    FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
    ------[ RGX registers ]------
    RGX Register Base Address (Linear): 0x000000007ea26330
    RGX Register Base Address (Physical): 0x4E20000000
    CORE_ID : 0x0000000008470000
    CORE_REVISION : 0x00D0013E
    DESIGNER_REV_FIELD1 : 0x00000000
    DESIGNER_REV_FIELD2 : 0x00000000
    CHANGESET_NUMBER : 0x0000000000000000
    CLK_CTRL : 0x0aaaaa002a2aaaaa
    CLK_STATUS : 0x0000000000600000
    CLK_CTRL2 : 0x0000000000000000
    CLK_STATUS2 : 0x0000000000000000
    EVENT_STATUS : 0x00004410
    TIMER : 0x000000001b08f4e4
    BIF_FAULT_BANK0_MMU_STATUS : 0x00000000
    BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000
    BIF_FAULT_BANK1_MMU_STATUS : 0x00000000
    BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000
    BIF_MMU_STATUS : 0x00000000
    BIF_MMU_ENTRY : 0x00000000
    BIF_MMU_ENTRY_STATUS : 0x0000000000000000
    BIF_STATUS_MMU : 0x00000000
    BIF_READS_EXT_STATUS : 0x00000000
    BIF_READS_INT_STATUS : 0x00000000
    BIFPM_STATUS_MMU : 0x00000000
    BIFPM_READS_EXT_STATUS : 0x00000000
    BIFPM_READS_INT_STATUS : 0x00000000
    BIF_CAT_BASE_INDEX : 0x0000000000000101
    BIF_CAT_BASE0 : 0x0000000000000000
    BIF_CAT_BASE1 : 0x00000008b5240000
    BIF_CAT_BASE2 : 0x0000000000000000
    BIF_CAT_BASE3 : 0x0000000000000000
    BIF_CAT_BASE4 : 0x0000000000000000
    BIF_CAT_BASE5 : 0x0000000000000000
    BIF_CAT_BASE6 : 0x0000000000000000
    BIF_CAT_BASE7 : 0x0000000000000000
    BIF_CTRL_INVAL : 0x00000000
    BIF_CTRL : 0x000000C0
    BIF_PM_CAT_BASE_VCE0 : 0x00000008b599d001
    BIF_PM_CAT_BASE_TE0 : 0x00000008b5992001
    BIF_PM_CAT_BASE_ALIST0 : 0x00000008b59ad001
    BIF_PM_CAT_BASE_VCE1 : 0x00000008b5aad001
    BIF_PM_CAT_BASE_TE1 : 0x00000008b5aa2001
    BIF_PM_CAT_BASE_ALIST1 : 0x00000008b5abd001
    PERF_TA_PHASE : 0x00003926
    PERF_TA_CYCLE : 0x292EC93B
    PERF_3D_PHASE : 0x0000330C
    PERF_3D_CYCLE : 0x71B49E44
    PERF_TA_OR_3D_CYCLE : 0x9AE34B2C
    PERF_TA_AND_3D_CYCLE : 0x00001C53
    PERF_COMPUTE_PHASE : 0x00000000
    PERF_COMPUTE_CYCLE : 0x00000000
    PM_PARTIAL_RENDER_ENABLE : 0x00000000
    ISP_RENDER : 0x00000000
    TLA_STATUS : 0x0000000000000000
    MCU_FENCE : 0x0000018000000000
    VDM_CONTEXT_STORE_STATUS : 0x00000001
    VDM_CONTEXT_STORE_TASK0 : 0x0000000000000000
    VDM_CONTEXT_STORE_TASK1 : 0x0000000000000000
    VDM_CONTEXT_STORE_TASK2 : 0x0000000000000000
    VDM_CONTEXT_RESUME_TASK0 : 0x0000000000000000
    VDM_CONTEXT_RESUME_TASK1 : 0x0000000000000000
    VDM_CONTEXT_RESUME_TASK2 : 0x0000000000000000
    ISP_CTL : 0x0003500F
    ISP_STATUS : 0x00000003
    MTS_INTCTX : 0x00000000
    MTS_BGCTX : 0x00000000
    MTS_BGCTX_COUNTED_SCHEDULE : 0x00000000
    MTS_SCHEDULE : 0x00000000
    MTS_GPU_INT_STATUS : 0x00004510
    CDM_CONTEXT_STORE_STATUS : 0x00000000
    CDM_CONTEXT_PDS0 : 0x0000000000000000
    CDM_CONTEXT_PDS1 : 0x0000000000000000
    CDM_TERMINATE_PDS : 0x0000000000000000
    CDM_TERMINATE_PDS1 : 0x0000000000000000
    SIDEKICK_IDLE : 0x0000007E
    SLC_IDLE : 0x000000FF
    SLC_STATUS0 : 0x00000000
    SLC_STATUS1 : 0x0000000000000000
    SLC_STATUS2 : 0x0000000000000000
    SLC_CTRL_BYPASS : 0x01000000
    SLC_CTRL_MISC : 0x0000000000200003
    MIPS_ADDR_REMAP1_CONFIG1 : 0x1FC00001
    MIPS_ADDR_REMAP1_CONFIG2 : 0x00000008b514f00c
    MIPS_ADDR_REMAP2_CONFIG1 : 0x1FC01001
    MIPS_ADDR_REMAP2_CONFIG2 : 0x00000008b515e00c
    MIPS_ADDR_REMAP3_CONFIG1 : 0x1FC02001
    MIPS_ADDR_REMAP3_CONFIG2 : 0x00000008b514d00c
    MIPS_ADDR_REMAP4_CONFIG1 : 0x1FC00000
    MIPS_ADDR_REMAP4_CONFIG2 : 0x000000000000000c
    MIPS_ADDR_REMAP5_CONFIG1 : 0x00000001
    MIPS_ADDR_REMAP5_CONFIG2 : 0x00000008b514f00c
    MIPS_WRAPPER_CONFIG : 0x000000000001cf80
    MIPS_EXCEPTION_STATUS : 0x00000020
    ---- [ MIPS internal state ] ----
    PC : 0xC0017480
    STATUS_REGISTER : 0x00481C05
    CAUSE_REGISTER : 0x00800000
    BAD_REGISTER : 0xC0130000
    EPC : 0xC0017484
    SP : 0xCF600FE0
    BAD_INSTRUCTION : 0x00000000
    TLB :
    0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV , PA1 0x00000000 C
    1) VA 0xCF000000 ( 16k) -> PA0 0x8b50e0000 DVGC, PA1 0x8b50e4000 DVGC
    2) VA 0xCF600000 ( 4k) -> PA0 0x8b515f000 DV C, PA1 0x00000000 C
    3) VA 0xC0040000 ( 64k) -> PA0 0x8b5150000 DVGC, PA1 0x8b5160000 DVG
    4) VA 0xC0100000 ( 64k) -> PA0 0x8b5360000 DVGC, PA1 0x8c8630000 DVGC
    5) VA 0xC00C0000 ( 64k) -> PA0 0x8b5230000 DVGC, PA1 0x8b5340000 DVGC
    6) VA 0xC00E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x8b5350000 DV C
    7) VA 0xF00E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
    8) VA 0xC0080000 ( 64k) -> PA0 0x8b5190000 DVG , PA1 0x8b51b0000 DVG
    9) VA 0xC0160000 ( 64k) -> PA0 0x8d40f0000 DV , PA1 0x00000000 C
    10) VA 0xC0060000 ( 64k) -> PA0 0x8b5170000 DVG , PA1 0x8b5180000 VGC
    11) VA 0xC0120000 ( 64k) -> PA0 0x00000000 C, PA1 0x8c8640000 DV
    12) VA 0xF0180000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
    13) VA 0xC0140000 ( 64k) -> PA0 0x8c8870000 DVG , PA1 0x8cfd50000 DVG
    14) VA 0xC0000000 ( 64k) -> PA0 0x8b5110000 DVGC, PA1 0x8b5120000 DVGC
    15) VA 0xF01E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
    ------[ RGX FW Trace Info ]------
    RGX FW thread 0: Trace buffer not yet allocated
    ------[ Full CCB Status ]------
    FWCtx 0xC00C0300 (TQ_3D-P247-T421-SVCameraProce)
    `--<Empty>
    FWCtx 0xC00C0040 (TA-P247-T421-SVCameraProcess)
    `--<Empty>
    FWCtx 0xC00C00E0 (3D-P247-T421-SVCameraProcess)
    `--<Empty>
    ------[ RGX Device ID:0 End ]------
    ------[ System Summary Device ID:0 ]------
    Device System Power State: ON
    MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
    ------[ Server Thread Summary ]------
    pvr_defer_free : Running
    Number of deferred cleanup items : 0
    pvr_device_wdg : Running
    pvr_cacheop : Running
    Configuration: QSZ: 16, UKT: -1, KDFT: 131072, LINESIZE: 64, PGSIZE: 65536, KDF: Yes, URBF: Yes
    Pending deferred CacheOp entries : 0
    ------[ AppHint Settings ]------
    Build Vars
    EnableTrustedDeviceAceConfig: N
    CleanupThreadPriority: 0x00000005
    CacheOpThreadPriority: 0x00000001
    WatchdogThreadPriority: 0x00000000
    HWPerfClientBufferSize: 0x000c0000
    Module Params
    none
    Debug Info Params
    CacheOpConfig: 0x0000000c
    CacheOpUMKMThresholdSize: 0xffffffff
    Debug Info Params Device ID: 0
    none
    ------[ HTB Log state: Off ]------
    ------[ Active Sync Checkpoints ]------
    ------[ Native Fence Sync: timelines ]------
    foreign_sync: @0 ctx=1 refs=1
    sw: RM_SWTimeline-CameraProcess-SVC @0 cur=0
    rogue-ta3d: @13004 ctx=3 refs=9
    @12972: (++) refs=4 fwaddr=0xc01400b1 enqueue=2 status=Signalled 12972-update fence
    @12979: (++) refs=1 fwaddr=0xc0140199 enqueue=1 status=Signalled 12979-update fence
    @12980: (++) refs=4 fwaddr=0xc0140071 enqueue=2 status=Signalled 12980-update fence
    @12987: (++) refs=1 fwaddr=0xc0140081 enqueue=1 status=Signalled 12987-update fence
    @12988: (++) refs=4 fwaddr=0xc0140049 enqueue=2 status=Signalled 12988-update fence
    @12995: (++) refs=1 fwaddr=0xc0140149 enqueue=1 status=Signalled 12995-update fence
    @12996: (++) refs=4 fwaddr=0xc0140131 enqueue=2 status=Signalled 12996-update fence
    @13003: (++) refs=1 fwaddr=0xc0140061 enqueue=1 status=Signalled 13003-update fence
    rogue-tq3d: @1625 ctx=5 refs=1
    QE-SVCameraProcess-247: @3313 ctx=6 refs=4
    @3309: (++) refs=1 fwaddr=0xc0140111 enqueue=4 status=Signalled 3309-TQM
    @3311: (++) refs=1 fwaddr=0xc01400f9 enqueue=4 status=Signalled 3311-TQM
    @3312: (++) refs=1 fwaddr=0xc0140099 enqueue=1 status=Signalled 3312-TQM
    V3-SVCameraProcess-247: @14630 ctx=7 refs=8
    @14622: (++) refs=1 fwaddr=0xc0140101 enqueue=1 status=Signalled 14622-es3_DoKickTA_17924
    @14623: (++) refs=1 fwaddr=0xc0140069 enqueue=1 status=Signalled 14623-es3_DoKickTA_17933
    @14624: (++) refs=1 fwaddr=0xc0140141 enqueue=1 status=Signalled 14624-es3_DoKickTA_17930
    @14625: (++) refs=1 fwaddr=0xc0140181 enqueue=1 status=Signalled 14625-es3_DoKickTA_17932
    @14627: (++) refs=1 fwaddr=0xc01400f1 enqueue=1 status=Signalled 14627-es3_DoKickTA_17937
    @14628: (++) refs=1 fwaddr=0xc01400c1 enqueue=1 status=Signalled 14628-es3_DoKickTA_17940
    @14629: (++) refs=1 fwaddr=0xc01400b9 enqueue=1 status=Signalled 14629-es3_DoKickTA_17939
    P3-SVCameraProcess-247: @9755 ctx=8 refs=2
    @9754: (++) refs=1 fwaddr=0xc0140039 enqueue=1 status=Signalled 9754-es3_DoKick3D_17939
    ------------[ PVR DBG: END ]------------
    ==== firmware_trace (2) ====
    ==== debug_dump (2) ====
    Time now: 157752982us
    Services State: OK
    Server Errors: 0
    KM Arch: 64 Bit
    RGX Power State: ON
    BIF0 - OK
    RGX FW Power State: RGXFWIF_POW_IDLE (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
    Thread0: FW IRQ count = 32584
    Last sampled IRQ count in LISR = 32584
    TIMER : 0x000000001b09e3e2
    PC : 0xC0017480
    EPC : 0xC0017484
    SP : 0xCF600FE0
    TLB :
    `--<Empty>
    `--<Empty>
    `--<Empty>
    Build Vars
    Module Params
    none
    Debug Info Params
    none
    ===== Dumping dmesg =================================================
    [TS: 157.66]
    [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [ 0.000000] Linux version 5.10.120-g95b90aa828 (ubuntu@c027fcd6a9de) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Nov 12 07:11:46 UTC 2024
    [ 0.000000] Machine model: Neusoft Reach DB2 Board - OSPI
    [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [ 0.000000] printk: bootconsole [ns16550a0] enabled
    [ 0.000000] efi: UEFI not found.
