Part Number: AM5728
root@phycore-am57xx-1:~#
root@phycore-am57xx-1:~# [ OK ] Stopped target Boot Completion Check.
[ OK ] Stopped target Multi-User System.
[ OK ] Stopped target Login Prompts.
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped target RPC Port Mapper.
[ OK ] Stopped target Sound Card.
[ OK ] Stopped target Timers.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping Save/Restore Sound Card State...
Stopping can0 interface setup...
Stopping can1 interface setup...
Stopping D-Bus System Message Bus...
Stopping Getty on tty1...
Stopping NFS status monitor for NFSv2/3 locking....
Stopping Serial Getty on ttyS2...
Stopping Login Service...
Stopping TI IPC Daemon...
Stopping HawkBit client for Rauc...
[ OK ] Stopped OpenSSH Key Generation.
[ OK ] Stopped NFS status monitor for NFSv2/3 locking..
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped TI IPC Daemon.
[ OK ] Stopped HawkBit client for Rauc.
[ OK ] Stopped Save/Restore Sound Card State.
[ OK ] Stopped can0 interface setup.
[ OK ] Stopped can1 interface setup.
[ OK ] Stopped Login Service.
[ OK ] Removed slice system-getty.slice.
[ OK ] Stopped target Network is Online.
[ OK ] Stopped target Network.
[ OK ] Stopped target Host and Network Name Lookups.
Stopping Network Name Resolution...
[ OK ] Stopped Network Name Resolution.
Stopping Network Service...
[ OK ] Stopped Network Service.
[ OK ] Stopped Serial Getty on ttyS2.
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Paths.
[ OK ] Stopped Dispatch Password �ts to Console Directory Watch.
[ OK ] Stopped Forward Password R�uests to Wall Directory Watch.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Sockets.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Closed sshd.socket.
[ OK ] Stopped target System Initialization.
Stopping Hardware RNG Entropy Gatherer Daemon...
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting Temporary Directory (/tmp)...
Unmounting /var/volatile...
[ OK ] Stopped Hardware RNG Entropy Gatherer Daemon.
[ OK ] Unmounted Temporary Directory (/tmp).
[ OK ] Unmounted /var/volatile.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped target Swap.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
[ OK ] Started Power-Off.
[ OK ] Reached target Power-Off.
[ 174.070190] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 174.094268] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 174.108764] systemd-journald[114]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 174.131530] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 174.146301] systemd-shutdown[1]: Unmounting file systems.
[ 174.154815] [244]: Remounting '/' read-only in with options '(null)'.
[ 174.176483] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 174.184936] systemd-shutdown[1]: All filesystems unmounted.
[ 174.190917] systemd-shutdown[1]: Deactivating swaps.
[ 174.196014] systemd-shutdown[1]: All swaps deactivated.
[ 174.201324] systemd-shutdown[1]: Detaching loop devices.
[ 174.209838] systemd-shutdown[1]: All loop devices detached.
[ 174.215454] systemd-shutdown[1]: Detaching DM devices.
[ 174.221221] systemd-shutdown[1]: All DM devices detached.
[ 174.226715] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
[ 174.247955] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 174.254760] systemd-shutdown[1]: Powering off.
[ 174.314422] reboot: Power down
U-Boot SPL 2021.01-g0769550075 (Mar 13 2024 - 08:21:37 +0000)
DRA752-GP ES2.0
Trying to boot from MMC1
no pinctrl state for default mode
Loading Environment from FAT... no pinctrl state for default mode
OK
U-Boot 2021.01-g0769550075 (Mar 13 2024 - 08:21:37 +0000)
CPU : DRA752-GP ES2.0
Model: PHYTEC PCM-948 AM57x RDK
SoM: PHYTEC phyCORE-AM57x (41300111I)
DRAM: 2 GiB
MMC: no pinctrl state for default mode
OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... OK
Net:
Warning: ethernet@48484000 MAC addresses don't match:
Address in ROM is 88:3f:4a:53:27:28
Address in environment is 50:51:a9:92:c8:fa
eth2: ethernet@48484000
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
5370368 bytes read in 239 ms (21.4 MiB/s)
214503 bytes read in 16 ms (12.8 MiB/s)
Loading Device Tree to 8fec8000, end 8fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.168 (oe-user@oe-host) (arm-phytec-linux-gnueabi-gcc (GCC) 9.5.0, GNU ld (GNU Binutils) 2.34.0.20200910) #1 SMP PREEMPT Mon Mar 4 13:13:09 UTC 2024
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: PHYTEC PCM-948 AM57x RDK
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 512 MiB at 0x00000000df000000
[ 0.000000] OMAP4: Map 0x00000000afd00000 to (ptrval) for dram barrier
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000afcfffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x00000000afd00000-0x00000000feffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000afcfffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000feffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000feffffff]
[ 0.000000] DRA752 ES2.0
[ 0.000000] percpu: Embedded 16 pages/cpu s33612 r8192 d23732 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 517702
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=a4c7c155-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1155292K/2077696K available (10240K kernel code, 750K rwdata, 3596K rodata, 2048K init, 297K bss, 234276K reserved, 688128K cma-reserved, 770048K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000000] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000030] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
[ 0.001403] TI gptimer clockevent: always-on 32786 Hz at /ocp/interconnect@4ae00000/segment@10000/target-module@8000
[ 0.003051] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2c000
[ 0.003234] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2e000
[ 0.004211] Console: colour dummy device 80x30
[ 0.004241] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664)
[ 0.062011] pid_max: default: 32768 minimum: 301
[ 0.062133] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.062133] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.062744] CPU: Testing write buffer coherency: ok
[ 0.062774] CPU0: Spectre v2: using ICIALLU workaround
[ 0.062805] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[ 0.062957] /cpus/cpu@0 missing clock-frequency property
[ 0.062988] /cpus/cpu@1 missing clock-frequency property
[ 0.063018] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.063629] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.063720] rcu: Hierarchical SRCU implementation.
