TMS320C6655: fopen Hanging in Code Composer Studio
Part Number: TMS320C6655
Hi everyone,
I'm experiencing an issue with Code Composer Studio (CCS) where the fopen function hangs during execution.
When I run my code, the fopen function seems to hang indefinitely. Additionally, the execution shows as suspended and ends at __CSL_intcIsrNMI: CALLDISP 1.
Here's a simplified version of my code:
#include <stdio.h>
int main() {
    FILE *file = fopen("example.dat", "rb");
    if (file == NULL) {
        perror("Unable to open file!");
        return 1;
    // Additional code here...
    fclose(file);
    return 0;
I am also seeing similar problems with printf and fgets functions.
Setup:
  • CCS Version: 9.3.0.00012
  • Target Device: TMS320C6655
  • Host OS: Windows 10
Has anyone encountered similar problems or have any suggestions on what might be causing this behavior?
Any help would be greatly appreciated!
Rahul
    Our expert looking into this thread is out of the office and returning on December 18th. Please expect a delayed response. Suggest to wait till then. Thanks for your patience.
    Thanks.
  • Rahul,
    The fopen and other printf functions worked successfully for me.
    I used Processor SDK 6.3 for C665x.
    PROCESSOR-SDK-RTOS-C665x 06_03_00_106
    http://software-dl.ti.com/processor-sdk-rtos/esd/C665x/latest/index_FDS.html
    Sample code which worked for me ----> It uses fopen and printf.
     * Copyright (c) 2011 Texas Instruments Incorporated - http://www.ti.com
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     * FILE PURPOSE: EEPROM writer utility
     * FILE NAME: eepromwriter.c
     * DESCRIPTION: A simple EEPROM writer using platform lib APIs to program the EEPROM
     *              with an image that the ibl can read.
    #include <stdlib.h>
    #include <stdio.h>
    #include<ctype.h>
    #include <string.h>
    #include "platform.h"
    #include "types.h"
    /* EEPROM writer utility version */
    char version[] = "01.00.00.05";
    /* The input file name is hard coded */
    char *input_file = "eepromwriter_input.txt";
    /* Parameters defined in the input_file */
    #define FILE_NAME      "file_name"
    #define BUS_ADDR       "bus_addr"
    #define START_ADDR     "start_addr"
    #define SWAP_DATA      "swap_data"
    /* Memory address to store the write data */
    #define WRITE_DATA_ADDRESS     0x0C000000
     * Structure:   EEPROM_WRITER_INFO_T
     *              EEPROM writer control data. This structure should be filled in
     *              by the user before running
    #define MAX_LINE_LENGTH 40
    typedef struct EEPROM_WRITER_INFO_tag
        char        file_name[MAX_LINE_LENGTH]; /* CCS format data file name */
        uint32_t    busAddr;                    /* Slave bus address */
        uint32_t    startAddr;                  /* Start address to write */
        uint32_t    swapData;                   /* Swap byte in the 32-bit word of the data */
        uint32_t    deviceTotalBytes;           /* Total number of bytes available in the device */
        uint32_t    writeBytes;                 /* Number of bytes to be written into the device */
        uint8_t     *writeData;                 /* Address to store the write data */
        uint8_t     *readData;                  /* Address to store the read data */
    } EEPROM_WRITER_INFO_T;
    EEPROM_WRITER_INFO_T eepromWriterInfo;
    /* OSAL functions for Platform Library */
    uint8_t *Osal_platformMalloc (uint32_t num_bytes, uint32_t alignment)
    	return malloc(num_bytes);
    void Osal_platformFree (uint8_t *dataPtr, uint32_t num_bytes)
        /* Free up the memory */
        if (dataPtr)
            free(dataPtr);
    void Osal_platformSpiCsEnter(void)
        return;
    void Osal_platformSpiCsExit (void)
        return;
     * Function:    print_platform_errno
    void
        void
        printf ("Returned platform error number is %d\n", platform_errno);
     * Function:    form_block
     *      Form a block of data to write to the NOR. The block is
     *      created as a byte stream from the 4 byte stream in which
     *      the MSB is always sent first.
    void
    formBlock
        uint32_t      *data,
        uint32_t      blockSize,
        uint8_t       *scratch
        uint32_t i, j;
        /* Convert the data to a byte stream */
        for (i = j = 0; j < blockSize; i++, j+=4)
            scratch[j+0] = (data[i] >> 24) & 0xff;
            scratch[j+1] = (data[i] >> 16) & 0xff;
            scratch[j+2] = (data[i] >>  8) & 0xff;
            scratch[j+3] = (data[i] >>  0) & 0xff;
     * Function:    flash_eeprom
     *              Write the data from memory to EEPROM.
