AM62A7-Q1: app_edgeai.py issue
Part Number: AM62A7-Q1
Other Parts Discussed in Thread: AM62A7
Hello Team,
We are currently working on a custom hardware project using the AM62A7 SoC and have built a Yocto SDK (Version 10) for our setup.
Hardware Setup:
Hadware - Custom Board (Based on EVM-SK)
Camera - IMX219
When we execute the app_edgeai.py with the object detection config file, no output is displayed on the connected HDMI monitor.
# GST_DEBUG=2 ./app_edgeai.py ../configs/object_detection.yaml -n
libtidl_onnxrt_EP loaded 0x396a12b0
Final number of subgraphs created are : 1, - Offloaded Nodes - 283, Total Nodes - 283
APP: Init ... !!!
   273.703973 s: MEM: Init ... !!!
   273.704048 s: MEM: Initialized DMA HEAP (fd=5) !!!
   273.704254 s: MEM: Init ... Done !!!
   273.704285 s: IPC: Init ... !!!
   273.721574 s: IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
   273.733202 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
   273.743368 s:  VX_ZONE_INIT:Enabled
   273.743402 s:  VX_ZONE_ERROR:Enabled
   273.743414 s:  VX_ZONE_WARNING:Enabled
   273.744835 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
   273.745048 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
   273.745173 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
   273.745580 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
   273.745599 s:  VX_ZONE_INIT:[tivxInitLocal:142] Initialization Done !!!
   273.748880 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
0:00:05.206817540  1280 0xffff8c000de0 FIXME                default gstutils.c:4036:gst_pad_create_stream_id_internal:<background_0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:05.387455290  1280 0xffff8c001530 FIXME                default gstutils.c:4036:gst_pad_create_stream_id_internal:<post_0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:05.390044705  1280 0xffff8c001c80 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<source0> Can't give latency since framerate isn't fixated !
0:00:05.390136880  1280 0xffff8c001c80 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
0:00:05.391290975  1280 0xffff8c002160 WARN                    v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<source0:src> VIDIOC_CROPCAP failed
0:00:05.391366235  1280 0xffff8c001c80 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<source0> Can't give latency since framerate isn't fixated !
0:00:05.391411330  1280 0xffff8c001c80 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
0:00:05.391556395  1280 0xffff8c001c80 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<source0> Can't give latency since framerate isn't fixated !
0:00:05.391603490  1280 0xffff8c001c80 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
0:00:05.393107975  1280 0xffff8c001c80 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<source0> Can't give latency since framerate isn't fixated !
0:00:05.393169980  1280 0xffff8c002160 WARN                    v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<source0:src> VIDIOC_CROPCAP failed
0:00:05.393186270  1280 0xffff8c001c80 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
==========[INPUT PIPELINE(S)]==========
0:00:05.397492580  1280     0x39743230 WARN                    v4l2 v4l2_calls.c:934:gst_v4l2_get_attribute:<source0:src> Failed to get value for control 9963776 on device '/dev/video-imx219-cam0'.
0:00:05.397655940  1280     0x39743230 WARN                    v4l2 v4l2_calls.c:934:gst_v4l2_get_attribute:<source0:src> Failed to get value for control 9963777 on device '/dev/video-imx219-cam0'.
0:00:05.397838415  1280     0x39743230 WARN                    v4l2 v4l2_calls.c:934:gst_v4l2_get_attribute:<source0:src> Failed to get value for control 9963778 on device '/dev/video-imx219-cam0'.
0:00:05.397946355  1280     0x39743230 WARN                    v4l2 v4l2_calls.c:934:gst_v4l2_get_attribute:<source0:src> Failed to get value for control 9963779 on device '/dev/video-imx219-cam0'.
[PIPE-0]
v4l2src device=/dev/video-imx219-cam0 io-mode=5 pixel-aspect-ratio=None ! queue leaky=2 ! capsfilter caps="video/x-bayer, width=(int)1920, height=(int)1080, format=(string)rggb;" ! tiovxisp dcc-isp-file=/opt/imaging/imx219/linear/dcc_viss.bin sensor-name=SENSOR_SONY_IMX219_RPI ! capsfilter caps="video/x-raw, format=(string)NV12;" ! tiovxmultiscaler name=split_01
split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1280, height=(int)720;" ! tiovxdlcolorconvert out-pool-size=4 ! capsfilter caps="video/x-raw, format=(string)RGB;" ! appsink max-buffers=2 drop=True name=sen_0
split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1168, height=(int)748;" ! tiovxmultiscaler target=1 ! capsfilter caps="video/x-raw, width=(int)416, height=(int)416;" ! tiovxdlpreproc out-pool-size=4 data-type=3 tensor-format=1 ! capsfilter caps="application/x-tensor-tiovx;" ! appsink max-buffers=2 drop=True name=pre_0
==========[OUTPUT PIPELINE]==========
appsrc do-timestamp=True format=3 block=True name=post_0 ! tiovxdlcolorconvert ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1280, height=(int)720;" ! queue ! mosaic_0.sink_0
tiovxmosaic target=1 background=/tmp/background_0 name=mosaic_0 src::pool-size=4
sink_0::startx="<320>" sink_0::starty="<150>" sink_0::widths="<1280>" sink_0::heights="<720>"
! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080;" ! queue ! tiperfoverlay title=Object Detection ! kmssink sync=False max-lateness=5000000 qos=True processing-deadline=15000000 driver-name=tidss connector-id=40 plane-id=31 force-modesetting=True fd=40
0:00:05.475707905  1280 0xffff8c002160 WARN          v4l2bufferpool gstv4l2bufferpool.c:1334:gst_v4l2_buffer_pool_dqbuf:<source0:pool0:src> Driver should never set v4l2_buffer.field to ANY
0:00:05.778187165  1280 0xffff8c001a10 FIXME               basesink gstbasesink.c:3399:gst_base_sink_default_event:<pre_0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:05.778190250  1280 0xffff8c0017a0 FIXME               basesink gstbasesink.c:3399:gst_base_sink_default_event:<sen_0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:05.841347885  1280 0xffff8c001c80 FIXME             aggregator gstaggregator.c:1448:gst_aggregator_aggregate_func:<tiovxisp0> Subclass should call gst_aggregator_selected_samples() from its aggregate implementation.
0:00:05.841848760  1280 0xffff8c002160 WARN                    v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<source0:src> VIDIOC_CROPCAP failed
Device Tree:
// SPDX-License-Identifier: GPL-2.0
 * AM62A SK: https://www.ti.com/lit/zip/sprr459
 * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/
/dts-v1/;
#include <dt-bindings/leds/common.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/net/ti-dp83867.h>
#include "k3-am62a7.dtsi"
	compatible = "ti,am62a7-sk", "ti,am62a7";
	model = "Texas Instruments AM62A7 SK";
	aliases {
		serial0 = &mcu_uart0;
		serial1 = &wkup_uart0;
		serial2 = &main_uart0;
		mmc0 = &sdhci0;
		mmc1 = &sdhci1;
		ethernet0 = &cpsw_port1;
		spi0 = &ospi0;
	chosen {
		stdout-path = "serial2:115200n8";
	memory@80000000 {
		device_type = "memory";
		/* 4G RAM */
		reg = <0x00000000 0x80000000 0x00000000 0x80000000>,
		      <0x00000008 0x80000000 0x00000000 0x80000000>;
	reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		/* global cma region */
		linux,cma {
			compatible = "shared-dma-pool";
			reusable;
			size = <0x00 0x24000000>;
			alloc-ranges = <0x00 0xc0000000 0x00 0x24000000>;
			linux,cma-default;
		secure_tfa_ddr: tfa@9e780000 {
			reg = <0x00 0x9e780000 0x00 0x80000>;
			alignment = <0x1000>;
			no-map;
		secure_ddr: optee@9e800000 {
			reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
			no-map;
		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9c800000 {
			reg = <0x00 0x9c800000 0x00 0x100000>;
			no-map;
		wkup_r5fss0_core0_memory_region: r5f-dma-memory@9c900000 {
			reg = <0x00 0x9c900000 0x00 0x01e00000>;
			no-map;
		mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@9b800000 {
			reg = <0x00 0x9b800000 0x00 0x100000>;
			no-map;
		mcu_r5fss0_core0_memory_region: r5f-dma-memory@9b900000 {
			reg = <0x00 0x9b900000 0x00 0x0f00000>;
			no-map;
		c7x_0_dma_memory_region: c7x-dma-memory@99800000 {
			reg = <0x00 0x99800000 0x00 0x100000>;
			no-map;
		c7x_0_memory_region: c7x-memory@99900000 {
			reg = <0x00 0x99900000 0x00 0x01f00000>;
			no-map;
		edgeai_rtos_ipc_memory_region: edgeai-rtos-ipc-memory-region {
			reg = <0x00 0xa0000000 0x00 0x01000000>;
			no-map;
		edgeai_memory_region: edgeai-dma-memory@a1000000 {
			reg = <0x00 0xa1000000 0x00 0x02000000>;
			no-map;
		edgeai_shared_region: edgeai_shared-memories {
			compatible = "dma-heap-carveout";
			reg = <0x00 0xa3000000 0x00 0x0b000000>;
		edgeai_core_heaps: edgeai-core-heap-memory@ae000000 {
			reg = <0x00 0xae000000 0x00 0x12000000>;
			no-map;
	opp-table {
		/* Add 1.4GHz OPP for am62p5-sk board. Requires VDD_CORE at 0v85 */
		opp-1400000000 {
			opp-hz = /bits/ 64 <1400000000>;
			opp-supported-hw = <0x01 0x0004>;
			clock-latency-ns = <6000000>;
	vmain_pd: regulator-0 {
		/* TPS25750 PD CONTROLLER OUTPUT */
		compatible = "regulator-fixed";
		regulator-name = "vmain_pd";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-always-on;
		regulator-boot-on;
	vcc_5v0: regulator-1 {
		/* Output of TPS63070 */
		regulator-name = "vcc_5v0";
		vin-supply = <&vmain_pd>;
		regulator-boot-on;
	vcc_3v3_main: regulator-2 {
		/* output of LM5141-Q1 */
		regulator-name = "vcc_3v3_main";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		regulator-boot-on;
	vdd_mmc1: regulator-3 {
		/* TPS22918DBVR */
		regulator-name = "vdd_mmc1";
		regulator-boot-on;
		enable-active-high;
		//gpio = <&exp1 3 GPIO_ACTIVE_HIGH>; //Not connected with the CPU by default pulled high
	vcc_3v3_sys: regulator-4 {
		/* output of TPS222965DSGT */
		regulator-name = "vcc_3v3_sys";
		vin-supply = <&vcc_3v3_main>;
		regulator-boot-on;
	vddshv_sdio: regulator-5 {
		compatible = "regulator-gpio";
		regulator-name = "vddshv_sdio";
		pinctrl-names = "default";
		pinctrl-0 = <&vddshv_sdio_pins_default>;
		regulator-min-microvolt = <1800000>;
		regulator-boot-on;
		vin-supply = <&ldo1>;
		gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
		states = <1800000 0x0>,
			 <3300000 0x1>;
	reg_dummy: regulator-dummy {
		regulator-name = "dummy";
	leds {
		compatible = "gpio-leds";
		pinctrl-0 = <&usr_led_pins_default>;
		led-0 {
			label = "am62a-sk:green:heartbeat";
			gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
			linux,default-trigger = "heartbeat";
			function = LED_FUNCTION_HEARTBEAT;
			default-state = "off";
	tlv320_mclk: clk-0 {
		#clock-cells = <0>;
		compatible = "fixed-clock";
		clock-frequency = <12288000>;
	codec_audio: sound {
		compatible = "simple-audio-card";
		simple-audio-card,name = "AM62Ax-SKEVM";
		simple-audio-card,widgets =
			"Headphone",	"Headphone Jack",
			"Line",		"Line In",
			"Microphone",	"Microphone Jack";
		simple-audio-card,routing =
			"Headphone Jack",	"HPLOUT",
			"Headphone Jack",	"HPROUT",
			"LINE1L",		"Line In",
			"LINE1R",		"Line In",
			"MIC3R",		"Microphone Jack",
			"Microphone Jack",	"Mic Bias";
		simple-audio-card,format = "dsp_b";
		simple-audio-card,bitclock-master = <&sound_master>;
		simple-audio-card,frame-master = <&sound_master>;
		simple-audio-card,bitclock-inversion;
		simple-audio-card,cpu {
			sound-dai = <&mcasp1>;
		sound_master: simple-audio-card,codec {
			sound-dai = <&tlv320aic3106>;
			clocks = <&tlv320_mclk>;
	hdmi: connector {
		compatible = "hdmi-connector";
		label = "hdmi";
		type = "a";
		port {
			hdmi_connector_in: endpoint {
				remote-endpoint = <&sii9022_out>;
	clk_imx219_fixed: imx219-xclk {
		#clock-cells = <0>;
		clock-frequency = <24000000>;
	usb_c_connector: connector {
		compatible = "usb-c-connector";
		label = "micro-usb";
		self-powered;
		data-role = "dual";
		power-role = "sink";
		port {
			usb_con_hs: endpoint {
				remote-endpoint = <&usb0_hs_ep>;
&main_pmx0 {
	main_uart0_pins_default: main-uart0-pins-default {
		pinctrl-single,pins = <
			AM62AX_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
			AM62AX_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
	main_i2c0_pins_default: main-i2c0-pins-default {
			AM62AX_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */
			AM62AX_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */
	main_i2c1_pins_default: main-i2c1-pins-default {
			AM62AX_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */
			AM62AX_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */
	main_i2c2_pins_default: main-i2c2-pins-default {
			AM62AX_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */
			AM62AX_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */
	main_mmc1_pins_default: main-mmc1-pins-default {
			AM62AX_IOPAD(0x23c, PIN_INPUT, 0) /* (A21) MMC1_CMD */
			AM62AX_IOPAD(0x234, PIN_INPUT, 0) /* (B22) MMC1_CLK */
			AM62AX_IOPAD(0x230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */
			AM62AX_IOPAD(0x22c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */
			AM62AX_IOPAD(0x228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */
			AM62AX_IOPAD(0x224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */
			AM62AX_IOPAD(0x240, PIN_INPUT, 0) /* (D17) MMC1_SDCD */
	usr_led_pins_default: usr-led-pins-default {
			AM62AX_IOPAD(0x244, PIN_OUTPUT, 7) /* (D18) MMC1_SDWP.GPIO1_49 */
	main_usb1_pins_default: main-usb1-pins-default {
			AM62AX_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */
	main_mdio1_pins_default: main-mdio1-pins-default {
			AM62AX_IOPAD(0x160, PIN_OUTPUT, 0) /* (V12) MDIO0_MDC */
			AM62AX_IOPAD(0x15c, PIN_INPUT, 0) /* (V13) MDIO0_MDIO */
	main_rgmii1_pins_default: main-rgmii1-pins-default {
			AM62AX_IOPAD(0x14c, PIN_INPUT, 0) /* (AB16) RGMII1_RD0 */
			AM62AX_IOPAD(0x150, PIN_INPUT, 0) /* (V15) RGMII1_RD1 */
			AM62AX_IOPAD(0x154, PIN_INPUT, 0) /* (W15) RGMII1_RD2 */
			AM62AX_IOPAD(0x158, PIN_INPUT, 0) /* (V14) RGMII1_RD3 */
			AM62AX_IOPAD(0x148, PIN_INPUT, 0) /* (AA16) RGMII1_RXC */
			AM62AX_IOPAD(0x144, PIN_INPUT, 0) /* (AA15) RGMII1_RX_CTL */
			AM62AX_IOPAD(0x134, PIN_INPUT, 0) /* (Y17) RGMII1_TD0 */
			AM62AX_IOPAD(0x138, PIN_INPUT, 0) /* (V16) RGMII1_TD1 */
			AM62AX_IOPAD(0x13c, PIN_INPUT, 0) /* (Y16) RGMII1_TD2 */
			AM62AX_IOPAD(0x140, PIN_INPUT, 0) /* (AA17) RGMII1_TD3 */
			AM62AX_IOPAD(0x130, PIN_INPUT, 0) /* (AB17) RGMII1_TXC */
			AM62AX_IOPAD(0x12c, PIN_INPUT, 0) /* (W16) RGMII1_TX_CTL */
	main_mcasp1_pins_default: main-mcasp1-pins-default {
			AM62AX_IOPAD(0x090, PIN_INPUT, 2) /* (L19) GPMC0_BE0n_CLE.MCASP1_ACLKX */
			AM62AX_IOPAD(0x098, PIN_INPUT, 2) /* (R18) GPMC0_WAIT0.MCASP1_AFSX */
			AM62AX_IOPAD(0x08c, PIN_OUTPUT, 2) /* (K19) GPMC0_WEn.MCASP1_AXR0 */
			AM62AX_IOPAD(0x084, PIN_INPUT, 2) /* (L18) GPMC0_ADVn_ALE.MCASP1_AXR2 */
	main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-pins-default {
			AM62AX_IOPAD(0x01d4, PIN_INPUT, 7) // (C15) UART0_RTSn.GPIO1_23
	main_dss0_pins_default: main-dss0-pins-default {
			AM62AX_IOPAD(0x100, PIN_OUTPUT, 0) /* (V17) VOUT0_VSYNC */
			AM62AX_IOPAD(0x0f8, PIN_OUTPUT, 0) /* (T18) VOUT0_HSYNC */
			AM62AX_IOPAD(0x104, PIN_OUTPUT, 0) /* (AA22) VOUT0_PCLK */
			AM62AX_IOPAD(0x0fc, PIN_OUTPUT, 0) /* (U17) VOUT0_DE */
			AM62AX_IOPAD(0x0b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */
			AM62AX_IOPAD(0x0bc, PIN_OUTPUT, 0) /* (U21) VOUT0_DATA1 */
			AM62AX_IOPAD(0x0c0, PIN_OUTPUT, 0) /* (U20) VOUT0_DATA2 */
			AM62AX_IOPAD(0x0c4, PIN_OUTPUT, 0) /* (U19) VOUT0_DATA3 */
			AM62AX_IOPAD(0x0c8, PIN_OUTPUT, 0) /* (T19) VOUT0_DATA4 */
			AM62AX_IOPAD(0x0cc, PIN_OUTPUT, 0) /* (U18) VOUT0_DATA5 */
			AM62AX_IOPAD(0x0d0, PIN_OUTPUT, 0) /* (V22) VOUT0_DATA6 */
			AM62AX_IOPAD(0x0d4, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA7 */
			AM62AX_IOPAD(0x0d8, PIN_OUTPUT, 0) /* (V19) VOUT0_DATA8 */
			AM62AX_IOPAD(0x0dc, PIN_OUTPUT, 0) /* (V18) VOUT0_DATA9 */
			AM62AX_IOPAD(0x0e0, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA10 */
			AM62AX_IOPAD(0x0e4, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA11 */
			AM62AX_IOPAD(0x0e8, PIN_OUTPUT, 0) /* (W20) VOUT0_DATA12 */
			AM62AX_IOPAD(0x0ec, PIN_OUTPUT, 0) /* (W19) VOUT0_DATA13 */
