SK-AM69: edgeai-tiovx-apps-test hangs
Part Number: SK-AM69
Hello!
I'm trying to build custom Linux image with EdgeAI components included to run TIOVX apps. There were problems with remote cores creating IPC channels previously discussed in the related thread, but now it seems to be ok:
root@am69-b55:/opt/edgeai-tiovx-apps/bin# dmesg | grep rpmsg
[    8.287923] virtio_rpmsg_bus virtio0: rpmsg host is online
[    8.291665] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    8.495336] virtio_rpmsg_bus virtio1: rpmsg host is online
[    8.514919] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[    8.527418] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[    8.541320] virtio_rpmsg_bus virtio2: rpmsg host is online
[    8.545300] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    8.618502] virtio_rpmsg_bus virtio3: rpmsg host is online
[    8.625787] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    8.690892] virtio_rpmsg_bus virtio4: rpmsg host is online
[    8.696156] virtio_rpmsg_bus virtio5: rpmsg host is online
[    8.697897] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[    8.699898] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[    8.810164] virtio_rpmsg_bus virtio6: rpmsg host is online
[    8.812145] virtio_rpmsg_bus virtio7: rpmsg host is online
[    8.814948] virtio_rpmsg_bus virtio8: rpmsg host is online
[    8.816430] virtio_rpmsg_bus virtio9: rpmsg host is online
[    8.816887] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
[    8.818829] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
[    8.819630] virtio_rpmsg_bus virtio10: rpmsg host is online
[    8.821419] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
[    8.822608] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd
[    8.822813] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
[    8.823040] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15
[    8.823096] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    8.823159] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    8.823207] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[    8.823302] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[    8.823378] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
[    8.823495] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
[    8.823537] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
[    8.823560] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
[    8.823999] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[    8.825103] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    8.825221] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
[    8.825321] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
[    8.825511] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
[    8.838825] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[    8.914138] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe
[    9.182701] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    9.195030] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[    9.268574] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[    9.382806] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
So the problem is that edgeai-tiovx-apps-test default application is hangs on tiovx_modules_wait_graph function. I've added some printf lines to understand where the problem:
root@am69-b55:/opt/edgeai-tiovx-apps/bin# ./edgeai-tiovx-apps-test
APP: Init ... !!!
    38.035141 s: MEM: Init ... !!!
    38.035215 s: MEM: Initialized DMA HEAP (fd=5) !!!
    38.035344 s: MEM: Init ... Done !!!
    38.035357 s: IPC: Init ... !!!
    38.067007 s: IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
    38.077319 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
    38.078990 s:  VX_ZONE_INIT:Enabled
    38.079002 s:  VX_ZONE_ERROR:Enabled
    38.079009 s:  VX_ZONE_WARNING:Enabled
    38.080877 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:134] Added target MPU-0
    38.080986 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:134] Added target MPU-1
    38.081058 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:134] Added target MPU-2
    38.081130 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:134] Added target MPU-3
    38.081140 s:  VX_ZONE_INIT:[tivxInitLocal:127] Initialization Done !!!
    38.083469 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
Running Multi Scaler module test
tiovx_multi_scaler_init_cfg
tiovx_multi_scaler_module_crop_params_init
tiovx_modules_initialize_graph
tiovx_modules_add_node
tiovx_modules_verify_graph
tiovx_modules_acquire_buf
input_filename: /opt/edgeai-test-data/raw_images/modules_test/baboon_640x480_nv12.yuv
readImage status: 0
tiovx_modules_enqueue_buf: 0
tiovx_modules_schedule_graph: 0
tiovx_modules_wait_graph start
vxWaitGraph //hangs here for about 2 minutes
tiovx_modules_wait_graph: 0
tiovx_modules_dequeue_buf //hangs on vxGraphParameterDequeueDoneRef forever
I think that the problem may be in some components of the edgeai and something is not initialized as it should be, can you please help fix this?
    What SDK version are you using?
    Thank you,
    Fabiana
  • Hi Fabiana,
    I've used commits from file processor-sdk-analytics-10_00-config.txt. So I assume it is 10.00.
    Also I found that after couple of minutes it goes to tiovx_modules_dequeue_buf function but  nothing happens later. This app is working fine on TI's default edgeai image. I'm using TI's SK-AM69 evaluation board.
    If I want to restart the app I have to wait this line in console: virtio_rpmsg_bus virtio4: msg received with no recipient or it will stuck on tiovx_modules_verify_graph function.
    edgeai-tiovx-apps-main app is hangs too on line and interrupt signal is not working:
  • Hi Andre,
    Could you please run /opt/vx_app_arm_remote_log.out on the background and share the output?
    Thank you,
    Fabiana
    it hangs too
    vx_app_arm_remote_log.log
    root@am69-b55:/opt/edgeai-gst-apps#  /opt/vx_app_arm_remote_log.out
    [MCU2_0]      4.266366 s: CIO: Init ... Done !!!
    [MCU2_0]      4.266416 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]      4.266441 s: CPU is running FreeRTOS
    [MCU2_0]      4.266457 s: APP: Init ... !!!
    [MCU2_0]      4.266490 s: SCICLIENT: Init ... !!!
    [MCU2_0]      4.266603 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU2_0]      4.266630 s: SCICLIENT: DMSC FW revision 0xa
    [MCU2_0]      4.266649 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU2_0]      4.266670 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]      4.266689 s: UDMA: Init ... !!!
    [MCU2_0]      4.267543 s: UDMA: Init ... Done !!!
    [MCU2_0]      4.267575 s: UDMA: Init for CSITX/CSIRX ... !!!
    [MCU2_0]      4.268007 s: UDMA: Init for CSITX/CSIRX ... Done !!!
    [MCU2_0]      4.268036 s: MEM: Init ... !!!
    [MCU2_0]      4.268061 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bb000000 of size 6291456 bytes !!!
    [MCU2_0]      4.268104 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 60000000 of size 262144 bytes !!!
    [MCU2_0]      4.268141 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ bb600000 of size 2097152 bytes !!!
    [MCU2_0]      4.268179 s: MEM: Init ... Done !!!
    [MCU2_0]      4.268196 s: IPC: Init ... !!!
    [MCU2_0]      4.268229 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_0]      4.268264 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0]     17.683584 s: IPC: HLOS is ready !!!
    [MCU2_0]     17.691077 s: IPC: Init ... Done !!!
    [MCU2_0]     17.691126 s: APP: Syncing with 10 CPUs ... !!!
    [MCU2_0]     18.317784 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU2_0]     18.317814 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_0]     18.318326 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_0]     18.318373 s: FVID2: Init ... !!!
    [MCU2_0]     18.318407 s: FVID2: Init ... Done !!!
    [MCU2_0]     18.318428 s: VHWA: VPAC Init ... !!!
    [MCU2_0]     18.318446 s: SCICLIENT: Sciclient_pmSetModuleState module=399 state=2
    [MCU2_0]     18.318556 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]     18.318580 s: VHWA: LDC Init ... !!!
    [MCU2_0]     18.323873 s: VHWA: LDC Init ... Done !!!
    [MCU2_0]     18.323911 s: VHWA: MSC Init ... !!!
    [MCU2_0]     18.335460 s: VHWA: MSC Init ... Done !!!
    [MCU2_0]     18.335492 s: VHWA: NF Init ... !!!
    [MCU2_0]     18.336835 s: VHWA: NF Init ... Done !!!
    [MCU2_0]     18.336861 s: VHWA: VISS Init ... !!!
    [MCU2_0]     18.345646 s: VHWA: VISS Init ... Done !!!
    [MCU2_0]     18.345683 s: VHWA: VPAC Init ... Done !!!
    [MCU2_0]     18.345715 s:  VX_ZONE_INIT:Enabled
    [MCU2_0]     18.345737 s:  VX_ZONE_ERROR:Enabled
    [MCU2_0]     18.345756 s:  VX_ZONE_WARNING:Enabled
    [MCU2_0]     18.347055 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU2-0
    [MCU2_0]     18.347149 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_NF
    [MCU2_0]     18.347220 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_LDC1
    [MCU2_0]     18.347308 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC1
    [MCU2_0]     18.347384 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC2
    [MCU2_0]     18.347516 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_VISS1
    [MCU2_0]     18.347612 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE1
    [MCU2_0]     18.347711 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE2
    [MCU2_0]     18.347802 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE3
    [MCU2_0]     18.347899 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE4
    [MCU2_0]     18.347983 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE5
    [MCU2_0]     18.348073 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE6
    [MCU2_0]     18.348161 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE7
    [MCU2_0]     18.348264 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE8
    [MCU2_0]     18.348362 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE9
    [MCU2_0]     18.348460 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE10
    [MCU2_0]     18.348551 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE11
    [MCU2_0]     18.348637 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE12
    [MCU2_0]     18.348720 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DISPLAY1
    [MCU2_0]     18.348798 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DISPLAY2
    [MCU2_0]     18.348876 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CSITX
    [MCU2_0]     18.348948 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CSITX2
    [MCU2_0]     18.349040 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M1
    [MCU2_0]     18.349124 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M2
    [MCU2_0]     18.349221 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M3
    [MCU2_0]     18.349315 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M4
    [MCU2_0]     18.349353 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU2_0]     18.349377 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_0]     18.356282 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_0]     18.356320 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU2_0]     18.356372 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU2_0]     18.356394 s: UDMA Copy: Init ... !!!
