Part Number: TMS320C6748
Customer plant to use TMS320C6748EZCEA3 and start the board assembly. They want to know following BGA spec.
Could you answer it?
Could you answer
BGA Solder Joint Geometry
(A)Ball size(Diameter) ( mm)
(B)Solder Mask Opening ( mm)
(C)BGA PAD Diameter ( mm)
PCB Dimension Recommendations
(D)PCB PAD Diameter ( mm)
(E)PCB solder Mask Oper ( mm)
Could you support it?
Thanks and best regards,
Daisuke Nomura