			AM62AX_IOPAD(0x0f0, PIN_OUTPUT, 0) /* (Y21) VOUT0_DATA14 */
			AM62AX_IOPAD(0x0f4, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA15 */
			AM62AX_IOPAD(0x05c, PIN_OUTPUT, 1) /* (P22) GPMC0_AD8.VOUT0_DATA16 */
			AM62AX_IOPAD(0x060, PIN_OUTPUT, 1) /* (R19) GPMC0_AD9.VOUT0_DATA17 */
			AM62AX_IOPAD(0x064, PIN_OUTPUT, 1) /* (R20) GPMC0_AD10.VOUT0_DATA18 */
			AM62AX_IOPAD(0x068, PIN_OUTPUT, 1) /* (R22) GPMC0_AD11.VOUT0_DATA19 */
			AM62AX_IOPAD(0x06c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */
			AM62AX_IOPAD(0x070, PIN_OUTPUT, 1) /* (R21) GPMC0_AD13.VOUT0_DATA21 */
			AM62AX_IOPAD(0x074, PIN_OUTPUT, 1) /* (T20) GPMC0_AD14.VOUT0_DATA22 */
			AM62AX_IOPAD(0x078, PIN_OUTPUT, 1) /* (T21) GPMC0_AD15.VOUT0_DATA23 */
	main_mmc0_pins_default: main-mmc0-pins-default {
			AM62AX_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */
			AM62AX_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLKLB */
			AM62AX_IOPAD(0x21c, PIN_INPUT, 0) /* (AB1) MMC0_CLK */
			AM62AX_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */
			AM62AX_IOPAD(0x210, PIN_INPUT_PULLUP, 0) /* (AA1) MMC0_DAT1 */
			AM62AX_IOPAD(0x20c, PIN_INPUT_PULLUP, 0) /* (AA3) MMC0_DAT2 */
			AM62AX_IOPAD(0x208, PIN_INPUT_PULLUP, 0) /* (Y4) MMC0_DAT3 */
			AM62AX_IOPAD(0x204, PIN_INPUT_PULLUP, 0) /* (AB2) MMC0_DAT4 */
			AM62AX_IOPAD(0x200, PIN_INPUT_PULLUP, 0) /* (AC1) MMC0_DAT5 */
			AM62AX_IOPAD(0x1fc, PIN_INPUT_PULLUP, 0) /* (AD2) MMC0_DAT6 */
			AM62AX_IOPAD(0x1f8, PIN_INPUT_PULLUP, 0) /* (AC2) MMC0_DAT7 */
	vddshv_sdio_pins_default: vddshv-sdio-pins-default {
			AM62AX_IOPAD(0x07c, PIN_OUTPUT, 7) /* (M19) GPMC0_CLK.GPIO0_31 */
	can_pins_default: can-pins-default {
			AM62AX_IOPAD(0x1d8, PIN_INPUT, 0)
			AM62AX_IOPAD(0x1dc, PIN_OUTPUT, 0)
	cam_pins_default: cam-pins_default {
			AM62AX_IOPAD(0x1b4, PIN_OUTPUT, 7) /* (D16) SPI0_CS */
			AM62AX_IOPAD(0x1b8, PIN_OUTPUT, 7) /* (C16) SPI1_CS */
	hdmi_interrupt_pin_default: hdmi_interrupt-pin_default {
			/*AM62AX_IOPAD(0x018, PIN_INPUT, 7) /* (H18) HDMI Interrupt */
			AM62AX_IOPAD(0x018, PIN_INPUT_PULLUP | PIN_DEBOUNCE_CONF6, 7) /* (H18) HDMI Interrupt */
			AM62AX_IOPAD(0x010, PIN_OUTPUT, 7) /* (J18) HDMI Reset */
	main_gpio0_pin_default: main_gpio0-pin_default {
			AM62AX_IOPAD(0x004, PIN_OUTPUT, 7) /* (K22) Modem Reset */
			AM62AX_IOPAD(0x030, PIN_OUTPUT, 7) /* (G19) RF_Disable */
			AM62AX_IOPAD(0x034, PIN_OUTPUT, 7) /* (K20) RF_Disable */
			AM62AX_IOPAD(0x02C, PIN_OUTPUT, 7) /* (H21) FLASH_led */
			AM62AX_IOPAD(0x01C, PIN_INPUT, 7) /* (K21) IGNITION */
/* m2interface: m2-interface@1{
        pinctrl-0 = <&ospi0_pins_default>;
	status = "okay";
	reset-gpios = <&main_gpio0 1 GPIO_ACTIVE_LOW>;
	mpu_disable{
		label = "mpu-disable";
		gpios = <&main_gpio0 12 GPIO_ACTIVE_LOW>;
	gps_disable{
                label = "gps-disable";
                gpios = <&main_gpio0 13 GPIO_ACTIVE_LOW>;
&main_mcan0{
        pinctrl-0 = <&can_pins_default>;
	status = "okay";
&mcu_pmx0 {
	status = "okay";
	pmic_irq_pins_default: pmic-irq-pins-default {
			AM62AX_MCU_IOPAD(0x000, PIN_INPUT, 7) /* (E11) MCU_GPIO0_0 */
&mcu_gpio0 {
	status = "okay";
&main_i2c0 {
	status = "okay";
	pinctrl-0 = <&main_i2c0_pins_default>;
	clock-frequency = <400000>;
	tps659312: pmic@48 {
		compatible = "ti,tps6593-q1";
		reg = <0x48>;
		ti,primary-pmic;
		system-power-controller;
		gpio-controller;
		#gpio-cells = <2>;
		pinctrl-0 = <&pmic_irq_pins_default>;
		interrupt-parent = <&mcu_gpio0>;
		interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
		buck123-supply = <&vcc_3v3_sys>;
		buck4-supply = <&vcc_3v3_sys>;
		buck5-supply = <&vcc_3v3_sys>;
		ldo1-supply = <&vcc_3v3_sys>;
		ldo2-supply = <&vcc_3v3_sys>;
		ldo3-supply = <&buck5>;
		ldo4-supply = <&vcc_3v3_sys>;
		regulators {
			buck123: buck123 {
				regulator-name = "vcc_core";
				regulator-min-microvolt = <715000>;
				regulator-max-microvolt = <895000>;
				regulator-boot-on;
			buck4: buck4 {
				regulator-name = "vcc_1v1";
				regulator-min-microvolt = <1100000>;
				regulator-max-microvolt = <1100000>;
				regulator-boot-on;
			buck5: buck5 {
				regulator-name = "vcc_1v8_sys";
				regulator-max-microvolt = <1800000>;
				regulator-boot-on;
			ldo1: ldo1 {
				regulator-name = "vddshv5_sdio";
				regulator-boot-on;
			ldo2: ldo2 {
				regulator-name = "vpp_1v8";
				regulator-boot-on;
			ldo3: ldo3 {
				regulator-name = "vcc_0v85";
				regulator-min-microvolt = <850000>;
				regulator-max-microvolt = <850000>;
				regulator-boot-on;
			ldo4: ldo4 {
				regulator-name = "vdda_1v8";
				regulator-boot-on;
&main_i2c1 {
	status = "okay";
	pinctrl-0 = <&main_i2c1_pins_default>;
	clock-frequency = <100000>;
	tlv320aic3106: audio-codec@1b {
		#sound-dai-cells = <0>;
		compatible = "ti,tlv320aic3106";
		reg = <0x1b>;
		ai3x-micbias-vg = <1>;	/* 2.0V */
		ai3x-ocmv = <1>;	/* 1.5V */
		/* Regulators */
		AVDD-supply = <&vcc_3v3_sys>;
		IOVDD-supply = <&vcc_3v3_sys>;
		DRVDD-supply = <&vcc_3v3_sys>;
	sii9022: sii9022@3b {
		//#sound-dai-cells = <0>;
		compatible = "sil,sii9022";
		reg = <0x3b>;
		status = "okay";
		//ti,no-reset-on-init;
		pinctrl-0 = <&hdmi_interrupt_pin_default>;
		interrupt-parent = <&main_gpio0>;
		interrupts = <6 IRQ_TYPE_EDGE_FALLING>;
		//reset-gpios = <&main_gpio0 4 GPIO_ACTIVE_HIGH>; //010
		//sil,i2s-data-lanes = < 0 >;
		ports {
			#address-cells = <1>;
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				sii9022_in: endpoint {
					//bus-width = <24>;
					remote-endpoint = <&dpi1_out>;
			port@1 {
				reg = <1>;
				sii9022_out: endpoint {
					remote-endpoint = <&hdmi_connector_in>;
&sdhci1 {
	/* SD/MMC */
	status = "okay";
	vmmc-supply = <&vdd_mmc1>;
	vqmmc-supply = <&vddshv_sdio>;
	pinctrl-0 = <&main_mmc1_pins_default>;
	//ti,driver-strength-ohm = <50>;
	disable-wp;
	no-1-8-v;
&main_gpio0 {
	status = "okay";
	pinctrl-0 = <&main_gpio0_pin_default>;
	gpio-line-names = "MODEM_RESET", "MODED_RF_OFF",
					  "MODEM_GPS_OFF", "FLASH_LED",
					  "IGNITION" ;
/*	modem_reset {
		gpio-hog;
		gpios = <1 GPIO_ACTIVE_LOW>;
		output-low;
		line-name = "MODEM_RESET";
	modem_rf_off {
		gpio-hog;
		gpios = <12 GPIO_ACTIVE_HIGH>;
		output-low;
		line-name = "MODED_RF_OFF";
	modem_gps_off {
		gpio-hog;
		gpios = <13 GPIO_ACTIVE_HIGH>;
		output-low;
		line-name = "MODED_GPS_OFF";
	flash_led {
		gpio-hog;
		gpios = <11 GPIO_ACTIVE_HIGH>;
		output-low;
		line-name = "FLASH_LED";
	ignition {
		gpio-hog;
		gpios = <7 GPIO_ACTIVE_HIGH>;
		output-low;
		line-name = "IGNITION";
&main_gpio1 {
	status = "okay";
	//pinctrl-names = "default";
	//pinctrl-0 = <&cam_pins_default>;
	/*gpio-line-names = "CSI_RESET",	//gpio1 15
					  "CSI_ENABLE";	//gpio1 16
	csi_reset {
		gpio-hog;
		gpios = <15 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "CSI_RESET";
	csi_enable {
		gpio-hog;
		gpios = <16 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "CSI_ENABLE";
&main_gpio_intr {
	status = "okay";
&main_uart0 {
	status = "okay";
	pinctrl-0 = <&main_uart0_pins_default>;
	interrupts-extended = <&gic500 GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>,
			<&main_pmx0 0x1c8>; /* (D14) UART0_RXD PADCONFIG114 */
	interrupt-names = "irq", "wakeup";
&usbss0 {
	status = "okay";
	ti,vbus-divider;
&usb0 {
	status = "okay";
	usb-role-switch;
	port {
		usb0_hs_ep: endpoint {
			remote-endpoint = <&usb_con_hs>;
&usbss1 {
	status = "okay";
&usb1 {
	dr_mode = "host";
	pinctrl-0 = <&main_usb1_pins_default>;
	connector {
                compatible = "usb-a-connector";
&cpsw3g {
	status = "okay";
	pinctrl-0 = <&main_rgmii1_pins_default>;
	cpts@3d000 {
		/* MAP HW3_TS_PUSH to GENF1 */
		ti,pps = <2 1>;
&cpsw_port1 {
	status = "okay";
	phy-mode = "rgmii-rxid";
	phy-handle = <&cpsw3g_phy0>;
&cpsw_port2 {
	status = "disabled";
&cpsw3g_mdio {
	status = "okay";
	pinctrl-0 = <&main_mdio1_pins_default>;
	cpsw3g_phy0: ethernet-phy@0 {
		reg = <0>;
		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
		ti,min-output-impedance;
&mcasp1 {
	status = "okay";
	pinctrl-0 = <&main_mcasp1_pins_default>;
	op-mode = <0>;          /* MCASP_IIS_MODE */
	tdm-slots = <2>;
	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
	       1 0 2 0
	       0 0 0 0
	       0 0 0 0
	       0 0 0 0
	tx-num-evt = <32>;
	rx-num-evt = <32>;
&ti_csi2rx0 {
	status = "okay";
&dphy0 {
	status = "okay";
&dss {
	status = "okay";
	pinctrl-0 = <&main_dss0_pins_default>;
&dss_ports {
	/* VP2: DPI Output */
	hdmi0_dss: port@1 {
		reg = <1>;
		dpi1_out: endpoint {
			remote-endpoint = <&sii9022_in>;
&mailbox0_cluster0 {
	ti,mbox-num-fifos = <2>;
	mbox_r5_0: mbox-r5-0 {
		ti,mbox-rx = <0 0 0>;
		ti,mbox-tx = <1 0 0>;
&mailbox0_cluster1 {
	mbox_c7x_0: mbox-c7x-0 {
&mailbox0_cluster2 {
	mbox_mcu_r5_0: mbox-mcu-r5-0 {
&c7x_0 {
	mboxes = <&mailbox0_cluster1>, <&mbox_c7x_0>;
	memory-region = <&c7x_0_dma_memory_region>,
			<&c7x_0_memory_region>;
&wkup_r5fss0_core0 {
	mboxes = <&mailbox0_cluster0>, <&mbox_r5_0>;
	memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
		<&wkup_r5fss0_core0_memory_region>;
&mcu_r5fss0_core0 {
	mboxes = <&mailbox0_cluster2>, <&mbox_mcu_r5_0>;
	memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
			<&mcu_r5fss0_core0_memory_region>;
#define K3_TS_OFFSET(pa, val)	(0x4+(pa)*4) (0x10000 | val)
&timesync_router {
	status = "okay";
	pinctrl-0 = <&cpsw_cpts>;
	/* Use Time Sync Router to map GENF1 input to HW3_TS_PUSH output */
	cpsw_cpts: cpsw-cpts {
			/* pps [cpsw cpts genf1] in17 -> out12 [cpsw cpts hw3_push] */
			K3_TS_OFFSET(12, 17)
&fss {
	status = "okay";
&sdhci0 {
	status = "okay";
	pinctrl-0 = <&main_mmc0_pins_default>;
	disable-wp;
&main_i2c2 {
	status = "okay";
	pinctrl-0 = <&main_i2c2_pins_default>;
	ov5640: camera@10 {
		compatible = "sony,imx219";
		reg = <0x10>;
		clocks = <&clk_imx219_fixed>;
		clock-names = "xclk";
		reset-gpios = <&main_gpio1 15 GPIO_ACTIVE_HIGH>;
		/* Add dummy regulators */
		vanasupply = <&reg_dummy>;
		vdig-supply = <&reg_dummy>;
		vddl-supply = <&reg_dummy>;
		port {
			csi2_cam0: endpoint {
					remote-endpoint = <&csi2rx0_in_sensor>;
					link-frequencies = /bits/ 64 <456000000>;
					clock-lanes = <0>;
					data-lanes = <1 2>;
&csi0_port0 {
        status = "okay";
        csi2rx0_in_sensor: endpoint {
            remote-endpoint = <&csi2_cam0>;
            bus-type = <4>; /* CSI2 DPHY. */
            clock-lanes = <0>;
            data-lanes = <1 2>;
XML File
title: "Object Detection"
log_level: 2
inputs:
    input0:
        source: /dev/video-imx219-cam0
        subdev-id: /dev/v4l-imx219-subdev0
        format: rggb
        width: 1920
        height: 1080
        framerate: 30
    input1:
        source: /opt/edgeai-test-data/videos/video0_1280_768.h264
        format: h264
        width: 1280
        height: 768
        framerate: 30
        loop: True
    input2:
        source: /opt/edgeai-test-data/images/%04d.jpg
        width: 1280
        height: 720
        index: 0
        framerate: 1
        loop: True
models:
    model0:
        model_path: /opt/model_zoo/TVM-OD-5120-ssdLite-mobDet-DSP-coco-320x320
        viz_threshold: 0.6
    model1:
        model_path: /opt/model_zoo/TFL-OD-2020-ssdLite-mobDet-DSP-coco-320x320
        viz_threshold: 0.6
    model2:
        model_path: /opt/model_zoo/ONR-OD-8200-yolox-nano-lite-mmdet-coco-416x416
        viz_threshold: 0.6
outputs:
    output0:
        sink: kmssink
        width: 1920
        height: 1080
        overlay-perf-type: graph
    output1:
        sink: /opt/edgeai-test-data/output/output_video0.mkv
        width: 1920
        height: 1080
    output2:
        sink: /opt/edgeai-test-data/output/output_image_%04d.jpg
        width: 1920
        height: 1080
    output3:
        sink: remote
        width: 1920
        height: 1080
        port: 8081
        host: 127.0.0.1
        encoding: jpeg
flows:
    flow0: [input0,model2,output0,[320,150,1280,720]]
Boot Log:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.6.32-ti-g32e5747cb891 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM62A7 SK
[    0.000000] earlycon: ns16550a0 at I/O port 0x0 (options '')
[    0.000000] Malformed early option 'earlycon'
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000c0000000..0x00000000e3ffffff (589824 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000099800000..0x00000000998fffff (1024 KiB) nomap non-reusable c7x-dma-memory@99800000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000099900000..0x000000009b7fffff (31744 KiB) nomap non-reusable c7x-memory@99900000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9b800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable r5f-dma-memory@9b900000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-dma-memory@9c900000
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a0ffffff (16384 KiB) nomap non-reusable edgeai-rtos-ipc-memory-region
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a2ffffff (32768 KiB) nomap non-reusable edgeai-dma-memory@a1000000
[    0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout
[    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000adffffff (180224 KiB) map non-reusable edgeai_shared-memories
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 288 MiB
[    0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ae000000..0x00000000bfffffff (294912 KiB) nomap non-reusable edgeai-core-heap-memory@ae000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
[    0.000000]   node   0: [mem 0x0000000080080000-0x00000000997fffff]
[    0.000000]   node   0: [mem 0x0000000099800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a2ffffff]
[    0.000000]   node   0: [mem 0x00000000a3000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000bfffffff]
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s43112 r8192 d30616 u81920
[    0.000000] pcpu-alloc: s43112 r8192 d30616 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a root=/dev/mmcblk1p2 rootfstype=ext4 rootwait loglevel=7
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 2807560K/4194304K available (12224K kernel code, 1262K rwdata, 4072K rodata, 2432K init, 506K bss, 796920K reserved, 589824K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.000307] Console: colour dummy device 80x25
[    0.000353] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.000364] pid_max: default: 32768 minimum: 301
[    0.000440] LSM: initializing lsm=capability,integrity
[    0.000536] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.000554] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002166] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.002231] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.002402] rcu: Hierarchical SRCU implementation.
[    0.002406] rcu:     Max phase no-delay instances is 1000.
[    0.002635] Platform MSI: msi-controller@1820000 domain created
[    0.002815] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.003038] EFI services will not be available.
[    0.003267] smp: Bringing up secondary CPUs ...
[    0.003848] Detected VIPT I-cache on CPU1
[    0.003914] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.003930] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[    0.003975] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.004635] Detected VIPT I-cache on CPU2
[    0.004689] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.004703] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
[    0.004736] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.005319] Detected VIPT I-cache on CPU3
[    0.005369] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.005383] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
[    0.005413] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.005486] smp: Brought up 1 node, 4 CPUs
[    0.005492] SMP: Total of 4 processors activated.
[    0.005497] CPU features: detected: 32-bit EL0 Support
[    0.005501] CPU features: detected: CRC32 instructions
[    0.005557] CPU: All CPU(s) started at EL2
[    0.005560] alternatives: applying system-wide alternatives
[    0.007059] devtmpfs: initialized
[    0.015959] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.015983] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.029658] pinctrl core: initialized pinctrl subsystem
[    0.030088] DMI not present or invalid.