[ 0.063903] EFI services will not be available.
[ 0.064422] smp: Bringing up secondary CPUs ...
[ 0.124633] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.124664] CPU1: Spectre v2: using ICIALLU workaround
[ 0.124786] smp: Brought up 1 node, 2 CPUs
[ 0.124786] SMP: Total of 2 processors activated (3994.41 BogoMIPS).
[ 0.124786] CPU: All CPU(s) started in HYP mode.
[ 0.124816] CPU: Virtualization extensions available.
[ 0.125152] devtmpfs: initialized
[ 0.148529] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.148712] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.148742] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.162292] pinctrl core: initialized pinctrl subsystem
[ 0.162841] DMI not present or invalid.
[ 0.163299] NET: Registered protocol family 16
[ 0.165130] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.167785] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.186157] thermal_sys: Registered thermal governor 'fair_share'
[ 0.186157] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.186157] thermal_sys: Registered thermal governor 'step_wise'
[ 0.186187] thermal_sys: Registered thermal governor 'user_space'
[ 0.186187] thermal_sys: Registered thermal governor 'two_stage'
[ 0.186950] cpuidle: using governor ladder
[ 0.186981] cpuidle: using governor menu
[ 3.542144] No ATAGs?
[ 3.542205] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 3.542236] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 3.584503] iommu: Default domain type: Translated
[ 3.587890] SCSI subsystem initialized
[ 3.588348] mc: Linux media interface: v0.10
[ 3.588378] videodev: Linux video capture interface: v2.00
[ 3.588439] pps_core: LinuxPPS API ver. 1 registered
[ 3.588470] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 3.588500] PTP clock support registered
[ 3.588562] EDAC MC: Ver: 3.0.0
[ 3.589691] Advanced Linux Sound Architecture Driver Initialized.
[ 3.590484] clocksource: Switched to clocksource 32k_counter
[ 3.596710] NET: Registered protocol family 2
[ 3.596893] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 3.597686] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 3.597717] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 3.597778] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 3.597930] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.597991] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 3.598022] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 3.598144] NET: Registered protocol family 1
[ 3.598541] RPC: Registered named UNIX socket transport module.
[ 3.598571] RPC: Registered udp transport module.
[ 3.598571] RPC: Registered tcp transport module.
[ 3.598571] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.598602] NET: Registered protocol family 44
[ 3.598602] PCI: CLS 0 bytes, default 64
[ 3.600036] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 3.600189] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 3.600982] Initialise system trusted keyrings
[ 3.601135] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 3.605010] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.605499] NFS: Registering the id_resolver key type
[ 3.605529] Key type id_resolver registered
[ 3.605529] Key type id_legacy registered
[ 3.605590] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.605621] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 3.605651] ntfs: driver 2.1.32 [Flags: R/O].
[ 3.606018] Key type asymmetric registered
[ 3.606018] Asymmetric key parser 'x509' registered
[ 3.606079] bounce: pool size: 64 pages
[ 3.606109] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 3.606109] io scheduler mq-deadline registered
[ 3.606109] io scheduler kyber registered
[ 4.306427] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 4.788452] OMAP GPIO hardware version 0.1
[ 4.981201] ti-sysc 48059000.target-module: dts flag should be at module level for ti,no-idle-on-init
[ 4.981201] ti-sysc 48059000.target-module: dts flag should be at module level for ti,no-reset-on-init
[ 5.381805] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400
[ 5.396820] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400
[ 5.411651] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 5.426483] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 5.530303] edma 43300000.dma: memcpy is disabled
[ 5.533050] edma 43300000.dma: TI EDMA DMA engine driver
[ 5.684417] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[ 5.690002] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges:
[ 5.690032] dra7-pcie 51000000.pcie: IO 0x0020003000..0x0020012fff -> 0x0000000000
[ 5.690063] dra7-pcie 51000000.pcie: MEM 0x0020013000..0x002fffffff -> 0x0020013000
[ 6.690948] dra7-pcie 51000000.pcie: Phy link never came up
[ 6.691070] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 6.691101] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 6.691101] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 6.691101] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 6.691162] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400
[ 6.691162] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 6.691192] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[ 6.691253] pci 0000:00:00.0: supports D1
[ 6.691284] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 6.699249] PCI: bus0: Fast back to back transfers disabled
[ 6.707061] PCI: bus1: Fast back to back transfers enabled
[ 6.707092] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 6.707122] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 6.707122] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 6.707458] pcieport 0000:00:00.0: PME: Signaling with IRQ 185
