Someting wrong occurs when custom boards boot up.Here is the relative logs:
Line 610: [ 6.882357] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found Line 612: [ 6.892199] vdec 30210000.video-codec: failed to get irq resource, falling back to polling Line 618: [ 6.941934] vdec 30210000.video-codec: Direct firmware load for cnm/wave521c_k3_codec_fw.bin failed with error -2 Line 619: [ 6.955095] vdec 30210000.video-codec: request_firmware, fail: -2 Line 622: [ 6.981074] vdec 30210000.video-codec: wave5_vpu_load_firmware, fail: -2 Line 623: [ 6.989768] vdec: probe of 30210000.video-codec failed with error -2
My dts is as follows:
// SPDX-License-Identifier: GPL-2.0 /* * AM62A SK: https://www.ti.com/lit/zip/sprr459 * * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ */ /dts-v1/; #include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/net/ti-dp83867.h> #include "k3-am62a7.dtsi" / { compatible = "ti,am62a7-sk", "ti,am62a7"; model = "Texas Instruments AM62A7 SK"; aliases { serial0 = &wkup_uart0; serial2 = &main_uart0; serial3 = &main_uart1; mmc0 = &sdhci0; mmc1 = &sdhci1; ethernet0 = &cpsw_port1; spi0 = &ospi0; rtc0 = &wkup_rtc0; rtc1 = &tps659312; }; chosen { stdout-path = "serial2:115200n8"; }; memory@80000000 { device_type = "memory"; /* 4G RAM */ reg = <0x00000000 0x80000000 0x00000000 0x80000000>, <0x00000008 0x80000000 0x00000000 0x80000000>; }; reserved-memory { #address-cells = <2>; #size-cells = <2>; ranges; /* global cma region */ linux,cma { compatible = "shared-dma-pool"; reusable; size = <0x00 0x24000000>; alloc-ranges = <0x00 0xc0000000 0x00 0x24000000>; linux,cma-default; }; secure_tfa_ddr: tfa@9e780000 { reg = <0x00 0x9e780000 0x00 0x80000>; alignment = <0x1000>; no-map; }; secure_ddr: optee@9e800000 { reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ alignment = <0x1000>; no-map; }; wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9c800000 { compatible = "shared-dma-pool"; reg = <0x00 0x9c800000 0x00 0x100000>; no-map; }; wkup_r5fss0_core0_memory_region: r5f-dma-memory@9c900000 { compatible = "shared-dma-pool"; reg = <0x00 0x9c900000 0x00 0x01e00000>; no-map; }; mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@9b800000 { compatible = "shared-dma-pool"; reg = <0x00 0x9b800000 0x00 0x100000>; no-map; }; mcu_r5fss0_core0_memory_region: r5f-dma-memory@9b900000 { compatible = "shared-dma-pool"; reg = <0x00 0x9b900000 0x00 0x0f00000>; no-map; }; c7x_0_dma_memory_region: c7x-dma-memory@99800000 { compatible = "shared-dma-pool"; reg = <0x00 0x99800000 0x00 0x100000>; no-map; }; c7x_0_memory_region: c7x-memory@99900000 { compatible = "shared-dma-pool"; reg = <0x00 0x99900000 0x00 0x01f00000>; no-map; }; edgeai_rtos_ipc_memory_region: edgeai-rtos-ipc-memory-region { reg = <0x00 0xa0000000 0x00 0x01000000>; no-map; }; edgeai_memory_region: edgeai-dma-memory@a1000000 { compatible = "shared-dma-pool"; reg = <0x00 0xa1000000 0x00 0x02000000>; no-map; }; edgeai_shared_region: edgeai_shared-memories { compatible = "dma-heap-carveout"; reg = <0x00 0xa3000000 