[    0.030667] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.031417] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.031534] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.031691] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.031747] audit: initializing netlink subsys (disabled)
[    0.031905] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1
[    0.032332] thermal_sys: Registered thermal governor 'step_wise'
[    0.032338] thermal_sys: Registered thermal governor 'power_allocator'
[    0.032381] cpuidle: using governor menu
[    0.032530] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.032613] ASID allocator initialised with 65536 entries
[    0.044372] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
[    0.046054] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[    0.048043] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[    0.048468] Modules: 27600 pages in range for non-PLT usage
[    0.048473] Modules: 519120 pages in range for PLT usage
[    0.049162] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.049171] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.049176] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.049179] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.049183] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.049186] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.049191] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.049194] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.050487] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
[    0.051172] iommu: Default domain type: Translated
[    0.051182] iommu: DMA domain TLB invalidation policy: strict mode
[    0.051450] SCSI subsystem initialized
[    0.051607] libata version 3.00 loaded.
[    0.051769] usbcore: registered new interface driver usbfs
[    0.051796] usbcore: registered new interface driver hub
[    0.051826] usbcore: registered new device driver usb
[    0.052323] pps_core: LinuxPPS API ver. 1 registered
[    0.052327] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.052339] PTP clock support registered
[    0.052497] EDAC MC: Ver: 3.0.0
[    0.052949] scmi_core: SCMI protocol bus registered
[    0.053190] FPGA manager framework
[    0.053272] Advanced Linux Sound Architecture Driver Initialized.
[    0.054132] vgaarb: loaded
[    0.054429] clocksource: Switched to clocksource arch_sys_counter
[    0.054633] VFS: Disk quotas dquot_6.6.0
[    0.054660] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.060789] Carveout Heap: Exported 176 MiB at 0x00000000a3000000
[    0.060892] NET: Registered PF_INET protocol family
[    0.061078] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.063964] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.064007] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.064058] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.064272] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.065081] TCP: Hash tables configured (established 32768 bind 32768)
[    0.065217] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.065304] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.065529] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.065950] RPC: Registered named UNIX socket transport module.
[    0.065958] RPC: Registered udp transport module.
[    0.065961] RPC: Registered tcp transport module.
[    0.065964] RPC: Registered tcp-with-tls transport module.
[    0.065966] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.065974] NET: Registered PF_XDP protocol family
[    0.065993] PCI: CLS 0 bytes, default 64
[    0.067263] Initialise system trusted keyrings
[    0.067453] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.067738] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.067969] NFS: Registering the id_resolver key type
[    0.067991] Key type id_resolver registered
[    0.067994] Key type id_legacy registered
[    0.068012] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.068016] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.101672] Key type asymmetric registered
[    0.101681] Asymmetric key parser 'x509' registered
[    0.101730] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.101856] io scheduler mq-deadline registered
[    0.101862] io scheduler kyber registered
[    0.101890] io scheduler bfq registered
[    0.104767] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.105384] pinctrl-single f4000.pinctrl: 151 pins, size 604
[    0.106903] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.112983] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.123166] loop: module loaded
[    0.124094] megasas: 07.725.01.00-rc1
[    0.127589] tun: Universal TUN/TAP device driver, 1.6
[    0.128184] PPP generic driver version 2.4.2
[    0.128614] VFIO - User Level meta-driver version: 0.3
[    0.129710] usbcore: registered new interface driver usb-storage
[    0.130237] i2c_dev: i2c /dev entries driver
[    0.131728] sdhci: Secure Digital Host Controller Interface driver
[    0.131736] sdhci: Copyright(c) Pierre Ossman
[    0.131951] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.132672] ledtrig-cpu: registered to indicate activity on CPUs
[    0.132951] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.133605] usbcore: registered new interface driver usbhid
[    0.133609] usbhid: USB HID core driver
[    0.133880] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[    0.134028] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[    0.134137] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[    0.134194] omap-mailbox 29030000.mailbox: no available mbox devices found
[    0.135481] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.136055] optee: probing for conduit method.
[    0.136082] optee: revision 4.2 (12d7c4ee)
[    0.136349] optee: dynamic shared memory is enabled
[    0.137004] random: crng init done
[    0.137080] optee: initialized driver
[    0.138595] Initializing XFRM netlink socket
[    0.138627] NET: Registered PF_PACKET protocol family
[    0.138691] Key type dns_resolver registered
[    0.146340] registered taskstats version 1
[    0.146496] Loading compiled-in X.509 certificates
[    0.158536] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[    0.197669] i2c 0-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@48/regulators/buck5
[    0.197868] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    0.199330] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[    0.199399] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
[    0.199497] i2c 1-003b: Fixed dependency cycle(s) with /connector
[    0.199544] i2c 1-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.199717] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    0.200831] i2c 2-0010: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[    0.201033] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    0.201301] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    0.201436] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    0.201644] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    0.201898] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
[    0.202574] ti-udma 485c0100.dma-controller: Number of rings: 82
[    0.205108] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    0.207595] ti-udma 485c0000.dma-controller: Number of rings: 150
[    0.212253] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    0.214122] ti-udma 4e230000.dma-controller: Number of rings: 6
[    0.214711] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
[    0.215830] printk: console [ttyS2] disabled
[    0.216130] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 253, base_baud = 3000000) is a 8250
[    0.216175] printk: console [ttyS2] enabled
[    1.978441] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.986467] mdio_bus 8000f00.mdio: MDIO device at address 0 is missing.
[    1.993123] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    2.006082] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    2.013215] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    2.019629] pps pps0: new PPS source ptp0
[    2.023911] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    2.037762] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    2.049205] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.054766] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.062550] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    2.068557] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
[    2.078002] xhci-hcd xhci-hcd.0.auto: irq 268, io mem 0x31100000
[    2.084768] hub 1-0:1.0: USB hub found
[    2.088568] hub 1-0:1.0: 1 port detected
[    2.094040] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
[    2.106388] mmc0: CQHCI version 5.10
[    2.151221] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    2.237234] mmc0: Command Queue Engine enabled
[    2.241713] mmc0: new HS200 MMC card at address 0001
[    2.247318] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    2.253211]  mmcblk0: p1 p2
[    2.256647] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    2.262611] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    2.268448] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    2.346449] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    2.426800] tps6594-rtc tps6594-rtc.5.auto: registered as rtc0
[    2.432780] tps6594-rtc tps6594-rtc.5.auto: hctosys: unable to read the hardware clock
[    2.442590] mmc1: CQHCI version 5.10
[    2.487228] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    2.496791] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.504147] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.512714] clk: Disabling unused clocks
[    2.521317] ALSA device list:
[    2.524372]   No soundcards found.
[    2.549231] mmc1: new high speed SDXC card at address 59b4
[    2.555272] mmcblk1: mmc1:59b4 SD64G 59.4 GiB
[    2.561850]  mmcblk1: p1 p2
[    2.704543] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
[    2.711872] EXT4-fs (mmcblk1p2): write access will be enabled during recovery
[    3.100078] EXT4-fs (mmcblk1p2): orphan cleanup on readonly fs
[    3.108100] EXT4-fs (mmcblk1p2): recovery complete
[    3.123125] EXT4-fs (mmcblk1p2): mounted filesystem facd0c37-449c-455c-bde6-37d1707798d6 ro with ordered data mode. Quota mode: none.
[    3.135218] VFS: Mounted root (ext4 filesystem) readonly on device 179:98.
[    3.143406] devtmpfs: mounted
[    3.147003] Freeing unused kernel memory: 2432K
[    3.151572] Run /sbin/init as init process
[    3.155662]   with arguments:
[    3.155665]     /sbin/init
[    3.155668]   with environment:
[    3.155670]     HOME=/
[    3.155673]     TERM=linux
[    3.676640] systemd[1]: System time before build time, advancing clock.
[    3.772987] NET: Registered PF_INET6 protocol family
[    3.778804] Segment Routing with IPv6
[    3.782523] In-situ OAM (IOAM) with IPv6
[    3.850701] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    3.882533] systemd[1]: Detected architecture arm64.
[    3.912338] systemd[1]: Hostname set to <proctor-am62a7-v2>.
[    4.019878] systemd-sysv-generator[105]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    4.247138] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.363304] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.451378] systemd[1]: Queued start job for default target Graphical Interface.
[    4.487612] systemd[1]: Created slice Slice /system/getty.
[    4.512595] systemd[1]: Created slice Slice /system/modprobe.
[    4.536543] systemd[1]: Created slice Slice /system/serial-getty.
[    4.560009] systemd[1]: Created slice User and Session Slice.
[    4.582834] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.606740] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.630606] systemd[1]: Expecting device /dev/ttyS2...
[    4.650629] systemd[1]: Reached target Path Units.
[    4.670551] systemd[1]: Reached target Remote File Systems.
[    4.690541] systemd[1]: Reached target Slice Units.
[    4.710546] systemd[1]: Reached target Swaps.
[    4.765819] systemd[1]: Listening on RPCbind Server Activation Socket.
[    4.786695] systemd[1]: Reached target RPC Port Mapper.
[    4.813434] systemd[1]: Listening on Process Core Dump Socket.
[    4.834891] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    4.859512] systemd[1]: Listening on Journal Audit Socket.
[    4.883161] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.907145] systemd[1]: Listening on Journal Socket.
[    4.927305] systemd[1]: Listening on Network Service Netlink Socket.
[    4.953887] systemd[1]: Listening on udev Control Socket.
[    4.975056] systemd[1]: Listening on udev Kernel Socket.
[    4.995062] systemd[1]: Listening on User Database Manager Socket.
[    5.046770] systemd[1]: Mounting Huge Pages File System...
[    5.070580] systemd[1]: Mounting POSIX Message Queue File System...
[    5.098240] systemd[1]: Mounting Kernel Debug File System...
[    5.119022] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    5.136414] systemd[1]: Mounting Temporary Directory /tmp...
[    5.181383] systemd[1]: Starting Create List of Static Device Nodes...
[    5.206647] systemd[1]: Starting Load Kernel Module configfs...
[    5.234557] systemd[1]: Starting Load Kernel Module drm...
[    5.262786] systemd[1]: Starting Load Kernel Module fuse...
[    5.291015] systemd[1]: Starting Start psplash boot splash screen...
[    5.320408] systemd[1]: Starting RPC Bind...
[    5.335688] fuse: init (API version 7.39)
[    5.346886] systemd[1]: Starting File System Check on Root Device...
[    5.421896] systemd[1]: Starting Journal Service...
[    5.453306] systemd[1]: Starting Load Kernel Modules...
[    5.465530] systemd[1]: Starting Generate network units from Kernel command line...
[    5.480070] systemd[1]: Starting Coldplug All udev Devices...
[    5.493920] systemd[1]: Started RPC Bind.
[    5.500473] systemd[1]: Mounted Huge Pages File System.
[    5.510237] systemd[1]: Mounted POSIX Message Queue File System.
[    5.521958] systemd[1]: Mounted Kernel Debug File System.
[    5.533371] systemd[1]: Mounted Temporary Directory /tmp.
[    5.545692] systemd[1]: Finished Create List of Static Device Nodes.
[    5.549512] cryptodev: loading out-of-tree module taints kernel.
[    5.564241] cryptodev: driver 1.13 loaded.
[    5.564534] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    5.581310] systemd[1]: Finished Load Kernel Module configfs.
[    5.584961] systemd-journald[126]: Collecting audit messages is enabled.
[    5.595550] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    5.607112] systemd[1]: Finished Load Kernel Module drm.
[    5.614012] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    5.625837] systemd[1]: Finished Load Kernel Module fuse.
[    5.635474] systemd[1]: psplash-start.service: Main process exited, code=exited, status=255/EXCEPTION
[    5.650113] systemd[1]: psplash-start.service: Failed with result 'exit-code'.
[    5.658264] systemd[1]: Failed to start Start psplash boot splash screen.
[    5.702614] systemd[1]: Dependency failed for Start psplash-systemd progress communication helper.
[    5.726624] systemd[1]: psplash-systemd.service: Job psplash-systemd.service/start failed with result 'dependency'.
[    5.737925] systemd[1]: Started Journal Service.
[    5.972737] EXT4-fs (mmcblk1p2): re-mounted facd0c37-449c-455c-bde6-37d1707798d6 r/w. Quota mode: none.
[    6.129243] systemd-journald[126]: Received client request to flush runtime journal.
[    6.276883] audit: type=1334 audit(1709054766.596:2): prog-id=6 op=LOAD
[    6.283674] audit: type=1334 audit(1709054766.604:3): prog-id=7 op=LOAD
[    6.491855] audit: type=1334 audit(1709054766.812:4): prog-id=8 op=LOAD
[    6.530006] audit: type=1334 audit(1709054766.848:5): prog-id=9 op=LOAD
[    6.663501] audit: type=1334 audit(1709054766.984:6): prog-id=10 op=LOAD
[    6.673234] audit: type=1334 audit(1709054766.984:7): prog-id=11 op=LOAD
[    6.681893] audit: type=1334 audit(1709054766.992:8): prog-id=12 op=LOAD
[    7.398719] CAN device driver interface
[    7.416793] m_can_platform 20701000.can: m_can device registered (irq=539, version=32)
[    7.464070] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
[    7.522929] mc: Linux media interface: v0.10
[    7.574161] videodev: Linux video capture interface: v2.00
[    7.582584] audit: type=1334 audit(1709124495.340:9): prog-id=13 op=LOAD
[    7.648399] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
[    7.649543] platform 79000000.r5f: configured R5F for remoteproc mode
[    7.666323] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[    7.677363] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
[    7.680378] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
[    7.680884] imx219 2-0010: supply VANA not found, using dummy regulator
[    7.701269] k3-dsp-rproc 7e000000.dsp: local reset is deasserted for device
[    7.702133] imx219 2-0010: supply VDIG not found, using dummy regulator
[    7.716262] imx219 2-0010: supply VDDL not found, using dummy regulator
[    7.718601] remoteproc remoteproc1: 79000000.r5f is available
[    7.734577] remoteproc remoteproc0: 7e000000.dsp is available
[    7.763103] remoteproc remoteproc1: powering up 79000000.r5f
[    7.768922] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 53172
[    7.799910] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    7.812051] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node r5f-dma-memory@9b800000
[    7.812786] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
[    7.821928] virtio_rpmsg_bus virtio0: rpmsg host is online
[    7.821978] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    7.822068] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    7.846479] platform 78000000.r5f: configured R5F for IPC-only mode
[    7.848592] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7)
[    7.862610] remoteproc remoteproc1: remote processor 79000000.r5f is now up
[    7.876282] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
[    7.876470] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
[    7.893436] remoteproc remoteproc2: 78000000.r5f is available
[    7.899318] remoteproc remoteproc2: attaching to 78000000.r5f
[    7.950220] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    7.950532] platform 78000000.r5f: R5F core initialized in IPC-only mode
[    7.958681] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    7.980746] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[    7.985883] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node r5f-dma-memory@9c800000
[    7.998126] vdec 30210000.video-codec: Product Code:      0x521c
[    8.009756] virtio_rpmsg_bus virtio1: rpmsg host is online
[    8.009955] vdec 30210000.video-codec: Firmware Revision: 320127
[    8.009976] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    8.022137] i2c i2c-1: Added multiplexed i2c bus 3
[    8.036434] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
[    8.043558] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
[    8.064750] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    8.065601] remoteproc remoteproc0: powering up 7e000000.dsp
[    8.078240] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11563088
[    8.092865] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000
[    8.109980] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node c7x-dma-memory@99800000
[    8.120288] virtio_rpmsg_bus virtio2: rpmsg host is online
[    8.126189] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    8.133712] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    8.141515] virtio_rpmsg_bus virtio1: msg received with no recipient
[    8.148173] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    8.155785] m_can_platform 20701000.can main_mcan0: renamed from can0
[    8.160571] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7)
[    8.169628] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
[    8.170323] e5010 fd20000.jpeg-encoder: Device registered as /dev/video2
[    8.176823] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    8.190808] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    8.208379] virtio_rpmsg_bus virtio2: msg received with no recipient
[    8.234177] Console: switching to colour frame buffer device 240x67
[    8.274237] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
[    8.348996] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[    8.451099] dbus-broker-lau[409]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[    8.586282] audit: type=1334 audit(1709124496.340:10): prog-id=14 op=LOAD
[    8.593718] audit: type=1334 audit(1709124496.340:11): prog-id=15 op=LOAD
[    9.060171] usbcore: registered new interface driver option
[    9.072092] usbserial: USB Serial support registered for GSM modem (1-port)
[    9.079504] option 1-1:1.0: GSM modem (1-port) converter detected
[    9.086747] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[    9.099832] option 1-1:1.1: GSM modem (1-port) converter detected
[    9.112086] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[    9.124178] option 1-1:1.2: GSM modem (1-port) converter detected
[    9.137695] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
[    9.146969] option 1-1:1.3: GSM modem (1-port) converter detected
[    9.174884] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
[    9.192777] Bluetooth: Core ver 2.22
[    9.195735] option 1-1:1.4: GSM modem (1-port) converter detected
[    9.196484] NET: Registered PF_BLUETOOTH protocol family
[    9.207976] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB4
[    9.210461] Bluetooth: HCI device and connection manager initialized
[    9.227187] Bluetooth: HCI socket layer initialized
[    9.237613] Bluetooth: L2CAP socket layer initialized
[    9.246026] Bluetooth: SCO socket layer initialized
[    9.342488] omap_i2c 20010000.i2c: controller timed out
[    9.662150] EXT4-fs (mmcblk0p2): mounted filesystem 5ba76116-f063-4caa-ab9a-7b4bc67f1e85 r/w with ordered data mode. Quota mode: none.
[    9.790049] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.809978] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.816466] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   11.360219] kauditd_printk_skb: 2 callbacks suppressed
[   11.360232] audit: type=1006 audit(1709124499.116:14): pid=722 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[   11.378316] audit: type=1300 audit(1709124499.116:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffffdb60a28 a2=4 a3=1 items=0 ppid=1 pid=722 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   11.405153] audit: type=1327 audit(1709124499.116:14): proctitle="(systemd)"
[   12.362795] audit: type=1006 audit(1709124500.120:15): pid=687 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
[   12.377344] audit: type=1300 audit(1709124500.120:15): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd23b8488 a2=4 a3=1 items=0 ppid=1 pid=687 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   12.409308] audit: type=1327 audit(1709124500.120:15): proctitle="(weston)"
[   19.287944] audit: type=1006 audit(1709124507.044:16): pid=1366 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[   19.300477] audit: type=1300 audit(1709124507.044:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffc520fec8 a2=1 a3=1 items=0 ppid=1 pid=1366 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   19.327115] audit: type=1327 audit(1709124507.044:16): proctitle="(systemd)"
[   19.334256] audit: type=1334 audit(1709124507.076:17): prog-id=18 op=LOAD
[   19.341124] audit: type=1300 audit(1709124507.076:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc770bfd8 a2=90 a3=0 items=0 ppid=1 pid=1366 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   19.366987] audit: type=1327 audit(1709124507.076:17): proctitle="(systemd)"
[   19.374124] audit: type=1334 audit(1709124507.084:18): prog-id=18 op=UNLOAD
[   19.381152] audit: type=1300 audit(1709124507.084:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff93d68c60 items=0 ppid=1 pid=1366 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   19.406804] audit: type=1327 audit(1709124507.084:18): proctitle="(systemd)"
[   19.413914] audit: type=1334 audit(1709124507.084:19): prog-id=19 op=LOAD
For your information, we tried to stream the camera using the below command and it works fine
media-ctl -V '"imx219 2-0010":0 [fmt:SRGGB8_1X8/1920x1080 field:none]'
gst-launch-1.0 \
v4l2src device=/dev/video-imx219-cam0 io-mode=5 ! video/x-bayer,width=1920,height=1080,framerate=30/1,format=rggb ! queue leaky=2 ! \
tiovxisp sink_0::device=/dev/v4l-imx219-subdev0 sensor-name=SENSOR_SONY_IMX219_RPI dcc-isp-file=/opt/imaging/imx219/linear/dcc_viss_1920x1080.bin \
sink_0::dcc-2a-file=/opt/imaging/imx219/linear/dcc_2a_1920x1080.bin sink_0::pool-size=8 src::pool-size=8 ! \
video/x-raw,format=NV12, width=1920,height=1080 ! \
kmssink driver-name=tidss sync=false force-modesetting=true
Any insights, suggestions, or troubleshooting steps would be greatly appreciated. Please let me know if more details are required!