[ 6.760345] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 6.764312] printk: console [ttyS2] disabled
[ 6.764465] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 111, base_baud = 3000000) is a 8250
[ 7.787658] printk: console [ttyS2] enabled
[ 7.793273] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 124, base_baud = 3000000) is a 8250
[ 7.804962] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 7.810607] random: crng init done
[ 7.832794] brd: module loaded
[ 7.841369] loop: module loaded
[ 7.930572] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 7.968688] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[ 7.978424] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
[ 7.988861] cpsw-switch 48484000.switch: initialized cpsw ale version 1.4
[ 7.995697] cpsw-switch 48484000.switch: ALE Table size 1024
[ 8.001495] cpsw-switch 48484000.switch: cpts: overflow check period 500 (jiffies)
[ 8.009094] cpsw-switch 48484000.switch: CPTS: ref_clk_freq:266000000 calc_mult:4036623398 calc_shift:30 error:-1 nsec/sec
[ 8.020233] cpsw-switch 48484000.switch: Detected MACID = 88:3f:4a:53:27:28
[ 8.027252] cpsw-switch 48484000.switch: Detected MACID = 88:3f:4a:53:27:29
[ 8.035675] cpsw-switch 48484000.switch: initialized (regs 0x0000000048484000, pool size 256) hw_ver:0019010F 1.15 (0)
[ 8.047821] i2c /dev entries driver
[ 8.059204] sdhci: Secure Digital Host Controller Interface driver
[ 8.065460] sdhci: Copyright(c) Pierre Ossman
[ 8.071563] sdhci-pltfm: SDHCI platform and OF driver helper
[ 8.079681] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 8.089172] sdhci-omap 480b4000.mmc: supply vqmmc not found, using dummy regulator
[ 8.096832] ledtrig-cpu: registered to indicate activity on CPUs
[ 8.097259] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 8.107879] sdhci-omap 4809c000.mmc: Got WP GPIO
[ 8.110870] NET: Registered protocol family 10
[ 8.112731] sdhci-omap 4809c000.mmc: supply vqmmc not found, using dummy regulator
[ 8.120910] Segment Routing with IPv6
[ 8.128295] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 8.134674] NET: Registered protocol family 17
[ 8.139404] Key type dns_resolver registered
[ 8.143829] Registering SWP/SWPB emulation handler
[ 8.149078] omap_voltage_late_init: Voltage driver support not added
[ 8.155487] Power Management for TI OMAP4+ devices.
[ 8.160827] Loading compiled-in X.509 certificates
[ 8.194610] dmm 4e000000.dmm: workaround for errata i878 in use
[ 8.202331] dmm 4e000000.dmm: initialized all PAT entries
[ 8.209930] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 8.245452] palmas 0-0058: Irq flag is 0x00000008
[ 8.273712] palmas 0-0058: Muxing GPIO 29, PWM 0, LED 0
[ 8.295074] VDD_MPU: supplied by regulator-dummy
[ 8.301361] VDD_DDR: supplied by regulator-dummy
[ 8.307708] VDD_DSP: supplied by regulator-dummy
[ 8.314086] VDD_CORE: Bringing 1050000uV into 1030000-1030000uV
[ 8.320831] VDD_CORE: supplied by regulator-dummy
[ 8.326965] SMPS7: supplied by regulator-dummy
[ 8.332489] VDD_1V8: supplied by regulator-dummy
[ 8.338592] ETH0_VDD_1V2: Bringing 0uV into 1200000-1200000uV
[ 8.345184] ETH0_VDD_1V2: supplied by regulator-dummy
[ 8.351257] VDD_SD: supplied by regulator-dummy
[ 8.357574] VDD_SHV5: supplied by regulator-dummy
[ 8.364105] VDDA_1V8_PHYA: supplied by regulator-dummy
[ 8.371063] VDDA_1V8_PHYB: supplied by regulator-dummy
[ 8.378112] LDO5: supplied by regulator-dummy
[ 8.382873] LDO6: supplied by regulator-dummy
[ 8.387603] LDO7: supplied by regulator-dummy
[ 8.392333] LDO8: supplied by regulator-dummy
[ 8.397125] VDD_RTC: supplied by regulator-dummy
[ 8.403717] VDDA_1V8_PLL: supplied by regulator-dummy
[ 8.410583] VUSB_3V3: supplied by regulator-dummy
[ 8.431213] rtc-m41t80 0-0068: Oscillator failure, data is invalid.
[ 8.437683] rtc-m41t80 0-0068: registered as rtc0
[ 8.442596] rtc-m41t80 0-0068: Oscillator failure, data is invalid.
[ 8.448913] rtc-m41t80 0-0068: hctosys: unable to read the hardware clock
[ 8.455841] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 8.463317] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[ 8.470306] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 8.478363] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 8.484893] platform 40800000.dsp: Adding to iommu group 0
[ 8.491760] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 8.497802] platform 58820000.ipu: Adding to iommu group 1
[ 8.504821] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 8.510894] platform 55020000.ipu: Adding to iommu group 2
[ 8.517852] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 8.525085] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 8.531311] platform 41000000.dsp: Adding to iommu group 3
[ 8.537963] DSS: OMAP DSS rev 6.1
[ 8.545227] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 8.553253] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
[ 8.563354] omapdrm omapdrm.0: [drm] Cannot find any crtc or sizes
[ 8.570465] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[ 8.580596] VDD_3V3: supplied by VDD_3V3_ON
[ 8.585021] VTT: supplied by VDD_3V3
[ 8.585052] sdhci-omap 480b4000.mmc: supply vqmmc not found, using dummy regulator
[ 8.597473] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[ 8.606353] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 8.611053] sdhci-omap 4809c000.mmc: Got WP GPIO
[ 8.615844] input: keys as /devices/platform/keys/input/input0
[ 8.615844] sdhci-omap 4809c000.mmc: supply vqmmc not found, using dummy regulator
[ 8.616333] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[ 8.622985] ALSA device list:
[ 8.639038] No soundcards found.
