Other Parts Discussed in Thread: TDA4VH, PCM3168A
Hi experts,
I'm currently using TDA4VH SDK9.2 on EVM Board. However, the Linux audio driver is not supported in SDK9.2.
I've ported some dts- related modifications from SDK10.0 to SDK9.2, as shown below.
My device tree:
// SPDX-License-Identifier: GPL-2.0
* Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/
* EVM Board Schematics: https://www.ti.com/lit/zip/sprr458
/dts-v1/;
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/gpio/gpio.h>
#include "k3-j784s4.dtsi"
compatible = "ti,j784s4-evm", "ti,j784s4";
model = "Texas Instruments J784S4 EVM";
chosen {
stdout-path = "serial2:115200n8";
aliases {
serial0 = &wkup_uart0;
serial1 = &mcu_uart0;
serial2 = &main_uart8;
mmc0 = &main_sdhci0;
mmc1 = &main_sdhci1;
i2c0 = &main_i2c0;
memory@80000000 {
device_type = "memory";
/* 32G RAM */
reg = <0x00 0x80000000 0x00 0x80000000>,
<0x08 0x80000000 0x07 0x80000000>;
reserved_memory: reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
/* global cma region */
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x00 0x70000000>;
linux,cma-default;
secure_ddr: optee@9e800000 {
reg = <0x00 0x9e800000 0x00 0x01800000>;
no-map;
mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
reg = <0x00 0xa0000000 0x00 0x100000>;
no-map;
mcu_r5fss0_core0_memory_region: r5f-memory@a0100000 {
reg = <0x00 0xa0100000 0x00 0xf00000>;
no-map;
mcu_r5fss0_core1_dma_memory_region: r5f-dma-memory@a1000000 {
reg = <0x00 0xa1000000 0x00 0x100000>;
no-map;
mcu_r5fss0_core1_memory_region: r5f-memory@a1100000 {
reg = <0x00 0xa1100000 0x00 0xf00000>;
no-map;
main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a2000000 {
reg = <0x00 0xa2000000 0x00 0x100000>;
no-map;
main_r5fss0_core0_memory_region: r5f-memory@a2100000 {
reg = <0x00 0xa2100000 0x00 0xf00000>;
no-map;
main_r5fss0_core1_dma_memory_region: r5f-dma-memory@a3000000 {
reg = <0x00 0xa3000000 0x00 0x100000>;
no-map;
main_r5fss0_core1_memory_region: r5f-memory@a3100000 {
reg = <0x00 0xa3100000 0x00 0xf00000>;
no-map;
main_r5fss1_core0_dma_memory_region: r5f-dma-memory@a4000000 {
reg = <0x00 0xa4000000 0x00 0x100000>;
no-map;
main_r5fss1_core0_memory_region: r5f-memory@a4100000 {
reg = <0x00 0xa4100000 0x00 0xf00000>;
no-map;
main_r5fss1_core1_dma_memory_region: r5f-dma-memory@a5000000 {
reg = <0x00 0xa5000000 0x00 0x100000>;
no-map;
main_r5fss1_core1_memory_region: r5f-memory@a5100000 {
reg = <0x00 0xa5100000 0x00 0xf00000>;
no-map;
main_r5fss2_core0_dma_memory_region: r5f-dma-memory@a6000000 {
reg = <0x00 0xa6000000 0x00 0x100000>;
no-map;
main_r5fss2_core0_memory_region: r5f-memory@a6100000 {
reg = <0x00 0xa6100000 0x00 0xf00000>;
no-map;
main_r5fss2_core1_dma_memory_region: r5f-dma-memory@a7000000 {
reg = <0x00 0xa7000000 0x00 0x100000>;
no-map;
main_r5fss2_core1_memory_region: r5f-memory@a7100000 {
reg = <0x00 0xa7100000 0x00 0xf00000>;
no-map;
c71_0_dma_memory_region: c71-dma-memory@a8000000 {
reg = <0x00 0xa8000000 0x00 0x100000>;
no-map;
c71_0_memory_region: c71-memory@a8100000 {
reg = <0x00 0xa8100000 0x00 0xf00000>;
no-map;
c71_1_dma_memory_region: c71-dma-memory@a9000000 {
reg = <0x00 0xa9000000 0x00 0x100000>;
no-map;
c71_1_memory_region: c71-memory@a9100000 {
reg = <0x00 0xa9100000 0x00 0xf00000>;
no-map;
c71_2_dma_memory_region: c71-dma-memory@aa000000 {
reg = <0x00 0xaa000000 0x00 0x100000>;
no-map;
c71_2_memory_region: c71-memory@aa100000 {
reg = <0x00 0xaa100000 0x00 0xf00000>;
no-map;
c71_3_dma_memory_region: c71-dma-memory@ab000000 {
reg = <0x00 0xab000000 0x00 0x100000>;
no-map;
c71_3_memory_region: c71-memory@ab100000 {
reg = <0x00 0xab100000 0x00 0xf00000>;
no-map;
evm_12v0: regulator-evm12v0 {
/* main supply */
compatible = "regulator-fixed";
regulator-name = "evm_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-always-on;