    [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a6000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a6100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a7000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a7100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@a8000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 79 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@a8100000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 96 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
    [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d5000000, size 176 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d5000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e0000000, size 8 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e0000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e0800000, size 24 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e0800000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
    [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [ 0.000000] Zone ranges:
    [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
    [ 0.000000] DMA32 empty
    [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
    [ 0.000000] Movable zone start for each node
    [ 0.000000] Early memory node ranges
    [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
    [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b4ffffff]
    [ 0.000000] node 0: [mem 0x00000000b5000000-0x00000000d4ffffff]
    [ 0.000000] node 0: [mem 0x00000000d5000000-0x00000000e1ffffff]
    [ 0.000000] node 0: [mem 0x00000000e2000000-0x00000000ffffffff]
    [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff]
    [ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff]
    [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [ 0.000000] On node 0 totalpages: 65536
    [ 0.000000] DMA zone: 32 pages used for memmap
    [ 0.000000] DMA zone: 0 pages reserved
    [ 0.000000] DMA zone: 32768 pages, LIFO batch:3
    [ 0.000000] Normal zone: 32 pages used for memmap
    [ 0.000000] Normal zone: 32768 pages, LIFO batch:3
    [ 0.000000] cma: Reserved 384 MiB at 0x00000000e8000000
    [ 0.000000] psci: probing for conduit method from DT.
    [ 0.000000] psci: PSCIv1.1 detected in firmware.
    [ 0.000000] psci: Using standard PSCI v0.2 function IDs
    [ 0.000000] psci: Trusted OS migration not required
    [ 0.000000] psci: SMC Calling Convention v1.2
    [ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
    [ 0.000000] pcpu-alloc: s49880 r8192 d73000 u131072 alloc=2*65536
    [ 0.000000] pcpu-alloc: [0] 0 [0] 1
    [ 0.000000] Detected PIPT I-cache on CPU0
    [ 0.000000] CPU features: detected: GIC system register CPU interface
    [ 0.000000] CPU features: detected: EL2 vector hardening
    [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
    [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
    [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [ 0.000000] CPU features: detected: Spectre-BHB
    [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472
    [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p1 rw rootfstype=ext4 rootwait
    [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
    [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [ 0.000000] software IO TLB: mapped [mem 0x00000000e4000000-0x00000000e8000000] (64MB)
    [ 0.000000] Memory: 1963328K/4194304K available (7616K kernel code, 1218K rwdata, 3584K rodata, 1536K init, 658K bss, 1837760K reserved, 393216K cma-reserved)
    [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
    [ 0.000000] rcu: RCU event tracing is enabled.
    [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [ 0.000000] Trampoline variant of Tasks RCU enabled.
    [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [ 0.000000] GICv3: 960 SPIs implemented
    [ 0.000000] GICv3: 0 Extended SPIs implemented
    [ 0.000000] GICv3: Distributor has no Range Selector support
    [ 0.000000] GICv3: 16 PPIs implemented
    [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [ 0.000000] ITS [mem 0x01820000-0x0182ffff]
    [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a8800000 (flat, esz 8, psz 64K, shr 0)
    [ 0.000000] ITS: using cache flushing for cmd queue
    [ 0.000000] GICv3: using LPI property table @0x00000008a80b0000
    [ 0.000000] GIC: using cache flushing for LPI property table
    [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a80c0000
    [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [ 0.000003] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [ 0.008389] Console: colour dummy device 80x25
    [ 0.012956] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [ 0.023628] pid_max: default: 32768 minimum: 301
    [ 0.028381] LSM: Security Framework initializing
    [ 0.033134] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [ 0.040706] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
    [ 0.049951] rcu: Hierarchical SRCU implementation.
    [ 0.055065] Platform MSI: msi-controller@1820000 domain created
    [ 0.061286] EFI services will not be available.
    [ 0.066091] smp: Bringing up secondary CPUs ...
    [ 0.080900] Detected PIPT I-cache on CPU1
    [ 0.080929] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [ 0.080941] GICv3: CPU1: using allocated LPI pending table @0x00000008a80d0000
    [ 0.080980] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [ 0.081046] smp: Brought up 1 node, 2 CPUs
    [ 0.110402] SMP: Total of 2 processors activated.
    [ 0.115211] CPU features: detected: 32-bit EL0 Support
    [ 0.120469] CPU features: detected: CRC32 instructions
    [ 0.126639] CPU: All CPU(s) started at EL2
    [ 0.130835] alternatives: patching kernel code
    [ 0.135901] devtmpfs: initialized
    [ 0.145434] KASLR disabled due to lack of seed
    [ 0.150123] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [ 0.160090] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
    [ 0.167745] pinctrl core: initialized pinctrl subsystem
    [ 0.173378] DMI not present or invalid.
    [ 0.177721] NET: Registered protocol family 16
    [ 0.182977] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [ 0.190247] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [ 0.198225] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [ 0.206543] thermal_sys: Registered thermal governor 'step_wise'
    [ 0.206546] thermal_sys: Registered thermal governor 'power_allocator'
    [ 0.213152] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [ 0.226799] ASID allocator initialised with 32768 entries
    [ 0.243789] cryptd: max_cpu_qlen set to 1000
    [ 0.250144] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [ 0.258949] vsys_3v3: supplied by board_12v0
    [ 0.263506] vsys_5v0: supplied by board_12v0
    [ 0.268360] iommu: Default domain type: Translated
    [ 0.273539] SCSI subsystem initialized
    [ 0.277536] mc: Linux media interface: v0.10
    [ 0.281914] videodev: Linux video capture interface: v2.00
    [ 0.287552] pps_core: LinuxPPS API ver. 1 registered
    [ 0.292628] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.301968] PTP clock support registered
    [ 0.305992] EDAC MC: Ver: 3.0.0
    [ 0.309819] FPGA manager framework
    [ 0.313761] clocksource: Switched to clocksource arch_sys_counter
    [ 0.320233] VFS: Disk quotas dquot_6.6.0
    [ 0.324308] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
    [ 0.334906] Carveout Heap: Exported 512 MiB at 0x00000000b5000000
    [ 0.341215] NET: Registered protocol family 2
    [ 0.345857] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [ 0.354624] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
    [ 0.363398] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
    [ 0.371601] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
    [ 0.379416] TCP: Hash tables configured (established 32768 bind 32768)
    [ 0.386180] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [ 0.393077] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
    [ 0.400486] NET: Registered protocol family 1
    [ 0.405346] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [ 0.416187] Initialise system trusted keyrings
    [ 0.420836] workingset: timestamp_bits=46 max_order=16 bucket_order=0
    [ 0.429602] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.455122] Key type asymmetric registered
    [ 0.459313] Asymmetric key parser 'x509' registered
    [ 0.464318] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [ 0.471879] io scheduler mq-deadline registered
    [ 0.476506] io scheduler kyber registered
    [ 0.481677] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [ 0.487917] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [ 0.495217] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [ 0.501487] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [ 0.509535] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [ 0.517650] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001f8f)
    [ 0.527145] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
    [ 0.537032] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
    [ 0.545012] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [ 0.558438] brd: module loaded
    [ 0.564960] loop: module loaded
    [ 0.570549] tun: Universal TUN/TAP device driver, 1.6
    [ 0.576306] VFIO - User Level meta-driver version: 0.3
    [ 0.581582] i2c /dev entries driver
    [ 0.585710] sdhci: Secure Digital Host Controller Interface driver
    [ 0.592029] sdhci: Copyright(c) Pierre Ossman
    [ 0.596614] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 0.602808] ledtrig-cpu: registered to indicate activity on CPUs
    [ 0.609106] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [ 0.616237] optee: probing for conduit method.
