AM62A7: SBL boot from SD card fail
Part Number: AM62A7
Hi TI experts:
    SBL boot from SD card fail on our board, Our sdk version is 10.0. the related HW change is showed as attached picture, and logs attached file too,please help us to fix it, thanks!
Best regards!
Hawayi
am62a7_sbl_boot_fail.txt
SYSFW Firmware Version 10.0.8--v10.00.08 (Fiery Fox)
SYSFW Firmware revision 0xa
SYSFW ABI revision 4.0
[BOOTLOADER_PROFILE] Boot Media       : SD Card
[BOOTLOADER_PROFILE] Boot Image Size  : 617 KB
[BOOTLOADER_PROFILE] Cores present    :
mcu-r5f0-0
r5f0-0
c75ss0
a530-0
[BOOTLOADER PROFILE] System_init                      :      25621us
[BOOTLOADER PROFILE] Board_init                       :          0us
[BOOTLOADER PROFILE] Drivers_open                     :       2978us
[BOOTLOADER PROFILE] Board_driversOpen                :          0us
[BOOTLOADER PROFILE] Sciclient Get Version            :      10093us
[BOOTLOADER PROFILE] MCU R5 Image Load                :     261696us
[BOOTLOADER PROFILE] DM R5 Image Load                 :     271208us
[BOOTLOADER PROFILE] C75 Image Load                   :     277498us
[BOOTLOADER PROFILE] A53 Image Load                   :    2478673us
[BOOTLOADER_PROFILE] SBL Total Time Taken             :    3327770us
Image loading done, switching to application ...
Starting linux and RTOS/Baremetal applications
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.6.32 (root@3e6b576e6584) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #1 SMP PREEMPT Tue Nov 12 05:09:39 UTC 2024
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM62A7 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000c0000000..0x00000000e3ffffff (589824 KiB) map reusable linux,cma
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000099800000..0x00000000998fffff (1024 KiB) nomap non-reusable c7x-dma-memory@99800000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000099900000..0x000000009b7fffff (31744 KiB) nomap non-reusable c7x-memory@99900000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9b800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable r5f-dma-memory@9b900000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-dma-memory@9c900000
[    0.000000] OF: reserved mem: 0x000000009e780000..0x000000009e7fffff (512 KiB) nomap non-reusable tfa@9e780000
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a0ffffff (16384 KiB) nomap non-reusable edgeai-rtos-ipc-memory-region@a0000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a2ffffff (32768 KiB) nomap non-reusable edgeai-dma-memory@a1000000
[    0.000000] OF: reserved mem: initialized node edgeai_shared-memories@a3000000, compatible id dma-heap-carveout
[    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000adffffff (180224 KiB) map non-reusable edgeai_shared-memories@a3000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 288 MiB
[    0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ae000000..0x00000000bfffffff (294912 KiB) nomap non-reusable edgeai-core-heap-memory@ae000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000997fffff]
[    0.000000]   node   0: [mem 0x0000000099800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x00000000a2ffffff]
[    0.000000]   node   0: [mem 0x00000000a3000000-0x00000000adffffff]
[    0.000000]   node   0: [mem 0x00000000ae000000-0x00000000bfffffff]
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s43112 r8192 d30616 u81920
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000f9900000-0x00000000fd900000] (64MB)
[    0.000000] Memory: 750404K/2097152K available (12160K kernel code, 1262K rwdata, 4064K rodata, 2432K init, 506K bss, 756924K reserved, 589824K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @82400000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000081840000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000081850000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008537] Console: colour dummy device 80x25
[    0.013124] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023805] pid_max: default: 32768 minimum: 301
[    0.028602] LSM: initializing lsm=capability,integrity
[    0.033946] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.041518] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.051129] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.058429] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.066333] rcu: Hierarchical SRCU implementation.
[    0.071237] rcu:     Max phase no-delay instances is 1000.
[    0.076814] Platform MSI: msi-controller@1820000 domain created
[    0.083101] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.092500] EFI services will not be available.
[    0.097365] smp: Bringing up secondary CPUs ...
[    0.102594] Detected VIPT I-cache on CPU1
[    0.102667] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.102684] GICv3: CPU1: using allocated LPI pending table @0x0000000081860000
[    0.102734] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.103380] Detected VIPT I-cache on CPU2
[    0.103431] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.103445] GICv3: CPU2: using allocated LPI pending table @0x0000000081870000
[    0.103475] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.104043] Detected VIPT I-cache on CPU3
[    0.104092] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.104105] GICv3: CPU3: using allocated LPI pending table @0x0000000081880000
[    0.104137] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.104202] smp: Brought up 1 node, 4 CPUs
[    0.183916] SMP: Total of 4 processors activated.