[ 8.667938] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[ 8.675231] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[ 8.683288] Waiting for root device PARTUUID=a4c7c155-02...
[ 8.757904] mmc0: new high speed SDHC card at address aaaa
[ 8.763854] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 8.772918] mmcblk0: p1 p2
[ 8.784149] mmc1: new DDR MMC card at address 0001
[ 8.789276] mmcblk1: mmc1:0001 008GB0 7.28 GiB
[ 8.793975] mmcblk1boot0: mmc1:0001 008GB0 partition 1 8.00 MiB
[ 8.800079] mmcblk1boot1: mmc1:0001 008GB0 partition 2 8.00 MiB
[ 8.806121] mmcblk1rpmb: mmc1:0001 008GB0 partition 3 4.00 MiB, chardev (243:0)
[ 8.814910] mmcblk1: p1 p2
[ 8.843811] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 8.852020] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 8.861236] devtmpfs: mounted
[ 8.865234] Freeing unused kernel memory: 2048K
[ 8.890808] Run /sbin/init as init process
[ 9.213134] systemd[1]: systemd 244.5+ running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK -SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ +LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 9.235412] systemd[1]: Detected architecture arm.
Welcome to The Yogurt Distribution BSP-Yocto-AM57x-PD23.1.1!
[ 9.334045] systemd[1]: Set hostname to <phycore-am57xx-1>.
[ 9.620574] omapdrm omapdrm.0: [drm] Cannot find any crtc or sizes
[ 9.645263] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 9.681457] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 9.721496] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 9.761169] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password �ts to Console Directory Watch.
[ 9.800750] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R�uests to Wall Directory Watch.
[ 9.840759] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 9.870880] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 9.910797] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 9.950836] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 9.998657] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 10.040679] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 10.081298] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 10.123352] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 10.132080] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 10.170959] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 10.211212] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 10.250915] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 10.290893] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 10.330963] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 10.342529] systemd[1]: Mounting POSIX Message Queue File System...
[ 10.383544] systemd[1]: Mounting Kernel Debug File System...
[ 10.417022] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 10.453735] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st�odes for the current kernel...
[ 10.494567] systemd[1]: Starting RPC Bind...
[ 10.520721] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 10.535064] systemd[1]: Starting Journal Service...
[ 10.564483] systemd[1]: Starting Load Kernel Modules...
[ 10.589447] cmemk: loading out-of-tree module taints kernel.
[ 10.596038] CMEMK module: reference Linux version 5.10.168
[ 10.603912] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 10.612213] allocated heap buffer 0x40500000 of size 0x100000
[ 10.618011] cmemk initialized
[ 10.640747] cryptodev: driver 1.10 loaded.
[ 10.647064] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.654968] systemd[1]: Starting udev Coldplug all Devices...
[ 10.696533] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 10.731628] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta� nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 11.000854] systemd-journald[115]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
Starting Network Service...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Network Service.
[ 11.615783] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[ 11.624999] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 11.633270] remoteproc remoteproc0: 58820000.ipu is available
Starting Wait for Network to be Configured...
[ 11.653442] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
Starting Network Name Resolution...[ 11.675048] remoteproc remoteproc1: 55020000.ipu is available
[ 11.704742] omap-sham 4b101000.sham: will run requests pump with realtime priority
[ 11.721588] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[ 11.783386] remoteproc remoteproc2: 40800000.dsp is available
[ 11.808929] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[ 11.823883] remoteproc remoteproc3: 41000000.dsp is available
[ OK ] Started udev Coldplug all Devices.
[ 11.851593] omap-sham 42701000.sham: hw accel on OMAP rev 4.3
Starting udev Wait for Complete Device Initialization...
[ 11.910675] omap-sham 42701000.sham: will run requests pump with realtime priority
[ 11.989593] omap_gpio 4805b000.gpio: Could not set line 7 debounce to 20000 microseconds (-22)
[ 12.061828] remoteproc remoteproc0: powering up 58820000.ipu
[ 12.067535] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4953912
[ 12.080444] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
[ 12.123565] palmas-rtc 48070000.i2c:pmic@58:rtc: registered as rtc2
[ 12.137145] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 12.174346] remoteproc0#vdev0buffer: assigned reserved memory node ipu1-memory@9d000000
[ 12.211029] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 12.212493] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[ 12.221954] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 12.230621] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[ 12.240570] remoteproc remoteproc0: remote processor 58820000.ipu is now up
[ 12.244873] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[ 12.254608] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[ 12.261962] Micrel KSZ9031 Gigabit PHY 48485000.mdio:02: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:02, irq=POLL)
[ 12.310882] remoteproc remoteproc1: powering up 55020000.ipu
[ 12.316619] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 4954008
[ 12.324707] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 12.331481] at24 0-0050: supply vcc not found, using dummy regulator
[ 12.332214] palmas_pwrbutton 48070000.i2c:pmic@58:power-button: h/w controlled shutdown duration=12 seconds
[ 12.349822] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
[ 12.358673] Driver for 1-wire Dallas network protocol.