0x00 0x0b000000>; }; edgeai_core_heaps: edgeai-core-heap-memory@ae000000 { compatible = "shared-dma-pool"; reg = <0x00 0xae000000 0x00 0x12000000>; no-map; }; }; opp-table { /* Add 1.4GHz OPP for am62p5-sk board. Requires VDD_CORE at 0v85 */ opp-1400000000 { opp-hz = /bits/ 64 <1400000000>; opp-supported-hw = <0x01 0x0004>; clock-latency-ns = <6000000>; }; }; vmain_pd: regulator-0 { /* TPS25750 PD CONTROLLER OUTPUT */ compatible = "regulator-fixed"; regulator-name = "vmain_pd"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; regulator-always-on; regulator-boot-on; }; vcc_5v0: regulator-1 { /* Output of TPS63070 */ compatible = "regulator-fixed"; regulator-name = "vcc_5v0"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; vin-supply = <&vmain_pd>; regulator-always-on; regulator-boot-on; }; vcc_3v3_main: regulator-2 { /* output of LM5141-Q1 */ compatible = "regulator-fixed"; regulator-name = "vcc_3v3_main"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; vin-supply = <&vmain_pd>; regulator-always-on; regulator-boot-on; }; vcc_3v3_sys: regulator-4 { /* output of TPS222965DSGT */ compatible = "regulator-fixed"; regulator-name = "vcc_3v3_sys"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; vin-supply = <&vcc_3v3_main>; regulator-always-on; regulator-boot-on; }; vddshv_sdio: regulator-5 { compatible = "regulator-gpio"; regulator-name = "vddshv_sdio"; pinctrl-names = "default"; pinctrl-0 = <&vddshv_sdio_pins_default>; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; regulator-boot-on; vin-supply = <&ldo1>; gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>; states = <1800000 0x0>, <3300000 0x1>; }; leds { compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <&usr_led_pins_default>; led-0 { label = "am62a-sk:green:heartbeat"; gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; function = LED_FUNCTION_HEARTBEAT; default-state = "off"; }; }; tlv320_mclk: clk-0 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <12288000>; }; codec_audio: sound { compatible = "simple-audio-card"; simple-audio-card,name = "AM62Ax-SKEVM"; simple-audio-card,widgets = "Headphone", "Headphone Jack", "Line", "Line In", "Microphone", "Microphone Jack"; simple-audio-card,routing = "Headphone Jack", "HPLOUT", "Headphone Jack", "HPROUT", "LINE1L", "Line In", "LINE1R", "Line In", "MIC3R", "Microphone Jack", "Microphone Jack", "Mic Bias"; simple-audio-card,format = "dsp_b"; simple-audio-card,bitclock-master = <&sound_master>; simple-audio-card,frame-master = <&sound_master>; simple-audio-card,bitclock-inversion; simple-audio-card,cpu { sound-dai = <&mcasp1>; }; sound_master: simple-audio-card,codec { sound-dai = <&tlv320aic3106>; clocks = <&tlv320_mclk>; }; }; }; &mcu_pmx0 { wkup_uart0_pins_default: wkup-uart0-default-pins { pinctrl-single,pins = < AM62AX_MCU_IOPAD(0x0024, PIN_INPUT, 0) /* (C9) WKUP_UART0_RXD */ AM62AX_MCU_IOPAD(0x0028, PIN_OUTPUT, 0) /* (E9) WKUP_UART0_TXD */ AM62AX_MCU_IOPAD(0x002c, PIN_INPUT, 0) /* (C10) WKUP_UART0_CTSn */ AM62AX_MCU_IOPAD(0x0030, PIN_OUTPUT, 