    [ 0.620796] optee: revision 3.17 (15a746d2)
    [ 0.620931] optee: dynamic shared memory is enabled
    [ 0.635765] optee: initialized driver
    [ 0.640254] NET: Registered protocol family 17
    [ 0.644876] 9pnet: Installing 9P2000 support
    [ 0.649280] Key type dns_resolver registered
    [ 0.653714] Loading compiled-in X.509 certificates
    [ 0.660630] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [ 0.667020] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [ 0.674575] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi')
    [ 0.736289] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [ 0.745186] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [ 0.755085] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [ 0.774004] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [ 0.783894] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [ 0.790656] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [ 0.800168] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [ 0.810331] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [ 0.817092] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [ 0.825096] printk: console [ttyS2] disabled
    [ 0.829500] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
    [ 0.838247] printk: console [ttyS2] enabled
    [ 0.846686] printk: bootconsole [ns16550a0] disabled
    [ 0.858692] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [ 0.968690] mmc0: CQHCI version 5.10
    [ 0.976372] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [ 0.983460] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [ 0.992989] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [ 1.003381] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [ 1.012868] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [ 1.013336] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [ 1.023800] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [ 1.038137] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [ 1.055466] spi-nor spi0.0: gd25lx512me (65536 Kbytes)
    [ 1.061939] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [ 1.069258] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [ 1.077772] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [ 1.085120] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [ 1.092509] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [ 1.099840] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [ 1.125919] Waiting for root device /dev/mmcblk0p1...
    [ 1.149023] mmc0: Command Queue Engine enabled
    [ 1.153466] mmc0: new HS200 MMC card at address 0001
    [ 1.158800] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
    [ 1.163419] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB
    [ 1.169423] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB
    [ 1.175419] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (239:0)
    [ 1.184170] mmcblk0: p1
    [ 1.325632] EXT4-fs (mmcblk0p1): recovery complete
    [ 1.330882] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [ 1.339003] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [ 1.346865] devtmpfs: mounted
    [ 1.350180] Freeing unused kernel memory: 1536K
    [ 1.354741] Run /sbin/init as init process
    [ 1.358832] with arguments:
    [ 1.358834] /sbin/init
    [ 1.358836] with environment:
    [ 1.358839] HOME=/
    [ 1.358841] TERM=linux
    [ 1.406814] systemd[1]: System time before build time, advancing clock.
    [ 1.427639] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [ 1.449438] systemd[1]: Detected architecture arm64.
    [ 1.486061] systemd[1]: Set hostname to <db2>.
    [ 1.598644] systemd[1]: Configuration file /lib/systemd/system/apps.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [ 1.612882] systemd[1]: Configuration file /lib/systemd/system/apps.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [ 1.636751] random: systemd: uninitialized urandom read (16 bytes read)
    [ 1.643466] systemd[1]: system-serial\x2dgetty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [ 1.656675] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [ 1.666602] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [ 1.689851] random: systemd: uninitialized urandom read (16 bytes read)
    [ 1.696982] systemd[1]: Created slice User and Session Slice.
    [ 1.717871] random: systemd: uninitialized urandom read (16 bytes read)
    [ 1.724515] systemd[1]: Reached target Slices.
    [ 1.739788] systemd[1]: Listening on Process Core Dump Socket.
    [ 1.765060] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [ 1.773512] systemd[1]: Listening on Journal Socket (/dev/log).
    [ 1.794157] systemd[1]: Listening on Journal Socket.
    [ 1.810142] systemd[1]: Listening on udev Control Socket.
    [ 1.829996] systemd[1]: Listening on udev Kernel Socket.
    [ 1.850091] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [ 1.861456] systemd[1]: Mounting POSIX Message Queue File System...
    [ 1.884515] systemd[1]: Mounting Kernel Debug File System...
    [ 1.904454] systemd[1]: Mounting Temporary Directory (/tmp)...
    [ 1.924592] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [ 1.949909] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [ 1.962222] systemd[1]: Starting Journal Service...
    [ 1.985708] systemd[1]: Starting Load Kernel Modules...
    [ 2.008950] systemd[1]: Starting Remount Root and Kernel File Systems...
    [ 2.020349] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
    [ 2.049189] systemd[1]: Starting udev Coldplug all Devices...
    [ 2.076672] systemd[1]: Started Journal Service.
    [ 2.614942] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a7000000
    [ 2.649977] pvrsrvkm: loading out-of-tree module taints kernel.
    [ 2.706945] urandom_read_iter: 44 callbacks suppressed
    [ 2.706949] random: systemd: uninitialized urandom read (16 bytes read)
    [ 2.725669] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [ 2.732812] random: systemd: uninitialized urandom read (16 bytes read)
    [ 2.743383] random: systemd: uninitialized urandom read (16 bytes read)
    [ 2.755035] remoteproc remoteproc0: 4d80800000.dsp is available
    [ 2.779960] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [ 2.805740] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [ 2.829378] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a7000000
    [ 2.845607] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: MCU cluster requires both R5F cores to be enabled, num_cores = 0
    [ 2.874336] platform 5c00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [ 2.898434] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
    [ 2.912881] platform 5c00000.r5f: configured R5F for IPC-only mode
    [ 2.920122] virtio_rpmsg_bus virtio0: rpmsg host is online
    [ 2.926698] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [ 2.933820] PVR_K: 153: Read BVNC 22.104.208.318 from HW device registers
    [ 2.941672] remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [ 2.948009] PVR_K: 153: RGX Device registered with BVNC 22.104.208.318
    [ 2.954816] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [ 3.013121] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [ 3.054008] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [ 3.068525] remoteproc remoteproc1: 5c00000.r5f is available
    [ 3.126709] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a6000000
    [ 3.155034] remoteproc remoteproc1: attaching to 5c00000.r5f
    [ 3.191449] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [ 3.225575] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [ 3.249893] remoteproc remoteproc2: 4d81800000.dsp is available
    [ 3.264609] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [ 3.294416] remoteproc remoteproc2: attaching to 4d81800000.dsp
    [ 3.336303] remoteproc remoteproc3: b034000.pru is available
    [ 3.336737] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [ 3.356849] remoteproc remoteproc4: b004000.rtu is available
    [ 3.364869] virtio_rpmsg_bus virtio1: rpmsg host is online
    [ 3.380164] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [ 3.401189] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a6000000
    [ 3.406286] remoteproc remoteproc5: b00a000.txpru is available
    [ 3.422743] remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [ 3.431018] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached
    [ 3.440727] remoteproc remoteproc6: b038000.pru is available
    [ 3.447730] platform 5d00000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [ 3.460866] virtio_rpmsg_bus virtio2: rpmsg host is online
    [ 3.462159] remoteproc remoteproc8: b006000.rtu is available
    [ 3.472172] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [ 3.481285] remoteproc remoteproc9: b00c000.txpru is available
    [ 3.482972] remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [ 3.490407] remoteproc remoteproc10: b134000.pru is available
    [ 3.500520] remoteproc remoteproc11: b104000.rtu is available
    [ 3.507237] platform 5d00000.r5f: configured R5F for IPC-only mode
    [ 3.516203] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [ 3.520598] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached
    [ 3.526114] remoteproc remoteproc12: b10a000.txpru is available
    [ 3.539416] remoteproc remoteproc7: 5d00000.r5f is available
    [ 3.547298] remoteproc remoteproc13: b138000.pru is available
    [ 3.553573] remoteproc remoteproc7: attaching to 5d00000.r5f
    [ 3.561226] remoteproc remoteproc14: b106000.rtu is available
    [ 3.567830] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@a8000000
    [ 3.569216] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [ 3.586812] remoteproc remoteproc16: b10c000.txpru is available
    [ 3.612801] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [ 3.630830] random: crng init done
    [ 3.632284] remoteproc remoteproc15: 64800000.dsp is available
    [ 3.635385] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [ 3.640484] remoteproc remoteproc15: attaching to 64800000.dsp
    [ 3.647482] random: 99 urandom warning(s) missed due to ratelimiting
    [ 3.654573] remoteproc remoteproc15: unsupported resource 65538
    [ 3.664072] remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [ 3.668250] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [ 3.678389] virtio_rpmsg_bus virtio3: rpmsg host is online
    [ 3.684587] remoteproc15#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@a8000000
    [ 3.695271] remoteproc7#vdev0buffer: registered virtio3 (type 7)
    [ 3.697680] virtio_rpmsg_bus virtio4: rpmsg host is online
    [ 3.702588] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [ 3.707806] remoteproc15#vdev0buffer: registered virtio4 (type 7)
    [ 3.715419] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [ 3.720847] remoteproc remoteproc15: remote processor 64800000.dsp is now attached
    [ 3.731389] remoteproc remoteproc7: remote processor 5d00000.r5f is now attached
    [ 3.743143] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [ 3.756248] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [ 3.764294] k3_r5_rproc bus@100000:r5fss@5e00000: MCU cluster requires both R5F cores to be enabled, num_cores = 0
    [ 3.774965] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [ 3.783117] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [ 3.790554] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [ 3.798590] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [ 3.806335] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [ 3.813902] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [ 3.821671] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [ 3.830399] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.notifyservice addr 0x1e
    [ 3.838778] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a
    [ 3.846330] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [ 3.857226] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 13/Nov/2024 SHA:7eb793a2
    [ 3.868006] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
    [ 3.878628] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 13/Nov/2024 SHA:7eb793a2
    [ 3.928370] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [ 8.203971] PVR_K: 421: RGX Firmware image 'rgx.fw.22.104.208.318.64k' loaded
    [ 8.240314] PVR_K: 421: Shader binary image 'rgx.sh.22.104.208.318' loaded
    [ 33.179364] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) show-blocked-tasks(w)
    [ 157.652351] seq_file: buggy .next function _Next [pvrsrvkm] did not update position index
    ===== Running pvrdebug -dd then dumping dmesg =======================
    [ 1.358839] HOME=/
    [ 157.774616] PVR_K: 5213: User requested PVR debug info
    [ 157.779959] PVR_K: 5213: ------------[ PVR DBG: START (High) ]------------
    [ 157.786981] PVR_K: 5213: OS kernel info: Linux 5.10.120-g95b90aa828 #1 SMP PREEMPT Tue Nov 12 07:11:46 UTC 2024 aarch64
    [ 157.798936] PVR_K: 5213: DDK info: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (release) j721e_linux
    [ 157.809533] PVR_K: 5213: Time now: 157809514us
    [ 157.816033] PVR_K: 5213: Services State: OK
    [ 157.820573] PVR_K: 5213: Server Errors: 0
    [ 157.825480] PVR_K: 5213: Connections Device ID:0(128) P247-V247-T421-SVCameraProcess, P5213-V5213-T5213-pvrdebug
    [ 157.836071] PVR_K: 5213: ------[ Driver Info ]------
    [ 157.841173] PVR_K: 5213: Comparison of UM/KM components: MATCHING
    [ 157.847584] PVR_K: 5213: KM Arch: 64 Bit
    [ 157.851755] PVR_K: 5213: UM Connected Clients: 64 Bit
    [ 157.856969] PVR_K: 5213: UM info: 1.15 @ 6133109 (release) build options: 0x80000810
    [ 157.864927] PVR_K: 5213: KM info: 1.15 @ 6133109 (release) build options: 0x00000810
    [ 157.872935] PVR_K: 5213: Window system: wayland
    [ 157.877612] PVR_K: 5213: ------[ RGX Device ID:0 Start ]------
    [ 157.883644] PVR_K: 5213: ------[ RGX Info ]------
    [ 157.888498] PVR_K: 5213: Device Node (Info): 000000004f146d24 (0000000062bf77b2)
    [ 157.895996] PVR_K: 5213: RGX BVNC: 22.104.208.318 (rogue)
    [ 157.901491] PVR_K: 5213: RGX Device State: Active
    [ 157.906349] PVR_K: 5213: RGX Power State: ON
    [ 157.910723] PVR_K: 5213: FW info: 1.15 @ 6133109 (release) build options: 0x80000810
    [ 157.918711] PVR_K: 5213: BIF0 - OK
    [ 157.922242] PVR_K: 5213: RGX FW State: OK (HWRState 0x00000001: HWR OK;)
    [ 157.929056] PVR_K: 5213: RGX FW Power State: RGXFWIF_POW_IDLE (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
    [ 157.942443] PVR_K: 5213: RGX DVFS: 0 frequency changes. Current frequency: 750.000 MHz (sampled at 149902755760 ns). FW frequency: 100.000 MHz.
