AM62A7-Q1: VIDIOC_DQBUF failed in AM62A
Part Number: AM62A7-Q1
Hi Expert,
My customer encounters an issue about the V4L2 dqbuf failed I think, we find the error is report from below code, and it will work in sometimes, and will report this error sometimes, I can't real know what the mean is for this error log.
v4l2_capture_module.c
 * Copyright (c) 2024 Texas Instruments Incorporated
 * All rights reserved not granted herein.
 * Limited License.
 * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
 * license under copyrights and patents it now or hereafter owns or controls to make,
 * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
 * terms herein.  With respect to the foregoing patent license, such license is granted
 * solely to the extent that any such patent is necessary to Utilize the software alone.
 * The patent license shall not apply to any combinations which include this software,
 * other than combinations with devices manufactured by or for TI ("TI Devices").
 * No hardware patent is licensed hereunder.
 * Redistributions must preserve existing copyright notices and reproduce this license
 * (including the above copyright notice and the disclaimer and (if applicable) source
 * code license limitations below) in the documentation and/or other materials provided
 * with the distribution
 * Redistribution and use in binary form, without modification, are permitted provided
 * that the following conditions are met:
 * *       No reverse engineering, decompilation, or disassembly of this software is
 * permitted with respect to any software provided in binary form.
 * *       any redistribution and use are licensed by TI for use only with TI Devices.
 * *       Nothing shall obligate TI to provide you with source code for the software
 * licensed and provided to you in object code.
 * If software source code is provided to you, modification and redistribution of the
 * source code are permitted provided that the following conditions are met:
 * *       any redistribution and use of the source code, including any resulting derivative
 * works, are licensed by TI for use only with TI Devices.
 * *       any redistribution and use of any object code compiled from the source code
 * and any resulting derivative works, are licensed by TI for use only with TI Devices.
 * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
 * may be used to endorse or promote products derived from this software without
 * specific prior written permission.
 * DISCLAIMER.
 * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
 * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
 * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
 * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
 * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
 * OF THE POSSIBILITY OF SUCH DAMAGE.
#include "v4l2_capture_module.h"
#include "tiovx_utils.h"
#include <sys/ioctl.h>
#include <errno.h>
#include <stdlib.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#define V4L2_CAPTURE_DEFAULT_WIDTH 1920
#define V4L2_CAPTURE_DEFAULT_HEIGHT 1080
#define V4L2_CAPTURE_DEFAULT_PIX_FMT V4L2_PIX_FMT_SRGGB8
#define V4L2_CAPTURE_DEFAULT_DEVICE "/dev/video-imx219-cam0"
#define V4L2_CAPTURE_DEFAULT_BUFQ_DEPTH 4
#define V4L2_CAPTURE_MAX_BUFQ_DEPTH 8
#define V4L2_CAPTURE_MAX_RETRIES 10
#define V4L2_CAPTURE_STREAMON_DELAY 2 // in sec
void v4l2_capture_init_cfg(v4l2CaptureCfg *cfg)
    cfg->width = V4L2_CAPTURE_DEFAULT_WIDTH;
    cfg->height = V4L2_CAPTURE_DEFAULT_HEIGHT;
    cfg->pix_format = V4L2_CAPTURE_DEFAULT_PIX_FMT;
    cfg->bufq_depth = V4L2_CAPTURE_DEFAULT_BUFQ_DEPTH;
    sprintf(cfg->device, V4L2_CAPTURE_DEFAULT_DEVICE);
struct _v4l2CaptureHandle {
    v4l2CaptureCfg cfg;
    int fd;
    Buf *bufq[V4L2_CAPTURE_MAX_BUFQ_DEPTH];
    bool queued[V4L2_CAPTURE_MAX_BUFQ_DEPTH];
static int xioctl(int fh, int request, void *arg)
    int r;
    do {
        r = ioctl(fh, request, arg);
    } while (-1 == r && EINTR == errno);
    return r;
int v4l2_capture_check_caps(v4l2CaptureHandle *handle)
    struct v4l2_capability cap;
    int status = 0;
    if (-1 == xioctl(handle->fd, VIDIOC_QUERYCAP, &cap)) {
        if (EINVAL == errno) {
            TIOVX_MODULE_ERROR("[V4L2_CAPTURE] %s is no V4L2 device\n",
                    handle->cfg.device);
        } else {
            TIOVX_MODULE_ERROR("[V4L2_CAPTURE] VIDIOC_QUERYCAP Failed\n");
        status = -1;
    if (!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE)) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] %s is not a capture device\n",
        status = -1;
