I read your post coincidently. And I had some question about TCP3e module in 6670.
By reading TCP3e User's Guide, I can see that if you input 1 bit, then you got 3 bits. There is a picture in the user's guide which describe the process of encoding. Here
is my question: after encoding, the info bits of the encoded bits are placed together and parity bits are placed together. Why? And EDMA put them in the correct order
which is one bit info bit and two parity bits?
And what's the relationship between transfer block and code block?
Thank you
Nick