[    0.188727] CPU features: detected: 32-bit EL0 Support
[    0.193996] CPU features: detected: CRC32 instructions
[    0.199304] CPU: All CPU(s) started at EL2
[    0.203500] alternatives: applying system-wide alternatives
[    0.210750] devtmpfs: initialized
[    0.221699] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.231712] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.254488] pinctrl core: initialized pinctrl subsystem
[    0.260359] DMI not present or invalid.
[    0.264858] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.271724] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.279048] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.287064] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.295238] audit: initializing netlink subsys (disabled)
[    0.300946] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.301343] thermal_sys: Registered thermal governor 'step_wise'
[    0.308881] thermal_sys: Registered thermal governor 'power_allocator'
[    0.315075] cpuidle: using governor menu
[    0.325904] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.332925] ASID allocator initialised with 65536 entries
[    0.348410] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
[    0.361166] Modules: 27616 pages in range for non-PLT usage
[    0.361180] Modules: 519136 pages in range for PLT usage
[    0.367585] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.379987] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.386394] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.393332] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.399738] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.406676] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.413082] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.420020] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.427707] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
[    0.437139] iommu: Default domain type: Translated
[    0.442067] iommu: DMA domain TLB invalidation policy: strict mode
[    0.448646] SCSI subsystem initialized
[    0.452747] usbcore: registered new interface driver usbfs
[    0.458385] usbcore: registered new interface driver hub
[    0.463840] usbcore: registered new device driver usb
[    0.469430] pps_core: LinuxPPS API ver. 1 registered
[    0.474508] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.483854] PTP clock support registered
[    0.488005] EDAC MC: Ver: 3.0.0
[    0.491643] scmi_core: SCMI protocol bus registered
[    0.496895] FPGA manager framework
[    0.500446] Advanced Linux Sound Architecture Driver Initialized.
[    0.507519] vgaarb: loaded
[    0.510608] clocksource: Switched to clocksource arch_sys_counter
[    0.517087] VFS: Disk quotas dquot_6.6.0
[    0.521133] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.533741] Carveout Heap: Exported 176 MiB at 0x00000000a3000000
[    0.540095] NET: Registered PF_INET protocol family
[    0.545225] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.554232] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.563024] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.570954] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.579149] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.587031] TCP: Hash tables configured (established 16384 bind 16384)
[    0.593891] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.600807] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.608288] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.614488] RPC: Registered named UNIX socket transport module.
[    0.620563] RPC: Registered udp transport module.
[    0.625372] RPC: Registered tcp transport module.
[    0.630179] RPC: Registered tcp-with-tls transport module.
[    0.635786] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.642375] NET: Registered PF_XDP protocol family
[    0.647289] PCI: CLS 0 bytes, default 64
[    0.652551] Initialise system trusted keyrings
[    0.657322] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.664204] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.670408] NFS: Registering the id_resolver key type
[    0.675604] Key type id_resolver registered
[    0.679880] Key type id_legacy registered
[    0.683992] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.690846] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.727403] Key type asymmetric registered
[    0.731595] Asymmetric key parser 'x509' registered
[    0.736629] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.744319] io scheduler mq-deadline registered
[    0.748957] io scheduler kyber registered
[    0.753088] io scheduler bfq registered
[    0.759789] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.766268] pinctrl-single f4000.pinctrl: 151 pins, size 604
[    0.773419] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.784903] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.800925] loop: module loaded
[    0.805073] megasas: 07.725.01.00-rc1
[    0.812119] tun: Universal TUN/TAP device driver, 1.6
[    0.818204] VFIO - User Level meta-driver version: 0.3
[    0.824461] usbcore: registered new interface driver usb-storage
[    0.831114] i2c_dev: i2c /dev entries driver
[    0.836967] sdhci: Secure Digital Host Controller Interface driver
[    0.843312] sdhci: Copyright(c) Pierre Ossman
[    0.847968] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.854100] pinctrl-single f4000.pinctrl: Invalid number of rows: 0
[    0.860512] pinctrl-single f4000.pinctrl: no pins entries for usr-led-default-pins
[    0.868518] ledtrig-cpu: registered to indicate activity on CPUs
[    0.874927] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.882116] usbcore: registered new interface driver usbhid
[    0.887818] usbhid: USB HID core driver
[    0.892020] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[    0.898852] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[    0.905640] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
[    0.912366] omap-mailbox 29030000.mailbox: no available mbox devices found
[    0.920598] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.929539] optee: probing for conduit method.