    if (!(cap.capabilities & V4L2_CAP_STREAMING)) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] %s does not support streaming i/o\n",
        status = -1;
    return status;
int v4l2_capture_set_fmt(v4l2CaptureHandle *handle)
    struct v4l2_format fmt;
    int status = 0;
    CLR(&fmt);
    fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    fmt.fmt.pix.width = handle->cfg.width;
    fmt.fmt.pix.height = handle->cfg.height;
    fmt.fmt.pix.pixelformat = handle->cfg.pix_format;
    fmt.fmt.pix.field = V4L2_FIELD_ANY;
    if (-1 == xioctl(handle->fd, VIDIOC_S_FMT, &fmt)) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] Set format failed\n");
        status = -1;
    return status;
int v4l2_capture_request_buffers(v4l2CaptureHandle *handle)
    struct v4l2_requestbuffers req;
    int status = 0;
    CLR(&req);
    req.count = handle->cfg.bufq_depth;
    req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    req.memory = V4L2_MEMORY_DMABUF;
    if (-1 == xioctl(handle->fd, VIDIOC_REQBUFS, &req)) {
            TIOVX_MODULE_ERROR("[V4L2_CAPTURE] %s does not support DMABUF\n",
        } else {
            TIOVX_MODULE_ERROR("[V4L2_CAPTURE] VIDIOC_REQBUFS failed\n");
        status = -1;
        return status;
    if (req.count < handle->cfg.bufq_depth) {
        TIOVX_MODULE_ERROR("Failed to allocate requested buffers,"
                           " requested %d, allocted %d\n",
                           handle->cfg.bufq_depth, req.count);
        status = -1;
    return status;
v4l2CaptureHandle *v4l2_capture_create_handle(v4l2CaptureCfg *cfg)
    v4l2CaptureHandle *handle = NULL;
    handle = malloc(sizeof(v4l2CaptureHandle));
    handle->fd = -1;
    memcpy(&handle->cfg, cfg, sizeof(v4l2CaptureCfg));
    handle->fd = open(cfg->device, O_RDWR | O_NONBLOCK, 0);
    if (-1 == handle->fd) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] Cannot open '%s': %d, %s\n",
                            cfg->device, errno, strerror(errno));
        goto free_handle;
    if (0 != v4l2_capture_check_caps(handle)) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] Check caps failed\n");
        goto free_fd;
    if (0 != v4l2_capture_set_fmt(handle)) {
        goto free_fd;
    if (0 != v4l2_capture_request_buffers(handle)) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] request buffers failed\n");
        goto free_fd;
    for (int i=0; i < handle->cfg.bufq_depth; i++) {
        handle->queued[i] = false;
    return handle;
free_fd:
    close(handle->fd);
free_handle:
    free(handle);
    return NULL;
int v4l2_capture_start(v4l2CaptureHandle *handle)
    int status = 0;
    enum v4l2_buf_type type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    if (-1 == xioctl(handle->fd, VIDIOC_STREAMON, &type)) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] VIDIOC_STREAMON failed\n");
        status = -1;
    sleep(V4L2_CAPTURE_STREAMON_DELAY);
    return status;
int v4l2_capture_enqueue_buf(v4l2CaptureHandle *handle, Buf *tiovx_buffer)
    struct v4l2_buffer buf;
    int status = 0;
    if (handle->queued[tiovx_buffer->buf_index] == true) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] Buffer alread enqueued\n");
        status = -1;
        goto ret;
    CLR(&buf);
    buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    buf.memory = V4L2_MEMORY_DMABUF;
    buf.index = tiovx_buffer->buf_index;
    buf.m.fd = getDmaFd(tiovx_buffer->handle);
    if (-1 == xioctl(handle->fd, VIDIOC_QBUF, &buf)) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] VIDIOC_QBUF failed\n");
        status = -1;
    } else {
        handle->queued[tiovx_buffer->buf_index] = true;
        handle->bufq[tiovx_buffer->buf_index] = tiovx_buffer;
ret:
    return status;
Buf *v4l2_capture_dqueue_buf(v4l2CaptureHandle *handle)
    Buf *tiovx_buffer = NULL;
    int i = 0;
    CLR(&buf);
    for (i=0; i < V4L2_CAPTURE_MAX_RETRIES; i++) {
        if (-1 == xioctl(handle->fd, VIDIOC_DQBUF, &buf)) {
            if (errno == EAGAIN) {
                continue;
            } else {
                TIOVX_MODULE_ERROR("[V4L2_CAPTURE] VIDIOC_DQBUF failed\n");
                goto ret;
        } else {
            break;
    if (i == V4L2_CAPTURE_MAX_RETRIES) {
        TIOVX_MODULE_PRINTF("[V4L2_CAPTURE] DQBUF Exceeded max retries\n");
        goto ret;
    handle->queued[buf.index] = false;
    tiovx_buffer = handle->bufq[buf.index];
ret:
    return tiovx_buffer;
int v4l2_capture_stop(v4l2CaptureHandle *handle)
    int status = 0;
    if (-1 == xioctl(handle->fd, VIDIOC_STREAMOFF, &type)) {
        TIOVX_MODULE_ERROR("[V4L2_CAPTURE] VIDIOC_STREAMOFF failed\n");
        status = -1;
    return status;
