Problem of GEL file with custom built Board having TMS320C6748 processor
Other Parts Discussed in Thread: TMS320C6748
We are trying to bring up our Board.  Processor : TMS320C6748 rev 2, JTAG Emu: Black Hawk 560M. All voltage levels are correct in the Board.
I have inserted the GEL File "Gel_6748.txt
#define PLL0_BASE       0x01C11000                              /*SYSTEM PLL BASE ADDRESS*/
#define PLL0_PID        *(unsigned int*) (PLL0_BASE + 0x00)     /*PID*/
#define PLL0_RSTYPE     *(unsigned int*) (PLL0_BASE + 0xE4)     /*Reset Type status Reg*/
#define PLL0_RSCTRL     *(unsigned int*) (PLL0_BASE + 0xE8)     /*Reset Control Register*/
#define PLL0_PLLCTL     *(unsigned int*) (PLL0_BASE + 0x100)    /*PLL Control Register*/
#define PLL0_OCSEL      *(unsigned int*) (PLL0_BASE + 0x104)    /*OBSCLK Select Register*/
//#define PLL0_SECCTL     *(unsigned int*) (PLL0_BASE + 0x108)    /*PLL Secondary Control Register*/
#define PLL0_PLLM       *(unsigned int*) (PLL0_BASE + 0x110)    /*PLL Multiplier*/
#define PLL0_PREDIV     *(unsigned int*) (PLL0_BASE + 0x114)    /*Pre divider*/
#define PLL0_PLLDIV1    *(unsigned int*) (PLL0_BASE + 0x118)    /*Divider-1*/
#define PLL0_PLLDIV2    *(unsigned int*) (PLL0_BASE + 0x11C)    /*Divider-2*/
#define PLL0_PLLDIV3    *(unsigned int*) (PLL0_BASE + 0x120)    /*Divider-3*/
#define PLL0_OSCDIV1    *(unsigned int*) (PLL0_BASE + 0x124)    /*Oscilator Divider*/
#define PLL0_POSTDIV    *(unsigned int*) (PLL0_BASE + 0x128)    /*Post Divider*/
//#define PLL0_BPDIV      *(unsigned int*) (PLL0_BASE + 0x12C)    /*Bypass Divider*/
//#define PLL0_WAKEUP     *(unsigned int*) (PLL0_BASE + 0x130)    /*Wakeup Reg*/
#define PLL0_PLLCMD     *(unsigned int*) (PLL0_BASE + 0x138)    /*Command Reg*/
#define PLL0_PLLSTAT    *(unsigned int*) (PLL0_BASE + 0x13C)    /*Control Status Reg*/
#define PLL0_ALNCTL     *(unsigned int*) (PLL0_BASE + 0x140)    /*Clock Align Control Reg*/
#define PLL0_DCHANGE    *(unsigned int*) (PLL0_BASE + 0x144)    /*PLLDIV Ratio Chnage status*/
#define PLL0_CKEN       *(unsigned int*) (PLL0_BASE + 0x148)    /*Clock Enable Reg*/
#define PLL0_CKSTAT     *(unsigned int*) (PLL0_BASE + 0x14C)    /*Clock Status Reg*/
#define PLL0_SYSTAT     *(unsigned int*) (PLL0_BASE + 0x150)    /*Sysclk status reg*/
#define PLL0_PLLDIV4    *(unsigned int*) (PLL0_BASE + 0x160)    /*Divider 4*/
#define PLL0_PLLDIV5    *(unsigned int*) (PLL0_BASE + 0x164)    /*Divider 5*/
#define PLL0_PLLDIV6    *(unsigned int*) (PLL0_BASE + 0x168)    /*Divider 6*/
#define PLL0_PLLDIV7    *(unsigned int*) (PLL0_BASE + 0x16C)    /*Divider 7*/
//#define PLL0_PLLDIV8    *(unsigned int*) (PLL0_BASE + 0x170)    /*Divider 8*/
//#define PLL0_PLLDIV9    *(unsigned int*) (PLL0_BASE + 0x174)    /*Divider 9*/
//#define PLL0_PLLDIV10   *(unsigned int*) (PLL0_BASE + 0x178)    /*Divider 10*/
//#define PLL0_PLLDIV11   *(unsigned int*) (PLL0_BASE + 0x17C)    /*Divider 11*/
//#define PLL0_PLLDIV12   *(unsigned int*) (PLL0_BASE + 0x180)    /*Divider 12*/
//#define PLL0_PLLDIV13   *(unsigned int*) (PLL0_BASE + 0x184)    /*Divider 13*/
//#define PLL0_PLLDIV14   *(unsigned int*) (PLL0_BASE + 0x188)    /*Divider 14*/
//#define PLL0_PLLDIV15   *(unsigned int*) (PLL0_BASE + 0x18C)    /*Divider 15*/
//#define PLL0_PLLDIV16   *(unsigned int*) (PLL0_BASE + 0x190)    /*Divider 16*/
#define PLL0_EMUCNT0   *(unsigned int*) (PLL0_BASE + 0x1F0)    /*Emulation Performance Counter 0 Register*/
#define PLL0_EMUCNT0   *(unsigned int*) (PLL0_BASE + 0x1F4)    /*Emulation Performance Counter 1 Register*/
#define PLL1_BASE       0x01E1A000                              /*SYSTEM PLL1 BASE ADDRESS*/
#define PLL1_PID        *(unsigned int*) (PLL1_BASE + 0x00)     /*PID*/
//#define PLL1_RSTYPE     *(unsigned int*) (PLL1_BASE + 0xE4)     /*Reset Type status Reg*/
#define PLL1_PLLCTL     *(unsigned int*) (PLL1_BASE + 0x100)    /*PLL Control Register*/
#define PLL1_OCSEL      *(unsigned int*) (PLL1_BASE + 0x104)    /*OBSCLK Select Register*/
//#define PLL1_SECCTL     *(unsigned int*) (PLL1_BASE + 0x108)    /*PLL Secondary Control Register*/
#define PLL1_PLLM       *(unsigned int*) (PLL1_BASE + 0x110)    /*PLL Multiplier*/
#define PLL1_PREDIV     *(unsigned int*) (PLL1_BASE + 0x114)    /*Pre divider*/
#define PLL1_PLLDIV1    *(unsigned int*) (PLL1_BASE + 0x118)    /*Divider-1*/
#define PLL1_PLLDIV2    *(unsigned int*) (PLL1_BASE + 0x11C)    /*Divider-2*/
#define PLL1_PLLDIV3    *(unsigned int*) (PLL1_BASE + 0x120)    /*Divider-3*/
#define PLL1_OSCDIV1    *(unsigned int*) (PLL1_BASE + 0x124)    /*Oscilator Divider*/
#define PLL1_POSTDIV    *(unsigned int*) (PLL1_BASE + 0x128)    /*Post Divider*/
//#define PLL1_BPDIV      *(unsigned int*) (PLL1_BASE + 0x12C)    /*Bypass Divider*/
//#define PLL1_WAKEUP     *(unsigned int*) (PLL1_BASE + 0x130)    /*Wakeup Reg*/
#define PLL1_PLLCMD     *(unsigned int*) (PLL1_BASE + 0x138)    /*Command Reg*/
#define PLL1_PLLSTAT    *(unsigned int*) (PLL1_BASE + 0x13C)    /*Status Reg*/
#define PLL1_ALNCTL     *(unsigned int*) (PLL1_BASE + 0x140)    /*Clock Align Control Reg*/
#define PLL1_DCHANGE    *(unsigned int*) (PLL1_BASE + 0x144)    /*PLLDIV Ratio Chnage status*/
#define PLL1_CKEN       *(unsigned int*) (PLL1_BASE + 0x148)    /*Clock Enable Reg*/
#define PLL1_CKSTAT     *(unsigned int*) (PLL1_BASE + 0x14C)    /*Clock Status Reg*/
#define PLL1_SYSTAT     *(unsigned int*) (PLL1_BASE + 0x150)    /*Sysclk status reg*/
//#define PLL1_PLLDIV4    *(unsigned int*) (PLL1_BASE + 0x160)    /*Divider 4*/
//#define PLL1_PLLDIV5    *(unsigned int*) (PLL1_BASE + 0x164)    /*Divider 5*/
//#define PLL1_PLLDIV6    *(unsigned int*) (PLL1_BASE + 0x168)    /*Divider 6*/
//#define PLL1_PLLDIV7    *(unsigned int*) (PLL1_BASE + 0x16C)    /*Divider 7*/
//#define PLL1_PLLDIV8    *(unsigned int*) (PLL1_BASE + 0x170)    /*Divider 8*/
//#define PLL1_PLLDIV9    *(unsigned int*) (PLL1_BASE + 0x174)    /*Divider 9*/
//#define PLL1_PLLDIV10   *(unsigned int*) (PLL1_BASE + 0x178)    /*Divider 10*/
//#define PLL1_PLLDIV11   *(unsigned int*) (PLL1_BASE + 0x17C)    /*Divider 11*/
//#define PLL1_PLLDIV12   *(unsigned int*) (PLL1_BASE + 0x180)    /*Divider 12*/
//#define PLL1_PLLDIV13   *(unsigned int*) (PLL1_BASE + 0x184)    /*Divider 13*/
//#define PLL1_PLLDIV14   *(unsigned int*) (PLL1_BASE + 0x188)    /*Divider 14*/
//#define PLL1_PLLDIV15   *(unsigned int*) (PLL1_BASE + 0x18C)    /*Divider 15*/
//#define PLL1_PLLDIV16   *(unsigned int*) (PLL1_BASE + 0x190)    /*Divider 16*/
#define PLL1_PLLDIV16   *(unsigned int*) (PLL1_BASE + 0x1F0)    /*Emulation Performance Counter 0 Register*/
#define PLL1_PLLDIV16   *(unsigned int*) (PLL1_BASE + 0x1F4)    /*Emulation Performance Counter 1 Register*/
/*PSC Module Related Registers*/
#define PSC0_BASE       0x01C10000
#define PSC1_BASE       0x01E27000
#define PSC0_MDCTL      (PSC0_BASE+0xA00)						/*Module Control n Register (modules 0-15)*/
#define PSC0_MDSTAT     (PSC0_BASE+0x800)						/*Module Status n Register (modules 0-15)*/