[ 12.364074] omap_rtc 48838000.rtc: registered as rtc1
[ 12.375610] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 32 bytes/write
[ 12.383605] input: palmas_pwron as /devices/platform/44000000.ocp/48000000.interconnect/48000000.interconnect:segment@0/48070000.target-module/48070000.i2c/i2c-0/0-0058/48070000.i2c:pmic@58:power-button/input/input1
[ 12.424316] remoteproc1#vdev0buffer: assigned reserved memory node ipu2-memory@95800000
[ 12.436431] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 12.437896] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x32
[ 12.446258] remoteproc1#vdev0buffer: registered virtio1 (type 7)
[ 12.456024] virtio_rpmsg_bus virtio1: creating channel rpmsg-client-sample addr 0x33
[ 12.456817] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[ 12.471954] virtio_rpmsg_bus virtio1: creating channel rpmsg-omx addr 0x3c
[ 12.478973] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[ 12.499420] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=48485000.mdio:01, irq=POLL)
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
[ 12.684997] CAN device driver interface
[ 12.689392] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ 12.740814] remoteproc remoteproc2: powering up 40800000.dsp
[ 12.748687] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5641976
[ 12.759338] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 12.768615] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 12.785339] remoteproc remoteproc3: powering up 41000000.dsp
[ 12.792419] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 12.794525] remoteproc2#vdev0buffer: assigned reserved memory node dsp1-memory@99000000
[ 12.806152] omap-des 480a5000.des: will run requests pump with realtime priority
[ 12.808746] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5642104
[ 12.828155] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 12.839111] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 12.850830] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=91923dec, irq=110)
[ 12.865356] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 12.866912] virtio_rpmsg_bus virtio2: creating channel rpmsg-client-sample addr 0x32
[ 12.879150] virtio_rpmsg_bus virtio2: creating channel rpmsg-client-sample addr 0x33
[ 12.879425] remoteproc2#vdev0buffer: registered virtio2 (type 7)
[ 12.891632] c_can_platform 48480000.can: c_can_platform device registered (regs=5d9234d2, irq=137)
[ 12.897857] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[ 12.909637] virtio_rpmsg_bus virtio2: creating channel rpmsg-omx addr 0x3c
[ 12.918518] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d
[ 12.941741] virtio_rpmsg_bus virtio2: creating channel rpmsg-rpc addr 0x65
[ 12.948730] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 12.980895] vpe 489d0000.vpe: Device registered as /dev/video0
[ 13.015930] remoteproc3#vdev0buffer: assigned reserved memory node dsp2-memory@9f000000
[ 13.025756] power_supply bq27000-battery: power_supply_get_battery_info currently only supports devicetree
[ 13.079040] ahci 4a140000.sata: supply ahci not found, using dummy regulator
[ 13.087738] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 13.088806] virtio_rpmsg_bus virtio3: creating channel rpmsg-client-sample addr 0x32
[ 13.106872] virtio_rpmsg_bus virtio3: creating channel rpmsg-client-sample addr 0x33
[ 13.116821] virtio_rpmsg_bus virtio3: creating channel rpmsg-omx addr 0x3c
[ 13.128112] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 13.129516] virtio_rpmsg_bus virtio3: creating channel rpmsg-rpc addr 0x65
[ 13.138458] ahci 4a140000.sata: supply phy not found, using dummy regulator
[ 13.152618] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 13.183105] remoteproc3#vdev0buffer: registered virtio3 (type 7)
[ 13.189239] remoteproc remoteproc3: remote processor 41000000.dsp is now up
[ 13.197357] omap-aes 4b500000.aes: will run requests pump with realtime priority
[ 13.254058] ahci 4a140000.sata: supply target not found, using dummy regulator
[ 13.260986] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 13.267395] omap-aes 4b700000.aes: will run requests pump with realtime priority
[ 13.290985] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
[ 13.298461] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 13.324859] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
[ 13.383178] scsi host0: ahci
[ 13.386260] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 34
[ OK ] Listening on Load/Save RF �itch Status /dev/rfkill Watch.