int v4l2_capture_delete_handle(v4l2CaptureHandle *handle)
    int status = 0;
    close(handle->fd);
    free(handle);
    return status;
error log as below:
自启动failed.txt
U-Boot SPL 2023.04 (Aug 21 2024 - 16:08:24 +0800)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
am62a_init: board_init_f done
SPL initial stack usage: 17064 bytes
am62a_init: spl_boot_device: devstat = 0x24b bootmedia = 0x9 bootindex = 0
Trying to boot from MMC1
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
U-Boot SPL 2023.04 (Nov 21 2024 - 07:23:18 +0000)
Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices
U-Boot 2023.04 (Sep 05 2024 - 14:17:30 +0800)
SoC:   AM62AX SR1.0 HS-FS
Model: Texas Instruments AM62A7 SK
DRAM:  1 GiB
Core:  58 devices, 28 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   Could not get PHY for ethernet@8000000port@1: addr 0
am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
MMC: no card present
SD/MMC found on device 1
** Bad device specification mmc 1 **
Couldn't find partition mmc 1
Can't set block device
## Error: "main_cpsw0_qsgmii_phyinit" not defined
ERROR: reserving fdt memory region failed (addr=ae000000 size=12000000 flags=4)
19376640 bytes read in 135 ms (136.9 MiB/s)
58603 bytes read in 30 ms (1.9 MiB/s)
Working FDT set to 88000000
   Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.80 (root@hzh57566u) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #5 SMP PREEMPT Sun Sep 22 13:38:31 CST 2024
[    0.000000] Machine model: Texas Instruments AM62A7 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000bd000000, size 48 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 240 MiB
[    0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000997fffff]
[    0.000000]   node   0: [mem 0x0000000099800000-0x000000009b7fefff]
[    0.000000]   node   0: [mem 0x000000009b800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a2ffffff]
[    0.000000]   node   0: [mem 0x00000000a3000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000bcffffff]
[    0.000000]   node   0: [mem 0x00000000bd000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258047
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=3f057e2b-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 379056K/1048572K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 620364K reserved, 49152K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008514] Console: colour dummy device 80x25
[    0.013100] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023782] pid_max: default: 32768 minimum: 301
[    0.028549] LSM: Security Framework initializing
[    0.033364] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.040935] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.050412] cblist_init_generic: Setting adjustable number of callback queues.
[    0.057846] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.064138] cblist_init_generic: Setting adjustable number of callback queues.
[    0.071533] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.077900] rcu: Hierarchical SRCU implementation.
[    0.082808] rcu:     Max phase no-delay instances is 1000.
[    0.088363] Platform MSI: msi-controller@1820000 domain created
[    0.094608] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.104003] EFI services will not be available.
[    0.108871] smp: Bringing up secondary CPUs ...
[    0.114094] Detected VIPT I-cache on CPU1
[    0.114182] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.114198] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
[    0.114247] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.114862] Detected VIPT I-cache on CPU2
[    0.114930] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.114944] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000
[    0.114974] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.115522] Detected VIPT I-cache on CPU3
[    0.115590] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.115604] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000
[    0.115634] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.115701] smp: Brought up 1 node, 4 CPUs
[    0.195442] SMP: Total of 4 processors activated.
[    0.200254] CPU features: detected: 32-bit EL0 Support
[    0.205525] CPU features: detected: CRC32 instructions
[    0.210830] CPU: All CPU(s) started at EL2
[    0.215028] alternatives: applying system-wide alternatives
[    0.221988] devtmpfs: initialized
[    0.232577] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.242587] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.251236] pinctrl core: initialized pinctrl subsystem
[    0.257133] DMI not present or invalid.