#define PSC0_PTCMD      *(unsigned int*) (PSC0_BASE + 0x120)
#define PSC0_PTSTAT     *(unsigned int*) (PSC0_BASE + 0x128)
#define PSC1_MDCTL      (PSC1_BASE+0xA00)
#define PSC1_MDSTAT     (PSC1_BASE+0x800)
#define PSC1_PTCMD      *(unsigned int*) (PSC1_BASE + 0x120)	/*Power Domain Transition Command Register*/
#define PSC1_PTSTAT     *(unsigned int*) (PSC1_BASE + 0x128)	/*Power Domain Transition Status Register*/
#define PSC_TIMEOUT      200                    // check///
#define LPSC_EDMA_CC0    0
#define LPSC_EDMA_TC0    1
#define LPSC_EDMA_TC1    2
#define LPSC_EMIFA       3   /*PSC0*/
#define LPSC_SPI0        4   /*PSC0*/
#define LPSC_MMCSD0      5   /*PSC0*/
//#define LPSC_ARM_AINTC   6
//#define LPSC_ARM_RAMROM  7   /*PSC0*/
// LPSC #8 not used
#define LPSC_UART0       9   /*PSC0*/
//#define LPSC_SCR0      10
#define LPSC_SCR1        11
#define LPSC_SCR2        12
#define LPSC_PRU		 13
//#define LPSC_ARM       14  /*PSC0*/
#define LPSC_DSP         15  /*PSC0*/
#define LPSC_EDMA_CC1    0
#define LPSC_USB20       1   /*PSC1*/
#define LPSC_USB11       2   /*PSC1*/
#define LPSC_GPIO        3   /*PSC1*/
#define LPSC_UHPI        4   /*PSC1*/
#define LPSC_EMAC        5   /*PSC1*/
#define LPSC_DDR         6   /*PSC1*/
#define LPSC_MCASP0      7   /*PSC1*/
#define LPSC_SATA        8   /*PSC1*/
#define LPSC_VPIF        9   /*PSC1*/
#define LPSC_SPI1        10  /*PSC1*/
#define LPSC_I2C1        11  /*PSC1*/
#define LPSC_UART1       12  /*PSC1*/
#define LPSC_UART2       13  /*PSC1*/
#define LPSC_MCBSP0      14  /*PSC1*/
#define LPSC_MCBSP1      15  /*PSC1*/
#define LPSC_LCDC        16  /*PSC1*/
#define LPSC_EPWM        17  /*PSC1*/
#define LPSC_MMCSD1      18
#define LPSC_UPP         19
#define LPSC_ECAP        20
#define LPSC_EDMA_TC2    21
// LPSC #22-23 not used
#define LPSC_SCR_F0      24
#define LPSC_SCR_F1      25
#define LPSC_SCR_F2      26
#define LPSC_SCR_F6      27
#define LPSC_SCR_F7      28
#define LPSC_SCR_F8      29
#define LPSC_BR_F7       30
#define LPSC_SHARED_RAM  31
/*DDR MMR Declaration*/
#define VTPIO_CTL           *(unsigned int*)(0x01E2C000)                  // VTPIO_CTL Register
#define EMIFDDR_SDRAM_CFG   0xB0000000
#define EMIFDDR_REVID       *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x00)      //EMIF Module ID and Revision Register
#define EMIFDDR_SDRSTAT     *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x04)      //DDR Slew Register
#define EMIFDDR_SDCR        *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x08)      //Deep Sleep Register
#define EMIFDDR_SDRCR       *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x0C)      //Pullup/Pulldown Enable Register
#define EMIFDDR_SDTIMR1     *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x10)      //Pullup/Pulldown Selection Register
#define EMIFDDR_SDTIMR2     *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x14)      //RXACTIVE Control Register
#define EMIFDDR_SDCR2       *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x18)      //Power Down Control Register
//#define EMIFDDR_PBBPR       *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x20)      //VBUSM Burst Priority Register
//#define EMIFDDR_VBUSMCFG1   *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x28)      //VBUSM config Value1 Register
//#define EMIFDDR_VBUSMCFG2   *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x2C)      //VBUSM config Value2 Register
//#define EMIFDDR_IRR         *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0xC0)      //Interrupt Raw Register
//#define EMIFDDR_IMR         *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0xC4)      //Interrupt Masked Register
//#define EMIFDDR_IMSR        *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0xC8)      //Interrupt Mask Set Register
//#define EMIFDDR_IMCR        *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0xCC)      //Interrupt Mask Clear Register
//#define DDRPHYREV           *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0xE0)      //DDR PHY ID and Revision Register
//#define DRPYC1R             *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0xE4)      //DDR PHY Control 1 Register
#define DDR2 0
#define MDDR 1
#define VTP_TIMEOUT 200
#define DDR_DEBUG 0
#define EMIFDDR_BASE_ADDR       0xC0000000
#define EMIFA_BASE_ADDR         0x40000000
#define EMIFA_CS2_BASE_ADDR     0x60000000
#define EMIFA_CS3_BASE_ADDR     0x62000000
#define EMIFA_CS4_BASE_ADDR     0x64000000
#define EMIFA_CS5_BASE_ADDR     0x66000000
/*EMIF2.5 MMR Declaration*/
#define EMIFA             0x68000000
#define EMIFA_AWAITCFG    *(unsigned int*)(EMIFA + 0x04)
#define EMIFA_SDCFG       *(unsigned int*)(EMIFA + 0x08)
#define EMIFA_SDREF       *(unsigned int*)(EMIFA + 0x0C)
#define EMIFA_ACFG2       *(unsigned int*)(EMIFA + 0x10)    //Async Bank1 Config Register
#define EMIFA_ACFG3       *(unsigned int*)(EMIFA + 0x14)    //Async Bank2 Config Register
#define EMIFA_ACFG4       *(unsigned int*)(EMIFA + 0x18)    //Async Bank3 Config Register
#define EMIFA_ACFG5       *(unsigned int*)(EMIFA + 0x1C)    //Async Bank4 Config Register
#define EMIFA_SDTIM       *(unsigned int*)(EMIFA + 0x20)    //SDRAM Timing Register
#define EMIFA_SRPD        *(unsigned int*)(EMIFA + 0x3C)
#define EMIFA_NANDFCR     *(unsigned int*)(EMIFA + 0x60)
/*GPIO MMR*/
#define GPIO_REG_BASE         (0x01E26000)
#define GPIO_BANK_OFFSET      (0x28)
#define GPIO_DAT_OFFSET       (0x04)
#define GPIO_SET_OFFSET       (0x08)
#define GPIO_CLR_OFFSET       (0x0C)
#define GPIO_BINTEN           *(unsigned int*)(GPIO_REG_BASE + 0x08)
#define GPIO_BANK01_BASE      (GPIO_REG_BASE + 0x10)
#define GPIO_BANK23_BASE      (GPIO_BANK01_BASE + GPIO_BANK_OFFSET)
#define GPIO_BANK45_BASE      (GPIO_BANK23_BASE + GPIO_BANK_OFFSET)
#define GPIO_BANK67_BASE      (GPIO_BANK45_BASE + GPIO_BANK_OFFSET)
#define GPIO_BANK8_BASE       (GPIO_BANK67_BASE + GPIO_BANK_OFFSET)
#define GPIO_BANK23_DIR       *(unsigned int*)(GPIO_BANK23_BASE)
#define GPIO_BANK23_DAT       *(unsigned int*)(GPIO_BANK23_BASE + GPIO_DAT_OFFSET)
#define GPIO_BANK23_SET       *(unsigned int*)(GPIO_BANK23_BASE + GPIO_SET_OFFSET)
#define GPIO_BANK23_CLR       *(unsigned int*)(GPIO_BANK23_BASE + GPIO_CLR_OFFSET)
/*System MMR Declaration*/
#define SYS_BASE           0x01C14000
//#define HOST0CFG           *(unsigned int*)(SYS_BASE + 0x040)  //ARM HOST0CFG
#define KICK0R             *(unsigned int*)(SYS_BASE + 0x038)
#define KICK1R             *(unsigned int*)(SYS_BASE + 0x03c)
#define PINMUX0            *(unsigned int*)(SYS_BASE + 0x120)  //PINMUX0
#define PINMUX1            *(unsigned int*)(SYS_BASE + 0x124)  //PINMUX1
#define PINMUX2            *(unsigned int*)(SYS_BASE + 0x128)  //PINMUX2
#define PINMUX3            *(unsigned int*)(SYS_BASE + 0x12C)  //PINMUX3
#define PINMUX4            *(unsigned int*)(SYS_BASE + 0x130)  //PINMUX4
#define PINMUX5            *(unsigned int*)(SYS_BASE + 0x134)  //PINMUX5