regulator-boot-on;
vsys_3v3: regulator-vsys3v3 {
/* Output of LM5140 */
regulator-name = "vsys_3v3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&evm_12v0>;
regulator-boot-on;
vsys_5v0: regulator-vsys5v0 {
regulator-name = "vsys_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
vdd_mmc1: regulator-sd {
/* Output of TPS22918 */
regulator-name = "vdd_mmc1";
regulator-boot-on;
enable-active-high;
vin-supply = <&vsys_3v3>;
gpio = <&exp2 2 GPIO_ACTIVE_HIGH>;
vdd_sd_dv: regulator-TLV71033 {
/* Output of TLV71033 */
compatible = "regulator-gpio";
regulator-name = "tlv71033";
pinctrl-names = "default";
pinctrl-0 = <&vdd_sd_dv_pins_default>;
regulator-min-microvolt = <1800000>;
regulator-boot-on;
vin-supply = <&vsys_5v0>;
gpios = <&main_gpio0 8 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
dp0_pwr_3v3: regulator-dp0-prw {
regulator-name = "dp0-pwr";
gpio = <&exp4 0 GPIO_ACTIVE_HIGH>;
enable-active-high;
dp0: dp0-connector {
compatible = "dp-connector";
label = "DP0";
type = "full-size";
dp-pwr-supply = <&dp0_pwr_3v3>;
port {
dp0_connector_in: endpoint {
remote-endpoint = <&dp0_out>;
vsys_io_1v8: regulator-vsys-io-1v8 {
regulator-name = "vsys_io_1v8";
regulator-max-microvolt = <1800000>;
regulator-boot-on;
vsys_io_1v2: regulator-vsys-io-1v2 {
regulator-name = "vsys_io_1v2";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
regulator-boot-on;
edp1_refclk: clock-edp1-refclk {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <19200000>;
dp1_pwr_3v3: regulator-dp1-prw {
regulator-name = "dp1-pwr";
gpio = <&exp4 1 GPIO_ACTIVE_HIGH>; /* P1 - DP1_PWR_SW_EN */
enable-active-high;
transceiver1: can-phy0 {
compatible = "ti,tcan1042";
#phy-cells = <0>;
max-bitrate = <5000000>;
pinctrl-0 = <&mcu_mcan0_gpio_pins_default>;
standby-gpios = <&wkup_gpio0 69 GPIO_ACTIVE_HIGH>;
transceiver2: can-phy1 {
#phy-cells = <0>;
pinctrl-0 = <&mcu_mcan1_gpio_pins_default>;
standby-gpios = <&wkup_gpio0 2 GPIO_ACTIVE_HIGH>;
transceiver3: can-phy2 {
/* standby pin has been grounded by default */
#phy-cells = <0>;
codec_audio: sound {
compatible = "ti,j7200-cpb-audio";
model = "j784s4-cpb";
ti,cpb-mcasp = <&mcasp0>;
ti,cpb-codec = <&pcm3168a_1>;
clocks = <&k3_clks 265 0>, <&k3_clks 265 1>,
<&k3_clks 157 34>, <&k3_clks 157 63>;
clock-names = "cpb-mcasp-auxclk", "cpb-mcasp-auxclk-48000",
"cpb-codec-scki", "cpb-codec-scki-48000";
&wkup_pmx1 {
pmic_irq_pins_default: pmic-irq-pins-default {
pinctrl-single,pins = <
/* (G33) MCU_OSPI1_CSn1.WKUP_GPIO0_39 */
J784S4_WKUP_IOPAD(0x028, PIN_INPUT, 7)
mcu_fss0_ospi1_pins_default: mcu-fss0-ospi1-pins-default {
J784S4_WKUP_IOPAD(0x008, PIN_OUTPUT, 0) /* (F32) MCU_OSPI1_CLK */
J784S4_WKUP_IOPAD(0x024, PIN_OUTPUT, 0) /* (G32) MCU_OSPI1_CSn0 */
J784S4_WKUP_IOPAD(0x014, PIN_INPUT, 0) /* (E35) MCU_OSPI1_D0 */
J784S4_WKUP_IOPAD(0x018, PIN_INPUT, 0) /* (D31) MCU_OSPI1_D1 */
J784S4_WKUP_IOPAD(0x01C, PIN_INPUT, 0) /* (G31) MCU_OSPI1_D2 */
J784S4_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (F33) MCU_OSPI1_D3 */
J784S4_WKUP_IOPAD(0x010, PIN_INPUT, 0) /* (F31) MCU_OSPI1_DQS */
J784S4_WKUP_IOPAD(0x00C, PIN_INPUT, 0) /* (C31) MCU_OSPI1_LBCLKO */
mcu_fss0_ospi0_pins1_default: mcu-fss0-ospi0-pins1-default {
J784S4_WKUP_IOPAD(0x004, PIN_OUTPUT, 6) /* (C32) MCU_OSPI0_ECC_FAIL */
J784S4_WKUP_IOPAD(0x000, PIN_OUTPUT, 6) /* (B34) MCU_OSPI0_RESET_OUT0 */
&wkup_pmx2 {
status = "okay";
wkup_i2c0_pins_default: wkup_i2c0_pins_default {
J784S4_WKUP_IOPAD(0x098, PIN_INPUT, 0) /* (N33) WKUP_I2C0_SCL */
J784S4_WKUP_IOPAD(0x09C, PIN_INPUT, 0) /* (N35) WKUP_I2C0_SDA */
mcu_uart0_pins_default: mcu-uart0-pins-default {
J784S4_WKUP_IOPAD(0x090, PIN_INPUT, 0) /* (H37) MCU_UART0_CTSn */
J784S4_WKUP_IOPAD(0x094, PIN_OUTPUT, 0) /* (K37) MCU_UART0_RTSn */
J784S4_WKUP_IOPAD(0x08C, PIN_INPUT, 0) /* (K38) MCU_UART0_RXD */