    [MCU2_0]     18.357285 s: UDMA Copy: Init ... Done !!!
    [MCU2_0]     18.357320 s: APP: Init ... Done !!!
    [MCU2_0]     18.357341 s: APP: Run ... !!!
    [MCU2_0]     18.357358 s: IPC: Starting echo test ...
    [MCU2_0]     18.357536 s: APP: Run ... Done !!!
    [MCU2_0]     18.358624 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[.] mcu3_1[.] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]     18.358725 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[.] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]     18.358793 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]     18.358860 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[.] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]     18.358923 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]     18.358990 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[.] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU2_0]     18.359053 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU2_0]     18.359119 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU2_0]     18.359184 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]      4.385056 s: CIO: Init ... Done !!!
    [MCU2_1]      4.385106 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]      4.385130 s: CPU is running FreeRTOS
    [MCU2_1]      4.385146 s: APP: Init ... !!!
    [MCU2_1]      4.385180 s: SCICLIENT: Init ... !!!
    [MCU2_1]      4.385293 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU2_1]      4.385323 s: SCICLIENT: DMSC FW revision 0xa
    [MCU2_1]      4.385342 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU2_1]      4.385364 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]      4.385381 s: UDMA: Init ... !!!
    [MCU2_1]      4.386264 s: UDMA: Init ... Done !!!
    [MCU2_1]      4.386294 s: MEM: Init ... !!!
    [MCU2_1]      4.386319 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bb800000 of size 8388608 bytes !!!
    [MCU2_1]      4.386362 s: MEM: Init ... Done !!!
    [MCU2_1]      4.386379 s: IPC: Init ... !!!
    [MCU2_1]      4.386410 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_1]      4.386441 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]     18.098709 s: IPC: HLOS is ready !!!
    [MCU2_1]     18.105649 s: IPC: Init ... Done !!!
    [MCU2_1]     18.105693 s: APP: Syncing with 10 CPUs ... !!!
    [MCU2_1]     18.317781 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU2_1]     18.317813 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_1]     18.318328 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_1]     18.318374 s: FVID2: Init ... !!!
    [MCU2_1]     18.318414 s: FVID2: Init ... Done !!!
    [MCU2_1]     18.318439 s: VHWA: DMPAC: Init ... !!!
    [MCU2_1]     18.318458 s: SCICLIENT: Sciclient_pmSetModuleState module=92 state=2
    [MCU2_1]     18.318610 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]     18.318636 s: SCICLIENT: Sciclient_pmSetModuleState module=96 state=2
    [MCU2_1]     18.318698 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]     18.318722 s: VHWA: DOF Init ... !!!
    [MCU2_1]     18.327044 s: VHWA: DOF Init ... Done !!!
    [MCU2_1]     18.327077 s: VHWA: SDE Init ... !!!
    [MCU2_1]     18.330031 s: VHWA: SDE Init ... Done !!!
    [MCU2_1]     18.330056 s: VHWA: DMPAC: Init ... Done !!!
    [MCU2_1]     18.330090 s:  VX_ZONE_INIT:Enabled
    [MCU2_1]     18.330112 s:  VX_ZONE_ERROR:Enabled
    [MCU2_1]     18.330132 s:  VX_ZONE_WARNING:Enabled
    [MCU2_1]     18.331462 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU2-1
    [MCU2_1]     18.331546 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DMPAC_SDE
    [MCU2_1]     18.331640 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DMPAC_DOF
    [MCU2_1]     18.331676 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU2_1]     18.331701 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_1]     18.331847 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_1]     18.331878 s: APP: Init ... Done !!!
    [MCU2_1]     18.331897 s: APP: Run ... !!!
    [MCU2_1]     18.331914 s: IPC: Starting echo test ...
    [MCU2_1]     18.332066 s: APP: Run ... Done !!!
    [MCU2_1]     18.333050 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]     18.333155 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]     18.333225 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]     18.333292 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]     18.333359 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU2_1]     18.333424 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU2_1]     18.333487 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]     18.356124 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]     18.358011 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]      4.510858 s: CIO: Init ... Done !!!
    [MCU3_0]      4.510912 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_0]      4.510938 s: CPU is running FreeRTOS
    [MCU3_0]      4.510955 s: APP: Init ... !!!
    [MCU3_0]      4.510984 s: SCICLIENT: Init ... !!!
    [MCU3_0]      4.511097 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU3_0]      4.511126 s: SCICLIENT: DMSC FW revision 0xa
    [MCU3_0]      4.511146 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU3_0]      4.511167 s: SCICLIENT: Init ... Done !!!
    [MCU3_0]      4.511185 s: MEM: Init ... !!!
    [MCU3_0]      4.511206 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bc000000 of size 8388608 bytes !!!
    [MCU3_0]      4.511248 s: MEM: Init ... Done !!!
    [MCU3_0]      4.511265 s: IPC: Init ... !!!
    [MCU3_0]      4.511296 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_0]      4.511324 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_0]     18.196691 s: IPC: HLOS is ready !!!
    [MCU3_0]     18.203298 s: IPC: Init ... Done !!!
    [MCU3_0]     18.203337 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_0]     18.317781 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU3_0]     18.317809 s: REMOTE_SERVICE: Init ... !!!
    [MCU3_0]     18.318276 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU3_0]     18.318358 s:  VX_ZONE_INIT:Enabled
    [MCU3_0]     18.318376 s:  VX_ZONE_ERROR:Enabled
    [MCU3_0]     18.318393 s:  VX_ZONE_WARNING:Enabled
    [MCU3_0]     18.319623 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU3-0
    [MCU3_0]     18.319664 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU3_0]     18.319689 s: APP: OpenVX Target kernel init ... !!!
    [MCU3_0]     18.319709 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU3_0]     18.319729 s: APP: Init ... Done !!!
    [MCU3_0]     18.319753 s: APP: Run ... !!!
    [MCU3_0]     18.319768 s: IPC: Starting echo test ...
    [MCU3_0]     18.319929 s: APP: Run ... Done !!!
    [MCU3_0]     18.320641 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_0]     18.320856 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_0]     18.320926 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_0]     18.323087 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[.]
    [MCU3_0]     18.323213 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[P]
    [MCU3_0]     18.323817 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]     18.332502 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]     18.356077 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]     18.358026 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]      4.637557 s: CIO: Init ... Done !!!
    [MCU3_1]      4.637612 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_1]      4.637637 s: CPU is running FreeRTOS
    [MCU3_1]      4.637654 s: APP: Init ... !!!
    [MCU3_1]      4.637682 s: SCICLIENT: Init ... !!!
    [MCU3_1]      4.637796 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU3_1]      4.637825 s: SCICLIENT: DMSC FW revision 0xa
    [MCU3_1]      4.637845 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU3_1]      4.637866 s: SCICLIENT: Init ... Done !!!
    [MCU3_1]      4.637884 s: MEM: Init ... !!!
    [MCU3_1]      4.637906 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bc800000 of size 8388608 bytes !!!
    [MCU3_1]      4.637951 s: MEM: Init ... Done !!!
    [MCU3_1]      4.637968 s: IPC: Init ... !!!
    [MCU3_1]      4.637998 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_1]      4.638028 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_1]     18.281069 s: IPC: HLOS is ready !!!
    [MCU3_1]     18.287380 s: IPC: Init ... Done !!!
    [MCU3_1]     18.287421 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_1]     18.317782 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU3_1]     18.317810 s: REMOTE_SERVICE: Init ... !!!
    [MCU3_1]     18.318337 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU3_1]     18.318386 s:  VX_ZONE_INIT:Enabled
    [MCU3_1]     18.318404 s:  VX_ZONE_ERROR:Enabled
    [MCU3_1]     18.318422 s:  VX_ZONE_WARNING:Enabled
    [MCU3_1]     18.319663 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU3-1
    [MCU3_1]     18.319706 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU3_1]     18.319731 s: APP: OpenVX Target kernel init ... !!!
    [MCU3_1]     18.319752 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU3_1]     18.319773 s: APP: Init ... Done !!!
    [MCU3_1]     18.319791 s: APP: Run ... !!!
    [MCU3_1]     18.319807 s: IPC: Starting echo test ...
    [MCU3_1]     18.320026 s: APP: Run ... Done !!!
    [MCU3_1]     18.320668 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_1]     18.320860 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_1]     18.321013 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_1]     18.323122 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[.]
    [MCU3_1]     18.323199 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[P]
    [MCU3_1]     18.323825 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]     18.332521 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]     18.356107 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]     18.358034 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_0]      4.780862 s: CIO: Init ... Done !!!
    [MCU4_0]      4.780916 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_0]      4.780942 s: CPU is running FreeRTOS
    [MCU4_0]      4.780960 s: APP: Init ... !!!