     *              Returns TRUE if the data is written successfully
     *                      FALSE if the data write fails
    Bool
    flash_eeprom
        PLATFORM_DEVICE_info    *p_device
        uint8_t       *scrach_block;
        printf ("Writing %d bytes from DSP memory address 0x%08x to EEPROM bus address 0x%04x starting from device address 0x%04x ...\n",
                eepromWriterInfo.writeBytes,
                (uint32_t)eepromWriterInfo.writeData,
                eepromWriterInfo.busAddr,
                eepromWriterInfo.startAddr);
        if (eepromWriterInfo.swapData)
    	    scrach_block = malloc(eepromWriterInfo.deviceTotalBytes);
    	    if (scrach_block == NULL)
    	        printf ("Can not allocate scratch block memory!\n");
    	        return (FALSE);
            formBlock((uint32_t *)(eepromWriterInfo.writeData), eepromWriterInfo.deviceTotalBytes, scrach_block);
    	else
    		scrach_block = eepromWriterInfo.writeData;
        if(platform_device_write(p_device->handle, eepromWriterInfo.startAddr, scrach_block, eepromWriterInfo.writeBytes) != Platform_EOK)
            print_platform_errno();
            	free (scrach_block);
            return FALSE;
    	if(eepromWriterInfo.swapData)
        return TRUE;
     * Function:    flash_verify
     *              Read back the data file that was just flashed.
     *              Returns TRUE if the data verified correctly.
     *                      FALSE if the data verification failed
    Bool
    flash_verify
        uint32_t    i, j;
        uint32_t    *read_data_w;
        printf ("Reading %d bytes from EEPROM bus address 0x%04x to DSP memory address 0x%08x starting from device address 0x%04x ...\n",
                (uint32_t)eepromWriterInfo.readData,
    	        return (FALSE);
    	else
    		scrach_block = eepromWriterInfo.readData;
        if(platform_device_read(p_device->handle, eepromWriterInfo.startAddr, scrach_block, eepromWriterInfo.writeBytes) != Platform_EOK)
            return FALSE;
        printf ("Verifying data read ...\n");
            /* Convert the packed data */
            read_data_w = (uint32_t *)(eepromWriterInfo.readData);
            for  (i = 0, j = 0; i < eepromWriterInfo.deviceTotalBytes; i += 4)
                read_data_w[j++] = (scrach_block[i+0] << 24) | (scrach_block[i+1] << 16) | (scrach_block[i+2] << 8) | scrach_block[i+3];
        for (i = 0; i < eepromWriterInfo.writeBytes; i++)
            if (eepromWriterInfo.readData[i] != eepromWriterInfo.writeData[i])
                printf ("Failure at byte %d, expected 0x%08x, read 0x%08x\n", i, eepromWriterInfo.writeData[i], eepromWriterInfo.readData[i]);
                return (FALSE);
        return (TRUE);
    int32_t
    xtoi
        char            *xs,
        uint32_t        *result
        uint32_t    szlen = strlen(xs);
        int32_t     i, xv, fact;
        if (szlen > 0)
            /* Converting more than 32bit hexadecimal value? */
            if (szlen>8) return 2; /* exit */
            /* Begin conversion here */
            *result = 0;
            fact = 1;
            /* Run until no more character to convert */
            for(i=szlen-1; i>=0 ;i--)
                if (isxdigit(*(xs+i)))
                    if (*(xs+i)>=97)
                        xv = ( *(xs+i) - 97) + 10;
                    else if ( *(xs+i) >= 65)
                        xv = (*(xs+i) - 65) + 10;
                    else
                        xv = *(xs+i) - 48;
                    *result += (xv * fact);
                    fact *= 16;
                else
                    // Conversion was abnormally terminated
                    // by non hexadecimal digit, hence
                    // returning only the converted with
                    // an error value 4 (illegal hex character)
                    return 4;
            return 0;
        // Nothing to convert
        return 1;
     * Function:    parse_input_file
    static Bool
    parse_input_file
        FILE*               fp
        char line[MAX_LINE_LENGTH];
        char tokens[] = " :=;\n\r";
        char *key, *data;
        memset(line, 0, MAX_LINE_LENGTH);
        fgets(line, MAX_LINE_LENGTH, fp);
        key  = (char *)strtok(line, tokens);
        data = (char *)strtok(NULL, tokens);