[    0.261637] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.268610] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.276013] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.284015] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.292178] audit: initializing netlink subsys (disabled)
[    0.297835] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.298232] thermal_sys: Registered thermal governor 'step_wise'
[    0.305764] thermal_sys: Registered thermal governor 'power_allocator'
[    0.311942] cpuidle: using governor menu
[    0.322777] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.329796] ASID allocator initialised with 65536 entries
[    0.347156] KASLR disabled due to lack of seed
[    0.358047] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.365014] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.371425] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.378365] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.384773] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.391712] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.398120] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.405060] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.412679] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
[    0.422939] iommu: Default domain type: Translated
[    0.427956] iommu: DMA domain TLB invalidation policy: strict mode
[    0.434643] SCSI subsystem initialized
[    0.438760] usbcore: registered new interface driver usbfs
[    0.444403] usbcore: registered new interface driver hub
[    0.449855] usbcore: registered new device driver usb
[    0.455417] pps_core: LinuxPPS API ver. 1 registered
[    0.460495] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.469850] PTP clock support registered
[    0.473979] EDAC MC: Ver: 3.0.0
[    0.477949] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[    0.484776] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[    0.491579] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[    0.498307] omap-mailbox 29030000.mailbox: no available mbox devices found
[    0.505630] FPGA manager framework
[    0.509178] Advanced Linux Sound Architecture Driver Initialized.
[    0.516225] clocksource: Switched to clocksource arch_sys_counter
[    0.522676] VFS: Disk quotas dquot_6.6.0
[    0.526728] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.539493] Carveout Heap: Exported 176 MiB at 0x00000000a3000000
[    0.545846] NET: Registered PF_INET protocol family
[    0.550961] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.559533] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.568140] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.576073] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.584052] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.591645] TCP: Hash tables configured (established 8192 bind 8192)
[    0.598250] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.605049] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.612428] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.618582] RPC: Registered named UNIX socket transport module.
[    0.624653] RPC: Registered udp transport module.
[    0.629463] RPC: Registered tcp transport module.
[    0.634272] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.640862] NET: Registered PF_XDP protocol family
[    0.645771] PCI: CLS 0 bytes, default 64
[    0.650413] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.660307] Initialise system trusted keyrings
[    0.665051] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[    0.675813] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.682335] NFS: Registering the id_resolver key type
[    0.687554] Key type id_resolver registered
[    0.691833] Key type id_legacy registered
[    0.695984] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.702840] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.747536] Key type asymmetric registered
[    0.751729] Asymmetric key parser 'x509' registered
[    0.756760] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.764464] io scheduler mq-deadline registered
[    0.769101] io scheduler kyber registered
[    0.776156] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.782761] pinctrl-single f4000.pinctrl: 151 pins, size 604
[    0.794854] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.809946] loop: module loaded
[    0.814327] megasas: 07.719.03.00-rc1
[    0.820965] tun: Universal TUN/TAP device driver, 1.6
[    0.826799] VFIO - User Level meta-driver version: 0.3
[    0.832733] usbcore: registered new interface driver usb-storage
[    0.839398] i2c_dev: i2c /dev entries driver
[    0.845139] sdhci: Secure Digital Host Controller Interface driver
[    0.851487] sdhci: Copyright(c) Pierre Ossman
[    0.856141] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.862539] ledtrig-cpu: registered to indicate activity on CPUs
[    0.868852] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.875769] usbcore: registered new interface driver usbhid
[    0.881470] usbhid: USB HID core driver
[    0.886208] optee: probing for conduit method.