    [MCU4_0]      4.780997 s: SCICLIENT: Init ... !!!
    [MCU4_0]      4.781110 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU4_0]      4.781139 s: SCICLIENT: DMSC FW revision 0xa
    [MCU4_0]      4.781161 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU4_0]      4.781183 s: SCICLIENT: Init ... Done !!!
    [MCU4_0]      4.781203 s: UDMA: Init ... !!!
    [MCU4_0]      4.782091 s: UDMA: Init ... Done !!!
    [MCU4_0]      4.782125 s: MEM: Init ... !!!
    [MCU4_0]      4.782152 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bd000000 of size 6291456 bytes !!!
    [MCU4_0]      4.782204 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ bd600000 of size 2097152 bytes !!!
    [MCU4_0]      4.782244 s: MEM: Init ... Done !!!
    [MCU4_0]      4.782263 s: IPC: Init ... !!!
    [MCU4_0]      4.782301 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_0]      4.782333 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_0]     18.310014 s: IPC: HLOS is ready !!!
    [MCU4_0]     18.316236 s: IPC: Init ... Done !!!
    [MCU4_0]     18.316275 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_0]     18.317780 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU4_0]     18.317808 s: REMOTE_SERVICE: Init ... !!!
    [MCU4_0]     18.318354 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU4_0]     18.318389 s: FVID2: Init ... !!!
    [MCU4_0]     18.318427 s: FVID2: Init ... Done !!!
    [MCU4_0]     18.318448 s: VHWA: VPAC Init ... !!!
    [MCU4_0]     18.318466 s: SCICLIENT: Sciclient_pmSetModuleState module=400 state=2
    [MCU4_0]     18.318664 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU4_0]     18.318690 s: VHWA: LDC Init ... !!!
    [MCU4_0]     18.324015 s: VHWA: LDC Init ... Done !!!
    [MCU4_0]     18.324050 s: VHWA: MSC Init ... !!!
    [MCU4_0]     18.335517 s: VHWA: MSC Init ... Done !!!
    [MCU4_0]     18.335550 s: VHWA: NF Init ... !!!
    [MCU4_0]     18.336890 s: VHWA: NF Init ... Done !!!
    [MCU4_0]     18.336916 s: VHWA: VISS Init ... !!!
    [MCU4_0]     18.345707 s: VHWA: VISS Init ... Done !!!
    [MCU4_0]     18.345747 s: VHWA: VPAC Init ... Done !!!
    [MCU4_0]     18.345780 s:  VX_ZONE_INIT:Enabled
    [MCU4_0]     18.345801 s:  VX_ZONE_ERROR:Enabled
    [MCU4_0]     18.345820 s:  VX_ZONE_WARNING:Enabled
    [MCU4_0]     18.347005 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU4-0
    [MCU4_0]     18.347109 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_NF
    [MCU4_0]     18.347191 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_LDC1
    [MCU4_0]     18.347283 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_MSC1
    [MCU4_0]     18.347372 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_MSC2
    [MCU4_0]     18.347512 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_VISS1
    [MCU4_0]     18.347552 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU4_0]     18.347577 s: APP: OpenVX Target kernel init ... !!!
    [MCU4_0]     18.354330 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU4_0]     18.354363 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU4_0]     18.354413 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU4_0]     18.354437 s: UDMA Copy: Init ... !!!
    [MCU4_0]     18.355372 s: UDMA Copy: Init ... Done !!!
    [MCU4_0]     18.355409 s: APP: Init ... Done !!!
    [MCU4_0]     18.355429 s: APP: Run ... !!!
    [MCU4_0]     18.355448 s: IPC: Starting echo test ...
    [MCU4_0]     18.355612 s: APP: Run ... Done !!!
    [MCU4_0]     18.356710 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[.] mcu3_1[.] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]     18.356792 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[.] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]     18.356860 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[.] mcu4_0[s] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]     18.356928 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]     18.356992 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]     18.357058 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU4_0]     18.357123 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU4_0]     18.357187 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_0]     18.358043 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]      4.897399 s: CIO: Init ... Done !!!
    [MCU4_1]      4.897457 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_1]      4.897487 s: CPU is running FreeRTOS
    [MCU4_1]      4.897504 s: APP: Init ... !!!
    [MCU4_1]      4.897533 s: SCICLIENT: Init ... !!!
    [MCU4_1]      4.897648 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU4_1]      4.897678 s: SCICLIENT: DMSC FW revision 0xa
    [MCU4_1]      4.897698 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU4_1]      4.897720 s: SCICLIENT: Init ... Done !!!
    [MCU4_1]      4.897738 s: MEM: Init ... !!!
    [MCU4_1]      4.897761 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bd800000 of size 8388608 bytes !!!
    [MCU4_1]      4.897804 s: MEM: Init ... Done !!!
    [MCU4_1]      4.897821 s: IPC: Init ... !!!
    [MCU4_1]      4.897852 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_1]      4.897884 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_1]     18.311518 s: IPC: HLOS is ready !!!
    [MCU4_1]     18.317707 s: IPC: Init ... Done !!!
    [MCU4_1]     18.317748 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_1]     18.317782 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU4_1]     18.317806 s: REMOTE_SERVICE: Init ... !!!
    [MCU4_1]     18.318371 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU4_1]     18.318415 s:  VX_ZONE_INIT:Enabled
    [MCU4_1]     18.318434 s:  VX_ZONE_ERROR:Enabled
    [MCU4_1]     18.318452 s:  VX_ZONE_WARNING:Enabled
    [MCU4_1]     18.319687 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU4-1
    [MCU4_1]     18.319725 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU4_1]     18.319749 s: APP: OpenVX Target kernel init ... !!!
    [MCU4_1]     18.319769 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU4_1]     18.319790 s: APP: Init ... Done !!!
    [MCU4_1]     18.319809 s: APP: Run ... !!!
    [MCU4_1]     18.319824 s: IPC: Starting echo test ...
    [MCU4_1]     18.320037 s: APP: Run ... Done !!!
    [MCU4_1]     18.320629 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU4_1]     18.320847 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU4_1]     18.320917 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU4_1]     18.323133 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[.]
    [MCU4_1]     18.323213 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[P]
    [MCU4_1]     18.323850 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]     18.332531 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]     18.356115 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]     18.358050 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]      5.153918 s: CIO: Init ... Done !!!
    [C7x_1 ]      5.153934 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]      5.153946 s: CPU is running FreeRTOS
    [C7x_1 ]      5.153956 s: APP: Init ... !!!
    [C7x_1 ]      5.153965 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      5.154071 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_1 ]      5.154085 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_1 ]      5.154096 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_1 ]      5.154108 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      5.154118 s: UDMA: Init ... !!!
    [C7x_1 ]      5.154975 s: UDMA: Init ... Done !!!
    [C7x_1 ]      5.154986 s: MEM: Init ... !!!
    [C7x_1 ]      5.154999 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 108000000 of size 134217728 bytes !!!
    [C7x_1 ]      5.155021 s: MEM: Init ... Done !!!
    [C7x_1 ]      5.155031 s: IPC: Init ... !!!
    [C7x_1 ]      5.155046 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_1 ]      5.155062 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     17.331311 s: IPC: HLOS is ready !!!
    [C7x_1 ]     17.335110 s: IPC: Init ... Done !!!
    [C7x_1 ]     17.335127 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_1 ]     18.317785 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_1 ]     18.317804 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]     18.317977 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]     18.318003 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]     18.318043 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]     18.318060 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]     18.318449 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1
    [C7x_1 ]     18.318518 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_2
    [C7x_1 ]     18.318586 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_3
    [C7x_1 ]     18.318655 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_4
    [C7x_1 ]     18.318725 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_5
    [C7x_1 ]     18.318795 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_6
    [C7x_1 ]     18.318878 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_7
    [C7x_1 ]     18.318957 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_8
    [C7x_1 ]     18.318984 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_1 ]     18.318999 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]     18.319670 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]     18.319685 s: APP: Init ... Done !!!
    [C7x_1 ]     18.319695 s: APP: Run ... !!!
    [C7x_1 ]     18.319705 s: IPC: Starting echo test ...
    [C7x_1 ]     18.319875 s: APP: Run ... Done !!!
    [C7x_1 ]     18.320632 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[s] c7x_2[x] c7x_3[x] c7x_4[x]
    [C7x_1 ]     18.320679 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[s] c7x_2[x] c7x_3[x] c7x_4[x]
    [C7x_1 ]     18.320797 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[x] c7x_3[x] c7x_4[x]
    [C7x_1 ]     18.323127 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[x] c7x_3[P] c7x_4[.]
    [C7x_1 ]     18.323187 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[x] c7x_3[P] c7x_4[P]
    [C7x_1 ]     18.323848 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]     18.332539 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]     18.356131 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]     18.358057 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_2 ]      5.356453 s: CIO: Init ... Done !!!
    [C7x_2 ]      5.356470 s: ### CPU Frequency = 1000000000 Hz
    [C7x_2 ]      5.356482 s: CPU is running FreeRTOS
    [C7x_2 ]      5.356491 s: APP: Init ... !!!
