DRA821U-Q1: DRA821U2-Q1
Part Number: DRA821U-Q1
Can I use different driver strength for chip selection from address lines when I do the DDR SI simulation?
Max
  • Hello, Due to the year-end holiday, there will be a delayed response on this topic. Please expect a response in the new year. Thank you for understanding.
    On physical hardware, it is possible to set the drive strength of the DDR chip select IO different compared to the DDR address IO, so there is no concern if you simulate using different drive strength settings for chip select and address.
    Kevin