Thanks in advance for your support.
Raveen
  • Hello Raveen,
    We will find a resolution for this issue. Thank you for providing the logs and information as a starting point!
    It is good that you are getting live output from your small standalone pipeline. I didn't see some of the expected logs in the dmesg prints, but if the camera is giving frames otherwise, then I'll ignore that detail.
    You can try running 'kmstest' to check that the display subsystem (DSS) is detecting and outputting to a monitor.
    Can you try pulling the first portion of the GST pipeline string (v4l2 -> caps filter -> tiovxisp) from the app-edgeai.py output, and try directing that to KMS sink?
    Does your standalone pipeline produce similar warnings with GST_DEBUG=2? It is not immediately clear which warnings indicate issue
    Can you also run /opt/vx_app_arm_remote_log.out in the background to see if any other warnings / errors are issued?
    BR,
    Reese
  • Hi Reese,
    Thank you for the replay.
    We observed that the remoteproc core did not start during boot-up. However, after configuring the U-Boot environment variable "dorprocboot=1", the remoteproc core successfully started, albeit with a warning. We believe this warning is unlikely to affect the performance of the AI application.
    U-Boot SPL 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    SPL initial stack usage: 13568 bytes
    Trying to boot from MMC2
    alloc space exhausted
    Could not get FIT buffer of 4671872 bytes
            check CONFIG_SPL_SYS_MALLOC_SIZE
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    i2c_write: error waiting for data ACK (status=0x116)
    pca953x gpio@22: Error reading output register
    U-Boot 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    SoC:   AM62AX SR1.0 HS-FS
    Model: Texas Instruments AM62A7 SK
    DRAM:  2 GiB (effective 4 GiB)
    Core:  87 devices, 30 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   Could not get PHY for mdio@f00: addr 0
    am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
    No ethernet found.
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    688 bytes read in 33 ms (19.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    53172 bytes read in 47 ms (1.1 MiB/s)
    Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices
    Load Remote Processor 0 with data@addr=0x82000000 53172 bytes: Success!
    11604048 bytes read in 261 ms (42.4 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 11604048 bytes: Success!
    20560384 bytes read in 837 ms (23.4 MiB/s)
    59706 bytes read in 38 ms (1.5 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
    Working FDT set to 8feee000
    Starting kernel ...
    For the HDMI test, we used the kmstest utility and successfully displayed a color pattern on the screen.
    root@am62axx-evm:/opt/edgeai-gst-apps# kmstest
    Connector 0/@40: HDMI-A-1
    Crtc 0/@38: 1920x1080@60.00 148.500 1920/88/44/148/+ 1080/4/5/36/+ 60 (60.00) 0x5 0x48
    Plane 0/@31: 0,0-1920x1080
    Fb 51 1920x1080-XR24
    press enter to exit
    However, after starting the remoteproc, the camera streaming functionality did not work as expected. Instead, we observed a static green screen on the monitor (not flashing, but a solid green screen). Please find the relevant log below for further reference.
    root@am62axx-evm:/opt/edgeai-gst-apps# media-ctl -V '"imx219 2-0010":0 [fmt:SRGGB8_1X8/1920x1080 field:none]'
    root@am62axx-evm:/opt/edgeai-gst-apps# gst-launch-1.0 \
    APP: Init ... !!!
       660.342975 s: MEM: Init ... !!!
       660.343026 s: MEM: Initialized DMA HEAP (fd=8) !!!
       660.343205 s: MEM: Init ... Done !!!
       660.343219 s: IPC: Init ... !!!
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio0.rpmsg_chrdev.-1.13
       660.361203 s: IPC: ERROR: Unable to create TX channels for CPU [c7x_1] !!!
       660.361221 s: IPC: Init ... Done !!!
    APP: ERROR: IPC init failed !!!
    REMOTE_SERVICE: Init ... !!!
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio2.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio0.rpmsg_chrdev.-1.21
    REMOTE_SERVICE: Init ... Done !!!
       660.369666 s: GTC Frequency = 200 MHz
    APP: Init ... Done !!!
       660.381107 s:  VX_ZONE_INIT:Enabled
       660.381149 s:  VX_ZONE_ERROR:Enabled
       660.381159 s:  VX_ZONE_WARNING:Enabled
       660.385887 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
       660.386074 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
       660.386222 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
       660.386330 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
       660.386349 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
       660.388960 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
    0:00:00.435179910  1633     0x13916ee0 WARN                 kmssink gstkmssink.c:2101:_validate_and_set_external_fd:<kmssink0> Can't set fd... driver-name already set.
    Setting pipeline to PAUSED ...
    0:00:00.586707115  1633 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.586821300  1633 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    Pipeline is live and does not need PREROLL ...
    0:00:00.587616735  1633 0xffffb0000eb0 WARN                    v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed
    0:00:00.587739525  1633 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.587785060  1633 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    Pipeline is PREROLLED ...
    Setting pipeline to PLAYING ...
    0:00:00.588772880  1633 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.588841860  1633 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    New clock: GstSystemClock
    0:00:00.589817900  1633 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.589855845  1633 0xffffb0000eb0 WARN                    v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed
    0:00:00.589894935  1633 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    0:00:00.678209645  1633 0xffffb0000eb0 WARN          v4l2bufferpool gstv4l2bufferpool.c:1334:gst_v4l2_buffer_pool_dqbuf:<v4l2src0:pool0:src> Driver should never set v4l2_buffer.field to ANY
    ^Chandling interrupt.
    Interrupt: Stopping pipeline ...
    Execution ended after 0:00:11.392145540
    Setting pipeline to NULL ...
    Log of /opt/vx_app_arm_remote_log.out we run in a separate terminal.
    root@am62axx-evm:/opt/edgeai-gst-apps# /opt/vx_app_arm_remote_log.out
    [MCU1_0]      0.033836 s: CIO: Init ... Done !!!
    [MCU1_0]      0.033876 s: APP: Init ... !!!
    [MCU1_0]      0.033908 s: MEM: Init ... !!!
    [MCU1_0]      0.033924 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ af000000 of size 16777216 bytes !!!
    [MCU1_0]      0.033963 s: MEM: Init ... Done !!!
    [MCU1_0]      0.033992 s: IPC: Init ... !!!
    [MCU1_0]      0.034008 s: IPC: 3 CPUs participating in IPC !!!
    [MCU1_0]      0.034305 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU1_0]      0.038651 s: #Sciserver Version: v2023.11.0.0REL.MCUSDK.MM.NN.PP.bb
    [MCU1_0]      0.041424 s: ##RM_PM_HAL Version: vMM.NN.PP
    [MCU1_0]      0.044370 s: ##Starting Sciserver..... PASSED
    [MCU1_0]     14.555957 s: IPC: HLOS is ready !!!
    [MCU1_0]     14.556045 s: IPC: Init ... Done !!!
    [MCU1_0]     14.556066 s: APP: Syncing with 2 CPUs ... !!!
    [C7x_1 ]      5.568470 s: CIO: Init ... Done !!!
    [C7x_1 ]      5.568489 s: APP: Init ... !!!
    [C7x_1 ]      5.568501 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      5.568562 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_1 ]      5.568582 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_1 ]      5.568597 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_1 ]      5.568613 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      5.568626 s: UDMA: Init ... !!!
    [C7x_1 ]      5.568639 s: UDMA: Init ... Done !!!
    [C7x_1 ]      5.568651 s: MEM: Init ... !!!
    [C7x_1 ]      5.568664 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ b2000000 of size 117440512 bytes !!!
    [C7x_1 ]      5.568693 s: MEM: Init ... Done !!!
    [C7x_1 ]      5.568705 s: IPC: Init ... !!!
    [C7x_1 ]      5.568717 s: IPC: 3 CPUs participating in IPC !!!
    [C7x_1 ]      5.568915 s: IPC: Waiting for HLOS to be ready ... !!!
    Boot log:
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    No ethernet found.
    Starting kernel ...
    [    0.000000] Linux version 6.6.32-ti-gdb8871293143-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #1 SMP PREEMPT Thu Aug  1 19:10:56 UTC 2024
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Memory: 2807620K/4194304K available (12160K kernel code, 1262K rwdata, 4064K rodata, 2432K init, 506K bss, 796860K reserved, 589824K cma-reserved)
    [    0.008520] Console: colour dummy device 80x25
    [    0.013110] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023792] pid_max: default: 32768 minimum: 301
    [    0.028590] LSM: initializing lsm=capability,integrity
    [    0.033942] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.041521] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.051129] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.058429] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.066343] rcu: Hierarchical SRCU implementation.
    [    0.071249] rcu:     Max phase no-delay instances is 1000.
    [    0.076830] Platform MSI: msi-controller@1820000 domain created
    [    0.083082] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.092485] EFI services will not be available.
    [    0.097347] smp: Bringing up secondary CPUs ...
    [    0.102568] Detected VIPT I-cache on CPU1
    [    0.102634] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.102650] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.102695] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.103346] Detected VIPT I-cache on CPU2
    [    0.103397] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.103410] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
    [    0.103440] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.104019] Detected VIPT I-cache on CPU3
    [    0.104069] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.104081] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
    [    0.104112] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.104182] smp: Brought up 1 node, 4 CPUs
    [    0.183901] SMP: Total of 4 processors activated.
    [    0.188714] CPU features: detected: 32-bit EL0 Support
    [    0.193985] CPU features: detected: CRC32 instructions
    [    0.199294] CPU: All CPU(s) started at EL2
    [    0.203492] alternatives: applying system-wide alternatives
    [    0.210724] devtmpfs: initialized
    [    0.222941] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.232940] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.253559] pinctrl core: initialized pinctrl subsystem
    [    0.259379] DMI not present or invalid.
    [    0.263886] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.270693] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.278025] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.286107] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.294263] audit: initializing netlink subsys (disabled)
    [    0.299950] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
    [    0.300360] thermal_sys: Registered thermal governor 'step_wise'
    [    0.307881] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.314064] cpuidle: using governor menu
    [    0.324901] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.331922] ASID allocator initialised with 65536 entries
    [    0.349201] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
    [    0.360511] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.371861] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    0.381344] Modules: 27616 pages in range for non-PLT usage
    [    0.381350] Modules: 519136 pages in range for PLT usage
    [    0.387721] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.400112] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.406521] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.413461] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.419868] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.426807] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.433215] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.440154] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.447856] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
    [    0.457441] iommu: Default domain type: Translated
    [    0.462369] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.468957] SCSI subsystem initialized
    [    0.473078] usbcore: registered new interface driver usbfs
    [    0.478719] usbcore: registered new interface driver hub
    [    0.484179] usbcore: registered new device driver usb
    [    0.489810] pps_core: LinuxPPS API ver. 1 registered
    [    0.494891] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.504240] PTP clock support registered
    [    0.508409] EDAC MC: Ver: 3.0.0
    [    0.512060] scmi_core: SCMI protocol bus registered
    [    0.517321] FPGA manager framework
    [    0.520872] Advanced Linux Sound Architecture Driver Initialized.
    [    0.527978] vgaarb: loaded
    [    0.531045] clocksource: Switched to clocksource arch_sys_counter
    [    0.537518] VFS: Disk quotas dquot_6.6.0
    [    0.541575] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.554875] Carveout Heap: Exported 176 MiB at 0x00000000a3000000
    [    0.561217] NET: Registered PF_INET protocol family
    [    0.566385] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.576812] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.585618] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.593553] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.601860] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.610228] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.617086] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.624040] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.631555] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.637759] RPC: Registered named UNIX socket transport module.
    [    0.643834] RPC: Registered udp transport module.
    [    0.648644] RPC: Registered tcp transport module.
    [    0.653453] RPC: Registered tcp-with-tls transport module.
    [    0.659061] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.665651] NET: Registered PF_XDP protocol family
    [    0.670564] PCI: CLS 0 bytes, default 64
    [    0.675882] Initialise system trusted keyrings
    [    0.680634] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.687522] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.693757] NFS: Registering the id_resolver key type
    [    0.698960] Key type id_resolver registered
    [    0.703239] Key type id_legacy registered
    [    0.707354] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.714209] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.755521] Key type asymmetric registered
    [    0.759715] Asymmetric key parser 'x509' registered
    [    0.764746] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.772434] io scheduler mq-deadline registered
    [    0.777074] io scheduler kyber registered
    [    0.781198] io scheduler bfq registered
    [    0.788037] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.794528] pinctrl-single f4000.pinctrl: 151 pins, size 604
    [    0.801824] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.813977] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.830665] loop: module loaded
    [    0.834846] megasas: 07.725.01.00-rc1
    [    0.842169] tun: Universal TUN/TAP device driver, 1.6
    [    0.848258] VFIO - User Level meta-driver version: 0.3
    [    0.854654] usbcore: registered new interface driver usb-storage
    [    0.861376] i2c_dev: i2c /dev entries driver
    [    0.867268] sdhci: Secure Digital Host Controller Interface driver
    [    0.873602] sdhci: Copyright(c) Pierre Ossman
    [    0.878274] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.884794] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.891261] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.898526] usbcore: registered new interface driver usbhid
    [    0.904229] usbhid: USB HID core driver
    [    0.908438] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    0.915269] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    0.922055] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    0.928793] omap-mailbox 29030000.mailbox: no available mbox devices found
    [    0.937107] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.946081] optee: probing for conduit method.
    [    0.950654] optee: revision 4.2 (12d7c4ee)
    [    0.950938] optee: dynamic shared memory is enabled
    [    0.960801] random: crng init done
    [    0.964379] optee: initialized driver
    [    0.969539] Initializing XFRM netlink socket
    [    0.973955] NET: Registered PF_PACKET protocol family
    [    0.979187] Key type dns_resolver registered
    [    0.991188] registered taskstats version 1
    [    0.995511] Loading compiled-in X.509 certificates
    [    1.012746] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    [    1.061576] i2c 0-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@48/regulators/buck5
    [    1.071413] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.078397] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    1.087548] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/sii9022@3b
    [    1.096996] i2c 1-003b: Fixed dependency cycle(s) with /connector
    [    1.103277] i2c 1-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.110838] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.117768] i2c 2-0010: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    1.127605] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.133649] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.141993] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.151232] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.160215] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.169748] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.178376] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.189391] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.200304] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.209781] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.216378] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.225767] printk: console [ttyS2] disabled
    [    1.230464] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 253, base_baud = 3000000) is a 8250
    [    1.239363] printk: console [ttyS2] enabled
    [    1.247831] printk: bootconsole [ns16550a0] disabled
    [    1.299057] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.307087] mdio_bus 8000f00.mdio: MDIO device at address 0 is missing.
    [    1.313738] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.326692] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.333826] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.340195] pps pps0: new PPS source ptp0
    [    1.344467] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.358340] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.371849] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.377376] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.385139] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.391142] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
    [    1.400569] xhci-hcd xhci-hcd.0.auto: irq 268, io mem 0x31100000
    [    1.407278] hub 1-0:1.0: USB hub found
    [    1.411085] hub 1-0:1.0: 1 port detected
    [    1.416394] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.428473] mmc0: CQHCI version 5.10
    [    1.473290] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.559022] mmc0: Command Queue Engine enabled
    [    1.563501] mmc0: new HS200 MMC card at address 0001
    [    1.568971] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    1.574756]  mmcblk0: p1 p2
    [    1.578078] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    1.583887] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    1.589565] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    1.671067] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    1.714082] tps6594-rtc tps6594-rtc.5.auto: registered as rtc0
    [    1.720061] tps6594-rtc tps6594-rtc.5.auto: hctosys: unable to read the hardware clock
    [    1.731091] mmc1: CQHCI version 5.10
    [    1.731802] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.742010] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.750397] clk: Disabling unused clocks
    [    1.759017] ALSA device list:
    [    1.762052]   No soundcards found.
    [    1.773639] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.781298] Waiting for root device PARTUUID=076c4a2a-02...
    [    1.819649] mmc1: new high speed SDXC card at address 59b4
    [    1.825717] mmcblk1: mmc1:59b4 SD64G 59.4 GiB
    [    1.832343]  mmcblk1: p1 p2
    [    2.366303] EXT4-fs (mmcblk1p2): recovery complete
    [    2.375563] EXT4-fs (mmcblk1p2): mounted filesystem 391702fc-cf91-4f81-afcd-ec5ecaef14e3 r/w with ordered data mode. Quota mode: none.
    [    2.387718] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.395144] devtmpfs: mounted
    [    2.398766] Freeing unused kernel memory: 2432K
    [    2.403359] Run /sbin/init as init process
    [    2.927856] systemd[1]: System time before build time, advancing clock.
    [    3.018965] NET: Registered PF_INET6 protocol family
    [    3.024808] Segment Routing with IPv6
    [    3.028536] In-situ OAM (IOAM) with IPv6
    [    3.090823] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    3.122649] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    3.152978] systemd[1]: Hostname set to <am62axx-evm>.
    [    3.256831] systemd-sysv-generator[105]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
    [    3.493437] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.616646] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.708590] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.748741] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    3.773418] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    3.797329] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    3.820789] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.843483] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    3.867378] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    3.891226] systemd[1]: Expecting device /dev/ttyS2...
    [    3.911291] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    3.931173] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.951161] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    3.971169] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    4.035364] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    4.059314] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    4.086772] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    4.107561] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.132207] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    4.155775] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.179818] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.199956] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.226087] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.247711] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.267735] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    4.315412] systemd[1]: Mounting Huge Pages File System...
    [    4.339349] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.367261] systemd[1]: Mounting Kernel Debug File System...
    [    4.387654] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.414426] systemd[1]: Mounting Temporary Directory /tmp...
    [    4.440528] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.467570] systemd[1]: Starting Load Kernel Module configfs...
    [    4.495473] systemd[1]: Starting Load Kernel Module drm...
    [    4.519693] systemd[1]: Starting Load Kernel Module fuse...
    [    4.545694] systemd[1]: Starting Start psplash boot splash screen...
    [    4.581560] systemd[1]: Starting RPC Bind...
    [    4.599576] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    4.599854] fuse: init (API version 7.39)
    [    4.619961] systemd[1]: Starting Journal Service...
    [    4.658121] systemd[1]: Starting Load Kernel Modules...
    [    4.684518] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.712324] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.731888] cryptodev: loading out-of-tree module taints kernel.
    [    4.733726] systemd-journald[124]: Collecting audit messages is enabled.
    [    4.742674] systemd[1]: Starting Coldplug All udev Devices...
    [    4.745451] cryptodev: driver 1.13 loaded.
    [    4.762866] systemd[1]: Started RPC Bind.