J784S4_WKUP_IOPAD(0x088, PIN_OUTPUT, 0) /* (J37) MCU_UART0_TXD */
wkup_uart0_pins_default: wkup-uart0-pins-default {
J784S4_WKUP_IOPAD(0x048, PIN_INPUT, 0) /* (K35) WKUP_UART0_RXD */
J784S4_WKUP_IOPAD(0x04c, PIN_OUTPUT, 0) /* (K34) WKUP_UART0_TXD */
mcu_cpsw_pins_default: mcu-cpsw-pins-default {
J784S4_WKUP_IOPAD(0x02c, PIN_INPUT, 0) /* (A35) MCU_RGMII1_RD0 */
J784S4_WKUP_IOPAD(0x028, PIN_INPUT, 0) /* (B36) MCU_RGMII1_RD1 */
J784S4_WKUP_IOPAD(0x024, PIN_INPUT, 0) /* (C36) MCU_RGMII1_RD2 */
J784S4_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (D36) MCU_RGMII1_RD3 */
J784S4_WKUP_IOPAD(0x01c, PIN_INPUT, 0) /* (B37) MCU_RGMII1_RXC */
J784S4_WKUP_IOPAD(0x004, PIN_INPUT, 0) /* (C37) MCU_RGMII1_RX_CTL */
J784S4_WKUP_IOPAD(0x014, PIN_OUTPUT, 0) /* (D37) MCU_RGMII1_TD0 */
J784S4_WKUP_IOPAD(0x010, PIN_OUTPUT, 0) /* (D38) MCU_RGMII1_TD1 */
J784S4_WKUP_IOPAD(0x00c, PIN_OUTPUT, 0) /* (E37) MCU_RGMII1_TD2 */
J784S4_WKUP_IOPAD(0x008, PIN_OUTPUT, 0) /* (E38) MCU_RGMII1_TD3 */
J784S4_WKUP_IOPAD(0x018, PIN_OUTPUT, 0) /* (E36) MCU_RGMII1_TXC */
J784S4_WKUP_IOPAD(0x000, PIN_OUTPUT, 0) /* (C38) MCU_RGMII1_TX_CTL */
mcu_mdio_pins_default: mcu-mdio-pins-default {
J784S4_WKUP_IOPAD(0x034, PIN_OUTPUT, 0) /* (A36) MCU_MDIO0_MDC */
J784S4_WKUP_IOPAD(0x030, PIN_INPUT, 0) /* (B35) MCU_MDIO0_MDIO */
mcu_adc0_pins_default: mcu-adc0-pins-default {
J784S4_WKUP_IOPAD(0x0cc, PIN_INPUT, 0) /* (P36) MCU_ADC0_AIN0 */
J784S4_WKUP_IOPAD(0x0d0, PIN_INPUT, 0) /* (V36) MCU_ADC0_AIN1 */
J784S4_WKUP_IOPAD(0x0d4, PIN_INPUT, 0) /* (T34) MCU_ADC0_AIN2 */
J784S4_WKUP_IOPAD(0x0d8, PIN_INPUT, 0) /* (T36) MCU_ADC0_AIN3 */
J784S4_WKUP_IOPAD(0x0dc, PIN_INPUT, 0) /* (P34) MCU_ADC0_AIN4 */
J784S4_WKUP_IOPAD(0x0e0, PIN_INPUT, 0) /* (R37) MCU_ADC0_AIN5 */
J784S4_WKUP_IOPAD(0x0e4, PIN_INPUT, 0) /* (R33) MCU_ADC0_AIN6 */
J784S4_WKUP_IOPAD(0x0e8, PIN_INPUT, 0) /* (V38) MCU_ADC0_AIN7 */
mcu_adc1_pins_default: mcu-adc1-pins-default {
J784S4_WKUP_IOPAD(0x0ec, PIN_INPUT, 0) /* (Y38) MCU_ADC1_AIN0 */
J784S4_WKUP_IOPAD(0x0f0, PIN_INPUT, 0) /* (Y34) MCU_ADC1_AIN1 */
J784S4_WKUP_IOPAD(0x0f4, PIN_INPUT, 0) /* (V34) MCU_ADC1_AIN2 */
J784S4_WKUP_IOPAD(0x0f8, PIN_INPUT, 0) /* (W37) MCU_ADC1_AIN3 */
J784S4_WKUP_IOPAD(0x0fc, PIN_INPUT, 0) /* (AA37) MCU_ADC1_AIN4 */
J784S4_WKUP_IOPAD(0x100, PIN_INPUT, 0) /* (W33) MCU_ADC1_AIN5 */
J784S4_WKUP_IOPAD(0x104, PIN_INPUT, 0) /* (U33) MCU_ADC1_AIN6 */
J784S4_WKUP_IOPAD(0x108, PIN_INPUT, 0) /* (Y36) MCU_ADC1_AIN7 */
&wkup_gpio0 {
status = "okay";
&wkup_gpio_intr {
status = "okay";
&wkup_i2c0 {
status = "okay";
pinctrl-0 = <&wkup_i2c0_pins_default>;
clock-frequency = <400000>;
tps659413: pmic@48 {
compatible = "ti,tps6594-q1";
reg = <0x48>;
system-power-controller;
pinctrl-0 = <&pmic_irq_pins_default>;
interrupt-parent = <&wkup_gpio0>;
interrupts = <39 IRQ_TYPE_EDGE_FALLING>;
ti,primary-pmic;
gpio-controller;
#gpio-cells = <2>;
buck12-supply = <&vsys_3v3>;
buck3-supply = <&vsys_3v3>;
buck4-supply = <&vsys_3v3>;
buck5-supply = <&vsys_3v3>;
ldo1-supply = <&vsys_3v3>;
ldo2-supply = <&vsys_3v3>;
ldo3-supply = <&vsys_3v3>;
ldo4-supply = <&vsys_3v3>;
regulators {
bucka12: buck12 {
regulator-name = "vdd_ddr_1v1";
regulator-min-microvolt = <1100000>;
regulator-max-microvolt = <1100000>;
regulator-boot-on;
bucka3: buck3 {
regulator-name = "vdd_ram_0v85";
regulator-min-microvolt = <850000>;
regulator-max-microvolt = <850000>;
regulator-boot-on;
bucka4: buck4 {
regulator-name = "vdd_io_1v8";
regulator-boot-on;
bucka5: buck5 {
regulator-name = "vdd_mcu_0v85";
regulator-boot-on;
ldoa1: ldo1 {
regulator-name = "vdd_mcuio_1v8";
regulator-boot-on;
ldoa2: ldo2 {
regulator-name = "vdd_mcuio_3v3";
regulator-boot-on;
ldoa3: ldo3 {
regulator-name = "vds_dll_0v8";
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <800000>;
regulator-boot-on;
ldoa4: ldo4 {
