Part Number: TDA4VM
hi expert
SDK8.2 QNX+RTOX
We set UART0-RX(AB2) to pull-up and found through measurement that the voltage is still 0
Read padconfig121 register, the result is 0x00050007
Please help check if the settings are correct
Part Number: TDA4VM
hi expert
SDK8.2 QNX+RTOX
Can you test after setting the Padconfig register to 0x00070007?
Since you want to set to Pull-up, you will also want to enable bit 17. Let me know your results.
Neehar
You are still having trouble with the Padconfig register set to 0x00070007?
Neehar