    [    4.772312] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    4.808904] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    4.833434] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [    4.847570] EXT4-fs (mmcblk1p2): re-mounted 391702fc-cf91-4f81-afcd-ec5ecaef14e3 r/w. Quota mode: none.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Start psplas…temd progress communication helper.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
    [    5.177299] systemd-journald[124]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev gracefully...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    5.461797] audit: type=1334 audit(1709054766.528:2): prog-id=6 op=LOAD
    [    5.468655] audit: type=1334 audit(1709054766.536:3): prog-id=7 op=LOAD
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Load/Save OS Random Seed.
    [  OK  ] Finished Create Volatile Files and Directories.
    [    5.708797] audit: type=1334 audit(1709054766.776:4): prog-id=8 op=LOAD
             Starting Network Name Resolution...
    [    5.743148] audit: type=1334 audit(1709054766.808:5): prog-id=9 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [    5.827141] audit: type=1334 audit(1709054766.892:6): prog-id=10 op=LOAD
    [    5.837331] audit: type=1334 audit(1709054766.892:7): prog-id=11 op=LOAD
    [    5.847158] audit: type=1334 audit(1709054766.892:8): prog-id=12 op=LOAD
             Starting User Database Manager...
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [    6.626701] CAN device driver interface
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [    6.643832] m_can_platform 20701000.can: m_can device registered (irq=539, version=32)
             Starting Docker Socket for the API...
    [    6.683557] mc: Linux media interface: v0.10
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [    6.724804] videodev: Linux video capture interface: v2.00
             Starting Weston socket...
    [    6.751239] audit: type=1334 audit(1709064845.800:9): prog-id=13 op=LOAD
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [    6.823686] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [  OK  ] Listening on Weston socket.
    [    6.834805] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
    [    6.855097] platform 79000000.r5f: configured R5F for IPC-only mode
    [    6.867358] k3-dsp-rproc 7e000000.dsp: configured DSP for IPC-only mode
    [    6.876076] remoteproc remoteproc0: 7e000000.dsp is available
    [    6.878327] imx219 2-0010: supply VANA not found, using dummy regulator
    [    6.884027] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
    [    6.884203] remoteproc remoteproc0: attaching to 7e000000.dsp
    [    6.889285] k3-dsp-rproc 7e000000.dsp: DSP initialized in IPC-only mode
    [    6.901732] remoteproc remoteproc1: 79000000.r5f is available
    [    6.903174] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node c7x-dma-memory@99800000
    [    6.909678] remoteproc remoteproc1: attaching to 79000000.r5f
    [    6.915640] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.916281] imx219 2-0010: supply VDIG not found, using dummy regulator
    [    6.916336] imx219 2-0010: supply VDDL not found, using dummy regulator
    [    6.925028] platform 79000000.r5f: R5F core initialized in IPC-only mode
    [    6.930321] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7)
    [    6.935494] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node r5f-dma-memory@9b800000
    [    6.936107] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.942313] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.945080] remoteproc remoteproc0: remote processor 7e000000.dsp is now attached
    [    6.948929] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
    [    6.955896] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    6.962455] remoteproc remoteproc1: remote processor 79000000.r5f is now attached
    [    7.001983] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [  OK  ] Reached target Socket Units.
    [    7.040003] platform 78000000.r5f: configured R5F for IPC-only mode
    [    7.041308] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
    [    7.046849] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    7.053303] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
    [    7.071934] remoteproc remoteproc2: 78000000.r5f is available
    [    7.077885] remoteproc remoteproc2: attaching to 78000000.r5f
    [    7.083427] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [  OK  ] Finished Reboot and dump vmcore via[    7.091406] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
     kexec.
    [    7.092055] platform 78000000.r5f: R5F core initialized in IPC-only mode
    [    7.109802] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    7.111462] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    7.126463] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    7.127314] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    7.141266] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7)
    [    7.148223] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
    [    7.151348] e5010 fd20000.jpeg-encoder: Device registered as /dev/video2
    [    7.158806] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    7.170752] vdec 30210000.video-codec: Product Code:      0x521c
    [    7.177041] vdec 30210000.video-codec: Firmware Revision: 320127
    [  OK  ] Reached target Hardware activated USB gadget.
    [  OK  ] Started D-Bus System Message Bus.
    [    7.213077] i2c i2c-1: Added multiplexed i2c bus 3
    [  OK  ] Reached target Basic System.
    [    7.258952] dbus-broker-lau[404]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [    7.270189] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [  OK  ] Started Job spooling tools.
    [    7.353154] Console: switching to colour frame buffer device 240x67
    [    7.390550] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Periodic Command Scheduler m_can_platform 20701000.can main_mcan0: renamed from can0
    [0m.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Expand the rootfs partiti…to full size of the boot device....
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [    7.651238] audit: type=1334 audit(1709064846.700:10): prog-id=14 op=LOAD
    [    7.660928] audit: type=1334 audit(1709064846.704:11): prog-id=15 op=LOAD
             Starting User Login Management...
             Starting Telnet Server...
             Starting Virtual Console Setup...
    [  OK  ] Finished Telnet Server.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [    7.920496] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
    [    8.141358] usbcore: registered new interface driver option
    [    8.147120] usbserial: USB Serial support registered for GSM modem (1-port)
    [    8.154316] option 1-1:1.0: GSM modem (1-port) converter detected
    [    8.160861] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
    [  OK  ] Started Telephony service.
    [    8.170138] option 1-1:1.1: GSM modem (1-port) converter detected
    [    8.179698] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
    [    8.186845] option 1-1:1.2: GSM modem (1-port) converter detected
    [    8.194226] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
    [    8.201406] option 1-1:1.3: GSM modem (1-port) converter detected
    [    8.208254] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
    [    8.215715] option 1-1:1.4: GSM modem (1-port) converter detected
    [    8.222767] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB4
             Starting Save/Restore Sound Card State...
    [  OK  ] Finished Save/Restore Sound Card State.
    [    8.335292] Bluetooth: Core ver 2.22
    [    8.339007] NET: Registered PF_BLUETOOTH protocol family
    [    8.345063] Bluetooth: HCI device and connection manager initialized
    [    8.351756] Bluetooth: HCI socket layer initialized
    [    8.356918] Bluetooth: L2CAP socket layer initialized
    [    8.362226] Bluetooth: SCO socket layer initialized
    [  OK  ] Reached target Sound Card.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [    8.491092] omap_i2c 20010000.i2c: controller timed out
    [  OK  ] Stopped Virtual Console Setup.
    [    9.547061] omap_i2c 20010000.i2c: controller timed out
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [  OK  ] Started User Login Management.
    [  OK  ] Created slice Slice /system/systemd-fsck.
             Expecting device /dev/mmcblk0p1...
             Expecting device /dev/mmcblk0p2...
    [    9.910564] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    9.932580] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    9.939685] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Found device /dev/mmcblk0p1.
    [  OK  ] Found device /dev/mmcblk0p2.
    [  OK  ] Finished Virtual Console Setup.
             Starting File System Check on /dev/mmcblk0p1...
             Starting File System Check on /dev/mmcblk0p2...
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/BOOT-mmcblk0p1...
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland compositor, as a system service...
    [  OK  ] Mounted /run/media/BOOT-mmcblk0p1.
    [  OK  ] Finished File System Check on /dev/mmcblk0p2.
             Mounting /run/media/rootfs-mmcblk0p2...
    [   10.513732] EXT4-fs (mmcblk0p2): mounted filesystem 5ba76116-f063-4caa-ab9a-7b4bc67f1e85 r/w with ordered data mode. Quota mode: none.
    [  OK  ] Mounted /run/media/rootfs-mmcblk0p2.
    [  OK  ] Finished Synchronize System and HW clocks.
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
             Expecting device /dev/mmcblk1p1...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [   11.359471] kauditd_printk_skb: 2 callbacks suppressed
    [   11.359485] audit: type=1006 audit(1709064850.408:14): pid=689 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   11.377450] audit: type=1300 audit(1709064850.408:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe453cc08 a2=4 a3=1 items=0 ppid=1 pid=689 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   11.404421] audit: type=1327 audit(1709064850.408:14): proctitle="(systemd)"
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/BOOT-mmcblk1p1...
    [  OK  ] Mounted /run/media/BOOT-mmcblk1p1.
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User weston   12.563108] audit: type=1006 audit(1709064851.608:15): pid=658 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    0m.
    [   12.578081] audit: type=1300 audit(1709064851.608:15): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd21c09b8 a2=4 a3=1 items=0 ppid=1 pid=658 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   12.605006] audit: type=1327 audit(1709064851.608:15): proctitle="(weston)"
    [  OK  ] Started Weston, a Wayland compositor, as a system service.
             Starting EdgeAI OOB demos...
             Stopping Weston, a Wayland compositor, as a system service...
    [  OK  ] Started containerd container runtime.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62axx-evm ttyS2
    Arago 2023.10 am62axx-evm ttyS2
    am62axx-evm login: ***************************************************************
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts-examples
            libqt5charts-plugins
            libqt5charts-qmlplugins
            libqt5charts5
            libqt5serialport-examples
            libqt5serialport-plugins
            libqt5serialport-qmlplugins
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg-qmlplugins
            libqt5svg5
            libqt5virtualkeyboard-plugins
            libqt5virtualkeyboard-qmlplugins
            libqt5virtualkeyboard5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring5
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity-plugins
            qtconnectivity-qmlplugins
            qtconnectivity
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-tools
            qtdeclarative
            qtgraphicaleffects-qmlplugins
            qtlocation-examples
            qtlocation-plugins
            qtlocation-qmlplugins
            qtlocation
            qtmultimedia-examples
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquics-qmlplugins.control
            qtquics2-plugins.control
            qtquics2-qmlplugins.control
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    am62axx-evm login: root
    [   21.403867] audit: type=1006 audit(1709064860.452:16): pid=1334 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   21.416410] audit: type=1300 audit(1709064860.452:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffee47e648 a2=1 a3=1 items=0 ppid=1 pid=1334 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   21.443018] audit: type=1327 audit(1709064860.452:16): proctitle="(systemd)"
    [   21.450119] audit: type=1334 audit(1709064860.464:17): prog-id=18 op=LOAD
    [   21.456979] audit: type=1300 audit(1709064860.464:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffef033b18 a2=90 a3=0 items=0 ppid=1 pid=1334 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   21.482829] audit: type=1327 audit(1709064860.464:17): proctitle="(systemd)"
    [   21.489920] audit: type=1334 audit(1709064860.492:18): prog-id=18 op=UNLOAD
    [   21.496932] audit: type=1300 audit(1709064860.492:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff977bac60 items=0 ppid=1 pid=1334 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   21.522582] audit: type=1327 audit(1709064860.492:18): proctitle="(systemd)"
    [   21.529710] audit: type=1334 audit(1709064860.492:19): prog-id=19 op=LOAD
    IMX219 Camera 0 detected
        device = /dev/video-imx219-cam0
        name = imx219
        format = [fmt:SRGGB8_1X8/1920x1080]
        subdev_id = /dev/v4l-imx219-subdev0
        isp_required = yes
    We run a few commands to get more logs about the remote proc please find the log below,
    root@am62axx-evm:/opt/edgeai-gst-apps# rpmsg_char_simple -r 0 -n 3
    Created endpt device rpmsg-char-0-1703, fd = 4 port = 1025
    Exchanging 3 messages with rpmsg device rpmsg-char-0-1703 on rproc id 0 ...
    Sending message #0: hello there 0!
    Received message #0: round trip delay(usecs) = 119320
    hello there 0!
    Sending message #1: hello there 1!
    Received message #1: round trip delay(usecs) = 35860
    hello there 1!
    Sending message #2: hello there 2!
    Received message #2: round trip delay(usecs) = 35530
    hello there 2!
    Communicated 3 messages successfully on rpmsg-char-0-1703
    TEST STATUS: PASSED
    root@am62axx-evm:/opt/edgeai-gst-apps# head /sys/class/remoteproc/remoteproc*/name
    ==> /sys/class/remoteproc/remoteproc0/name <==
    7e000000.dsp
    ==> /sys/class/remoteproc/remoteproc1/name <==
    79000000.r5f
    ==> /sys/class/remoteproc/remoteproc2/name <==
    78000000.r5f
    root@am62axx-evm:/opt/edgeai-gst-apps# cat /sys/kernel/debug/remoteproc/remoteproc0/trace0
    root@am62axx-evm:/opt/edgeai-gst-apps# cat /sys/kernel/debug/remoteproc/remoteproc1/trace0
    [mcu-r5f0-0]     0.000000s : [IPC RPMSG ECHO] Version: REL.MCUSD
    root@am62axx-evm:/opt/edgeai-gst-apps# cat /sys/kernel/debug/remoteproc/remoteproc2/trace0
    Raveen
  • Hello Raveen,
    Looks like there are some IPC errors when you run the Gstreamer command.
    Let's first see if your v4l2 capture works. Can you try to use yavta to capture raw images? Please refer to this FAQ about properly setting the formats in the media control pipeline which is necessary for capturing: What are the common reasons V4L2 based applications fail to capture images from a probed CSI sensor?.
    Jianzhong
  • Hi Jianzhong,
    I ran the "yavta" and it seems v4l2 works fine please find the below log,
    root@am62axx-evm:/opt/edgeai-gst-apps# yavta -s 1920x1080 -f SRGGB8 /dev/video-imx219-cam0 -c
    Device /dev/video-imx219-cam0 opened.
    Device `j721e-csi2rx' on `platform:30102000.ticsi2rx' (driver 'j721e-csi2rx') supports video, capture, without mplanes.
    Video format set: SRGGB8 (42474752) 1920x1080 (stride 1920) field none buffer size 2073600
    Video format: SRGGB8 (42474752) 1920x1080 (stride 1920) field none buffer size 2073600
    8 buffers requested.
    length: 2073600 offset: 0 timestamp type/source: mono/EoF
    Buffer 0/0 mapped at address 0xffff89115000.
    length: 2073600 offset: 2076672 timestamp type/source: mono/EoF
    Buffer 1/0 mapped at address 0xffff88f1a000.
    length: 2073600 offset: 4153344 timestamp type/source: mono/EoF
    Buffer 2/0 mapped at address 0xffff88d1f000.
    length: 2073600 offset: 6230016 timestamp type/source: mono/EoF
    Buffer 3/0 mapped at address 0xffff88b24000.
    length: 2073600 offset: 8306688 timestamp type/source: mono/EoF
    Buffer 4/0 mapped at address 0xffff88929000.
    length: 2073600 offset: 10383360 timestamp type/source: mono/EoF
    Buffer 5/0 mapped at address 0xffff8872e000.
    length: 2073600 offset: 12460032 timestamp type/source: mono/EoF
    Buffer 6/0 mapped at address 0xffff88533000.
    length: 2073600 offset: 14536704 timestamp type/source: mono/EoF
    Buffer 7/0 mapped at address 0xffff88338000.
    0 (0) [-] any 0 2073600 B 1393.972319 1393.972344 18.948 fps ts mono/EoF
    1 (1) [-] any 1 2073600 B 1394.005640 1394.005660 30.011 fps ts mono/EoF
    2 (2) [-] any 2 2073600 B 1394.038961 1394.038976 30.011 fps ts mono/EoF
    3 (3) [-] any 3 2073600 B 1394.072287 1394.072301 30.007 fps ts mono/EoF
    4 (4) [-] any 4 2073600 B 1394.105614 1394.105630 30.006 fps ts mono/EoF
    5 (5) [-] any 5 2073600 B 1394.138941 1394.138955 30.006 fps ts mono/EoF
    6 (6) [-] any 6 2073600 B 1394.172267 1394.172281 30.007 fps ts mono/EoF
    7 (7) [-] any 7 2073600 B 1394.205594 1394.205609 30.006 fps ts mono/EoF
    8 (0) [-] any 8 2073600 B 1394.238920 1394.238933 30.007 fps ts mono/EoF
    9 (1) [-] any 9 2073600 B 1394.272249 1394.272265 30.004 fps ts mono/EoF
    10 (2) [-] any 10 2073600 B 1394.305574 1394.305588 30.008 fps ts mono/EoF
    11 (3) [-] any 11 2073600 B 1394.338900 1394.338914 30.007 fps ts mono/EoF
    12 (4) [-] any 12 2073600 B 1394.372227 1394.372241 30.006 fps ts mono/EoF
    13 (5) [-] any 13 2073600 B 1394.405554 1394.405568 30.006 fps ts mono/EoF
    14 (6) [-] any 14 2073600 B 1394.438881 1394.438894 30.006 fps ts mono/EoF
    15 (7) [-] any 15 2073600 B 1394.472208 1394.472222 30.006 fps ts mono/EoF
    16 (0) [-] any 16 2073600 B 1394.505537 1394.505551 30.004 fps ts mono/EoF
    17 (1) [-] any 17 2073600 B 1394.538861 1394.538874 30.008 fps ts mono/EoF
    18 (2) [-] any 18 2073600 B 1394.572188 1394.572202 30.006 fps ts mono/EoF
    19 (3) [-] any 19 2073600 B 1394.605515 1394.605529 30.006 fps ts mono/EoF
    20 (4) [-] any 20 2073600 B 1394.638841 1394.638855 30.007 fps ts mono/EoF
    21 (5) [-] any 21 2073600 B 1394.672169 1394.672183 30.005 fps ts mono/EoF
    22 (6) [-] any 22 2073600 B 1394.705494 1394.705508 30.008 fps ts mono/EoF
    23 (7) [-] any 23 2073600 B 1394.738821 1394.738835 30.006 fps ts mono/EoF
    24 (0) [-] any 24 2073600 B 1394.772155 1394.772174 29.999 fps ts mono/EoF
    25 (1) [-] any 25 2073600 B 1394.805475 1394.805490 30.012 fps ts mono/EoF
    26 (2) [-] any 26 2073600 B 1394.838803 1394.838817 30.005 fps ts mono/EoF
    27 (3) [-] any 27 2073600 B 1394.872129 1394.872144 30.007 fps ts mono/EoF
    28 (4) [-] any 28 2073600 B 1394.905458 1394.905472 30.004 fps ts mono/EoF
    29 (5) [-] any 29 2073600 B 1394.938782 1394.938796 30.008 fps ts mono/EoF
    30 (6) [-] any 30 2073600 B 1394.972108 1394.972122 30.007 fps ts mono/EoF
    31 (7) [-] any 31 2073600 B 1395.005439 1395.005453 30.002 fps ts mono/EoF
    32 (0) [-] any 32 2073600 B 1395.038763 1395.038776 30.008 fps ts mono/EoF
    33 (1) [-] any 33 2073600 B 1395.072089 1395.072102 30.007 fps ts mono/EoF
    34 (2) [-] any 34 2073600 B 1395.105417 1395.105432 30.005 fps ts mono/EoF
    35 (3) [-] any 35 2073600 B 1395.138742 1395.138757 30.008 fps ts mono/EoF
    36 (4) [-] any 36 2073600 B 1395.172070 1395.172085 30.005 fps ts mono/EoF
    37 (5) [-] any 37 2073600 B 1395.205396 1395.205410 30.007 fps ts mono/EoF
    38 (6) [-] any 38 2073600 B 1395.238728 1395.238758 30.001 fps ts mono/EoF
    39 (7) [-] any 39 2073600 B 1395.272057 1395.272077 30.004 fps ts mono/EoF
    40 (0) [-] any 40 2073600 B 1395.305377 1395.305391 30.012 fps ts mono/EoF
    41 (1) [-] any 41 2073600 B 1395.338703 1395.338717 30.007 fps ts mono/EoF
    42 (2) [-] any 42 2073600 B 1395.372030 1395.372044 30.006 fps ts mono/EoF
    43 (3) [-] any 43 2073600 B 1395.405357 1395.405371 30.006 fps ts mono/EoF
    44 (4) [-] any 44 2073600 B 1395.438684 1395.438697 30.006 fps ts mono/EoF
    45 (5) [-] any 45 2073600 B 1395.472010 1395.472024 30.007 fps ts mono/EoF
    46 (6) [-] any 46 2073600 B 1395.505339 1395.505354 30.004 fps ts mono/EoF
    47 (7) [-] any 47 2073600 B 1395.538664 1395.538678 30.008 fps ts mono/EoF
    48 (0) [-] any 48 2073600 B 1395.571990 1395.572044 30.007 fps ts mono/EoF
    49 (1) [-] any 49 2073600 B 1395.605317 1395.605332 30.006 fps ts mono/EoF
    50 (2) [-] any 50 2073600 B 1395.638644 1395.638658 30.006 fps ts mono/EoF
    what is the next step?