0) /* (C8) WKUP_UART0_RTSn */ >; }; }; /* WKUP UART0 is used for DM firmware logs */ &wkup_uart0 { pinctrl-names = "default"; pinctrl-0 = <&wkup_uart0_pins_default>; status = "reserved"; }; &main_pmx0 { main_dss0_pins_default: main-dss0-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x100, PIN_OUTPUT, 0) /* (V17) VOUT0_VSYNC */ AM62AX_IOPAD(0x0f8, PIN_OUTPUT, 0) /* (T18) VOUT0_HSYNC */ AM62AX_IOPAD(0x104, PIN_OUTPUT, 0) /* (AA22) VOUT0_PCLK */ AM62AX_IOPAD(0x0fc, PIN_OUTPUT, 0) /* (U17) VOUT0_DE */ AM62AX_IOPAD(0x0b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */ AM62AX_IOPAD(0x0bc, PIN_OUTPUT, 0) /* (U21) VOUT0_DATA1 */ AM62AX_IOPAD(0x0c0, PIN_OUTPUT, 0) /* (U20) VOUT0_DATA2 */ AM62AX_IOPAD(0x0c4, PIN_OUTPUT, 0) /* (U19) VOUT0_DATA3 */ AM62AX_IOPAD(0x0c8, PIN_OUTPUT, 0) /* (T19) VOUT0_DATA4 */ AM62AX_IOPAD(0x0cc, PIN_OUTPUT, 0) /* (U18) VOUT0_DATA5 */ AM62AX_IOPAD(0x0d0, PIN_OUTPUT, 0) /* (V22) VOUT0_DATA6 */ AM62AX_IOPAD(0x0d4, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA7 */ AM62AX_IOPAD(0x0d8, PIN_OUTPUT, 0) /* (V19) VOUT0_DATA8 */ AM62AX_IOPAD(0x0dc, PIN_OUTPUT, 0) /* (V18) VOUT0_DATA9 */ AM62AX_IOPAD(0x0e0, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA10 */ AM62AX_IOPAD(0x0e4, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA11 */ AM62AX_IOPAD(0x0e8, PIN_OUTPUT, 0) /* (W20) VOUT0_DATA12 */ AM62AX_IOPAD(0x0ec, PIN_OUTPUT, 0) /* (W19) VOUT0_DATA13 */ AM62AX_IOPAD(0x0f0, PIN_OUTPUT, 0) /* (Y21) VOUT0_DATA14 */ AM62AX_IOPAD(0x0f4, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA15 */ AM62AX_IOPAD(0x05c, PIN_OUTPUT, 1) /* (P22) GPMC0_AD8.VOUT0_DATA16 */ AM62AX_IOPAD(0x060, PIN_OUTPUT, 1) /* (R19) GPMC0_AD9.VOUT0_DATA17 */ AM62AX_IOPAD(0x064, PIN_OUTPUT, 1) /* (R20) GPMC0_AD10.VOUT0_DATA18 */ AM62AX_IOPAD(0x068, PIN_OUTPUT, 1) /* (R22) GPMC0_AD11.VOUT0_DATA19 */ AM62AX_IOPAD(0x06c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */ AM62AX_IOPAD(0x070, PIN_OUTPUT, 1) /* (R21) GPMC0_AD13.VOUT0_DATA21 */ AM62AX_IOPAD(0x074, PIN_OUTPUT, 1) /* (T20) GPMC0_AD14.VOUT0_DATA22 */ AM62AX_IOPAD(0x078, PIN_OUTPUT, 1) /* (T21) GPMC0_AD15.VOUT0_DATA23 */ >; }; main_uart0_pins_default: main-uart0-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x1c8, PIN_INPUT, 0) /* (E14) UART0_RXD */ AM62AX_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (D15) UART0_TXD */ >; }; main_uart1_pins_default: main-uart1-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x01e8, PIN_INPUT, 1) /* (C17) I2C1_SCL.UART1_RXD */ AM62AX_IOPAD(0x01ec, PIN_OUTPUT, 1) /* (E17) I2C1_SDA.UART1_TXD */ AM62AX_IOPAD(0x0194, PIN_INPUT, 2) /* (C19) MCASP0_AXR3.UART1_CTSn */ AM62AX_IOPAD(0x0198, PIN_OUTPUT, 2) /* (B19) MCASP0_AXR2.UART1_RTSn */ >; }; main_i2c0_pins_default: main-i2c0-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */ AM62AX_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */ >; }; main_i2c1_pins_default: main-i2c1-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */ AM62AX_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */ AM62AX_IOPAD(0x08c, PIN_OUTPUT, 7) /* LT9211 