[ 13.714538] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: probing service rpc_example_2 with src 1024 dst 101
[ 13.738769] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: probing service rpc_example_1 with src 1024 dst 101
[ 13.739196] rpmsg_rpc virtio0.rpmsg-rpc.-1.101: published functions = 8
[ 13.747924] ata1: SATA link down (SStatus 0 SControl 300)
[ 13.792907] rpmsg_rpc virtio2.rpmsg-rpc.-1.101: probing service rpc_example_4 with src 1024 dst 101
[ 13.794036] rpmsg_rpc virtio1.rpmsg-rpc.-1.101: published functions = 8
[ 13.854095] rpmsg_rpc virtio3.rpmsg-rpc.-1.101: probing service rpc_example_3 with src 1024 dst 101
[ 13.854461] remoteproc remoteproc4: 4b234000.pru is available
[ 13.895690] rpmsg_rpc virtio2.rpmsg-rpc.-1.101: published functions = 8
[ 13.915618] rpmsg_rpc virtio3.rpmsg-rpc.-1.101: published functions = 8
[ 13.922027] remoteproc remoteproc5: 4b238000.pru is available
[ 13.947052] OF: graph: no port node found in /ocp/interconnect@4a000000/segment@0/target-module@80000/ocp2scp@0/phy@5000
[ 13.961761] remoteproc remoteproc6: 4b2b4000.pru is available
[ 13.970855] remoteproc remoteproc7: 4b2b8000.pru is available
[ 14.019683] usbcore: registered new interface driver usbfs
[ 14.027435] usbcore: registered new interface driver hub
[ 14.033508] usbcore: registered new device driver usb
[ 14.058563] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 14.070526] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 14.083099] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[ 14.092620] xhci-hcd xhci-hcd.2.auto: irq 206, io mem 0x48890000
[ 14.098785] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 14.104370] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 14.112091] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 14.118774] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 14.127075] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.134399] usb usb1: Product: xHCI Host Controller
[ 14.139282] usb usb1: Manufacturer: Linux 5.10.168 xhci-hcd
[ 14.144897] usb usb1: SerialNumber: xhci-hcd.2.auto
[ 14.150817] hub 1-0:1.0: USB hub found
[ 14.154602] hub 1-0:1.0: 1 port detected
[ 14.159332] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 14.167541] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 14.175903] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.183227] usb usb2: Product: xHCI Host Controller
[ 14.188110] usb usb2: Manufacturer: Linux 5.10.168 xhci-hcd
[ 14.193725] usb usb2: SerialNumber: xhci-hcd.2.auto
[ 14.199432] hub 2-0:1.0: USB hub found
[ 14.203216] hub 2-0:1.0: 1 port detected
[ 14.208526] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 14.214141] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[ 14.222106] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[ 14.231628] xhci-hcd xhci-hcd.3.auto: irq 207, io mem 0x488d0000
[ 14.237792] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 14.243408] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[ 14.251129] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[ 14.257843] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 14.266204] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.273620] usb usb3: Product: xHCI Host Controller
[ 14.278503] usb usb3: Manufacturer: Linux 5.10.168 xhci-hcd
[ 14.284118] usb usb3: SerialNumber: xhci-hcd.3.auto
[ 14.289916] hub 3-0:1.0: USB hub found
[ 14.293731] hub 3-0:1.0: 1 port detected
[ 14.298553] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 14.306823] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 14.315246] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.322570] usb usb4: Product: xHCI Host Controller
[ 14.327484] usb usb4: Manufacturer: Linux 5.10.168 xhci-hcd
[ 14.333160] usb usb4: SerialNumber: xhci-hcd.3.auto
[ 14.339019] hub 4-0:1.0: USB hub found
[ 14.342864] hub 4-0:1.0: 1 port detected
[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Boot Completion Check.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting sshd.socket.
[ OK ] Listening on sshd.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Save/Restore Sound Card State...
[ OK ] Started can0 interface setup.
[ OK ] Started can1 interface setup.[ 15.466888] c_can_platform 4ae3c000.can can0: setting BTR=0504 BRPE=0000
[ 15.479248] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 15.488250] c_can_platform 48480000.can can1: setting BTR=0504 BRPE=0000
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Login Service...
Starting TI IPC Daemon...
Starting OpenSSH Key Generation...
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started TI IPC Daemon.
[ OK ] Started OpenSSH Key Generation.
[ OK ] Reached target Sound Card.
[ OK ] Started Login Service.
[ 16.500549] IPv6: ADDRCONF(NETDEV_CHANGE): can1: link becomes ready
____ _ _ __ __ _____ _____ ____
| _ \ | | | |\ \ / /|_ _|| ____| / ___|
| |_) || |_| | \ V / | | | _| | |
| __/ | _ | | | | | | |___ | |___
|_| |_| |_| |_| |_| |_____| \____|
__ __ ___ ____ _ _ ____ _____
\ \ / / / _ \ / ___|| | | || _ \ |_ _|
\ V / | | | || | _ | | | || |_) | | |
| | | |_| || |_| || |_| || _ < | |
|_| \___/ \____| \___/ |_| \_\ |_|
Yogurt (Phytec Base Distribution) BSP-Yocto-AM57x-PD23.1.1 phycore-am57xx-1 ttyS2
phycore-am57xx-1 login: root
U-Boot SPL 2021.01-g0769550075 (Mar 13 2024 - 08:21:37 +0000) DRA752-GP ES2.0 Trying to boot from MMC1 no pinctrl state for default mode Loading Environment from FAT... no pinctrl state for default mode OK U-Boot 2021.01-g0769550075 (Mar 13 2024 - 08:21:37 +0000) CPU : DRA752-GP ES2.0 Model: PHYTEC PCM-948 AM57x RDK SoM: PHYTEC phyCORE-AM57x (41300111I) DRAM: 2 GiB MMC: no pinctrl state for default mode OMAP SD/MMC: 0, OMAP SD/MMC: 1 Loading Environment from FAT... OK Net: Warning: ethernet@48484000 MAC addresses don't match: Address in ROM is 50:51:a9:92:da:de Address in environment is 50:51:a9:92:c8:fa eth2: ethernet@48484000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 Failed to load 'boot.scr' Failed to load 'uEnv.txt' switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 5370368 bytes read in 238 ms (21.5 MiB/s) 214503 bytes read in 18 ms (11.4 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8fec8000, end 8fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.10.168 (oe-user@oe-host) (arm-phytec-linux-gnueabi-gcc (GCC) 9.5.0, GNU ld (GNU Binutils) 2.34.0.20200910) #1 SMP PREEMPT Mon Mar 4 13:13:09 UTC 2024 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: PHYTEC PCM-948 AM57x RDK [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB [ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 512 MiB at 0x00000000df000000 [ 0.000000] OMAP4: Map 0x00000000afd00000 to (ptrval) for dram barrier [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000afcfffff] [ 0.000000] Normal empty [ 0.000000] HighMem [mem 0x00000000afd00000-0x00000000feffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000abffffff] [ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000afcfffff] [ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000feffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000feffffff] [ 0.000000] DRA752 ES2.0 [ 0.000000] percpu: Embedded 16 pages/cpu s33612 r8192 d23732 u65536 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 517702 [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=a4c7c155-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1155292K/2077696K available (10240K kernel code, 750K rwdata, 3596K rodata, 2048K init, 297K bss, 234276K reserved, 688128K cma-reserved, 770048K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000000] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns [ 0.001373] TI gptimer clockevent: always-on 32786 Hz at /ocp/interconnect@4ae00000/segment@10000/target-module@8000 [ 0.003051] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2c000 [ 0.003234] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2e000 [ 0.004211] Console: colour dummy device 80x30 [ 0.004241] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664) [ 0.062011] pid_max: default: 32768 minimum: 301 [ 0.062133] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.062133] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.062744] CPU: Testing write buffer coherency: ok [ 0.062774] CPU0: Spectre v2: using ICIALLU workaround [ 0.062805] CPU0: Spectre BHB: enabling loop workaround for all CPUs [ 0.062988] /cpus/cpu@0 missing clock-frequency property [ 0.062988] /cpus/cpu@1 missing clock-frequency property [ 0.063018] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.063629] Setting up static identity map for 0x80200000 - 0x80200060 [ 0.063720] rcu: Hierarchical SRCU implementation. [ 0.063903] EFI services will not be available. [ 0.064453] smp: Bringing up secondary CPUs ... [ 0.124664] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.124694] CPU1: Spectre v2: using ICIALLU workaround [ 0.124816] smp: Brought up 1 node, 2 CPUs [ 0.124816] SMP: Total of 2 processors activated (3994.41 BogoMIPS). [ 0.124847] CPU: All CPU(s) started in HYP mode. [ 0.124847] CPU: Virtualization extensions available. [ 0.125183] devtmpfs: initialized [ 0.148437] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.148620] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.148651] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.162231] pinctrl core: initialized pinctrl subsystem [ 0.162780] DMI not present or invalid. [ 0.163269] NET: Registered protocol family 16 [ 0.165069] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.167694] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.186065] thermal_sys: Registered thermal governor 'fair_share' [ 0.186065] thermal_sys: Registered thermal governor 'bang_bang' [ 0.186065] thermal_sys: Registered thermal governor 'step_wise' [ 0.186065] thermal_sys: Registered thermal governor 'user_space' [ 0.186096] thermal_sys: Registered thermal governor 'two_stage' [ 0.186859] cpuidle: using governor ladder [ 0.186889] cpuidle: using governor menu [ 3.541259] No ATAGs? [ 3.541320] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 3.541351] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 3.583648] iommu: Default domain type: Translated [ 3.587036] SCSI subsystem initialized [ 3.587524] mc: Linux media interface: v0.10 [ 3.587554] videodev: Linux video capture interface: v2.00 [ 3.587615] pps_core: LinuxPPS API ver. 1 registered [ 3.587615] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 3.587646] PTP clock support registered [ 3.587677] EDAC MC: Ver: 3.0.0 [ 3.588775] Advanced Linux Sound Architecture Driver Initialized. [ 3.589599] clocksource: Switched to clocksource 32k_counter [ 3.595855] NET: Registered protocol family 2 [ 3.596008] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 3.596832] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 3.596862] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 3.596923] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 3.597045] TCP: Hash tables configured (established 8192 bind 8192) [ 3.597106] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 3.597137] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 3.597259] NET: Registered protocol family 1 [ 3.597656] RPC: Registered named UNIX socket transport module. [ 3.597656] RPC: Registered udp transport module. [ 3.597686] RPC: Registered tcp transport module. [ 3.597686] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.597686] NET: Registered protocol family 44 [ 3.597717] PCI: CLS 0 bytes, default 64 [ 3.599121] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 3.599273] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 3.600006] Initialise system trusted keyrings [ 3.600158] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 3.604003] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 3.604461] NFS: Registering the id_resolver key type [ 3.604522] Key type id_resolver registered [ 3.604522] Key type id_legacy registered [ 3.604583] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 3.604614] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 3.604644] ntfs: driver 2.1.32 [Flags: R/O]. [ 3.605010] Key type asymmetric registered [ 3.605010] Asymmetric key parser 'x509' registered [ 3.605072] bounce: pool size: 64 pages [ 3.605102] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 3.605102] io scheduler mq-deadline registered [ 3.605102] io scheduler