#define PINMUX6            *(unsigned int*)(SYS_BASE + 0x138)  //PINMUX6
#define PINMUX7            *(unsigned int*)(SYS_BASE + 0x13C)  //PINMUX7
#define PINMUX8            *(unsigned int*)(SYS_BASE + 0x140)  //PINMUX8
#define PINMUX9            *(unsigned int*)(SYS_BASE + 0x144)  //PINMUX9
#define PINMUX10           *(unsigned int*)(SYS_BASE + 0x148)  //PINMUX10
#define PINMUX11           *(unsigned int*)(SYS_BASE + 0x14C)  //PINMUX11
#define PINMUX12           *(unsigned int*)(SYS_BASE + 0x150)  //PINMUX12
#define PINMUX13           *(unsigned int*)(SYS_BASE + 0x154)  //PINMUX13
#define PINMUX14           *(unsigned int*)(SYS_BASE + 0x158)  //PINMUX14
#define PINMUX15           *(unsigned int*)(SYS_BASE + 0x15C)  //PINMUX15
#define PINMUX16           *(unsigned int*)(SYS_BASE + 0x160)  //PINMUX16
#define PINMUX17           *(unsigned int*)(SYS_BASE + 0x164)  //PINMUX17
#define PINMUX18           *(unsigned int*)(SYS_BASE + 0x168)  //PINMUX18
#define PINMUX19           *(unsigned int*)(SYS_BASE + 0x16C)  //PINMUX19
#define CFGCHIP0           *(unsigned int*)(SYS_BASE + 0x17C)
#define CFGCHIP1           *(unsigned int*)(SYS_BASE + 0x180)
#define CFGCHIP2           *(unsigned int*)(SYS_BASE + 0x184)
#define CFGCHIP3           *(unsigned int*)(SYS_BASE + 0x188)
#define CFGCHIP4           *(unsigned int*)(SYS_BASE + 0x18C)
#define PD0                0   /*Power Domain-0*/
#define PD1                1   /*Power Domain-1*/
#define PLLEN_MUX_SWITCH         4
#define PLL_LOCK_TIME_CNT        2400
#define PLL_STABILIZATION_TIME   2000
#define PLL_RESET_TIME_CNT       200
OnTargetConnect( )
    Clear_Memory_Map();
    Setup_Memory_Map();
OnPreFileLoaded ( )
	GEL_TextOut("\t I AM IN PRE FILE LOAD -------------\n","Output",1,1,1);
	GEL_AdvancedReset("System Reset");
    PSC_All_On_Full_EVM();
    Core_300MHz_mDDR_150MHz();
    Wake_DSP();
menuitem "Wake Core"
hotmenu Wake_DSP()
    PSC0_LPSC_enableCore(1, LPSC_DSP);
    GEL_TextOut("\tDSP Wake Complete.\n","Output",1,1,1);
    GEL_TextOut("\t---------------------------------------------\n","Output",1,1,1);
menuitem "OMAP-L138 Memory Map"
 *  Clear_Memory_Map( )                                                     *
 *      Clear the Memory Map                                                *
hotmenu Clear_Memory_Map()
    GEL_MapOff( );
    GEL_MapReset( );
    GEL_TextOut("\tMemory Map Cleared.\n","Output",1,1,1);
hotmenu Setup_Memory_Map()
    GEL_MapOn( );
    GEL_MapReset( );
    /* ARM */
//    GEL_MapAddStr( 0xFFFD0000, 0, 0x00010000, "R|W|AS4", 0 );   // ARM Local ROM
//    GEL_MapAddStr( 0xFFFE0000, 0, 0x00002000, "R|W|AS4", 0 );   // ARM INTC
//    GEL_MapAddStr( 0xFFFF0000, 0, 0x00002000, "R|W|AS4", 0 );   // ARM Local RAM
//    GEL_MapAddStr( 0x01BC0000, 0, 0x00001000, "R|W|AS4", 0 );   // ARM ETB Memory
//    GEL_MapAddStr( 0x01BC1000, 0, 0x00000800, "R|W|AS4", 0 );   // ARM ETB Regs
//    GEL_MapAddStr( 0x01BC1800, 0, 0x00000100, "R|W|AS4", 0 );   // ARM Ice Crusher
    /* DSP */
    GEL_MapAddStr( 0x00700000, 0, 0x00100000, "R|W|AS4", 0 );   // DSP L2 ROM
    GEL_MapAddStr( 0x00800000, 0, 0x00040000, "R|W|AS4", 0 );   // DSP l2 RAM
    GEL_MapAddStr( 0x00E00000, 0, 0x00008000, "R|W|AS4", 0 );   // DSP L1P RAM
    GEL_MapAddStr( 0x00F00000, 0, 0x00008000, "R|W|AS4", 0 );   // DSP L1D RAM
    GEL_MapAddStr( 0x01800000, 0, 0x00010000, "R|W|AS4", 0 );   // DSP Interrupt Controller
    GEL_MapAddStr( 0x01810000, 0, 0x00001000, "R|W|AS4", 0 );   // DSP Powerdown Controller
    GEL_MapAddStr( 0x01811000, 0, 0x00001000, "R|W|AS4", 0 );   // DSP Security ID
    GEL_MapAddStr( 0x01812000, 0, 0x00008000, "R|W|AS4", 0 );   // DSP Revision ID
    GEL_MapAddStr( 0x01820000, 0, 0x00010000, "R|W|AS4", 0 );   // DSP EMC
    GEL_MapAddStr( 0x01830000, 0, 0x00010000, "R|W|AS4", 0 );   // DSP Internal Reserved
    GEL_MapAddStr( 0x01840000, 0, 0x00010000, "R|W|AS4", 0 );   // DSP Memory System
    GEL_MapAddStr( 0x11700000, 0, 0x00100000, "R|W|AS4", 0 );   // DSP L2 ROM (mirror)
    GEL_MapAddStr( 0x11800000, 0, 0x00040000, "R|W|AS4", 0 );   // DSP l2 RAM (mirror)
    GEL_MapAddStr( 0x11E00000, 0, 0x00008000, "R|W|AS4", 0 );   // DSP L1P RAM (mirror)
    GEL_MapAddStr( 0x11F00000, 0, 0x00008000, "R|W|AS4", 0 );   // DSP L1D RAM (mirror)
    /* Shared RAM */
    GEL_MapAddStr( 0x80000000, 0, 0x00020000, "R|W|AS4", 0 );   // Shared RAM
    /* EMIFA */
    GEL_MapAddStr( 0x40000000, 0, 0x20000000, "R|W|AS4", 0 );   // EMIFA SDRAM Data
    GEL_MapAddStr( 0x60000000, 0, 0x02000000, "R|W|AS4", 0 );   // EMIFA CS2
    GEL_MapAddStr( 0x62000000, 0, 0x02000000, "R|W|AS4", 0 );   // EMIFA CS3
    GEL_MapAddStr( 0x64000000, 0, 0x02000000, "R|W|AS4", 0 );   // EMIFA CS4
    GEL_MapAddStr( 0x66000000, 0, 0x02000000, "R|W|AS4", 0 );   // EMIFA CS5
    GEL_MapAddStr( 0x68000000, 0, 0x00008000, "R|W|AS4", 0 );   // EMIFA Control
    /* DDR */
    GEL_MapAddStr( 0xB0000000, 0, 0x00008000, "R|W|AS4", 0 );   // DDR Control
    GEL_MapAddStr( 0xC0000000, 0, 0x20000000, "R|W|AS4", 0 );   // DDR Data
    /* Peripherals */
    GEL_MapAddStr( 0x01C00000, 0, 0x00008000, "R|W|AS4", 0 );   // TPCC0
    GEL_MapAddStr( 0x01C08000, 0, 0x00000400, "R|W|AS4", 0 );   // TPTC0
    GEL_MapAddStr( 0x01C08400, 0, 0x00000400, "R|W|AS4", 0 );   // TPTC1
    GEL_MapAddStr( 0x01C10000, 0, 0x00001000, "R|W|AS4", 0 );   // PSC 0
    GEL_MapAddStr( 0x01C11000, 0, 0x00001000, "R|W|AS4", 0 );   // PLL Controller 0
//  GEL_MapAddStr( 0x01C12000, 0, 0x00001000, "R|W|AS4", 0 );   // Key Manager
    GEL_MapAddStr( 0x01C13000, 0, 0x00001000, "R|W|AS4", 0 );   // SecCo
    GEL_MapAddStr( 0x01C14000, 0, 0x00001000, "R|W|AS4", 0 );   // SysConfig
//  GEL_MapAddStr( 0x01C16000, 0, 0x00001000, "R|W|AS4", 0 );   // IOPU 0
//  GEL_MapAddStr( 0x01C17000, 0, 0x00001000, "R|W|AS4", 0 );   // IOPU 2
    GEL_MapAddStr( 0x01C20000, 0, 0x00001000, "R|W|AS4", 0 );   // Timer64P 0
    GEL_MapAddStr( 0x01C21000, 0, 0x00001000, "R|W|AS4", 0 );   // Timer64P 1
    GEL_MapAddStr( 0x01C22000, 0, 0x00001000, "R|W|AS4", 0 );   // I2C 0
    GEL_MapAddStr( 0x01C23000, 0, 0x00001000, "R|W|AS4", 0 );   // RTC
//  GEL_MapAddStr( 0x01C24000, 0, 0x00001000, "R|W|AS4", 0 );   // IOPU 1
//  GEL_MapAddStr( 0x01C30000, 0, 0x00000200, "R|W|AS4", 0 );   // PRU Data RAM 0
//  GEL_MapAddStr( 0x01C32000, 0, 0x00000200, "R|W|AS4", 0 );   // PRU Data RAM 1
//  GEL_MapAddStr( 0x01C34000, 0, 0x00004000, "R|W|AS4", 0 );   // PRU Control Registers
//  GEL_MapAddStr( 0x01C38000, 0, 0x00001000, "R|W|AS4", 0 );   // PRU 0 Config Memory
//  GEL_MapAddStr( 0x01C3C000, 0, 0x00001000, "R|W|AS4", 0 );   // PRU 1 Config Memory
    GEL_MapAddStr( 0x01C40000, 0, 0x00001000, "R|W|AS4", 0 );   // MMC/SD 0
    GEL_MapAddStr( 0x01C41000, 0, 0x00001000, "R|W|AS4", 0 );   // SPI 0
    GEL_MapAddStr( 0x01C42000, 0, 0x00001000, "R|W|AS4", 0 );   // UART 0
//  GEL_MapAddStr( 0x01C43000, 0, 0x00001000, "R|W|AS4", 0 );   // MPU 0