    [C7x_2 ]      5.356500 s: SCICLIENT: Init ... !!!
    [C7x_2 ]      5.356604 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_2 ]      5.356618 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_2 ]      5.356630 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_2 ]      5.356642 s: SCICLIENT: Init ... Done !!!
    [C7x_2 ]      5.356652 s: UDMA: Init ... !!!
    [C7x_2 ]      5.357520 s: UDMA: Init ... Done !!!
    [C7x_2 ]      5.357532 s: MEM: Init ... !!!
    [C7x_2 ]      5.357545 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 108000000 of size 134217728 bytes !!!
    [C7x_2 ]      5.357567 s: MEM: Init ... Done !!!
    [C7x_2 ]      5.357576 s: IPC: Init ... !!!
    [C7x_2 ]      5.357591 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_2 ]      5.357607 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_2 ]     17.581778 s: IPC: HLOS is ready !!!
    [C7x_2 ]     17.585641 s: IPC: Init ... Done !!!
    [C7x_2 ]     17.585657 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_2 ]     18.317785 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_2 ]     18.317806 s: REMOTE_SERVICE: Init ... !!!
    [C7x_2 ]     18.317987 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_2 ]     18.318010 s:  VX_ZONE_INIT:Enabled
    [C7x_2 ]     18.318021 s:  VX_ZONE_ERROR:Enabled
    [C7x_2 ]     18.318032 s:  VX_ZONE_WARNING:Enabled
    [C7x_2 ]     18.318893 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2
    [C7x_2 ]     18.318972 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_2
    [C7x_2 ]     18.319041 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_3
    [C7x_2 ]     18.319110 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_4
    [C7x_2 ]     18.319177 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_5
    [C7x_2 ]     18.319245 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_6
    [C7x_2 ]     18.319310 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_7
    [C7x_2 ]     18.319377 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_8
    [C7x_2 ]     18.319409 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_2 ]     18.319424 s: APP: OpenVX Target kernel init ... !!!
    [C7x_2 ]     18.320670 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_2 ]     18.320687 s: UDMA Copy: Init ... !!!
    [C7x_2 ]     18.323118 s: UDMA Copy: Init ... Done !!!
    [C7x_2 ]     18.323135 s: APP: Init ... Done !!!
    [C7x_2 ]     18.323146 s: APP: Run ... !!!
    [C7x_2 ]     18.323156 s: IPC: Starting echo test ...
    [C7x_2 ]     18.323307 s: APP: Run ... Done !!!
    [C7x_2 ]     18.323982 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[.] c7x_4[.]
    [C7x_2 ]     18.324031 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[.] c7x_4[.]
    [C7x_2 ]     18.324074 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[.] c7x_4[.]
    [C7x_2 ]     18.324118 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[.]
    [C7x_2 ]     18.324162 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]     18.324205 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]     18.332549 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]     18.356137 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]     18.358067 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_3 ]      5.561247 s: CIO: Init ... Done !!!
    [C7x_3 ]      5.561263 s: ### CPU Frequency = 1000000000 Hz
    [C7x_3 ]      5.561276 s: CPU is running FreeRTOS
    [C7x_3 ]      5.561285 s: APP: Init ... !!!
    [C7x_3 ]      5.561294 s: SCICLIENT: Init ... !!!
    [C7x_3 ]      5.561397 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_3 ]      5.561412 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_3 ]      5.561423 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_3 ]      5.561436 s: SCICLIENT: Init ... Done !!!
    [C7x_3 ]      5.561446 s: UDMA: Init ... !!!
    [C7x_3 ]      5.562321 s: UDMA: Init ... Done !!!
    [C7x_3 ]      5.562333 s: MEM: Init ... !!!
    [C7x_3 ]      5.562345 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 108000000 of size 134217728 bytes !!!
    [C7x_3 ]      5.562367 s: MEM: Init ... Done !!!
    [C7x_3 ]      5.562376 s: IPC: Init ... !!!
    [C7x_3 ]      5.562391 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_3 ]      5.562406 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_3 ]     17.645765 s: IPC: HLOS is ready !!!
    [C7x_3 ]     17.649612 s: IPC: Init ... Done !!!
    [C7x_3 ]     17.649629 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_3 ]     18.317784 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_3 ]     18.317804 s: REMOTE_SERVICE: Init ... !!!
    [C7x_3 ]     18.317987 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_3 ]     18.318012 s:  VX_ZONE_INIT:Enabled
    [C7x_3 ]     18.318023 s:  VX_ZONE_ERROR:Enabled
    [C7x_3 ]     18.318035 s:  VX_ZONE_WARNING:Enabled
    [C7x_3 ]     18.318473 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3
    [C7x_3 ]     18.318553 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_2
    [C7x_3 ]     18.318625 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_3
    [C7x_3 ]     18.318700 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_4
    [C7x_3 ]     18.318778 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_5
    [C7x_3 ]     18.318861 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_6
    [C7x_3 ]     18.318936 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_7
    [C7x_3 ]     18.319016 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_8
    [C7x_3 ]     18.319041 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_3 ]     18.319056 s: APP: OpenVX Target kernel init ... !!!
    [C7x_3 ]     18.319712 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_3 ]     18.319729 s: UDMA Copy: Init ... !!!
    [C7x_3 ]     18.322313 s: UDMA Copy: Init ... Done !!!
    [C7x_3 ]     18.322329 s: APP: Init ... Done !!!
    [C7x_3 ]     18.322340 s: APP: Run ... !!!
    [C7x_3 ]     18.322350 s: IPC: Starting echo test ...
    [C7x_3 ]     18.322504 s: APP: Run ... Done !!!
    [C7x_3 ]     18.323132 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[x] c7x_3[s] c7x_4[.]
    [C7x_3 ]     18.323218 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[x] c7x_3[s] c7x_4[.]
    [C7x_3 ]     18.323268 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[.]
    [C7x_3 ]     18.323313 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[P]
    [C7x_3 ]     18.323380 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[P]
    [C7x_3 ]     18.323856 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]     18.332560 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]     18.356156 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]     18.358075 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_4 ]      5.765222 s: CIO: Init ... Done !!!
    [C7x_4 ]      5.765238 s: ### CPU Frequency = 1000000000 Hz
    [C7x_4 ]      5.765251 s: CPU is running FreeRTOS
    [C7x_4 ]      5.765260 s: APP: Init ... !!!
    [C7x_4 ]      5.765269 s: SCICLIENT: Init ... !!!
    [C7x_4 ]      5.765374 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_4 ]      5.765389 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_4 ]      5.765401 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_4 ]      5.765412 s: SCICLIENT: Init ... Done !!!
    [C7x_4 ]      5.765423 s: UDMA: Init ... !!!
    [C7x_4 ]      5.766288 s: UDMA: Init ... Done !!!
    [C7x_4 ]      5.766301 s: MEM: Init ... !!!
    [C7x_4 ]      5.766313 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 108000000 of size 134217728 bytes !!!
    [C7x_4 ]      5.766336 s: MEM: Init ... Done !!!
    [C7x_4 ]      5.766346 s: IPC: Init ... !!!
    [C7x_4 ]      5.766361 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_4 ]      5.766377 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_4 ]     17.693906 s: IPC: HLOS is ready !!!
    [C7x_4 ]     17.697532 s: IPC: Init ... Done !!!
    [C7x_4 ]     17.697549 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_4 ]     18.317785 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_4 ]     18.317806 s: REMOTE_SERVICE: Init ... !!!
    [C7x_4 ]     18.317984 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_4 ]     18.318009 s:  VX_ZONE_INIT:Enabled
    [C7x_4 ]     18.318022 s:  VX_ZONE_ERROR:Enabled
    [C7x_4 ]     18.318033 s:  VX_ZONE_WARNING:Enabled
    [C7x_4 ]     18.318478 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4
    [C7x_4 ]     18.318556 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_2
    [C7x_4 ]     18.318629 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_3
    [C7x_4 ]     18.318702 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_4
    [C7x_4 ]     18.318779 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_5
    [C7x_4 ]     18.318863 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_6
    [C7x_4 ]     18.318938 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_7
    [C7x_4 ]     18.319019 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_8
    [C7x_4 ]     18.319043 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_4 ]     18.319058 s: APP: OpenVX Target kernel init ... !!!
    [C7x_4 ]     18.319716 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_4 ]     18.319734 s: UDMA Copy: Init ... !!!
    [C7x_4 ]     18.322372 s: UDMA Copy: Init ... Done !!!
    [C7x_4 ]     18.322388 s: APP: Init ... Done !!!
    [C7x_4 ]     18.322399 s: APP: Run ... !!!
    [C7x_4 ]     18.322408 s: IPC: Starting echo test ...
    [C7x_4 ]     18.322566 s: APP: Run ... Done !!!
    [C7x_4 ]     18.323214 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]     18.323265 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]     18.323311 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]     18.323371 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]     18.323452 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[s]
    [C7x_4 ]     18.323860 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]     18.332571 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]     18.356151 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]     18.358081 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
  • It seems that the problem is in vxWaitGraph(graph->tiovx_graph) or vxGraphParameterDequeueDoneRef functions in edgeai-tiovx-apps/modules/core/src/tiovx_modules.c source file. Is there any way to debug this function?
