AM625SIP: Plan for different RAM variations
Genius 3186 points
Part Number: AM625SIP
Other Parts Discussed in Thread: AM6252
May I have question about AM625SIP?
Do you have plan for another capacity of RAM? (such as 1GB, 2GB, 4GB)
I believe there is only 512MB RAM SIP, it often not enough for application use GPU.
GR
  • Hi GR,
    at this point we cannot share a timeline for the next updated Version. although we do have plans to add variants.
    do you have your requirements and EE clearly called out. Maybe if you can share more details about your requirements i will be able to help you better.
    regards
    Anshu
  • Hi Anshu,
    Thanks for your supporting.
    My customer want to use 2GByte or 4GByte RAM.
    If running Debian or Yocto-Linux that have many librarys, It require more than 1GByte RAM often for many application.
    And another customer say that Why only AM6254+512KB RAM?? if 512KB RAM, you should select silicon of AM6251 or AM6252.
    Because customer's application that select quad core A53 require more than 2GByte RAM in many case.
    GR