    GEL_MapAddStr( 0x01D00000, 0, 0x00001000, "R|W|AS4", 0 );   // McASP 0 Control
    GEL_MapAddStr( 0x01D01000, 0, 0x00001000, "R|W|AS4", 0 );   // McASP 0 FIFO Ctrl
    GEL_MapAddStr( 0x01D02000, 0, 0x00001000, "R|W|AS4", 0 );   // McASP 0 Data
    GEL_MapAddStr( 0x01D0C000, 0, 0x00001000, "R|W|AS4", 0 );   // UART 1
    GEL_MapAddStr( 0x01D0D000, 0, 0x00001000, "R|W|AS4", 0 );   // UART 2
//  GEL_MapAddStr( 0x01D0E000, 0, 0x00001000, "R|W|AS4", 0 );   // IOPU 4
    GEL_MapAddStr( 0x01D10000, 0, 0x00000800, "R|W|AS4", 0 );   // McBSP 0 Control
    GEL_MapAddStr( 0x01D10800, 0, 0x00000200, "R|W|AS4", 0 );   // McBSP 0 FIFO Ctrl
    GEL_MapAddStr( 0x01D11000, 0, 0x00000800, "R|W|AS4", 0 );   // McBSP 1 Control
    GEL_MapAddStr( 0x01D11800, 0, 0x00000200, "R|W|AS4", 0 );   // McBSP 1 FIFO Ctrl
    GEL_MapAddStr( 0x01E00000, 0, 0x00010000, "R|W|AS4", 0 );   // USB0 (USB HS) Cfg
    GEL_MapAddStr( 0x01E10000, 0, 0x00001000, "R|W|AS4", 0 );   // UHPI Cfg
//  GEL_MapAddStr( 0x01E11000, 0, 0x00001000, "R|W|AS4", 0 );   // UHPI (IODFT)
    GEL_MapAddStr( 0x01E13000, 0, 0x00001000, "R|W|AS4", 0 );   // LCD Controller
    GEL_MapAddStr( 0x01E14000, 0, 0x00001000, "R|W|AS4", 0 );   // MPU 1
    GEL_MapAddStr( 0x01E15000, 0, 0x00001000, "R|W|AS4", 0 );   // MPU 2
    GEL_MapAddStr( 0x01E16000, 0, 0x00001000, "R|W|AS4", 0 );   // UPP
    GEL_MapAddStr( 0x01E17000, 0, 0x00001000, "R|W|AS4", 0 );   // VPIF
    GEL_MapAddStr( 0x01E18000, 0, 0x00002000, "R|W|AS4", 0 );   // SATA
    GEL_MapAddStr( 0x01E1A000, 0, 0x00001000, "R|W|AS4", 0 );   // PLL Controller 1
    GEL_MapAddStr( 0x01E1B000, 0, 0x00001000, "R|W|AS4", 0 );   // MMC/SD 1
    GEL_MapAddStr( 0x01E20000, 0, 0x00002000, "R|W|AS4", 0 );   // EMAC CPPI
    GEL_MapAddStr( 0x01E22000, 0, 0x00001000, "R|W|AS4", 0 );   // EMAC CONTROL registers
    GEL_MapAddStr( 0x01E23000, 0, 0x00001000, "R|W|AS4", 0 );   // EMAC registers
    GEL_MapAddStr( 0x01E24000, 0, 0x00001000, "R|W|AS4", 0 );   // EMAC MDIO port
    GEL_MapAddStr( 0x01E25000, 0, 0x00001000, "R|W|AS4", 0 );   // USB1 (USB FS)
    GEL_MapAddStr( 0x01E26000, 0, 0x00001000, "R|W|AS4", 0 );   // GPIO
    GEL_MapAddStr( 0x01E27000, 0, 0x00001000, "R|W|AS4", 0 );   // PSC 1
    GEL_MapAddStr( 0x01E28000, 0, 0x00001000, "R|W|AS4", 0 );   // I2C 1
//  GEL_MapAddStr( 0x01E29000, 0, 0x00001000, "R|W|AS4", 0 );   // IOPU 3
//  GEL_MapAddStr( 0x01E2A000, 0, 0x00001000, "R|W|AS4", 0 );   // PBIST Controller
//  GEL_MapAddStr( 0x01E2B000, 0, 0x00001000, "R|W|AS4", 0 );   // PBIST Combiner
    GEL_MapAddStr( 0x01E2C000, 0, 0x00001000, "R|W|AS4", 0 );   // System Config
    GEL_MapAddStr( 0x01E30000, 0, 0x00008000, "R|W|AS4", 0 );   // TPCC1
    GEL_MapAddStr( 0x01E38000, 0, 0x00000400, "R|W|AS4", 0 );   // TPTC2
    GEL_MapAddStr( 0x01F00000, 0, 0x00001000, "R|W|AS4", 0 );   // EPWM 0
    GEL_MapAddStr( 0x01F01000, 0, 0x00001000, "R|W|AS4", 0 );   // HRPWM 0
    GEL_MapAddStr( 0x01F02000, 0, 0x00001000, "R|W|AS4", 0 );   // EPWM 1
    GEL_MapAddStr( 0x01F03000, 0, 0x00001000, "R|W|AS4", 0 );   // HRPWM 1
    GEL_MapAddStr( 0x01F06000, 0, 0x00001000, "R|W|AS4", 0 );   // ECAP 0
    GEL_MapAddStr( 0x01F07000, 0, 0x00001000, "R|W|AS4", 0 );   // ECAP 1
    GEL_MapAddStr( 0x01F08000, 0, 0x00001000, "R|W|AS4", 0 );   // ECAP 2
//  GEL_MapAddStr( 0x01F0B000, 0, 0x00001000, "R|W|AS4", 0 );   // IOPU 5
    GEL_MapAddStr( 0x01F0C000, 0, 0x00001000, "R|W|AS4", 0 );   // Timer64P 2
    GEL_MapAddStr( 0x01F0D000, 0, 0x00001000, "R|W|AS4", 0 );   // Timer64P 3
    GEL_MapAddStr( 0x01F0E000, 0, 0x00001000, "R|W|AS4", 0 );   // SPI1
    GEL_MapAddStr( 0x01F10000, 0, 0x00001000, "R|W|AS4", 0 );   // McBSP 0 FIFO Data
    GEL_MapAddStr( 0x01F11000, 0, 0x00001000, "R|W|AS4", 0 );   // McBSP 1 FIFO Data
    GEL_TextOut("\tMemory Map Setup Complete.\n","Output",1,1,1);
Set_Core_300MHz() {
/***** ORIGINAL SETUP *******/
  device_PLL0(0,25,2,1,2,3,6);
/***** L&T- DIGITAL BOARD SETUP *******/
//	device_PLL0(1,25,1,1,2,4,6);
    GEL_TextOut("\tPLL0 init done for Core:300MHz, EMIFA:25MHz\n","Output",1,1,1);
Set_Core_200MHz() {
    device_PLL0(0,24,2,0,1,7,3);
    GEL_TextOut("\tPLL0 init done for Core:200MHz, EMIFA:25MHz\n","Output",1,1,1);
Set_Core_100MHz() {
    device_PLL0(0,24,5,0,1,3,1);
    GEL_TextOut("\tPLL0 init done for Core:100MHz, EMIFA:25MHz\n","Output",1,1,1);
Set_DDRPLL_150MHz() {
  //  device_PLL1(24,1,0,1,2);
	device_PLL1(25,1,0,1,2);
    DEVICE_DDRConfig(DDR2, 150);
    GEL_TextOut("\tPLL1 init done for DDR:150MHz\n","Output",1,1,1);
Set_DDRPLL_132MHz() {
    device_PLL1(21,1,0,1,2);
    GEL_TextOut("\tPLL1 init done for DDR:132MHz\n","Output",1,1,1);
Set_DDRPLL_126MHz() {
    device_PLL1(20,1,0,1,2);
    GEL_TextOut("\tPLL1 init done for DDR:126MHz\n","Output",1,1,1);
Set_DDRPLL_102MHz() {
    device_PLL1(16,1,0,1,2);
    GEL_TextOut("\tPLL1 init done for DDR:102MHz\n","Output",1,1,1);
Set_mDDR_150MHz() {
    GEL_TextOut("\tmDDR initialization is in progress....\n","Output",1,1,1);
    Set_DDRPLL_150MHz();
    GEL_TextOut("\tmDDR init for 150 MHz is done\n","Output",1,1,1);
Set_mDDR_132MHz() {
    Set_DDRPLL_132MHz();
    DEVICE_DDRConfig(MDDR, 132);
    GEL_TextOut("\tmDDR init for 132 MHz is done\n","Output",1,1,1);
Set_mDDR_126MHz() {
    Set_DDRPLL_126MHz();
    DEVICE_DDRConfig(MDDR, 126);
    GEL_TextOut("\tmDDR init for 126 MHz is done\n","Output",1,1,1);
Set_mDDR_102MHz() {
    Set_DDRPLL_102MHz();
    DEVICE_DDRConfig(MDDR, 102);
    GEL_TextOut("\tmDDR init for 102 MHz is done\n","Output",1,1,1);
menuitem "Frequency Settings"
hotmenu Core_300MHz_mDDR_150MHz() {
GEL_TextOut("\t ---- JUST BEFORE SETTING CORE FREQ---------------------\n","Output",1,1,1);
    Set_Core_300MHz();
 // Set_mDDR_150MHz();
hotmenu Core_300MHz_mDDR_132MHz() {
    Set_Core_300MHz();
    Set_mDDR_132MHz();
hotmenu Core_200MHz_mDDR_126MHz() {
    Set_Core_200MHz();
    Set_mDDR_126MHz();
hotmenu Core_100MHz_mDDR_102MHz() {
    Set_Core_100MHz();
    Set_mDDR_102MHz();
menuitem "Experimenter"
hotmenu PSC_All_On_Experimenter() {
    GEL_TextOut("\tEnabling Experimenter PSCs...\n","Output",1,1,1);
    // PSC0
    PSC0_LPSC_enable(0, LPSC_EDMA_CC0);
    PSC0_LPSC_enable(0, LPSC_EDMA_TC0);
    PSC0_LPSC_enable(0, LPSC_EDMA_TC1);
    PSC0_LPSC_enable(0, LPSC_SPI0);
    PSC0_LPSC_enable(0, LPSC_MMCSD0);
//  PSC0_LPSC_enable(0, LPSC_ARM_AINTC);
//  PSC0_LPSC_enable(0, LPSC_ARM_RAMROM);
    PSC0_LPSC_enable(0, LPSC_UART0);
    PSC0_LPSC_enable(0, LPSC_SCR0);
    PSC0_LPSC_enable(0, LPSC_SCR1);
    PSC0_LPSC_enable(0, LPSC_SCR2);
    // PSC1
    PSC1_LPSC_enable(0, LPSC_EDMA_CC1);
    PSC1_LPSC_enable(0, LPSC_USB20);
    PSC1_LPSC_enable(0, LPSC_USB11);
    CFGCHIP2 = 0x09F2;  // Enable USB clock, PHY_PLLON, glue logic mux(USB2 ref clk input)
    PSC1_LPSC_enable(0, LPSC_GPIO);
    PSC1_LPSC_enable(0, LPSC_UHPI);
    PSC1_LPSC_enable(0, LPSC_EMAC);
    PSC1_LPSC_enable(0, LPSC_DDR);
    PSC1_LPSC_enable(0, LPSC_MCASP0);