regulator-name = "vda_mcu_1v8";
regulator-boot-on;
&main_pmx0 {
main_cpsw2g_pins_default: main-cpsw2g-pins-default {
J784S4_IOPAD(0x0b8, PIN_INPUT, 6) /* (AC34) MCASP1_ACLKX.RGMII1_RD0 */
J784S4_IOPAD(0x0a0, PIN_INPUT, 6) /* (AD34) MCASP0_AXR12.RGMII1_RD1 */
J784S4_IOPAD(0x0a4, PIN_INPUT, 6) /* (AJ36) MCASP0_AXR13.RGMII1_RD2 */
J784S4_IOPAD(0x0a8, PIN_INPUT, 6) /* (AF34) MCASP0_AXR14.RGMII1_RD3 */
J784S4_IOPAD(0x0b0, PIN_INPUT, 6) /* (AL33) MCASP1_AXR3.RGMII1_RXC */
J784S4_IOPAD(0x0ac, PIN_INPUT, 6) /* (AE34) MCASP0_AXR15.RGMII1_RX_CTL */
J784S4_IOPAD(0x08c, PIN_INPUT, 6) /* (AE35) MCASP0_AXR7.RGMII1_TD0 */
J784S4_IOPAD(0x090, PIN_INPUT, 6) /* (AC35) MCASP0_AXR8.RGMII1_TD1 */
J784S4_IOPAD(0x094, PIN_INPUT, 6) /* (AG35) MCASP0_AXR9.RGMII1_TD2 */
J784S4_IOPAD(0x098, PIN_INPUT, 6) /* (AH36) MCASP0_AXR10.RGMII1_TD3 */
J784S4_IOPAD(0x0b4, PIN_INPUT, 6) /* (AL34) MCASP1_AXR4.RGMII1_TXC */
J784S4_IOPAD(0x09c, PIN_INPUT, 6) /* (AF35) MCASP0_AXR11.RGMII1_TX_CTL */
main_cpsw2g_mdio_pins_default: main-cpsw2g-mdio-pins-default {
J784S4_IOPAD(0x0c0, PIN_INPUT, 6) /* (AD38) MCASP1_AXR0.MDIO0_MDC */
J784S4_IOPAD(0x0bc, PIN_INPUT, 6) /* (AD33) MCASP1_AFSX.MDIO0_MDIO */
main_uart8_pins_default: main-uart8-pins-default {
J784S4_IOPAD(0x040, PIN_INPUT, 14) /* (AF37) MCASP0_AXR0.UART8_CTSn */
J784S4_IOPAD(0x044, PIN_OUTPUT, 14) /* (AG37) MCASP0_AXR1.UART8_RTSn */
J784S4_IOPAD(0x0d0, PIN_INPUT, 11) /* (AP38) SPI0_CS1.UART8_RXD */
J784S4_IOPAD(0x0d4, PIN_OUTPUT, 11) /* (AN38) SPI0_CLK.UART8_TXD */
main_i2c0_pins_default: main-i2c0-pins-default {
J784S4_IOPAD(0x0e0, PIN_INPUT_PULLUP, 0) /* (AN36) I2C0_SCL */
J784S4_IOPAD(0x0e4, PIN_INPUT_PULLUP, 0) /* (AP37) I2C0_SDA */
main_i2c5_pins_default: main-i2c5-pins-default {
J784S4_IOPAD(0x01c, PIN_INPUT, 8) /* (AG34) MCAN15_TX.I2C5_SCL */
J784S4_IOPAD(0x018, PIN_INPUT, 8) /* (AK36) MCAN14_RX.I2C5_SDA */
main_mmc1_pins_default: main-mmc1-pins-default {
J784S4_IOPAD(0x104, PIN_INPUT, 0) /* (AB38) MMC1_CLK */
J784S4_IOPAD(0x108, PIN_INPUT, 0) /* (AB36) MMC1_CMD */
J784S4_IOPAD(0x100, PIN_INPUT, 0) /* (No Pin) MMC1_CLKLB */
J784S4_IOPAD(0x0fc, PIN_INPUT, 0) /* (AA33) MMC1_DAT0 */
J784S4_IOPAD(0x0f8, PIN_INPUT, 0) /* (AB34) MMC1_DAT1 */
J784S4_IOPAD(0x0f4, PIN_INPUT, 0) /* (AA32) MMC1_DAT2 */
J784S4_IOPAD(0x0f0, PIN_INPUT, 0) /* (AC38) MMC1_DAT3 */
J784S4_IOPAD(0x0e8, PIN_INPUT, 8) /* (AR38) TIMER_IO0.MMC1_SDCD */
vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
J784S4_IOPAD(0x020, PIN_INPUT, 7) /* (AJ35) MCAN15_RX.GPIO0_8 */
dp0_pins_default: dp0-pins-default {
J784S4_IOPAD(0x0cc, PIN_INPUT, 12) /* (AM37) SPI0_CS0.DP0_HPD */
main_i2c4_pins_default: main-i2c4-pins-default {
J784S4_IOPAD(0x014, PIN_INPUT_PULLUP, 8) /* (AG33) MCAN14_TX.I2C4_SCL */
J784S4_IOPAD(0x010, PIN_INPUT_PULLUP, 8) /* (AH33) MCAN13_RX.I2C4_SDA */
main_usbss0_pins_default: main-usbss0-pins-default {
J784S4_IOPAD(0x0ec, PIN_OUTPUT, 6) /* (AN37) TIMER_IO1.USB0_DRVVBUS */
main_mcan16_pins_default: main-mcan16-default-pins {
J784S4_IOPAD(0x028, PIN_INPUT, 0) /* (AE33) MCAN16_RX */
J784S4_IOPAD(0x024, PIN_OUTPUT, 0) /* (AH34) MCAN16_TX */
main_i2c3_pins_default: main-i2c3-default-pins {
J784S4_IOPAD(0x064, PIN_INPUT, 13) /* (AF38) MCAN0_TX.I2C3_SCL */
J784S4_IOPAD(0x060, PIN_INPUT, 13) /* (AE36) MCASP2_AXR1.I2C3_SDA */
mcasp0_pins_default: mcasp0-default-pins {
J784S4_IOPAD(0x038, PIN_OUTPUT_PULLDOWN, 1) /* (AK35) MCASP0_ACLKX */
J784S4_IOPAD(0x03c, PIN_OUTPUT_PULLDOWN, 1) /* (AK38) MCASP0_AFSX */
J784S4_IOPAD(0x07c, PIN_OUTPUT_PULLDOWN, 1) /* (AJ38) MCASP0_AXR3 */
J784S4_IOPAD(0x080, PIN_INPUT_PULLDOWN, 1) /* (AK34) MCASP0_AXR4 */
audio_ext_refclk1_pins_default: audio-ext-refclk1-default-pins {
J784S4_IOPAD(0x078, PIN_OUTPUT, 1) /* (AH37) MCAN2_RX.AUDIO_EXT_REFCLK1 */
&wkup_pmx0 {
typec_dir_gpio_pins_default: typec-dir-gpio-pins-default {