        if(strlen(data) == 0)
           return FALSE;
        if(strcmp(key, FILE_NAME) != 0)
            return FALSE;
        strcpy (eepromWriterInfo.file_name, data);
           return FALSE;
        if(strcmp(key, BUS_ADDR) != 0)
            return FALSE;
        if ((data[0] == '0') && (data[1] == 'x' || data[1] == 'X'))
            if (xtoi (&data[2], &eepromWriterInfo.busAddr) != 0)
                return FALSE;
        else
            eepromWriterInfo.busAddr = (uint32_t)atoi(data);
           return FALSE;
        if(strcmp(key, START_ADDR) != 0)
            return FALSE;
        eepromWriterInfo.startAddr = (uint32_t)atoi(data);
           return FALSE;
        if(strcmp(key, SWAP_DATA) != 0)
            return FALSE;
        eepromWriterInfo.swapData = (uint32_t)atoi(data);
        return TRUE;
     * Function:    find_file_length
    static Bool
    find_file_length
        FILE*               fp
        char        *pEnd;
        char        *ext;
        uint32_t    data_len, write_addr;
        ext = strrchr(eepromWriterInfo.file_name, '.');
        if (ext && (strcmp(ext, ".dat") == 0))
            /* Read the write address from the CCS header */
            strtoul (line,&pEnd,16);
            strtoul (pEnd,&pEnd,16);
            write_addr = strtoul (pEnd,&pEnd,16);
            /* Read the data length */
            data_len = (strtoul (pEnd,NULL,16)) * 4;
        else
            /* find the data length by seeking to the end and getting position */
            fseek(fp, 0, SEEK_END);
            data_len = ftell(fp);
            fseek(fp, 0, SEEK_SET);
        if (data_len > (eepromWriterInfo.deviceTotalBytes - eepromWriterInfo.startAddr))
            printf ("The data file is too big to fit into the device.\n");
            return FALSE;
        eepromWriterInfo.writeBytes = data_len;
        if (write_addr != WRITE_DATA_ADDRESS)
            write_addr = WRITE_DATA_ADDRESS;
        eepromWriterInfo.writeData  = (uint8_t *)write_addr;
        eepromWriterInfo.readData   = (uint8_t *)(write_addr + eepromWriterInfo.deviceTotalBytes);
        return TRUE;
     * Function:    main
    void main ()
        FILE                    *fp;
        platform_init_flags     init_flags;
        platform_init_config    init_config;
        PLATFORM_DEVICE_info    *p_device;
        Bool                    ret;
        printf("EEPROM Writer Utility Version %s\n\n", version);
        fp = fopen(input_file, "r");
        if (fp == NULL)
            printf("Error in opening %s input file\n", input_file);
            return;
        ret = parse_input_file(fp);
        fclose (fp);
        if (ret == FALSE)
            printf("Error in parsing %s input file\n", input_file);
            return;
        /* Initialize main Platform lib */
        memset(&init_config, 0, sizeof(platform_init_config));
        memset(&init_flags, 0x01, sizeof(platform_init_flags));
        init_flags.pll = 0;
        init_flags.ddr = 0;
        init_flags.phy = 0;
        if (platform_init(&init_flags, &init_config) != Platform_EOK)
            printf ("Platform init failed!\n");
            return;
        p_device = platform_device_open(eepromWriterInfo.busAddr, 0);
        if (p_device == NULL)
            printf ("EEPROM device open failed!\n");
            return;
        eepromWriterInfo.deviceTotalBytes = p_device->block_count * p_device->page_count * p_device->page_size;
        /* Open and find the length of the data file */
        fp = fopen (eepromWriterInfo.file_name, "rb");
        if (fp == NULL)
            printf ("Failed to open file %s\n", eepromWriterInfo.file_name);
            platform_device_close(p_device->handle);
            return;
        /* Parse the CCS format file */
        ret = find_file_length(fp);
        fclose (fp);
        if (ret == FALSE)
            printf("Error in parsing CCS file %s\n", eepromWriterInfo.file_name);
            return;
        /* Write the EEPROM */
        if (flash_eeprom (p_device) == FALSE)
            printf ("EEPROM write failed\n");
            return;
        /* verify the flash */
        if(flash_verify (p_device) == FALSE)
            printf ("EEPROM read verify failed\n");
            return;
        printf ("EEPROM programming completed successfully\n");
        return;
    Shankari G