    PSC1_LPSC_force(LPSC_SATA); // Must use force to enable SATA
    PSC1_LPSC_enable(0, LPSC_SATA);
    PSC1_LPSC_enable(0, LPSC_SPI1);
    PSC1_LPSC_enable(0, LPSC_I2C1);
    PSC1_LPSC_enable(0, LPSC_UART1);
    PSC1_LPSC_enable(0, LPSC_UART2);
    PSC1_LPSC_enable(0, LPSC_MCBSP0);
    PSC1_LPSC_enable(0, LPSC_MCBSP1);
    PSC1_LPSC_enable(0, LPSC_EPWM);
    PSC1_LPSC_enable(0, LPSC_MMCSD1);
    PSC1_LPSC_enable(0, LPSC_ECAP);
    PSC1_LPSC_enable(0, LPSC_EDMA_TC2);
    PSC1_LPSC_enable(0, LPSC_SCR_F0);
    PSC1_LPSC_enable(0, LPSC_SCR_F1);
    PSC1_LPSC_enable(0, LPSC_SCR_F2);
    PSC1_LPSC_enable(0, LPSC_SCR_F6);
    PSC1_LPSC_enable(0, LPSC_SCR_F7);
    PSC1_LPSC_enable(0, LPSC_SCR_F8);
    PSC1_LPSC_enable(0, LPSC_BR_F7);
    PSC1_LPSC_enable(0, LPSC_SHARED_RAM);
    GEL_TextOut("\tPSC Enable Complete.\n","Output",1,1,1);
menuitem "Full EVM"
hotmenu PSC_All_On_Full_EVM() {
    // PSC0
    PSC0_LPSC_enable(0, LPSC_EMIFA);
//  PSC0_LPSC_enable(0, LPSC_SCR0);
    // PSC1
    CFGCHIP2 = 0x09F2;  //Enable USB clock, PHY_PLLON, glue logic mux(USB2 ref clk input)
    PSC1_LPSC_enable(0, LPSC_VPIF);
    PSC1_LPSC_enable(0, LPSC_LCDC);
    PSC1_LPSC_enable(0, LPSC_UPP);
    GEL_TextOut("\tPSC Enable Complete FOR EVM.\n","Output",1,1,1);
hotmenu EMIFA_NAND_PINMUX() {
    PINMUX7        = (PINMUX7 & ~0x00FF0FF0) | 0x00110110;
    PINMUX9        = 0x11111111;
    PINMUX12       = (PINMUX12 & ~0x0FF00000) | 0x01100000;
    EMIFA_ACFG2  &= ~0x1; // 8-bit
    EMIFA_NANDFCR = (EMIFA_NANDFCR & ~0x30) | 0x12;
    // Set OE Low
    PINMUX6         = (PINMUX6 & ~0x000000F0) | 0x00000080;
    GPIO_BANK23_DIR = (GPIO_BANK23_DIR & ~(1 << 6));
    GPIO_BANK23_CLR = (1 << 6);
    GEL_TextOut("\tEMIFA Pins Configured for NAND.\n","Output",1,1,1);
hotmenu EMIFA_NOR_PINMUX() {
    PINMUX5       = (PINMUX5 & ~0xFF000000) | 0x11000000;
    PINMUX6       = (PINMUX6 & ~0x0F00000F) | 0x01000001;
    PINMUX7       = (PINMUX7 & ~0x00FF000F) | 0x00110001;
    PINMUX8       = 0x11111111;
    PINMUX10      = 0x11111111;
    PINMUX11      = 0x11111111;
    PINMUX12      = 0x11111111;
    EMIFA_ACFG2 |= 0x1; // 16-bit
    GEL_TextOut("\tEMIFA Pins Configured for NOR.\n","Output",1,1,1);
hotmenu SPI1_PINMUX() {
    PINMUX5 = (PINMUX5 & ~0x00FF0FF0) | 0x00110110;
    GEL_TextOut("\tSPI1 Pins Configured.\n","Output",1,1,1);
   Device_PLL0 init:
   CLKMODE -  0---->On Chip Oscilator  1---->External Oscilator
   PLL0_SYSCLK1 - Not used on Freon subchip, fixed divider (/1) - allow to change div1
   PLL0_SYSCLK2 - Used on Freon subchip, but it has a fixed divider ratio to SYSCLK1(/2) - should be used for sc ASYNC3 domain
                  to simplify clock management for peripherals during the ROM boot loader CFGCHIP3[ASYNC3_CLKSRC] - configure with div1
   PLL0_SYSCLK3 - Variable Divider, not used on Freon subchip, but ASYNC1 (EMIFA) on matrix - treat same as in Primus (configure)
   PLL0_SYSCLK4 - Used on Freon subchip, but it has a fixed ratio to div1 (/4) - configure with div1
   PLL0_SYSCLK5 - Variable divider, not used on Freon subchip - do nothing
   PLL0_SYSCLK6 - Not used on Freon subchip, fixed ratio to div1 (/1) - configure with div1
   PLL0_SYSCLK7 - Variable divider, is used on Freon subchip (Test, RMII, possibly USB 1.1) - treat the same as on Primus (configure)
   PLL0_SYSCLK8 - Variable divider, not used on Freon subchip - treat same as in Primus (do nothing)
   PLL0_SYSCLK9 - Variable divider, used on Freon subchip (test) - treat same as in Primus (do nothing)
   DIV4p5CLOCK  - Not used on Freon, can be used in in EMIFA on matrix - treat same as in Primus - configure in EMIF setups, not here
device_PLL0(unsigned int CLKMODE, unsigned int PLLM, unsigned int POSTDIV,unsigned int PLLDIV1, unsigned int PLLDIV2, unsigned int PLLDIV3, unsigned int PLLDIV7 ) {
	unsigned int i;
   /* Clear PLL lock bit */
    CFGCHIP0 &= ~(0x00000010);
	GEL_TextOut("\t---INSIDE CORE SETTING FUNCTION------------\n","Output",1,1,1);
   /* Set PLLENSRC '0',bit 5, PLL Enable(PLLEN) selection is controlled through MMR */
   PLL0_PLLCTL &= ~(0x00000020);
   /* PLLCTL.EXTCLKSRC bit 9 should be left at 0 for Freon */
   PLL0_PLLCTL &= ~(0x00000200);
   /* Set PLLEN=0 to put in bypass mode*/
   PLL0_PLLCTL &= ~(0x00000001);
   /*wait for 4 cycles to allow PLLEN mux switches properly to bypass clock*/
   for(i=0; i<PLLEN_MUX_SWITCH; i++) {;}
   /* Select the Clock Mode bit 8 as External Clock or On Chip Oscilator*/
   PLL0_PLLCTL &= 0xFFFFFEFF;
   PLL0_PLLCTL |= (CLKMODE << 8);
   /*Clear PLLRST bit to reset the PLL */
   PLL0_PLLCTL &= ~(0x00000008);
   /* Disable the PLL output*/
   PLL0_PLLCTL |= (0x00000010);
   /* PLL initialization sequence
   Power up the PLL by setting PWRDN bit set to 0 */
   PLL0_PLLCTL &= ~(0x00000002);
   /* Enable the PLL output*/
   PLL0_PLLCTL &= ~(0x00000010);
   /*PLL stabilisation time- take out this step , not required here when PLL in bypassmode*/
   for(i=0; i<PLL_STABILIZATION_TIME; i++) {;}
   /*Program the required multiplier value in PLLM*/
   PLL0_PLLM    = PLLM; /* Make PLLMULTIPLEIR as bootpacket*/
   /*If desired to scale all the SYSCLK frequencies of a given PLLC, program the POSTDIV ratio*/
   PLL0_POSTDIV = 0x8000 | POSTDIV; /* Make POSTDIV as bootpacket*/
   /*Check for the GOSTAT bit in PLLSTAT to clear to 0 to indicate that no GO operation is currently in progress*/
   while(PLL0_PLLSTAT & 0x1==1){}
   /*Program the RATIO field in PLLDIVx with the desired divide factors. In addition, make sure in this step you leave the PLLDIVx.DxEN bits set so clocks are still enabled (default).*/
   PLL0_PLLDIV1 = 0x8000 | PLLDIV1;   /* Make PLLDIV1 as bootpacket, do it for other PLLDIVx to if required*/
   PLL0_PLLDIV2 = 0x8000 | PLLDIV2;
   PLL0_PLLDIV4 = 0x8000 | (((PLLDIV1+1)*4)-1);
   PLL0_PLLDIV6 = 0x8000 | PLLDIV1;
   PLL0_PLLDIV3 = 0x8000 | PLLDIV3;   /* Make PLLDIV3 as bootpacket, do it for other PLLDIVx to if required*/
   PLL0_PLLDIV7 = 0x8000 | PLLDIV7;   /* Make PLLDIV7 as bootpacket, do it for other PLLDIVx to if required*/
   /*Set the GOSET bit in PLLCMD to 1 to initiate a new divider transition.*/
   PLL0_PLLCMD |= 0x1;
   /*Wait for the GOSTAT bit in PLLSTAT to clear to 0 (completion of phase alignment).*/
   while(PLL0_PLLSTAT & 0x1==1) { }
   /*Wait for PLL to reset properly. See PLL spec for PLL reset time - This step is not required here -step11*/
   for(i=0; i<PLL_RESET_TIME_CNT; i++) {;}   /*128 MXI Cycles*/
   /*Set the PLLRST bit in PLLCTL to 1 to bring the PLL out of reset*/
   PLL0_PLLCTL |= 0x8;
   /*Wait for PLL to lock. See PLL spec for PLL lock time*/
   for(i=0; i<PLL_LOCK_TIME_CNT; i++) {;} /*Make PLL_LOCK_TIME_CNT as boot Packet*/
   /*Set the PLLEN bit in PLLCTL to 1 to remove the PLL from bypass mode*/
   PLL0_PLLCTL |=  0x1;
   /* SET PLL lock bit*/
   CFGCHIP0 |= (0x1 << 4) & 0x00000010;
DDR PLL1 init:
device_PLL1(unsigned int PLLM,unsigned int POSTDIV,unsigned int PLLDIV1, unsigned int PLLDIV2, unsigned int PLLDIV3 ) {
   unsigned int i=0;
   CFGCHIP3 &= ~(0x00000020);
   PLL1_PLLCTL &= ~(0x00000020);
   PLL1_PLLCTL &= ~(0x00000200);
   PLL1_PLLCTL &= ~(0x00000001);
   PLL1_PLLCTL &= ~(0x00000008);
   PLL1_PLLCTL |= (0x00000010);
   PLL1_PLLCTL &= ~(0x00000002);
   PLL1_PLLCTL &= ~(0x00000010);
   PLL1_PLLM    = PLLM; /* Make PLLMULTIPLEIR as bootpacket*/
   PLL1_POSTDIV = 0x8000 | POSTDIV; /* Make POSTDIV as bootpacket*/
   while(PLL1_PLLSTAT & 0x1==1){}
   PLL1_PLLDIV1 = 0x8000 | PLLDIV1;   /* Make PLLDIV1 as bootpacket, do it for other PLLDIVx to if required*/
   PLL1_PLLDIV2 = 0x8000 | PLLDIV2;   /* Make PLLDIV2 as bootpacket, do it for other PLLDIVx to if required*/
   PLL1_PLLDIV3 = 0x8000 | PLLDIV3;   /* Make PLLDIV3 as bootpacket, do it for other PLLDIVx to if required*/
   PLL1_PLLCMD |= 0x1;
   while(PLL1_PLLSTAT & 0x1==1) { }
   /*Wait for PLL to reset properly. See PLL spec for PLL reset time - */
   PLL1_PLLCTL |= 0x8;
   PLL1_PLLCTL |=  0x1;
   CFGCHIP3 |= (0x1 << 5) & 0x00000020;
Device Kick Unlock:
    Kick0 register + data (unlock)
    Kick1 register + data (unlock)
DEVICE_kickUnlock() {
   KICK0R = 0x83e70b13;  // Kick0 register + data (unlock)
   KICK1R = 0x95a4f1e0;  // Kick1 register + data (unlock)
  PSC Common functions :
/*Force module state without handshaking */
PSC1_LPSC_force(unsigned int LPSC_num) {
    *(unsigned int*) (PSC1_MDCTL+4*LPSC_num) = (*(unsigned int*) (PSC1_MDCTL+4*LPSC_num) | 0x80000000);
/*SyncReset Function for PSC1*/
PSC1_LPSC_SyncReset(unsigned int PD, unsigned int LPSC_num) {
    unsigned int j;
    if( (*(unsigned int*)(PSC1_MDSTAT+4 * LPSC_num) & 0x1F) != 0x1 ) {
      *(unsigned int*) (PSC1_MDCTL+4*LPSC_num) = (*(unsigned int*) (PSC1_MDCTL+4*LPSC_num) & 0xFFFFFFE0) | 0x0001;
      PSC1_PTCMD = 0x1<<PD;
      j = 0;
      /*Wait for power state transition to finish*/
      while( (PSC1_PTSTAT & (0x1<<PD) ) !=0) {
        if( j++ > PSC_TIMEOUT ) {
          GEL_TextOut("\tPSC1 Sync Reset Transition Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
      j = 0;
      while( (*(unsigned int*)(PSC1_MDSTAT+4 * LPSC_num) & 0x1F) !=0x1) {
          GEL_TextOut("\tPSC1 Sync Reset Verify Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
/*Enable Function for PSC1*/
PSC1_LPSC_enable(unsigned int PD, unsigned int LPSC_num) {
    unsigned int j;
    if( (*(unsigned int*)(PSC1_MDSTAT+4 * LPSC_num) & 0x1F) != 0x3 ) {
      *(unsigned int*) (PSC1_MDCTL+4*LPSC_num) = (*(unsigned int*) (PSC1_MDCTL+4*LPSC_num) & 0xFFFFFFE0) | 0x0003;
      j = 0;
          GEL_TextOut("\tPSC1 Enable Transition Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
      j = 0;
      while( (*(unsigned int*)(PSC1_MDSTAT+4 * LPSC_num) & 0x1F) !=0x3) {
          GEL_TextOut("\tPSC1 Enable Verify Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
/*LPSC Enable Function for ARM or DSP*/
PSC0_LPSC_enableCore(unsigned int PD, unsigned int LPSC_num) {
    unsigned int j;
    if( (*(unsigned int*)(PSC0_MDSTAT+4 * LPSC_num) & 0x11F) != 0x103 ) {
      *(unsigned int*) (PSC0_MDCTL+4*LPSC_num) = (*(unsigned int*) (PSC0_MDCTL+4*LPSC_num) & 0xFFFFFEE0) | 0x0103;
      PSC0_PTCMD = 0x1<<PD;
      j = 0;
      while( (PSC0_PTSTAT & (0x1<<PD) ) !=0) {
          GEL_TextOut("\tPSC0 Enable Core Transition Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
      j = 0;
      while( (*(unsigned int*)(PSC0_MDSTAT+4 * LPSC_num) & 0x11F) !=0x103) {
          GEL_TextOut("\tPSC0 Enable Core Verify Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
/*SyncReset Function for PSC0*/
PSC0_LPSC_SyncReset(unsigned int PD, unsigned int LPSC_num) {
    unsigned int j;
    if( (*(unsigned int*)(PSC0_MDSTAT+4 * LPSC_num) & 0x1F) != 0x1 ) {
      *(unsigned int*) (PSC0_MDCTL+4*LPSC_num) = (*(unsigned int*) (PSC0_MDCTL+4*LPSC_num) & 0xFFFFFFE0) | 0x0001;
      j = 0;
          GEL_TextOut("\tPSC0 Sync Reset Transition Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
      j = 0;
      while( (*(unsigned int*)(PSC0_MDSTAT+4 * LPSC_num) & 0x1F) !=0x1) {
          GEL_TextOut("\tPSC0 Sync Reset Verify Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
/*Enable Function for PSC0*/
PSC0_LPSC_enable(unsigned int PD, unsigned int LPSC_num) {
    unsigned int j;
    if( (*(unsigned int*)(PSC0_MDSTAT+4 * LPSC_num) & 0x1F) != 0x3 ) {
      *(unsigned int*) (PSC0_MDCTL+4*LPSC_num) = (*(unsigned int*) (PSC0_MDCTL+4*LPSC_num) & 0xFFFFFFE0) | 0x0003;
      j = 0;
          GEL_TextOut("\tPSC0 Enable Transition Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
      j = 0;
      while( (*(unsigned int*)(PSC0_MDSTAT+4 * LPSC_num) & 0x1F) !=0x3) {
          GEL_TextOut("\tPSC0 Enable Verify Timeout on Domain %d, LPSC %d\n","Output",1,1,1,PD,LPSC_num);
          break;
  DDR Configuration routine:
    1. DDR Enable
    2. VTP calibration
    3. Configure DDR
    4. Set to self-refresh, enable mclkstop and DDR Sync Reset
    5. Enable DDR and disable self-refresh
  int freq is MHz
  DDR2 = 0
  MDDR = 1
  A DDR configuration spreadsheet tool is located here:
    http://processors.wiki.ti.com/index.php/Programming_mDDR/DDR2_EMIF_on_OMAP-L1x/C674x
DEVICE_DDRConfig(unsigned int ddr_type, unsigned int freq)
    unsigned int j;
    unsigned int tmp_SDCR=0x00134A22;
    // Enable the Clock to EMIFDDR SDRAM
    PSC1_LPSC_enable(PD0, LPSC_DDR);
    // Begin VTP Calibration
    VTPIO_CTL &= ~0x00000040;       // Clear POWERDN
    VTPIO_CTL &= ~0x00000080;       // Clear LOCK
    VTPIO_CTL |=  0x00002000;       // Set CLKRZ in case it was cleared before (VTP looks for CLKRZ edge transition)
    VTPIO_CTL &= ~0x00002000;       // Clear CLKRZ (Use read-modify-write to ensure 1 VTP cycle wait for previous instruction)
    VTPIO_CTL |=  0x00002000;       // Set CLKRZ (Use read-modify-write to ensure 1 VTP cycle wait for previous instruction)
    j = 0;
    // Polling READY bit to see when VTP calibration is done
    while((VTPIO_CTL & 0x00008000) == 0) {
      if( j++ > VTP_TIMEOUT ) {
        GEL_TextOut("\tVTP Ready timeout\n","Output",1,1,1);
        break;
    VTPIO_CTL |= 0x00000080;       // Set LOCK bit for static calibration mode
    VTPIO_CTL |= 0x00000040;       // Set POWERDN bit to power down VTP module
    // End VTP Calibration
    VTPIO_CTL |= 0x00004000;       // Set IOPWRDN to allow powerdown of input receivers when PWRDNEN is set
    // Setting based on the looser of 512Mb mDDR MT46H32M16LFBF-6,
    //                                  1Gb mDDR MT46H64M16LF-6, or
    //                                  1Gb mDDR MT46H64M16LFBF-6 on EVM
    // Config DDR timings
    DRPYC1R     = (0x0               << 8)   |  // Reserved
                  (0x1               << 7)   |  // EXT_STRBEN
                  (0x1               << 6)   |  // PWRDNEN
                  (0x0               << 3)   |  // Reserved
                  (0x4               << 0);     // RL