reset_pin */ >; }; main_i2c2_pins_default: main-i2c2-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */ AM62AX_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */ AM62AX_IOPAD(0x16c, PIN_OUTPUT, 7) /* (MAX96714 Reset_Pin */ >; }; main_mmc0_pins_default: main-mmc0-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */ AM62AX_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLKLB */ AM62AX_IOPAD(0x21c, PIN_INPUT, 0) /* (AB1) MMC0_CLK */ AM62AX_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */ AM62AX_IOPAD(0x210, PIN_INPUT_PULLUP, 0) /* (AA1) MMC0_DAT1 */ AM62AX_IOPAD(0x20c, PIN_INPUT_PULLUP, 0) /* (AA3) MMC0_DAT2 */ AM62AX_IOPAD(0x208, PIN_INPUT_PULLUP, 0) /* (Y4) MMC0_DAT3 */ AM62AX_IOPAD(0x204, PIN_INPUT_PULLUP, 0) /* (AB2) MMC0_DAT4 */ AM62AX_IOPAD(0x200, PIN_INPUT_PULLUP, 0) /* (AC1) MMC0_DAT5 */ AM62AX_IOPAD(0x1fc, PIN_INPUT_PULLUP, 0) /* (AD2) MMC0_DAT6 */ AM62AX_IOPAD(0x1f8, PIN_INPUT_PULLUP, 0) /* (AC2) MMC0_DAT7 */ >; }; main_mmc1_pins_default: main-mmc1-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x23c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ AM62AX_IOPAD(0x234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ AM62AX_IOPAD(0x230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ AM62AX_IOPAD(0x22c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ AM62AX_IOPAD(0x228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ AM62AX_IOPAD(0x224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ AM62AX_IOPAD(0x240, PIN_INPUT, 0) /* (D17) MMC1_SDCD */ >; }; usr_led_pins_default: usr-led-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x244, PIN_OUTPUT, 7) /* (D18) MMC1_SDWP.GPIO1_49 */ >; }; main_usb0_pins_default: main-usb0-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x0254, PIN_OUTPUT, 0) /* (C20) USB0_DRVVBUS */ >; }; main_0_other_pins_default: main-0-other-default-pins { pinctrl-single,pins = < AM62X_IOPAD(0x170, PIN_INPUT, 7) /*GPIO0_90 TRIGGER1_IN*/ AM62X_IOPAD(0x164, PIN_OUTPUT, 7) /*GPIO0_87 PWR_EDLC_CTRL*/ >; }; main_1_other_pins_default: main-1-other-default-pins { pinctrl-single,pins = < AM62X_IOPAD(0x1dc, PIN_OUTPUT, 7) /*GPIO1_25 KEY_CTRL*/ AM62X_IOPAD(0x17c, PIN_OUTPUT, 7) /*GPIO1_1 PWR_ALARM_OUT*/ AM62X_IOPAD(0x1d4, PIN_INPUT, 7) /*GPIO1_23 KEY_INT*/ >; }; main_epwm0_default: main-epwm0-default { pinctrl-single,pins = < AM62X_IOPAD(0x1ac, PIN_OUTPUT, 6) >; }; main_epwm1_default: main-epwm1-default { pinctrl-single,pins = < AM62X_IOPAD(0x19c, PIN_OUTPUT, 6) >; }; main_usb1_pins_default: main-usb1-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */ >; }; main_mdio1_pins_default: main-mdio1-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x160, PIN_OUTPUT, 0) /* (V12) MDIO0_MDC */ AM62AX_IOPAD(0x15c, PIN_INPUT, 0) /* (V13) MDIO0_MDIO */ >; }; main_rgmii1_pins_default: main-rgmii1-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x14c, PIN_INPUT, 1) /* (AB16) RMII1_RD0 */ AM62AX_IOPAD(0x150, PIN_INPUT, 1) /* (V15) RMII1_RD1 */ AM62AX_IOPAD(0x148, PIN_INPUT, 1) /* (AA16) RMII1_RXC */ AM62AX_IOPAD(0x144, PIN_INPUT, 