[    0.890787] optee: revision 4.1 (012cdca4)
[    0.891054] optee: dynamic shared memory is enabled
[    0.900605] optee: initialized driver
[    0.905725] Initializing XFRM netlink socket
[    0.910149] NET: Registered PF_PACKET protocol family
[    0.915374] Key type dns_resolver registered
[    0.920090] registered taskstats version 1
[    0.924310] Loading compiled-in X.509 certificates
[    0.937175] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
[    0.982778] i2c 0-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@48/regulators/buck5
[    0.992831] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    0.999688] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.006124] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.012039] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.020403] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.029612] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.038607] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
[    1.048760] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.056850] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.067632] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.077435] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.086733] ti-udma 4e230000.dma-controller: Number of rings: 6
[    1.093221] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
[    1.102495] printk: console [ttyS2] disabled
[    1.106934] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 253, base_baud = 3000000) is a 8250
[    1.115811] printk: console [ttyS2] enabled
[    1.124270] printk: bootconsole [ns16550a0] disabled
[    1.137457] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    1.142537] 2 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.149496] Creating 2 MTD partitions on "fc40000.spi.0":
[    1.154890] 0x000000000000-0x0000037c0000 : "ospi.tiboot3"
[    1.161472] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.174155] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1000000 KHz
[    1.186789] mmc0: CQHCI version 5.10
[    1.186938] mmc1: CQHCI version 5.10
[    1.231782] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.305032] mmc0: Command Queue Engine enabled
[    1.309542] mmc0: new HS200 MMC card at address 0001
[    1.315936] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    1.322423]  mmcblk0: p1 p2 p3
[    1.326242] mmcblk0boot0: mmc0:0001 8GUF4R 31.9 MiB
[    1.332208] mmcblk0boot1: mmc0:0001 8GUF4R 31.9 MiB
[    1.338103] mmcblk0rpmb: mmc0:0001 8GUF4R 4.00 MiB, chardev (240:0)
[    1.511443] vddshv_sdio: Bringing 1800000uV into 3300000-3300000uV
[    1.519390] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.528095] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.535449] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.548776] ALSA device list:
[    1.551753]   No soundcards found.
[    2.711433] sdhci-am654 fa00000.mmc: Power on failed
[    2.747490] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    2.912444] EXT4-fs (mmcblk0p2): recovery complete
[    2.917982] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[    2.926609] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.933025] devtmpfs: mounted
[    2.937225] Freeing unused kernel memory: 1984K
[    2.941888] Run /sbin/init as init process
[    3.027485] systemd[1]: System time before build time, advancing clock.
[    3.069726] NET: Registered PF_INET6 protocol family
[    3.076210] Segment Routing with IPv6
[    3.079945] In-situ OAM (IOAM) with IPv6
[    3.103440] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    3.135688] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[    3.205436] systemd[1]: Hostname set to <am62axx-evm>.
[    3.316865] systemd-sysv-generator[151]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    3.342451] systemd-sysv-generator[151]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    3.642249] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.668168] systemd[1]: Configuration file /lib/systemd/system/application.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    3.682986] systemd[1]: Configuration file /lib/systemd/system/application.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    3.745530] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.827956] systemd[1]: Queued start job for default target Graphical Interface.
[    3.901800] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    3.927585] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    3.952121] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    3.974861] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    3.996815] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    4.020885] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    4.044959] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    4.060617] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    4.080572] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    4.096999] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    4.170655] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    4.192691] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    4.232951] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    4.257228] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    4.283962] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    4.307109] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.331138] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.350318] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    4.375408] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    4.398538] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    4.422796] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    4.489170] systemd[1]: Mounting Huge Pages File System...
[    4.515175] systemd[1]: Mounting POSIX Message Queue File System...
[    4.547325] systemd[1]: Mounting Kernel Debug File System...
[    4.565595] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[    4.613142] systemd[1]: Mounting Temporary Directory /tmp...
[    4.641873] systemd[1]: Starting Create List of Static Device Nodes...
[    4.672423] systemd[1]: Starting Load Kernel Module configfs...
[    4.708411] systemd[1]: Starting Load Kernel Module drm...
[    4.735153] systemd[1]: Starting Load Kernel Module fuse...
[    4.749341] fuse: init (API version 7.37)
[    4.769448] systemd[1]: Starting Start psplash boot splash screen...
[    4.817650] systemd[1]: Starting RPC Bind...
[    4.836846] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[    4.862282] systemd[1]: Starting Journal Service...
[    4.889268] systemd[1]: Starting Load Kernel Modules...
[    4.937172] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network …ts from Kernel command line...
[    4.970355] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.994080] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    4.999114] systemd[1]: Starting Coldplug All udev Devices...
[    5.028007] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    5.045075] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    5.445748] systemd-journald[166]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /media/ram...
         Mounting /var/volatile...
[    5.658027] audit: type=1334 audit(1651167747.628:2): prog-id=5 op=LOAD
[    5.664843] audit: type=1334 audit(1651167747.636:3): prog-id=6 op=LOAD
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[    6.252753] random: crng init done
[  OK  ] Finished Load/Save Random Seed.
[    6.313263] mc: Linux media interface: v0.10
[  OK  ] Found device /dev/ttyS2.
[    6.337879] videodev: Linux video capture interface: v2.00
[    6.380894] === ox02c10_power_on
[    6.403763] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    6.419327] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
[  OK  ] Started Network Time Synchronization.
[    6.435458] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
[  OK  ] Reached target System Initializatio[    6.448488] === ox02c10_power_on max96714 is locked, loops:1
n.