/* (A33) MCU_OSPI0_CSn1.WKUP_GPIO0_28 */
J784S4_WKUP_IOPAD(0x030, PIN_INPUT, 7)
mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-pins-default {
J784S4_WKUP_IOPAD(0x000, PIN_OUTPUT, 0) /* (E32) MCU_OSPI0_CLK */
J784S4_WKUP_IOPAD(0x02c, PIN_OUTPUT, 0) /* (A32) MCU_OSPI0_CSn0 */
J784S4_WKUP_IOPAD(0x00c, PIN_INPUT, 0) /* (B33) MCU_OSPI0_D0 */
J784S4_WKUP_IOPAD(0x010, PIN_INPUT, 0) /* (B32) MCU_OSPI0_D1 */
J784S4_WKUP_IOPAD(0x014, PIN_INPUT, 0) /* (C33) MCU_OSPI0_D2 */
J784S4_WKUP_IOPAD(0x018, PIN_INPUT, 0) /* (C35) MCU_OSPI0_D3 */
J784S4_WKUP_IOPAD(0x01c, PIN_INPUT, 0) /* (D33) MCU_OSPI0_D4 */
J784S4_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (D34) MCU_OSPI0_D5 */
J784S4_WKUP_IOPAD(0x024, PIN_INPUT, 0) /* (E34) MCU_OSPI0_D6 */
J784S4_WKUP_IOPAD(0x028, PIN_INPUT, 0) /* (E33) MCU_OSPI0_D7 */
J784S4_WKUP_IOPAD(0x008, PIN_INPUT, 0) /* (C34) MCU_OSPI0_DQS */
&wkup_pmx2{
mcu_mcan0_pins_default: mcu-mcan0-default-pins {
J784S4_WKUP_IOPAD(0x050, PIN_OUTPUT, 0) /* (K33) MCU_MCAN0_TX */
J784S4_WKUP_IOPAD(0x054, PIN_INPUT, 0) /* (F38) MCU_MCAN0_RX */
mcu_mcan1_pins_default: mcu-mcan1-default-pins {
J784S4_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /* (H35) WKUP_GPIO0_4.MCU_MCAN1_TX */
J784S4_WKUP_IOPAD(0x06c, PIN_INPUT, 0) /* (K36) WKUP_GPIO0_5.MCU_MCAN1_RX */
mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-default-pins {
J784S4_WKUP_IOPAD(0x040, PIN_INPUT, 7) /* (J38) MCU_SPI0_D1.WKUP_GPIO0_69 */
mcu_mcan1_gpio_pins_default: mcu-mcan1-gpio-default-pins {
J784S4_WKUP_IOPAD(0x060, PIN_INPUT, 7) /* (J35) WKUP_GPIO0_2 */
&main_uart8 {
status = "okay";
pinctrl-0 = <&main_uart8_pins_default>;
&ufs_wrapper {
status = "okay";
&fss {
status = "okay";
&ospi0 {
status = "okay";
pinctrl-0 = <&mcu_fss0_ospi0_pins_default>;
ospi0_nor: flash@0 {
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-tx-bus-width = <8>;
spi-rx-bus-width = <8>;
spi-max-frequency = <25000000>;
cdns,tshsl-ns = <60>;
cdns,tsd2d-ns = <60>;
cdns,tchsh-ns = <60>;
cdns,tslch-ns = <60>;
cdns,read-delay = <4>;
partitions {
compatible = "fixed-partitions";
#address-cells = <1>;
#size-cells = <1>;
partition@0 {
label = "ospi.tiboot3";
reg = <0x0 0x100000>;
partition@100000 {
label = "ospi.tispl";
reg = <0x100000 0x200000>;
partition@300000 {
label = "ospi.u-boot";
reg = <0x300000 0x400000>;
partition@700000 {
label = "ospi.env";
reg = <0x700000 0x40000>;
partition@740000 {
label = "ospi.env.backup";
reg = <0x740000 0x40000>;
partition@800000 {
label = "ospi.rootfs";
reg = <0x800000 0x37c0000>;
partition@3fc0000 {
label = "ospi.phypattern";
reg = <0x3fc0000 0x40000>;
ospi0_nand: nand@0 {
compatible = "spi-nand";
reg = <0x0>;
cdns,read-delay = <2>;
#size-cells = <1>;
status = "disabled";
partitions {
#size-cells = <1>;
partition@0 {
label = "ospi_nand.tiboot3";
partition@100000 {
label = "ospi_nand.tispl";
partition@300000 {
label = "ospi_nand.u-boot";
partition@700000 {
label = "ospi_nand.env";
partition@740000 {
label = "ospi_nand.env.backup";
partition@2000000 {
label = "ospi_nand.rootfs";
reg = <0x2000000 0x5fc0000>;
partition@7fc0000 {
label = "ospi_nand.phypattern";
reg = <0x7fc0000 0x40000>;
&ospi1 {
status = "okay";
pinctrl-0 = <&mcu_fss0_ospi1_pins_default>;
flash@0{
reg = <0x0>;
spi-tx-bus-width = <1>;
spi-rx-bus-width = <4>;
spi-max-frequency = <40000000>;
partitions {
#size-cells = <1>;
partition@0 {
label = "qspi.tiboot3";
partition@100000 {
label = "qspi.tispl";
partition@300000 {
label = "qspi.u-boot";
partition@700000 {
label = "qspi.env";
partition@740000 {
label = "qspi.env.backup";
partition@800000 {
label = "qspi.rootfs";
partition@3fc0000 {
label = "qspi.phypattern";
&main_i2c0 {
status = "okay";
pinctrl-0 = <&main_i2c0_pins_default>;
exp1: gpio@20 {
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "PCIE1_2L_MODE_SEL", "PCIE1_4L_PERSTZ", "PCIE1_2L_RC_RSTZ",