    Our expert is currently out of the office on the Thanksgiving holiday; please expect a delay in response until next week.
    Thanks.
  • Hi Andre,
    Please run this script like below
    /opt/vx_app_arm_remote_log.out &
    Press enter after the log stops
    Then run the edgeai-tiovx-apps-test
    This will enable remote core logs and we will know
    if there are any errors in the remote core
    vxWaitGraph waits for response from the remote core
    MCU2_0 in this case
    Rahul T R
  • Hi Rahul,
    No new messages appeared:
    tiovx.log
    root@am69-b55:/opt/edgeai-gst-apps# /opt/vx_app_arm_remote_log.out &
    [1] 749
    root@am69-b55:/opt/edgeai-gst-apps# [MCU2_0]    169.442185 s: CIO: Init ... Done !!!
    [MCU2_0]    169.442235 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_0]    169.442260 s: CPU is running FreeRTOS
    [MCU2_0]    169.442276 s: APP: Init ... !!!
    [MCU2_0]    169.442309 s: SCICLIENT: Init ... !!!
    [MCU2_0]    169.442422 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU2_0]    169.442452 s: SCICLIENT: DMSC FW revision 0xa
    [MCU2_0]    169.442474 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU2_0]    169.442495 s: SCICLIENT: Init ... Done !!!
    [MCU2_0]    169.442514 s: UDMA: Init ... !!!
    [MCU2_0]    169.443381 s: UDMA: Init ... Done !!!
    [MCU2_0]    169.443412 s: UDMA: Init for CSITX/CSIRX ... !!!
    [MCU2_0]    169.443838 s: UDMA: Init for CSITX/CSIRX ... Done !!!
    [MCU2_0]    169.443870 s: MEM: Init ... !!!
    [MCU2_0]    169.443895 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bb000000 of size 6291456 bytes !!!
    [MCU2_0]    169.443940 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 60000000 of size 262144 bytes !!!
    [MCU2_0]    169.443979 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ bb600000 of size 2097152 bytes !!!
    [MCU2_0]    169.444017 s: MEM: Init ... Done !!!
    [MCU2_0]    169.444034 s: IPC: Init ... !!!
    [MCU2_0]    169.444072 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_0]    169.444103 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_0]    182.674733 s: IPC: HLOS is ready !!!
    [MCU2_0]    182.681769 s: IPC: Init ... Done !!!
    [MCU2_0]    182.681808 s: APP: Syncing with 10 CPUs ... !!!
    [MCU2_0]    183.634310 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU2_0]    183.634341 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_0]    183.634818 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_0]    183.634881 s: FVID2: Init ... !!!
    [MCU2_0]    183.634923 s: FVID2: Init ... Done !!!
    [MCU2_0]    183.634943 s: VHWA: VPAC Init ... !!!
    [MCU2_0]    183.634960 s: SCICLIENT: Sciclient_pmSetModuleState module=399 state=2
    [MCU2_0]    183.635077 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_0]    183.635102 s: VHWA: LDC Init ... !!!
    [MCU2_0]    183.640314 s: VHWA: LDC Init ... Done !!!
    [MCU2_0]    183.640356 s: VHWA: MSC Init ... !!!
    [MCU2_0]    183.651894 s: VHWA: MSC Init ... Done !!!
    [MCU2_0]    183.651928 s: VHWA: NF Init ... !!!
    [MCU2_0]    183.653213 s: VHWA: NF Init ... Done !!!
    [MCU2_0]    183.653238 s: VHWA: VISS Init ... !!!
    [MCU2_0]    183.662032 s: VHWA: VISS Init ... Done !!!
    [MCU2_0]    183.662078 s: VHWA: VPAC Init ... Done !!!
    [MCU2_0]    183.662116 s:  VX_ZONE_INIT:Enabled
    [MCU2_0]    183.662136 s:  VX_ZONE_ERROR:Enabled
    [MCU2_0]    183.662153 s:  VX_ZONE_WARNING:Enabled
    [MCU2_0]    183.663522 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU2-0
    [MCU2_0]    183.663621 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_NF
    [MCU2_0]    183.663706 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_LDC1
    [MCU2_0]    183.663786 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC1
    [MCU2_0]    183.663875 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC2
    [MCU2_0]    183.664017 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_VISS1
    [MCU2_0]    183.664128 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE1
    [MCU2_0]    183.664214 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE2
    [MCU2_0]    183.664303 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE3
    [MCU2_0]    183.664383 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE4
    [MCU2_0]    183.664460 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE5
    [MCU2_0]    183.664534 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE6
    [MCU2_0]    183.664610 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE7
    [MCU2_0]    183.664712 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE8
    [MCU2_0]    183.664794 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE9
    [MCU2_0]    183.664883 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE10
    [MCU2_0]    183.664987 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE11
    [MCU2_0]    183.665085 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CAPTURE12
    [MCU2_0]    183.665181 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DISPLAY1
    [MCU2_0]    183.665262 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DISPLAY2
    [MCU2_0]    183.665339 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CSITX
    [MCU2_0]    183.665438 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target CSITX2
    [MCU2_0]    183.665525 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M1
    [MCU2_0]    183.665617 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M2
    [MCU2_0]    183.665702 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M3
    [MCU2_0]    183.665780 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSS_M2M4
    [MCU2_0]    183.665817 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU2_0]    183.665841 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_0]    183.672889 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_0]    183.672926 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU2_0]    183.672989 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU2_0]    183.673011 s: UDMA Copy: Init ... !!!
    [MCU2_0]    183.673920 s: UDMA Copy: Init ... Done !!!
    [MCU2_0]    183.673953 s: APP: Init ... Done !!!
    [MCU2_0]    183.673972 s: APP: Run ... !!!
    [MCU2_0]    183.673988 s: IPC: Starting echo test ...
    [MCU2_0]    183.674179 s: APP: Run ... Done !!!
    [MCU2_0]    183.675334 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[.] mcu3_1[.] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    183.675414 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[.] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    183.675484 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[.] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    183.675551 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    183.675619 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    183.675686 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_0]    183.675754 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU2_0]    183.675819 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU2_0]    183.675884 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]    169.578117 s: CIO: Init ... Done !!!
    [MCU2_1]    169.578175 s: ### CPU Frequency = 1000000000 Hz
    [MCU2_1]    169.578203 s: CPU is running FreeRTOS
    [MCU2_1]    169.578220 s: APP: Init ... !!!
    [MCU2_1]    169.578255 s: SCICLIENT: Init ... !!!
    [MCU2_1]    169.578369 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU2_1]    169.578398 s: SCICLIENT: DMSC FW revision 0xa
    [MCU2_1]    169.578418 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU2_1]    169.578440 s: SCICLIENT: Init ... Done !!!
    [MCU2_1]    169.578458 s: UDMA: Init ... !!!
    [MCU2_1]    169.579331 s: UDMA: Init ... Done !!!
    [MCU2_1]    169.579364 s: MEM: Init ... !!!
    [MCU2_1]    169.579390 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bb800000 of size 8388608 bytes !!!
    [MCU2_1]    169.579433 s: MEM: Init ... Done !!!
    [MCU2_1]    169.579452 s: IPC: Init ... !!!
    [MCU2_1]    169.579485 s: IPC: 11 CPUs participating in IPC !!!
    [MCU2_1]    169.579513 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU2_1]    182.745527 s: IPC: HLOS is ready !!!
    [MCU2_1]    182.752464 s: IPC: Init ... Done !!!
    [MCU2_1]    182.752510 s: APP: Syncing with 10 CPUs ... !!!
    [MCU2_1]    183.634307 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU2_1]    183.634342 s: REMOTE_SERVICE: Init ... !!!
    [MCU2_1]    183.634836 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU2_1]    183.634903 s: FVID2: Init ... !!!
    [MCU2_1]    183.634942 s: FVID2: Init ... Done !!!
    [MCU2_1]    183.634966 s: VHWA: DMPAC: Init ... !!!
    [MCU2_1]    183.634985 s: SCICLIENT: Sciclient_pmSetModuleState module=92 state=2
    [MCU2_1]    183.635137 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]    183.635161 s: SCICLIENT: Sciclient_pmSetModuleState module=96 state=2
    [MCU2_1]    183.635221 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU2_1]    183.635243 s: VHWA: DOF Init ... !!!
    [MCU2_1]    183.643662 s: VHWA: DOF Init ... Done !!!
    [MCU2_1]    183.643695 s: VHWA: SDE Init ... !!!
    [MCU2_1]    183.646702 s: VHWA: SDE Init ... Done !!!
    [MCU2_1]    183.646731 s: VHWA: DMPAC: Init ... Done !!!