[  OK  ] Started Daily Cleanup of Temporary [    6.472570] === ox02c10_power_off
Directories.
[    6.486830] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
[    6.495417] platform 79000000.r5f: configured R5F for remoteproc mode
[    6.496551] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
[    6.506145] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
[    6.510483] remoteproc remoteproc0: 7e000000.dsp is available
[    6.519501] remoteproc remoteproc1: 79000000.r5f is available
[    6.524499] k3-dsp-rproc 7e000000.dsp: register pm nitifiers in remoteproc mode
[  OK  ] Reached target System Time Set.
[    6.549023] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[  OK  ] Started Daily rotation of log files[    6.566292] platform 78000000.r5f: configured R5F for IPC-only mode
[    6.568444] remoteproc remoteproc1: powering up 79000000.r5f
[    6.581335] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 3726464
[  OK  ] Reached target Timer Units.[    6.590593] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
[    6.593565] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node r5f-dma-memory@9b800000
[    6.613531] virtio_rpmsg_bus virtio0: rpmsg host is online
[    6.619222] rproc-virtio rproc-virtio.5.auto: registered virtio0 (type 7)
[    6.622211] remoteproc remoteproc2: 78000000.r5f is available
[    6.626075] remoteproc remoteproc1: remote processor 79000000.r5f is now up
[  OK  ] Listening on Avahi mDNS/DNS-SD Stac[    6.634254] remoteproc remoteproc2: attaching to 78000000.r5f
k Activation Socket.[    6.651618] remoteproc remoteproc0: powering up 7e000000.dsp
[    6.652935] platform 78000000.r5f: R5F core initialized in IPC-only mode
[    6.658031] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11534416
[    6.664697] rproc-virtio rproc-virtio.6.auto: assigned reserved memory node r5f-dma-memory@9c800000
[    6.681828] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    6.682371] virtio_rpmsg_bus virtio1: rpmsg host is online
[    6.683349] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    6.686270] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
[    6.696362] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:10 UTC (10)
[    6.699878] rproc-virtio rproc-virtio.6.auto: registered virtio1 (type 7)
[    6.707650] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node c7x-dma-memory@99800000
[    6.715586] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
[    6.719385] systemd-journald[166]: Time jumped backwards, rotating.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[    6.752795] e5010 fd20000.e5010: Device registered as /dev/video2
[    6.759512] virtio_rpmsg_bus virtio2: rpmsg host is online
[    6.760005] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    6.767609] rproc-virtio rproc-virtio.7.auto: registered virtio2 (type 7)
[    6.778954] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
[    6.779559] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    6.797805] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    6.805189] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    6.820773] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    6.828525] virtio_rpmsg_bus virtio1: msg received with no recipient
         Starting Docker Socket for the API...
[    6.848396] virtio_rpmsg_bus virtio2: msg received with no recipient
[    6.873337] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
         Starting Weston socket...
         Starting D-Bus System Message Bus...
[    6.983411] virtio_rpmsg_bus virtio0: msg received with no recipient
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Listening on Weston socket.
[  OK  ] Finished Reboot and dump vmcore via kexec.
[  OK  ] Reached target Socket Units.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Reached target Basic System.
[  OK  ] Started My Shell Script.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
         Starting DEMO...
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
         Starting Telephony service...
         Starting Expand the rootfs…ll size of the boot device....
[  OK  ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
[    7.423161] audit: type=1334 audit(11.220:4): prog-id=7 op=LOAD
[    7.429669] audit: type=1334 audit(11.228:5): prog-id=8 op=LOAD
         Starting User Login Management...
[  OK  ] Started TEE Supplicant.
         Starting Telnet Server...
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[  OK  ] Started DEMO.
[  OK  ] Started Telephony service.
[    7.545549] Bluetooth: Core ver 2.22
[  OK  ] Reached target Preparation for Netw[    7.555344] NET: Registered PF_BLUETOOTH protocol family
ork.
[    7.562394] Bluetooth: HCI device and connection manager initialized
[    7.572285] Bluetooth: HCI socket layer initialized
[    7.577407] Bluetooth: L2CAP socket layer initialized
[    7.582577] Bluetooth: SCO socket layer initialized
         Starting Network Configuration...
[  OK  ] Finished Expand the rootfs…full size of the boot device..
[    7.988120] virtio_rpmsg_bus virtio0: msg received with no recipient
[    8.050235] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.095341] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    8.104721] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  OK  ] Started User Login Management.
[  OK  ] Started Network Configuration.