kyber registered [ 4.305389] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 4.787231] OMAP GPIO hardware version 0.1 [ 4.980041] ti-sysc 48059000.target-module: dts flag should be at module level for ti,no-idle-on-init [ 4.980072] ti-sysc 48059000.target-module: dts flag should be at module level for ti,no-reset-on-init [ 5.380798] omap-mailbox 4883c000.mailbox: omap mailbox rev 0x400 [ 5.395812] omap-mailbox 4883e000.mailbox: omap mailbox rev 0x400 [ 5.410675] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 5.425476] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 5.529327] edma 43300000.dma: memcpy is disabled [ 5.532073] edma 43300000.dma: TI EDMA DMA engine driver [ 5.683441] pinctrl-single 4a003400.pinmux: 282 pins, size 1128 [ 5.688995] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges: [ 5.689056] dra7-pcie 51000000.pcie: IO 0x0020003000..0x0020012fff -> 0x0000000000 [ 5.689086] dra7-pcie 51000000.pcie: MEM 0x0020013000..0x002fffffff -> 0x0020013000 [ 6.690032] dra7-pcie 51000000.pcie: Phy link never came up [ 6.690124] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00 [ 6.690155] pci_bus 0000:00: root bus resource [bus 00-ff] [ 6.690155] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 6.690185] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff] [ 6.690216] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400 [ 6.690246] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff] [ 6.690246] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff] [ 6.690338] pci 0000:00:00.0: supports D1 [ 6.690338] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 6.698333] PCI: bus0: Fast back to back transfers disabled [ 6.706146] PCI: bus1: Fast back to back transfers enabled [ 6.706176] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff] [ 6.706207] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff] [ 6.706207] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 6.706542] pcieport 0000:00:00.0: PME: Signaling with IRQ 185 [ 6.759552] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 6.763488] printk: console [ttyS2] disabled [ 6.763641] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 111, base_baud = 3000000) is a 8250 [ 7.786834] printk: console [ttyS2] enabled [ 7.792449] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 124, base_baud = 3000000) is a 8250 [ 7.804168] omap_rng 48090000.rng: Random Number Generator ver. 20 [ 7.809722] random: crng init done [ 7.832031] brd: module loaded [ 7.840576] loop: module loaded [ 7.929687] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 7.967834] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY [ 7.977569] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY [ 7.987976] cpsw-switch 48484000.switch: initialized cpsw ale version 1.4 [ 7.994842] cpsw-switch 48484000.switch: ALE Table size 1024 [ 8.000610] cpsw-switch 48484000.switch: cpts: overflow check period 500 (jiffies) [ 8.008209] cpsw-switch 48484000.switch: CPTS: ref_clk_freq:266000000 calc_mult:4036623398 calc_shift:30 error:-1 nsec/sec [ 8.019348] cpsw-switch 48484000.switch: Detected MACID = 50:51:a9:92:da:de [ 8.026367] cpsw-switch 48484000.switch: Detected MACID = 50:51:a9:92:da:df [ 8.034790] cpsw-switch 48484000.switch: initialized (regs 0x0000000048484000, pool size 256) hw_ver:0019010F 1.15 (0) [ 8.046936] i2c /dev entries driver [ 8.058258] sdhci: Secure Digital Host Controller Interface driver [ 8.064514] sdhci: Copyright(c) Pierre Ossman [ 8.070617] sdhci-pltfm: SDHCI platform and OF driver helper [ 8.078552] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22) [ 8.087493] sdhci-omap 4809c000.mmc: Got CD GPIO [ 8.092315] sdhci-omap 4809c000.mmc: Got WP GPIO [ 8.097167] sdhci-omap 480b4000.mmc: supply vqmmc not found, using dummy regulator [ 8.097167] sdhci-omap 4809c000.mmc: supply vqmmc not found, using dummy regulator [ 8.119689] ledtrig-cpu: registered to indicate activity on CPUs [ 8.132873] NET: Registered protocol family 10 [ 8.138153] Segment Routing with IPv6 [ 8.141906] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 8.148254] NET: Registered protocol family 17 [ 8.153015] Key type dns_resolver registered [ 8.157409] Registering SWP/SWPB emulation handler [ 8.162689] omap_voltage_late_init: Voltage driver support not added [ 8.169067] Power Management for TI OMAP4+ devices. [ 8.174407] Loading compiled-in X.509 certificates [ 8.208587] dmm 4e000000.dmm: workaround for errata i878 in use [ 8.216339] dmm 4e000000.dmm: initialized all PAT entries [ 8.223937] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz [ 8.259216] palmas 0-0058: Irq flag is 0x00000008 [ 8.293060] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0 [ 8.314453] VDD_MPU: Bringing 0uV into 850000-850000uV U-Boot SPL 2021.01-g0769550075 (Mar 13 2024 - 08:21:37 +0000) DRA752-GP ES2.0 Trying to boot from MMC1 no pinctrl state for default mode Loading Environment from FAT... no pinctrl state for default mode OK U-Boot 2021.01-g0769550075 (Mar 13 2024 - 08:21:37 +0000) CPU : DRA752-GP ES2.0 Model: PHYTEC PCM-948 AM57x RDK SoM: PHYTEC phyCORE-AM57x (41300111I) DRAM: 2 GiB MMC: no pinctrl state for default mode OMAP SD/MMC: 0, OMAP SD/MMC: 1 Loading Environment from FAT... OK Net: Warning: ethernet@48484000 MAC addresses don't match: Address in ROM is 50:51:a9:92:da:de Address in environment is 50:51:a9:92:c8:fa eth2: ethernet@48484000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 Failed to load 'boot.scr' Failed to load 'uEnv.txt' switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 5370368 bytes read in 239 ms (21.4 MiB/s) 214503 bytes read in 16 ms (12.8 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8fec8000, end 8fffffff ... OK Starting kernel ...
NOTE : This does not happen on all the SOMs, but a few are affected by this.
I have attached boot-up logs for the same: 1) one which successfully boots up 2) Another which crashes.
Upon comparing both the logs, we noticed that the line where VDD_MPU is different between both.
Crashing : VDD_MPU: Bringing 0uV into 850000-850000uV
Working : VDD_MPU: supplied by regulator-dummy
What does this mean ? since same image is flashed on both SOMs.
Sujan