    [ 157.955539] PVR_K: 5213: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
    [ 157.963834] PVR_K: 5213: RGX Kernel CCB WO:0x6E RO:0x6E
    [ 157.969166] PVR_K: 5213: RGX Firmware CCB WO:0x0 RO:0x0
    [ 157.974521] PVR_K: 5213: RGX Kernel CCB commands executed = 18030
    [ 157.980904] PVR_K: 5213: RGX SLR: Forced UFO updates requested = 0
    [ 157.987203] PVR_K: 5213: RGX Errors: WGP:0, TRP:0
    [ 157.991998] PVR_K: 5213: Thread0: FW IRQ count = 32604
    [ 157.997234] PVR_K: 5213: Last sampled IRQ count in LISR = 32604
    [ 158.003255] PVR_K: 5213: FW System config flags = 0x00020000 (Ctx switch options: Medium CSW profile; VDM CS INDEX mode;)
    [ 158.014416] PVR_K: 5213: FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
    [ 158.022664] PVR_K: 5213: ------[ RGX registers ]------
    [ 158.028024] PVR_K: 5213: RGX Register Base Address (Linear): 0x000000007ea26330
    [ 158.035613] PVR_K: 5213: RGX Register Base Address (Physical): 0x4E20000000
    [ 158.042672] PVR_K: 5213: CORE_ID : 0x0000000008470000
    [ 158.049725] PVR_K: 5213: CORE_REVISION : 0x00D0013E
    [ 158.056082] PVR_K: 5213: DESIGNER_REV_FIELD1 : 0x00000000
    [ 158.062446] PVR_K: 5213: DESIGNER_REV_FIELD2 : 0x00000000
    [ 158.068829] PVR_K: 5213: CHANGESET_NUMBER : 0x0000000000000000
    [ 158.075898] PVR_K: 5213: CLK_CTRL : 0x0aaaaa002a2aaaaa
    [ 158.082963] PVR_K: 5213: CLK_STATUS : 0x0000000000600000
    [ 158.090027] PVR_K: 5213: CLK_CTRL2 : 0x0000000000000000
    [ 158.097081] PVR_K: 5213: CLK_STATUS2 : 0x0000000000000000
    [ 158.104133] PVR_K: 5213: EVENT_STATUS : 0x00004410
    [ 158.110493] PVR_K: 5213: TIMER : 0x000000001b19de50
    [ 158.117553] PVR_K: 5213: BIF_FAULT_BANK0_MMU_STATUS : 0x00000000
    [ 158.123924] PVR_K: 5213: BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000
    [ 158.130984] PVR_K: 5213: BIF_FAULT_BANK1_MMU_STATUS : 0x00000000
    [ 158.137336] PVR_K: 5213: BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000
    [ 158.144383] PVR_K: 5213: BIF_MMU_STATUS : 0x00000000
    [ 158.150741] PVR_K: 5213: BIF_MMU_ENTRY : 0x00000000
    [ 158.157108] PVR_K: 5213: BIF_MMU_ENTRY_STATUS : 0x0000000000000000
    [ 158.164164] PVR_K: 5213: BIF_STATUS_MMU : 0x00000000
    [ 158.170555] PVR_K: 5213: BIF_READS_EXT_STATUS : 0x00000000
    [ 158.176936] PVR_K: 5213: BIF_READS_INT_STATUS : 0x00000000
    [ 158.183303] PVR_K: 5213: BIFPM_STATUS_MMU : 0x00000000
    [ 158.189665] PVR_K: 5213: BIFPM_READS_EXT_STATUS : 0x00000000
    [ 158.196031] PVR_K: 5213: BIFPM_READS_INT_STATUS : 0x00000000
    [ 158.202389] PVR_K: 5213: BIF_CAT_BASE_INDEX : 0x0000000000000101
    [ 158.209445] PVR_K: 5213: BIF_CAT_BASE0 : 0x0000000000000000
    [ 158.216511] PVR_K: 5213: BIF_CAT_BASE1 : 0x00000008b5240000
    [ 158.223624] PVR_K: 5213: BIF_CAT_BASE2 : 0x0000000000000000
    [ 158.230703] PVR_K: 5213: BIF_CAT_BASE3 : 0x0000000000000000
    [ 158.237766] PVR_K: 5213: BIF_CAT_BASE4 : 0x0000000000000000
    [ 158.244819] PVR_K: 5213: BIF_CAT_BASE5 : 0x0000000000000000
    [ 158.251868] PVR_K: 5213: BIF_CAT_BASE6 : 0x0000000000000000
    [ 158.258919] PVR_K: 5213: BIF_CAT_BASE7 : 0x0000000000000000
    [ 158.265978] PVR_K: 5213: BIF_CTRL_INVAL : 0x00000000
    [ 158.272339] PVR_K: 5213: BIF_CTRL : 0x000000C0
    [ 158.278780] PVR_K: 5213: BIF_PM_CAT_BASE_VCE0 : 0x00000008b59ad001
    [ 158.285856] PVR_K: 5213: BIF_PM_CAT_BASE_TE0 : 0x00000008b599e001
    [ 158.292916] PVR_K: 5213: BIF_PM_CAT_BASE_ALIST0 : 0x00000008b59a4001
    [ 158.299997] PVR_K: 5213: BIF_PM_CAT_BASE_VCE1 : 0x00000008b5abd001
    [ 158.307059] PVR_K: 5213: BIF_PM_CAT_BASE_TE1 : 0x00000008b5aae001
    [ 158.314119] PVR_K: 5213: BIF_PM_CAT_BASE_ALIST1 : 0x00000008b5ab4001
    [ 158.321180] PVR_K: 5213: PERF_TA_PHASE : 0x0000392F
    [ 158.327540] PVR_K: 5213: PERF_TA_CYCLE : 0x29354831
    [ 158.333903] PVR_K: 5213: PERF_3D_PHASE : 0x00003314
    [ 158.340262] PVR_K: 5213: PERF_3D_CYCLE : 0x721539EE
    [ 158.346619] PVR_K: 5213: PERF_TA_OR_3D_CYCLE : 0x9B4A65CC
    [ 158.352981] PVR_K: 5213: PERF_TA_AND_3D_CYCLE : 0x00001C53
    [ 158.359335] PVR_K: 5213: PERF_COMPUTE_PHASE : 0x00000000
    [ 158.365700] PVR_K: 5213: PERF_COMPUTE_CYCLE : 0x00000000
    [ 158.372056] PVR_K: 5213: PM_PARTIAL_RENDER_ENABLE : 0x00000000
    [ 158.378429] PVR_K: 5213: ISP_RENDER : 0x00000000
    [ 158.384803] PVR_K: 5213: TLA_STATUS : 0x0000000000000000
    [ 158.391848] PVR_K: 5213: MCU_FENCE : 0x0000018000000000
    [ 158.398906] PVR_K: 5213: VDM_CONTEXT_STORE_STATUS : 0x00000001
    [ 158.405262] PVR_K: 5213: VDM_CONTEXT_STORE_TASK0 : 0x0000000000000000
    [ 158.412320] PVR_K: 5213: VDM_CONTEXT_STORE_TASK1 : 0x0000000000000000
    [ 158.419411] PVR_K: 5213: VDM_CONTEXT_STORE_TASK2 : 0x0000000000000000
    [ 158.426480] PVR_K: 5213: VDM_CONTEXT_RESUME_TASK0 : 0x0000000000000000
    [ 158.433542] PVR_K: 5213: VDM_CONTEXT_RESUME_TASK1 : 0x0000000000000000
    [ 158.440586] PVR_K: 5213: VDM_CONTEXT_RESUME_TASK2 : 0x0000000000000000
    [ 158.447637] PVR_K: 5213: ISP_CTL : 0x0003500F
    [ 158.453991] PVR_K: 5213: ISP_STATUS : 0x00000003
    [ 158.460367] PVR_K: 5213: MTS_INTCTX : 0x00000000
    [ 158.466786] PVR_K: 5213: MTS_BGCTX : 0x00000000
    [ 158.473144] PVR_K: 5213: MTS_BGCTX_COUNTED_SCHEDULE : 0x00000000
    [ 158.479520] PVR_K: 5213: MTS_SCHEDULE : 0x00000000
    [ 158.485882] PVR_K: 5213: MTS_GPU_INT_STATUS : 0x00004510
    [ 158.492233] PVR_K: 5213: CDM_CONTEXT_STORE_STATUS : 0x00000000
    [ 158.498591] PVR_K: 5213: CDM_CONTEXT_PDS0 : 0x0000000000000000
    [ 158.505646] PVR_K: 5213: CDM_CONTEXT_PDS1 : 0x0000000000000000
    [ 158.512700] PVR_K: 5213: CDM_TERMINATE_PDS : 0x0000000000000000
    [ 158.519772] PVR_K: 5213: CDM_TERMINATE_PDS1 : 0x0000000000000000
    [ 158.526851] PVR_K: 5213: SIDEKICK_IDLE : 0x0000007E
    [ 158.533227] PVR_K: 5213: SLC_IDLE : 0x000000FF