[    0.934124] optee: revision 4.2 (12d7c4ee)
[    0.934410] optee: dynamic shared memory is enabled
[    0.944255] random: crng init done
[    0.947824] optee: initialized driver
[    0.953054] Initializing XFRM netlink socket
[    0.957473] NET: Registered PF_PACKET protocol family
[    0.962708] Key type dns_resolver registered
[    0.973817] registered taskstats version 1
[    0.978174] Loading compiled-in X.509 certificates
[    0.994337] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[    1.039439] i2c 0-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@48/regulators/buck5
[    1.049247] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.056249] omap_i2c 20020000.i2c: bus 1 rev0.12 at 400 kHz
[    1.062169] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.070476] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.079680] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.088660] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
[    1.098142] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.106557] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.117356] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.127822] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.137178] ti-udma 4e230000.dma-controller: Number of rings: 6
[    1.143750] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
[    1.153211] printk: console [ttyS2] disabled
[    1.157902] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 251, base_baud = 3000000) is a 8250
[    1.166780] printk: console [ttyS2] enabled
[    1.175263] printk: bootconsole [ns16550a0] disabled
[    1.588826] spi-nand: probe of spi0.0 failed with error -110
[    1.634615] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.642424] mdio_bus 8000f00.mdio: MDIO device at address 0 is missing.
[    1.649069] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    1.662023] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.669155] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.675636] pps pps0: new PPS source ptp0
[    1.679894] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    1.693537] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.703273] platform 31000000.usb: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    1.716609] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.722173] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.730005] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    1.736009] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
[    1.745442] xhci-hcd xhci-hcd.0.auto: irq 266, io mem 0x31100000
[    1.752140] hub 1-0:1.0: USB hub found
[    1.755932] hub 1-0:1.0: 1 port detected
[    1.762475] mmc1: CQHCI version 5.10
[    1.762513] mmc0: CQHCI version 5.10
[    1.802630] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.807176] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.842334] mmc1: new SDHC card at address 1234
[    1.847479] mmcblk1: mmc1:1234 SA08G 7.21 GiB
[    1.854494]  mmcblk1: p1 p2
[    1.882379] mmc0: Command Queue Engine enabled
[    1.886862] mmc0: new HS200 MMC card at address 0001
[    1.892439] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
[    1.898317] mmcblk0boot0: mmc0:0001 8GUF4R 31.9 MiB
[    1.904070] mmcblk0boot1: mmc0:0001 8GUF4R 31.9 MiB
[    1.909763] mmcblk0rpmb: mmc0:0001 8GUF4R 4.00 MiB, chardev (239:0)
[    2.042908] vddshv_sdio: failed to get the current voltage: -EINVAL
[    2.049280] gpio-regulator regulator-5: Failed to register regulator: -22
[    2.056084] gpio-regulator: probe of regulator-5 failed with error -22
[    2.057593] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.069981] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.078483] clk: Disabling unused clocks
[    2.086812] ALSA device list:
[    2.089779]   No soundcards found.
[    3.149417] EXT4-fs (mmcblk1p2): recovery complete
[    3.158750] EXT4-fs (mmcblk1p2): mounted filesystem 1dd12b03-bcfc-4390-8fae-5acaef0c0405 r/w with ordered data mode. Quota mode: none.
[    3.170893] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.192108] devtmpfs: mounted
[    3.195852] Freeing unused kernel memory: 2432K
[    3.200464] Run /sbin/init as init process
[    4.297528] systemd[1]: System time before build time, advancing clock.
[   12.195488] platform regulator-3: deferred probe pending
[   12.200823] platform 2b300050.target-module: deferred probe pending
[   25.006598] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[   25.012681] rcu:     (detected by 0, t=5252 jiffies, g=-843, q=62 ncpus=4)
[   25.019281] rcu: All QSes seen, last rcu_preempt kthread activity 5252 (4294898499-4294893247), jiffies_till_next_fqs=1, root ->qsmask 0x0
[   25.031688] rcu: rcu_preempt kthread starved for 5257 jiffies! g-843 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=1
[   25.041841] rcu:     Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
[   25.050951] rcu: RCU grace-period kthread stack dump:
[   25.055986] task:rcu_preempt     state:R  running task     stack:0     pid:16    ppid:2      flags:0x00000008
[   25.065886] Call trace:
[   25.068322]  __switch_to+0xcc/0x12c
[   25.071816]  __schedule+0x264/0x9c4
[   25.075296]  schedule+0x5c/0xc4
[   25.078429]  schedule_timeout+0x90/0x108
[   25.082342]  rcu_gp_fqs_loop+0x114/0x4c8
[   25.086261]  rcu_gp_kthread+0x134/0x160
[   25.090089]  kthread+0x110/0x114
[   25.093310]  ret_from_fork+0x10/0x20
[   25.096879] rcu: Stack dump where RCU GP kthread last ran:
[   25.102348] Task dump for CPU 1:
[   25.105563] task:hwrng           state:R  running task     stack:0     pid:61    ppid:2      flags:0x00000008
[   25.115459] Call trace:
[   25.117893]  __switch_to+0xcc/0x12c
[   25.121373]  0x68153aa0654d6000