    Raveen
  • Raveen,
    Thanks for the test. That tells the the CSI Rx path is working fine. Looks like something is going on when the ISP is brought into the pipeline. Because ISP driver is running on the DM R5 core, IPC is involved for communications between A53 cores and the DM R5 core. I saw the following errors when you ran  the gst pipeline:
    Let me loop in our IPC team for help.
    Jianzhong
  • Raveen,
    I'm a little confused here. What's the difference between the following 2 cases:
    Jianzhong
  • Jianzhong,
    We initially booted the board using command-line settings, as the env.txt file was missing. After the boot process completed, we tested video streaming using a GStreamer pipeline command, and it worked fine—we were able to see the video stream.
    However, after adding the env.txt file with the following env variables:
    Copy code
    dorprocboot=1 name_overlays=
    we observed a different behavior during the boot process. The following logs were noted:
    It seems the U-Boot is load the remote processors using the following environment variables:
    boot_rprocs=if test ${dorprocboot} -eq 1 && test ${boot} = mmc; then rproc init; run boot_rprocs_mmc; fi;
    boot_rprocs_mmc=env set rproc_id; env set rproc_fw; env set secure_suffix; if test ${secure_rprocs} -eq 1; then env set secure_suffix -sec; fi; for i in ${rproc_fw_binaries} ; do if test -z "${rproc_id}" ; then env set rproc_id $i; else env set rproc_fw $i${secure_suffix}; run rproc_load_and_boot_one; env set rproc_id; env set rproc_fw; fi; done
    After the boot process is completed with dorprocboot=1 uboot env variable, we encountered issues with both the GStreamer pipeline and the Edge AI application. Below is a comparison of the two scenarios:
    Scenario 1: Setting dorprocboot=0
    • Behavior:
      • GStreamer video streaming works, and we can see the video output.
      • However, when running the app_edgeai.py application, the monitor initially displays a green screen, and after a few seconds, the application terminates.
    Scenario 2: Setting dorprocboot=1
    • Behavior:
      • GStreamer video streaming does not work. Running the pipeline command produces no output.
      • The app_edgeai.py application starts but only shows a static green screen until the application is terminated manually. No video stream is observed.
    Note: We added dorprocboot=1 to the env.txt file because it was originally included in the prebuilt WIC image (tisdk-edgeai-image-am62a-evm.wic) provided by TI
    Raveen
  • Hello Raveen,
    I'll let our U-Boot team comment on the differences between  dorprocboot=1 and dorprocboot=0. After that, we can continue debugging camera streaming.
    Jianzhong
  • dorprocboot determines whether the remote cores (C7 and MCU R5F) are initialized in uboot with the rproc driver, or in Linux with the remoteproc driver. The default behavior of when the EdgeAI cores are initialized is different in different AM62Ax SDK releases.
    For more information, please refer to the latest AM62Ax academy version of the page "Booting Remote Cores"
    https://dev.ti.com/tirex/explore/node?node=A__AX2DLf3J3o-JHYMSq7Eg0w__AM62A-ACADEMY__WeZ9SsL__LATEST
    Nick
  • Hi Nick,
    Thank you for the info, I referred the AM62Ax academy, we are now booting remoter core from Linux.
    Here are cores started by the Linux,
    root@am62axx-evm:/opt/edgeai-gst-apps/apps_python# head /sys/class/remoteproc/remoteproc*/state
    ==> /sys/class/remoteproc/remoteproc0/state <==
    running
    ==> /sys/class/remoteproc/remoteproc1/state <==
    running
    ==> /sys/class/remoteproc/remoteproc2/state <==
    attached
    root@am62axx-evm:/opt/edgeai-gst-apps/apps_python# head /sys/class/remoteproc/remoteproc*/firmware
    ==> /sys/class/remoteproc/remoteproc0/firmware <==
    am62a-c71_0-fw
    ==> /sys/class/remoteproc/remoteproc1/firmware <==
    am62a-mcu-r5f0_0-fw
    ==> /sys/class/remoteproc/remoteproc2/firmware <==
    unknown
    It seems the remote cores are up and running.
    In my previous post, I shared details about my hardware setup and the kmstest log. Currently, I am facing an issue where the application fails to run. When executed, it briefly flashes a green screen before closing unexpectedly. Please refer to the below log for more details.
    root@am62axx-evm:/opt/edgeai-gst-apps/apps_python# ./app_edgeai.py ../configs/imx219_cam_example.yaml -n
    libtidl_onnxrt_EP loaded 0x1b054cb0
    Final number of subgraphs created are : 1, - Offloaded Nodes - 283, Total Nodes - 283
    APP: Init ... !!!
      6476.728924 s: MEM: Init ... !!!
      6476.729037 s: MEM: Initialized DMA HEAP (fd=5) !!!
      6476.729212 s: MEM: Init ... Done !!!
      6476.729236 s: IPC: Init ... !!!
      6476.746694 s: IPC: Init ... Done !!!
      6476.750605 s: GTC Frequency = 200 MHz
      6476.750714 s:  VX_ZONE_INIT:Enabled
      6476.750719 s:  VX_ZONE_ERROR:Enabled
      6476.750722 s:  VX_ZONE_WARNING:Enabled
      6476.751764 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
      6476.751970 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
      6476.752150 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
      6476.752780 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
      6476.752790 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
      6476.753432 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
      6477.193705 s:  VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1
      6477.193716 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
      6477.193720 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
      6477.193724 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      6477.193729 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
      6477.193739 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
      6477.193743 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
      6477.193912 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
      6477.197129 s:  VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1
      6477.197140 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
      6477.197144 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
      6477.197148 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      6477.197153 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
      6477.197164 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
      6477.197168 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
      6477.197360 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
      6477.237781 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.246660 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.261800 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.295707 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.328263 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.362295 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.394955 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.429125 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.461657 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.495623 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.528205 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.562268 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.594847 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.628891 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.661488 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.695623 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.728159 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.762139 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.794837 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.828834 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.861461 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.895455 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.928097 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.962201 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6477.994773 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.028743 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.061408 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.095412 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.128102 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.162182 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.194852 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.228935 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.261468 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.295555 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.328058 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.362060 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.394772 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.428904 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.461425 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.495392 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.527998 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.562005 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.594670 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.628839 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.661316 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.695408 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.727971 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.762099 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.794630 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.828797 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.861285 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.895280 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.927917 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.962203 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6478.994619 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.028761 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.061293 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.095286 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.127866 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.161962 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.194592 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.228592 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.261185 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.295192 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.327858 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.361894 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.394569 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.428559 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.461206 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.495170 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.527812 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.561862 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.594469 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.628487 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.661124 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.695210 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.727759 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.761895 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.794428 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.828450 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.861086 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.895103 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.927701 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.961842 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6479.994391 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.028395 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.061048 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.095038 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.127687 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.161764 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.194390 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.228368 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.260991 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.295000 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.327967 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.361839 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.394385 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.428417 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.461050 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.495002 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.527629 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.561643 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.594254 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.628412 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.660996 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.695215 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.727804 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.761740 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.794282 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.828365 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.860890 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.894911 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.927543 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.961669 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6480.994194 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.028241 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.060841 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.094891 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.127509 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.161585 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.194201 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.228215 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.260789 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.295008 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.327497 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.361489 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.394180 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.428219 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.460814 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.494804 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.527452 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.561482 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.594070 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.628123 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.660729 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.694814 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
     ==========[INPUT PIPELINE(S)]==========
    [PIPE-0]
    v4l2src device=/dev/video-imx219-cam0 io-mode=5 pixel-aspect-ratio=None ! queue leaky=2 ! capsfilter caps="video/x-bayer, width=(int)1920, height=(int)1080, format=(string)rggb;" ! tiovxisp dcc-isp-file=/opt/imaging/imx219/linear/dcc_viss.bin sensor-name=SENSOR_SONY_IMX219_RPI ! capsfilter caps="video/x-raw, format=(string)NV12;" ! tiovxmultiscaler name=split_01
    split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1920, height=(int)1080;" ! tiovxdlcolorconvert out-pool-size=4 ! capsfilter caps="video/x-raw, format=(string)RGB;" ! appsink max-buffers=2 drop=True name=sen_0
    split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1168, height=(int)748;" ! tiovxmultiscaler target=1 ! capsfilter caps="video/x-raw, width=(int)416, height=(int)416;" ! tiovxdlpreproc out-pool-size=4 data-type=3 tensor-format=1 ! capsfilter caps="application/x-tensor-tiovx;" ! appsink max-buffers=2 drop=True name=pre_0
    ==========[OUTPUT PIPELINE]==========
    appsrc do-timestamp=True format=3 block=True name=post_0 ! tiovxdlcolorconvert ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080;" ! queue ! mosaic_0.sink_0
    tiovxmosaic target=1 background=/tmp/background_0 name=mosaic_0 src::pool-size=4
    sink_0::startx="<0>" sink_0::starty="<0>" sink_0::widths="<1920>" sink_0::heights="<1080>"
    ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080;" ! queue ! tiperfoverlay title=IMX219 Camera ! kmssink sync=False max-lateness=5000000 qos=True processing-deadline=15000000 driver-name=tidss connector-id=40 plane-id=31 force-modesetting=True fd=40
    [ERROR] Error pulling tensor from GST Pipeline
     6481.727415 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.761454 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.794031 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.828127 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.860676 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.894681 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.927346 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.961461 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6481.993986 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6482.028046 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6482.060610 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6482.094769 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6482.127610 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6482.161708 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
      6482.414992 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b44730 of type 00000816 at external count 1, internal count 0, releasing it
      6482.415003 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=multi_scaler_node_coeff_obj) now as a part of garbage collection
      6482.415063 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b44958 of type 00000816 at external count 1, internal count 0, releasing it
      6482.415068 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=user_data_object_115) now as a part of garbage collection
      6482.415120 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6be7520 of type 00000813 at external count 1, internal count 0, releasing it
      6482.415124 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=object_array_116) now as a part of garbage collection
      6482.415137 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b77be0 of type 0000080f at external count 1, internal count 0, releasing it
      6482.415141 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_117) now as a part of garbage collection
      6482.415152 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6be76c8 of type 00000813 at external count 1, internal count 0, releasing it
      6482.415156 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=scaler_node_output_arr0_buf0) now as a part of garbage collection
      6482.415166 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b77ea8 of type 0000080f at external count 1, internal count 0, releasing it
      6482.415171 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_119) now as a part of garbage collection
      6482.415177 s: MEM: ERROR: Failed to free memory at virt addr = 0xffff5ca48000 !!!
      6482.415182 s:  VX_ZONE_ERROR:[tivxMemBufferFree:262] Shared ptr mem free failed
      6482.415190 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6be7870 of type 00000813 at external count 1, internal count 0, releasing it
      6482.415194 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=scaler_node_output_arr1_buf0) now as a part of garbage collection
      6482.415204 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b78170 of type 0000080f at external count 1, internal count 0, releasing it
      6482.415208 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_121) now as a part of garbage collection
      6482.415213 s: MEM: ERROR: Failed to free memory at virt addr = 0xffff5c7c8000 !!!
      6482.415217 s:  VX_ZONE_ERROR:[tivxMemBufferFree:262] Shared ptr mem free failed
      6482.415225 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b44b80 of type 00000816 at external count 1, internal count 0, releasing it
      6482.415229 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=user_data_object_122) now as a part of garbage collection
      6482.415270 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b44da8 of type 00000816 at external count 1, internal count 0, releasing it
      6482.415399 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=multi_scaler_node_coeff_obj) now as a part of garbage collection
      6482.415449 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b44fd0 of type 00000816 at external count 1, internal count 0, releasing it
      6482.415453 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=user_data_object_164) now as a part of garbage collection
      6482.415489 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6be7d68 of type 00000813 at external count 1, internal count 0, releasing it
      6482.415494 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=object_array_165) now as a part of garbage collection
      6482.415505 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b789c8 of type 0000080f at external count 1, internal count 0, releasing it
      6482.415509 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_166) now as a part of garbage collection
      6482.415519 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6be7f10 of type 00000813 at external count 1, internal count 0, releasing it
      6482.415523 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=scaler_node_output_arr0_buf0) now as a part of garbage collection
      6482.415533 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffa6b78c90 of type 0000080f at external count 1, internal count 0, releasing it
      6482.415537 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_168) now as a part of garbage collection
      6482.415688 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:120] De-Initialization Done for HOST !!!
      6482.420520 s:  VX_ZONE_INIT:[tivxDeInitLocal:206] De-Initialization Done !!!
    APP: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... Done !!!
      6482.421035 s: IPC: Deinit ... !!!
      6482.421536 s: IPC: DeInit ... Done !!!
      6482.421562 s: MEM: Deinit ... !!!
      6482.422493 s: DDR_SHARED_MEM: Alloc's: 83 alloc's of 152926011 bytes
      6482.422504 s: DDR_SHARED_MEM: Free's : 83 free's  of 152926011 bytes
      6482.422507 s: DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
      6482.422516 s: MEM: Deinit ... Done !!!
    APP: Deinit ... Done !!!
    Raveen
  • Hello Raveen,
    Can you share the log of "media-ctl -p"?
    Also, did the following pipeline work now (which worked when you booted the board using command-line settings)?
    gst-launch-1.0 \
    v4l2src device=/dev/video-imx219-cam0 io-mode=5 ! video/x-bayer,width=1920,height=1080,framerate=30/1,format=rggb ! queue leaky=2 ! \
    tiovxisp sink_0::device=/dev/v4l-imx219-subdev0 sensor-name=SENSOR_SONY_IMX219_RPI dcc-isp-file=/opt/imaging/imx219/linear/dcc_viss_1920x1080.bin \
    sink_0::dcc-2a-file=/opt/imaging/imx219/linear/dcc_2a_1920x1080.bin sink_0::pool-size=8 src::pool-size=8 ! \
    video/x-raw,format=NV12, width=1920,height=1080 ! \
    kmssink driver-name=tidss sync=false force-modesetting=true
    Jianzhong
  • Hi Jianzhong,
    Please find the logs below,
    root@am62axx-evm:/opt/edgeai-gst-apps# media-ctl -p
    Media controller API version 6.6.32
    Media device information
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    bus info        platform:30102000.ticsi2rx
    hw revision     0x1
    driver version  6.6.32
    Device topology
    - entity 1: 30102000.ticsi2rx (7 pads, 7 links, 1 route)
                type V4L2 subdev subtype Unknown flags 0
                device node name /dev/v4l-subdev0
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    [stream:0 fmt:SRGGB8_1X8/1920x1080 field:none]
                    <- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
            pad2: Source
                    -> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
            pad3: Source
                    -> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
            pad4: Source
                    -> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
            pad5: Source
                    -> "30102000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE]
            pad6: Source
                    -> "30102000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE]
    - entity 9: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 1 route)
                device node name /dev/v4l-subdev1
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    <- "imx219 2-0010":0 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE]
            pad2: Source
            pad3: Source
            pad4: Source
    - entity 15: imx219 2-0010 (1 pad, 1 link, 0 routes)
                 type V4L2 subdev subtype Sensor flags 0
                 device node name /dev/v4l-subdev2
            pad0: Source
                    [stream:0 fmt:SRGGB8_1X8/1920x1080 field:none colorspace:raw xfer:none quantization:full-range
                     crop.bounds:(8,8)/3280x2464
                     crop:(688,700)/1920x1080]
                    -> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE]
    - entity 21: 30102000.ticsi2rx context 0 (1 pad, 1 link)
                 type Node subtype V4L flags 0
                 device node name /dev/video3
            pad0: Sink
                    <- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE]
    - entity 27: 30102000.ticsi2rx context 1 (1 pad, 1 link)
                 device node name /dev/video4
            pad0: Sink
                    <- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE]
    - entity 33: 30102000.ticsi2rx context 2 (1 pad, 1 link)
                 device node name /dev/video5
            pad0: Sink
                    <- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE]
    - entity 39: 30102000.ticsi2rx context 3 (1 pad, 1 link)
                 device node name /dev/video6
            pad0: Sink
                    <- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE]
    - entity 45: 30102000.ticsi2rx context 4 (1 pad, 1 link)
                 device node name /dev/video7
            pad0: Sink
                    <- "30102000.ticsi2rx":5 [ENABLED,IMMUTABLE]
    - entity 51: 30102000.ticsi2rx context 5 (1 pad, 1 link)
                 device node name /dev/video8
            pad0: Sink
                    <- "30102000.ticsi2rx":6 [ENABLED,IMMUTABLE]
    The pipe you shared in the  previous replay is working, I can see the video streaming,
    root@am62axx-evm:/opt/edgeai-gst-apps# export GST_DEBUG=2
    root@am62axx-evm:/opt/edgeai-gst-apps# gst-launch-1.0 v4l2src device=/dev/video-imx219-cam0 io-mode=5 ! video/x-bayer,width=1920,height=1080,framerate=30/1,format=rggb ! queue leaky=2 ! tiovxisp sink_0::device=/dev/v4l-imx219-subdev0 sensor-name=SENSOR_SONY_IMX219_RPI dcc-isp-file=/opt/imaging/imx219/linear/dcc_viss_1920x1080.bin sink_0::dcc-2a-file=/opt/imaging/imx219/linear/dcc_2a_1920x1080.bin sink_0::pool-size=8 src::pool-size=8 ! video/x-raw,format=NV12, width=1920,height=1080 ! kmssink driver-name=tidss sync=false force-modesetting=true
    APP: Init ... !!!
       133.303285 s: MEM: Init ... !!!
       133.303338 s: MEM: Initialized DMA HEAP (fd=8) !!!
       133.303473 s: MEM: Init ... Done !!!
       133.303486 s: IPC: Init ... !!!
       133.320773 s: IPC: Init ... Done !!!
    REMOTE_SERVICE: Init ... !!!
    REMOTE_SERVICE: Init ... Done !!!
       133.324712 s: GTC Frequency = 200 MHz
    APP: Init ... Done !!!
       133.324842 s:  VX_ZONE_INIT:Enabled
       133.324857 s:  VX_ZONE_ERROR:Enabled
       133.324867 s:  VX_ZONE_WARNING:Enabled
       133.325697 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
       133.325977 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
       133.326177 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
       133.326326 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
       133.326351 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
       133.327221 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
    0:00:00.157241785  1496     0x3af51ae0 WARN                 kmssink gstkmssink.c:2101:_validate_and_set_external_fd:<kmssink0> Can't set fd... driver-name already set.
    Setting pipeline to PAUSED ...
    0:00:00.295530260  1496 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.295661840  1496 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    Pipeline is live and does not need PREROLL ...
    0:00:00.295968385  1496 0xffffb0000eb0 WARN                    v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed
    0:00:00.296028900  1496 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.296065055  1496 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    Pipeline is PREROLLED ...
    Setting pipeline to PLAYING ...