    [ 158.539577] PVR_K: 5213: SLC_STATUS0 : 0x00000000
    [ 158.545934] PVR_K: 5213: SLC_STATUS1 : 0x0000000000000000
    [ 158.552987] PVR_K: 5213: SLC_STATUS2 : 0x0000000000000000
    [ 158.560076] PVR_K: 5213: SLC_CTRL_BYPASS : 0x01000000
    [ 158.566454] PVR_K: 5213: SLC_CTRL_MISC : 0x0000000000200003
    [ 158.573513] PVR_K: 5213: MIPS_ADDR_REMAP1_CONFIG1 : 0x1FC00001
    [ 158.579896] PVR_K: 5213: MIPS_ADDR_REMAP1_CONFIG2 : 0x00000008b514f00c
    [ 158.586945] PVR_K: 5213: MIPS_ADDR_REMAP2_CONFIG1 : 0x1FC01001
    [ 158.593302] PVR_K: 5213: MIPS_ADDR_REMAP2_CONFIG2 : 0x00000008b515e00c
    [ 158.600354] PVR_K: 5213: MIPS_ADDR_REMAP3_CONFIG1 : 0x1FC02001
    [ 158.606720] PVR_K: 5213: MIPS_ADDR_REMAP3_CONFIG2 : 0x00000008b514d00c
    [ 158.613779] PVR_K: 5213: MIPS_ADDR_REMAP4_CONFIG1 : 0x1FC00000
    [ 158.620153] PVR_K: 5213: MIPS_ADDR_REMAP4_CONFIG2 : 0x000000000000000c
    [ 158.627209] PVR_K: 5213: MIPS_ADDR_REMAP5_CONFIG1 : 0x00000001
    [ 158.633575] PVR_K: 5213: MIPS_ADDR_REMAP5_CONFIG2 : 0x00000008b514f00c
    [ 158.640630] PVR_K: 5213: MIPS_WRAPPER_CONFIG : 0x000000000001cf80
    [ 158.647680] PVR_K: 5213: MIPS_EXCEPTION_STATUS : 0x00000020
    [ 158.654148] PVR_K: 5213: ---- [ MIPS internal state ] ----
    [ 158.659728] PVR_K: 5213: PC : 0xC0017480
    [ 158.666090] PVR_K: 5213: STATUS_REGISTER : 0x00481C05
    [ 158.672482] PVR_K: 5213: CAUSE_REGISTER : 0x00800000
    [ 158.678872] PVR_K: 5213: BAD_REGISTER : 0xC0130000
    [ 158.685238] PVR_K: 5213: EPC : 0xC0017484
    [ 158.691598] PVR_K: 5213: SP : 0xCF600FE0
    [ 158.697961] PVR_K: 5213: BAD_INSTRUCTION : 0x00000000
    [ 158.704317] PVR_K: 5213: TLB :
    [ 158.709730] PVR_K: 5213: 0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV , PA1 0x00000000 C
    [ 158.718433] PVR_K: 5213: 1) VA 0xCF000000 ( 16k) -> PA0 0x8b50e0000 DVGC, PA1 0x8b50e4000 DVGC
    [ 158.727223] PVR_K: 5213: 2) VA 0xCF600000 ( 4k) -> PA0 0x8b515f000 DV C, PA1 0x00000000 C
    [ 158.735927] PVR_K: 5213: 3) VA 0xC0040000 ( 64k) -> PA0 0x8b5150000 DVGC, PA1 0x8b5160000 DVG
    [ 158.744711] PVR_K: 5213: 4) VA 0xC0100000 ( 64k) -> PA0 0x8b5360000 DVGC, PA1 0x8c8630000 DVGC
    [ 158.754089] PVR_K: 5213: 5) VA 0xC00C0000 ( 64k) -> PA0 0x8b5230000 DVGC, PA1 0x8b5340000 DVGC
    [ 158.762909] PVR_K: 5213: 6) VA 0xC00E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x8b5350000 DV C
    [ 158.771619] PVR_K: 5213: 7) VA 0xF00E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
    [ 158.780250] PVR_K: 5213: 8) VA 0xC0080000 ( 64k) -> PA0 0x8b5190000 DVG , PA1 0x8b51b0000 DVG
    [ 158.789085] PVR_K: 5213: 9) VA 0xC0160000 ( 64k) -> PA0 0x8d40f0000 DV , PA1 0x00000000 C
    [ 158.797801] PVR_K: 5213: 10) VA 0xC0060000 ( 64k) -> PA0 0x8b5170000 DVG , PA1 0x8b5180000 VGC
    [ 158.806599] PVR_K: 5213: 11) VA 0xC0120000 ( 64k) -> PA0 0x00000000 C, PA1 0x8c8640000 DV
    [ 158.815303] PVR_K: 5213: 12) VA 0xF0180000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
    [ 158.823927] PVR_K: 5213: 13) VA 0xC0140000 ( 64k) -> PA0 0x8c8870000 DVG , PA1 0x8cfd50000 DVG
    [ 158.832848] PVR_K: 5213: 14) VA 0xC0000000 ( 64k) -> PA0 0x8b5110000 DVGC, PA1 0x8b5120000 DVGC
    [ 158.841666] PVR_K: 5213: 15) VA 0xF01E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
    [ 158.850290] PVR_K: 5213: --------------------------------
    [ 158.855783] PVR_K: 5213: ------[ RGX FW Trace Info ]------
    [ 158.861361] PVR_K: 5213: Debug log type: none
    [ 158.865806] PVR_K: 5213: RGX FW thread 0: Trace buffer not yet allocated
    [ 158.872600] PVR_K: 5213: ------[ Full CCB Status ]------
    [ 158.878037] PVR_K: 5213: FWCtx 0xC00C0300 (TQ_3D-P247-T421-SVCameraProce)
    [ 158.884940] PVR_K: 5213: `--<Empty>
    [ 158.888698] PVR_K: 5213: FWCtx 0xC00C0040 (TA-P247-T421-SVCameraProcess)
    [ 158.895521] PVR_K: 5213: |--Waiting FENCE @ 18952 Int=17955 Ext=17920
    [ 158.902241] PVR_K: 5213: | |--Addr:0xc0160034 Val=0x00000658
    [ 158.908375] PVR_K: 5213: | `--Addr:0xc0140081 Val=0x00000519
    [ 158.914492] PVR_K: 5213: |--Waiting TA @ 19008 Int=17955 Ext=17920
    [ 158.920985] PVR_K: 5213: `--Waiting UPDATE @ 19120 Int=17955 Ext=17920
    [ 158.927813] PVR_K: 5213: |--Addr:0xc0160034 Val=0x00000659
    [ 158.933921] PVR_K: 5213: `--Addr:0xc0140019 Val=0x00000519
    [ 158.940034] PVR_K: 5213: FWCtx 0xC00C00E0 (3D-P247-T421-SVCameraProcess)
    [ 158.946836] PVR_K: 5213: |--Waiting FENCE_PR @ 22416 Int=17955 Ext=17920
    [ 158.953816] PVR_K: 5213: | `--Addr:0xc0160034 Val=0x00000659
    [ 158.960055] PVR_K: 5213: |--Waiting 3D @ 22464 Int=17955 Ext=17920
    [ 158.966524] PVR_K: 5213: `--Waiting UPDATE @ 22856 Int=17955 Ext=17920
    [ 158.973337] PVR_K: 5213: |--Addr:0xc0160034 Val=0x0000065a
    [ 158.979440] PVR_K: 5213: |--Addr:0xc01401a1 Val=0x00000519
    [ 158.985546] PVR_K: 5213: `--Addr:0xc0140129 Val=0x00000519
    [ 158.991652] PVR_K: 5213: ------[ RGX Device ID:0 End ]------
    [ 158.997407] PVR_K: 5213: ------[ System Summary Device ID:0 ]------
    [ 159.003808] PVR_K: 5213: Device System Power State: ON
    [ 159.009078] PVR_K: 5213: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
    [ 159.018405] PVR_K: 5213: ------[ Server Thread Summary ]------
    [ 159.024449] PVR_K: 5213: pvr_defer_free : Running
    [ 159.029515] PVR_K: 5213: Number of deferred cleanup items : 0
    [ 159.035739] PVR_K: 5213: pvr_device_wdg : Running
    [ 159.040726] PVR_K: 5213: pvr_cacheop : Running
    [ 159.045440] PVR_K: 5213: Configuration: QSZ: 16, UKT: -1, KDFT: 131072, LINESIZE: 64, PGSIZE: 65536, KDF: Yes, URBF: Yes
    [ 159.056738] PVR_K: 5213: Pending deferred CacheOp entries : 0
    [ 159.062925] PVR_K: 5213: ------[ AppHint Settings ]------
    [ 159.068436] PVR_K: 5213: Build Vars
    [ 159.072189] PVR_K: 5213: EnableTrustedDeviceAceConfig: N
