BYTES-3P-BE-AM6254: Failed to change cpu frequency - error
Part Number: BYTES-3P-BE-AM6254
Hello TI,
I am currently working on AM6254ATGFHIAMCRQ1, after the boot up process i am getting continuous error which is attached below,
[   60.616265] cpufreq: __target_index: Failed to change cpu frequency: -34
[   61.010427] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   61.018651] cpufreq: __target_index: Failed to change cpu frequency: -34
[   61.413177] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   61.421551] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.517427] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.525514] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.540541] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.548777] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.717356] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.725589] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.750272] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.758456] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.965640] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.973949] cpufreq: __target_index: Failed to change cpu frequency: -34
[   92.178786] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   92.187026] cpufreq: __target_index: Failed to change cpu frequency: -34
[   92.817851] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   92.826155] cpufreq: __target_index: Failed to change cpu frequency: -34
[   93.239507] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   93.247674] cpufreq: __target_index: Failed to change cpu frequency: -34
[   94.738596] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   94.746863] cpufreq: __target_index: Failed to change cpu frequency: -34
[   95.747298] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   95.755384] cpufreq: __target_index: Failed to change cpu frequency: -34
[   96.658580] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   96.666776] cpufreq: __target_index: Failed to change cpu frequency: -34
[   96.993591] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   97.001652] cpufreq: __target_index: Failed to change cpu frequency: -34
[   97.937477] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   97.945755] cpufreq: __target_index: Failed to change cpu frequency: -34
[   98.247538] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   98.255609] cpufreq: __target_index: Failed to change cpu frequency: -34
[   99.216638] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   99.224859] cpufreq: __target_index: Failed to change cpu frequency: -34
[  100.072273] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[  100.080494] cpufreq: __target_index: Failed to change cpu frequency: -34
[  100.739521] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[  100.747674] cpufreq: __target_index: Failed to change cpu frequency: -34
[  100.867933] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
like this i am getting error, so what is actual problem, and what are the approaches need to be try?
Sridhar