         Starting Network Name Resolution...
[    8.369591] ox02c 0-0010: Consider updating driver ox02c to match on endpoints
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[    8.680564] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY
[    8.699798] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    8.730531] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 1
[    8.740040] xhci-hcd xhci-hcd.9.auto: USB3 root hub has no ports
[    8.746930] xhci-hcd xhci-hcd.9.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000010010
[    8.758311] xhci-hcd xhci-hcd.9.auto: irq 541, io mem 0x31000000
[    8.777160] hub 1-0:1.0: USB hub found
[    8.782297] hub 1-0:1.0: 1 port detected
[    8.821592] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    8.828116] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 2
[    8.838673] xhci-hcd xhci-hcd.10.auto: USB3 root hub has no ports
[    8.845687] xhci-hcd xhci-hcd.10.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000010010
[    8.857453] xhci-hcd xhci-hcd.10.auto: irq 542, io mem 0x31100000
[    8.899968] hub 2-0:1.0: USB hub found
[    8.907123] hub 2-0:1.0: 1 port detected
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server    8.993124] virtio_rpmsg_bus virtio0: msg received with no recipient
m.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Finished Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Created slice Slice /system/systemd-fsck.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting Weston, a Wayland…ositor, as a system service...
[    9.311235] audit: type=1334 audit(13.108:6): prog-id=9 op=LOAD
[    9.320018] audit: type=1334 audit(13.116:7): prog-id=10 op=LOAD
         Starting User Database Manager...
[  OK  ] Found device /dev/mmcblk0p1.
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[  OK  ] Found device /dev/mmcblk0p3.
         Starting File System Check on /dev/mmcblk0p1...
         Starting File System Check on /dev/mmcblk0p3...
[  OK  ] Finished File System Check on /dev/mmcblk0p1.
         Mounting /run/media/boot-mmcblk0p1...
[  OK  ] Started User Database Manager.
[  OK  ] Mounted /run/media/boot-mmcblk0p1.
[  OK  ] Finished File System Check on /dev/mmcblk0p3.
         Mounting /run/media/persist-mmcblk0p3...
[  OK  ] Created slice User Slice of UID 100[    9.830399] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Quota mode: none.
0.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Mounted /run/media/persist-mmcblk0p3.
[  OK  ] Finished User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[    9.899328] audit: type=1006 audit(13.696:8): pid=670 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[    9.913229] audit: type=1300 audit(13.696:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff7146e88 a2=4 a3=ffff8bce6020 items=0 ppid=1 pid=670 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[    9.939232] audit: type=1327 audit(13.696:8): proctitle="(systemd)"
[    9.998265] virtio_rpmsg_bus virtio0: msg received with no recipient
[  OK  ] Finished Synchronize System and HW clocks.
[  OK  ] Started containerd container runtime.
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Session c1 of User weston.
[   10.533281] audit: type=1006 audit(14.332:9): pid=564 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
[FAILED] Failed to start Weston, a …mpositor, as a system service.
See 'systemctl status weston.service' for details.
         Starting EdgeAI OOB demos...
[FAILED] Failed to start EdgeAI OOB demos.
See 'systemctl status edgeai-init.service' for details.
[   11.003314] virtio_rpmsg_bus virtio0: msg received with no recipient
NOTICE: This file system contains the following GPL-3.0 packages:
        adwaita-icon-theme-symbolic
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gnu-config
        grub-common
        grub-editenv
        grub-efi
        gzip
        hidapi
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libeigen-dev
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libopcodes
        libqt5charts-examples
        libqt5charts-plugins
        libqt5charts-qmlplugins
        libqt5charts5
        libqt5sensors-plugins
        libqt5sensors-qmlplugins
        libqt5sensors5
        libqt5serialport-examples
        libqt5serialport-plugins
        libqt5serialport-qmlplugins
        libqt5serialport5
        libqt5svg-examples
        libqt5svg-plugins
        libqt5svg-qmlplugins
        libqt5svg5
        libqt5virtualkeyboard-plugins
        libqt5virtualkeyboard-qmlplugins
        libqt5virtualkeyboard5
        libqt5webchannel-plugins
        libqt5webchannel-qmlplugins
        libqt5webchannel5
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase
        qtconnectivity-plugins
        qtconnectivity-qmlplugins
        qtconnectivity
        qtdeclarative-plugins
        qtdeclarative-qmlplugins
        qtdeclarative-tools
        qtdeclarative
        qtgraphicaleffects-qmlplugins
        qtlocation-examples
        qtlocation-plugins
        qtlocation-qmlplugins
        qtlocation
        qtmultimedia-examples
        qtmultimedia-plugins
        qtmultimedia-qmlplugins
        qtmultimedia
        qtquick3d-plugins
        qtquick3d-qmlplugins
        qtquick3d
        qtquics-qmlplugins.control
        qtquics2-plugins.control
        qtquics2-qmlplugins.control
        qtquics2.control
        qtscript-examples
        qtscript-plugins
        qtscript-qmlplugins
        qtscript
        qtwayland-examples
        qtwayland-plugins
        qtwayland-qmlplugins
        qtwayland
        tar
        which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Finished Print notice about GPLv3 packages.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Record Runlevel Change in UTMP...