1) /* (AA15) RMII1_RX_CTL */ AM62AX_IOPAD(0x134, PIN_INPUT, 1) /* (Y17) RMII1_TD0 */ AM62AX_IOPAD(0x138, PIN_INPUT, 1) /* (V16) RMII1_TD1 */ AM62AX_IOPAD(0x130, PIN_INPUT, 1) /* (AB17) RMII1_TXC */ AM62AX_IOPAD(0x12c, PIN_INPUT, 1) /* (W16) RMII1_TX_CTL */ >; }; main_mcasp1_pins_default: main-mcasp1-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x090, PIN_INPUT, 2) /* (L19) GPMC0_BE0n_CLE.MCASP1_ACLKX */ AM62AX_IOPAD(0x098, PIN_INPUT, 2) /* (R18) GPMC0_WAIT0.MCASP1_AFSX */ AM62AX_IOPAD(0x08c, PIN_OUTPUT, 2) /* (K19) GPMC0_WEn.MCASP1_AXR0 */ AM62AX_IOPAD(0x084, PIN_INPUT, 2) /* (L18) GPMC0_ADVn_ALE.MCASP1_AXR2 */ >; }; main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x01d4, PIN_INPUT, 7) /* (C15) UART0_RTSn.GPIO1_23 */ >; }; vddshv_sdio_pins_default: vddshv-sdio-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x07c, PIN_OUTPUT, 7) /* (M19) GPMC0_CLK.GPIO0_31 */ >; }; ospi0_pins_default: ospi0-default-pins { pinctrl-single,pins = < AM62AX_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */ AM62AX_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */ AM62AX_IOPAD(0x00c, PIN_INPUT, 0) /* (E25) OSPI0_D0 */ AM62AX_IOPAD(0x010, PIN_INPUT, 0) /* (G24) OSPI0_D1 */ AM62AX_IOPAD(0x014, PIN_INPUT, 0) /* (F25) OSPI0_D2 */ AM62AX_IOPAD(0x018, PIN_INPUT, 0) /* (F24) OSPI0_D3 */ AM62AX_IOPAD(0x01c, PIN_INPUT, 0) /* (J23) OSPI0_D4 */ AM62AX_IOPAD(0x020, PIN_INPUT, 0) /* (J25) OSPI0_D5 */ AM62AX_IOPAD(0x024, PIN_INPUT, 0) /* (H25) OSPI0_D6 */ AM62AX_IOPAD(0x028, PIN_INPUT, 0) /* (J22) OSPI0_D7 */ AM62AX_IOPAD(0x008, PIN_INPUT, 0) /* (J24) OSPI0_DQS */ >; }; }; &mcu_pmx0 { status = "okay"; pmic_irq_pins_default: pmic-irq-default-pins { pinctrl-single,pins = < AM62AX_MCU_IOPAD(0x000, PIN_INPUT, 7) /* (E11) MCU_GPIO0_0 */ >; }; mcu_gpio_other_pins_default: mcu-gpio-other-default-pins { pinctrl-single,pins = < /*for test, acutual need driver?*/ AM62AX_MCU_IOPAD(0x03C, PIN_OUTPUT, 7) /* MCU_GPIO0_15 MCU_PWR_5V0_CTRL*/ AM62AX_MCU_IOPAD(0x004, PIN_INPUT, 7) /* MCU_GPIO0_1 MCU_TRIGGER2_ACC*/ AM62AX_MCU_IOPAD(0x040, PIN_OUTPUT, 7) /* MCU_GPIO0_16 */ AM62AX_MCU_IOPAD(0x010, PIN_INPUT, 7) /* MCU_GPIO0_4 MCU_MPQ8880_FAIL*/ >; }; }; &mcu_gpio0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&mcu_gpio_other_pins_default>; }; &main_i2c0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>; /* typec_pd0: usb-power-controller@3f { compatible = "ti,tps6598x"; reg = <0x3f>; connector { compatible = "usb-c-connector"; label = "USB-C"; self-powered; data-role = "dual"; power-role = "sink"; port { usb_con_hs: endpoint { remote-endpoint = <&usb0_hs_ep>; }; }; }; }; */ tps659312: pmic@48 { compatible = "ti,tps6593-q1"; reg = <0x48>; ti,primary-pmic; system-power-controller; gpio-controller; #gpio-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pmic_irq_pins_default>; interrupt-parent = <&mcu_gpio0>; interrupts = <0 IRQ_TYPE_EDGE_FALLING>; buck123-supply = <&vcc_3v3_sys>; buck4-supply = <&vcc_3v3_sys>; buck5-supply = <&vcc_3v3_sys>; ldo1-supply = <&vcc_3v3_sys>; ldo2-supply = <&vcc_3v3_sys>; ldo3-supply = <&buck5>; ldo4-supply = <&vcc_3v3_sys>; regulators { buck123: buck123 { regulator-name = "vcc_core"; regulator-min-microvolt = <715000>; regulator-max-microvolt = <895000>; regulator-boot-on; regulator-always-on; }; buck4: buck4 { regulator-name = "vcc_1v1"; regulator-min-microvolt = <1100000>; regulator-max-microvolt = <1100000>; regulator-boot-on; regulator-always-on; }; buck5: buck5 { regulator-name = "vcc_1v8_sys"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; }; ldo1: ldo1 { regulator-name = "vddshv5_sdio"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-boot-on; regulator-always-on; }; ldo2: ldo2 { regulator-name = "vpp_1v8"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; }; ldo3: ldo3 { regulator-name = "vcc_0v85"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <850000>; regulator-boot-on; regulator-always-on; }; ldo4: ldo4 { regulator-name = "vdda_1v8"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; }; }; }; }; &main_i2c1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <100000>; exp1: gpio@22 { compatible = "ti,tca6424"; reg = <0x22>; gpio-controller; #gpio-cells = <2>; interrupt-parent = <&main_gpio1>; interrupts = <23 IRQ_TYPE_EDGE_FALLING>; interrupt-controller; #interrupt-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>; gpio-line-names = "GPIO_CPSW2_RST", "GPIO_CPSW1_RST", "BT_EN_SOC", "MMC1_SD_EN", "VPP_EN", "EXP_PS_3V3_En", "EXP_PS_5V0_En", "EXP_HAT_DETECT", "GPIO_AUD_RSTn", "GPIO_eMMC_RSTn", "UART1_FET_BUF_EN", "BT_UART_WAKE_SOC", "GPIO_HDMI_RSTn", "CSI_GPIO0", "CSI_GPIO1", "WLAN_ALERTn", "HDMI_INTn", "TEST_GPIO2", "MCASP1_FET_EN", "MCASP1_BUF_BT_EN", "MCASP1_FET_SEL", "UART1_FET_SEL", "PD_I2C_IRQ", "IO_EXP_TEST_LED"; }; tlv320aic3106: audio-codec@1b { #sound-dai-cells = <0>; compatible = "ti,tlv320aic3106"; reg = <0x1b>; ai3x-micbias-vg = <1>; /* 2.0V */ /* Regulators */ AVDD-supply = <&vcc_3v3_sys>; IOVDD-supply = <&vcc_3v3_sys>; DRVDD-supply = <&vcc_3v3_sys>; DVDD-supply = <&buck5>; }; exp2: gpio@23 { compatible = "ti,tca6424"; reg = <0x23>; gpio-controller; #gpio-cells = <2>; gpio-line-names = "", "", "", "", "", "", "", "", "WL_LT_EN", "CSI_RSTz", "", "", "", "", "", "", "SPI0_FET_SEL", "SPI0_FET_OE", "RGMII2_BRD_CONN_DET", "CSI_SEL2", "CSI_EN", "AUTO_100M_1000M_CONFIG", "CSI_VLDO_SEL", "SoC_WLAN_SDIO_RST"; }; }; &main_i2c2 { #address-cells = <1>; #size-cells = <0>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c2_pins_default>; clock-frequency = <400000>; deserializer@2a { compatible = "maxim,max96714f"; #address-cells = <1>; #size-cells = <0>; reg = <0x2a>; powerdown-gpios = <&main_gpio0 89 GPIO_ACTIVE_LOW>; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; max96714_gmsl_in: endpoint { remote-endpoint = <&max96917f_gmsl_out>; }; }; port@1 { reg = <1>; max96714_csi_out: endpoint { data-lanes = <1 2 3 4>; link-frequencies = /bits/ 64 <500000000>; remote-endpoint = <&csi2_phy0>; }; }; }; serializer:serializer@40 { compatible = "maxim,max96717f"; #address-cells = <1>; #size-cells = <0>; #clock-cells = <0>; reg = <0x40>; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; max96717f_csi_in: endpoint { bus-type = <4>; data-lanes = <1 2 3 4>; remote-endpoint = <&sensor_out>; }; }; port@1 { reg = <1>; max96917f_gmsl_out: endpoint { remote-endpoint = <&max96714_gmsl_in>; }; }; }; camera: camera@36 { compatible = "ovti,ox03f10"; reg = <0x36>; clocks = <&serializer>; clock-names = "xvclk"; assigned-clocks = <&serializer>; assigned-clock-rates = <24000000>; // reset-gpios = <&serializer 2 GPIO_ACTIVE_HIGH>; port { sensor_out: endpoint { remote-endpoint = <&max96717f_csi_in>; }; }; }; }; }; hdmi-bridge@3b { compatible = "lontium,lt9211"; reg = <0x3b>; reset-gpios = <&main_gpio0 34 GPIO_ACTIVE_HIGH>; interrupt-parent = <&main_gpio_intr>; interrupts = <84 IRQ_TYPE_EDGE_FALLING>; /*vccio-supply = <<9211_1v8>;*/ ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; lt9211_in: endpoint { remote-endpoint = <&dpi1_out>; }; }; /* port@2 { reg = <2>; lt9211_out: endpoint { remote-endpoint = <&lvds_connector_in>; }; }; */ }; }; }; &cdns_csi2rx0 { ports { #address-cells = <1>; #size-cells = <0>; csi0_port0: port@0 { reg = <0>; status = "okay"; csi2_phy0: endpoint { remote-endpoint = <&max96714_csi_out>; clock-lanes = <0>; data-lanes = <1 2 3 4>; link-frequencies = /bits/ 64 <800000000>; }; }; }; }; &ti_csi2rx0 { status = "okay"; }; &dphy0 { status = "okay"; }; &sdhci0 { /* eMMC */ status = "okay"; non-removable; pinctrl-names = "default"; pinctrl-0 = <&main_mmc0_pins_default>; disable-wp; }; &sdhci1 { /* SD/MMC */ status = "okay"; vqmmc-supply = <&vddshv_sdio>; pinctrl-names = "default"; pinctrl-0 = <&main_mmc1_pins_default>; disable-wp; }; &main_gpio0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_0_other_pins_default>; }; &main_gpio1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_1_other_pins_default>; }; &main_gpio_intr { status = "okay"; }; &main_uart0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart0_pins_default>; interrupts-extended = <&gic500 GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>, <&main_pmx0 0x1c8>; /* (D14) UART0_RXD PADCONFIG114 */ interrupt-names = "irq", "wakeup"; }; /* Main UART1 is used for TIFS firmware logs */ &main_uart1 { pinctrl-names = "default"; pinctrl-0 = <&main_uart1_pins_default>; status = "reserved"; }; /* Main Timer2 is used by C7x DSP */ &main_timer2 { status = "reserved"; }; &usbss0 { status = "okay"; }; &usb0 { dr_mode = "host"; pinctrl-names = "default"; pinctrl-0 = <&main_usb0_pins_default>; }; &usbss1 { status = "okay"; }; &usb1 { dr_mode = "host"; pinctrl-names = "default"; pinctrl-0 = <&main_usb1_pins_default>; }; &epwm0 { pinctrl-names = "default"; pinctrl-0 = <&main_epwm0_default>; status = "okay"; }; &epwm1 { pinctrl-names = "default"; pinctrl-0 = <&main_epwm1_default>; status = "okay"; }; &cpsw3g { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_rgmii1_pins_default>; cpts@3d000 { /* MAP HW3_TS_PUSH to GENF1 */ ti,pps = <2 1>; }; }; &cpsw_port1 { status = "okay"; /*phy-mode = "rgmii-rxid";*/ phy-mode = "rmii"; phy-handle = <&cpsw3g_phy0>; }; &cpsw_port2 { status = "disabled"; }; &cpsw3g_mdio { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_mdio1_pins_default>; cpsw3g_phy0: ethernet-phy@0 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0>; reset-gpios = <&main_gpio1 0 GPIO_ACTIVE_LOW>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; ti,min-output-impedance; }; }; &mcasp1 { status = "okay"; #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&main_mcasp1_pins_default>; op-mode = <0>; /* MCASP_IIS_MODE */ tdm-slots = <2>; serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ 1 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 >; tx-num-evt = <0>; rx-num-evt = <0>; }; &dss { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_dss0_pins_default>; }; &dss_ports { /* VP2: DPI Output */ lvds_dss: port@1 { reg = <1>; dpi1_out: endpoint { remote-endpoint = <<9211_in>; }; }; }; &mailbox0_cluster0 { ti,mbox-num-fifos = <2>; mbox_r5_0: mbox-r5-0 { ti,mbox-rx = <0 0 0>; ti,mbox-tx = <1 0 0>; }; }; &mailbox0_cluster1 { ti,mbox-num-fifos = <2>; mbox_c7x_0: mbox-c7x-0 { ti,mbox-rx = <0 0 0>; ti,mbox-tx = <1 0 0>; }; }; &mailbox0_cluster2 { ti,mbox-num-fifos = <2>; mbox_mcu_r5_0: mbox-mcu-r5-0 { ti,mbox-rx = <0 0 0>; ti,mbox-tx = <1 0 0>; }; }; &c7x_0 { mboxes = <&mailbox0_cluster1>, <&mbox_c7x_0>; memory-region = <&c7x_0_dma_memory_region>, <&c7x_0_memory_region>; }; &wkup_r5fss0_core0 { mboxes = <&mailbox0_cluster0>, <&mbox_r5_0>; memory-region = <&wkup_r5fss0_core0_dma_memory_region>, <&wkup_r5fss0_core0_memory_region>; }; &mcu_r5fss0_core0 { mboxes = <&mailbox0_cluster2>, <&mbox_mcu_r5_0>; memory-region = <&mcu_r5fss0_core0_dma_memory_region>, <&mcu_r5fss0_core0_memory_region>; }; #define K3_TS_OFFSET(pa, val) (0x4+(pa)*4) (0x10000 | val) ×ync_router { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&cpsw_cpts>; /* Use Time Sync Router to map GENF1 input to HW3_TS_PUSH output */ cpsw_cpts: cpsw-cpts { pinctrl-single,pins = < /* pps [cpsw cpts genf1] in17 -> out12 [cpsw cpts hw3_push] */ K3_TS_OFFSET(12, 17) >; }; }; &fss { status = "okay"; }; &ospi0 { pinctrl-names = "default"; pinctrl-0 = <&ospi0_pins_default>; flash@0{ compatible = "spi-nand"; reg = <0x0>; spi-tx-bus-width = <8>; spi-rx-bus-width = <8>; spi-max-frequency = <25000000>; cdns,tshsl-ns = <60>; cdns,tsd2d-ns = <60>; cdns,tchsh-ns = <60>; cdns,tslch-ns = <60>; cdns,read-delay = <2>; partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; partition@0 { label = "ospi_nand.tiboot3"; reg = <0x0 0x80000>; }; partition@80000 { label = "ospi_nand.tispl"; reg = <0x80000 0x200000>; }; partition@280000 { label = "ospi_nand.u-boot"; reg = <0x280000 0x400000>; }; partition@680000 { label = "ospi_nand.env"; reg = <0x680000 0x40000>; }; partition@6c0000 { label = "ospi_nand.env.backup"; reg = <0x6c0000 0x40000>; }; partition@2000000 { label = "ospi_nand.rootfs"; reg = <0x2000000 0x5fc0000>; }; partition@7fc0000 { label = "ospi_nand.phypattern"; reg = <0x7fc0000 0x40000>; }; }; }; };
By the way, the SDK version is 10_00_00_08;
regards
twl