    [ 159.077941] PVR_K: 5213: CleanupThreadPriority: 0x00000005
    [ 159.083873] PVR_K: 5213: CacheOpThreadPriority: 0x00000001
    [ 159.089788] PVR_K: 5213: WatchdogThreadPriority: 0x00000000
    [ 159.095798] PVR_K: 5213: HWPerfClientBufferSize: 0x000c0000
    [ 159.101809] PVR_K: 5213: Module Params
    [ 159.105855] PVR_K: 5213: none
    [ 159.109252] PVR_K: 5213: Debug Info Params
    [ 159.113668] PVR_K: 5213: CacheOpConfig: 0x0000000c
    [ 159.118925] PVR_K: 5213: CacheOpUMKMThresholdSize: 0xffffffff
    [ 159.125116] PVR_K: 5213: Debug Info Params Device ID: 0
    [ 159.130621] PVR_K: 5213: none
    [ 159.134037] PVR_K: 5213: ------[ HTB Log state: Off ]------
    [ 159.139704] PVR_K: 5213: ------[ Active Sync Checkpoints ]------
    [ 159.145807] ------[ Native Fence Sync: timelines ]------
    [ 159.151133] foreign_sync: @0 ctx=1 refs=1
    [ 159.155165] sw: RM_SWTimeline-CameraProcess-SVC @0 cur=0
    [ 159.160487] rogue-ta3d: @13036 ctx=3 refs=9
    [ 159.164662] @12988: (++) refs=4 fwaddr=0xc0140049 enqueue=2 status=Signalled 12988-update fence
    [ 159.173426] @13011: (++) refs=1 fwaddr=0xc0140191 enqueue=1 status=Signalled 13011-update fence
    [ 159.182192] @13012: (++) refs=4 fwaddr=0xc01401a1 enqueue=2 status=Signalled 13012-update fence
    [ 159.190960] @13019: (++) refs=1 fwaddr=0xc01400b9 enqueue=1 status=Signalled 13019-update fence
    [ 159.199724] @13020: (++) refs=4 fwaddr=0xc0140119 enqueue=2 status=Signalled 13020-update fence
    [ 159.208488] @13027: (++) refs=1 fwaddr=0xc01400c9 enqueue=1 status=Signalled 13027-update fence
    [ 159.217251] @13028: (++) refs=4 fwaddr=0xc0140159 enqueue=2 status=Signalled 13028-update fence
    [ 159.226012] @13035: (++) refs=1 fwaddr=0xc0140079 enqueue=1 status=Signalled 13035-update fence
    [ 159.234893] rogue-tq3d: @1629 ctx=5 refs=1
    [ 159.239133] QE-SVCameraProcess-247: @3321 ctx=6 refs=8
    [ 159.244268] @3309: (++) refs=1 fwaddr=0xc0140111 enqueue=4 status=Signalled 3309-TQM
    [ 159.252083] @3311: (++) refs=1 fwaddr=0xc01400f9 enqueue=4 status=Signalled 3311-TQM
    [ 159.259893] @3313: (++) refs=1 fwaddr=0xc01401a9 enqueue=4 status=Signalled 3313-TQM
    [ 159.267703] @3315: (++) refs=1 fwaddr=0xc01400d1 enqueue=4 status=Signalled 3315-TQM
    [ 159.275511] @3317: (++) refs=1 fwaddr=0xc0140091 enqueue=4 status=Signalled 3317-TQM
    [ 159.283319] @3319: (++) refs=1 fwaddr=0xc0140001 enqueue=4 status=Signalled 3319-TQM
    [ 159.291128] @3320: (++) refs=1 fwaddr=0xc0140131 enqueue=1 status=Signalled 3320-TQM
    [ 159.299108] V3-SVCameraProcess-247: @14667 ctx=7 refs=2
    [ 159.304325] @14666: (+-) refs=2 fwaddr=0xc01401c1 enqueue=1 status=Signalled 14666-es3_DoKickTA_17953
    [ 159.313621] P3-SVCameraProcess-247: @9780 ctx=8 refs=2
    [ 159.318747] @9779: (+-) refs=2 fwaddr=0xc01401d1 enqueue=1 status=Signalled 9779-es3_DoKick3D_17953
    [ 159.327997] PVR_K: 5213: ------------[ PVR DBG: END ]------------
    [ 159.334461] ------------[ cut here ]------------
    [ 159.339246] WARNING: CPU: 1 PID: 5213 at /home/jenkins/workspace/DB2_MCU_APA_BaseTDA4_Manual/BSP/psdkla/board-support/extra-drivers/ti-img-rogue-driver-1.15.6133109/binary_j721e_linux_wayland_release/target_aarch64/kbuild/services/server/common/pvr_notifier.c:529 PVRSRVDebugRequest+0x390/0x598 [pvrsrvkm]
    [ 159.366133] Modules linked in: veth rpmsg_char omap_rng rng_core irq_pruss_intc pru_rproc icss_iep crct10dif_ce ti_k3_r5_remoteproc pvrsrvkm(O) pruss sa2ul sha512_generic authenc ti_k3_dsp_remoteproc virtio_rpmsg_bus cdns_dphy rti_wdt sch_fq_codel rpmsg_kdrv_switch
    [ 159.389594] CPU: 1 PID: 5213 Comm: pvrdebug Tainted: G O 5.10.120-g95b90aa828 #1
    [ 159.398271] Hardware name: Neusoft Reach DB2 Board - OSPI (DT)
    [ 159.404088] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--)
    [ 159.410131] pc : PVRSRVDebugRequest+0x390/0x598 [pvrsrvkm]
    [ 159.415655] lr : PVRSRVDebugRequest+0x38c/0x598 [pvrsrvkm]
    [ 159.421125] sp : ffff80012506faf0
    [ 159.424426] x29: ffff80012506faf0 x28: ffff800008efa75e
    [ 159.429722] x27: ffff800008efa791 x26: ffff800008efa794
    [ 159.435019] x25: ffff00082b9f19a0 x24: 0000000000000018
    [ 159.440316] x23: ffff00082b360200 x22: 0000000000000009
    [ 159.445613] x21: 0000000000000000 x20: ffff00082b3602d8
    [ 159.450911] x19: 0000000000000000 x18: 0000000000000000
    [ 159.456207] x17: 0000000000000000 x16: 0000000000000000
    [ 159.461505] x15: 0000000000000000 x14: 0000000000000000
    [ 159.466805] x13: 0000000000000000 x12: 0000000000000000
    [ 159.472104] x11: 0000000000000001 x10: 00000000000009c0
    [ 159.477404] x9 : ffff80012506f960 x8 : ffff000868a65020
    [ 159.482702] x7 : ffff00087fa9b0c0 x6 : ffff00082ab30980
    [ 159.487998] x5 : 0000000000f0000f x4 : ffff00082b9bf100
    [ 159.493295] x3 : ffff00082a84ce90 x2 : 0000000000000000
    [ 159.498594] x1 : 0000000000000000 x0 : 0000000000000000
    [ 159.503893] Call trace:
    [ 159.506380] PVRSRVDebugRequest+0x390/0x598 [pvrsrvkm]
    [ 159.511539] PVRSRVDumpDebugInfoKM+0x40/0x5c [pvrsrvkm]
    [ 159.516812] PVRSRVBridgeDumpDebugInfo+0x38/0x54 [pvrsrvkm]
    [ 159.522425] BridgedDispatchKM+0x3f4/0x4ec [pvrsrvkm]
    [ 159.527500] PVRSRV_BridgeDispatchKM+0x160/0x188 [pvrsrvkm]
    [ 159.533059] drm_ioctl_kernel+0xbc/0x110
    [ 159.536970] drm_ioctl+0x2ec/0x330
    [ 159.540365] vfs_ioctl+0x28/0x48
    [ 159.543583] __arm64_sys_ioctl+0x78/0xac
    [ 159.547500] el0_svc_common.constprop.0+0x144/0x1b8
    [ 159.552368] do_el0_svc+0x48/0x78
    [ 159.555673] el0_svc+0x14/0x20
    [ 159.558719] el0_sync_handler+0xcc/0x154
    [ 159.562643] el0_sync+0x180/0x1c0
    [ 159.565953] ---[ end trace 1e320cef263e0938 ]---
    ===== Dumping HTB trace file ========================================
    [TS: 159.49]
    Failed to get pvrhtbd output file name. Command output
    follows.