    [MCU2_1]    183.646765 s:  VX_ZONE_INIT:Enabled
    [MCU2_1]    183.646788 s:  VX_ZONE_ERROR:Enabled
    [MCU2_1]    183.646809 s:  VX_ZONE_WARNING:Enabled
    [MCU2_1]    183.648177 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU2-1
    [MCU2_1]    183.648264 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DMPAC_SDE
    [MCU2_1]    183.648350 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DMPAC_DOF
    [MCU2_1]    183.648388 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU2_1]    183.648413 s: APP: OpenVX Target kernel init ... !!!
    [MCU2_1]    183.648562 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU2_1]    183.648589 s: APP: Init ... Done !!!
    [MCU2_1]    183.648610 s: APP: Run ... !!!
    [MCU2_1]    183.648626 s: IPC: Starting echo test ...
    [MCU2_1]    183.648775 s: APP: Run ... Done !!!
    [MCU2_1]    183.649777 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    183.649857 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    183.649926 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    183.649997 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU2_1]    183.650066 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU2_1]    183.650133 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU2_1]    183.650199 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]    183.672823 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU2_1]    183.674671 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    169.721352 s: CIO: Init ... Done !!!
    [MCU3_0]    169.721406 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_0]    169.721431 s: CPU is running FreeRTOS
    [MCU3_0]    169.721449 s: APP: Init ... !!!
    [MCU3_0]    169.721480 s: SCICLIENT: Init ... !!!
    [MCU3_0]    169.721598 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU3_0]    169.721629 s: SCICLIENT: DMSC FW revision 0xa
    [MCU3_0]    169.721650 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU3_0]    169.721672 s: SCICLIENT: Init ... Done !!!
    [MCU3_0]    169.721691 s: MEM: Init ... !!!
    [MCU3_0]    169.721715 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bc000000 of size 8388608 bytes !!!
    [MCU3_0]    169.721758 s: MEM: Init ... Done !!!
    [MCU3_0]    169.721775 s: IPC: Init ... !!!
    [MCU3_0]    169.721806 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_0]    169.721837 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_0]    182.819064 s: IPC: HLOS is ready !!!
    [MCU3_0]    182.825696 s: IPC: Init ... Done !!!
    [MCU3_0]    182.825740 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_0]    183.634306 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU3_0]    183.634339 s: REMOTE_SERVICE: Init ... !!!
    [MCU3_0]    183.634837 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU3_0]    183.634912 s:  VX_ZONE_INIT:Enabled
    [MCU3_0]    183.634932 s:  VX_ZONE_ERROR:Enabled
    [MCU3_0]    183.634950 s:  VX_ZONE_WARNING:Enabled
    [MCU3_0]    183.636204 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU3-0
    [MCU3_0]    183.636260 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU3_0]    183.636287 s: APP: OpenVX Target kernel init ... !!!
    [MCU3_0]    183.636308 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU3_0]    183.636330 s: APP: Init ... Done !!!
    [MCU3_0]    183.636348 s: APP: Run ... !!!
    [MCU3_0]    183.636363 s: IPC: Starting echo test ...
    [MCU3_0]    183.636577 s: APP: Run ... Done !!!
    [MCU3_0]    183.637089 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[.] mcu4_0[x] mcu4_1[x] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_0]    183.637442 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_0]    183.637515 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_0]    183.639656 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[.]
    [MCU3_0]    183.639758 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[P]
    [MCU3_0]    183.640350 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    183.649217 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    183.672788 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_0]    183.674688 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[s] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    169.865048 s: CIO: Init ... Done !!!
    [MCU3_1]    169.865105 s: ### CPU Frequency = 1000000000 Hz
    [MCU3_1]    169.865131 s: CPU is running FreeRTOS
    [MCU3_1]    169.865147 s: APP: Init ... !!!
    [MCU3_1]    169.865176 s: SCICLIENT: Init ... !!!
    [MCU3_1]    169.865290 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU3_1]    169.865320 s: SCICLIENT: DMSC FW revision 0xa
    [MCU3_1]    169.865340 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU3_1]    169.865362 s: SCICLIENT: Init ... Done !!!
    [MCU3_1]    169.865381 s: MEM: Init ... !!!
    [MCU3_1]    169.865403 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bc800000 of size 8388608 bytes !!!
    [MCU3_1]    169.865445 s: MEM: Init ... Done !!!
    [MCU3_1]    169.865463 s: IPC: Init ... !!!
    [MCU3_1]    169.865494 s: IPC: 11 CPUs participating in IPC !!!
    [MCU3_1]    169.865529 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU3_1]    182.939609 s: IPC: HLOS is ready !!!
    [MCU3_1]    182.946068 s: IPC: Init ... Done !!!
    [MCU3_1]    182.946109 s: APP: Syncing with 10 CPUs ... !!!
    [MCU3_1]    183.634305 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU3_1]    183.634333 s: REMOTE_SERVICE: Init ... !!!
    [MCU3_1]    183.634852 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU3_1]    183.634928 s:  VX_ZONE_INIT:Enabled
    [MCU3_1]    183.634949 s:  VX_ZONE_ERROR:Enabled
    [MCU3_1]    183.634967 s:  VX_ZONE_WARNING:Enabled
    [MCU3_1]    183.636216 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU3-1
    [MCU3_1]    183.636261 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU3_1]    183.636286 s: APP: OpenVX Target kernel init ... !!!
    [MCU3_1]    183.636306 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU3_1]    183.636329 s: APP: Init ... Done !!!
    [MCU3_1]    183.636347 s: APP: Run ... !!!
    [MCU3_1]    183.636363 s: IPC: Starting echo test ...
    [MCU3_1]    183.636572 s: APP: Run ... Done !!!
    [MCU3_1]    183.637242 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_1]    183.637450 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_1]    183.637522 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU3_1]    183.639658 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[.]
    [MCU3_1]    183.639735 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[P]
    [MCU3_1]    183.640359 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    183.649235 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    183.672805 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU3_1]    183.674697 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[s] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_0]    170.025507 s: CIO: Init ... Done !!!
    [MCU4_0]    170.025568 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_0]    170.025594 s: CPU is running FreeRTOS
    [MCU4_0]    170.025613 s: APP: Init ... !!!
    [MCU4_0]    170.025650 s: SCICLIENT: Init ... !!!
    [MCU4_0]    170.025769 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU4_0]    170.025800 s: SCICLIENT: DMSC FW revision 0xa
    [MCU4_0]    170.025822 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU4_0]    170.025845 s: SCICLIENT: Init ... Done !!!
    [MCU4_0]    170.025865 s: UDMA: Init ... !!!
    [MCU4_0]    170.026788 s: UDMA: Init ... Done !!!
    [MCU4_0]    170.026825 s: MEM: Init ... !!!
    [MCU4_0]    170.026855 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bd000000 of size 6291456 bytes !!!
    [MCU4_0]    170.026908 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ bd600000 of size 2097152 bytes !!!
    [MCU4_0]    170.026951 s: MEM: Init ... Done !!!
    [MCU4_0]    170.026969 s: IPC: Init ... !!!
    [MCU4_0]    170.027007 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_0]    170.027041 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_0]    183.133239 s: IPC: HLOS is ready !!!
    [MCU4_0]    183.139354 s: IPC: Init ... Done !!!
    [MCU4_0]    183.139399 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_0]    183.634309 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU4_0]    183.634337 s: REMOTE_SERVICE: Init ... !!!
    [MCU4_0]    183.634914 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU4_0]    183.634950 s: FVID2: Init ... !!!
    [MCU4_0]    183.634988 s: FVID2: Init ... Done !!!
    [MCU4_0]    183.635011 s: VHWA: VPAC Init ... !!!
    [MCU4_0]    183.635030 s: SCICLIENT: Sciclient_pmSetModuleState module=400 state=2
    [MCU4_0]    183.635191 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU4_0]    183.635219 s: VHWA: LDC Init ... !!!
    [MCU4_0]    183.640551 s: VHWA: LDC Init ... Done !!!
    [MCU4_0]    183.640588 s: VHWA: MSC Init ... !!!
    [MCU4_0]    183.652046 s: VHWA: MSC Init ... Done !!!
    [MCU4_0]    183.652078 s: VHWA: NF Init ... !!!
    [MCU4_0]    183.653369 s: VHWA: NF Init ... Done !!!
    [MCU4_0]    183.653396 s: VHWA: VISS Init ... !!!
    [MCU4_0]    183.662104 s: VHWA: VISS Init ... Done !!!
    [MCU4_0]    183.662144 s: VHWA: VPAC Init ... Done !!!
    [MCU4_0]    183.662181 s:  VX_ZONE_INIT:Enabled
    [MCU4_0]    183.662202 s:  VX_ZONE_ERROR:Enabled
    [MCU4_0]    183.662221 s:  VX_ZONE_WARNING:Enabled
    [MCU4_0]    183.663492 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU4-0
    [MCU4_0]    183.663585 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_NF
    [MCU4_0]    183.663668 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_LDC1
    [MCU4_0]    183.663752 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_MSC1
    [MCU4_0]    183.663842 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_MSC2
    [MCU4_0]    183.663993 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC2_VISS1
    [MCU4_0]    183.664032 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU4_0]    183.664058 s: APP: OpenVX Target kernel init ... !!!