"PCIE1_2L_EP_RST_EN", "PCIE0_4L_MODE_SEL", "PCIE0_4L_PERSTZ",
"PCIE0_4L_RC_RSTZ", "PCIE0_4L_EP_RST_EN", "PCIE1_4L_PRSNT#",
"PCIE0_4L_PRSNT#", "CDCI1_OE1/OE4", "CDCI1_OE2/OE3",
"AUDIO_MUX_SEL", "EXP_MUX2", "EXP_MUX3", "GESI_EXP_PHY_RSTZ";
p12-hog {
/* P12 - AUDIO_MUX_SEL */
gpio-hog;
gpios = <12 GPIO_ACTIVE_HIGH>;
output-low;
line-name = "AUDIO_MUX_SEL";
exp2: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "R_GPIO_RGMII1_RST", "ENET2_I2CMUX_SEL", "GPIO_USD_PWR_EN",
"USBC_PWR_EN", "USBC_MODE_SEL1", "USBC_MODE_SEL0",
"GPIO_LIN_EN", "R_CAN_STB", "CTRL_PM_I2C_OE#",
"ENET2_EXP_PWRDN", "ENET2_EXP_SPARE2", "CDCI2_RSTZ",
"USB2.0_MUX_SEL", "CANUART_MUX_SEL0", "CANUART_MUX2_SEL1",
"CANUART_MUX1_SEL1", "ENET1_EXP_PWRDN", "ENET1_EXP_RESETZ",
"ENET1_I2CMUX_SEL", "ENET1_EXP_SPARE2", "ENET2_EXP_RESETZ",
"USER_INPUT1", "USER_LED1", "USER_LED2";
p13-hog {
/* P13 - CANUART_MUX_SEL0 */
gpio-hog;
gpios = <13 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "CANUART_MUX_SEL0";
p15-hog {
/* P15 - CANUART_MUX1_SEL1 */
gpio-hog;
gpios = <15 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "CANUART_MUX1_SEL1";
&main_sdhci0 {
/* eMMC */
status = "okay";
non-removable;
ti,driver-strength-ohm = <50>;
disable-wp;
no-mmc-hs400;
&main_sdhci1 {
/* SD card */
status = "okay";
pinctrl-0 = <&main_mmc1_pins_default>;
disable-wp;
vmmc-supply = <&vdd_mmc1>;
vqmmc-supply = <&vdd_sd_dv>;
&serdes0 {
status = "okay";
serdes0_pcie_link: phy@0 {
reg = <0>;
cdns,num-lanes = <2>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_PCIE>;
resets = <&serdes_wiz0 1>, <&serdes_wiz0 2>;
serdes0_usb_link: phy@3 {
reg = <3>;
cdns,num-lanes = <1>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_USB3>;
resets = <&serdes_wiz0 4>;
&serdes_wiz0 {
status = "okay";
&usb_serdes_mux {
idle-states = <0>; /* USB0 to SERDES lane 3 */
&usbss0 {
status = "okay";
pinctrl-0 = <&main_usbss0_pins_default>;
ti,vbus-divider;
&usb0 {
dr_mode = "otg";
maximum-speed = "super-speed";
phys = <&serdes0_usb_link>;
phy-names = "cdns3,usb3-phy";
&serdes1 {
status = "okay";
serdes1_pcie_link: phy@0 {
reg = <0>;
#phy-cells = <0>;
resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>;
&serdes_wiz1 {
status = "okay";
&pcie0_rc {
status = "okay";
reset-gpios = <&exp1 6 GPIO_ACTIVE_HIGH>;
phys = <&serdes1_pcie_link>;
phy-names = "pcie-phy";
&pcie0_ep {
&pcie1_rc {
status = "okay";
num-lanes = <2>;
reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
phys = <&serdes0_pcie_link>;
&pcie1_ep {
num-lanes = <2>;
&serdes_ln_ctrl {
idle-states = <J784S4_SERDES0_LANE0_PCIE1_LANE0>, <J784S4_SERDES0_LANE1_PCIE1_LANE1>,
<J784S4_SERDES0_LANE2_IP3_UNUSED>, <J784S4_SERDES0_LANE3_USB>,
<J784S4_SERDES1_LANE0_PCIE0_LANE0>, <J784S4_SERDES1_LANE1_PCIE0_LANE1>,
<J784S4_SERDES1_LANE2_PCIE0_LANE2>, <J784S4_SERDES1_LANE3_PCIE0_LANE3>,
<J784S4_SERDES2_LANE2_QSGMII_LANE1>, <J784S4_SERDES2_LANE3_QSGMII_LANE2>;
&main_gpio0 {
status = "okay";
&mcu_cpsw {
status = "okay";
pinctrl-0 = <&mcu_cpsw_pins_default>;
cpts@3d000 {
/* Map HW4_TS_PUSH to GENF1 */
ti,pps = <3 1>;
&davinci_mdio {
pinctrl-0 = <&mcu_mdio_pins_default>;
mcu_phy0: ethernet-phy@0 {
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,min-output-impedance;
&mcu_cpsw_port1 {
status = "okay";
phy-mode = "rgmii-rxid";
phy-handle = <&mcu_phy0>;
&main_cpsw1 {
status = "okay";
pinctrl-0 = <&main_cpsw2g_pins_default>;
&main_cpsw1_mdio {
pinctrl-0 = <&main_cpsw2g_mdio_pins_default>;
main_phy0: ethernet-phy@0 {
reg = <0>;
&main_cpsw1_port1 {
status = "okay";
phy-handle = <&main_phy0>;
&serdes_refclk {
clock-frequency = <100000000>;
&dss {
status = "okay";
assigned-clocks = <&k3_clks 218 2>,
<&k3_clks 218 5>,
<&k3_clks 218 14>,
<&k3_clks 218 18>;
assigned-clock-parents = <&k3_clks 218 3>,
<&k3_clks 218 7>,