    ========================== HTB Log Dump ============================
    Detected OS: Linux
    TMP_DIR=/tmp
    TLD_BIN=/usr/bin/pvrtld
    PVRDEBUG_BIN=/usr/bin/pvrdebug
    HTB_BIN=/usr/bin/pvrhtb2txt
    WORK_DIR=/tmp/pvrhtbd_2208301709
    Host Trace Logging is not enabled in either:
    /etc/powervr.ini
    or cmdline args
    Nothing will be captured
    ===== Dumping files from pvr debugfs ================================
    [TS: 159.55]
    ==== /sys/kernel/debug/pvr/cacheop_config ====
    KDF: Yes, URBF: Yes
    ==== /sys/kernel/debug/pvr/firmware_trace ====
    ==== /sys/kernel/debug/pvr/debug_dump ====
    Time now: 159669373us
    Services State: OK
    Server Errors: 0
    KM Arch: 64 Bit
    RGX Power State: ON
    BIF0 - OK
    RGX Kernel CCB WO:0x51 RO:0x51
    RGX Kernel CCB commands executed = 18129
    Thread0: FW IRQ count = 32782
    Last sampled IRQ count in LISR = 32782
    TIMER : 0x000000001b5f8f5b
    BIF_PM_CAT_BASE_VCE0 : 0x00000008b5995001
    BIF_PM_CAT_BASE_TE0 : 0x00000008b59a5001
    BIF_PM_CAT_BASE_ALIST0 : 0x00000008b59af001
    BIF_PM_CAT_BASE_VCE1 : 0x00000008b5aa5001
    BIF_PM_CAT_BASE_TE1 : 0x00000008b5ab5001
    BIF_PM_CAT_BASE_ALIST1 : 0x00000008b5abf001
    PERF_TA_PHASE : 0x00003980
    PERF_TA_CYCLE : 0x296FD229
    PERF_3D_PHASE : 0x0000335C
    PERF_3D_CYCLE : 0x758C4947
    PERF_TA_OR_3D_CYCLE : 0x9EFBFF1D
    PC : 0xC0017484
    EPC : 0xC0017480
    SP : 0xCF600FE0
    TLB :
    `--<Empty>
    `--<Empty>
    `--<Empty>
    Build Vars
    Module Params
    none
    Debug Info Params
    none
    rogue-ta3d: @13084 ctx=3 refs=9
    @13052: (++) refs=4 fwaddr=0xc0140161 enqueue=2 status=Signalled 13052-update fence
    @13059: (++) refs=1 fwaddr=0xc0140129 enqueue=1 status=Signalled 13059-update fence
    @13060: (++) refs=4 fwaddr=0xc0140061 enqueue=2 status=Signalled 13060-update fence
    @13067: (++) refs=1 fwaddr=0xc01400e9 enqueue=1 status=Signalled 13067-update fence
    @13068: (++) refs=4 fwaddr=0xc0140151 enqueue=2 status=Signalled 13068-update fence
    @13075: (++) refs=1 fwaddr=0xc01400b9 enqueue=1 status=Signalled 13075-update fence
    @13076: (++) refs=4 fwaddr=0xc0140149 enqueue=2 status=Signalled 13076-update fence
    @13083: (++) refs=1 fwaddr=0xc0140139 enqueue=1 status=Signalled 13083-update fence
    rogue-tq3d: @1635 ctx=5 refs=1
    QE-SVCameraProcess-247: @3333 ctx=6 refs=6
    @3325: (++) refs=1 fwaddr=0xc01401c9 enqueue=4 status=Signalled 3325-TQM
    @3327: (++) refs=1 fwaddr=0xc0140171 enqueue=4 status=Signalled 3327-TQM
    @3329: (++) refs=1 fwaddr=0xc01400f9 enqueue=4 status=Signalled 3329-TQM
    @3331: (++) refs=1 fwaddr=0xc0140031 enqueue=4 status=Signalled 3331-TQM
    @3332: (++) refs=1 fwaddr=0xc01400c9 enqueue=1 status=Signalled 3332-TQM
    V3-SVCameraProcess-247: @14720 ctx=7 refs=8
    @14712: (++) refs=1 fwaddr=0xc0140039 enqueue=1 status=Signalled 14712-es3_DoKickTA_18034
    @14713: (++) refs=1 fwaddr=0xc01401b1 enqueue=1 status=Signalled 14713-es3_DoKickTA_18043
    @14714: (++) refs=1 fwaddr=0xc0140119 enqueue=1 status=Signalled 14714-es3_DoKickTA_18040
    @14715: (++) refs=1 fwaddr=0xc0140179 enqueue=1 status=Signalled 14715-es3_DoKickTA_18042
    @14717: (++) refs=1 fwaddr=0xc0140191 enqueue=1 status=Signalled 14717-es3_DoKickTA_18047
    @14718: (++) refs=1 fwaddr=0xc01401c1 enqueue=1 status=Signalled 14718-es3_DoKickTA_18050
    @14719: (++) refs=1 fwaddr=0xc0140051 enqueue=1 status=Signalled 14719-es3_DoKickTA_18049
    P3-SVCameraProcess-247: @9815 ctx=8 refs=2
    @9814: (++) refs=1 fwaddr=0xc0140071 enqueue=1 status=Signalled 9814-es3_DoKick3D_18049
    ==== /sys/kernel/debug/pvr/status ====
    Driver Status: OK
    Firmware Status: OK
    Server Errors: 0
    HWR Event Count: 0
    CRR Event Count: 0
    SLR Event Count: 0
    WGP Error Count: 0
    TRP Error Count: 0
    FWF Event Count: 0
    APM Event Count: 0
    GPU Utilisation: 10%
    ==== /sys/kernel/debug/pvr/version ====
    Driver Version: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (rogue) (release) build options: 0x00000810 j721e_linux
    Device Name: rgx_j721e
    GPU variant BVNC: 22.104.208.318 (HW)
    Firmware Version: 1.15 @ 6133109 (release) build options: 0x80000810 j721e_linux
    ==== /sys/kernel/debug/pvr/host_trace ====
    ==== /sys/kernel/debug/pvr/driver_stats ====
    MemoryUsageKMalloc 667136
    MemoryUsageKMallocMax 678400
    MemoryUsageVMalloc 131072
    MemoryUsageVMallocMax 131072
    MemoryUsageAllocPTMemoryUMA 262144
    MemoryUsageAllocPTMemoryUMAMax 262144
    MemoryUsageVMapPTUMA 196608
    MemoryUsageVMapPTUMAMax 196608
    MemoryUsageAllocPTMemoryLMA 0
    MemoryUsageAllocPTMemoryLMAMax 0
    MemoryUsageIORemapPTLMA 0
    MemoryUsageIORemapPTLMAMax 0
    MemoryUsageAllocGPUMemLMA 0
    MemoryUsageAllocGPUMemLMAMax 0
    MemoryUsageAllocGPUMemUMA 313982976
    MemoryUsageAllocGPUMemUMAMax 316801024
    MemoryUsageAllocGPUMemUMAPool 5373952
    MemoryUsageAllocGPUMemUMAPoolMax 6684672
    MemoryUsageMappedGPUMemUMA/LMA 218562560
    MemoryUsageMappedGPUMemUMA/LMAMax 222298112
    MemoryUsageDmaBufImport 52690944
    MemoryUsageDmaBufImportMax 52690944
    ==== /sys/kernel/debug/pvr/power_timing_stats ====
    Forced Power-on Transition (nanoseconds):
    Pre-Device: 485
    Pre-System: 0
    Post-System: 0
    Post-Device: 180150
    Forced Power-off Transition (nanoseconds):
    Pre-Device: 0
    Pre-System: 0
    Post-System: 0
    Post-Device: 0
    Not Forced Power-on Transition (nanoseconds):
    Pre-Device: 0
    Pre-System: 0
    Post-System: 0
    Post-Device: 0
    Not Forced Power-off Transition (nanoseconds):
    Pre-Device: 0
    Pre-System: 0
    Post-System: 0
    Post-Device: 0
    FW bootup time (timer ticks): 15653633
    Host Acknowledge Time for FW Idle Signal (timer ticks): 0
    Last 10 Clock Speed Change Timers (nanoseconds):
    Prepare DVFS DVFS Change Post DVFS
    ==== /sys/kernel/debug/pvr/buildvar/HWPerfClientBufferSize ====
    0x000c0000
    ==== /sys/kernel/debug/pvr/apphint/0/EnableFWPoisonOnFree ====
    N
    ==== /sys/kernel/debug/pvr/apphint/0/ZeroFreelist ====
    N
    ==== /sys/kernel/debug/pvr/apphint/0/DisableFEDLogging ====
    N
    ==== /sys/kernel/debug/pvr/apphint/0/EnableAPM ====
    0x00000002
    ==== /sys/kernel/debug/pvr/apphint/0/HWRDebugDumpLimit ====
    0x00000001
    ==== /sys/kernel/debug/pvr/apphint/0/FirmwareLogType ====
    trace
    ==== /sys/kernel/debug/pvr/apphint/0/EnableLogGroup ====
    none
    ==== /sys/kernel/debug/pvr/apphint/0/CheckMList ====
    N
    ==== /sys/kernel/debug/pvr/apphint/0/AssertOutOfMemory ====
    N
    ==== /sys/kernel/debug/pvr/apphint/0/AssertOnHWRTrigger ====
    N
    ==== /sys/kernel/debug/pvr/apphint/TimeCorrClock ====
    mono
    ==== /sys/kernel/debug/pvr/apphint/CacheOpUMKMThresholdSize ====
    0xffffffff
    ==== /sys/kernel/debug/pvr/apphint/CacheOpConfig ====
    0x0000000c
    ==== /sys/kernel/debug/pvr/apphint/HWPerfClientFilter_OpenGL ====
    0x00000000
    ==== /sys/kernel/debug/pvr/apphint/HWPerfClientFilter_Vulkan ====
    0x00000000
    ==== /sys/kernel/debug/pvr/apphint/HWPerfClientFilter_OpenCL ====
    0x00000000
    ==== /sys/kernel/debug/pvr/apphint/HWPerfClientFilter_OpenGLES ====
    0x00000000
    ==== /sys/kernel/debug/pvr/apphint/HWPerfClientFilter_EGL ====
    0x00000000
    ==== /sys/kernel/debug/pvr/apphint/HWPerfClientFilter_Services ====
    0x00000000
    ==== /sys/kernel/debug/pvr/apphint/HWPerfHostFilter ====
    0x00000000
    ==== /sys/kernel/debug/pvr/apphint/HWPerfFWFilter ====
    0x0000000000000000
    ==== /sys/kernel/debug/pvr/apphint/EnableFTraceGPU ====
    N
    ==== /sys/kernel/debug/pvr/apphint/HTBOperationMode ====
    dropoldest
    ==== /sys/kernel/debug/pvr/apphint/EnableHTBLogGroup ====
    none
    ==== Dumping native syncs info ======================================
    [TS: 159.77]
    Not found
    ===== Dumping lockdep related files =================================
    [TS: 159.77]
    Not found
    ===== Dumping ftrace files ==========================================
    [TS: 159.78]
    Not found
    ===== Dumping app info ==============================================
    [TS: 159.78]
    ===== Dumping fw snapshot ===========================================
    [TS: 159.78]
    ==== firmware_trace (1) ====
    ==== debug_dump (1) ====
    Time now: 161896253us
    Services State: OK
    Server Errors: 0
    KM Arch: 64 Bit
    RGX Power State: ON
    BIF0 - OK
    RGX DVFS: 0 frequency changes. Current frequency: 749.999 MHz (sampled at 159915313495 ns). FW frequency: 100.000 MHz.
