SK-AM62A-LP: ESM Error(interrupt ) Mapping
Part Number: SK-AM62A-LP
Other Parts Discussed in Thread: SK-AM62P-LP, AM62P
Hello Expert,
Board :SK-AM62P-LP
OS :Processor SDK LINUX RT AM62P Debian Trixie -Version: 10.00.07.04
MCU+SDK :Version: 10.00.07.04
Above are my specifications, i am running the dcc example code which  is available in the mcu+sdk.
In the  TRM ,the total no.of possible error events are 1024 and these are classified as a 32 groups
And below is the events mapping to the ESM(Main) & WKUP_ESM
SDL_ESM_config DCC_Test_esmInitConfig_Inst =
     /**< All high priority events to error pin */
        .esmErrorConfig = {1u, 8u}, /* Self test error config */
    .enableBitmap = {0x00000000u, 0x00000006bu, 0x00000000u, 0x00003000u,
                 0x00000000u, 0x00000380u,
     /**< All events enable: except clkstop events for unused clocks
      *   and PCIE events */
    .priorityBitmap = {0x00000000u, 0x00000006bu, 0x0000000u, 0x00003000u,
    /**< All events high priority: except clkstop events for unused clocks
    .errorpinBitmap = {0x00000000u, 0x00000006bu, 0x00000000u, 0x00003000u,
    /**< All events high priority: except clkstop for unused clocks
SDL_ESM_config DCC_Test_esmInitConfig_Main =
    .enableBitmap = {0x00000000u, 0x000000078u, 0x00008000u,0x003f3000u,
    .priorityBitmap = {0x00000000u, 0x000000078u, 0x00008000u,0x003f3000u,
    .errorpinBitmap = {0x00000000u, 0x000000078u, 0x00008000u,0x003f3000u,
As per my understanding , above values are mapped as  a bits ,ex:
enableBitmap[0] is represents the error enable of 0 to 31 events ,
enableBitmap[1] is for 32 to 63 like that  (correct me if am wrong ) w.r t esm module.
Inside Esm_init () we are getting the Maximum error events for each Esm module .where EMS0(main) =249 ,WKUP_Max_events =92;
But if you see in the above code snippet you are registering more than 92 error events for wakup_esm. How it is possible  to register?
And in the above code snippet,you are enabling the ECC ,some other error events also,is it required to enable  those error events ?
Can you tell us how to map these ESM error events ?
Thank you.