<&k3_clks 218 16>,
<&k3_clks 218 22>;
&serdes_wiz4 {
status = "okay";
&serdes4 {
status = "okay";
serdes4_dp_link: phy@0 {
reg = <0>;
cdns,num-lanes = <4>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_DP>;
cdns,max-bit-rate = <2700>;
resets = <&serdes_wiz4 1>, <&serdes_wiz4 2>,
<&serdes_wiz4 3>, <&serdes_wiz4 4>;
&mhdp {
status = "okay";
pinctrl-0 = <&dp0_pins_default>;
phys = <&serdes4_dp_link>;
phy-names = "dpphy";
&dss_ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dpi0_out: endpoint {
remote-endpoint = <&dp0_in>;
port@2 {
reg = <2>;
dpi2_out: endpoint {
remote-endpoint = <&dsi0_in>;
&main_i2c4 {
status = "okay";
pinctrl-0 = <&main_i2c4_pins_default>;
exp4: gpio@20 {
compatible = "ti,tca6408";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
dsi_edp_bridge: dsi-edp-bridge@2c {
compatible = "ti,sn65dsi86";
reg = <0x2c>;
clock-names = "refclk";
clocks = <&edp1_refclk>;
enable-gpios = <&exp4 2 GPIO_ACTIVE_HIGH>;
vpll-supply = <&vsys_io_1v8>;
vccio-supply = <&vsys_io_1v8>;
vcca-supply = <&vsys_io_1v2>;
vcc-supply = <&vsys_io_1v2>;
dsi_edp_bridge_ports: ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dp1_in: endpoint {
remote-endpoint = <&dsi0_out>;
port@1 {
reg = <1>;
dp1_out: endpoint {
remote-endpoint = <&dp1_panel_in>;
aux-bus {
panel {
compatible = "ti,panel-edp";
power-supply = <&dp1_pwr_3v3>;
port {
dp1_panel_in: endpoint {
remote-endpoint = <&dp1_out>;
&dsi0_ports {
port@0 {
reg = <0>;
dsi0_out: endpoint {
remote-endpoint = <&dp1_in>;
port@1 {
reg = <1>;
dsi0_in: endpoint {
remote-endpoint = <&dpi2_out>;
&main_i2c5 {
status = "okay";
pinctrl-0 = <&main_i2c5_pins_default>;
exp5: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
&mailbox0_cluster0 {
status = "okay";
interrupts = <436>;
mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 {
ti,mbox-rx = <2 0 0>;
ti,mbox-tx = <3 0 0>;
&mailbox0_cluster1 {
status = "okay";
interrupts = <432>;
mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 {
mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 {
&mailbox0_cluster2 {
status = "okay";
interrupts = <428>;
mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 {
mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 {
&mailbox0_cluster3 {
status = "okay";
interrupts = <424>;
mbox_main_r5fss2_core0: mbox-main-r5fss2-core0 {
mbox_main_r5fss2_core1: mbox-main-r5fss2-core1 {
&mailbox0_cluster4 {
status = "okay";
interrupts = <420>;
mbox_c71_0: mbox-c71-0 {
mbox_c71_1: mbox-c71-1 {
&mailbox0_cluster5 {
status = "okay";
interrupts = <416>;
mbox_c71_2: mbox-c71-2 {
mbox_c71_3: mbox-c71-3 {
&mcu_r5fss0_core0 {
status = "okay";
mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>;
memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
<&mcu_r5fss0_core0_memory_region>;
&mcu_r5fss0_core1 {
status = "okay";
mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>;
memory-region = <&mcu_r5fss0_core1_dma_memory_region>,
<&mcu_r5fss0_core1_memory_region>;
&main_r5fss0_core0 {
status = "okay";
mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>;
memory-region = <&main_r5fss0_core0_dma_memory_region>,
<&main_r5fss0_core0_memory_region>;
&main_r5fss0_core1 {
status = "okay";
mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>;
memory-region = <&main_r5fss0_core1_dma_memory_region>,
<&main_r5fss0_core1_memory_region>;
&main_r5fss1_core0 {
status = "okay";
mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core0>;
memory-region = <&main_r5fss1_core0_dma_memory_region>,
<&main_r5fss1_core0_memory_region>;
&main_r5fss1_core1 {
status = "okay";
mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core1>;
memory-region = <&main_r5fss1_core1_dma_memory_region>,
<&main_r5fss1_core1_memory_region>;
&main_r5fss2_core0 {
status = "okay";
mboxes = <&mailbox0_cluster3 &mbox_main_r5fss2_core0>;