    0:00:00.297035955  1496 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.297102135  1496 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    New clock: GstSystemClock
    0:00:00.297221320  1496 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.297256380  1496 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    0:00:00.297873670  1496 0xffffb0000b70 WARN                 v4l2src gstv4l2src.c:987:gst_v4l2src_query:<v4l2src0> Can't give latency since framerate isn't fixated !
    0:00:00.297907495  1496 0xffffb0000eb0 WARN                    v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed
    0:00:00.297941750  1496 0xffffb0000b70 WARN              aggregator gstaggregator.c:2159:gst_aggregator_query_latency_unlocked:<tiovxisp0> Latency query failed
    0:00:00.387241065  1496 0xffffb0000eb0 WARN          v4l2bufferpool gstv4l2bufferpool.c:1334:gst_v4l2_buffer_pool_dqbuf:<v4l2src0:pool0:src> Driver should never set v4l2_buffer.field to ANY
    0:00:00.454536510  1496 0xffffb0000eb0 WARN                    v4l2 gstv4l2object.c:4666:gst_v4l2_object_get_crop_rect:<v4l2src0:src> VIDIOC_CROPCAP failed
    0:00:00.469055135  1496 0xffffb0000b70 WARN            kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22
    Redistribute latency...
    0:00:00.499244475  1496 0xffffb0000b70 WARN            kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22
    0:00:00.515095285  1496 0xffffb0000b70 WARN            kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22
    0:00:00.533286010  1496 0xffffb0000b70 WARN            kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22
    0:00:00.548350305  1496 0xffffb0000b70 WARN            kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22
    0:00:00.565727515  1496 0xffffb0000b70 WARN            kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22
    0:00:00.594164100  1496 0xffffb0000b70 WARN            kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22
    0:00:00.628178835  1496 0xffffb0000b70 WARN            kmsallocator gstkmsallocator.c:526:gst_kms_allocator_dmabuf_import:<KMSMemory::allocator> Failed to close GEM handle: Invalid argument 22
    ^Chandling interrupt.
    Interrupt: Stopping pipeline ...
    Execution ended after 0:00:11.561091105
    Setting pipeline to NULL ...
    Freeing pipeline ...
       145.131899 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:120] De-Initialization Done for HOST !!!
       145.136366 s:  VX_ZONE_INIT:[tivxDeInitLocal:206] De-Initialization Done !!!
    APP: Deinit ... !!!
       145.136813 s: IPC: Deinit ... !!!
       145.137264 s: IPC: DeInit ... Done !!!
       145.137296 s: MEM: Deinit ... !!!
       145.137364 s: DDR_SHARED_MEM: Alloc's: 37 alloc's of 55412555 bytes
       145.137377 s: DDR_SHARED_MEM: Free's : 37 free's  of 55412555 bytes
       145.137387 s: DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
       145.137401 s: MEM: Deinit ... Done !!!
    Raveen
  • Hello Jianzhong,
    I am awaiting your support as our project is currently on hold. Kindly provide a response at your earliest convenience.
    Raveen
  • Hello Raveen,
    I apologize for the delay in response. Your "media-ctl -p" output looks okay. Since now streaming from camera to display works fine, the issue  is with "./app_edgeai.py ../configs/imx219_cam_example.yaml -n", right? Can you update the current status and error message so that our EdgeAI team member can take a look?
    Thanks you.
    Jianzhong
  • Hi Jianzhong,
    Thank you for the response, there is no improvement we still facing the same issue,
    Error Log:
    root@am62axx-evm:/opt/edgeai-gst-apps/apps_python# ./app_edgeai.py ../configs/object_detection.yaml -n
    libtidl_onnxrt_EP loaded 0x3c2555d0
    APP: Init ... !!!
       129.609722 s: MEM: Init ... !!!
       129.609815 s: MEM: Initialized DMA HEAP (fd=5) !!!
       129.610021 s: MEM: Init ... Done !!!
       129.610054 s: IPC: Init ... !!!
       129.627440 s: IPC: Init ... Done !!!
       129.639036 s: GTC Frequency = 200 MHz
       129.649455 s:  VX_ZONE_INIT:Enabled
       129.649515 s:  VX_ZONE_ERROR:Enabled
       129.649525 s:  VX_ZONE_WARNING:Enabled
       129.651147 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
       129.651351 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
       129.651463 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
       129.651564 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
       129.651579 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
       129.655327 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
    [PIPE-0]
    split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1280, height=(int)720;" ! tiovxdlcolorconvert out-pool-size=4 ! capsfilter caps="video/x-raw, format=(string)RGB;" ! appsink max-buffers=2 drop=True name=sen_0
    appsrc do-timestamp=True format=3 block=True name=post_0 ! tiovxdlcolorconvert ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1280, height=(int)720;" ! queue ! mosaic_0.sink_0
    sink_0::startx="<320>" sink_0::starty="<150>" sink_0::widths="<1280>" sink_0::heights="<720>"
    ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080;" ! queue ! tiperfoverlay title=Object Detection ! kmssink sync=False max-lateness=5000000 qos=True processing-deadline=15000000 driver-name=tidss connector-id=40 plane-id=31 force-modesetting=True fd=40
       130.647501 s:  VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1
       130.647543 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
       130.647753 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
       130.647772 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       130.647788 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
       130.647808 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
       130.647818 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
       130.647999 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
       130.651813 s:  VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1
       130.651856 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
       130.651868 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
       130.651879 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       130.651895 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
       130.651914 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
       130.651925 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
       130.652111 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
       130.705521 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.321: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.725846 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.341: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.732357 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.348: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.749546 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.365: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.782130 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.397: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.815974 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.431: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.848750 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.464: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.882698 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.498: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.915440 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.531: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.949298 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.565: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       130.982070 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.597: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.015977 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.631: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.048697 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.664: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.082590 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.698: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.115342 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.731: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.149319 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.765: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.182015 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.797: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.215888 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.831: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.248735 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.864: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.282595 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.898: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.315324 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.931: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.349195 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.964: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.381996 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:11.997: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.415897 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.031: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.448780 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.064: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.482806 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.098: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.515336 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.131: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.549251 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.165: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.581936 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.197: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.615854 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.231: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.648653 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.264: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.682684 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.298: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.715250 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.331: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.749162 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.364: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.781927 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.397: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.815844 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.431: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.848554 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.464: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.882499 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.498: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.915233 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.531: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.949199 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.564: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       131.981861 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.597: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.015797 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.631: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.048509 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.664: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.082417 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.698: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.115142 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.730: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.149135 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.764: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.181816 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.797: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.215732 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.831: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.248463 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.864: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.282390 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.898: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.315104 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.930: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.349004 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.964: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.381782 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:12.997: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.415718 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.031: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.448423 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.064: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.482370 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.098: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.515116 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.130: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.549032 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.164: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.581740 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.197: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.615782 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.231: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.648462 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.264: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.682315 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.298: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.715048 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.330: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.748969 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.364: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.781692 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.397: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.815821 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.431: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.848524 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.464: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.882404 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.498: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.915076 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.530: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.948982 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.564: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       132.981672 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.597: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.015589 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.631: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.048351 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.664: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.082281 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.698: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.114963 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.730: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.148995 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.764: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.181646 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.797: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.215527 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.831: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.248306 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.864: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.282212 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.898: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.314915 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.930: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.348853 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.964: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.381610 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:13.997: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.415541 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.031: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.448261 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.064: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.482183 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.097: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.514920 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.130: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.548865 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.164: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.581670 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.197: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.615523 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.231: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.648303 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.264: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.682172 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.297: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.714850 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.330: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.748785 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.364: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.781504 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.397: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.815394 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.431: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.848146 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.463: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.882106 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.497: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.914836 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.530: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.948744 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.564: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       133.981461 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.597: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.015465 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.631: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.048119 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.663: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.082067 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.697: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.114860 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.730: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.148819 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.764: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.181434 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.797: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.215361 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.831: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.248075 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.863: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.282094 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.897: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.314771 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.930: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.348681 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.964: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.381411 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:14.997: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.415378 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.031: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.448204 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.064: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.482089 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.097: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.514764 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.130: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.548662 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.164: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.581370 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.197: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.615325 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.231: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.648067 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.263: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.681960 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.297: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.714692 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.330: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.748592 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.364: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.781304 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.397: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.815235 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.431: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.847969 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.463: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.881911 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.497: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.914672 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.530: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.948544 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.564: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       134.981263 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.597: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.015218 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.631: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.047900 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.663: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.081862 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.697: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.114606 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.730: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.148573 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.764: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.181233 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.797: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.215166 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.830: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.247862 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.863: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.281794 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.897: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.314561 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.930: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.348453 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.964: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.381212 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:15.997: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.415178 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:16.030: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.447840 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:16.063: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.481804 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:16.097: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.514560 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:16.130: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.548433 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:16.164: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.581420 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:16.197: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.615394 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (python3:1476): CRITICAL **: 00:02:16.231: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
       135.870525 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f724730 of type 00000816 at external count 1, internal count 0, releasing it
       135.870620 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=multi_scaler_node_coeff_obj) now as a part of garbage collection
       135.870684 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f724958 of type 00000816 at external count 1, internal count 0, releasing it
       135.870699 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=user_data_object_115) now as a part of garbage collection
       135.870749 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f7c7520 of type 00000813 at external count 1, internal count 0, releasing it
       135.870762 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=object_array_116) now as a part of garbage collection
       135.870783 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f757be0 of type 0000080f at external count 1, internal count 0, releasing it
       135.870796 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_117) now as a part of garbage collection
       135.870815 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f7c76c8 of type 00000813 at external count 1, internal count 0, releasing it
       135.870827 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=scaler_node_output_arr0_buf0) now as a part of garbage collection
       135.870845 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f757ea8 of type 0000080f at external count 1, internal count 0, releasing it
       135.870858 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_119) now as a part of garbage collection
       135.870871 s: MEM: ERROR: Failed to free memory at virt addr = 0xffff464d0000 !!!
       135.870883 s:  VX_ZONE_ERROR:[tivxMemBufferFree:262] Shared ptr mem free failed
       135.870898 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f7c7870 of type 00000813 at external count 1, internal count 0, releasing it
       135.870911 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=scaler_node_output_arr1_buf0) now as a part of garbage collection
       135.870929 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f758170 of type 0000080f at external count 1, internal count 0, releasing it
       135.870942 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_121) now as a part of garbage collection
       135.870955 s: MEM: ERROR: Failed to free memory at virt addr = 0xffff46250000 !!!
       135.870966 s:  VX_ZONE_ERROR:[tivxMemBufferFree:262] Shared ptr mem free failed
       135.870980 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f724b80 of type 00000816 at external count 1, internal count 0, releasing it
       135.870992 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=user_data_object_122) now as a part of garbage collection
       135.871055 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f724da8 of type 00000816 at external count 1, internal count 0, releasing it
       135.871069 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=multi_scaler_node_coeff_obj) now as a part of garbage collection
       135.871117 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f724fd0 of type 00000816 at external count 1, internal count 0, releasing it
       135.871131 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=user_data_object_164) now as a part of garbage collection
       135.871175 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f7c7d68 of type 00000813 at external count 1, internal count 0, releasing it
       135.871189 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=object_array_165) now as a part of garbage collection
       135.871209 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f7589c8 of type 0000080f at external count 1, internal count 0, releasing it
       135.871221 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_166) now as a part of garbage collection
       136.203825 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f7c7f10 of type 00000813 at external count 1, internal count 0, releasing it
       136.203856 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=scaler_node_output_arr0_buf0) now as a part of garbage collection
       136.203879 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff8f758c90 of type 0000080f at external count 1, internal count 0, releasing it
       136.203892 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_168) now as a part of garbage collection
       136.204160 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:120] De-Initialization Done for HOST !!!
       136.209008 s:  VX_ZONE_INIT:[tivxDeInitLocal:206] De-Initialization Done !!!
    APP: Deinit ... !!!
       136.209563 s: IPC: Deinit ... !!!
       136.210117 s: IPC: DeInit ... Done !!!
       136.210166 s: MEM: Deinit ... !!!
       136.210956 s: DDR_SHARED_MEM: Alloc's: 83 alloc's of 121822011 bytes
       136.210986 s: DDR_SHARED_MEM: Free's : 83 free's  of 121822011 bytes
       136.210996 s: DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
       136.211010 s: MEM: Deinit ... Done !!!
    Config File:
    root@am62axx-evm:/opt/edgeai-gst-apps/apps_python# cat ../configs/object_detection.yaml
    title: "Object Detection"
    log_level: 2
    inputs:
        input0:
            source: /dev/video-imx219-cam0
            subdev-id: /dev/v4l-imx219-subdev0
            format: rggb
            width: 1920
            height: 1080
            framerate: 30
        input1:
            source: /opt/edgeai-test-data/videos/video0_1280_768.h264
            format: h264
            width: 1280
            height: 768
            framerate: 30
            loop: True
        input2:
            source: /opt/edgeai-test-data/images/%04d.jpg
            width: 1280
            height: 720
            index: 0
            framerate: 1
            loop: True
    models:
        model0:
            model_path: /opt/model_zoo/TVM-OD-5120-ssdLite-mobDet-DSP-coco-320x320
            viz_threshold: 0.6
        model1:
            model_path: /opt/model_zoo/TFL-OD-2020-ssdLite-mobDet-DSP-coco-320x320
            viz_threshold: 0.6
        model2:
            model_path: /opt/model_zoo/ONR-OD-8200-yolox-nano-lite-mmdet-coco-416x416
            viz_threshold: 0.6
    outputs:
        output0:
            sink: kmssink
            width: 1920
            height: 1080
            overlay-perf-type: graph
        output1:
            sink: /opt/edgeai-test-data/output/output_video0.mkv
            width: 1920
            height: 1080
        output2:
            sink: /opt/edgeai-test-data/output/output_image_%04d.jpg
            width: 1920
            height: 1080
        output3:
            sink: remote
            width: 1920
            height: 1080
            port: 8081
            host: 127.0.0.1
            encoding: jpeg
    flows:
        flow0: [input0,model2,output0,[320,150,1280,720]]
    kmstest log:
    root@am62axx-evm:/opt/edgeai-gst-apps/apps_python# kmstest
    Connector 0/@40: HDMI-A-1
      Crtc 0/@38: 1920x1080@60.00 148.500 1920/88/44/148/+ 1080/4/5/36/+ 60 (60.00) 0x5 0x48
      Plane 0/@31: 0,0-1920x1080
        Fb 51 1920x1080-XR24
    press enter to exit
    Raveen
  • Hi Raveen,
    I saw this error: "Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node". Not sure why the multiscaler node creation failed. Could you add multiscaler to the pipeline I provided and see if it runs? For example,
    gst-launch-1.0 \
    tiovxmultiscaler ! video/x-raw,format=NV12, width=640, height=480 ! \
    Can you run /opt/vx_app_arm_remote_log.out in the background while you're running app_edgeai.py? This logger should provide some more information about what's going on.
    Also, what's your DDR size?
    Jianzhong
  • Jianzhong,
    I have run the command you provided with multiscalar, I got a blank green screen in the display.
    root@am62axx-evm:/opt/edgeai-gst-apps/apps_python# gst-launch-1.0 \
    APP: Init ... !!!
      2784.397175 s: MEM: Init ... !!!
      2784.397218 s: MEM: Initialized DMA HEAP (fd=8) !!!
      2784.397354 s: MEM: Init ... Done !!!
      2784.397367 s: IPC: Init ... !!!
      2784.414633 s: IPC: Init ... Done !!!
      2784.418831 s: GTC Frequency = 200 MHz
      2784.418952 s:  VX_ZONE_INIT:Enabled
      2784.418966 s:  VX_ZONE_ERROR:Enabled
      2784.418976 s:  VX_ZONE_WARNING:Enabled
      2784.419772 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
      2784.420029 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
      2784.420258 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
      2784.420531 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
      2784.420569 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
      2784.421123 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
      2784.659350 s:  VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1
      2784.659431 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
      2784.659444 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
      2784.659456 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      2784.659471 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
      2784.659489 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
      2784.659500 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
      2784.659660 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
      2784.742020 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.020: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.749533 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.028: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.756047 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.034: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.763972 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.042: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.795436 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.073: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.829311 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.107: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.862022 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.140: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.895988 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.174: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.928665 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.207: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.962572 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.241: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2784.995355 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.273: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.029271 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.307: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.061964 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.340: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.095986 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.374: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.128648 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.407: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.162545 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.440: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.195295 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.473: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.229226 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.507: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.261961 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.540: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.295926 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.574: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.328673 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.607: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.362565 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.641: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.395284 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.673: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.429188 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.707: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.461883 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.740: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.496059 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.774: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.528566 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.807: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.562467 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.840: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.595229 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.873: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.629120 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.907: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.661836 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.940: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.695973 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:13.974: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.728501 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.006: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.762536 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.041: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.795236 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.073: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.829092 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.107: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.861806 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.140: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.895781 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.174: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.928451 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.206: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.962373 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.240: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2785.995147 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.273: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.029092 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.307: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.061767 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.340: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.095748 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.374: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.128437 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.406: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.162351 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.440: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.195096 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.473: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.228989 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.507: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.261758 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.540: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.295723 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.574: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.328380 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.606: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.362311 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.640: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.395068 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.673: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.428957 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.707: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.461739 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.740: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.495808 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.774: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.528396 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.806: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.562302 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.840: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.595038 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.873: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.628912 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.907: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.661671 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.940: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.695635 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:14.974: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.728298 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.006: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.762376 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.040: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.794998 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.073: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.828874 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.107: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.861622 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.140: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.895586 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.174: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.928263 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.206: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.962198 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.240: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2786.994966 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.273: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.028924 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.307: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.061611 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.340: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.095571 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.374: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.128232 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.406: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.162183 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.440: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.194908 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.473: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.228806 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.507: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.261599 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:15.540: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2787.295539 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:21.938: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2793.694234 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:21.972: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2793.726957 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:22.005: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2793.760942 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:22.039: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2793.793609 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1748): CRITICAL **: 18:12:22.072: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
      2793.827555 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is ^Chandling interrupt.
    Interrupt: Stopping pipeline ...
    Execution ended after 0:00:09.263177865
    Setting pipeline to NULL ...
    Freeing pipeline ...
      2793.920327 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffb3053c68 of type 00000816 at external count 1, internal count 0, releasing it
      2793.920392 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=multi_scaler_node_coeff_obj) now as a part of garbage collection
      2793.920471 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffb3053e90 of type 00000816 at external count 1, internal count 0, releasing it
      2793.920486 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=user_data_object_104) now as a part of garbage collection
      2793.920531 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffb30f7870 of type 00000813 at external count 1, internal count 0, releasing it
      2793.920545 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=object_array_105) now as a part of garbage collection
      2793.920566 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffb3086b30 of type 0000080f at external count 1, internal count 0, releasing it
      2793.920579 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_106) now as a part of garbage collection
      2793.920598 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffb30f7a18 of type 00000813 at external count 1, internal count 0, releasing it
      2793.920610 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=scaler_node_output_arr0_buf0) now as a part of garbage collection
      2793.920629 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffffb3086df8 of type 0000080f at external count 1, internal count 0, releasing it
      2793.920642 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_108) now as a part of garbage collection
      2793.920732 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:120] De-Initialization Done for HOST !!!
      2793.925202 s:  VX_ZONE_INIT:[tivxDeInitLocal:206] De-Initialization Done !!!
    APP: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... !!!
    REMOTE_SERVICE: Deinit ... Done !!!
      2793.925701 s: IPC: Deinit ... !!!