    [MCU4_0]    183.670959 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU4_0]    183.670997 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU4_0]    183.671059 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU4_0]    183.671084 s: UDMA Copy: Init ... !!!
    [MCU4_0]    183.672018 s: UDMA Copy: Init ... Done !!!
    [MCU4_0]    183.672052 s: APP: Init ... Done !!!
    [MCU4_0]    183.672072 s: APP: Run ... !!!
    [MCU4_0]    183.672089 s: IPC: Starting echo test ...
    [MCU4_0]    183.672259 s: APP: Run ... Done !!!
    [MCU4_0]    183.673410 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[.] mcu3_1[.] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    183.673490 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[.] mcu3_1[P] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    183.673561 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[.] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    183.673629 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[.] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    183.673695 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[.] c7x_3[.] c7x_4[.]
    [MCU4_0]    183.673760 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[.] c7x_4[.]
    [MCU4_0]    183.673826 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[.]
    [MCU4_0]    183.673892 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_0]    183.674705 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[s] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    170.159036 s: CIO: Init ... Done !!!
    [MCU4_1]    170.159097 s: ### CPU Frequency = 1000000000 Hz
    [MCU4_1]    170.159124 s: CPU is running FreeRTOS
    [MCU4_1]    170.159142 s: APP: Init ... !!!
    [MCU4_1]    170.159176 s: SCICLIENT: Init ... !!!
    [MCU4_1]    170.159289 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [MCU4_1]    170.159320 s: SCICLIENT: DMSC FW revision 0xa
    [MCU4_1]    170.159340 s: SCICLIENT: DMSC FW ABI revision 4.0
    [MCU4_1]    170.159362 s: SCICLIENT: Init ... Done !!!
    [MCU4_1]    170.159381 s: MEM: Init ... !!!
    [MCU4_1]    170.159404 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ bd800000 of size 8388608 bytes !!!
    [MCU4_1]    170.159450 s: MEM: Init ... Done !!!
    [MCU4_1]    170.159467 s: IPC: Init ... !!!
    [MCU4_1]    170.159501 s: IPC: 11 CPUs participating in IPC !!!
    [MCU4_1]    170.159534 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU4_1]    183.628158 s: IPC: HLOS is ready !!!
    [MCU4_1]    183.634227 s: IPC: Init ... Done !!!
    [MCU4_1]    183.634273 s: APP: Syncing with 10 CPUs ... !!!
    [MCU4_1]    183.634307 s: APP: Syncing with 10 CPUs ... Done !!!
    [MCU4_1]    183.634332 s: REMOTE_SERVICE: Init ... !!!
    [MCU4_1]    183.634909 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU4_1]    183.634958 s:  VX_ZONE_INIT:Enabled
    [MCU4_1]    183.634980 s:  VX_ZONE_ERROR:Enabled
    [MCU4_1]    183.634997 s:  VX_ZONE_WARNING:Enabled
    [MCU4_1]    183.636256 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU4-1
    [MCU4_1]    183.636295 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [MCU4_1]    183.636322 s: APP: OpenVX Target kernel init ... !!!
    [MCU4_1]    183.636345 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU4_1]    183.636367 s: APP: Init ... Done !!!
    [MCU4_1]    183.636386 s: APP: Run ... !!!
    [MCU4_1]    183.636402 s: IPC: Starting echo test ...
    [MCU4_1]    183.636609 s: APP: Run ... Done !!!
    [MCU4_1]    183.637113 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU4_1]    183.637450 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU4_1]    183.637526 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[x] c7x_4[x]
    [MCU4_1]    183.639666 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[.]
    [MCU4_1]    183.639745 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[P]
    [MCU4_1]    183.640384 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    183.649242 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    183.672816 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [MCU4_1]    183.674712 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[s] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    170.430018 s: CIO: Init ... Done !!!
    [C7x_1 ]    170.430035 s: ### CPU Frequency = 1000000000 Hz
    [C7x_1 ]    170.430048 s: CPU is running FreeRTOS
    [C7x_1 ]    170.430057 s: APP: Init ... !!!
    [C7x_1 ]    170.430066 s: SCICLIENT: Init ... !!!
    [C7x_1 ]    170.430171 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_1 ]    170.430186 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_1 ]    170.430197 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_1 ]    170.430210 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]    170.430220 s: UDMA: Init ... !!!
    [C7x_1 ]    170.431115 s: UDMA: Init ... Done !!!
    [C7x_1 ]    170.431128 s: MEM: Init ... !!!
    [C7x_1 ]    170.431140 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 108000000 of size 134217728 bytes !!!
    [C7x_1 ]    170.431162 s: MEM: Init ... Done !!!
    [C7x_1 ]    170.431171 s: IPC: Init ... !!!
    [C7x_1 ]    170.431185 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_1 ]    170.431201 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]    182.602306 s: IPC: HLOS is ready !!!
    [C7x_1 ]    182.606045 s: IPC: Init ... Done !!!
    [C7x_1 ]    182.606061 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_1 ]    183.634309 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_1 ]    183.634329 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]    183.634499 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]    183.634523 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]    183.634608 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]    183.634649 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]    183.634998 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1
    [C7x_1 ]    183.635064 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_2
    [C7x_1 ]    183.635132 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_3
    [C7x_1 ]    183.635201 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_4
    [C7x_1 ]    183.635271 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_5
    [C7x_1 ]    183.635339 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_6
    [C7x_1 ]    183.635410 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_7
    [C7x_1 ]    183.635484 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_8
    [C7x_1 ]    183.635511 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_1 ]    183.635526 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]    183.636211 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]    183.636229 s: APP: Init ... Done !!!
    [C7x_1 ]    183.636239 s: APP: Run ... !!!
    [C7x_1 ]    183.636250 s: IPC: Starting echo test ...
    [C7x_1 ]    183.636409 s: APP: Run ... Done !!!
    [C7x_1 ]    183.637254 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[s] c7x_2[x] c7x_3[x] c7x_4[x]
    [C7x_1 ]    183.637385 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[s] c7x_2[x] c7x_3[x] c7x_4[x]
    [C7x_1 ]    183.637430 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[x] c7x_3[x] c7x_4[x]
    [C7x_1 ]    183.639660 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[x] c7x_3[P] c7x_4[.]
    [C7x_1 ]    183.639719 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[x] c7x_3[P] c7x_4[P]
    [C7x_1 ]    183.640374 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    183.649252 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    183.672832 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_1 ]    183.674720 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[s] c7x_2[P] c7x_3[P] c7x_4[P]
    [C7x_2 ]    170.651245 s: CIO: Init ... Done !!!
    [C7x_2 ]    170.651261 s: ### CPU Frequency = 1000000000 Hz
    [C7x_2 ]    170.651274 s: CPU is running FreeRTOS
    [C7x_2 ]    170.651284 s: APP: Init ... !!!
    [C7x_2 ]    170.651293 s: SCICLIENT: Init ... !!!
    [C7x_2 ]    170.651397 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_2 ]    170.651412 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_2 ]    170.651423 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_2 ]    170.651436 s: SCICLIENT: Init ... Done !!!
    [C7x_2 ]    170.651446 s: UDMA: Init ... !!!
    [C7x_2 ]    170.652319 s: UDMA: Init ... Done !!!
    [C7x_2 ]    170.652332 s: MEM: Init ... !!!
    [C7x_2 ]    170.652345 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 108000000 of size 134217728 bytes !!!
    [C7x_2 ]    170.652368 s: MEM: Init ... Done !!!
    [C7x_2 ]    170.652377 s: IPC: Init ... !!!
    [C7x_2 ]    170.652392 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_2 ]    170.652408 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_2 ]    182.731955 s: IPC: HLOS is ready !!!
    [C7x_2 ]    182.735411 s: IPC: Init ... Done !!!
    [C7x_2 ]    182.735427 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_2 ]    183.634308 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_2 ]    183.634330 s: REMOTE_SERVICE: Init ... !!!
    [C7x_2 ]    183.634499 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_2 ]    183.634524 s:  VX_ZONE_INIT:Enabled
    [C7x_2 ]    183.634535 s:  VX_ZONE_ERROR:Enabled
    [C7x_2 ]    183.634631 s:  VX_ZONE_WARNING:Enabled
    [C7x_2 ]    183.635437 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2
    [C7x_2 ]    183.635514 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_2
    [C7x_2 ]    183.635587 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_3
    [C7x_2 ]    183.635652 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_4
    [C7x_2 ]    183.635717 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_5
    [C7x_2 ]    183.635784 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_6
    [C7x_2 ]    183.635847 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_7
    [C7x_2 ]    183.635912 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-2_PRI_8
    [C7x_2 ]    183.635937 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_2 ]    183.635951 s: APP: OpenVX Target kernel init ... !!!
    [C7x_2 ]    183.637218 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_2 ]    183.637236 s: UDMA Copy: Init ... !!!
    [C7x_2 ]    183.639651 s: UDMA Copy: Init ... Done !!!
    [C7x_2 ]    183.639668 s: APP: Init ... Done !!!
    [C7x_2 ]    183.639679 s: APP: Run ... !!!