    RGX Kernel CCB WO:0x59 RO:0x59
    RGX Kernel CCB commands executed = 18393
    Thread0: FW IRQ count = 33263
    Last sampled IRQ count in LISR = 33263
    TIMER : 0x000000001bc31cd6
    BIF_PM_CAT_BASE_VCE0 : 0x00000008b5997001
    BIF_PM_CAT_BASE_TE0 : 0x00000008b599a001
    BIF_PM_CAT_BASE_ALIST0 : 0x00000008b599d001
    BIF_PM_CAT_BASE_VCE1 : 0x00000008b5aa7001
    BIF_PM_CAT_BASE_TE1 : 0x00000008b5aaa001
    BIF_PM_CAT_BASE_ALIST1 : 0x00000008b5aad001
    PERF_TA_PHASE : 0x00003A58
    PERF_TA_CYCLE : 0x2A0CB62C
    PERF_3D_PHASE : 0x0000341C
    PERF_3D_CYCLE : 0x7ECE64DB
    PERF_TA_OR_3D_CYCLE : 0xA8DAFEB4
    PC : 0xC0017480
    EPC : 0xC001747C
    SP : 0xCF600FE0
    TLB :
    `--<Empty>
    `--<Empty>
    `--<Empty>
    Build Vars
    Module Params
    none
    Debug Info Params
    none
    rogue-ta3d: @13276 ctx=3 refs=9
    @13244: (++) refs=4 fwaddr=0xc0140131 enqueue=2 status=Signalled 13244-update fence
    @13251: (++) refs=1 fwaddr=0xc0140039 enqueue=1 status=Signalled 13251-update fence
    @13252: (++) refs=4 fwaddr=0xc0140041 enqueue=2 status=Signalled 13252-update fence
    @13259: (++) refs=1 fwaddr=0xc01400a1 enqueue=1 status=Signalled 13259-update fence
    @13260: (++) refs=4 fwaddr=0xc0140081 enqueue=2 status=Signalled 13260-update fence
    @13267: (++) refs=1 fwaddr=0xc01400a9 enqueue=1 status=Signalled 13267-update fence
    @13268: (++) refs=4 fwaddr=0xc0140061 enqueue=2 status=Signalled 13268-update fence
    @13275: (++) refs=1 fwaddr=0xc0140051 enqueue=1 status=Signalled 13275-update fence
    rogue-tq3d: @1659 ctx=5 refs=1
    QE-SVCameraProcess-247: @3381 ctx=6 refs=8
    @3369: (++) refs=1 fwaddr=0xc0140141 enqueue=4 status=Signalled 3369-TQM
    @3371: (++) refs=1 fwaddr=0xc0140011 enqueue=4 status=Signalled 3371-TQM
    @3373: (++) refs=1 fwaddr=0xc0140019 enqueue=4 status=Signalled 3373-TQM
    @3375: (++) refs=1 fwaddr=0xc0140171 enqueue=4 status=Signalled 3375-TQM
    @3377: (++) refs=1 fwaddr=0xc0140021 enqueue=4 status=Signalled 3377-TQM
    @3379: (++) refs=1 fwaddr=0xc0140199 enqueue=4 status=Signalled 3379-TQM
    @3380: (++) refs=1 fwaddr=0xc01400d1 enqueue=1 status=Signalled 3380-TQM
    V3-SVCameraProcess-247: @14936 ctx=7 refs=8
    @14928: (++) refs=1 fwaddr=0xc0140059 enqueue=1 status=Signalled 14928-es3_DoKickTA_18298
    @14929: (++) refs=1 fwaddr=0xc01400d9 enqueue=1 status=Signalled 14929-es3_DoKickTA_18307
    @14930: (++) refs=1 fwaddr=0xc0140079 enqueue=1 status=Signalled 14930-es3_DoKickTA_18304
    @14931: (++) refs=1 fwaddr=0xc0140181 enqueue=1 status=Signalled 14931-es3_DoKickTA_18306
    @14933: (++) refs=1 fwaddr=0xc0140049 enqueue=1 status=Signalled 14933-es3_DoKickTA_18311
    @14934: (++) refs=1 fwaddr=0xc01401a1 enqueue=1 status=Signalled 14934-es3_DoKickTA_18314
    @14935: (++) refs=1 fwaddr=0xc0140151 enqueue=1 status=Signalled 14935-es3_DoKickTA_18313
    P3-SVCameraProcess-247: @9959 ctx=8 refs=2
    @9958: (++) refs=1 fwaddr=0xc01401b1 enqueue=1 status=Signalled 9958-es3_DoKick3D_18313
    Time now: 161915761us
    Services State: OK
    Server Errors: 0
    KM Arch: 64 Bit
    RGX Power State: ON
    BIF0 - OK
    RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
    RGX Kernel CCB WO:0x64 RO:0x64
    RGX Kernel CCB commands executed = 18404
    Thread0: FW IRQ count = 33282
    Last sampled IRQ count in LISR = 33282
    TIMER : 0x000000001bc3fb1d
    BIF_PM_CAT_BASE_VCE0 : 0x00000008b599d001
    BIF_PM_CAT_BASE_TE0 : 0x00000008b5992001
    BIF_PM_CAT_BASE_ALIST0 : 0x00000008b59ad001
    BIF_PM_CAT_BASE_VCE1 : 0x00000008b5aad001
    BIF_PM_CAT_BASE_TE1 : 0x00000008b5aa2001
    BIF_PM_CAT_BASE_ALIST1 : 0x00000008b5abd001
    PERF_TA_PHASE : 0x00003A61
    PERF_TA_CYCLE : 0x2A13619A
    PERF_3D_PHASE : 0x00003424
    PERF_3D_CYCLE : 0x7F36B3C7
    PERF_TA_OR_3D_CYCLE : 0xA949F90E
    PC : 0xC0017480
    EPC : 0xC0017484
    SP : 0xCF600FE0
    TLB :
    `--<Empty>
    `--<Empty>
    `--<Empty>
    Build Vars
    Module Params
    none
    Debug Info Params
    none
    rogue-ta3d: @13284 ctx=3 refs=9
    @13276: (++) refs=4 fwaddr=0xc0140089 enqueue=2 status=Signalled 13276-update fence
    @13283: (++) refs=1 fwaddr=0xc0140149 enqueue=1 status=Signalled 13283-update fence
    rogue-tq3d: @1660 ctx=5 refs=1
    QE-SVCameraProcess-247: @3383 ctx=6 refs=3
    @3381: (++) refs=1 fwaddr=0xc0140001 enqueue=4 status=Signalled 3381-TQM
    @3382: (++) refs=1 fwaddr=0xc0140179 enqueue=1 status=Signalled 3382-TQM
    V3-SVCameraProcess-247: @14945 ctx=7 refs=8
    @14937: (++) refs=1 fwaddr=0xc01400f1 enqueue=1 status=Signalled 14937-es3_DoKickTA_18309
    @14938: (++) refs=1 fwaddr=0xc0140009 enqueue=1 status=Signalled 14938-es3_DoKickTA_18318
    @14939: (++) refs=1 fwaddr=0xc0140169 enqueue=1 status=Signalled 14939-es3_DoKickTA_18315
    @14940: (++) refs=1 fwaddr=0xc0140101 enqueue=1 status=Signalled 14940-es3_DoKickTA_18317
    @14942: (++) refs=1 fwaddr=0xc0140159 enqueue=1 status=Signalled 14942-es3_DoKickTA_18322
    @14943: (++) refs=1 fwaddr=0xc01400e9 enqueue=1 status=Signalled 14943-es3_DoKickTA_18325
    @14944: (++) refs=1 fwaddr=0xc01401b9 enqueue=1 status=Signalled 14944-es3_DoKickTA_18324
    P3-SVCameraProcess-247: @9965 ctx=8 refs=2
    @9964: (++) refs=1 fwaddr=0xc0140191 enqueue=1 status=Signalled 9964-es3_DoKick3D_18324
    [TS (END): 161.82]
    There's a lot to parse through here. I will investigate and let you know my findings and further questions I may have.
    Sarabesh S.
    On which core is the shared memory used by FBO located?
    The FBO is located as part of a unified memory in DDR. There isn't a particular core that the FBO is used by, I believe it depends on what is being done with the FBO.
    Also, could you please update you DDK to a stable version by copying the UM and patching the KM, noted here: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1316731/faq-tda4vl-q1-what-are-the-gpu-driver-bug-fixes-for-sdk-8-6-or-earlier
    There are several issues that exist in the older DDK versions that were fixed as part of newer release. The above FAQ provides a stable working version for 8.6 and earlier.
    Sarabesh S.
  • From the pvrdump log provided above, it can be seen that we are currently using the latest GPU version 1.15:
    Hello Jiang Nan
        with the disscussion in the webchat, this issue occurs after removing the ETHFW module, and never happen when work with ETHFW
        removing ETHFW is for mcm assertsion issue,
        please help check following patch, this patch is for mcm assertion issue, already verified in other project,
        after applying this patch, to see mem issue if fixed or not,
       Semon
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/2744.0001_2D00_mcm_2D00_Fix_2D00_race_2D00_condition_2D00_in_2D00_MCM_2D00_request_2D00_response_2D00_handl_5F00_SDK_5F00_8_5F00_6.patch
  • Our system and BSP developers are organizing the different versions of patches you provided and have identified the following subtle differences:
    The patch 《MCM_Core_attach_patch.zip》is provided by another developer from TI, and it contains a bit more information than what you have provided8105.MCM_Core_attach_patch.zip
  • Please confirm the following two points:
    1. Are these situations caused by the FBO buffer being cleared or the GPU crashing?
        Last year, when we reported the issue of screen flicker (alternating between normal frames and black frames, the entire image), we ultimately determined that the root cause was a GPU driver bug, which caused the system to crash.
    Now this is a local FBO buffer that suddenly turns black or white or randomly has other colors. What is the problem with the GPU that usually causes this phenomenon?
        PS: The principle behind this is to calculate the rotation and translation matrix of the external image of the car bottom based on the positioning information, and then rotate and translate the external image of the car bottom to the car bottom. This buffer always has data, and only defaults to a fixed gray color at the beginning of startup, as shown in the left figure below. In the subsequent operation process, the content of the car bottom area will be changed according to the positioning information. The correct effect is shown in the figure on the right below. Taking a step back, even if the system signal is abnormal and the positioning information is confused during operation, it will only cause the filling content of the car bottom area to be inaccurate or confused with the outside, rather than being cleaned up into a random fixed color and suddenly quickly restored as it is now.
    2、How to confirm the total amount of memory allocated to the GPU during the operation of TDA4 on Linux? How much memory has been used and how much is left?TDA4 seems to only be able to check the GPU load using the following command:
    cat /sys/kernel/debug/pvr/status