      2793.926139 s: IPC: DeInit ... Done !!!
      2793.926174 s: MEM: Deinit ... !!!
      2793.926660 s: DDR_SHARED_MEM: Alloc's: 56 alloc's of 53112526 bytes
      2793.926683 s: DDR_SHARED_MEM: Free's : 56 free's  of 53112526 bytes
      2793.926694 s: DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
      2793.926708 s: MEM: Deinit ... Done !!!
    APP: Deinit ... Done !!!
    We have 4GB DDR, we used the same part number used in the EVK
    root@am62axx-evm:/opt/edgeai-gst-apps/apps_python# free -h
                   total        used        free      shared  buff/cache   available
    Mem:           3.2Gi       329Mi       2.7Gi        13Mi       337Mi       2.9Gi
    Swap:             0B          0B          0B
    root@am62axx-evm:/opt/edgeai-gst-apps# /opt/vx_app_arm_remote_log.out
    [MCU1_0]      0.033912 s: CIO: Init ... Done !!!
    [MCU1_0]      0.033953 s: APP: Init ... !!!
    [MCU1_0]      0.033986 s: MEM: Init ... !!!
    [MCU1_0]      0.034004 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ af000000 of size 16777216 bytes !!!
    [MCU1_0]      0.034044 s: MEM: Init ... Done !!!
    [MCU1_0]      0.034071 s: IPC: Init ... !!!
    [MCU1_0]      0.034088 s: IPC: 3 CPUs participating in IPC !!!
    [MCU1_0]      0.034382 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU1_0]      0.038732 s: #Sciserver Version: v2023.11.0.0REL.MCUSDK.MM.NN.PP.bb
    [MCU1_0]      0.041505 s: ##RM_PM_HAL Version: vMM.NN.PP
    [MCU1_0]      0.044452 s: ##Starting Sciserver..... PASSED
    [MCU1_0]     15.404093 s: IPC: HLOS is ready !!!
    [MCU1_0]     15.404179 s: IPC: Init ... Done !!!
    [MCU1_0]     15.404203 s: APP: Syncing with 2 CPUs ... !!!
    [MCU1_0]     15.404226 s: APP: Syncing with 2 CPUs ... Done !!!
    [MCU1_0]     15.404246 s: REMOTE_SERVICE: Init ... !!!
    [MCU1_0]     15.404321 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU1_0]     15.404345 s: FVID2: Init ... !!!
    [MCU1_0]     15.404372 s: FVID2: Init ... Done !!!
    [MCU1_0]     15.404389 s: VHWA: VPAC Init ... !!!
    [MCU1_0]     15.404404 s: SCICLIENT: Sciclient_pmSetModuleState module=219 state=2
    [MCU1_0]     15.404488 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU1_0]     15.404548 s: VHWA: LDC Init ... !!!
    [MCU1_0]     15.404641 s: VHWA: LDC Init ... Done !!!
    [MCU1_0]     15.404664 s: VHWA: MSC Init ... !!!
    [MCU1_0]     15.405232 s: VHWA: MSC Init ... Done !!!
    [MCU1_0]     15.405286 s: VHWA: VISS Init ... !!!
    [MCU1_0]     15.405615 s: VHWA: VISS Init ... Done !!!
    [MCU1_0]     15.405638 s: VHWA: VPAC Init ... Done !!!
    [MCU1_0]     15.405663 s:  VX_ZONE_INIT:Enabled
    [MCU1_0]     15.405681 s:  VX_ZONE_ERROR:Enabled
    [MCU1_0]     15.405697 s:  VX_ZONE_WARNING:Enabled
    [MCU1_0]     15.406758 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU1-0
    [MCU1_0]     15.406861 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_LDC1
    [MCU1_0]     15.406971 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC1
    [MCU1_0]     15.407040 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC2
    [MCU1_0]     15.407105 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_VISS1
    [MCU1_0]     15.407135 s:  VX_ZONE_INIT:[tivxInitLocal:142] Initialization Done !!!
    [MCU1_0]     15.407156 s: APP: OpenVX Target kernel init ... !!!
    [MCU1_0]     15.411510 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU1_0]     15.411537 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU1_0]     15.411581 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU1_0]     15.411600 s: APP: Init ... Done !!!
    [MCU1_0]     15.411615 s: APP: Run ... !!!
    [MCU1_0]     15.411629 s: IPC: Starting echo test ...
    [MCU1_0]     15.411742 s: APP: Run ... Done !!!
    [MCU1_0]     15.412129 s: IPC: Echo status: a530-0[.] r5f0-0[s] c75ss0[P]
    [C7x_1 ]      5.668882 s: CIO: Init ... Done !!!
    [C7x_1 ]      5.668901 s: APP: Init ... !!!
    [C7x_1 ]      5.668914 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      5.668974 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_1 ]      5.668993 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_1 ]      5.669008 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_1 ]      5.669024 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      5.669037 s: UDMA: Init ... !!!
    [C7x_1 ]      5.669050 s: UDMA: Init ... Done !!!
    [C7x_1 ]      5.669062 s: MEM: Init ... !!!
    [C7x_1 ]      5.669075 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ b2000000 of size 117440512 bytes !!!
    [C7x_1 ]      5.669104 s: MEM: Init ... Done !!!
    [C7x_1 ]      5.669116 s: IPC: Init ... !!!
    [C7x_1 ]      5.669128 s: IPC: 3 CPUs participating in IPC !!!
    [C7x_1 ]      5.669326 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     15.137036 s: IPC: HLOS is ready !!!
    [C7x_1 ]     15.137107 s: IPC: Init ... Done !!!
    [C7x_1 ]     15.137121 s: APP: Syncing with 2 CPUs ... !!!
    [C7x_1 ]     15.404226 s: APP: Syncing with 2 CPUs ... Done !!!
    [C7x_1 ]     15.404243 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]     15.405064 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]     15.405098 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]     15.405115 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]     15.405130 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]     15.405853 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1
    [C7x_1 ]     15.405947 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_2
    [C7x_1 ]     15.406053 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_3
    [C7x_1 ]     15.406150 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_4
    [C7x_1 ]     15.406243 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_5
    [C7x_1 ]     15.406337 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_6
    [C7x_1 ]     15.406431 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_7
    [C7x_1 ]     15.406525 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_8
    [C7x_1 ]     15.406552 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_1 ]     15.406569 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]     15.406773 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]     15.406790 s: APP: Init ... Done !!!
    [C7x_1 ]     15.406803 s: APP: Run ... !!!
    [C7x_1 ]     15.406815 s: IPC: Starting echo test ...
    [C7x_1 ]     15.406912 s: APP: Run ... Done !!!
    [C7x_1 ]     15.412209 s: IPC: Echo status: a530-0[.] r5f0-0[P] c75ss0[s]
    Raveen
  • Hi Raveen,
    I'm still seeing this error: "Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node". Not exactly sure what could cause this error.
    We are currently working on a custom hardware project using the AM62A7 SoC and have built a Yocto SDK (Version 10) for our setup.
    What are the changes you made to build your version of SDK? Did you touch anything in the R5 firmware?
    Jianzhong
  • Hi Raveen,
    Can you please do below steps and share the logs
    1. reboot
    2. /opt/vx_app_arm_remote_log.out &
    3. press enter to get back to terminal
    4. gst-launch-1.0 videotestsrc ! video/x-raw, format=NV12, width=1920, height=1080 ! tiovxmultiscaler ! video/x-raw, format=NV12, width=1280, height=720, format=NV12 ! fakesink
    Rahul T R
  • Jianzhong,
    We have not made any changes to the R5 firmware. However, we did update the device tree. For your reference, the AI application is working well with SDK 9.1.
    Raveen
  • Hello Rahul,
    Please find the log below:
    root@am62axx-evm:/opt/edgeai-gst-apps#  /opt/vx_app_arm_remote_log.out &
    [1] 1469
    root@am62axx-evm:/opt/edgeai-gst-apps# [MCU1_0]      0.033834 s: CIO: Init ... Done !!!
    [MCU1_0]      0.033873 s: APP: Init ... !!!
    [MCU1_0]      0.033907 s: MEM: Init ... !!!
    [MCU1_0]      0.033924 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ af000000 of size 16777216 bytes !!!
    [MCU1_0]      0.033976 s: MEM: Init ... Done !!!
    [MCU1_0]      0.033992 s: IPC: Init ... !!!
    [MCU1_0]      0.034009 s: IPC: 3 CPUs participating in IPC !!!
    [MCU1_0]      0.034305 s: IPC: Waiting for HLOS to be ready ... !!!
    [MCU1_0]      0.038648 s: #Sciserver Version: v2023.11.0.0REL.MCUSDK.MM.NN.PP.bb
    [MCU1_0]      0.041422 s: ##RM_PM_HAL Version: vMM.NN.PP
    [MCU1_0]      0.044368 s: ##Starting Sciserver..... PASSED
    [MCU1_0]     15.765043 s: IPC: HLOS is ready !!!
    [MCU1_0]     15.765124 s: IPC: Init ... Done !!!
    [MCU1_0]     15.765145 s: APP: Syncing with 2 CPUs ... !!!
    [MCU1_0]     15.765167 s: APP: Syncing with 2 CPUs ... Done !!!
    [MCU1_0]     15.765187 s: REMOTE_SERVICE: Init ... !!!
    [MCU1_0]     15.765261 s: REMOTE_SERVICE: Init ... Done !!!
    [MCU1_0]     15.765283 s: FVID2: Init ... !!!
    [MCU1_0]     15.765310 s: FVID2: Init ... Done !!!
    [MCU1_0]     15.765328 s: VHWA: VPAC Init ... !!!
    [MCU1_0]     15.765342 s: SCICLIENT: Sciclient_pmSetModuleState module=219 state=2
    [MCU1_0]     15.765428 s: SCICLIENT: Sciclient_pmSetModuleState success
    [MCU1_0]     15.765493 s: VHWA: LDC Init ... !!!
    [MCU1_0]     15.765588 s: VHWA: LDC Init ... Done !!!
    [MCU1_0]     15.765610 s: VHWA: MSC Init ... !!!
    [MCU1_0]     15.766173 s: VHWA: MSC Init ... Done !!!
    [MCU1_0]     15.766196 s: VHWA: VISS Init ... !!!
    [MCU1_0]     15.766553 s: VHWA: VISS Init ... Done !!!
    [MCU1_0]     15.766574 s: VHWA: VPAC Init ... Done !!!
    [MCU1_0]     15.766599 s:  VX_ZONE_INIT:Enabled
    [MCU1_0]     15.766618 s:  VX_ZONE_ERROR:Enabled
    [MCU1_0]     15.766634 s:  VX_ZONE_WARNING:Enabled
    [MCU1_0]     15.767701 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MCU1-0
    [MCU1_0]     15.767777 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_LDC1
    [MCU1_0]     15.767849 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC1
    [MCU1_0]     15.767914 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_MSC2
    [MCU1_0]     15.768026 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target VPAC_VISS1
    [MCU1_0]     15.768075 s:  VX_ZONE_INIT:[tivxInitLocal:142] Initialization Done !!!
    [MCU1_0]     15.768096 s: APP: OpenVX Target kernel init ... !!!
    [MCU1_0]     15.772373 s: APP: OpenVX Target kernel init ... Done !!!
    [MCU1_0]     15.772398 s: VISS REMOTE SERVICE: Init ... !!!
    [MCU1_0]     15.772442 s: VISS REMOTE SERVICE: Init ... Done !!!
    [MCU1_0]     15.772460 s: APP: Init ... Done !!!
    [MCU1_0]     15.772476 s: APP: Run ... !!!
    [MCU1_0]     15.772489 s: IPC: Starting echo test ...
    [MCU1_0]     15.772601 s: APP: Run ... Done !!!
    [MCU1_0]     15.773240 s: IPC: Echo status: a530-0[.] r5f0-0[s] c75ss0[P]
    [C7x_1 ]      5.842978 s: CIO: Init ... Done !!!
    [C7x_1 ]      5.842997 s: APP: Init ... !!!
    [C7x_1 ]      5.843009 s: SCICLIENT: Init ... !!!
    [C7x_1 ]      5.843069 s: SCICLIENT: DMSC FW version [10.0.8--v10.00.08 (Fiery Fox)]
    [C7x_1 ]      5.843088 s: SCICLIENT: DMSC FW revision 0xa
    [C7x_1 ]      5.843103 s: SCICLIENT: DMSC FW ABI revision 4.0
    [C7x_1 ]      5.843118 s: SCICLIENT: Init ... Done !!!
    [C7x_1 ]      5.843131 s: UDMA: Init ... !!!
    [C7x_1 ]      5.843144 s: UDMA: Init ... Done !!!
    [C7x_1 ]      5.843156 s: MEM: Init ... !!!
    [C7x_1 ]      5.843170 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ b2000000 of size 117440512 bytes !!!
    [C7x_1 ]      5.843198 s: MEM: Init ... Done !!!
    [C7x_1 ]      5.843211 s: IPC: Init ... !!!
    [C7x_1 ]      5.843223 s: IPC: 3 CPUs participating in IPC !!!
    [C7x_1 ]      5.843422 s: IPC: Waiting for HLOS to be ready ... !!!
    [C7x_1 ]     15.433144 s: IPC: HLOS is ready !!!
    [C7x_1 ]     15.433216 s: IPC: Init ... Done !!!
    [C7x_1 ]     15.433231 s: APP: Syncing with 2 CPUs ... !!!
    [C7x_1 ]     15.765168 s: APP: Syncing with 2 CPUs ... Done !!!
    [C7x_1 ]     15.765185 s: REMOTE_SERVICE: Init ... !!!
    [C7x_1 ]     15.766159 s: REMOTE_SERVICE: Init ... Done !!!
    [C7x_1 ]     15.766182 s:  VX_ZONE_INIT:Enabled
    [C7x_1 ]     15.766198 s:  VX_ZONE_ERROR:Enabled
    [C7x_1 ]     15.766214 s:  VX_ZONE_WARNING:Enabled
    [C7x_1 ]     15.766980 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1
    [C7x_1 ]     15.767075 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_2
    [C7x_1 ]     15.767185 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_3
    [C7x_1 ]     15.767282 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_4
    [C7x_1 ]     15.767377 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_5
    [C7x_1 ]     15.767470 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_6
    [C7x_1 ]     15.767563 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_7
    [C7x_1 ]     15.767658 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target DSP_C7-1_PRI_8
    [C7x_1 ]     15.767686 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    [C7x_1 ]     15.767703 s: APP: OpenVX Target kernel init ... !!!
    [C7x_1 ]     15.767910 s: APP: OpenVX Target kernel init ... Done !!!
    [C7x_1 ]     15.767926 s: APP: Init ... Done !!!
    [C7x_1 ]     15.767939 s: APP: Run ... !!!
    [C7x_1 ]     15.767952 s: IPC: Starting echo test ...
    [C7x_1 ]     15.768049 s: APP: Run ... Done !!!
    [C7x_1 ]     15.773321 s: IPC: Echo status: a530-0[.] r5f0-0[P] c75ss0[s]
    root@am62axx-evm:/opt/edgeai-gst-apps# gst-launch-1.0 videotestsrc ! video/x-raw, format=NV12, width=1920, height=1080 ! tiovxmultiscaler ! video/x-raw, format=NV12, width=1280, height=720, format=NV12 ! fakesink
    APP: Init ... !!!
        59.388185 s: MEM: Init ... !!!
        59.388245 s: MEM: Initialized DMA HEAP (fd=5) !!!
        59.388427 s: MEM: Init ... Done !!!
        59.388440 s: IPC: Init ... !!!
        59.405383 s: IPC: Init ... Done !!!
        59.415852 s: GTC Frequency = 200 MHz
        59.428737 s:  VX_ZONE_INIT:Enabled
        59.428793 s:  VX_ZONE_ERROR:Enabled
        59.428803 s:  VX_ZONE_WARNING:Enabled
        59.433545 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
        59.433701 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
        59.433824 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
        59.433919 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
        59.433933 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
        59.436453 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
    Setting pipeline to PAUSED ...
    Pipeline is PREROLLING ...
        59.472249 s:  VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1
        59.472289 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node scaler_node
        59.472498 s:  VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core
        59.472514 s:  VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
        59.472529 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.hwa.vpac_msc_multi_scale ... failed !!!
        59.472546 s:  VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed
        59.472557 s:  VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed
        59.472722 s:  VX_ZONE_ERROR:[ownReleaseReferenceInt:594] Invalid reference
        59.520686 s:  VX_ZONE_ERROR:[vxGetStatus:1025] Reference is NULL
    ** (gst-launch-1.0:1472): CRITICAL **: 00:01:00.317: gst_tiovx_simo_process_graph: assertion 'VX_SUCCESS == vxGetStatus ((vx_reference) priv->graph)' failed
    ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error.
    Additional debug info:
    /usr/src/debug/gstreamer1.0/1.22.12/libs/gst/base/gstbasesrc.c(3134): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0:
    streaming stopped, reason not-linked (-1)
    ERROR: pipeline doesn't want to preroll.
        59.542264 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff9b1f3c68 of type 00000816 at external count 1, internal count 0, releasing it
        59.542299 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=multi_scaler_node_coeff_obj) now as a part of garbage collection
        59.542357 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff9b1f3e90 of type 00000816 at external count 1, internal count 0, releasing it
        59.542371 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=user_data_object_79) now as a part of garbage collection
        59.542417 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff9b296490 of type 00000813 at external count 1, internal count 0, releasing it
        59.542431 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=object_array_80) now as a part of garbage collection
        59.542451 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff9b226b30 of type 0000080f at external count 1, internal count 0, releasing it
        59.542464 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_81) now as a part of garbage collection
        59.542482 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff9b296638 of type 00000813 at external count 1, internal count 0, releasing it
        59.542495 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=scaler_node_output_arr0_buf0) now as a part of garbage collection
        59.542513 s:  VX_ZONE_WARNING:[vxReleaseContext:1213] Found a reference 0xffff9b226df8 of type 0000080f at external count 1, internal count 0, releasing it
        59.542525 s:  VX_ZONE_WARNING:[vxReleaseContext:1215] Releasing reference (name=image_83) now as a part of garbage collection
        59.542611 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:120] De-Initialization Done for HOST !!!
        59.547066 s:  VX_ZONE_INIT:[tivxDeInitLocal:206] De-Initialization Done !!!
    APP: Deinit ... !!!
        59.547565 s: IPC: Deinit ... !!!
        59.548063 s: IPC: DeInit ... Done !!!
        59.548105 s: MEM: Deinit ... !!!
        59.548616 s: DDR_SHARED_MEM: Alloc's: 8 alloc's of 13481016 bytes
        59.548656 s: DDR_SHARED_MEM: Free's : 8 free's  of 13481016 bytes
        59.548668 s: DDR_SHARED_MEM: Open's : 0 allocs  of 0 bytes
        59.548686 s: MEM: Deinit ... Done !!!
    Raveen
  • Hi Raveen,
    Can you please add below line
    tivx_set_debug_zone(VX_ZONE_INFO)
    at
    https://github.com/TexasInstruments/edgeai-gst-plugins/blob/4d68b057171c2ebcd6c6c9de141fdf23a4be6f26/gst-libs/gst/tiovx/gsttiovxcontext.c#L145
    After appInit call
    this will enable more OpenVX logs
    You can make this change on the target itself and for this steps to rebuild and install
    TexasInstruments/edgeai-gst-plugins: Repository to host GStreamer plugins for TI's EdgeAI class of devices
    edgeai-gst-plugins is packaged at /opt in target
    Regard
    Rahul T R