memory-region = <&main_r5fss2_core0_dma_memory_region>,
<&main_r5fss2_core0_memory_region>;
&main_r5fss2_core1 {
status = "okay";
mboxes = <&mailbox0_cluster3 &mbox_main_r5fss2_core1>;
memory-region = <&main_r5fss2_core1_dma_memory_region>,
<&main_r5fss2_core1_memory_region>;
&c71_0 {
status = "okay";
mboxes = <&mailbox0_cluster4 &mbox_c71_0>;
memory-region = <&c71_0_dma_memory_region>,
<&c71_0_memory_region>;
&c71_1 {
status = "okay";
mboxes = <&mailbox0_cluster4 &mbox_c71_1>;
memory-region = <&c71_1_dma_memory_region>,
<&c71_1_memory_region>;
&c71_2 {
status = "okay";
mboxes = <&mailbox0_cluster5 &mbox_c71_2>;
memory-region = <&c71_2_dma_memory_region>,
<&c71_2_memory_region>;
&c71_3 {
status = "okay";
mboxes = <&mailbox0_cluster5 &mbox_c71_3>;
memory-region = <&c71_3_dma_memory_region>,
<&c71_3_memory_region>;
&dp0_ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dp0_in: endpoint {
remote-endpoint = <&dpi0_out>;
port@4 {
reg = <4>;
dp0_out: endpoint {
remote-endpoint = <&dp0_connector_in>;
&ti_csi2rx0 {
status = "okay";
/* MIPI-CSI Connector 0 */
&ti_csi2rx1 {
status = "okay";
&ti_csi2rx2 {
status = "okay";
/* MIPI-CSI Connector 1 */
&dphy_rx0 {
status = "okay";
&dphy_rx1 {
status = "okay";
&dphy_rx2 {
status = "okay";
&tscadc0 {
pinctrl-0 = <&mcu_adc0_pins_default>;
status = "okay";
adc {
ti,adc-channels = <0 1 2 3 4 5 6 7>;
&tscadc1 {
pinctrl-0 = <&mcu_adc1_pins_default>;
status = "okay";
adc {
&dphy_tx0 {
status = "okay";
&dsi0 {
status = "okay";
#define K3_TS_OFFSET(pa, val) (0x4+(pa)*4) (0x10000 | val)
×ync_router {
status = "okay";
pinctrl-0 = <&mcu_cpsw_cpts>;
/* Use Time Sync Router to map GENF1 input to HW4_TS_PUSH output */
mcu_cpsw_cpts: mcu-cpsw-cpts {
/* pps [mcu cpsw cpts genf1] in17 -> out25 [mcu cpsw cpts hw4_push] */
K3_TS_OFFSET(25, 17)
&wkup_uart0 {
status = "reserved";
pinctrl-0 = <&wkup_uart0_pins_default>;
&mcu_uart0 {
status = "okay";
pinctrl-0 = <&mcu_uart0_pins_default>;
&mcu_mcan0 {
status = "okay";
pinctrl-0 = <&mcu_mcan0_pins_default>;
phys = <&transceiver1>;
&mcu_mcan1 {
status = "okay";
pinctrl-0 = <&mcu_mcan1_pins_default>;
phys = <&transceiver2>;
&main_mcan16 {
status = "okay";
pinctrl-0 = <&main_mcan16_pins_default>;
phys = <&transceiver3>;
&k3_clks {
/* Confiure AUDIO_EXT_REFCLK2 pin as output */
pinctrl-0 = <&audio_ext_refclk1_pins_default>;
&main_i2c3 {
status = "okay";
pinctrl-0 = <&main_i2c3_pins_default>;
exp3: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
pcm3168a_1: audio-codec@44 {
compatible = "ti,pcm3168a";
reg = <0x44>;
#sound-dai-cells = <1>;
reset-gpios = <&exp3 0 GPIO_ACTIVE_LOW>;
/* C_AUDIO_REFCLK2 -> RGMII6_RXC (W26) */
clocks = <&audio_refclk1>;
clock-names = "scki";
VDD1-supply = <&vsys_3v3>;
VDD2-supply = <&vsys_3v3>;
VCCAD1-supply = <&vsys_5v0>;
VCCAD2-supply = <&vsys_5v0>;
VCCDA1-supply = <&vsys_5v0>;
VCCDA2-supply = <&vsys_5v0>;
&mcasp0 {
status = "okay";
#sound-dai-cells = <0>;
pinctrl-0 = <&mcasp0_pins_default>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
auxclk-fs-ratio = <256>;
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
0 0 0 1
2 0 0 0
0 0 0 0
0 0 0 0
tx-num-evt = <0>;
rx-num-evt = <0>;
But the AUDIO still doesn't work, and the error message is as follows.
root@j784s4-evm:/mnt# ./tinyplay -D 0 -d 0 sample-1.wav
[ 28.160725] pcm3168a 2-0044: Unable to sync register 0x42. -121
[ 28.166728] pcm3168a 2-0044: Failed to sync regmap: -121
[ 28.172202] pcm3168a 2-0044: ASoC: error at snd_soc_pcm_component_pm_runtime_get on pcm3168a.2-0044: -121
[ 28.181788] CPB PCM3168A Playback: ASoC: error at __soc_pcm_open on CPB PCM3168A Playback: -121
failed to open for pcm 0,0. cannot open device (0) for card (0): Remote I/O error
Apart from the DTS - related modifications, are there any other codes that need to be incorporated?
yongxu