[  OK  ] Finished Record Runlevel Change in UTMP.
[   12.008464] virtio_rpmsg_bus virtio0: msg received with no recipient
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project am62axx-evm -
Arago 2023.10 am62axx-evm -
am62axx-evm login: [   13.013862] virtio_rpmsg_bus virtio0: msg received with no recipient
[   14.018631] virtio_rpmsg_bus virtio0: msg received with no recipient
[   15.023745] virtio_rpmsg_bus virtio0: msg received with no recipient
[   16.030939] virtio_rpmsg_bus virtio0: msg received with no recipient
am62axx-evm login:
am62axx-evm login: roo[   17.033844] virtio_rpmsg_bus virtio0: msg received with no recipient
t
[   17.495448] kauditd_printk_skb: 2 callbacks suppressed
[   17.495465] audit: type=1006 audit(21.292:10): pid=1023 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[   17.512569] audit: type=1300 audit(21.292:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff7146e88 a2=1 a3=ffff8bce6020 items=0 ppid=1 pid=1023 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[   17.538371] audit: type=1327 audit(21.292:10): proctitle="(systemd)"
[   17.544894] audit: type=1334 audit(21.324:11): prog-id=11 op=LOAD
[   17.551061] audit: type=1300 audit(21.324:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff57bc6d0 a2=78 a3=0 items=0 ppid=1 pid=1023 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[   17.576327] audit: type=1327 audit(21.324:11): proctitle="(systemd)"
[   17.583190] audit: type=1334 audit(21.336:12): prog-id=11 op=UNLOAD
[   17.589542] audit: type=1334 audit(21.336:13): prog-id=12 op=LOAD
[   17.595771] audit: type=1300 audit(21.336:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff57bc770 a2=78 a3=0 items=0 ppid=1 pid=1023 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[   17.620601] audit: type=1327 audit(21.336:13): proctitle="(systemd)"
[   18.041223] virtio_rpmsg_bus virtio0: msg received with no recipient
-sh: ./init_script.sh: No such file or directory
root@am62axx-evm:/opt/edgeai-gst-apps#
root@am62axx-evm:/opt/edgeai-gst-apps# [   19.044060] virtio_rpmsg_bus virtio0: msg received with no recipient
root@am62axx-evm:/opt/edgeai-gst-apps# [   20.049115] virtio_rpmsg_bus virtio0: msg received with no recipient
root@am62axx-evm:/opt/edgeai-gst-apps# [   21.054059] virtio_rpmsg_bus virtio0: msg received with no recipient
[   27.196910] virtio_rpmsg_bus virtio0: msg received with no recipient
[   27.553579] use of bytesused == 0 is deprecated and will be removed in the future,
[   27.561188] use the actual size instead.
root@am62axx-evm:/opt/edgeai-gst-apps# systemctl status application.service
* application.service - My Shell Script
     Loaded: loaded (/lib/systemd/system/application.service; enabled; vendor preset: disabled)
     Active: active (running) since Thu 1970-01-01 00:00:11 UTC; 37s ago
   Main PID: 299 (flash_emmc.sh)
      Tasks: 16 (limit: 444)
     Memory: 77.9M
     CGroup: /system.slice/application.service
             |-  299 /bin/bash /etc/init.d/flash_emmc.sh
             `- 1042 ./sva-dms
Jan 01 00:00:37 am62axx-evm flash_emmc.sh[1042]: [TIOVX_MODULES][ERROR] 295: v4l2_capture_dqueue_buf: [V4L2_CAPTURE] VIDIOC_DQBUF failed
     Active: active (running) since Thu 1970-01-01 00:00:11 UTC; 44s ago
     Memory: 83.9M
             `- 1042 ./sva-dms
Need you help for this issue, this is blocked customer project.
BR,
Biao