    // DRPYC1R Value = 0x000000C4
    if( DDR_DEBUG ) {
      // Configure EMIF with max timings for more slack
      // Try this if memory is not stable
      DRPYC1R  |=  0x7; // RL
    EMIFDDR_SDCR |= 0x00800000; // Set BOOTUNLOCK
    // Settings that change depending on DDR2 or MDDR
    if( ddr_type == DDR2 ) {
      tmp_SDCR = (0x0               << 25)  |  // MSDRAMEN
                 (0x1               << 20);    // DDR2EN
      GEL_TextOut("\tUsing DDR2 settings\n","Output",1,1,1);
    else if( ddr_type == MDDR ) {
      tmp_SDCR = (0x1               << 25)  |  // MSDRAMEN
                 (0x0               << 20);    // DDR2EN
      GEL_TextOut("\tUsing mDDR settings\n","Output",1,1,1);
    else {
      GEL_TextOut("\tUnknown DDR Type!  Using MDDR settings\n","Output",1,1,1);
    EMIFDDR_SDCR = tmp_SDCR                    |  // Settings that change depending on DDR2 or MDDR
                   (EMIFDDR_SDCR & 0xF0000000) |  // Reserved
                   (0x0               << 27)   |  // DDR2TERM1
                   (0x0               << 26)   |  // IBANK_POS
                   (0x0               << 24)   |  // DDRDRIVE1
                   (0x0               << 23)   |  // BOOTUNLOCK
                   (0x0               << 22)   |  // DDR2DDQS
                   (0x0               << 21)   |  // DDR2TERM0
                   (0x0               << 19)   |  // DDRDLL_DIS
                   (0x0               << 18)   |  // DDRDRIVE0
                   (0x1               << 17)   |  // DDREN
                   (0x1               << 16)   |  // SDRAMEN
                   (0x1               << 15)   |  // TIMUNLOCK
                   (0x1               << 14)   |  // NM
                   (0x0               << 12)   |  // Reserved
                   (0x3               << 9)    |  // CL
                   (0x0               << 7)    |  // Reserved
                   (0x2               << 4)    |  // IBANK
                   (0x2               << 0);      // PAGESIZE
    // mDDR SDCR Value = 0x02034622
      EMIFDDR_SDCR2   = 0x00000000; // IBANK_POS set to 0 so this register does not apply
    if( DDR_DEBUG ) {
      EMIFDDR_SDTIMR1 = (0x7F << 25)             |  // tRFC
                        (0x07 << 22)             |  // tRP
                        (0x07 << 19)             |  // tRCD
                        (0x07 << 16)             |  // tWR
                        (0x1F << 11)             |  // tRAS
                        (0x1F << 6)              |  // tRC
                        (0x07 << 3)              |  // tRRD
                        (EMIFDDR_SDTIMR1 & 0x4)  |  // Reserved
                        (0x03 << 0);                // tWTR
      EMIFDDR_SDTIMR2 = (EMIFDDR_SDTIMR2 & 0x80000000)                       |  // Reserved
                        (((unsigned int) ((70000 / 7812.5) - 0.5))  << 27)   |  // tRASMAX
                        (0x3                                        << 25)   |  // tXP
                        (0x0                                        << 23)   |  // tODT (Not supported)
                        (0x7F                                       << 16)   |  // tXSNR
                        (0xFF                                       << 8)    |  // tXSRD
                        (0x07                                       << 5)    |  // tRTP (1 Cycle)
                        (0x1F                                       << 0);      // tCKE
      // SDTIMR1 Value = 0xFFFFFFFB
      // SDTIMR2 Value = 0x467FFFFF
      GEL_TextOut("\tDDR Timings Configured for Debug\n","Output",1,1,1);
    else {
      // Let float -> integer truncate handle minus 1; Safer to round up for timings
      EMIFDDR_SDTIMR1 = (((unsigned int) (110.0 * freq / 1000))  << 25)  |  // tRFC
                        (((unsigned int) ( 18.0 * freq / 1000))  << 22)  |  // tRP
                        (((unsigned int) ( 18.0 * freq / 1000))  << 19)  |  // tRCD
                        (((unsigned int) ( 15.0 * freq / 1000))  << 16)  |  // tWR
                        (((unsigned int) ( 42.0 * freq / 1000))  << 11)  |  // tRAS
                        (((unsigned int) ( 60.0 * freq / 1000))  << 6)   |  // tRC
                        (((unsigned int) ( 12.0 * freq / 1000))  << 3)   |  // tRRD
                        ((2 - 1)                                 << 0);     // tWTR
                        (((unsigned int) ((70000 / 7812.5) - 1)) << 27)   |  // tRASMAX
                        (0x3                                     << 25)   |  // tXP (Should be 6-1 per MT46H64M16LFBF-6 datasheet, but field only goes up to 0b11)
                        (((unsigned int) (138.0 * freq / 1000))  << 16)   |  // tXSNR (tXSR for mDDR)
                        (((unsigned int) (138.0 * freq / 1000))  << 8)    |  // tXSRD (tXSR for mDDR)
                        ((2 - 1)                                 << 5)    |  // tRTP
                        ((1 - 1)                                 << 0);      // tCKE
      // SDTIMR1 Value @ 150MHz = 0x20923249
      // SDTIMR2 Value @ 150MHz = 0x3E141420
    EMIFDDR_SDCR    &= ~0x00008000; // Clear TIMUNLOCK
    // Let float -> integer truncate handle RR round-down; Safer to round down for refresh rate
    EMIFDDR_SDRCR   = (0x1                                  << 31)  |  // LPMODEN (Required for LPSC SyncReset/Enable)
                      (0x1                                  << 30)  |  // MCLKSTOPEN (Required for LPSC SyncReset/Enable)
                      (0x0                                  << 24)  |  // Reserved
                      (0x0                                  << 23)  |  // SR_PD
                      (0x0                                  << 16)  |  // Reserved
                      (((unsigned int) (7.8125 * freq))     << 0);     // RR
    // SyncReset the Clock to EMIFDDR SDRAM
    PSC1_LPSC_SyncReset(PD0, LPSC_DDR);
    // Disable self-refresh
    EMIFDDR_SDRCR &= ~0xC0000000;
    // SDRCR Value @ 150MHz = 0x00000493
    // Set PBBPR to a value lower than default to prevent blocking
    EMIFDDR_PBBPR = 0x30;
The GEL is haveing  some errors because of which i am getting the following error :
C674X_0: Output:     Memory Map Cleared.
C674X_0: Output:     ---------------------------------------------
C674X_0: Output:     Memory Map Setup Complete.
C674X_0: Output:      I AM IN PRE FILE LOAD -------------
C674X_0: Output:     PSC Enable Complete.
C674X_0: Trouble Reading Memory Block at 0x1c1417c on Page 0 of Length 0x4: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Release 5.0.333.0)
C674X_0: GEL: Error calling OnPreFileLoaded(): Target failed to read memory at 0x01C1417C
C674X_0: Trouble Reading Memory Block at 0x80000000 on Page 0 of Length 0x4: (Error -1178 @ 0x64) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
C674X_0: File Loader: Data verification failed at address 0x80000000 Please verify target memory and memory map.