    [C7x_2 ]    183.639689 s: IPC: Starting echo test ...
    [C7x_2 ]    183.639845 s: APP: Run ... Done !!!
    [C7x_2 ]    183.640490 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[.] c7x_4[.]
    [C7x_2 ]    183.640538 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[.] c7x_4[.]
    [C7x_2 ]    183.640581 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[.] c7x_4[.]
    [C7x_2 ]    183.640624 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[.]
    [C7x_2 ]    183.640667 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    183.640710 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    183.649259 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    183.672839 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_2 ]    183.674729 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[s] c7x_3[P] c7x_4[P]
    [C7x_3 ]    170.872601 s: CIO: Init ... Done !!!
    [C7x_3 ]    170.872617 s: ### CPU Frequency = 1000000000 Hz
    [C7x_3 ]    170.872630 s: CPU is running FreeRTOS
    [C7x_3 ]    170.872640 s: APP: Init ... !!!
    [C7x_3 ]    170.872649 s: SCICLIENT: Init ... !!!
    [C7x_3 ]    170.872758 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_3 ]    170.872773 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_3 ]    170.872785 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_3 ]    170.872797 s: SCICLIENT: Init ... Done !!!
    [C7x_3 ]    170.872808 s: UDMA: Init ... !!!
    [C7x_3 ]    170.873683 s: UDMA: Init ... Done !!!
    [C7x_3 ]    170.873695 s: MEM: Init ... !!!
    [C7x_3 ]    170.873707 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 108000000 of size 134217728 bytes !!!
    [C7x_3 ]    170.873730 s: MEM: Init ... Done !!!
    [C7x_3 ]    170.873740 s: IPC: Init ... !!!
    [C7x_3 ]    170.873756 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_3 ]    170.873772 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_3 ]    182.791609 s: IPC: HLOS is ready !!!
    [C7x_3 ]    182.794893 s: IPC: Init ... Done !!!
    [C7x_3 ]    182.794910 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_3 ]    183.634309 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_3 ]    183.634332 s: REMOTE_SERVICE: Init ... !!!
    [C7x_3 ]    183.634517 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_3 ]    183.634549 s:  VX_ZONE_INIT:Enabled
    [C7x_3 ]    183.634562 s:  VX_ZONE_ERROR:Enabled
    [C7x_3 ]    183.634573 s:  VX_ZONE_WARNING:Enabled
    [C7x_3 ]    183.635025 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3
    [C7x_3 ]    183.635106 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_2
    [C7x_3 ]    183.635180 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_3
    [C7x_3 ]    183.635254 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_4
    [C7x_3 ]    183.635328 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_5
    [C7x_3 ]    183.635404 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_6
    [C7x_3 ]    183.635478 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_7
    [C7x_3 ]    183.635562 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-3_PRI_8
    [C7x_3 ]    183.635588 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_3 ]    183.635602 s: APP: OpenVX Target kernel init ... !!!
    [C7x_3 ]    183.636247 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_3 ]    183.636261 s: UDMA Copy: Init ... !!!
    [C7x_3 ]    183.638850 s: UDMA Copy: Init ... Done !!!
    [C7x_3 ]    183.638868 s: APP: Init ... Done !!!
    [C7x_3 ]    183.638879 s: APP: Run ... !!!
    [C7x_3 ]    183.638888 s: IPC: Starting echo test ...
    [C7x_3 ]    183.639039 s: APP: Run ... Done !!!
    [C7x_3 ]    183.639671 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[x] c7x_3[s] c7x_4[.]
    [C7x_3 ]    183.639742 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[x] c7x_3[s] c7x_4[.]
    [C7x_3 ]    183.639802 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[.]
    [C7x_3 ]    183.639849 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[.] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[P]
    [C7x_3 ]    183.639894 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[s] c7x_4[P]
    [C7x_3 ]    183.640387 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    183.649269 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    183.672848 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_3 ]    183.674736 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[s] c7x_4[P]
    [C7x_4 ]    171.095265 s: CIO: Init ... Done !!!
    [C7x_4 ]    171.095281 s: ### CPU Frequency = 1000000000 Hz
    [C7x_4 ]    171.095294 s: CPU is running FreeRTOS
    [C7x_4 ]    171.095304 s: APP: Init ... !!!
    [C7x_4 ]    171.095313 s: SCICLIENT: Init ... !!!
    [C7x_4 ]    171.095420 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_4 ]    171.095434 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_4 ]    171.095445 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_4 ]    171.095457 s: SCICLIENT: Init ... Done !!!
    [C7x_4 ]    171.095468 s: UDMA: Init ... !!!
    [C7x_4 ]    171.096334 s: UDMA: Init ... Done !!!
    [C7x_4 ]    171.096346 s: MEM: Init ... !!!
    [C7x_4 ]    171.096360 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 108000000 of size 134217728 bytes !!!
    [C7x_4 ]    171.096381 s: MEM: Init ... Done !!!
    [C7x_4 ]    171.096392 s: IPC: Init ... !!!
    [C7x_4 ]    171.096407 s: IPC: 11 CPUs participating in IPC !!!
    [C7x_4 ]    171.096422 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_4 ]    182.932943 s: IPC: HLOS is ready !!!
    [C7x_4 ]    182.936148 s: IPC: Init ... Done !!!
    [C7x_4 ]    182.936165 s: APP: Syncing with 10 CPUs ... !!!
    [C7x_4 ]    183.634310 s: APP: Syncing with 10 CPUs ... Done !!!
    [C7x_4 ]    183.634331 s: REMOTE_SERVICE: Init ... !!!
    [C7x_4 ]    183.634525 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_4 ]    183.634551 s:  VX_ZONE_INIT:Enabled
    [C7x_4 ]    183.634564 s:  VX_ZONE_ERROR:Enabled
    [C7x_4 ]    183.634575 s:  VX_ZONE_WARNING:Enabled
    [C7x_4 ]    183.635027 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4
    [C7x_4 ]    183.635109 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_2
    [C7x_4 ]    183.635182 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_3
    [C7x_4 ]    183.635262 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_4
    [C7x_4 ]    183.635335 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_5
    [C7x_4 ]    183.635409 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_6
    [C7x_4 ]    183.635485 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_7
    [C7x_4 ]    183.635560 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-4_PRI_8
    [C7x_4 ]    183.635583 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_4 ]    183.635597 s: APP: OpenVX Target kernel init ... !!!
    [C7x_4 ]    183.636251 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_4 ]    183.636268 s: UDMA Copy: Init ... !!!
    [C7x_4 ]    183.638910 s: UDMA Copy: Init ... Done !!!
    [C7x_4 ]    183.638928 s: APP: Init ... Done !!!
    [C7x_4 ]    183.638939 s: APP: Run ... !!!
    [C7x_4 ]    183.638949 s: IPC: Starting echo test ...
    [C7x_4 ]    183.639103 s: APP: Run ... Done !!!
    [C7x_4 ]    183.639723 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[.] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]    183.639784 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[.] c7x_1[.] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]    183.639830 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[.] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]    183.639875 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[.] c7x_4[s]
    [C7x_4 ]    183.639994 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[x] c7x_3[P] c7x_4[s]
    [C7x_4 ]    183.640394 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    183.649276 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[x] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    183.672855 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    [C7x_4 ]    183.674745 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] mcu3_0[P] mcu3_1[P] mcu4_0[P] mcu4_1[P] c7x_1[P] c7x_2[P] c7x_3[P] c7x_4[s]
    root@am69-b55:/opt/edgeai-gst-apps# /usr/bin/edgeai-tiovx-apps-test
    APP: Init ... !!!
       273.824672 s: MEM: Init ... !!!
       273.824734 s: MEM: Initialized DMA HEAP (fd=5) !!!
       273.824876 s: MEM: Init ... Done !!!
       273.824890 s: IPC: Init ... !!!
       273.863185 s: IPC: Init ... Done !!!
       273.873319 s: GTC Frequency = 200 MHz
       273.874951 s:  VX_ZONE_INIT:Enabled
       273.874962 s:  VX_ZONE_ERROR:Enabled
       273.874969 s:  VX_ZONE_WARNING:Enabled
       273.876598 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:134] Added target MPU-0
       273.876712 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:134] Added target MPU-1
       273.876787 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:134] Added target MPU-2
       273.876856 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:134] Added target MPU-3
       273.876867 s:  VX_ZONE_INIT:[tivxInitLocal:127] Initialization Done !!!
       273.879032 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
    Running Multi Scaler module test
  • Hi Andre,
    Can you please run below IPC test, to make sure basic things are fine
    cd /opt/vision_apps
    source ./vision_apps_init.sh
    ./vx_app_arm_ipc.out
    Rahul T R
  • Hi Rahul,
    Problem is solved.
    For unknown reason  libtivision_apps.so.10.1.0 lib was generated instead of libtivision_apps.so.10.0.0. Previously I had newer recipe with 10.1.0 version of this lib, but after changing it to older one (10.0.0) - correct folder(10.0.0) was created with wrong library (10.1.0).  After deleting all downloaded sources and rebuilding from zero, edgeAI applications is working fine.