Error found during data verification.
Ensure the linker command file matches the memory map.
C674X_0: Trouble Reading Register CSR: (Error -1178 @ 0x41) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
C674X_0: Trouble Reading Memory Block at 0x700000 on Page 0 of Length 0x41: (Error -1178 @ 0x700000) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
C674X_0: Trouble Reading Memory Block at 0x700000 on Page 0 of Length 0x281: (Error -1178 @ 0x700000) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
  • Sandy,
    You said you have checked power levels. Have you also checked clocks and resets and confirmed that they all are stable or applied/released according to the device datasheet and the hardware design guide?
    Find out from the documentation which module is related to the register at the address specified (0x1c1417c) and make sure it has been properly enabled in the GEL script.
    Do you ahve a TI-supplied GEL script that can be compared to yours for differences that could explain this failure?
    RandyP
    If you need more help, please reply back. If this answers the question, please click  Verify Answer  , below.
  • Hi Randy,
    I downloaded the latest GeL file for TMS320C6748. I checked the entire memory mapping and everything appears to be correct. I made the following modification
    1) Inside function: Set_mDDR_150MHz()
     GEL_TextOut("\tDDR initialization is in progress....\n","Output",1,1,1);
    2)I changed the above lines because we have a DDR2 interface:MT47H32M16
    3)I got the following in Debug window:
    C674X_0: Output:               Target Connected.
    C674X_0: Output:               KICK Unlocked.
    C674X_0: Output:               PLL0 init done for Core:300MHz, EMIFA:25MHz
    C674X_0: Output:               DDR initialization is in progress....
    C674X_0: Trouble Reading Memory Block at 0x1c14188 on Page 0 of Length 0x4: (Error -1178 @ 0x1C14188) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
    C674X_0: GEL: Error while executing OnTargetConnect(): Target failed to read memory at 0x01C14188.
    C674X_0: Trouble Reading Memory Block at 0x11800000 on Page 0 of Length 0x4: (Error -1178 @ 0x64) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
    C674X_0: File Loader: Data verification failed at address 0x11800000 Please verify target memory and memory map.
    C674X_0: Trouble Reading Memory Block at 0x7f4d2c on Page 0 of Length 0x241: (Error -1178 @ 0x7F4D2C) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Release 5.0.333.0)
     4)All power supply, Clock Signals are Ok. Reset Pin is pulled high
    5)I also tried with slower JTAG clock but the result was same.
    6)I checked out 0x1c14188. It corresponds to “CFGCHIP3”.  It is found it in the function:
         unsigned int i=0;
    This should not create any issue but I don’t know why it’s creating problem. I am stuck. How do I debug it?
    The GEL File is attached here:
    #define PLL0_PLLSTAT    *(unsigned int*) (PLL0_BASE + 0x13C)    /*Status Reg*/
    #define PSC_TIMEOUT      200 // This value can be optimized by the user
    // LPSC #6 not used
    // LPSC #7 not used
    // LPSC #8 not used
    // LPSC #13 not used
    // LPSC #14 not used
    #define LPSC_UPP         19
    #define VTPIO_CTL           *(unsigned int*)(0x01E2C000)                    //VTPIO_CTL Register
    #define DDR_SLEW            *(unsigned int*)(0x01E2C004)                    //DDR_SLEW Register
    #define EMIFDDR_SDRSTAT     *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x04)      //SDRAM Status Register
    #define EMIFDDR_SDCR        *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x08)      //SDRAM Bank Config Register
    #define EMIFDDR_SDRCR       *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x0C)      //SDRAM Refresh Control Register
    #define EMIFDDR_SDTIMR1     *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x10)      //SDRAM Timing Register1
    #define EMIFDDR_SDTIMR2     *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x14)      //SDRAM Timing Register2
    #define EMIFDDR_SDCR2       *(unsigned int*)(EMIFDDR_SDRAM_CFG + 0x1C)      //SDRAM Config Register2
    #define DDR2 0              // Do not change this value
    #define MDDR 1              // Do not change this value
    #define VTP_TIMEOUT 200     // This value can be optimized by the user
    #define DDR_DEBUG 0         // Set this to "1" to program DDR with more timing slack
    /*GPIO MMR*/
    OnTargetConnect( )
        GEL_TextOut("\tTarget Connected.\n","Output",1,1,1);
        Clear_Memory_Map();
        Setup_Memory_Map();
        DEVICE_kickUnlock(); // No longer needed for Si Rev 2.0+
        GEL_MapOff( );
        GEL_MapReset( );
        GEL_MapOn( );
        GEL_MapReset( );
        /* DSP */
        /* Shared RAM */
        /* EMIFA */
        /* DDR */
        /* Peripherals */
    Set_Core_300MHz() {
        device_PLL0(0,24,1,0,1,11,5);
    Set_Core_200MHz() {
    Set_Core_100MHz() {
    Set_mDDR_150MHz() {
     //   GEL_TextOut("\tmDDR initialization is in progress....\n","Output",1,1,1);
    Set_mDDR_132MHz() {
    Set_mDDR_126MHz() {
    Set_mDDR_102MHz() {
        Set_Core_300MHz();
        Set_mDDR_150MHz();
        Set_Core_300MHz();
        Set_mDDR_132MHz();
        Set_Core_200MHz();
        Set_mDDR_126MHz();
        Set_Core_100MHz();
        Set_mDDR_102MHz();
        // PSC0
        // PSC1
    menuitem "Full EVM"
        // PSC0
        // PSC1
        // Set OE Low
       Device_PLL0 init:
       PLL0_SYSCLK1 - Fixed ratio /1
       PLL0_SYSCLK2 - Fixed ratio /2
       PLL0_SYSCLK3 - Variable Divider (EMIFA)
       PLL0_SYSCLK4 - Fixed ratio /4
       PLL0_SYSCLK5 - Not used -- do nothing
       PLL0_SYSCLK6 - Fixed ratio /1
       PLL0_SYSCLK7 - Variable Divider (RMII)
        unsigned int i=0;
        PLL0_PLLM    = PLLM;
        PLL0_PLLDIV1 = 0x8000 | PLLDIV1;             // Fixed Ratio /1
        PLL0_PLLDIV2 = 0x8000 | PLLDIV2;             // Fixed Ratio /2
        PLL0_PLLDIV4 = 0x8000 | (((PLLDIV1+1)*4)-1); // Fixed Ratio /4
        PLL0_PLLDIV6 = 0x8000 | PLLDIV1;             // Fixed Ratio /1
        PLL0_PLLDIV3 = 0x8000 | PLLDIV3;             // Variable Ratio (EMIF)
        PLL0_PLLDIV7 = 0x8000 | PLLDIV7;             // Variable Ratio (RMII)
        PLL0_PLLCMD |= 0x1;
        /*Wait for PLL to reset properly.*/
        PLL0_PLLCTL |= 0x8;
        /*Wait for PLL to lock.*/
        PLL0_PLLCTL |=  0x1;
    DDR PLL1 init:
        unsigned int i=0;
        PLL1_PLLM    = PLLM;
        PLL1_PLLDIV1 = 0x8000 | PLLDIV1;   // DDR frequency (aka 2X_CLK)
        PLL1_PLLDIV2 = 0x8000 | PLLDIV2;   // Optional CFGCHIP3[ASYNC3_CLKSRC] clock source
        PLL1_PLLDIV3 = 0x8000 | PLLDIV3;   // Optional PLL0 clock source
        PLL1_PLLCMD |= 0x1;
        /*Wait for PLL to reset properly */
        PLL1_PLLCTL |= 0x8;
        PLL1_PLLCTL |=  0x1;
    Device Kick Unlock:
        GEL_TextOut("\tKICK Unlocked.\n","Output",1,1,1);
        unsigned int j;
          j = 0;
              break;
          j = 0;
              break;
        unsigned int j;
          j = 0;
              break;
          j = 0;
              break;
    /*LPSC Enable Function for DSP*/
        unsigned int j;
          j = 0;
              break;
          j = 0;
              break;
        unsigned int j;
          j = 0;
              break;
          j = 0;
              break;
        unsigned int j;
          j = 0;
              break;
          j = 0;
              break;
        1. DDR Enable
        2. VTP calibration
        3. Configure DDR
      int freq is MHz
      DDR2 = 0
      MDDR = 1
        unsigned int j;
        unsigned int tmp_SDCR;
        j = 0;
            break;
                      (0x4               << 0);     // RL
        if( DDR_DEBUG ) {
          DDR_SLEW = 0x00000000;                   // Disable Pull Downs, Disable LVCMOS Rx
          DDR_SLEW = 0x00000030;                   // Enable Pull Downs, Enable LVCMOS Rx
        else {
                       (0x1               << 14)   |  // NM
                       (0x3               << 9)    |  // CL
        if( DDR_DEBUG ) {
        else {
    Problem Solved. Thanks a lot for all your valuable suggestion.
    In our Board a Ferrite Bead was not populated.
    1.2V supply was not available at pin - PLL0_VDDA12 & PLL1_VDDA12 . After mounting the ferrite bead on the board DDR2 was detected.
    I have one more query.
    The GEL file mentions about a link to configure DDR
    The values computed out of this spreadsheet are not used in GEL file.  What is its utility them?
    Sandeep
  • Sandeep,
    Good news. Small problems can be difficult to find. Good jub with this one.
    I have no idea why the values out of the spreadsheet are not used in the GEL file. Any of the possibilities you can imagine may be correct. For your board, please follow the suggestions in the TI Wiki page.
    RandyP
